[MOAB-dev] r3181 - MOAB/trunk
    kraftche at cae.wisc.edu
    Wed Sep 30 16:47:32 CDT 2009
Author: kraftche
Date: 2009-09-30 16:47:32 -0500 (Wed, 30 Sep 2009)
New Revision: 3181
Added:
   MOAB/trunk/stl_test.cc
Modified:
   MOAB/trunk/Makefile.am
Log:
add a few regresstion tests for STL file I/O
Modified: MOAB/trunk/Makefile.am
--- MOAB/trunk/Makefile.am	2009-09-30 21:47:12 UTC (rev 3180)
+++ MOAB/trunk/Makefile.am	2009-09-30 21:47:32 UTC (rev 3181)
@@ -40,6 +40,7 @@
 	cub_file_test \
 	exodus_test \
         gmsh_test \
+        stl_test \
         mbcn_test \
         bsp_tree_poly_test
 #                 merge_test \         # input files no longer exist?
@@ -373,6 +374,9 @@
 gmsh_test_SOURCES = TestUtil.hpp gmsh_test.cc
 gmsh_test_DEPENDENCIES = $(tag_test_LDADD)
+stl_test_SOURCES = TestUtil.hpp stl_test.cc
+stl_test_DEPENDENCIES = $(tag_test_LDADD)
 mbcn_test_SOURCES = MBCN.hpp MBCN.cpp mbcn_test.cc
 mbcn_test_CPPFLAGS = -DSRCDIR=$(srcdir)  # define anything to work around build issue
 mbcn_test_LDADD =
Added: MOAB/trunk/stl_test.cc
--- MOAB/trunk/stl_test.cc	                        (rev 0)
+++ MOAB/trunk/stl_test.cc	2009-09-30 21:47:32 UTC (rev 3181)
@@ -0,0 +1,264 @@
+#include "TestUtil.hpp"
+#include "MBCore.hpp"
+#include "ReadSTL.hpp"
+#include "WriteSTL.hpp"
+#include "FileOptions.hpp"
+#include "MBRange.hpp"
+#include <math.h>
+#include <algorithm>
+/* Input test file: gmsh2.msh
+ * Example version 2.0 ASCII input file from Gmsh 2.4 manual.
+#ifdef SRCDIR
+static const char sample[] = STRINGIFY(SRCDIR) "/test/sample.stl";
+#else
+static const char sample[] = "test/sample.stl";
+#endif
+const char* tmp_file = "test.stl";
+void test_read_ascii();
+void test_write_ascii();
+void test_type_option();
+void test_detect_type();
+void test_endian_option();
+void test_big_endian();
+void test_little_endian();
+void test_detect_byte_order();
+void read_file( MBInterface& moab,
+                const char* input_file,
+                const char* options = "" );
+void convert_file( const char* source_file,
+                   const char* dest_file,
+// check that the mesh constains the simple tetrahedron defined
+// in test/sample.stl
+void check_mesh_is_tet( MBInterface& moab );
+int main()
+  int result = 0;
+  result += RUN_TEST(test_read_ascii);
+  result += RUN_TEST(test_write_ascii);
+  result += RUN_TEST(test_type_option);
+  result += RUN_TEST(test_detect_type);
+  result += RUN_TEST(test_endian_option);
+  result += RUN_TEST(test_big_endian);
+  result += RUN_TEST(test_little_endian);
+  result += RUN_TEST(test_detect_byte_order);
+  remove( tmp_file );
+  return result;
+MBErrorCode read_file_( MBInterface& moab, const char* input_file, const char* options = "" )
+  MBErrorCode rval;
+  MBEntityHandle set;
+  ReadSTL reader( &moab );
+  FileOptions opts(options);
+  rval = reader.load_file( input_file, set, opts, 0, 0, 0 );
+  return rval;
+void read_file( MBInterface& moab, const char* input_file, const char* options )
+  MBErrorCode rval = read_file_( moab, input_file, options );
+  CHECK_ERR(rval);
+void convert_file( const char* input_file, const char* output_file, const char* options )
+  MBErrorCode rval;
+  MBCore moab;
+  FileOptions opts_reader("");
+  rval = reader.load_file( input_file, set, opts_reader, 0, 0, 0 );
+  CHECK_ERR(rval);
+  WriteSTL writer( &moab );
+  FileOptions opts_writer(options);
+  std::vector<std::string> empty;
+  rval = writer.write_file( output_file, true, opts_writer, 0, 0, empty, 0, 0, 3 );
+  CHECK_ERR(rval);
+  MBCore moab;
+  read_file( moab, sample, "ASCII" );
+  check_mesh_is_tet( moab );
+  convert_file( sample, tmp_file, "ASCII" );
+  MBCore moab;
+  read_file( moab, tmp_file, "ASCII" );
+  MBErrorCode rval;
+  MBCore moab;
+  rval = read_file_( moab, sample, "BINARY" );
+  CHECK( MB_SUCCESS != rval );
+  convert_file( sample, tmp_file, "BINARY" );
+  rval = read_file_( moab, tmp_file, "ASCII" );
+  MBCore moab;
+  read_file( moab, sample );
+  read_file_( moab, tmp_file );
+  MBErrorCode rval;
+  MBCore moab;
+  convert_file( sample, tmp_file, "BINARY;BIG_ENDIAN" );
+  rval = read_file_( moab, tmp_file, "BINARY;LITTLE_ENDIAN" );
+  convert_file( sample, tmp_file, "BINARY;LITTLE_ENDIAN" );
+  rval = read_file_( moab, tmp_file, "BINARY;BIG_ENDIAN" );
+  MBCore moab;
+  read_file( moab, tmp_file, "BINARY;BIG_ENDIAN" );
+  MBCore moab;
+  read_file( moab, tmp_file, "BINARY;LITTLE_ENDIAN" );
+  MBCore moab;
+  read_file( moab, tmp_file, "BINARY" );
+  MBErrorCode rval;
+  MBRange verts, tris, other;
+  rval = moab.get_entities_by_type( 0, MBVERTEX, verts );
+  CHECK_ERR(rval);
+  rval = moab.get_entities_by_type( 0, MBTRI, tris );
+  CHECK_ERR(rval);
+  rval = moab.get_entities_by_handle( 0, other );
+  CHECK_ERR(rval);
+  CHECK_EQUAL( 4, (int)verts.size() );
+  CHECK_EQUAL( 4, (int)tris.size() );
+  other = subtract( other, verts );
+  other = subtract( other, tris );
+  CHECK( other.all_of_type(MBENTITYSET) );
+  const double expt_coords[4][3] = { { 0, 0, 0 },
+                                     { 1, 0, 0 },
+                                     { 0, 1, 0 },
+                                     { 0, 0, 1 } };
+  MBEntityHandle vert_handles[4] = { 0, 0, 0, 0 };
+  for (MBRange::iterator i = verts.begin(); i != verts.end(); ++i) {
+    double coords[3];
+    rval = moab.get_coords( &*i, 1, coords );
+    CHECK_ERR(rval);
+    bool found = false;
+    for (int j = 0; j < 4; ++j) {
+      double ds = 0;
+      for (int d = 0; d < 3; ++d) {
+        double dl = expt_coords[j][d] - coords[d];
+        ds += dl*dl;
+      if (ds < 1e-6) {
+        CHECK_EQUAL( (MBEntityHandle)0, vert_handles[j] );
+        vert_handles[j] = *i;
+        found = true;
+        break;
+    CHECK(found);
+  const int expt_conn[4][3] = { { 0, 1, 3 },
+                                { 0, 2, 1 },
+                                { 0, 3, 2 },
+                                { 1, 2, 3 } };
+  MBEntityHandle tri_handles[4] = { 0, 0, 0, 0 };
+  for (MBRange::iterator i = tris.begin(); i != tris.end(); ++i) {
+    const MBEntityHandle* conn = 0;
+    int len = 0;
+    rval = moab.get_connectivity( *i, conn, len );
+    CHECK_ERR(rval);
+    CHECK_EQUAL( 3, len );
+    int conn_idx[3] = {
+      std::find( vert_handles, vert_handles + 4, conn[0] ) - vert_handles,
+      std::find( vert_handles, vert_handles + 4, conn[1] ) - vert_handles,
+      std::find( vert_handles, vert_handles + 4, conn[2] ) - vert_handles };
+    CHECK( conn_idx[0] != 4 );
+    CHECK( conn_idx[1] != 4 );
+    CHECK( conn_idx[2] != 4 );
+      int k = std::find( expt_conn[j], expt_conn[j]+3, conn_idx[0] ) - expt_conn[j];
+      if (k == 3)
+        continue;
+      if (expt_conn[j][(k+1)%3] == conn_idx[1] &&
+          expt_conn[j][(k+2)%3] == conn_idx[2]) {
+        CHECK_EQUAL( (MBEntityHandle)0, tri_handles[j] );
+        tri_handles[j] = *i;
+        found = true;
+        break;
+    CHECK(found);
