[MOAB-dev] r3177 - in MOAB/trunk: . test
kraftche at cae.wisc.edu
Wed Sep 30 12:55:14 CDT 2009
Author: kraftche
Date: 2009-09-30 12:55:13 -0500 (Wed, 30 Sep 2009)
New Revision: 3177
Added:
MOAB/trunk/gmsh_test.cc
MOAB/trunk/test/gmsh2.msh
Modified:
MOAB/trunk/Makefile.am
MOAB/trunk/ReadGmsh.cpp
Log:
o Support version 2.1 of Gmsh ASCII file format
o Support reading 15-node prism and 13-node pyramid from Gmsh file
o Fix wrong MOAB type for Gmsh type 10 (bug #27)
o Add simple regression test for Gmsh reader
Modified: MOAB/trunk/Makefile.am
--- MOAB/trunk/Makefile.am 2009-09-30 15:17:09 UTC (rev 3176)
+++ MOAB/trunk/Makefile.am 2009-09-30 17:55:13 UTC (rev 3177)
@@ -39,6 +39,7 @@
mesh_set_test \
cub_file_test \
exodus_test \
+ gmsh_test \
mbcn_test \
bsp_tree_poly_test
# merge_test \ # input files no longer exist?
@@ -367,6 +368,9 @@
exodus_test_SOURCES = TestUtil.hpp exodus_test.cc
exodus_test_DEPENDENCIES = $(tag_test_LDADD)
+gmsh_test_SOURCES = TestUtil.hpp gmsh_test.cc
+gmsh_test_DEPENDENCIES = $(tag_test_LDADD)
mbcn_test_SOURCES = MBCN.hpp MBCN.cpp mbcn_test.cc
mbcn_test_CPPFLAGS = -DSRCDIR=$(srcdir) # define anything to work around build issue
mbcn_test_LDADD =
Modified: MOAB/trunk/ReadGmsh.cpp
--- MOAB/trunk/ReadGmsh.cpp 2009-09-30 15:17:09 UTC (rev 3176)
+++ MOAB/trunk/ReadGmsh.cpp 2009-09-30 17:55:13 UTC (rev 3177)
@@ -16,6 +16,9 @@
* \class ReadGmsh
* \brief Gmsh (http://www.geuz.org/gmsh) file reader
+ * See: http://geuz.org/gmsh/doc/texinfo/gmsh.html#MSH-ASCII-file-format
* \author Jason Kraftcheck
@@ -53,29 +56,57 @@
-// Type info indexed by type id used in file format.
+// Indexed by position in Gmsh order, containing cooresponding
+// position in MOAB order.
const int hex_27_node_order[] = {
0, 1, 2, 3, 4, 5, 6, 7, // corners
8, 11, 12, 9, 13, 10, 14, 15, 16, 19, 17, 18, // edges
24, 20, 23, 21, 22, 25, // faces
26 }; // volume
+// Indexed by position in MOAB order, containing cooresponding
+// position in Gmsh order.
+const int pri_15_node_order[] = {
+ 0, 1, 2, 3, 4, 5, // corners
+ 6, 8, 9, 7, 10, 11, 12, 14, 13 // edges
+const int pyr_13_node_order[] = {
+ 0, 1, 2, 3, 4, // corners
+ 5, 8, 9, 6, 10, 7, 11, 12 // edges
+// Type info indexed by type id used in file format.
const ReadGmsh::ElementType typemap[] = {
- { MBMAXTYPE, 0, 0 },
- { MBEDGE, 2, 0 },
- { MBTRI, 3, 0 },
- { MBQUAD, 4, 0 },
- { MBTET, 4, 0 },
- { MBHEX, 8, 0 },
- { MBPRISM, 6, 0 },
- { MBPYRAMID, 5, 0 },
- { MBEDGE, 3, 0 },
- { MBTRI, 6, 0 },
- { MBQUAD, 8, 0 },
- { MBTET, 10, 0 },
+ { MBMAXTYPE, 0, 0 },
+ { MBEDGE, 2, 0 }, // 1
+ { MBTRI, 3, 0 }, // 2
+ { MBQUAD, 4, 0 }, // 3
+ { MBTET, 4, 0 }, // 4
+ { MBHEX, 8, 0 }, // 5
+ { MBPRISM, 6, 0 }, // 6
+ { MBPYRAMID, 5, 0 }, // 7
+ { MBEDGE, 3, 0 }, // 8
+ { MBTRI, 6, 0 }, // 9
+ { MBQUAD, 9, 0 }, // 10
+ { MBTET, 10, 0 }, // 11
{ MBHEX, 27, hex_27_node_order },
- { MBMAXTYPE,18, 0 }, // prism w/ mid-face nodes on quads but not tris
- { MBMAXTYPE,14, 0 }, // pyramid w/ mid-face nodes on quad but not tris
- { MBMAXTYPE, 1, 0 } // point element (0-rad sphere element?)
+ { MBMAXTYPE,18, 0 }, // 13 prism w/ mid-face nodes on quads but not tris
+ { MBMAXTYPE,14, 0 }, // 14 pyramid w/ mid-face nodes on quad but not tris
+ { MBMAXTYPE, 1, 0 }, // 15 point element (0-rad sphere element?)
+ { MBQUAD, 8, 0 }, // 16
+ { MBHEX, 20, hex_27_node_order },
+ { MBPRISM, 15, pri_15_node_order },
+ { MBPYRAMID,13, pyr_13_node_order },
+ { MBMAXTYPE, 9, 0 }, // 20 triangle w/ 2 nodes per edge
+ { MBMAXTYPE,10, 0 }, // 21 " " " " " " and mid-face node
+ { MBMAXTYPE,12, 0 }, // 22 triangle w/ 3 nodes per edge
+ { MBMAXTYPE,15, 0 }, // 23 " " " " " " and 3 mid-face nodes
+ { MBMAXTYPE,15, 0 }, // 24 triangle w/ 4 nodes per edge
+ { MBMAXTYPE,21, 0 }, // 25 " " " " " " and 6 mid-face nodes
+ { MBMAXTYPE, 4, 0 }, // 26 4-node edge
+ { MBMAXTYPE, 5, 0 }, // 27 5-node edge
+ { MBMAXTYPE, 6, 0 }, // 28 6-node edge
+ { MBMAXTYPE,20, 0 }, // 29 tet w/ 2 nodes per edge and 1 per face
+ { MBMAXTYPE,35, 0 }, // 30 tet w/ 3 nodes per edge, 3 per face, and 1 mid-voluem
+ { MBMAXTYPE,56, 0 } // 31 tet w/ 4 nodes per edge, 6 per face, and 4 mid-voluem
const int max_type_int = sizeof(typemap) / sizeof(typemap[0]) - 1;
@@ -174,7 +205,7 @@
if (!tokens.get_doubles( 1, &version ))
return MB_FILE_WRITE_ERROR;
- if (version != 2.0) {
+ if (version != 2.0 && version != 2.1) {
readMeshIface->report_error( "%s: unknown format version: %f\n", filename, version );
return MB_FILE_DOES_NOT_EXIST;
Added: MOAB/trunk/gmsh_test.cc
--- MOAB/trunk/gmsh_test.cc (rev 0)
+++ MOAB/trunk/gmsh_test.cc 2009-09-30 17:55:13 UTC (rev 3177)
@@ -0,0 +1,244 @@
+#include "TestUtil.hpp"
+#include "MBCore.hpp"
+#include "MBTagConventions.hpp"
+#include "MBCN.hpp"
+#include "ReadGmsh.hpp"
+#include "FileOptions.hpp"
+#include <math.h>
+#include <algorithm>
+/* Input test file: gmsh2.msh
+ * Example version 2.0 ASCII input file from Gmsh 2.4 manual.
+#ifdef SRCDIR
+static const char example[] = STRINGIFY(SRCDIR) "/test/gmsh2.msh";
+#else
+static const char example[] = "test/gmsh2.msh";
+#endif
+void test_read_nodes();
+void test_read_quads();
+void test_read_material_set();
+void test_read_geom_set();
+void read_file( MBInterface& moab, const char* input_file );
+int main()
+ int result = 0;
+ result += RUN_TEST(test_read_nodes);
+ result += RUN_TEST(test_read_quads);
+ result += RUN_TEST(test_read_material_set);
+ result += RUN_TEST(test_read_geom_set);
+ return result;
+ MBErrorCode rval;
+ MBEntityHandle set;
+ ReadGmsh reader( &moab );
+ FileOptions opts("");
+ rval = reader.load_file( input_file, set, opts, 0, 0, 0 );
+ CHECK_ERR(rval);
+ const double eps = 1e-100;
+ MBErrorCode rval;
+ MBCore moab;
+ MBInterface& mb = moab;
+ read_file( moab, example );
+ std::vector<MBEntityHandle> nodes;
+ rval = mb.get_entities_by_type( 0, MBVERTEX, nodes );
+ CHECK_ERR(rval);
+ CHECK_EQUAL( (size_t)6, nodes.size() );
+ MBTag id_tag;
+ rval = mb.tag_get_handle( GLOBAL_ID_TAG_NAME, id_tag );
+ CHECK_ERR(rval);
+ std::vector<int> ids(nodes.size());
+ rval = mb.tag_get_data( id_tag, &nodes[0], nodes.size(), &ids[0] );
+ CHECK_ERR(rval);
+ std::vector<int> sorted_ids( ids );
+ std::sort( sorted_ids.begin(), sorted_ids.end() );
+ std::vector<double> coords(3*nodes.size());
+ rval = mb.get_coords( &nodes[0], nodes.size(), &coords[0] );
+ CHECK_ERR(rval);
+ int idx, pos = 0;
+ CHECK_EQUAL( pos+1, sorted_ids[pos] );
+ idx = std::find( ids.begin(), ids.end(),pos+1 ) - ids.begin();
+ CHECK_REAL_EQUAL( coords[3*idx+0], 0.0, eps );
+ CHECK_REAL_EQUAL( coords[3*idx+1], 0.0, eps );
+ CHECK_REAL_EQUAL( coords[3*idx+2], 0.0, eps );
+ ++pos;
+ CHECK_REAL_EQUAL( coords[3*idx+0], 1.0, eps );
+ ++pos;
+ CHECK_REAL_EQUAL( coords[3*idx+1], 1.0, eps );
+ ++pos;
+ ++pos;
+ CHECK_REAL_EQUAL( coords[3*idx+0], 2.0, eps );
+ ++pos;
+ MBErrorCode rval;
+ MBCore moab;
+ std::vector<MBEntityHandle> quads;
+ rval = mb.get_entities_by_type( 0, MBQUAD, quads );
+ CHECK_ERR(rval);
+ CHECK_EQUAL( (size_t)2, quads.size() );
+ MBTag id_tag;
+ CHECK_ERR(rval);
+ std::vector<int> ids(quads.size());
+ rval = mb.tag_get_data( id_tag, &quads[0], quads.size(), &ids[0] );
+ CHECK_ERR(rval);
+ if (ids[0] != 1) {
+ std::swap( ids[0], ids[1] );
+ std::swap( quads[0], quads[1] );
+ int vtx_ids[4];
+ const MBEntityHandle* conn;
+ int len;
+ const int conn1[] = { 1, 2, 3, 4 };
+ int pos = 0;
+ CHECK_EQUAL( pos+1, ids[pos] );
+ rval = mb.get_connectivity( quads[pos], conn, len );
+ CHECK_ERR(rval);
+ CHECK_EQUAL( 4, len );
+ rval = mb.tag_get_data( id_tag, conn, len, vtx_ids );
+ CHECK_ERR(rval);
+ CHECK_ARRAYS_EQUAL( conn1, 4, vtx_ids, len );
+ const int conn2[] = { 2, 5, 6, 3 };
+ ++pos;
+ CHECK_ERR(rval);
+ CHECK_ERR(rval);
+ CHECK_ARRAYS_EQUAL( conn2, 4, vtx_ids, len );
+ MBErrorCode rval;
+ MBCore moab;
+ MBTag mat_tag;
+ rval = mb.tag_get_handle( MATERIAL_SET_TAG_NAME, mat_tag );
+ CHECK_ERR(rval);
+ MBRange sets;
+ rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &mat_tag, 0, 1, sets );
+ CHECK_ERR(rval);
+ CHECK_EQUAL( 1, (int)sets.size() );
+ MBEntityHandle set = sets.front();
+ int id;
+ rval = mb.tag_get_data( mat_tag, &set, 1, &id );
+ CHECK_ERR(rval);
+ CHECK_EQUAL( 99, id );
+ std::vector<MBEntityHandle> quads, contents;
+ CHECK_ERR(rval);
+ rval = mb.get_entities_by_handle( set, contents );
+ CHECK_ERR(rval);
+ std::sort( quads.begin(), quads.end() );
+ std::sort( contents.begin(), contents.end() );
+ CHECK_EQUAL( quads, contents );
+ MBErrorCode rval;
+ MBCore moab;
+ MBTag dim_tag, id_tag;
+ rval = mb.tag_get_handle( GEOM_DIMENSION_TAG_NAME, dim_tag );
+ CHECK_ERR(rval);
+ CHECK_ERR(rval);
+ MBRange sets;
+ rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &dim_tag, 0, 1, sets );
+ CHECK_ERR(rval);
+ int dim;
+ rval = mb.tag_get_data( dim_tag, &set, 1, &dim );
+ CHECK_ERR(rval);
+ CHECK_EQUAL( 2, dim );
+ int id;
+ rval = mb.tag_get_data( id_tag, &set, 1, &id );
+ CHECK_ERR(rval);
+ CHECK_EQUAL( 3, id );
+ CHECK_ERR(rval);
+ CHECK_ERR(rval);
Added: MOAB/trunk/test/gmsh2.msh
--- MOAB/trunk/test/gmsh2.msh (rev 0)
+++ MOAB/trunk/test/gmsh2.msh 2009-09-30 17:55:13 UTC (rev 3177)
@@ -0,0 +1,33 @@
+$MeshFormat
+2.1 0 8
+$EndMeshFormat
+$Nodes
+6
+1 0.0 0.0 0.0
+2 1.0 0.0 0.0
+3 1.0 1.0 0.0
+4 0.0 1.0 0.0
+5 2.0 0.0 0.0
+6 2.0 1.0 0.0
+$EndNodes
+$Elements
+2
+1 3 2 99 3 1 2 3 4
+2 3 2 99 3 2 5 6 3
+$EndElements
+$NodeData
+1
+"A scalar view"
+1
+0.0
+3
+0
+1
+6
+1 0.0
+2 0.1
+3 0.2
+4 0.0
+5 0.2
+6 0.4
+$EndNodeData
