[MOAB-dev] r3141 - MOAB/branches/python/tools/iMesh/python
jvporter at wisc.edu jvporter at wisc.edu
Tue Sep 15 14:08:23 CDT 2009
Author: jvporter
Date: 2009-09-15 14:08:23 -0500 (Tue, 15 Sep 2009)
New Revision: 3141
Modified:
   MOAB/branches/python/tools/iMesh/python/iMesh.c
   MOAB/branches/python/tools/iMesh/python/iMesh_Python.h
   MOAB/branches/python/tools/iMesh/python/iMesh_entSet.inl
   MOAB/branches/python/tools/iMesh/python/iMesh_iter.inl
   MOAB/branches/python/tools/iMesh/python/iMesh_tag.inl
   MOAB/branches/python/tools/iMesh/python/setup.py
Log:
* Adjust internal naming scheme for PyTAPS to simplify addition
  of iGeom interface
* Unglue setup.py from autotools
* Add support for alternate iXxx-Defs.inc files (e.g. iGeom)
Modified: MOAB/branches/python/tools/iMesh/python/iMesh.c
--- MOAB/branches/python/tools/iMesh/python/iMesh.c	2009-09-15 16:57:33 UTC (rev 3140)
+++ MOAB/branches/python/tools/iMesh/python/iMesh.c	2009-09-15 19:08:23 UTC (rev 3141)
@@ -14,10 +14,7 @@
 static PyTypeObject iMeshTag_Type;
 static int NPY_IMESHTAG;
-static iMeshEntitySet_Object * iMeshEntitySet_New(iMesh_Object *mesh);
-static iMeshTag_Object * iMeshTag_New(iMesh_Object *mesh);
 /* TODO: these are never freed! */
 static PyObject *g_helper_module;
 static PyObject *g_adj_list;
@@ -73,20 +70,20 @@
-iMeshEntitySet_New(iMesh_Object *mesh)
+iMeshEntitySet_New(iMesh_Object *instance)
     iMeshEntitySet_Object *o = iMeshEntitySet_NewRaw();
-    o->mesh = mesh;
-    Py_INCREF(o->mesh);
+    o->instance = instance;
+    Py_INCREF(o->instance);
     return o;
-iMeshTag_New(iMesh_Object *mesh)
+iMeshTag_New(iMesh_Object *instance)
     iMeshTag_Object *o = iMeshTag_NewRaw();
-    o->mesh = mesh;
     return o;
@@ -100,8 +97,8 @@
         return -1;
     int err;
-    iMesh_newMesh(options,&self->mesh,&err,strlen(options));
-    if(checkError(self->mesh,err))
+    iMesh_newMesh(options,&self->handle,&err,strlen(options));
+    if(checkError(self->handle,err))
         return -1;
     return 0;
@@ -109,10 +106,10 @@
 static void
 iMeshObj_dealloc(iMesh_Object *self)
-    if(self->mesh)
+    if(self->handle)
         int err;
-        iMesh_dtor(self->mesh,&err);
+        iMesh_dtor(self->handle,&err);
     self->ob_type->tp_free((PyObject*)self);
@@ -123,8 +120,8 @@
     iMeshEntitySet_Object *rootset = iMeshEntitySet_New(self);
     int err;
-    iMesh_getRootSet(self->mesh,&rootset->set.handle,&err);
+    iMesh_getRootSet(self->handle,&rootset->base.handle,&err);
         Py_DECREF((PyObject*)rootset);
         return NULL;
@@ -138,8 +135,8 @@
 iMeshObj_getGeometricDimension(iMesh_Object *self,void *closure)
     int dim,err;
-    iMesh_getGeometricDimension(self->mesh,&dim,&err);
+    iMesh_getGeometricDimension(self->handle,&dim,&err);
         return NULL;
     return Py_BuildValue("i",dim);
@@ -158,8 +155,8 @@
     int dim,err;
     if(!PyArg_Parse(value,"i",&dim))
         return -1;
-    iMesh_setGeometricDimension(self->mesh,dim,&err);
+    iMesh_setGeometricDimension(self->handle,dim,&err);
         return -1;
     return 0;
@@ -169,8 +166,8 @@
 iMeshObj_getDfltStorage(iMesh_Object *self,void *closure)
     int order,err;
-    iMesh_getDfltStorage(self->mesh,&order,&err);
+    iMesh_getDfltStorage(self->handle,&order,&err);
         return NULL;
     return Py_BuildValue("i",order);
@@ -182,8 +179,8 @@
     int *adjtable=0;
     int alloc=0,size,err;
-    iMesh_getAdjTable(self->mesh,&adjtable,&alloc,&size,&err);
+    iMesh_getAdjTable(self->handle,&adjtable,&alloc,&size,&err);
         return NULL;
     npy_intp dims[] = {4,4};
@@ -197,8 +194,8 @@
     if(!PyArg_ParseTuple(args,"i",&doReset))
         return NULL;
-    iMesh_areEHValid(self->mesh,doReset,&areInv,&err);
+    iMesh_areEHValid(self->handle,doReset,&areInv,&err);
         return NULL;
     return Py_BuildValue("i",areInv);
@@ -230,11 +227,11 @@
         size = PyArray_SIZE(ents);
         iBase_EntityHandle *data = PyArray_DATA(ents);
-        iMesh_getVtxArrCoords(self->mesh,data,size,storage_order,&coords,
+        iMesh_getVtxArrCoords(self->handle,data,size,storage_order,&coords,
                               &coords_alloc,&coords_size,&err);
         Py_DECREF(ents);
             return NULL;
         npy_intp outer;
@@ -249,9 +246,9 @@
     else if(iBaseEntity_Check(obj))
         double *v = malloc(3*sizeof(double));
-        iMesh_getVtxCoord(self->mesh,iBaseEntity_GetHandle(obj), v+0,v+1,v+2,
+        iMesh_getVtxCoord(self->handle,iBaseEntity_GetHandle(obj), v+0,v+1,v+2,
                           &err);
             return NULL;
         npy_intp dims[] = {3};
@@ -284,10 +281,10 @@
-        iMesh_getEntArrTopo(self->mesh,data,size,&topos,&topo_alloc,&topo_size,
+        iMesh_getEntArrTopo(self->handle,data,size,&topos,&topo_alloc,&topo_size,
                             &err);
         Py_DECREF(ents);
             return NULL;
         npy_intp dims[] = {topo_size};
@@ -298,8 +295,8 @@
         int topo;
         iBase_EntityHandle handle = ((iBaseEntity_Object*)obj)->handle;
-        iMesh_getEntTopo(self->mesh,handle,&topo,&err);
+        iMesh_getEntTopo(self->handle,handle,&topo,&err);
             return NULL;
         return PyInt_FromLong(topo);
@@ -331,10 +328,10 @@
-        iMesh_getEntArrType(self->mesh,data,size,&types,&type_alloc,&type_size,
+        iMesh_getEntArrType(self->handle,data,size,&types,&type_alloc,&type_size,
                             &err);
         Py_DECREF(ents);
             return NULL;
         npy_intp dims[] = {type_size};
@@ -344,8 +341,8 @@
         int type;
-        iMesh_getEntType(self->mesh,handle,&type,&err);
+        iMesh_getEntType(self->handle,handle,&type,&err);
             return NULL;
         return PyInt_FromLong(type);
@@ -380,11 +377,11 @@
-        iMesh_getEntArrAdj(self->mesh,data,size,type_req,&adj,&adj_alloc,
+        iMesh_getEntArrAdj(self->handle,data,size,type_req,&adj,&adj_alloc,
                            &adj_size,&offsets,&offsets_alloc,&offsets_size,
                            &err);
         Py_DECREF(ents);
             return NULL;
         npy_intp adj_dims[] = {adj_size};
@@ -413,9 +410,9 @@
         int adj_alloc=0,adj_size;
         iBase_EntityHandle handle = iBaseEntity_GetHandle(obj);
-        iMesh_getEntAdj(self->mesh,handle,type_req,&adj,&adj_alloc,&adj_size,
+        iMesh_getEntAdj(self->handle,handle,type_req,&adj,&adj_alloc,&adj_size,
                         &err);
             return NULL;
         npy_intp dims[] = {adj_size};
@@ -451,11 +448,11 @@
-        iMesh_getEntArr2ndAdj(self->mesh,data,size,bridge_type,type_req,&adj,
+        iMesh_getEntArr2ndAdj(self->handle,data,size,bridge_type,type_req,&adj,
                               &adj_alloc,&adj_size,&offsets,&offsets_alloc,
                               &offsets_size,&err);
         Py_DECREF(ents);
             return NULL;
@@ -484,9 +481,9 @@
-        iMesh_getEnt2ndAdj(self->mesh,handle,bridge_type,type_req,&adj,
+        iMesh_getEnt2ndAdj(self->handle,handle,bridge_type,type_req,&adj,
                            &adj_alloc,&adj_size,&err);
             return NULL;
@@ -513,8 +510,8 @@
     isList = (obj == Py_True);
-    iMesh_createEntSet(self->mesh,isList,&set->set.handle,&err);
+    iMesh_createEntSet(self->handle,isList,&set->base.handle,&err);
         Py_DECREF((PyObject*)set);
         return NULL;
@@ -532,8 +529,8 @@
     if(!PyArg_ParseTuple(args,"O!",&iBaseEntitySet_Type,&set))
         return NULL;
-    iMesh_destroyEntSet(self->mesh,set->handle,&err);
+    iMesh_destroyEntSet(self->handle,set->handle,&err);
         return NULL;
     Py_RETURN_NONE;
@@ -570,7 +567,7 @@
         int coord_size = PyArray_SIZE(verts);
         double *coords = PyArray_DATA(verts);
-        iMesh_setVtxArrCoords(self->mesh,entities,ent_size,storage_order,
+        iMesh_setVtxArrCoords(self->handle,entities,ent_size,storage_order,
                               coords,coord_size,&err);
         Py_DECREF(ents);
         Py_DECREF(verts);
@@ -590,7 +587,7 @@
         double *v = PyArray_DATA(verts);
         iBase_EntityHandle entity = iBaseEntity_GetHandle(obj);
-        iMesh_setVtxCoord(self->mesh,entity, v[0],v[1],v[2], &err);
+        iMesh_setVtxCoord(self->handle,entity, v[0],v[1],v[2], &err);
         Py_DECREF(verts);
     else
@@ -599,7 +596,7 @@
         return NULL;
         return NULL;
     Py_RETURN_NONE;
@@ -636,10 +633,10 @@
         iBase_EntityHandle *entities=0;
         int ent_alloc=0,ent_size;
-        iMesh_createVtxArr(self->mesh,count,storage_order,coords,coord_size,
+        iMesh_createVtxArr(self->handle,count,storage_order,coords,coord_size,
                            &entities,&ent_alloc,&ent_size,&err);
         Py_DECREF(vertices);
             return NULL;
         npy_intp dims[] = {ent_size};
@@ -657,10 +654,10 @@
         double *v = PyArray_DATA(vertices);
         iBaseEntity_Object *entity = iBaseEntity_New();
-        iMesh_createVtx(self->mesh, v[0],v[1],v[2], &entity->handle,&err);
+        iMesh_createVtx(self->handle, v[0],v[1],v[2], &entity->handle,&err);
             Py_DECREF((PyObject*)entity);
             return NULL;
@@ -692,10 +689,10 @@
-    iMesh_createEnt(self->mesh,topo,lower,lower_size,&entity->handle,&status,
+    iMesh_createEnt(self->handle,topo,lower,lower_size,&entity->handle,&status,
                     &err);
     Py_DECREF(ents);
         return NULL;
@@ -728,10 +725,10 @@
     int *status;
     int stat_alloc=0,stat_size;
-    iMesh_createEntArr(self->mesh,topo,lower,lower_size,&entities,&ent_alloc,
+    iMesh_createEntArr(self->handle,topo,lower,lower_size,&entities,&ent_alloc,
                        &ent_size,&status,&stat_alloc,&stat_size,&err);
     Py_DECREF(ents);
         return NULL;
     PyObject *pair = PyTuple_New(2);
@@ -763,13 +760,13 @@
         int size = PyArray_SIZE(ents);
         iBase_EntityHandle *entities = PyArray_DATA(ents);
-        iMesh_deleteEntArr(self->mesh,entities,size,&err);
+        iMesh_deleteEntArr(self->handle,entities,size,&err);
         Py_DECREF(ents);
-        iMesh_deleteEnt(self->mesh,entity,&err);
+        iMesh_deleteEnt(self->handle,entity,&err);
     else
@@ -777,7 +774,7 @@
         return NULL;
         return NULL;
     Py_RETURN_NONE;
@@ -803,9 +800,9 @@
     tag = iMeshTag_New(self);
-    iMesh_createTag(self->mesh,name,size,type,&tag->tag.handle,&err,
+    iMesh_createTag(self->handle,name,size,type,&tag->base.handle,&err,
                     strlen(name));
         Py_DECREF((PyObject*)tag);
         return NULL;
@@ -826,8 +823,8 @@
     forced = (obj == Py_True);
-    iMesh_destroyTag(self->mesh,tag->handle,forced,&err);
+    iMesh_destroyTag(self->handle,tag->handle,forced,&err);
         return NULL;
     Py_RETURN_NONE;
@@ -845,8 +842,8 @@
-    iMesh_getTagHandle(self->mesh,name,&tag->tag.handle,&err,strlen(name));
+    iMesh_getTagHandle(self->handle,name,&tag->base.handle,&err,strlen(name));
         return NULL;
@@ -870,16 +867,16 @@
         iBase_EntitySetHandle set = iBaseEntitySet_GetHandle(ents);
-        iMesh_getAllEntSetTags(self->mesh,set,&tags,&alloc,&size,&err);
+        iMesh_getAllEntSetTags(self->handle,set,&tags,&alloc,&size,&err);
             return NULL;
     else if(iBaseEntity_Check(ents))
         iBase_EntityHandle entity = iBaseEntity_GetHandle(ents);
-        iMesh_getAllTags(self->mesh,entity,&tags,&alloc,&size,&err);
+        iMesh_getAllTags(self->handle,entity,&tags,&alloc,&size,&err);
             return NULL;
     else
@@ -894,7 +891,7 @@
-static PyMethodDef iMesh_methods[] = {
+static PyMethodDef iMeshObj_methods[] = {
     { "areEHValid", (PyCFunction)iMeshObj_areEHValid, METH_VARARGS,
       "Return whether entity handles have changed since last reset or since "
       "instance construction"
@@ -951,7 +948,7 @@
   {0}
-static PyGetSetDef iMesh_getset[] = {
+static PyGetSetDef iMeshObj_getset[] = {
     { "rootSet", (getter)iMeshObj_getRootSet, 0,
       "root set", 0
@@ -1017,9 +1014,9 @@
     0,                            /* tp_weaklistoffset */
     0,                            /* tp_iter */
     0,                            /* tp_iternext */
-    iMesh_methods,                /* tp_methods */
+    iMeshObj_methods,             /* tp_methods */
     0,                            /* tp_members */
-    iMesh_getset,                 /* tp_getset */
+    iMeshObj_getset,              /* tp_getset */
     0,                            /* tp_base */
     0,                            /* tp_dict */
     0,                            /* tp_descr_get */
@@ -1039,10 +1036,10 @@
 iMeshEntSetArr_getitem(void *data,void *arr)
     ArrDealloc_Object *b = (ArrDealloc_Object*)PyArray_BASE(arr);
-    iMesh_Object *mesh = (iMesh_Object*)b->base;
-    iMeshEntitySet_Object *o = iMeshEntitySet_New(mesh);
+    iMesh_Object *instance = (iMesh_Object*)b->base;
+    iMeshEntitySet_Object *o = iMeshEntitySet_New(instance);
-    o->set.handle = *(iBase_EntitySetHandle*)data;
+    o->base.handle = *(iBase_EntitySetHandle*)data;
     return (PyObject*)o;
@@ -1051,10 +1048,10 @@
 iMeshTagArr_getitem(void *data,void *arr)
-    iMeshTag_Object *o = iMeshTag_New(mesh);
+    iMeshTag_Object *o = iMeshTag_New(instance);
-    o->tag.handle = *(iBase_TagHandle*)data;
+    o->base.handle = *(iBase_TagHandle*)data;
Modified: MOAB/branches/python/tools/iMesh/python/iMesh_Python.h
--- MOAB/branches/python/tools/iMesh/python/iMesh_Python.h	2009-09-15 16:57:33 UTC (rev 3140)
+++ MOAB/branches/python/tools/iMesh/python/iMesh_Python.h	2009-09-15 19:08:23 UTC (rev 3141)
@@ -12,13 +12,13 @@
 typedef struct
     PyObject_HEAD
-    iMesh_Instance mesh;
+    iMesh_Instance handle;
 } iMesh_Object;
 typedef struct
     PyObject_HEAD
-    iMesh_Object *mesh;
+    iMesh_Object *instance;
     int is_arr;
     union
@@ -29,8 +29,8 @@
 typedef struct
-    iBaseEntitySet_Object set;
+    iBaseEntitySet_Object base;
 } iMeshEntitySet_Object;
 #define iMeshEntitySet_NewRaw()                         \
@@ -41,12 +41,12 @@
     PyObject_TypeCheck((o),&iMeshEntitySet_Type)
 #define iMeshEntitySet_GetMesh(o)                       \
-    ( ((iMeshEntitySet_Object*)(o))->mesh )
+    ( ((iMeshEntitySet_Object*)(o))->instance )
 typedef struct
-    iBaseTag_Object tag;
+    iBaseTag_Object base;
 } iMeshTag_Object;
 #define iMeshTag_NewRaw()                               \
@@ -57,7 +57,7 @@
     PyObject_TypeCheck((o),&iMeshTag_Type)
 #define iMeshTag_GetMesh(o)                             \
-    ( ((iMeshTag_Object*)(o))->mesh )
+    ( ((iMeshTag_Object*)(o))->instance )
 #ifndef _IMESH_MODULE
Modified: MOAB/branches/python/tools/iMesh/python/iMesh_entSet.inl
--- MOAB/branches/python/tools/iMesh/python/iMesh_entSet.inl	2009-09-15 16:57:33 UTC (rev 3140)
+++ MOAB/branches/python/tools/iMesh/python/iMesh_entSet.inl	2009-09-15 19:08:23 UTC (rev 3141)
@@ -6,7 +6,7 @@
 static void
 iMeshEntSetObj_dealloc(iMeshEntitySet_Object *self)
-    Py_XDECREF(self->mesh);
+    Py_XDECREF(self->instance);
     ((PyObject*)self)->ob_type->tp_free((PyObject*)self);
@@ -19,9 +19,9 @@
         return NULL;
     int err;
-    iMesh_load(self->mesh->mesh,self->set.handle,name,options,&err,strlen(name),
-               strlen(options));
-    if(checkError(self->mesh->mesh,err))
+    iMesh_load(self->instance->handle,self->base.handle,name,options,&err,
+               strlen(name),strlen(options));
+    if(checkError(self->instance->handle,err))
         return NULL;
     Py_RETURN_NONE;
@@ -36,9 +36,9 @@
         return NULL;
     int err;
-    iMesh_save(self->mesh->mesh,self->set.handle,name,options,&err,strlen(name),
-               strlen(options));
+    iMesh_save(self->instance->handle,self->base.handle,name,options,&err,
         return NULL;
     Py_RETURN_NONE;
@@ -52,8 +52,8 @@
     if(!PyArg_ParseTuple(args,"i",&type))
         return NULL;
-    iMesh_getNumOfType(self->mesh->mesh,self->set.handle,type,&num,&err);
+    iMesh_getNumOfType(self->instance->handle,self->base.handle,type,&num,&err);
         return NULL;
     return Py_BuildValue("i",num);
@@ -67,8 +67,8 @@
     if(!PyArg_ParseTuple(args,"i",&topo))
         return NULL;
-    iMesh_getNumOfTopo(self->mesh->mesh,self->set.handle,topo,&num,&err);
+    iMesh_getNumOfTopo(self->instance->handle,self->base.handle,topo,&num,&err);
         return NULL;
@@ -85,9 +85,9 @@
     if(!PyArg_ParseTuple(args,"ii",&type,&topo))
         return NULL;
-    iMesh_getEntities(self->mesh->mesh,self->set.handle,type,topo,&entities,
-                      &alloc,&size,&err);
+    iMesh_getEntities(self->instance->handle,self->base.handle,type,topo,
+                      &entities,&alloc,&size,&err);
         return NULL;
     npy_intp dims[] = {size};
@@ -113,14 +113,14 @@
     int *offsets=0;
     int off_alloc=0,off_size;
-    iMesh_getAdjEntIndices(self->mesh->mesh,self->set.handle,type_requestor,
-                           topo_requestor,type_requested,
+    iMesh_getAdjEntIndices(self->instance->handle,self->base.handle,
+                           type_requestor,topo_requestor,type_requested,
                            &adj_ents,&adj_alloc,&adj_size,
                            &indices, &ind_alloc,&ind_size,
                            &offsets, &off_alloc,&off_size,
                            &err);
         return NULL;
     npy_intp ent_dims[] = {ent_size};
@@ -139,8 +139,8 @@
 iMeshEntSetObj_isList(iMeshEntitySet_Object *self,void *closure)
     int is_list,err;
-    iMesh_isList(self->mesh->mesh,self->set.handle,&is_list,&err);
+    iMesh_isList(self->instance->handle,self->base.handle,&is_list,&err);
         return NULL;
     return PyBool_FromLong(is_list);
@@ -154,9 +154,9 @@
     if(!PyArg_ParseTuple(args,"i",&num_hops))
         return NULL;
-    iMesh_getNumEntSets(self->mesh->mesh,self->set.handle,num_hops,&num_sets,
-                        &err);
+    iMesh_getNumEntSets(self->instance->handle,self->base.handle,num_hops,
+                        &num_sets,&err);
         return NULL;
     return Py_BuildValue("i",num_sets);
@@ -171,14 +171,14 @@
         return NULL;
-    iMesh_getEntSets(self->mesh->mesh,self->set.handle,num_hops,&sets,
+    iMesh_getEntSets(self->instance->handle,self->base.handle,num_hops,&sets,
                      &sets_alloc,&sets_size,&err);
         return NULL;
     npy_intp dims[] = {sets_size};
     return PyArray_NewFromMallocBase(1,dims,NPY_IMESHENTSET,sets,
-                                     (PyObject*)self->mesh);
+                                     (PyObject*)self->instance);
 static PyObject *
@@ -195,18 +195,21 @@
-        iMesh_addEntArrToSet(self->mesh->mesh,data,size,self->set.handle,&err);
+        iMesh_addEntArrToSet(self->instance->handle,data,size,
+                             self->base.handle,&err);
         Py_DECREF(ents);
     else if(iBaseEntitySet_Check(obj))
         iBaseEntitySet_Object *set = (iBaseEntitySet_Object*)obj;
-        iMesh_addEntSet(self->mesh->mesh,set->handle,self->set.handle,&err);
+        iMesh_addEntSet(self->instance->handle,set->handle,self->base.handle,
+                        &err);
         iBaseEntity_Object *ent = (iBaseEntity_Object*)obj;
-        iMesh_addEntToSet(self->mesh->mesh,ent->handle,self->set.handle,&err);
+        iMesh_addEntToSet(self->instance->handle,ent->handle,self->base.handle,
+                          &err);
     else
@@ -214,7 +217,7 @@
         return NULL;
         return NULL;
     Py_RETURN_NONE;
@@ -233,20 +236,21 @@
-        iMesh_rmvEntArrFromSet(self->mesh->mesh,data,size,self->set.handle,
-                               &err);
+        iMesh_rmvEntArrFromSet(self->instance->handle,data,size,
         Py_DECREF(ents);
-        iMesh_rmvEntSet(self->mesh->mesh,set->handle,self->set.handle,&err);
+        iMesh_rmvEntSet(self->instance->handle,set->handle,self->base.handle,
+                        &err);
-        iMesh_rmvEntFromSet(self->mesh->mesh,ent->handle,self->set.handle,
-                            &err);
+        iMesh_rmvEntFromSet(self->instance->handle,ent->handle,
     else
@@ -254,7 +258,7 @@
         return NULL;
         return NULL;
     Py_RETURN_NONE;
@@ -276,10 +280,11 @@
-        iMesh_isEntArrContained(self->mesh->mesh,self->set.handle,data,size,
-                                &contains,&contains_alloc,&contains_size,&err);
+        iMesh_isEntArrContained(self->instance->handle,self->base.handle,data,
+                                size,&contains,&contains_alloc,&contains_size,
+                                &err);
         Py_DECREF(ents);
             return NULL;
         npy_intp dims[] = {contains_size};
@@ -290,9 +295,9 @@
         int contains;
-        iMesh_isEntSetContained(self->mesh->mesh,self->set.handle,set->handle,
-                                &contains,&err);
+        iMesh_isEntSetContained(self->instance->handle,self->base.handle,
+                                set->handle,&contains,&err);
             return NULL;
         return PyBool_FromLong(contains);
@@ -301,9 +306,9 @@
         int contains;
-        iMesh_isEntContained(self->mesh->mesh,self->set.handle,ent->handle,
-                             &contains,&err);
+        iMesh_isEntContained(self->instance->handle,self->base.handle,
+                             ent->handle,&contains,&err);
             return NULL;
@@ -326,8 +331,9 @@
         return NULL;
-    iMesh_addPrntChld(self->mesh->mesh,self->set.handle,set->handle,&err);
+    iMesh_addPrntChld(self->instance->handle,self->base.handle,set->handle,
+                      &err);
         return NULL;
     Py_RETURN_NONE;
@@ -342,8 +348,9 @@
         return NULL;
-    iMesh_rmvPrntChld(self->mesh->mesh,self->set.handle,set->handle,&err);
+    iMesh_rmvPrntChld(self->instance->handle,self->base.handle,set->handle,
+                      &err);
         return NULL;
     Py_RETURN_NONE;
@@ -358,9 +365,9 @@
         return NULL;
-    iMesh_isChildOf(self->mesh->mesh,self->set.handle,set->handle,&is_child,
-                    &err);
+    iMesh_isChildOf(self->instance->handle,self->base.handle,set->handle,
+                    &is_child,&err);
         return NULL;
     return PyBool_FromLong(is_child);
@@ -374,9 +381,9 @@
         return NULL;
-    iMesh_getNumChld(self->mesh->mesh,self->set.handle,num_hops,&num_children,
-                     &err);
+    iMesh_getNumChld(self->instance->handle,self->base.handle,num_hops,
+                     &num_children,&err);
         return NULL;
     return Py_BuildValue("i",num_children);
@@ -390,9 +397,9 @@
         return NULL;
-    iMesh_getNumPrnt(self->mesh->mesh,self->set.handle,num_hops,&num_parents,
-                     &err);
+    iMesh_getNumPrnt(self->instance->handle,self->base.handle,num_hops,
+                     &num_parents,&err);
         return NULL;
     return Py_BuildValue("i",num_parents);
@@ -407,14 +414,14 @@
         return NULL;
-    iMesh_getChldn(self->mesh->mesh,self->set.handle,num_hops,&sets,
+    iMesh_getChldn(self->instance->handle,self->base.handle,num_hops,&sets,
         return NULL;
 static PyObject *
@@ -426,14 +433,14 @@
         return NULL;
-    iMesh_getPrnts(self->mesh->mesh,self->set.handle,num_hops,&sets,
+    iMesh_getPrnts(self->instance->handle,self->base.handle,num_hops,&sets,
         return NULL;
 static PyObject *
@@ -458,14 +465,14 @@
     int err;
     iMeshEntitySet_Object *result;
-    if(lhs->mesh->mesh != rhs->mesh->mesh)
+    if(lhs->instance->handle != rhs->instance->handle)
         return NULL;
-    result = iMeshEntitySet_New(lhs->mesh);
+    result = iMeshEntitySet_New(lhs->instance);
-    iMesh_subtract(lhs->mesh->mesh,lhs->set.handle,rhs->set.handle,
-                   &result->set.handle,&err);
-    if(checkError(lhs->mesh->mesh,err))
+    iMesh_subtract(lhs->instance->handle,lhs->base.handle,rhs->base.handle,
+                   &result->base.handle,&err);
+    if(checkError(lhs->instance->handle,err))
         Py_DECREF((PyObject*)result);
         return NULL;
@@ -480,14 +487,14 @@
     int err;
         return NULL;
-    iMesh_intersect(lhs->mesh->mesh,lhs->set.handle,rhs->set.handle,
+    iMesh_intersect(lhs->instance->handle,lhs->base.handle,rhs->base.handle,
         return NULL;
@@ -502,14 +509,14 @@
     int err;
         return NULL;
-    iMesh_unite(lhs->mesh->mesh,lhs->set.handle,rhs->set.handle,
+    iMesh_unite(lhs->instance->handle,lhs->base.handle,rhs->base.handle,
         return NULL;
@@ -624,8 +631,8 @@
 static PyMemberDef iMeshEntSetObj_members[] = {
-    {"instance", T_OBJECT_EX, offsetof(iMeshEntitySet_Object, mesh), READONLY,
-     "base iMesh instance"},
+    {"instance", T_OBJECT_EX, offsetof(iMeshEntitySet_Object, instance),
+     READONLY, "base iMesh instance"},
     {0}
Modified: MOAB/branches/python/tools/iMesh/python/iMesh_iter.inl
--- MOAB/branches/python/tools/iMesh/python/iMesh_iter.inl	2009-09-15 16:57:33 UTC (rev 3140)
+++ MOAB/branches/python/tools/iMesh/python/iMesh_iter.inl	2009-09-15 19:08:23 UTC (rev 3141)
@@ -14,22 +14,22 @@
                                      &array_size) )
         return -1;
-    self->mesh = set->mesh;
-    Py_INCREF(self->mesh);
+    self->instance = set->instance;
+    Py_INCREF(self->instance);
     if(array_size == 1)
         self->is_arr = 0;
-        iMesh_initEntIter(self->mesh->mesh,set->set.handle,type,topo,
+        iMesh_initEntIter(self->instance->handle,set->base.handle,type,topo,
                           &self->iter,&err);
     else
         self->is_arr = 1;
-        iMesh_initEntArrIter(self->mesh->mesh,set->set.handle,type,topo,
+        iMesh_initEntArrIter(self->instance->handle,set->base.handle,type,topo,
                              array_size,&self->arr_iter,&err);
         return -1;
     return 0;
@@ -38,16 +38,16 @@
 static void
 iMeshIterObj_dealloc(iMeshIter_Object *self)
-    if(self->mesh && self->iter)
+    if(self->instance && self->iter)
         int err;
         if(self->is_arr)
-            iMesh_endEntArrIter(self->mesh->mesh,self->arr_iter,&err);
+            iMesh_endEntArrIter(self->instance->handle,self->arr_iter,&err);
         else
-            iMesh_endEntIter(self->mesh->mesh,self->iter,&err);
+            iMesh_endEntIter(self->instance->handle,self->iter,&err);
@@ -56,11 +56,11 @@
     int err;
     if(self->is_arr)
-        iMesh_resetEntArrIter(self->mesh->mesh,self->arr_iter,&err);
+        iMesh_resetEntArrIter(self->instance->handle,self->arr_iter,&err);
     else
-        iMesh_resetEntIter(self->mesh->mesh,self->iter,&err);
+        iMesh_resetEntIter(self->instance->handle,self->iter,&err);
         return NULL;
     Py_RETURN_NONE;
@@ -75,9 +75,9 @@
         int alloc=0,size;
-        iMesh_getNextEntArrIter(self->mesh->mesh,self->arr_iter,&entities,
+        iMesh_getNextEntArrIter(self->instance->handle,self->arr_iter,&entities,
                                 &alloc,&size,&has_data,&err);
             return NULL;
         if(!has_data)
             return NULL;
@@ -88,9 +88,9 @@
     else
         iBase_EntityHandle entity;
-        iMesh_getNextEntIter(self->mesh->mesh,self->iter,&entity,&has_data,
-                             &err);
+        iMesh_getNextEntIter(self->instance->handle,self->iter,&entity,
+                             &has_data,&err);
             return NULL;
         if(!has_data)
             return NULL;
@@ -109,7 +109,7 @@
 static PyMemberDef iMeshIterObj_members[] = {
-    {"instance", T_OBJECT_EX, offsetof(iMeshIter_Object, mesh), READONLY,
+    {"instance", T_OBJECT_EX, offsetof(iMeshIter_Object, instance), READONLY,
     {0}
Modified: MOAB/branches/python/tools/iMesh/python/iMesh_tag.inl
--- MOAB/branches/python/tools/iMesh/python/iMesh_tag.inl	2009-09-15 16:57:33 UTC (rev 3140)
+++ MOAB/branches/python/tools/iMesh/python/iMesh_tag.inl	2009-09-15 19:08:23 UTC (rev 3141)
@@ -27,7 +27,7 @@
 static void
 iMeshTagObj_dealloc(iMeshTag_Object *self)
@@ -36,8 +36,9 @@
     char name[512];
     int err;
-    iMesh_getTagName(self->mesh->mesh,self->tag.handle,name,&err,sizeof(name));
+    iMesh_getTagName(self->instance->handle,self->base.handle,name,&err,
+                     sizeof(name));
         return NULL;
     return Py_BuildValue("s",name);
@@ -47,8 +48,8 @@
 iMeshTagObj_getSizeValues(iMeshTag_Object *self,void *closure)
     int size,err;
-    iMesh_getTagSizeValues(self->mesh->mesh,self->tag.handle,&size,&err);
+    iMesh_getTagSizeValues(self->instance->handle,self->base.handle,&size,&err);
         return NULL;
     return Py_BuildValue("i",size);
@@ -58,8 +59,8 @@
 iMeshTagObj_getSizeBytes(iMeshTag_Object *self,void *closure)
     int size,err;
-    iMesh_getTagSizeBytes(self->mesh->mesh,self->tag.handle,&size,&err);
+    iMesh_getTagSizeBytes(self->instance->handle,self->base.handle,&size,&err);
         return NULL;
@@ -69,8 +70,8 @@
 iMeshTagObj_getType(iMeshTag_Object *self,void *closure)
     int type,err;
-    iMesh_getTagType(self->mesh->mesh,self->tag.handle,&type,&err);
+    iMesh_getTagType(self->instance->handle,self->base.handle,&type,&err);
         return NULL;
     return Py_BuildValue("c",type_to_char(type));
@@ -91,8 +92,8 @@
     if(typechar == 0)
         /* infer the type of the data */
             return NULL;
     else
@@ -124,8 +125,8 @@
             data_size = PyArray_SIZE(data_arr);
             int *data = PyArray_DATA(data_arr);
-            iMesh_setIntArrData(self->mesh->mesh,entities,ent_size,
-                                self->tag.handle,data,data_size,&err);
+            iMesh_setIntArrData(self->instance->handle,entities,ent_size,
+                                self->base.handle,data,data_size,&err);
         else if(type == iBase_DOUBLE)
@@ -136,8 +137,8 @@
             double *data = PyArray_DATA(data_arr);
-            iMesh_setDblArrData(self->mesh->mesh,entities,ent_size,
+            iMesh_setDblArrData(self->instance->handle,entities,ent_size,
         else if(type == iBase_ENTITY_HANDLE)
@@ -148,8 +149,8 @@
             iBase_EntityHandle *data = PyArray_DATA(data_arr);
-            iMesh_setEHArrData(self->mesh->mesh,entities,ent_size,
+            iMesh_setEHArrData(self->instance->handle,entities,ent_size,
         else /* iBase_BYTES */
@@ -159,8 +160,8 @@
             char *data = PyArray_DATA(data_arr);
-            iMesh_setArrData(self->mesh->mesh,entities,ent_size,
+            iMesh_setArrData(self->instance->handle,entities,ent_size,
         Py_DECREF(ents);
@@ -175,7 +176,7 @@
             PyObject *o = PyNumber_Int(data_obj);
             if(o == NULL)
                 return NULL;
-            iMesh_setEntSetIntData(self->mesh->mesh,set,self->tag.handle,
+            iMesh_setEntSetIntData(self->instance->handle,set,self->base.handle,
                                    PyInt_AsLong(o),&err);
             Py_DECREF(o);
@@ -184,7 +185,7 @@
             PyObject *o = PyNumber_Float(data_obj);
             if(o == NULL)
                 return NULL;
-            iMesh_setEntSetDblData(self->mesh->mesh,set,self->tag.handle,
+            iMesh_setEntSetDblData(self->instance->handle,set,self->base.handle,
                                    PyFloat_AsDouble(o),&err);
             Py_DECREF(o);
@@ -192,7 +193,7 @@
             if(!iBaseEntity_Check(data_obj))
                 return NULL;
-            iMesh_setEntSetEHData(self->mesh->mesh,set,self->tag.handle,
+            iMesh_setEntSetEHData(self->instance->handle,set,self->base.handle,
                                   iBaseEntity_GetHandle(data_obj),&err);
@@ -204,8 +205,8 @@
             int data_size = PyArray_SIZE(data_arr);
-            iMesh_setEntSetData(self->mesh->mesh,set,self->tag.handle,data,
-                                data_size,&err);
+            iMesh_setEntSetData(self->instance->handle,set,self->base.handle,
+                                data,data_size,&err);
             Py_DECREF(data_arr);
@@ -218,7 +219,7 @@
             if(o == NULL)
                 return NULL;
-            iMesh_setIntData(self->mesh->mesh,entity,self->tag.handle,
+            iMesh_setIntData(self->instance->handle,entity,self->base.handle,
             Py_DECREF(o);
@@ -227,7 +228,7 @@
             if(o == NULL)
                 return NULL;
-            iMesh_setDblData(self->mesh->mesh,entity,self->tag.handle,
+            iMesh_setDblData(self->instance->handle,entity,self->base.handle,
             Py_DECREF(o);
@@ -235,7 +236,7 @@
                 return NULL;
-            iMesh_setEHData(self->mesh->mesh,entity,self->tag.handle,
+            iMesh_setEHData(self->instance->handle,entity,self->base.handle,
@@ -247,7 +248,7 @@
-            iMesh_setData(self->mesh->mesh,entity,self->tag.handle,data,
+            iMesh_setData(self->instance->handle,entity,self->base.handle,data,
                           data_size,&err);
@@ -258,7 +259,7 @@
         return NULL;
         return NULL;
     Py_RETURN_NONE;
@@ -277,8 +278,8 @@
     if(typechar == 0)
             return NULL;
     else
@@ -303,9 +304,9 @@
             int *data=0;
             int alloc=0,size;
-            iMesh_getIntArrData(self->mesh->mesh,entities,ent_size,
-                                self->tag.handle,&data,&alloc,&size,&err);
-            if(!checkError(self->mesh->mesh,err))
+            iMesh_getIntArrData(self->instance->handle,entities,ent_size,
+                                self->base.handle,&data,&alloc,&size,&err);
+            if(!checkError(self->instance->handle,err))
                 ret = PyArray_NewFromMalloc(1,dims,NPY_INT,data);
@@ -316,9 +317,9 @@
             double *data=0;
             int alloc=0,size;
-            iMesh_getDblArrData(self->mesh->mesh,entities,ent_size,
+            iMesh_getDblArrData(self->instance->handle,entities,ent_size,
                 ret = PyArray_NewFromMalloc(1,dims,NPY_DOUBLE,data);
@@ -329,9 +330,9 @@
             iBase_EntityHandle *data=0;
             int alloc=0,size;
-            iMesh_getEHArrData(self->mesh->mesh,entities,ent_size,
+            iMesh_getEHArrData(self->instance->handle,entities,ent_size,
                 ret = PyArray_NewFromMalloc(1,dims,NPY_IBASEENT,data);
@@ -342,9 +343,9 @@
             char *data=0;
             int alloc=0,size;
-            iMesh_getArrData(self->mesh->mesh,entities,ent_size,
+            iMesh_getArrData(self->instance->handle,entities,ent_size,
                 ret = PyArray_NewFromMalloc(1,dims,NPY_BYTE,data);
@@ -361,27 +362,27 @@
         if(type == iBase_INTEGER)
             int data;
-            iMesh_getEntSetIntData(self->mesh->mesh,set,self->tag.handle,&data,
-                                   &err);
+            iMesh_getEntSetIntData(self->instance->handle,set,
+                                   self->base.handle,&data,&err);
                 return NULL;
             return Py_BuildValue("i",data);
             double data;
-            iMesh_getEntSetDblData(self->mesh->mesh,set,self->tag.handle,&data,
-                                   &err);
+            iMesh_getEntSetDblData(self->instance->handle,set,
                 return NULL;
             return Py_BuildValue("d",data);
             iBaseEntity_Object *data = iBaseEntity_New();
-            iMesh_getEntSetEHData(self->mesh->mesh,set,self->tag.handle,
+            iMesh_getEntSetEHData(self->instance->handle,set,self->base.handle,
                                   &data->handle,&err);
                 Py_DECREF(data);
                 return NULL;
@@ -392,9 +393,9 @@
             char *data=0;
             int alloc=0,size;
-            iMesh_getEntSetData(self->mesh->mesh,set,self->tag.handle,&data,
+            iMesh_getEntSetData(self->instance->handle,set,self->base.handle,
+                                &data,&alloc,&size,&err);
                 return NULL;
             return PyArray_NewFromMalloc(1,dims,NPY_BYTE,data);
@@ -407,27 +408,27 @@
             int data;
-            iMesh_getIntData(self->mesh->mesh,entity,self->tag.handle,&data,
-                             &err);
+            iMesh_getIntData(self->instance->handle,entity,self->base.handle,
+                             &data,&err);
                 return NULL;
             double data;
-            iMesh_getDblData(self->mesh->mesh,entity,self->tag.handle,&data,
-                             &err);
+            iMesh_getDblData(self->instance->handle,entity,self->base.handle,
+                             &data,&err);
                 return NULL;
-            iMesh_getEHData(self->mesh->mesh,entity,self->tag.handle,
+            iMesh_getEHData(self->instance->handle,entity,self->base.handle,
                 Py_DECREF(data);
                 return NULL;
@@ -438,9 +439,9 @@
             char *data=0;
             int alloc=0,size;
-            iMesh_getData(self->mesh->mesh,entity,self->tag.handle,&data,
+            iMesh_getData(self->instance->handle,entity,self->base.handle,&data,
                           &alloc,&size,&err);
                 return NULL;
@@ -467,19 +468,19 @@
         int ent_size = PyArray_SIZE(ents);
-        iMesh_rmvArrTag(self->mesh->mesh,entities,ent_size,self->tag.handle,
-                        &err);
+        iMesh_rmvArrTag(self->instance->handle,entities,ent_size,
         Py_DECREF(ents);
         iBase_EntitySetHandle set = iBaseEntitySet_GetHandle(obj);
-        iMesh_rmvEntSetTag(self->mesh->mesh,set,self->tag.handle,&err);
+        iMesh_rmvEntSetTag(self->instance->handle,set,self->base.handle,&err);
-        iMesh_rmvTag(self->mesh->mesh,entity,self->tag.handle,&err);
+        iMesh_rmvTag(self->instance->handle,entity,self->base.handle,&err);
     else
@@ -487,7 +488,7 @@
         return NULL;
         return NULL;
     Py_RETURN_NONE;
@@ -507,7 +508,7 @@
 static PyMemberDef iMeshTagObj_members[] = {
-    {"instance", T_OBJECT_EX, offsetof(iMeshTag_Object, mesh), READONLY,
+    {"instance", T_OBJECT_EX, offsetof(iMeshTag_Object, instance), READONLY,
     {0}
Modified: MOAB/branches/python/tools/iMesh/python/setup.py
--- MOAB/branches/python/tools/iMesh/python/setup.py	2009-09-15 16:57:33 UTC (rev 3140)
+++ MOAB/branches/python/tools/iMesh/python/setup.py	2009-09-15 19:08:23 UTC (rev 3141)
@@ -6,6 +6,7 @@
 import re
 import os
 import sys
+import string
 def pair_fun(pre, post):
     def tmp(self):
@@ -13,26 +14,27 @@
         post(self)
     return tmp
-def add_imesh_defs(imesh_dir, self):
-        defs = parse_makefile( os.path.join(imesh_dir, 'iMesh-Defs.inc') )
+def add_itaps_defs(build_ext, itaps_dir, iface):
+    defs = parse_makefile( os.path.join(itaps_dir, iface+'-Defs.inc') )
+    prefix = string.upper(iface)
-        lib_match = re.compile(r'(?:(?<=\s)|^)-([lL])\s*(\S*)')
-        for match in lib_match.finditer( defs['IMESH_LIBS'] ):
-            if match.group(1) == 'l':
-                self.libraries.append( match.group(2) )
-            elif match.group(1) == 'L':
-                self.library_dirs.append( match.group(2) )
+    lib_match = re.compile(r'(?:(?<=\s)|^)-([lL])\s*(\S*)')
+    for match in lib_match.finditer( defs[prefix+'_LIBS'] ):
+        if match.group(1) == 'l':
+            build_ext.libraries.append( match.group(2) )
+        elif match.group(1) == 'L':
+            build_ext.library_dirs.append( match.group(2) )
+    inc_match = re.compile(r'(?:(?<=\s)|^)-(I)\s*(\S*)')
+    for match in inc_match.finditer( defs[prefix+'_INCLUDES'] ):
+        build_ext.include_dirs.append( match.group(2) )
-        inc_match = re.compile(r'(?:(?<=\s)|^)-(I)\s*(\S*)')
-        for match in inc_match.finditer( defs['IMESH_INCLUDES'] ):
-            self.include_dirs.append( match.group(2) )
 def new_init(self):
     self.imesh_dir = None
 def new_fin(self):
     if self.imesh_dir:
-        add_imesh_defs(self.imesh_dir, self)
+        add_itaps_defs(self, self.imesh_dir, 'iMesh')
 build_ext.user_options.append(('imesh-dir=', None,
                                'root directory for iMesh interface'))
@@ -40,22 +42,17 @@
 build_ext.finalize_options   = pair_fun(build_ext.finalize_options,   new_fin)
-def rebase(path):
-    return os.path.normpath( os.path.join( os.path.abspath(sys.argv[0]),
-                                           '../'+path) )
 iBase = Extension('itaps.iBase',
-                  depends = map(rebase, ['common.h', 'iBase_Python.h']),
-                  sources = map(rebase, ['iBase.c'])
+                  depends = ['common.h', 'iBase_Python.h'],
+                  sources = ['iBase.c']
 iMesh = Extension('itaps.iMesh',
-                                ['common.h', 'errors.h', 'iMesh_Python.h',
-                                 'iBase_Python.h', 'iMesh_entSet.inl',
-                                 'iMesh_iter.inl', 'iMesh_tag.inl',
-                                 'numpy_extensions.h', 'numpy_extensions.inl']),
-                  sources = map(rebase, ['iMesh.c'])
+                  depends = ['common.h', 'errors.h', 'iMesh_Python.h',
+                             'iBase_Python.h', 'iMesh_entSet.inl',
+                             'iMesh_iter.inl', 'iMesh_tag.inl',
+                             'numpy_extensions.h', 'numpy_extensions.inl'],
+                  sources = ['iMesh.c']
 class TestCommand(Command):
@@ -74,7 +71,7 @@
             raise DistutilsOptionError('"verbosity" option must be an integer')
     def run(self):
-        root = rebase('test')
+        root = 'test'
         old = os.getcwd()
         tests = []
         regex = re.compile(r'^(.*).py$')
@@ -108,7 +105,7 @@
             self.target = '_build/' + self.builder
     def run(self):
-        root = rebase('doc')
+        root = 'doc'
         old = os.getcwd()
         os.chdir(root)
@@ -170,7 +167,7 @@
     def run(self):
-        root = rebase('perf')
+        root = 'perf'
         old = os.getcwd()
         os.chdir(root)
@@ -209,7 +206,7 @@
             raise DistutilsOptionError('"count" option must be an integer')
     def run(self):
+        root = 'perf'
         old = os.getcwd()
         os.chdir(root)
         os.system('python perf.py -c%d "%s"' % (self.count, self.file))
@@ -224,7 +221,7 @@
       requires = ['numpy'],
       provides = ['itaps'],
-      package_dir = {'itaps': rebase('pkg')},
+      package_dir = {'itaps': 'pkg'},
       packages = ['itaps'],
       ext_modules = [iBase, iMesh],
       py_modules = ['itaps.helpers'],
