[MOAB-dev] r3139 - MOAB/trunk/tools/iMesh/python
jvporter at wisc.edu
Mon Sep 14 18:47:29 CDT 2009
Author: jvporter
Date: 2009-09-14 18:47:29 -0500 (Mon, 14 Sep 2009)
New Revision: 3139
Modified:
MOAB/trunk/tools/iMesh/python/iBase_Python.h
MOAB/trunk/tools/iMesh/python/iMesh.c
MOAB/trunk/tools/iMesh/python/iMesh_Python.h
Log:
Finalize C/C++ API for iMesh
Modified: MOAB/trunk/tools/iMesh/python/iBase_Python.h
--- MOAB/trunk/tools/iMesh/python/iBase_Python.h 2009-09-14 22:50:22 UTC (rev 3138)
+++ MOAB/trunk/tools/iMesh/python/iBase_Python.h 2009-09-14 23:47:29 UTC (rev 3139)
@@ -81,7 +81,7 @@
#define NPY_IBASETAG (*(int*) IBase_API[5])
-#if !defined(NO_IMPORT_ARRAY) && !defined(NO_IMPORT)
+#if !defined(NO_IMPORT_IBASE) && !defined(NO_IMPORT)
static int import_iBase(void)
PyObject *module = PyImport_ImportModule("itaps.iBase");
Modified: MOAB/trunk/tools/iMesh/python/iMesh.c
--- MOAB/trunk/tools/iMesh/python/iMesh.c 2009-09-14 22:50:22 UTC (rev 3138)
+++ MOAB/trunk/tools/iMesh/python/iMesh.c 2009-09-14 23:47:29 UTC (rev 3139)
@@ -1,3 +1,4 @@
+#define _IMESH_MODULE
#include "errors.h"
#include "common.h"
#include "iMesh_Python.h"
@@ -6,10 +7,10 @@
static enum iBase_TagValueType char_to_type(char c);
static char type_to_char(enum iBase_TagValueType t);
+static PyTypeObject iMesh_Type;
static PyTypeObject iMeshIter_Type;
static PyTypeObject iMeshEntitySet_Type;
static int NPY_IMESHENTSET;
static PyTypeObject iMeshTag_Type;
static int NPY_IMESHTAG;
@@ -1080,6 +1081,24 @@
import_array();
import_iBase();
+ /***** register C API *****/
+ static void *IMesh_API[6];
+ PyObject *api_obj;
+ /* Initialize the C API pointer array */
+ IMesh_API[0] = &iMesh_Type;
+ IMesh_API[1] = &iMeshIter_Type;
+ IMesh_API[2] = &iMeshEntitySet_Type;
+ IMesh_API[3] = &NPY_IMESHENTSET;
+ IMesh_API[4] = &iMeshTag_Type;
+ IMesh_API[5] = &NPY_IMESHTAG;
+ /* Create a CObject containing the API pointer array's address */
+ api_obj = PyCObject_FromVoidPtr(IMesh_API,NULL);
+ if(api_obj != NULL)
+ PyModule_AddObject(m, "_C_API", api_obj);
/***** import helper module *****/
if( (g_helper_module = PyImport_ImportModule("itaps.helpers")) == NULL)
return;
Modified: MOAB/trunk/tools/iMesh/python/iMesh_Python.h
--- MOAB/trunk/tools/iMesh/python/iMesh_Python.h 2009-09-14 22:50:22 UTC (rev 3138)
+++ MOAB/trunk/tools/iMesh/python/iMesh_Python.h 2009-09-14 23:47:29 UTC (rev 3139)
@@ -60,6 +60,60 @@
( ((iMeshTag_Object*)(o))->mesh )
+#ifndef _IMESH_MODULE
+#if defined(PY_IMESH_UNIQUE_SYMBOL)
+#define IMesh_API PY_IMESH_UNIQUE_SYMBOL
+#endif
+#if defined(NO_IMPORT) || defined(NO_IMPORT_IMESH)
+extern void **IMesh_API;
+#elif defined(PY_IMESH_UNIQUE_SYMBOL)
+void **IMesh_API;
+#else
+static void **IMesh_API = NULL;
+#endif
+#define iMesh_Type (*(PyTypeObject*)IMesh_API[0])
+#define iMeshIter_Type (*(PyTypeObject*)IMesh_API[1])
+#define iMeshEntitySet_Type (*(PyTypeObject*)IMesh_API[2])
+#define NPY_IMESHENTSET (*(int*) IMesh_API[3])
+#define iMeshTag_Type (*(PyTypeObject*)IMesh_API[4])
+#define NPY_IMESHTAG (*(int*) IMesh_API[5])
+#if !defined(NO_IMPORT_IMESH) && !defined(NO_IMPORT)
+static int import_iMesh(void)
+ PyObject *module = PyImport_ImportModule("itaps.iMesh");
+ PyObject *c_api = NULL;
+ if(module == NULL)
+ return -1;
+ c_api = PyObject_GetAttrString(module,"_C_API");
+ if(c_api == NULL)
+ Py_DECREF(module);
+ return -2;
+ if(PyCObject_Check(c_api))
+ IMesh_API = (void **)PyCObject_AsVoidPtr(c_api);
+ Py_DECREF(c_api);
+ if(IMesh_API == NULL)
+ return -3;
+ return 0;
+#endif
+#endif
#ifdef __cplusplus
} // extern "C"
#endif
