[MOAB-dev] MOAB build on windows
    Alfred von Loebbecke
    vonloebbecke at pa.nrl.navy.mil
    Sat Aug 22 15:23:10 CDT 2009
ok, thank you for all the help.
I'm getting one other error inside dagmc:
/tools/dagmc/DagMC.cpp(451): error C2065: 'M_PI' : undeclared identifier
is this the actual value of Pi?
thanks again and regards,
Alfred
James Porter wrote:
> On Thu, 2009-08-20 at 15:26 -0500, Jason Kraftcheck wrote:
>> #ifdef _MSC_VER
>> typedef unsigned _int16 uint16_t
>> #endif
> This is already in MBSysUtil.cpp, but the "hard" part is dealing with
> non-default configurations on Windows, such as #defining
> MOAB_FORCE_64_BIT_HANDLES. That'll probably fail since it uses int64_t
> in MBEntityHandle.h, which isn't defined on Windows either. It looks
> like everything that #includes stdint.h also includes MBEntityHandle.h,
> so I think we should consolidate the inclusions/typedefs to that file.
>> #ifdef _MSC_VER
>> #define finite _finite
>> #endif
> This also runs the risk of us redefining C99 extensions piecemeal. We
> can probably do this for now, but it's something we should keep in mind
> if we start using more C99 features.
> - Jim
