[MOAB-dev] r3114 - MOAB/trunk
    wilsonp at engr.wisc.edu
    Thu Aug 20 20:51:31 CDT 2009
Author: wilsonp
Date: 2009-08-20 20:51:30 -0500 (Thu, 20 Aug 2009)
New Revision: 3114
Added:
   MOAB/trunk/ReadABAQUS.cpp
   MOAB/trunk/ReadABAQUS.hpp
Modified:
   MOAB/trunk/MBReaderWriterSet.cpp
   MOAB/trunk/Makefile.am
Log:
Add support for reading mesh generated for use in ABAQUS.
[Note: these files typiclly use the extension ".inp"
       but that seemed to generic so I set up automatic
       support for ".abq" instead.]
This mesh format implements a part/assembly/instance
paradigm with nodes & elements collected in node sets
and element sets.  This was implemented in MOAB using
tags and meshsets (but no parent-child) relationships.
For example, assembly meshsets contain instance meshsets
and instance meshsets are tagged with the handle of the
assembly meshset that contains them.  At the moment an
extensive set of cross-referencing was done with this
general technique.  This should probably be documented
in more detail for this implementation, but could probably
have portions of it abstracted in order to support other
mesh formats with a similar paradigm.
At this point, the reader supports a limited set of
keywords, largely for determining which material is
in each mesh element.
The reader also only supports a limited set of
ABAQUS element types, but extending for additional types
is straightforward.  The corollary is that the purpose
of this reader is so limited that the type of element
rarely matters beyond mapping it onto the correct
MBEntityType and knowning the correct connectivity size.
Modified: MOAB/trunk/MBReaderWriterSet.cpp
--- MOAB/trunk/MBReaderWriterSet.cpp	2009-08-20 21:32:24 UTC (rev 3113)
+++ MOAB/trunk/MBReaderWriterSet.cpp	2009-08-21 01:51:30 UTC (rev 3114)
@@ -25,6 +25,7 @@
 #include "ReadGmsh.hpp"
 #include "ReadIDEAS.hpp"
 #include "ReadMCNP5.hpp"
+#include "ReadABAQUS.hpp"
 #include "ReadSms.hpp"
 #include "Tqdcfr.hpp"
 #include "ReadTetGen.hpp"
@@ -78,6 +79,8 @@
   register_factory( ReadMCNP5::factory, NULL, "MCNP5 format", "meshtal", "MESHTAL" );
+  register_factory( ReadABAQUS::factory, NULL, "ABAQUS INP mesh format", "abq", "Abaqus mesh" );
   register_factory( ReadVtk::factory, WriteVtk::factory, "Kitware VTK", "vtk", "VTK" );
   register_factory( ReadSms::factory, NULL, "RPI SMS", "sms", "SMS" );
Modified: MOAB/trunk/Makefile.am
--- MOAB/trunk/Makefile.am	2009-08-20 21:32:24 UTC (rev 3113)
+++ MOAB/trunk/Makefile.am	2009-08-21 01:51:30 UTC (rev 3114)
@@ -177,6 +177,8 @@
   ReadIDEAS.hpp \
   ReadMCNP5.cpp \
   ReadMCNP5.hpp \
+  ReadABAQUS.cpp \
+  ReadABAQUS.hpp \
   ReadTetGen.cpp \
   ReadTetGen.hpp \
   ScdElementData.cpp \
Added: MOAB/trunk/ReadABAQUS.cpp
--- MOAB/trunk/ReadABAQUS.cpp	                        (rev 0)
+++ MOAB/trunk/ReadABAQUS.cpp	2009-08-21 01:51:30 UTC (rev 3114)
@@ -0,0 +1,2225 @@
+ * MOAB, a Mesh-Oriented datABase, is a software component for creating,
+ * storing and accessing finite element mesh data.
+ * Copyright 2004 Sandia Corporation.  Under the terms of Contract
+ * DE-AC04-94AL85000 with Sandia Coroporation, the U.S. Government
+ * retains certain rights in this software.
+ * This library is free software; you can redistribute it and/or
+ * modify it under the terms of the GNU Lesser General Public
+ * License as published by the Free Software Foundation; either
+ * version 2.1 of the License, or (at your option) any later version.
+#ifdef WIN32
+#pragma warning(disable:4786)
+#endif
+#include <algorithm>
+#include <time.h>
+#include <string>
+#include <assert.h>
+#include <stdio.h>
+#include <cmath>
+#include "MBCN.hpp"
+#include "MBRange.hpp"
+#include "MBInterface.hpp"
+#include "MBTagConventions.hpp"
+#include "MBInternals.hpp"
+#include "MBReadUtilIface.hpp"
+#include "MBAffineXform.hpp"
+// #include "abaqus_order.h"
+#include "FileOptions.hpp"
+#define ABQ_AMBIGUOUS "AMBIGUOUS"
+#define ABQ_UNDEFINED "UNDEFINED"
+#define DEG2RAD 0.017453292519943295769236907684886
+#define MB_RETURN_IF_FAIL if (MB_SUCCESS != status) return status
+MBReaderIface* ReadABAQUS::factory( MBInterface* iface )
+  { return new ReadABAQUS( iface ); }
+ReadABAQUS::ReadABAQUS(MBInterface* impl)
+  : mdbImpl(impl)
+  assert(impl != NULL);
+  reset();
+  void* ptr = 0;
+  impl->query_interface( "MBReadUtilIface", &ptr );
+  readMeshIface = reinterpret_cast<MBReadUtilIface*>(ptr);
+  // initialize in case tag_get_handle fails below
+  mMaterialSetTag  = 0;
+  mDirichletSetTag = 0;
+  mNeumannSetTag   = 0;
+  mHasMidNodesTag  = 0;
+  mSetTypeTag        = 0;
+  mPartHandleTag     = 0;
+  mInstancePIDTag    = 0;
+  mInstanceGIDTag    = 0;
+  mLocalIDTag        = 0;
+  mInstanceHandleTag = 0;
+  mAssemblyHandleTag = 0;
+  mSetNameTag        = 0;
+  mMatNameTag        = 0;
+  mat_id             = 0;
+  //! get and cache predefined tag handles
+  mMaterialSetTag  = get_tag(MATERIAL_SET_TAG_NAME,   sizeof(int),MB_TAG_SPARSE,MB_TYPE_INTEGER);
+  mDirichletSetTag = get_tag(DIRICHLET_SET_TAG_NAME,  sizeof(int),MB_TAG_SPARSE,MB_TYPE_INTEGER);
+  mNeumannSetTag   = get_tag(NEUMANN_SET_TAG_NAME,    sizeof(int),MB_TAG_SPARSE,MB_TYPE_INTEGER);
+  int def_val[4] = {0,0,0,0};
+  mHasMidNodesTag  = get_tag(HAS_MID_NODES_TAG_NAME,4*sizeof(int),MB_TAG_SPARSE,MB_TYPE_INTEGER,def_val);
+  mSetTypeTag        = get_tag(ABAQUS_SET_TYPE_TAG_NAME,          sizeof(int),           MB_TAG_SPARSE,MB_TYPE_INTEGER);
+  mPartHandleTag     = get_tag(ABAQUS_PART_HANDLE_TAG_NAME,       sizeof(MBEntityHandle),MB_TAG_SPARSE,MB_TYPE_HANDLE);
+  mInstanceHandleTag = get_tag(ABAQUS_INSTANCE_HANDLE_TAG_NAME,   sizeof(MBEntityHandle),MB_TAG_DENSE, MB_TYPE_HANDLE);
+  mAssemblyHandleTag = get_tag(ABAQUS_ASSEMBLY_HANDLE_TAG_NAME,   sizeof(MBEntityHandle),MB_TAG_DENSE, MB_TYPE_HANDLE);
+  mInstancePIDTag    = get_tag(ABAQUS_INSTANCE_PART_ID_TAG_NAME,  sizeof(int),           MB_TAG_SPARSE,MB_TYPE_INTEGER);
+  mInstanceGIDTag    = get_tag(ABAQUS_INSTANCE_GLOBAL_ID_TAG_NAME,sizeof(int),           MB_TAG_SPARSE,MB_TYPE_INTEGER);
+  mLocalIDTag        = get_tag(ABAQUS_LOCAL_ID_TAG_NAME,          sizeof(int),           MB_TAG_DENSE, MB_TYPE_INTEGER);
+  mSetNameTag        = get_tag(ABAQUS_SET_NAME_TAG_NAME,         ABAQUS_SET_NAME_LENGTH, MB_TAG_SPARSE,MB_TYPE_OPAQUE,0);
+  mMatNameTag        = get_tag(ABAQUS_MAT_NAME_TAG_NAME,         ABAQUS_MAT_NAME_LENGTH, MB_TAG_SPARSE,MB_TYPE_OPAQUE,0);
+void ReadABAQUS::reset()
+ReadABAQUS::~ReadABAQUS()
+  std::string iface_name = "MBReadUtilIface";
+  mdbImpl->release_interface(iface_name, readMeshIface);
+  if (NULL != abFile)
+    abFile.close();
+MBErrorCode ReadABAQUS::check_file_stats()
+* check for existence of file
+* initialize meshsets, and offsets if necessary
+MBErrorCode ReadABAQUS::read_tag_values( const char* /* file_name */,
+					 const char* /* tag_name */,
+					 const FileOptions& /* opts */,
+					 std::vector<int>& /* tag_values_out */,
+					 const IDTag* /* subset_list */,
+					 int /* subset_list_length */ )
+  return MB_NOT_IMPLEMENTED;
+MBErrorCode ReadABAQUS::load_file(const char *abaqus_file_name,
+				  MBEntityHandle& file_set,
+				  const FileOptions& opts,
+				  const MBReaderIface::IDTag* subset_list,
+				  int subset_list_length,
+				  const MBTag* file_id_tag)
+  MBErrorCode status;
+  // open file
+  abFile.open(abaqus_file_name);
+  bool in_unsupported = false;
+  // initialize meshset, etc
+  status = mdbImpl->create_meshset(MESHSET_SET, file_set);
+  MB_RETURN_IF_FAIL;
+  next_line_type = get_next_line_type();
+  while (next_line_type != abq_eof)
+      switch (next_line_type)
+	case abq_keyword_line:
+	  in_unsupported=false;
+	  switch (get_keyword())
+	    case abq_heading:
+	      // read header
+	      status = read_heading(file_set);
+	      break;
+	    case abq_part:
+	      // read parts until done
+	      status = read_part(file_set);
+	      break;
+	    case abq_assembly:
+	      // read assembly (or assemblies?)
+	      status = read_assembly(file_set);
+	      break;
+	    default:
+	      // skip reading other content for now
+	      // (e.g. material properties, loads, surface interactions, etc)
+	      in_unsupported = true;
+	      // std::cout << "Ignoring unsupported keyword: " << readline << std::endl;
+	  break;
+	case abq_comment_line:
+	  break;
+	case abq_data_line:
+	  if (!in_unsupported)
+	      std::cerr << "Internal Error: found ABAQUS data line outside a keyword block."
+			<< std::endl << readline << std::endl;
+	      return MB_FAILURE;
+	  break;
+	default:
+	  std::cerr << "Internal Error: found unrecognized ABAQUS line."
+  // temporary??? delete parts
+  // get all node sets in part
+  MBRange part_sets;
+  int tag_val = ABQ_PART_SET;
+  void* tag_data[] = {&tag_val};
+  status = mdbImpl->get_entities_by_type_and_tag(file_set,
+						 MBENTITYSET,
+						 &mSetTypeTag,
+						 tag_data, 1, part_sets);
+  for (MBRange::iterator part_set = part_sets.begin();
+       part_set != part_sets.end();
+       part_set++)
+      MBRange ent_sets;
+      tag_val = ABQ_NODE_SET;
+      tag_data[0] = &tag_val;
+      status = mdbImpl->get_entities_by_type_and_tag(*part_set,
+						     MBENTITYSET,
+						     &mSetTypeTag,
+						     tag_data, 1, ent_sets);
+      status = mdbImpl->delete_entities(ent_sets);
+      tag_val = ABQ_ELEMENT_SET;
+						     MBENTITYSET,
+						     &mSetTypeTag,
+      MBRange node_list,ele_list;
+      status = get_set_elements(*part_set,ele_list);
+      status = mdbImpl->delete_entities(ele_list);
+      status = mdbImpl->get_entities_by_dimension(*part_set,0,node_list);
+      status = mdbImpl->delete_entities(node_list);
+  return MB_SUCCESS;
+MBErrorCode ReadABAQUS::read_heading(MBEntityHandle file_set)
+  std::vector<std::string> tokens;
+  // current line is only heading token. get next line
+  // perhaps keep first line and tag gometry with title?
+  while (abq_data_line    == next_line_type ||
+	 abq_comment_line == next_line_type   )
+MBErrorCode ReadABAQUS::read_assembly(MBEntityHandle file_set)
+  MBErrorCode status = MB_SUCCESS;
+  std::map<std::string,std::string> params;
+  std::map<std::string,abaqus_assembly_params> requiredParams;
+  requiredParams["NAME"]         = abq_assembly_name;
+  std::map<std::string,abaqus_assembly_params> allowableParams;
+  allowableParams[ABQ_AMBIGUOUS] = abq_assembly_ambiguous;
+  abaqus_assembly_params param;
+  std::string assembly_name;
+  // tokenize last line read
+  tokenize(readline,tokens,",\n");
+  extract_keyword_parameters(tokens,params);
+  // search for required parameters
+  for (std::map<std::string,abaqus_assembly_params>::iterator thisParam=requiredParams.begin();
+       thisParam != requiredParams.end();
+       thisParam++)
+      std::string param_key = match( (*thisParam).first,params );
+      param = requiredParams[param_key];
+      switch (param)
+	case abq_assembly_name:
+	  assembly_name = params[param_key];
+	  params.erase(param_key);
+	  // std::cout << "Adding ASSEMBLY with name: " << assembly_name << std::endl; // REMOVE
+	  break;
+	default:
+	  // std::cout << "Missing required ASSEMBLY parameter " << (*thisParam).first << std::endl;
+  // process parameters
+  for (std::map<std::string,std::string>::iterator thisParam=params.begin();
+       thisParam != params.end();
+       thisParam++)
+      // look for unambiguous match with this node parameter
+      param = allowableParams[match( (*thisParam).first, allowableParams )];
+      switch (param)
+	case abq_assembly_ambiguous:
+	  // std::cout << "\tIgnoring ambiguous ASSEMBLY parameter: " << (*thisParam).first
+	  //	    << "=" << (*thisParam).second << std::endl;
+	  break;
+	default:
+	  // std::cout << "\tIgnoring unsupported ASSEMBLY parameter: " << (*thisParam).first
+	  break;
+  MBEntityHandle assembly_set;
+  status = add_entity_set(file_set,ABQ_ASSEMBLY_SET,assembly_name,assembly_set);
+  bool end_assembly = false;
+  while (next_line_type != abq_eof && !end_assembly)
+      switch(next_line_type)
+	  in_unsupported = false;
+	  switch(get_keyword())
+	    case abq_end_assembly:
+	      end_assembly = true;
+	      break;
+	    case abq_instance:
+	      status = read_instance(assembly_set,file_set);
+	      break;
+	    case abq_nset:
+	      status = read_node_set(assembly_set,file_set);
+	      break;
+	    default:
+	      // std::cout << "\tIgnoring unsupported keyword in this ASSEMBLY: "
+	      //		<< readline << std::endl;
+	      break;
+	  break;
+	  break;
+	      // std::cout << "Internal Error: Data lines not allowed in ASSEMBLY keyword."
+	      //		<< std::endl << readline << std::endl;
+	  break;
+	case abq_blank_line:
+	  // std::cout << "Error: Blank lines are not allowed." << std::endl;
+	default:
+	  // std::cout << "Error reading ASSEMBLY " << assembly_name << std::endl;
+  num_assembly_instances[assembly_set] = 0;
+MBErrorCode ReadABAQUS::read_instance(MBEntityHandle assembly_set,MBEntityHandle file_set)
+  std::map<std::string,abaqus_instance_params> requiredParams;
+  requiredParams["NAME"]         = abq_instance_name;
+  requiredParams["PART"]         = abq_instance_part;
+  std::map<std::string,abaqus_instance_params> allowableParams;
+  allowableParams[ABQ_AMBIGUOUS] = abq_instance_ambiguous;
+  abaqus_instance_params param;
+  std::string instance_name,part_name;
+  for (std::map<std::string,abaqus_instance_params>::iterator thisParam=requiredParams.begin();
+       thisParam++)
+      switch (param)
+	case abq_instance_name:
+	  instance_name = params[param_key];
+	  break;
+	case abq_instance_part:
+	  part_name = params[param_key];
+	  break;
+	default:
+	  // std::cout << "Missing required INSTANCE parameter " << (*thisParam).first << std::endl;
+  // std::cout << "\tAdding INSTANCE with name: " << instance_name << " of PART wit name: " << part_name <<  std::endl; // REMOVE
+       thisParam++)
+      switch (param)
+	case abq_instance_ambiguous:
+	  // std::cout << "\t\tIgnoring ambiguous INSTANCE parameter: " << (*thisParam).first
+	  break;
+	default:
+	  // std::cout << "\t\tIgnoring unsupported INSTANCE parameter: " << (*thisParam).first
+	  break;
+  bool read_translation = false;
+  bool read_rotation = false;
+  std::vector<double> translation(3,0);
+  std::vector<double> rotation(7,0);
+  bool end_instance = false;
+  while (next_line_type != abq_eof && !end_instance)
+	    case abq_end_instance:
+	      end_instance = true;
+	      break;
+	    default:
+	      // std::cout << "\t\tIgnoring unsupported keyword in this INSTANCE: "
+	      break;
+	  break;
+	      tokenize(readline,tokens,", \n");
+	      if (!read_translation)
+		  if (tokens.size() != 3)
+		      std::cerr << "Wrong number of entries on INSTANCE translation line:"
+		  for (unsigned int i=0;i<3;i++)
+		    translation[i] = atof(tokens[i].c_str());
+		  read_translation = true;
+	      else
+		if (!read_rotation)
+		    if (tokens.size() != 7)
+			std::cerr << "Wrong number of entries on INSTANCE rotation line:"
+		    for (unsigned int i=0;i<7;i++)
+		      rotation[i] = atof(tokens[i].c_str());
+		    read_rotation = true;
+		else
+		    std::cerr << "Too many data lines for this INSTANCE: " << instance_name << std::endl;
+	  break;
+	  std::cerr << "Error: Blank lines are not allowed." << std::endl;
+	default:
+	  std::cerr << "Error reading INSTANCE " << instance_name << std::endl;
+  MBEntityHandle instance_set;
+  status = create_instance_of_part(file_set,assembly_set,part_name,
+				   instance_name,instance_set,translation,rotation);
+MBErrorCode ReadABAQUS::read_part(MBEntityHandle file_set)
+  std::map<std::string,abaqus_part_params> requiredParams;
+  requiredParams["NAME"]         = abq_part_name;
+  std::map<std::string,abaqus_part_params> allowableParams;
+  allowableParams[ABQ_AMBIGUOUS] = abq_part_ambiguous;
+  abaqus_part_params param;
+  std::string part_name;
+  for (std::map<std::string,abaqus_part_params>::iterator thisParam=requiredParams.begin();
+       thisParam++)
+      switch (param)
+	case abq_part_name:
+	  // std::cout << "Adding PART with name: " << part_name << std::endl; // REMOVE
+	  break;
+	default:
+	  std::cerr << "Missing required PART parameter " << (*thisParam).first << std::endl;
+       thisParam++)
+      switch (param)
+	case abq_part_ambiguous:
+	  // std::cout << "\tIgnoring ambiguous PART parameter: " << (*thisParam).first
+	  break;
+	default:
+	  // std::cout << "\tIgnoring unsupported PART parameter: " << (*thisParam).first
+	  break;
+  MBEntityHandle part_set;
+  status = add_entity_set(file_set,ABQ_PART_SET,part_name,part_set);
+  bool end_part = false;
+  while (next_line_type != abq_eof && !end_part)
+	    case abq_end_part:
+	      end_part = true;
+	      break;
+	    case abq_node:
+	      status = read_node_list(part_set);
+	      break;
+	    case abq_element:
+	      status = read_element_list(part_set);
+	      break;
+	    case abq_nset:
+	      status = read_node_set(part_set);
+	      break;
+	    case abq_elset:
+	      status = read_element_set(part_set);
+	      break;
+	    case abq_solid_section:
+	      status = read_solid_section(part_set);
+	      break;
+	    default:
+	      // std::cout << "\tIgnoring unsupported keyword in this PART: "
+	      break;
+	  break;
+	  break;
+	      std::cerr << "Internal Error: Data lines not allowed in PART keyword."
+	  break;
+	default:
+	  std::cerr << "Error reading PART " << part_name << std::endl;
+  num_part_instances[part_set] = 0;
+MBErrorCode ReadABAQUS::read_solid_section(MBEntityHandle parent_set)
+  std::map<std::string,abaqus_solid_section_params> requiredParams;
+  requiredParams["ELSET"]         = abq_solid_section_elset;
+  requiredParams["MATERIAL"]      = abq_solid_section_matname;
+  std::map<std::string,abaqus_solid_section_params> allowableParams;
+  allowableParams[ABQ_AMBIGUOUS] = abq_solid_section_ambiguous;
+  abaqus_solid_section_params param;
+  std::string elset_name,mat_name;
+  for (std::map<std::string,abaqus_solid_section_params>::iterator thisParam=requiredParams.begin();
+       thisParam++)
+      switch (param)
+	case abq_solid_section_elset:
+	  elset_name =  params[param_key];
+	  break;
+	case abq_solid_section_matname:
+	  mat_name =  params[param_key];
+	  break;
+	default:
+	  std::cerr << "Missing required SOLID SECTION parameter " << (*thisParam).first << std::endl;
+  // std::cout << "\tAdding SOLID SECTION with to ELEMENT SET: " << elset_name << " with material: " << mat_name << std::endl; // REMOVE
+       thisParam++)
+      switch (param)
+	case abq_solid_section_ambiguous:
+	  // std::cout << "\t\tIgnoring ambiguous SOLID_SECTION parameter: " << (*thisParam).first
+	  break;
+	default:
+	  // std::cout << "\t\tIgnoring unsupported SOLID_SECTION parameter: " << (*thisParam).first
+	  break;
+  MBEntityHandle set_handle;
+  status = get_set_by_name(parent_set,ABQ_ELEMENT_SET,elset_name,set_handle);
+  status = mdbImpl->tag_set_data(mMatNameTag,&set_handle,1,mat_name.c_str());
+  if (0 == matIDmap[mat_name])
+    matIDmap[mat_name] = ++mat_id;
+  status = mdbImpl->tag_set_data(mMaterialSetTag,&set_handle,1,&(matIDmap[mat_name]));
+	 next_line_type != abq_keyword_line)
+MBErrorCode ReadABAQUS::read_element_set(MBEntityHandle parent_set, MBEntityHandle file_set, MBEntityHandle assembly_set)
+  std::map<std::string,abaqus_elset_params> requiredParams;
+  requiredParams["ELSET"]         = abq_elset_elset;
+  std::map<std::string,abaqus_elset_params> allowableParams;
+  allowableParams[ABQ_AMBIGUOUS] = abq_elset_ambiguous;
+  allowableParams["GENERATE"]    = abq_elset_generate;
+  allowableParams["INSTANCE"]    = abq_elset_instance;
+  abaqus_elset_params param;
+  std::string elset_name;
+  bool generate_elset = false;
+  std::string instance_name;
+  MBEntityHandle element_container_set = parent_set;
+  MBRange element_range;
+  for (std::map<std::string,abaqus_elset_params>::iterator thisParam=requiredParams.begin();
+       thisParam++)
+      switch (param)
+	case abq_elset_elset:
+	  // std::cout << "\tAdding ELSET with name: " << elset_name << std::endl; // REMOVE
+	  break;
+	default:
+	  std::cerr << "Missing required ELSET parameter " << (*thisParam).first << std::endl;
+       thisParam++)
+      switch (param)
+	case abq_elset_generate:
+	  generate_elset = true;
+	  break;
+	case abq_elset_instance:
+	  instance_name = (*thisParam).second;
+	  status = get_set_by_name(parent_set,ABQ_INSTANCE_SET,instance_name,element_container_set);
+	  break;
+	case abq_elset_ambiguous:
+	  // std::cout << "\t\tIgnoring ambiguous ELSET parameter: " << (*thisParam).first
+	  break;
+	default:
+	  // std::cout << "\t\tIgnoring unsupported ELSET parameter: " << (*thisParam).first
+	  break;
+  std::vector<int> element_list;
+  MBRange tmp_element_range;
+      if (abq_data_line == next_line_type)
+	  if (generate_elset)
+		  std::cerr << "Wrong number (" << tokens.size() << ") of entries on GENERATE element set data line:"
+	      int e1 = atoi(tokens[0].c_str());
+	      int e2 = atoi(tokens[1].c_str());
+	      int incr = atoi(tokens[2].c_str());
+	      if ( ( (e2-e1)%incr ) != 0)
+		  std::cerr << "Invalid data on GENERATE element set data line:"
+	      for (int element_id=e1; element_id<=e2;element_id+=incr)
+		element_list.push_back(element_id);
+	  else
+	    for (unsigned int idx=0;idx<tokens.size();idx++)
+	      if(isalpha(tokens[idx][0]))
+		  tmp_element_range.clear();
+		  status = get_set_elements_by_name(element_container_set,ABQ_ELEMENT_SET,tokens[idx],tmp_element_range);
+		  element_range.merge(tmp_element_range);
+	      else
+		element_list.push_back(atoi(tokens[idx].c_str()));
+  status = get_elements_by_id(element_container_set,element_list,tmp_element_range);
+  MBEntityHandle element_set;
+  status = add_entity_set(parent_set,ABQ_ELEMENT_SET,elset_name,element_set);
+  status = mdbImpl->add_entities(element_set,element_range);
+  // SHOULD WE EVER DO THIS???
+  if (file_set)
+      status = mdbImpl->add_entities(file_set,&element_set,1);
+  if (assembly_set)
+      status = mdbImpl->add_entities(assembly_set,&element_set,1);
+      status = mdbImpl->tag_set_data(mAssemblyHandleTag,&element_set,1,&assembly_set);
+MBErrorCode ReadABAQUS::read_node_set(MBEntityHandle parent_set,MBEntityHandle file_set, MBEntityHandle assembly_set)
+  std::map<std::string,abaqus_nset_params> requiredParams;
+  requiredParams["NSET"]         = abq_nset_nset;
+  std::map<std::string,abaqus_nset_params> allowableParams;
+  allowableParams[ABQ_AMBIGUOUS] = abq_nset_ambiguous;
+  allowableParams["ELSET"]       = abq_nset_elset;
+  allowableParams["GENERATE"]    = abq_nset_generate;
+  allowableParams["INSTANCE"]    = abq_nset_instance;
+  abaqus_nset_params param;
+  std::string nset_name;
+  bool make_from_elset = false;
+  bool generate_nset = false;
+  std::string elset_name, instance_name;
+  MBEntityHandle node_container_set = parent_set;
+  MBRange node_range;
+  for (std::map<std::string,abaqus_nset_params>::iterator thisParam=requiredParams.begin();
+       thisParam++)
+      switch (param)
+	case abq_nset_nset:
+	  nset_name =  params[param_key];
+	  // std::cout << "\tAdding NSET with name: " << nset_name << std::endl; // REMOVE
+	  break;
+	default:
+	  std::cerr << "Missing required NSET parameter " << (*thisParam).first << std::endl;
+       thisParam++)
+      switch (param)
+	case abq_nset_elset:
+	  make_from_elset = true;
+	  elset_name = (*thisParam).second;
+	  break;
+	case abq_nset_generate:
+	  generate_nset = true;
+	  break;
+	case abq_nset_instance:
+	  status = get_set_by_name(parent_set, ABQ_INSTANCE_SET, instance_name,node_container_set);
+	  break;
+	case abq_nset_ambiguous:
+	  // std::cout << "\t\tIgnoring ambiguous NSET parameter: " << (*thisParam).first
+	  break;
+	default:
+	  // std::cout << "\t\tIgnoring unsupported NSET parameter: " << (*thisParam).first
+	  break;
+  if (make_from_elset && generate_nset)
+      std::cerr << "Incompatible NSET parameters ELSET & GENERATE " << std::endl;
+  if (make_from_elset)
+      status = get_set_nodes(parent_set,ABQ_ELEMENT_SET,elset_name,node_range);
+  else
+      std::vector<int> node_list;
+      MBRange tmp_node_range;
+	      if (generate_nset)
+		      std::cerr << "Wrong number of entries on GENERATE node set data line:"
+		  int n1 = atoi(tokens[0].c_str());
+		  int n2 = atoi(tokens[1].c_str());
+		  if ( ( (n2-n1) % incr ) != 0)
+		      std::cerr << "Invalid data on GENERATE node set data line:"
+		  for (int node_id=n1; node_id<=n2;node_id+=incr)
+		    node_list.push_back(node_id);
+	      else
+		      tmp_node_range.clear();
+		      status = get_set_nodes(parent_set,ABQ_NODE_SET,tokens[idx],tmp_node_range);
+		      node_range.merge(tmp_node_range);
+		  else
+		    node_list.push_back(atoi(tokens[idx].c_str()));
+      status = get_nodes_by_id(node_container_set,node_list,tmp_node_range);
+  MBEntityHandle node_set;
+  status = add_entity_set(parent_set,ABQ_NODE_SET,nset_name,node_set);
+  status = mdbImpl->add_entities(node_set,node_range);
+  if (file_set)
+      status = mdbImpl->add_entities(file_set,&node_set,1);
+  if (assembly_set)
+      status = mdbImpl->add_entities(assembly_set,&node_set,1);
+      status = mdbImpl->tag_set_data(mAssemblyHandleTag,&node_set,1,&assembly_set);
+MBErrorCode ReadABAQUS::read_element_list(MBEntityHandle parent_set)
+  std::map<std::string,abaqus_element_params> requiredParams;
+  requiredParams["TYPE"]         = abq_element_type;
+  std::map<std::string,abaqus_element_params> allowableParams;
+  allowableParams[ABQ_AMBIGUOUS] = abq_element_ambiguous;
+  allowableParams["ELSET"]       = abq_element_elset;
+  abaqus_element_params param;
+  std::map<std::string,abaqus_element_type> elementTypes;
+  std::map<abaqus_element_type,unsigned int> nodes_per_element;
+  std::map<abaqus_element_type,MBEntityType> entityTypeMap;
+  elementTypes["DC3D8"]                 = abq_eletype_dc3d8;
+  nodes_per_element[abq_eletype_dc3d8]  = 8;
+  entityTypeMap[abq_eletype_dc3d8]      = MBHEX;
+  elementTypes["DCC3D8"]                = abq_eletype_dcc3d8;
+  nodes_per_element[abq_eletype_dcc3d8] = 8;
+  entityTypeMap[abq_eletype_dcc3d8]     = MBHEX;
+  elementTypes["C3D4"]                  = abq_eletype_c3d4;
+  nodes_per_element[abq_eletype_c3d4]   = 4;
+  entityTypeMap[abq_eletype_c3d4]       = MBTET;
+  elementTypes["C3D8R"]                 = abq_eletype_c3d8r;
+  nodes_per_element[abq_eletype_c3d8r]  = 8;
+  entityTypeMap[abq_eletype_c3d8r]      = MBHEX;
+  elementTypes["DS4"]                   = abq_eletype_ds4;
+  nodes_per_element[abq_eletype_ds4]    = 4;
+  entityTypeMap[abq_eletype_ds4]        = MBQUAD;
+  abaqus_element_type element_type;
+  bool make_element_set = false;
+  std::string element_set_name;
+  for (std::map<std::string,abaqus_element_params>::iterator thisParam=requiredParams.begin();
+       thisParam++)
+      switch (param)
+	case abq_element_type:
+	  element_type = elementTypes[ params[param_key]];
+	  if (abq_eletype_unsupported == element_type)
+	      std::cerr << "MOAB doesn't currently support this element type: "
+			<< (*thisParam).second << std::endl;
+	  // std::cout << "\tAdding ELEMENTS of type: " << params[param_key] << std::endl; // REMOVE
+	  break;
+	case abq_element_undefined:
+	  std::cerr << "Missing required ELEMENT parameter " << (*thisParam).first << std::endl
+		    << readline << std::endl;
+	default:
+	  break;
+       thisParam++)
+      switch (param)
+	case abq_element_elset:
+	  make_element_set = true;
+	  element_set_name = (*thisParam).second;
+	  break;
+	case abq_element_ambiguous:
+	  // std::cout << "\t\tIgnoring ambiguous ELEMENT parameter: " << (*thisParam).first
+	  break;
+	default:
+	  // std::cout << "\t\tIgnoring unsupported ELEMENT parameter: " << (*thisParam).first
+	  break;
+  std::vector<int> connect_list, element_ids;
+	  if (tokens.size() < nodes_per_element[element_type]+1)
+	      std::cerr << "Not enough data on node data line:"
+	  element_ids.push_back(atoi(tokens[0].c_str()));
+	  for (unsigned int i=1;i<nodes_per_element[element_type]+1;i++)
+	    connect_list.push_back(atoi(tokens[i].c_str()));
+  int num_elements = element_ids.size();
+  // get and fill element arrays
+  MBEntityHandle start_element = 0;
+  MBEntityHandle *connect;
+  status = readMeshIface->get_element_array( num_elements, nodes_per_element[element_type],
+					     entityTypeMap[element_type], MB_START_ID,
+					     start_element, connect);
+  if (0 == start_element) return MB_FAILURE;
+  // ASSUME: elements must be defined after nodes!
+  // get list of node entity handles and node IDs
+  MBRange node_list;
+  status = mdbImpl->get_entities_by_dimension(parent_set, 0, node_list);
+  std::vector<int> node_ids(node_list.size());
+  status = mdbImpl->tag_get_data(mLocalIDTag,node_list,&node_ids[0]);
+  std::map<int,MBEntityHandle> nodeIdMap;
+  for (unsigned int idx=0;idx<node_list.size();idx++)
+    nodeIdMap[node_ids[idx]] = node_list[idx];
+  for (unsigned int node=0;node<connect_list.size();node++)
+    connect[node] = nodeIdMap[connect_list[node]];
+  MBRange element_range(start_element, start_element+num_elements-1);
+  // add elements to file_set
+  // status = mdbImpl->add_entities(file_set,element_range);
+  // MB_RETURN_IF_FAIL;
+  // add elements to this parent_set
+  status = mdbImpl->add_entities(parent_set,element_range);
+  // tag elements with their local ID's
+  status = mdbImpl->tag_set_data(mLocalIDTag,element_range,&element_ids[0]);
+  // these elements don't know their instance_set (probably not defined)
+  if (make_element_set)
+      status = add_entity_set(parent_set,ABQ_ELEMENT_SET,element_set_name,element_set);
+      // this ad-hoc element set doesn't know its:
+      // * part_set (probably parent_set)
+      // * instance_set (probably not defined)
+      // * assembly_set (probably not defined)
+MBErrorCode ReadABAQUS::read_node_list(MBEntityHandle parent_set)
+  std::map<std::string,abaqus_node_params> allowableParams;
+  allowableParams[ABQ_AMBIGUOUS] = abq_node_ambiguous;
+  allowableParams["NSET"]        = abq_node_nset;
+  allowableParams["SYSTEM"]      = abq_node_system;
+  abaqus_node_params param;
+  bool make_node_set = false;
+  std::string node_set_name;
+  char coord_system = 'R';
+  // std::cout << "\tAdding NODES"  << std::endl; // REMOVE
+       thisParam++)
+      switch (param)
+	case abq_node_nset:
+	  make_node_set = true;
+	  node_set_name = (*thisParam).second;
+	  break;
+	case abq_node_system:
+	  // store coordinate system
+	  coord_system = (*thisParam).second[0];
+	  break;
+	case abq_node_ambiguous:
+	  // std::cout << "\t\tIgnoring ambiguous NODE parameter: " << (*thisParam).first
+	  break;
+	default:
+	  // std::cout << "\t\tIgnoring unsupported NODE parameter: " << (*thisParam).first
+	  break;
+  std::vector<double> coord_list;
+  std::vector<int> node_ids;
+	  if (tokens.size() < 4)
+	  node_ids.push_back(atoi(tokens[0].c_str()));
+	  for (unsigned int i=1;i<4;i++)
+	    coord_list.push_back(atof(tokens[i].c_str()));
+  unsigned int num_nodes = node_ids.size();
+  // transform coordinate systems
+  switch (coord_system)
+    case 'R':
+      break;
+    case 'C':
+      cyl2rect(coord_list);
+      break;
+    case 'S':
+      sph2rect(coord_list);
+      break;
+    default:
+      // std::cout << "Treating undefined coordinate system: " << coord_system
+      //		<< " as rectangular/Cartesian." << std::endl;
+      break;
+  // get and fill coordinate arrays
+  std::vector<double*> coord_arrays(3);
+  MBEntityHandle start_node = 0;
+  status = readMeshIface->get_node_arrays(3, num_nodes,MB_START_ID,
+					  start_node,coord_arrays);
+  if (0 == start_node) return MB_FAILURE;
+  for (unsigned int idx=0;idx<num_nodes;idx++)
+      coord_arrays[0][idx] = coord_list[idx*3];
+      coord_arrays[1][idx] = coord_list[idx*3+1];
+      coord_arrays[2][idx] = coord_list[idx*3+2];
+  MBRange node_range(start_node, start_node+num_nodes-1);
+  // add nodes to file_set
+  // status = mdbImpl->add_entities(file_set,node_range);
+  // add nodes to this parent_set
+  status = mdbImpl->add_entities(parent_set,node_range);
+  // tag nodes with their local ID's
+  status = mdbImpl->tag_set_data(mLocalIDTag,node_range,&node_ids[0]);
+  // these nodes don't know their instance_set (probably not defined)
+  if (make_node_set)
+      status = add_entity_set(parent_set,ABQ_NODE_SET,node_set_name,node_set);
+      // this ad-hoc node set doesn't know its:
+// SET CREATION & ACCESS UTILITIES
+MBErrorCode ReadABAQUS::get_elements_by_id(MBEntityHandle parent_set,
+					   std::vector<int> element_ids_subset,
+					   MBRange &element_range)
+  MBRange all_elements;
+  status = get_set_elements(parent_set,all_elements);
+  std::vector<int> element_ids(all_elements.size());
+  status = mdbImpl->tag_get_data(mLocalIDTag,all_elements,&element_ids[0]);
+  std::map<int,MBEntityHandle> elementIdMap;
+  for (unsigned int idx=0;idx<all_elements.size();idx++)
+    elementIdMap[element_ids[idx]] = all_elements[idx];
+  for (std::vector<int>::iterator element=element_ids_subset.begin();
+       element != element_ids_subset.end();
+       element++)
+    element_range.insert(elementIdMap[*element]);
+MBErrorCode ReadABAQUS::get_nodes_by_id(MBEntityHandle parent_set,
+					std::vector<int> node_ids_subset,
+					MBRange &node_range)
+  MBRange all_nodes;
+  status = mdbImpl->get_entities_by_type(parent_set,MBVERTEX,all_nodes);
+  std::vector<int> node_ids(all_nodes.size());
+  status = mdbImpl->tag_get_data(mLocalIDTag,all_nodes,&node_ids[0]);
+  for (unsigned int idx=0;idx<all_nodes.size();idx++)
+    nodeIdMap[node_ids[idx]] = all_nodes[idx];
+  for (std::vector<int>::iterator node=node_ids_subset.begin();
+       node != node_ids_subset.end();
+       node++)
+      node_range.insert(nodeIdMap[*node]);
+MBErrorCode ReadABAQUS::get_set_by_name(MBEntityHandle parent_set,
+					int ABQ_set_type,
+					std::string set_name,
+					MBEntityHandle &set_handle)
+  char this_set_name[ABAQUS_SET_NAME_LENGTH];
+  set_handle = 0;
+  MBRange sets;
+  void* tag_data[] = {&ABQ_set_type};
+  status = mdbImpl->get_entities_by_type_and_tag(parent_set,
+						 MBENTITYSET,
+						 &mSetTypeTag,
+						 tag_data, 1, sets);
+  if (MB_SUCCESS != status)
+      std::cerr << "Did not find any sets of that type" << std::endl;
+      return status;
+  for (MBRange::iterator this_set=sets.begin();
+       this_set != sets.end() && 0 == set_handle;
+       this_set++)
+      std::fill(this_set_name,this_set_name+ABAQUS_SET_NAME_LENGTH,'\0');
+      status = mdbImpl->tag_get_data(mSetNameTag, &(*this_set), 1, &this_set_name[0]);
+      if (MB_SUCCESS != status && MB_TAG_NOT_FOUND != status) return status;
+      if (set_name == std::string(this_set_name))
+	set_handle = *this_set;
+  if (0 == set_handle)
+      std::cerr << "Did not find requested set: " << set_name
+		<< std::endl;
+MBErrorCode ReadABAQUS::get_set_elements(MBEntityHandle set_handle,
+  MBRange dim_ent_list;
+  // could have elements of multiple dimensions in this set???
+  for (int dim=1;dim<=3;dim++)
+      dim_ent_list.clear();
+      status = mdbImpl->get_entities_by_dimension(set_handle,dim,dim_ent_list);
+      element_range.merge(dim_ent_list);
+MBErrorCode ReadABAQUS::get_set_elements_by_name(MBEntityHandle parent_set,
+						 int ABQ_set_type,
+  status = get_set_by_name(parent_set,ABQ_set_type,set_name,set_handle);
+  status = get_set_elements(set_handle,element_range);
+  if (element_range.size() == 0)
+      //std::cout << "No elements were found in set " << set_name << std::endl;
+MBErrorCode ReadABAQUS::get_set_nodes(MBEntityHandle parent_set,
+				      int ABQ_set_type,
+  MBRange ent_list;
+  for (int dim=0;dim<=3;dim++)
+      ent_list.merge(dim_ent_list);
+  status = mdbImpl->get_adjacencies(ent_list,0,false,node_range);
+  if (node_range.size() == 0)
+      std::cout << "No nodes were found in set " << set_name << std::endl;
+MBTag ReadABAQUS::get_tag(char* tag_name,
+			  int tag_size,
+			  MBTagType tag_type,
+			  MBDataType tag_data_type)
+  int def_val = 0;
+  return get_tag(tag_name,tag_size,tag_type,tag_data_type,&def_val);
+			  int tag_size,
+			  MBDataType tag_data_type,
+			  const void* def_val)
+  MBTag retval;
+  if (MB_TAG_NOT_FOUND == mdbImpl->tag_get_handle(tag_name, retval) )
+    mdbImpl->tag_create(tag_name,tag_size,tag_type,tag_data_type,retval,def_val);
+  return retval;
+MBErrorCode ReadABAQUS::create_instance_of_part(const MBEntityHandle file_set,
+						const MBEntityHandle assembly_set,
+						const std::string part_name,
+						const std::string instance_name,
+						MBEntityHandle &instance_set,
+						const std::vector<double> &translation,
+						const std::vector<double> &rotation)
+  status = get_set_by_name(file_set,ABQ_PART_SET,part_name,part_set);
+  status = add_entity_set(assembly_set,ABQ_INSTANCE_SET,instance_name,instance_set);
+  // cross-reference
+  status = mdbImpl->tag_set_data(mPartHandleTag,&instance_set,1,&part_set);
+  int instance_id = ++num_part_instances[part_set];
+  status = mdbImpl->tag_set_data(mInstancePIDTag,&instance_set,1,&instance_id);
+  status = mdbImpl->tag_set_data(mAssemblyHandleTag,&instance_set,1,&assembly_set);
+  instance_id = ++num_assembly_instances[assembly_set];
+  status = mdbImpl->tag_set_data(mInstanceGIDTag,&instance_set,1,&instance_id);
+  // ---- NODES ----
+  // get all nodes and IDs
+  MBRange part_node_list;
+  status = mdbImpl->get_entities_by_dimension(part_set,0,part_node_list);
+  std::vector<int> node_ids(part_node_list.size());
+  status = mdbImpl->tag_get_data(mLocalIDTag,part_node_list,&node_ids[0]);
+  for (unsigned int idx=0;idx<part_node_list.size();idx++)
+    nodeIdMap[node_ids[idx]] = part_node_list[idx];
+  // create new nodes
+  status = readMeshIface->get_node_arrays(3, part_node_list.size(),MB_START_ID,
+  // copy coordinates into new coord_arrays
+  status = mdbImpl->get_coords(part_node_list,coord_arrays[0],coord_arrays[1],coord_arrays[2]);
+  // rotate to new position
+  double rot_axis[3];
+  rot_axis[0] = rotation[3]-rotation[0];
+  rot_axis[1] = rotation[4]-rotation[1];
+  rot_axis[2] = rotation[5]-rotation[2];
+  MBAffineXform rotationXform;
+  if (rotation[6] != 0)
+    rotationXform = MBAffineXform::rotation(rotation[6]*DEG2RAD,rot_axis);
+  // translate to new position
+      double coords[3];
+      // transform to new location and then shift origin of rotation
+      for (unsigned int dim=0;dim<3;dim++)
+	coords[dim] = coord_arrays[dim][idx] + translation[dim] - rotation[dim];
+      // rotate around this origin
+	rotationXform.xform_vector(coords);
+      // transform irigin of rotation back
+	coord_arrays[dim][idx] = coords[dim] + rotation[dim];
+  MBRange instance_node_list(start_node, start_node+part_node_list.size()-1);
+  // (DO NOT) add nodes to file_set
+  // status = mdbImpl->add_entities(file_set,instance_node_list);
+  // add nodes to this instance_set
+  status = mdbImpl->add_entities(instance_set,instance_node_list);
+  // add nodes to this assembly_set
+  status = mdbImpl->add_entities(assembly_set,instance_node_list);
+  status = mdbImpl->tag_set_data(mLocalIDTag,instance_node_list,&node_ids[0]);
+  // tag nodes with their instance handle
+  std::vector<MBEntityHandle> tmp_instance_handles;
+  tmp_instance_handles.assign(part_node_list.size(),instance_set);
+  status = mdbImpl->tag_set_data(mInstanceHandleTag,instance_node_list,&tmp_instance_handles[0]);
+  // create a map of old handles to new handles!!!
+  std::map<MBEntityHandle,MBEntityHandle> p2i_nodes;
+    p2i_nodes[part_node_list[idx]]=instance_node_list[idx];
+  //  ---- ELEMENTS ----
+  MBRange part_element_list;
+  status = get_set_elements(part_set,part_element_list);
+  std::vector<int> part_element_ids(part_element_list.size());
+  status = mdbImpl->tag_get_data(mLocalIDTag,part_element_list,&part_element_ids[0]);
+  for (unsigned int idx=0;idx<part_element_list.size();idx++)
+      elementIdMap[part_element_ids[idx]] = part_element_list[idx];
+  // create new elements
+  MBRange instance_element_list;
+  instance_element_list.clear();
+  // cross-referencing storage and pointers/iterators
+  std::map<MBEntityHandle,MBEntityHandle> p2i_elements;
+  std::vector<int> instance_element_ids;
+  std::vector<int>::iterator part_element_id = part_element_ids.begin();
+  for (MBRange::iterator part_element=part_element_list.begin();
+       part_element != part_element_list.end();
+       part_element++,part_element_id++)
+      MBEntityType element_type = mdbImpl->type_from_handle(*part_element);
+      std::vector<MBEntityHandle> part_connectivity,instance_connectivity;
+      MBEntityHandle new_element;
+      status = mdbImpl->get_connectivity(&(*part_element),1,part_connectivity);
+      instance_connectivity.clear();
+      for (std::vector<MBEntityHandle>::iterator connectivity_node=part_connectivity.begin();
+	   connectivity_node != part_connectivity.end();
+	   connectivity_node++)
+	instance_connectivity.push_back(p2i_nodes[*connectivity_node]);
+      status = mdbImpl->create_element(element_type,&instance_connectivity[0],instance_connectivity.size(),new_element);
+      instance_element_list.insert(new_element);
+      p2i_elements[*part_element] = new_element;
+      instance_element_ids.push_back(*part_element_id);
+  // (DO NOT) add elements to file_set
+  // status = mdbImpl->add_entities(file_set,instance_element_list);
+  // add elements to this instance_set
+  status = mdbImpl->add_entities(instance_set,instance_element_list);
+  // add elements to this assembly_set
+  status = mdbImpl->add_entities(assembly_set,instance_element_list);
+  status = mdbImpl->tag_set_data(mLocalIDTag,instance_element_list,&(instance_element_ids[0]));
+  // tag elements with their instance handle
+  tmp_instance_handles.assign(part_element_list.size(),instance_set);
+  status = mdbImpl->tag_set_data(mInstanceHandleTag,instance_element_list,&(tmp_instance_handles[0]));
+  // ----- NODE SETS -----
+  MBRange part_node_sets;
+  int tag_val = ABQ_NODE_SET;
+  status = mdbImpl->get_entities_by_type_and_tag(part_set,
+						 MBENTITYSET,
+						 &mSetTypeTag,
+						 tag_data, 1, part_node_sets);
+  MBRange part_node_set_list, instance_node_set_list;
+  for (MBRange::iterator part_node_set = part_node_sets.begin();
+       part_node_set != part_node_sets.end();
+       part_node_set++)
+      char node_set_name[ABAQUS_SET_NAME_LENGTH];
+      std::fill(node_set_name,node_set_name+ABAQUS_SET_NAME_LENGTH,'\0');
+      status = mdbImpl->tag_get_data(mSetNameTag, &(*part_node_set), 1, &node_set_name[0]);
+      part_node_set_list.clear();
+      status = mdbImpl->get_entities_by_dimension(*part_node_set,0,part_node_set_list);
+      instance_node_set_list.clear();
+      for (MBRange::iterator set_node = part_node_set_list.begin();
+	   set_node != part_node_set_list.end();
+	   set_node++)
+	instance_node_set_list.insert(p2i_nodes[*set_node]);
+      MBEntityHandle instance_node_set;
+      status = add_entity_set(instance_set,ABQ_NODE_SET,node_set_name,instance_node_set);
+      status = mdbImpl->add_entities(instance_node_set,instance_node_set_list);
+      status = mdbImpl->add_entities(assembly_set,&instance_node_set,1);
+      status = mdbImpl->tag_set_data(mPartHandleTag,&instance_node_set,1,&part_set);
+      status = mdbImpl->tag_set_data(mInstanceHandleTag,&instance_node_set,1,&instance_set);
+      status = mdbImpl->tag_set_data(mAssemblyHandleTag,&instance_node_set,1,&assembly_set);
+  // ----- ELEMENT SETS -----
+  // get all element sets in part
+  MBRange part_element_sets;
+						 MBENTITYSET,
+						 &mSetTypeTag,
+						 tag_data, 1, part_element_sets);
+  MBRange part_element_set_list, instance_element_set_list;
+  for (MBRange::iterator part_element_set = part_element_sets.begin();
+       part_element_set != part_element_sets.end();
+       part_element_set++)
+      char element_set_name[ABAQUS_SET_NAME_LENGTH];
+      std::fill(element_set_name,element_set_name+ABAQUS_SET_NAME_LENGTH,'\0');
+      status = mdbImpl->tag_get_data(mSetNameTag, &(*part_element_set), 1, &element_set_name[0]);
+      part_element_set_list.clear();
+      status = get_set_elements(*part_element_set,part_element_set_list);
+      instance_element_set_list.clear();
+      for (MBRange::iterator set_element = part_element_set_list.begin();
+	   set_element != part_element_set_list.end();
+	   set_element++)
+	instance_element_set_list.insert(p2i_elements[*set_element]);
+      MBEntityHandle instance_element_set;
+      status = add_entity_set(instance_set,ABQ_ELEMENT_SET,element_set_name,instance_element_set);
+      std::cerr << instance_set << "\t" << instance_element_set << std::endl;
+      status = mdbImpl->add_entities(instance_element_set,instance_element_set_list);
+      status = mdbImpl->add_entities(assembly_set,&instance_element_set,1);
+      // status = mdbImpl->add_entities(file_set,&instance_element_set,1);
+      //MB_RETURN_IF_FAIL;
+      status = mdbImpl->tag_set_data(mPartHandleTag,&instance_element_set,1,&part_set);
+      status = mdbImpl->tag_set_data(mInstanceHandleTag,&instance_element_set,1,&instance_set);
+      status = mdbImpl->tag_set_data(mAssemblyHandleTag,&instance_element_set,1,&assembly_set);
+      char element_set_matname[ABAQUS_SET_NAME_LENGTH];
+      std::fill(element_set_matname,element_set_matname+ABAQUS_SET_NAME_LENGTH,'\0');
+      status = mdbImpl->tag_get_data(mMatNameTag, &(*part_element_set), 1, &element_set_matname[0]);
+      if (MB_TAG_NOT_FOUND != status)
+	  status = mdbImpl->tag_set_data(mMatNameTag,&instance_element_set,1,element_set_matname);
+      int element_set_mat_id;
+      status = mdbImpl->tag_get_data(mMaterialSetTag,&(*part_element_set), 1, &element_set_mat_id);
+	  status = mdbImpl->tag_set_data(mMaterialSetTag,&instance_element_set,1,&element_set_mat_id);
+MBErrorCode ReadABAQUS::add_entity_set(MBEntityHandle parent_set,
+				       int ABQ_Set_Type,
+				       MBEntityHandle &entity_set)
+  status = mdbImpl->create_meshset(MESHSET_SET, entity_set);
+  status = mdbImpl->tag_set_data(mSetTypeTag,&entity_set,1,&ABQ_Set_Type);
+  status = mdbImpl->tag_set_data(mSetNameTag,&entity_set,1,set_name.c_str());
+  status = mdbImpl->add_entities(parent_set,&entity_set,1);
+void ReadABAQUS::cyl2rect(std::vector<double> coord_list)
+  int num_nodes = coord_list.size()/3;
+  double x,y,r,t;
+  for (int node=0;node<num_nodes;node++)
+      r = coord_list[3*node];
+      t = coord_list[3*node+1]*DEG2RAD;
+      x = r*cos(t);
+      y = r*sin(t);
+      coord_list[3*node] = x;
+      coord_list[3*node+1] = y;
+void ReadABAQUS::sph2rect(std::vector<double> coord_list)
+  double x,y,z,r,t,p;
+      p = coord_list[3*node+2]*DEG2RAD;
+      x = r*cos(p)*cos(t);
+      y = r*cos(p)*sin(t);
+      z = r*sin(p);
+      coord_list[3*node+2] = z;
+// PARSING RECOGNITION
+abaqus_line_types ReadABAQUS::get_next_line_type()
+  readline.clear();
+  std::getline(abFile,readline);
+  if (abFile.eof())
+    return abq_eof;
+  std::string::size_type pos = readline.find_first_not_of(' ');
+  if (std::string::npos == pos)
+    return abq_blank_line;
+  if ('*' == readline[pos])
+    if ('*' == readline[pos+1])
+      return abq_comment_line;
+    else
+      return abq_keyword_line;
+  else
+    return abq_data_line;
+abaqus_keyword_type ReadABAQUS::get_keyword()
+  std::map<std::string,abaqus_keyword_type> keywords;
+  // set up list of supported keywords
+  // Note: any attempt to match something not in the keyword list
+  //       using the [] operator will create a new entry in the map
+  //       but that entry will have value abq_undefined based on the
+  //       definition of the abaqus_keyword_type enum.
+  keywords[ABQ_AMBIGUOUS]   = abq_ambiguous;
+  keywords["HEADING"]       = abq_heading;
+  keywords["PART"]          = abq_part;
+  keywords["END PART"]      = abq_end_part;
+  keywords["ASSEMBLY"]      = abq_assembly;
+  keywords["END ASSEMBLY"]  = abq_end_assembly;
+  keywords["NODE"]          = abq_node;
+  keywords["ELEMENT"]       = abq_element;
+  keywords["NSET"]          = abq_nset;
+  keywords["ELSET"]         = abq_elset;
+  keywords["SOLID SECTION"] = abq_solid_section;
+  keywords["INSTANCE"]      = abq_instance;
+  keywords["END INSTANCE"]  = abq_end_instance;
+  tokenize(readline,tokens,"*,\n");
+  // convert to upper case and test for unambiguous match/partial match
+  stringToUpper(tokens[0],tokens[0]);
+  return keywords[match(tokens[0],keywords)];
+// PARSING UTILITY FUNCTIONS
+// for a map of strings to values of type T
+// search the key list of the map for an unambiguous partial match with the token
+template <typename T>
+std::string ReadABAQUS::match(const std::string &token,
+			      std::map<std::string,T> &tokenList)
+  // initialize with no match and ABQ_UNDEFINED as return string
+  bool found_match = false;
+  std::string best_match = ABQ_UNDEFINED;
+  // search the map
+  for (typename std::map<std::string,T>::iterator thisToken=tokenList.begin();
+       thisToken != tokenList.end();
+       thisToken++)
+      // if a perfect match break the loop (assume keyword list is unambiguous)
+      if (token == (*thisToken).first)
+	  best_match = token;
+	  break;
+      else
+	  int short_length = ( token.length()<(*thisToken).first.length()?token.length():(*thisToken).first.length() );
+	  // if the token matches the first token.length() characters of the keyword
+	  // consider this a match
+	  if ( token.substr(short_length) == (*thisToken).first.substr(short_length) )
+	      if (!found_match)
+		  // if no match already, record match and matching keyword
+		  found_match = true;
+		  best_match = (*thisToken).first;
+	      else
+		// if match already set matching keyword to ABQ_AMBIGUOUS
+		best_match = ABQ_AMBIGUOUS;
+  // Possible return values: ABQ_UNDEFINED, keyword from list, ABQ_AMBIGUOUS
+  return best_match;
+// convert a string to upper case
+void ReadABAQUS::stringToUpper(std::string toBeConverted, std::string& converted)
+  converted = toBeConverted;
+  for (unsigned int i=0;i<toBeConverted.length();i++)
+    converted[i] = toupper(toBeConverted[i]);
+// extract key/value pairs from parameter list
+void ReadABAQUS::extract_keyword_parameters(std::vector<std::string> tokens,
+					 std::map<std::string,std::string>& params)
+  std::string key, value;
+  // NOTE: skip first token - it is the keyword
+  for (std::vector<std::string>::iterator token=tokens.begin()+1;
+       token!=tokens.end(); token++)
+      std::string::size_type pos = token->find('=');
+      stringToUpper(token->substr(0,pos),key);
+      if(std::string::npos != pos)
+	value = token->substr(pos+1);
+      else
+	value = "";
+      pos = key.find_first_not_of(' ',0);
+      key = key.substr(pos);
+      params[key] = value;
+// tokenize a string based on a set of possible delimiters
+void ReadABAQUS::tokenize( const std::string& str,
+                         std::vector<std::string>& tokens,
+                         const char* delimiters )
+  tokens.clear();
+  std::string::size_type pos, last = str.find_first_not_of( delimiters, 0 );
+  while ( std::string::npos != last )
+      pos = str.find_first_of( delimiters, last );
+      if ( std::string::npos == pos )
+	  tokens.push_back(str.substr(last));
+	  last = std::string::npos;
+      else
+	  tokens.push_back( str.substr( last, pos - last ) );
+	  last = str.find_first_not_of( delimiters, pos );
Added: MOAB/trunk/ReadABAQUS.hpp
--- MOAB/trunk/ReadABAQUS.hpp	                        (rev 0)
+++ MOAB/trunk/ReadABAQUS.hpp	2009-08-21 01:51:30 UTC (rev 3114)
@@ -0,0 +1,304 @@
+// Filename      : ReadABAQUS.hpp
+// Purpose       : ABAQUS inp file reader
+// Special Notes : Started with NetCDF EXODUS II reader
+// Creator       : Paul Wilson & Patrick Snouffer
+// Date          : 08/2009
+// Owner         : Paul Wilson
+#ifndef READABAQUS_HPP
+#define READABAQUS_HPP
+#ifndef IS_BUILDING_MB
+  #error "ReadABAQUS.hpp isn't supposed to be included into an application"
+#endif
+#include <vector>
+#include <map>
+#include <string>
+#include <iostream>
+#include <fstream>
+#include "MBForward.hpp"
+#include "MBReaderIface.hpp"
+#define ABAQUS_SET_TYPE_TAG_NAME "abaqus_set_type"
+#define ABAQUS_SET_NAME_TAG_NAME "abaqus_set_name"
+#define ABAQUS_SET_NAME_LENGTH   100
+#define ABAQUS_LOCAL_ID_TAG_NAME "abaqus_local_id"
+// many sets should know who contains them
+#define ABAQUS_INSTANCE_HANDLE_TAG_NAME   "abaqus_instance_handle"
+#define ABAQUS_ASSEMBLY_HANDLE_TAG_NAME "abaqus_assembly_handle"
+#define ABAQUS_PART_HANDLE_TAG_NAME       "abaqus_part_handle"
+// instances should know things about themselves:
+//  * which part they derive from (see ABAQUS_PART_HANDLE_TAG_NAME above)
+//  * which instance of a part this is
+//  * which instance of an assembly this is
+#define ABAQUS_INSTANCE_PART_ID_TAG_NAME   "abaqus_instance_part_id"
+#define ABAQUS_INSTANCE_GLOBAL_ID_TAG_NAME "abaqus_instance_global_id"
+// element sets have material name
+// using MOAB's general MATERIAL_SET to store material id
+#define ABAQUS_MAT_NAME_TAG_NAME "abaqus_mat_name"
+#define ABAQUS_MAT_NAME_LENGTH   100
+#define ABQ_ASSEMBLY_SET 1
+#define ABQ_PART_SET     2
+#define ABQ_INSTANCE_SET 3
+#define ABQ_NODE_SET     4
+#define ABQ_ELEMENT_SET  5
+enum abaqus_line_types { abq_undefined_line = 0,
+			 abq_blank_line,
+			 abq_comment_line,
+			 abq_keyword_line,
+			 abq_data_line,
+			 abq_eof };
+enum abaqus_keyword_type { abq_undefined = 0,
+			   abq_unsupported,
+			   abq_ambiguous,
+			   abq_heading,
+			   abq_part,
+			   abq_end_part,
+			   abq_assembly,
+                    	   abq_end_assembly,
+			   abq_node,
+			   abq_element,
+			   abq_nset,
+			   abq_elset,
+			   abq_instance,
+			   abq_end_instance,
+			   abq_solid_section};
+enum abaqus_part_params { abq_part_undefined = 0,
+			  abq_part_ambiguous,
+			  abq_part_name};
+enum abaqus_instance_params { abq_instance_undefined = 0,
+			      abq_instance_ambiguous,
+			      abq_instance_name,
+			      abq_instance_part};
+enum abaqus_assembly_params { abq_assembly_undefined = 0,
+			      abq_assembly_ambiguous,
+			      abq_assembly_name};
+enum abaqus_node_params { abq_node_undefined = 0,
+			  abq_node_ambiguous,
+			  abq_node_nset,
+			  abq_node_system};
+enum abaqus_element_params { abq_element_undefined = 0,
+			     abq_element_ambiguous,
+			     abq_element_elset,
+			     abq_element_type};
+enum abaqus_element_type { abq_eletype_unsupported = 0,
+			   abq_eletype_dc3d8,
+			   abq_eletype_c3d8r,
+			   abq_eletype_dcc3d8,
+			   abq_eletype_c3d4,
+                           abq_eletype_ds4};
+enum abaqus_nset_params { abq_nset_undefined = 0,
+			  abq_nset_ambiguous,
+			  abq_nset_nset,
+			  abq_nset_elset,
+			  abq_nset_generate,
+                          abq_nset_instance};
+enum abaqus_elset_params { abq_elset_undefined = 0,
+			   abq_elset_ambiguous,
+			   abq_elset_elset,
+			   abq_elset_generate,
+                           abq_elset_instance};
+enum abaqus_solid_section_params { abq_solid_section_undefined = 0,
+				   abq_solid_section_ambiguous,
+				   abq_solid_section_elset,
+				   abq_solid_section_matname};
+class MBReadUtilIface;
+class ReadABAQUS : public MBReaderIface
+public:
+  static MBReaderIface* factory( MBInterface* );
+  void tokenize( const std::string& str,
+                 const char* delimiters );
+  //! load an ABAQUS file
+  MBErrorCode load_file( const char *exodus_file_name,
+                         const MBReaderIface::IDTag* subset_list = 0,
+                         int subset_list_length = 0,
+                         const MBTag* file_id_tag = 0 );
+  MBErrorCode read_tag_values( const char* file_name,
+                               const char* tag_name,
+                               std::vector<int>& tag_values_out,
+                               const IDTag* subset_list = 0,
+                               int subset_list_length = 0 );
+  //! Constructor
+  ReadABAQUS(MBInterface* impl = NULL);
+  //! Destructor
+  virtual ~ReadABAQUS();
+private:
+  void reset();
+  MBErrorCode read_heading(MBEntityHandle file_set);
+  MBErrorCode read_part(MBEntityHandle file_set);
+  MBErrorCode read_assembly(MBEntityHandle file_set);
+  MBErrorCode read_unsupported(MBEntityHandle file_set);
+  MBErrorCode read_node_list(MBEntityHandle parent_set);
+  MBErrorCode read_element_list(MBEntityHandle parent_set);
+  MBErrorCode read_node_set(MBEntityHandle parent_set,
+			    MBEntityHandle file_set = 0,
+			    MBEntityHandle assembly_set = 0);
+  MBErrorCode read_element_set(MBEntityHandle parent_set,
+  MBErrorCode read_solid_section(MBEntityHandle parent_set);
+  MBErrorCode read_instance(MBEntityHandle assembly_set,
+			    MBEntityHandle file_set);
+  MBErrorCode get_elements_by_id(MBEntityHandle parent_set,
+				 MBRange &element_range);
+  MBErrorCode get_nodes_by_id(MBEntityHandle parent_set,
+			      MBRange &node_range);
+  MBErrorCode get_set_by_name(MBEntityHandle parent_set,
+			      int ABQ_set_type,
+			      MBEntityHandle &set_handle);
+  MBErrorCode get_set_elements(MBEntityHandle set_handle,
+  MBErrorCode get_set_elements_by_name(MBEntityHandle parent_set,
+				       int ABQ_set_type,
+  MBErrorCode get_set_nodes(MBEntityHandle parent_set,
+			    int ABQ_set_type,
+  MBErrorCode add_entity_set(MBEntityHandle parent_set,
+			     int ABQ_set_type,
+			     MBEntityHandle &entity_set);
+  MBErrorCode create_instance_of_part(const MBEntityHandle file_set,
+				      const MBEntityHandle parent_set,
+				      MBEntityHandle &entity_set,
+				      const std::vector<double> &rotation);
+  MBTag get_tag(char* tag_name, int tag_size, MBTagType tag_type, MBDataType tag_data_type);
+  MBTag get_tag(char* tag_name, int tag_size, MBTagType tag_type, MBDataType tag_data_type, const void* def_val);
+  void cyl2rect(std::vector<double> coord_list);
+  void sph2rect(std::vector<double> coord_list);
+  abaqus_line_types get_next_line_type();
+  abaqus_keyword_type get_keyword();
+  template <class T>
+  std::string match(const std::string &token,
+		    std::map<std::string,T> &tokenList);
+  void stringToUpper(std::string toBeConverted,std::string& converted);
+  void extract_keyword_parameters(std::vector<std::string> tokens,
+				  std::map<std::string,std::string>& params);
+  //! interface instance
+  MBInterface* mdbImpl;
+  // read mesh interface
+  MBReadUtilIface* readMeshIface;
+  std::ifstream abFile;        // abaqus file
+  std::string readline;
+  //! Cached tags for reading.  Note that all these tags are defined when the
+  //! core is initialized.
+  MBTag mMaterialSetTag;
+  MBTag mDirichletSetTag;
+  MBTag mNeumannSetTag;
+  MBTag mHasMidNodesTag;
+  MBTag mSetTypeTag;
+  MBTag mPartHandleTag;
+  MBTag mInstancePIDTag;
+  MBTag mInstanceGIDTag;
+  MBTag mLocalIDTag;
+  MBTag mInstanceHandleTag;
+  MBTag mAssemblyHandleTag;
+  MBTag mSetNameTag;
+  MBTag mMatNameTag;
+  abaqus_line_types  next_line_type;
+  std::map<MBEntityHandle,unsigned int> num_part_instances;
+  std::map<MBEntityHandle,unsigned int> num_assembly_instances;
+  std::map<std::string,unsigned int> matIDmap;
+  unsigned mat_id;
+#endif
