[MOAB-dev] r3104 - MOAB/trunk/mhdf/src
jvporter at wisc.edu
Mon Aug 10 17:05:15 CDT 2009
Author: jvporter
Date: 2009-08-10 17:05:14 -0500 (Mon, 10 Aug 2009)
New Revision: 3104
Modified:
MOAB/trunk/mhdf/src/tags.c
Log:
Fix bad commit
Modified: MOAB/trunk/mhdf/src/tags.c
--- MOAB/trunk/mhdf/src/tags.c 2009-08-10 21:53:01 UTC (rev 3103)
+++ MOAB/trunk/mhdf/src/tags.c 2009-08-10 22:05:14 UTC (rev 3104)
@@ -743,6 +743,7 @@
hid_t type_id;
int rank;
hsize_t dims[H5S_MAX_RANK];
+ int perm[H5S_MAX_RANK];
type_id = H5Aget_type( attrib_id );
switch (H5Tget_class(type_id)) {
@@ -754,6 +755,7 @@
break;
case H5T_ARRAY:
#if defined(H5Tget_array_dims_vers) && H5Tget_array_dims_vers > 1
+ (void)perm; // eliminate warning
rank = H5Tget_array_dims2( type_id, dims );
#else
rank = H5Tget_array_dims( type_id, dims, perm );
@@ -820,6 +822,7 @@
unsigned int index;
int rank, var_data;
H5T_class_t class_tmp;
API_BEGIN;
@@ -986,6 +989,7 @@
case H5T_ARRAY:
#else
