[MOAB-dev] r3103 - in MOAB/trunk: mhdf/src tools/mbperf
    jvporter at wisc.edu
    Mon Aug 10 16:53:01 CDT 2009
Author: jvporter
Date: 2009-08-10 16:53:01 -0500 (Mon, 10 Aug 2009)
New Revision: 3103
Modified:
   MOAB/trunk/mhdf/src/tags.c
   MOAB/trunk/tools/mbperf/mbperf.cpp
Log:
Eliminate the last of the warnings (I hope!)
Modified: MOAB/trunk/mhdf/src/tags.c
--- MOAB/trunk/mhdf/src/tags.c	2009-08-10 21:30:36 UTC (rev 3102)
+++ MOAB/trunk/mhdf/src/tags.c	2009-08-10 21:53:01 UTC (rev 3103)
@@ -743,7 +743,6 @@
   hid_t type_id;
   int rank;
   hsize_t dims[H5S_MAX_RANK];
-  int perm[H5S_MAX_RANK];
   type_id = H5Aget_type( attrib_id );
   switch (H5Tget_class(type_id)) {
@@ -821,7 +820,6 @@
   unsigned int index;
   int rank, var_data;
   H5T_class_t class_tmp;
   API_BEGIN;
Modified: MOAB/trunk/tools/mbperf/mbperf.cpp
--- MOAB/trunk/tools/mbperf/mbperf.cpp	2009-08-10 21:30:36 UTC (rev 3102)
+++ MOAB/trunk/tools/mbperf/mbperf.cpp	2009-08-10 21:53:01 UTC (rev 3103)
@@ -532,9 +532,10 @@
   int num_elems = nelem*nelem*nelem;
   MBEntityHandle vstart, estart;
-  MBReadUtilIface* readMeshIface;
+  void *ptr = 0;
   // get the read interface
-  gMB->query_interface("MBReadUtilIface", reinterpret_cast<void**>(&readMeshIface));
+  gMB->query_interface("MBReadUtilIface", &ptr);
+  MBReadUtilIface* readMeshIface = static_cast<MBReadUtilIface*>(ptr);
   // create a sequence to hold the node coordinates
   // get the current number of entities and start at the next slot
