[MOAB-dev] r3101 - in MOAB/trunk: . tools/iMesh
    kraftche at cae.wisc.edu
    Mon Aug 10 16:23:19 CDT 2009
Author: kraftche
Date: 2009-08-10 16:23:18 -0500 (Mon, 10 Aug 2009)
New Revision: 3101
Modified:
   MOAB/trunk/ReadIDEAS.cpp
   MOAB/trunk/WriteGMV.cpp
   MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
Log:
fix 'type-punned pointer' warnings
Modified: MOAB/trunk/ReadIDEAS.cpp
--- MOAB/trunk/ReadIDEAS.cpp	2009-08-10 21:08:12 UTC (rev 3100)
+++ MOAB/trunk/ReadIDEAS.cpp	2009-08-10 21:23:18 UTC (rev 3101)
@@ -17,7 +17,9 @@
 ReadIDEAS::ReadIDEAS(MBInterface* impl)
     : MBI(impl)
-  impl->query_interface("MBReadUtilIface", reinterpret_cast<void**>(&readMeshIface));
+  void* ptr = 0;
+  impl->query_interface("MBReadUtilIface", &ptr);
+  readMeshIface = reinterpret_cast<MBReadUtilIface*>(ptr);
Modified: MOAB/trunk/WriteGMV.cpp
--- MOAB/trunk/WriteGMV.cpp	2009-08-10 21:08:12 UTC (rev 3100)
+++ MOAB/trunk/WriteGMV.cpp	2009-08-10 21:23:18 UTC (rev 3101)
@@ -56,8 +56,9 @@
   assert(impl != NULL);
-  std::string iface_name = "MBWriteUtilIface";
-  impl->query_interface(iface_name, reinterpret_cast<void**>(&mWriteIface));
+  void* ptr = 0;
+  impl->query_interface( "MBWriteUtilIface", &ptr );
+  mWriteIface = reinterpret_cast<MBWriteUtilIface*>(ptr);
   // initialize in case tag_get_handle fails below
   mMaterialSetTag  = 0;
Modified: MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp	2009-08-10 21:08:12 UTC (rev 3100)
+++ MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp	2009-08-10 21:23:18 UTC (rev 3101)
@@ -348,8 +348,9 @@
     eatwhitespace(tmp_filename);
     eatwhitespace(tmp_options);
+    MBEntityHandle set = ENTITY_HANDLE(handle);
     MBErrorCode result = MBI->write_file(tmp_filename.c_str(), NULL, tmp_options.c_str(),
-                                         CONST_HANDLE_ARRAY_PTR(&handle), 1);
+                                         &set, 1);
     if (MB_SUCCESS != result) {
       std::string msg("iMesh_save:ERROR saving a mesh, with error type: ");
@@ -996,7 +997,8 @@
   void iMesh_destroyEntSet (iMesh_Instance instance,
                             /*in*/ iBase_EntitySetHandle entity_set, int *err)
-    MBErrorCode result = MBI->delete_entities(HANDLE_ARRAY_PTR(&entity_set), 1);
+    MBEntityHandle set = ENTITY_HANDLE(entity_set);
+    MBErrorCode result = MBI->delete_entities(&set, 1);
       iMesh_processError(iBase_ERROR_MAP[result], "iMesh_destroyEntSet: couldn't delete the set.");
@@ -1119,8 +1121,8 @@
                        /*in*/ iBase_EntitySetHandle entity_set_handle,
                        int *err)
-    MBErrorCode result = MBI->add_entities(ENTITY_HANDLE(entity_set_handle),
-                                           CONST_HANDLE_ARRAY_PTR(&entity_set_to_add), 1);
+    MBEntityHandle to_add = ENTITY_HANDLE(entity_set_to_add);
+    MBErrorCode result = MBI->add_entities(ENTITY_HANDLE(entity_set_handle), &to_add, 1);
     if (result != MB_SUCCESS) {
       std::string msg("iMesh_addEntSet:ERROR adding entitysets, with error type: ");
@@ -1137,8 +1139,9 @@
                        int *err)
+    MBEntityHandle to_remove = ENTITY_HANDLE(entity_set_handle);
     MBErrorCode result = MBI->remove_entities
-      (ENTITY_HANDLE(entity_set_handle), CONST_HANDLE_ARRAY_PTR(&entity_set_to_remove), 1);
+      (ENTITY_HANDLE(entity_set_handle), &to_remove, 1);
       std::string msg("iMesh_rmvEntSet:ERROR removing entitysets in EntitySet, "
@@ -1737,10 +1740,11 @@
         // set the tag data on this entity set
       result = MBI->tag_set_data(TAG_HANDLE(tag_handle),
                                  NULL, 0, tag_value);
-    else
-      result = MBI->tag_set_data(TAG_HANDLE(tag_handle),
-                                 HANDLE_ARRAY_PTR(&entity_set_handle), 1, tag_value);
+    else {
+      MBEntityHandle set = ENTITY_HANDLE(entity_set_handle);
+      result = MBI->tag_set_data(TAG_HANDLE(tag_handle), &set, 1, tag_value);
       iMesh_processError(iBase_ERROR_MAP[result], "iMesh_setEntSetData: error");
@@ -1898,8 +1902,8 @@
       iMesh_getRootSet(instance, &entity_set_handle, &success);
       if (iBase_ERROR_MAP[success] != iBase_SUCCESS) RETURN(iBase_ERROR_MAP[success]);
-    MBErrorCode result = MBI->tag_delete_data(TAG_HANDLE(tag_handle),
-                                              HANDLE_ARRAY_PTR(&entity_set_handle), 1);
+    MBErrorCode result = MBI->tag_delete_data(TAG_HANDLE(tag_handle), &set, 1);
       // don't check return; this tag may have never been set on the entity set
     RETURN(iBase_ERROR_MAP[result]);
