Author: kraftche
Date: 2009-08-03 17:26:52 -0500 (Mon, 03 Aug 2009)
New Revision: 3091
Modified:
MOAB/trunk/WriteHDF5.cpp
Log:
values transposed in debug output
Modified: MOAB/trunk/WriteHDF5.cpp
--- MOAB/trunk/WriteHDF5.cpp 2009-08-03 21:47:41 UTC (rev 3090)
+++ MOAB/trunk/WriteHDF5.cpp 2009-08-03 22:26:52 UTC (rev 3091)
@@ -791,7 +791,7 @@
tprint(" writing %c node chunk %ld of %ld, %ld values at %ld ",
- (char)('x'+d), num_writes - remaining_writes + 1, num_writes, offset, count );
+ (char)('x'+d), num_writes - remaining_writes + 1, num_writes, count, offset );
mhdf_writeNodeCoordWithOpt( node_table, offset, count, d, buffer, writeProp, &status );
CHK_MHDF_ERR_1(status, node_table);
@@ -868,7 +868,7 @@
return MB_FAILURE;
tprint(" writing node connectivity %ld of %ld, %ld values at %ld ",
- num_writes - remaining_writes + 1, num_writes, offset, count );
+ num_writes - remaining_writes + 1, num_writes, count, offset );
mhdf_writeConnectivityWithOpt( elem_table, offset, count,
id_type, buffer, writeProp, &status );
CHK_MHDF_ERR_1(status, elem_table);
