[MOAB-dev] r3088 - in MOAB/trunk: . parallel
    kraftche at cae.wisc.edu
    Mon Aug  3 15:38:35 CDT 2009
Author: kraftche
Date: 2009-08-03 15:38:34 -0500 (Mon, 03 Aug 2009)
New Revision: 3088
Modified:
   MOAB/trunk/WriteHDF5.cpp
   MOAB/trunk/WriteHDF5.hpp
   MOAB/trunk/parallel/WriteHDF5Parallel.cpp
   MOAB/trunk/parallel/WriteHDF5Parallel.hpp
Log:
more/better debugging output
Modified: MOAB/trunk/WriteHDF5.cpp
--- MOAB/trunk/WriteHDF5.cpp	2009-07-31 19:20:03 UTC (rev 3087)
+++ MOAB/trunk/WriteHDF5.cpp	2009-08-03 20:38:34 UTC (rev 3088)
@@ -37,6 +37,7 @@
 #include <time.h>
 #include <stdlib.h>
 #include <string.h>
+#include <stdarg.h>
 #include <limits>
 #include <cstdio>
 #include <iostream>
@@ -79,6 +80,9 @@
 #endif
+//#define TPRINT(A)
+#define TPRINT(A) tprint( (A) )
 #ifdef VALGRIND
 #  include <valgrind/memcheck.h>
 #else
@@ -338,8 +342,21 @@
   idMap.clear();
   return MB_SUCCESS;
+void WriteHDF5::tprint( const char* fmt, ... )
+  static const clock_t t0 = clock();
+  va_list args;
+  va_start(args, fmt);
+  char buffer[128];
+  size_t n = snprintf( buffer, sizeof(buffer), "%6.2f: \n", (double)(clock()-t0)/CLOCKS_PER_SEC );
+  vsnprintf( buffer+n, sizeof(buffer)-n, fmt, args );
+  fputs( buffer, stderr );
+  va_end(args);
 WriteHDF5::~WriteHDF5()
   if (!writeUtil) // init() failed.
@@ -432,7 +449,7 @@
   if (MB_SUCCESS != init())
     return MB_FAILURE;
-DEBUGOUT("Gathering Mesh\n");
+TPRINT("Gathering Mesh\n");
     // Gather mesh to export
   exportList.clear();
@@ -453,7 +470,7 @@
   //if (nodeSet.range.size() == 0)
   //  return MB_ENTITY_NOT_FOUND;
-DEBUGOUT("Checking ID space\n");
+TPRINT("Checking ID space\n");
     // Make sure ID space is sufficient
   elem_count = nodeSet.range.size() + setSet.range.size();
@@ -466,7 +483,7 @@
     return MB_FAILURE;
-DEBUGOUT( "Creating File\n" );
+TPRINT( "Creating File\n" );
     // Figure out the dimension in which to write the mesh.
   int mesh_dim;
@@ -493,7 +510,7 @@
   if (MB_SUCCESS != result)
     return result;
-DEBUGOUT("Writing Nodes.\n");
+TPRINT("Writing Nodes.");
     // Write node coordinates
   if (!nodeSet.range.empty()) {
@@ -502,7 +519,7 @@
       return result;
-DEBUGOUT("Writing connectivity.\n");
+TPRINT("Writing connectivity.");
     // Write element connectivity
   for (ex_itor = exportList.begin(); ex_itor != exportList.end(); ++ex_itor) {
@@ -511,14 +528,14 @@
       return result;
-DEBUGOUT("Writing sets.\n");
+TPRINT("Writing sets.");
     // Write meshsets
   result = write_sets();
     return result;
-DEBUGOUT("Writing adjacencies.\n");
+TPRINT("Writing adjacencies.");
     // Write adjacencies
   // Tim says don't save node adjacencies!
@@ -533,7 +550,7 @@
       return result;
-DEBUGOUT("Writing tags.\n");
+TPRINT("Writing tags.");
     // Write tags
@@ -770,6 +787,7 @@
         memset( buffer, 0, count * sizeof(double) );
+      TPRINT("  writing node chunk");
       mhdf_writeNodeCoordWithOpt( node_table, offset, count, d, buffer, writeProp, &status );
       CHK_MHDF_ERR_1(status, node_table);
@@ -783,6 +801,7 @@
   while (num_writes--) {
     assert(writeProp != H5P_DEFAULT);
     for (int d = 0; d < dim; ++d) {
+      TPRINT("  writing empty node chunk.");
       mhdf_writeNodeCoordWithOpt( node_table, offset, 0, d, 0, writeProp, &status );
@@ -842,6 +861,7 @@
       if (0 == (buffer[i] = idMap.find( buffer[i] )))
         return MB_FAILURE;
+    TPRINT("  writing connectivity chunk");
     mhdf_writeConnectivityWithOpt( elem_table, offset, count,
                                    id_type, buffer, writeProp, &status );
     CHK_MHDF_ERR_1(status, elem_table);
@@ -853,6 +873,7 @@
   // Do empty writes if necessary for parallel collective IO
+    TPRINT("  writing empty connectivity chunk.");
     mhdf_writeConnectivityWithOpt( elem_table, offset, 0, id_type, 0, writeProp, &status );
@@ -934,6 +955,7 @@
     if (id_list.size() + count > buffer_size) {
         // buffer is full, flush it
+      TPRINT("  writing parent/child link chunk");
       mhdf_writeSetParentsChildren( table, offset, count, id_type, buffer, &status );
       CHK_MHDF_ERR_1(status, table);
       offset += count;
@@ -943,6 +965,7 @@
         // If id_list still doesn't it in empty buffer, write it
         // directly rather than trying to buffer it
       if (id_list.size() > buffer_size) {
         mhdf_writeSetParentsChildren( table, offset, id_list.size(), id_type, &id_list[0], &status );
         offset += id_list.size();
@@ -955,6 +978,7 @@
   if (count) {
+    TPRINT("  writing final parent/child link chunk");
@@ -1072,6 +1096,7 @@
       if (id_list.size())
         if (data_count + id_list.size() > content_chunk_size) {
+          TPRINT("  writing set content chunk");
             // If there isn't enough space remaining in the buffer,
             // flush the buffer.
           mhdf_writeSetData( content_table,
@@ -1089,6 +1114,7 @@
             // the size of id_list is bigger than the entire buffer,
             // write id_list directly.
           if (id_list.size() > content_chunk_size) {
                                content_buffer_offset,
                                id_list.size(),
@@ -1108,6 +1134,7 @@
+    TPRINT("  writing set description chunk.");
     mhdf_writeSetMeta( set_table, set_offset, count, H5T_NATIVE_LONG,
                        buffer, &status );
     CHK_MHDF_ERR_2C(status, set_table, writeSetContents, content_table );
@@ -1115,6 +1142,7 @@
   if (data_count) {
+    TPRINT("  writing final set content chunk");
                        data_count,
@@ -1421,6 +1449,7 @@
       // If buffer is full, flush it
     if (count + adj_list.size() + 2 > (unsigned long)chunk_size)
+      TPRINT("  writing adjacency chunk.");
       mhdf_writeAdjacencyWithOpt( table, offset, count, id_type, buffer, writeProp, &status );
       VALGRIND_MAKE_MEM_UNDEFINED( dataBuffer, bufferSize );
@@ -1439,6 +1468,7 @@
   if (count)
+    TPRINT("  writing final adjacency chunk.");
@@ -1451,6 +1481,7 @@
   while (num_writes > 0) {
     --num_writes;
+    TPRINT("  writing empty adjacency chunk.");
     mhdf_writeAdjacencyWithOpt( table, offset, 0, id_type, 0, writeProp, &status );
     CHK_MHDF_ERR_1(status, table );
@@ -1691,6 +1722,7 @@
     CHK_MB_ERR_0( rval );
       // write the data
+    TPRINT("  writing sparse tag entity chunk.");
     mhdf_writeSparseTagEntitiesWithOpt( id_table, offset, count, id_type,
                                         id_buffer, writeProp, &status );
     CHK_MHDF_ERR_0( status );
@@ -1702,6 +1734,7 @@
+    TPRINT("  writing empty sparse tag entity chunk.");
     mhdf_writeSparseTagEntitiesWithOpt( id_table, offset, 0, id_type,
@@ -1826,6 +1859,7 @@
                           count * mb_size / sizeof(MBEntityHandle) );
       // write the data
+    TPRINT("  writing sparse tag value chunk.");
     mhdf_writeSparseTagValuesWithOpt( tables[1], offset, count,
                                       value_type, tag_buffer, writeProp, &status );
     if (mhdf_isError(&status) && value_type && value_type != id_type)
@@ -1839,6 +1873,7 @@
+    TPRINT("  writing empty sparse tag value chunk.");
     mhdf_writeSparseTagValuesWithOpt( tables[1], offset, 0,
                                       value_type, 0, writeProp, &status );
@@ -1962,6 +1997,7 @@
       if (bytes + size > data_buffer_size) {
           // write out tag data buffer
         if (bytes) { // bytes might be zero if tag value is larger than buffer
+          TPRINT("  writing var-length sparse tag value chunk.");
           mhdf_writeSparseTagValues( tables[1], data_offset,
                                      bytes / type_size,
                                      hdf_type, data_buffer,
@@ -1982,6 +2018,7 @@
                               &tmp_storage[0], tmp_storage.size() );
           ptr = &tmp_storage[0];
                                    size / type_size, hdf_type, ptr,
                                    &status );
@@ -2001,6 +2038,7 @@
       // write offsets
+    TPRINT("  writing var-length sparse tag index chunk.");
     mhdf_writeSparseTagIndices( tables[2], offset_offset, count,
                                 H5T_NATIVE_LONG, offset_buffer,
                                 &status );
@@ -2012,6 +2050,7 @@
     // flush data buffer
   if (bytes) {
+    TPRINT("  writing final var-length sparse tag value chunk.");
     mhdf_writeSparseTagValues( tables[1], data_offset, bytes / type_size,
                                hdf_type, data_buffer, &status );
     CHK_MHDF_ERR_2(status, tables + 1);
@@ -2054,6 +2093,7 @@
   mhdf_Status status;
+  TPRINT("  writing QA history.");
   mhdf_writeHistory( filePtr, &strs[0], strs.size(), &status );
   CHK_MHDF_ERR_0(status);
Modified: MOAB/trunk/WriteHDF5.hpp
--- MOAB/trunk/WriteHDF5.hpp	2009-07-31 19:20:03 UTC (rev 3087)
+++ MOAB/trunk/WriteHDF5.hpp	2009-08-03 20:38:34 UTC (rev 3088)
@@ -106,6 +106,11 @@
   virtual MBErrorCode write_shared_set_parents( hid_t )
     { return MB_SUCCESS;}
   virtual MBErrorCode write_finished();
+  virtual void tprint( const char* fmt, ... )
+#ifdef __GNUC__
+__attribute__((format(printf,2,3)))
+#endif
   //! Gather tags
Modified: MOAB/trunk/parallel/WriteHDF5Parallel.cpp
--- MOAB/trunk/parallel/WriteHDF5Parallel.cpp	2009-07-31 19:20:03 UTC (rev 3087)
+++ MOAB/trunk/parallel/WriteHDF5Parallel.cpp	2009-08-03 20:38:34 UTC (rev 3088)
@@ -1,10 +1,8 @@
 #undef DEBUG
-#ifdef DEBUG
-#  include <stdio.h>
-#  include <stdarg.h>
-#endif
+#include <stdio.h>
 #include <stdio.h>
 #include <time.h>
@@ -73,16 +71,8 @@
     VALGRIND_MAKE_MEM_UNDEFINED( &v[0], v.size() * sizeof(T) );
-#define TPRINT(A)
-//#define TPRINT(A) tprint( (A) )
-static void tprint(const char* A)
-  int rank;
-  MPI_Comm_rank( MPI_COMM_WORLD, &rank );
-  char buffer[128];
-  sprintf(buffer,"%02d: %6.2f: %s\n", rank, (double)clock()/CLOCKS_PER_SEC, A);
-  fputs( buffer, stderr );
 #ifdef DEBUG
 #  define START_SERIAL                     \
@@ -648,6 +638,7 @@
     return MB_FAILURE;
+TPRINT("Exiting parallel_create_file");
   return MB_SUCCESS;
@@ -2049,6 +2040,19 @@
   return WriteHDF5::write_finished();
+void WriteHDF5Parallel::tprint( const char* fmt, ... )
+  static const double t0 = MPI_Wtime();
+  va_list args;
+  int rank;
+  MPI_Comm_rank( MPI_COMM_WORLD, &rank );
+  char buffer[128];
+  size_t n = snprintf( buffer, sizeof(buffer), "%02d: %6.2f: \n", rank, MPI_Wtime()-t0 );
+  va_end(args);
 class TagNameCompare {
   MBInterface* iFace;
Modified: MOAB/trunk/parallel/WriteHDF5Parallel.hpp
--- MOAB/trunk/parallel/WriteHDF5Parallel.hpp	2009-07-31 19:20:03 UTC (rev 3087)
+++ MOAB/trunk/parallel/WriteHDF5Parallel.hpp	2009-08-03 20:38:34 UTC (rev 3088)
@@ -195,6 +195,12 @@
       //! Virtual function overridden from WriteHDF5.
       //! Release memory by clearing member lists.
+#ifdef __GNUC__
+#endif
       //! Remove any remote mesh entities from the passed range.
     void remove_remote_entities( MBEntityHandle relative, MBRange& range );
