[MOAB-dev] r3081 - MOAB/trunk
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Thu Jul 30 15:03:05 CDT 2009
Author: kraftche
Date: 2009-07-30 15:03:05 -0500 (Thu, 30 Jul 2009)
New Revision: 3081
Modified:
   MOAB/trunk/MBCN.hpp
   MOAB/trunk/MBRange.hpp
   MOAB/trunk/TagServer.hpp
Log:
fix some warnings encountered when compiling with icc
Modified: MOAB/trunk/MBCN.hpp
--- MOAB/trunk/MBCN.hpp	2009-07-30 20:02:35 UTC (rev 3080)
+++ MOAB/trunk/MBCN.hpp	2009-07-30 20:03:05 UTC (rev 3081)
@@ -141,49 +141,56 @@
   static void SetBasis(const int in_basis);
   //! return the string type name for this type
-  static const char *EntityTypeName(const MBEntityType this_type);
+  static inline
+  const char *EntityTypeName(const MBEntityType this_type);
   //! given a name, find the corresponding entity type
   static MBEntityType EntityTypeFromName(const char *name);
   //! return the topological entity dimension
-  static short int Dimension(const MBEntityType t);
+  static inline
+  short int Dimension(const MBEntityType t);
   //! return the number of (corner) vertices contained in the specified type.
-  static short int VerticesPerEntity(const MBEntityType t);
+  static inline
+  short int VerticesPerEntity(const MBEntityType t);
   //! return the number of sub-entities bounding the entity.
-  static short int NumSubEntities(const MBEntityType t, const int d);
+  static inline
+  short int NumSubEntities(const MBEntityType t, const int d);
   //! return the type of a particular sub-entity.
   //! \param this_type Type of entity for which sub-entity type is being queried
   //! \param sub_dimension Topological dimension of sub-entity whose type is being queried
   //! \param index Index of sub-entity whose type is being queried
   //! \return type Entity type of sub-entity with specified dimension and index
-  static MBEntityType SubEntityType(const MBEntityType this_type,
-                                    const int sub_dimension,
-                                    const int index);
+  static inline
+  MBEntityType SubEntityType(const MBEntityType this_type,
+                             const int sub_dimension,
+                             const int index);
   //! return the vertex indices of the specified sub-entity.
   //! \param this_type Type of entity for which sub-entity connectivity is being queried
   //! \param sub_dimension Dimension of sub-entity
   //! \param sub_index Index of sub-entity
   //! \param sub_entity_conn Connectivity of sub-entity (returned to calling function)
-  static void SubEntityVertexIndices(const MBEntityType this_type,
-                                     const int sub_index,
-                                     int sub_entity_conn[]);
+  static inline
+  void SubEntityVertexIndices(const MBEntityType this_type,
+                              const int sub_index,
+                              int sub_entity_conn[]);
   //! \param num_sub_ent_vertices the number of vertices in the sub-entity
-  static const short* SubEntityVertexIndices( const MBEntityType this_type,
-                                              MBEntityType& sub_type,
-                                              int& num_sub_ent_vertices );
+  static inline
+  const short* SubEntityVertexIndices( const MBEntityType this_type,
+                                       MBEntityType& sub_type,
+                                       int& num_sub_ent_vertices );
   //! return the node indices of the specified sub-entity.
   //! \param this_topo            The topology of the queried element type
@@ -336,13 +343,15 @@
     //! \param pvec Permutation array
     //! \param num_entries Number of indicies in permutation array
     //! \param is_reverse Array is reverse permutation
-  static void setPermutation(const MBEntityType t, const int dim, int *pvec, const int num_entries,
-                             const bool is_reverse = false);
+  static inline
+  void setPermutation(const MBEntityType t, const int dim, int *pvec,
+                      const int num_entries, const bool is_reverse = false);
     //! Reset permutation or reverse permutation vector
     //! \param t EntityType whose permutation vector is being reset
     //! \param dim Dimension of facets being reset; if -1 is input, all dimensions are reset
-  static void resetPermutation(const MBEntityType t, const int dim);
+  static inline
+  void resetPermutation(const MBEntityType t, const int dim);
     //! Permute a handle array according to permutation vector set with setPermute;
     //! permutation is done in-place
@@ -381,24 +390,27 @@
   //! \param num_verts Number of nodes defining entity
   //! \return bool Returns true if <em>this_type</em> combined with <em>num_nodes</em> indicates
   //!  mid-edge nodes are likely
-  static bool HasMidEdgeNodes(const MBEntityType this_type,
-                              const int num_verts);
+  static inline
+  bool HasMidEdgeNodes(const MBEntityType this_type,
+                       const int num_verts);
   //! true if entities of a given type and number of nodes indicates mid face nodes are present.
   //!  mid-face nodes are likely
-  static bool HasMidFaceNodes(const MBEntityType this_type,
+  static inline
+  bool HasMidFaceNodes(const MBEntityType this_type,
   //! true if entities of a given type and number of nodes indicates mid region nodes are present.
   //!  mid-region nodes are likely
-  static bool HasMidRegionNodes(const MBEntityType this_type,
+  static inline
+  bool HasMidRegionNodes(const MBEntityType this_type,
   //! true if entities of a given type and number of nodes indicates mid edge/face/region nodes
   //! are present.
@@ -406,15 +418,17 @@
   //! \param mid_nodes If <em>mid_nodes[i], i=1..2</em> is non-zero, indicates that mid-edge
   //!    (i=1), mid-face (i=2), and/or mid-region (i=3) nodes are likely
-  static void HasMidNodes(const MBEntityType this_type,
-                          const int num_verts,
-                          int mid_nodes[4]);
+  static inline
+  void HasMidNodes(const MBEntityType this_type,
+                   const int num_verts,
+                   int mid_nodes[4]);
   //! Same as above, except returns a single integer with the bits, from
   //! least significant to most significant set to one if the corresponding
   //! mid nodes on sub entities of the least dimension (0) to the highest
   //! dimension (3) are present in the elment type.
-  static int HasMidNodes( const MBEntityType this_type, const int num_verts );
+  static inline
+  int HasMidNodes( const MBEntityType this_type, const int num_verts );
   //! given data about an element and a vertex in that element, return the dimension
   //! and index of the sub-entity that the vertex resolves.  If it does not resolve a
Modified: MOAB/trunk/MBRange.hpp
--- MOAB/trunk/MBRange.hpp	2009-07-30 20:02:35 UTC (rev 3080)
+++ MOAB/trunk/MBRange.hpp	2009-07-30 20:03:05 UTC (rev 3081)
@@ -220,16 +220,16 @@
   ~MBRange();
   //! return the beginning const iterator of this range
-  const_iterator begin() const;
+  inline const_iterator begin() const;
   //! return the beginning const reverse iterator of this range
-  const_reverse_iterator rbegin() const;
+  inline const_reverse_iterator rbegin() const;
   //! return the ending const iterator for this range
-  const_iterator end() const;
+  inline const_iterator end() const;
   //! return the ending const reverse iterator for this range
-  const_reverse_iterator rend() const;
+  inline const_reverse_iterator rend() const;
   //! return the number of values this Ranges represents
   MBEntityHandle size() const;
@@ -239,7 +239,7 @@
   //! return whether empty or not
   //! always use "if(!Ranges::empty())" instead of "if(Ranges::size())"
-  bool empty() const;
+  inline bool empty() const;
   //! insert an item into the list and return the iterator for the inserted item
   iterator insert(MBEntityHandle val);
@@ -255,12 +255,12 @@
   iterator erase( iterator iter1, iterator iter2);
   //! erases a value from this container
-  iterator erase(MBEntityHandle val);
+  inline iterator erase(MBEntityHandle val);
   //! get first entity in range
-  const MBEntityHandle& front() const;
+  inline const MBEntityHandle& front() const;
   //! get last entity in range
-  const MBEntityHandle& back() const;
+  inline const MBEntityHandle& back() const;
   //! remove first entity from range
   MBEntityHandle pop_front();
   //! remove last entity from range
Modified: MOAB/trunk/TagServer.hpp
--- MOAB/trunk/TagServer.hpp	2009-07-30 20:02:35 UTC (rev 3080)
+++ MOAB/trunk/TagServer.hpp	2009-07-30 20:03:05 UTC (rev 3081)
@@ -304,11 +304,11 @@
   MBErrorCode get_default_data_ref(const MBTag tag_handle, const void *& data, int& size);
   //! get information about a tag
-  const TagInfo* get_tag_info(const char *tag_name ) const;
-  const TagInfo* get_tag_info( MBTag tag_handle ) const;
-  TagInfo* get_tag_info( MBTag tag_handle );
-  const TagInfo* get_tag_info( MBTagId id, MBTagType storage ) const;
-  TagInfo* get_tag_info( MBTagId id, MBTagType storage );
+  inline const TagInfo* get_tag_info(const char *tag_name ) const;
+  inline const TagInfo* get_tag_info( MBTag tag_handle ) const;
+  inline TagInfo* get_tag_info( MBTag tag_handle );
+  inline const TagInfo* get_tag_info( MBTagId id, MBTagType storage ) const;
+  inline TagInfo* get_tag_info( MBTagId id, MBTagType storage );
   unsigned long get_memory_use( MBTag tag_handle ) const;
