[MOAB-dev] r3075 - MOAB/trunk
kraftche at cae.wisc.edu
Thu Jul 30 12:22:08 CDT 2009
Author: kraftche
Date: 2009-07-30 12:22:08 -0500 (Thu, 30 Jul 2009)
New Revision: 3075
Modified:
MOAB/trunk/ReadHDF5.cpp
Log:
fix minor bug (not encountered unless explicitly changing buffer size using file read option, which is only done by testing code.)
Modified: MOAB/trunk/ReadHDF5.cpp
--- MOAB/trunk/ReadHDF5.cpp 2009-07-30 17:02:55 UTC (rev 3074)
+++ MOAB/trunk/ReadHDF5.cpp 2009-07-30 17:22:08 UTC (rev 3075)
@@ -2109,13 +2109,25 @@
long sets_per_buffer = bufferSize / (sizeof(long) + (avg_set_len+1)*sizeof(MBEntityHandle));
// round to down multiple of 8 to avoid alignment issues
sets_per_buffer = 8 * (sets_per_buffer / 8);
- if (sets_per_buffer < 10) // just in case there's one huge set
+ if (sets_per_buffer < 10) { // just in case there's one huge set
sets_per_buffer = 10;
+ if (sets_per_buffer * (long)sizeof(long) > bufferSize)
+ sets_per_buffer = bufferSize/(sizeof(long)+2*sizeof(MBEntityHandle));
long* offset_buffer = (long*)dataBuffer;
MBEntityHandle* content_buffer = (MBEntityHandle*)(offset_buffer + sets_per_buffer);
assert(bufferSize % sizeof(long) == 0);
long content_size = (MBEntityHandle*)(dataBuffer + bufferSize) - content_buffer;
assert(dataBuffer + bufferSize >= (char*)(content_buffer + content_size));
+ // content_size must be an even number or we might end up with half of a
+ // range pair in the buffer, which will break code below
+ if (content_size % 2)
+ --content_size;
+ if (!sets_per_buffer || !content_size) {
+ // buffer is too small to be usable
+ return MB_FAILURE;
MBRange ranged_ids(ranged_ids_in);
MBEntityHandle h = start_handle;
