[MOAB-dev] r3065 - MOAB/trunk/parallel
kraftche at cae.wisc.edu
Tue Jul 28 12:00:27 CDT 2009
Author: kraftche
Date: 2009-07-28 12:00:26 -0500 (Tue, 28 Jul 2009)
New Revision: 3065
Modified:
MOAB/trunk/parallel/WriteHDF5Parallel.cpp
Log:
replace asserts with proper error checks
Modified: MOAB/trunk/parallel/WriteHDF5Parallel.cpp
--- MOAB/trunk/parallel/WriteHDF5Parallel.cpp 2009-07-28 17:00:04 UTC (rev 3064)
+++ MOAB/trunk/parallel/WriteHDF5Parallel.cpp 2009-07-28 17:00:26 UTC (rev 3065)
@@ -42,6 +42,16 @@
#include "WriteHDF5Parallel.hpp"
+#define CHECK_MPI(A) do { if (MPI_SUCCESS != (A)) { \
+ writeUtil->report_error( "MPI Failure at " __FILE__ ":%d\n", __LINE__ ); \
+ return MB_FAILURE; } } while(false)
+#define CHECK_HDF(A) do { if (mhdf_isError(&(A))) { \
+ writeUtil->report_error( "MHDF Failure at " __FILE__ ":%d : %s\n", \
+ __LINE__, mhdf_message(&(A)) ); \
#define TPRINT(A)
//#define TPRINT(A) tprint( (A) )
static void tprint(const char* A)
@@ -87,7 +97,7 @@
#ifdef NDEBUG
-# undef assert(A)
+# undef assert
# define assert
#else
# undef assert
@@ -510,7 +520,7 @@
result = MPI_Gather( &tag_counts[0], 2*num_tags, MPI_UNSIGNED_LONG,
&proc_tag_offsets[0], 2*num_tags, MPI_UNSIGNED_LONG,
0, myPcomm->proc_config().proc_comm() );
- assert(MPI_SUCCESS == result);
+ CHECK_MPI(result);
// Calculate the total counts over all processors (tag_counts)
// and the offset at which each processor should begin writing
@@ -547,7 +557,8 @@
if (0 == myPcomm->proc_config().proc_rank())
rval = create_tag(tag_iter->tag_id, next_offset, next_var_len_offset);
- assert(MB_SUCCESS == rval);
+ if (MB_SUCCESS != rval)
+ return rval;
printdebug( "Creating table of size %lu for tag 0x%lx\n",
next_var_len_offset ? next_var_len_offset : next_offset,
(unsigned long)tag_iter->tag_id );
@@ -557,13 +568,13 @@
// Send total counts to all processors. This is necessary because all
// processors need to know if we are not writing anything for the tag (count == 0).
result = MPI_Bcast( &tag_counts[0], 2*num_tags, MPI_UNSIGNED_LONG, 0, myPcomm->proc_config().proc_comm() );
// Send to each processor its per-tag offset values.
result = MPI_Scatter( &proc_tag_offsets[0], 2*num_tags, MPI_UNSIGNED_LONG,
&tag_offsets[0], 2*num_tags, MPI_UNSIGNED_LONG,
tag_iter = tagList.begin();
@@ -621,7 +632,7 @@
std::vector<long> node_counts(myPcomm->proc_config().proc_size());
long num_nodes = nodeSet.range.size();
result = MPI_Gather( &num_nodes, 1, MPI_LONG, &node_counts[0], 1, MPI_LONG, 0, myPcomm->proc_config().proc_comm() );
// create node data in file
long first_id;
@@ -632,17 +643,13 @@
total += node_counts[i];
hid_t handle = mhdf_createNodeCoords( filePtr, dimension, total, &first_id, &status );
- if (mhdf_isError( &status ))
- writeUtil->report_error( "%s\n", mhdf_message( &status ) );
- return MB_FAILURE;
+ CHECK_HDF(status);
mhdf_closeData( filePtr, handle, &status );
// send id offset to every proc
result = MPI_Bcast( &first_id, 1, MPI_LONG, 0, myPcomm->proc_config().proc_comm() );
nodeSet.first_id = (id_t)first_id;
// calculate per-processor offsets
@@ -663,7 +670,7 @@
result = MPI_Scatter( &node_counts[0], 1, MPI_LONG,
&offset, 1, MPI_LONG,
nodeSet.offset = offset;
return assign_ids( nodeSet.range, nodeSet.first_id + nodeSet.offset );
@@ -708,7 +715,7 @@
int num_types = 2*exportList.size();
std::vector<int> counts(myPcomm->proc_config().proc_size());
result = MPI_Gather( &num_types, 1, MPI_INT, &counts[0], 1, MPI_INT, 0, myPcomm->proc_config().proc_comm() );
// Get list of types on this processor
std::vector<int> my_types(num_types);
@@ -743,7 +750,7 @@
result = MPI_Gatherv( &my_types[0], my_types.size(), MPI_INT,
&alltypes[0], &counts[0], &displs[0], MPI_INT,
// Merge type lists
std::list<elemtype> type_list;
@@ -766,7 +773,7 @@
// Send total number of types to each processor
total = type_list.size();
result = MPI_Bcast( &total, 1, MPI_INT, 0, myPcomm->proc_config().proc_comm() );
// Send list of types to each processor
std::vector<int> intlist(total * 2);
@@ -777,7 +784,7 @@
*viter = liter->numnode; ++viter;
result = MPI_Bcast( &intlist[0], 2*total, MPI_INT, 0, myPcomm->proc_config().proc_comm() );
#ifdef DEBUG
START_SERIAL;
@@ -844,7 +851,7 @@
result = MPI_Gather( &my_counts[0], numtypes, MPI_LONG,
&counts[0], numtypes, MPI_LONG, 0, myPcomm->proc_config().proc_comm() );
// Convert counts to offsets
for (int i = 0; i < numtypes; i++)
@@ -862,7 +869,7 @@
result = MPI_Scatter( &counts[0], numtypes, MPI_LONG,
// Update store offsets in ExportSets
viter = my_counts.begin();
@@ -881,7 +888,8 @@
ex_iter->num_nodes,
*citer,
*viter );
+ return rval;
++citer;
++viter;
@@ -889,7 +897,7 @@
// send start IDs to each processor
result = MPI_Bcast( &start_ids[0], numtypes, MPI_LONG, 0, myPcomm->proc_config().proc_comm() );
// Assign IDs to local elements
viter = start_ids.begin();
@@ -898,7 +906,8 @@
ex_iter->first_id = *(viter++);
id_t myfirst = (id_t)(ex_iter->first_id + ex_iter->offset);
rval = assign_ids( ex_iter->range, myfirst );
+ return rval;
return MB_SUCCESS;
@@ -932,7 +941,8 @@
for (ex_iter = exportList.begin(); ex_iter != exportList.end(); ++ex_iter)
rval = count_adjacencies( ex_iter->range, num_adj );
- assert (MB_SUCCESS == rval);
+ return rval;
*viter = num_adj; ++viter;
@@ -940,7 +950,7 @@
result = MPI_Gather( &local[0], numtypes, MPI_LONG,
&all[0], numtypes, MPI_LONG,
for (i = 0; i < numtypes; i++)
@@ -965,7 +975,7 @@
result = MPI_Scatter( &all[0], numtypes, MPI_LONG,
// Record the adjacency offset in each ExportSet
viter = local.begin();
@@ -985,11 +995,7 @@
mhdf_node_type_handle(),
*viter,
&status );
++viter;
@@ -1003,11 +1009,7 @@
ex_iter->name(),
*viter,
&status );
@@ -1138,7 +1140,7 @@
result = MPI_Allgather( &count, 1, MPI_INT,
&data.counts[0], 1, MPI_INT,
// Exchange tag values for sets between all processors
data.displs.resize(myPcomm->proc_config().proc_size()+1);
@@ -1149,11 +1151,12 @@
data.all_values.resize(total);
data.local_values.resize(count);
rval = iFace->tag_get_data( data.data_tag, data.range, &data.local_values[0] );
- assert( MB_SUCCESS == rval );
+ return rval;
result = MPI_Allgatherv( &data.local_values[0], count, MPI_INT,
&data.all_values[0], &data.counts[0], &data.displs[0], MPI_INT,
// Remove from the list any sets that are unique to one processor
@@ -1270,7 +1273,7 @@
MBErrorCode WriteHDF5Parallel::create_meshset_tables()
- MBErrorCode rval;
+ MBErrorCode rval = MB_SUCCESS;
int result, i;
long total_offset = 0;
MBRange::const_iterator riter;
@@ -1285,10 +1288,10 @@
rval = get_remote_set_data( multiProcSetTags.list[i],
remote_set_data[i],
- total_offset ); assert(MB_SUCCESS == rval);
+ total_offset );
+ return rval;
- //rval = get_interface_set_data( remote_set_data[i], total_offset );
- if (MB_SUCCESS != rval) return rval;
START_SERIAL;
printdebug("myLocalSets\n");
@@ -1302,7 +1305,7 @@
result = MPI_Gather( &local_count, 1, MPI_LONG,
&set_offsets[0], 1, MPI_LONG,
for (unsigned int j = 0; j <= myPcomm->proc_config().proc_size(); j++)
long tmp = set_offsets[j];
@@ -1314,7 +1317,7 @@
long sets_offset;
result = MPI_Scatter( &set_offsets[0], 1, MPI_LONG,
&sets_offset, 1, MPI_LONG, 0, myPcomm->proc_config().proc_comm() );
setSet.offset = (id_t)(sets_offset);
// Create the set description table
@@ -1322,12 +1325,13 @@
if (myPcomm->proc_config().proc_rank() == 0 && total_count_and_start_id[0] > 0)
rval = create_set_meta( (id_t)total_count_and_start_id[0], total_count_and_start_id[1] );
+ return rval;
// Send totals to all procs.
result = MPI_Bcast( total_count_and_start_id, 2, MPI_LONG, 0, myPcomm->proc_config().proc_comm() );
setSet.first_id = total_count_and_start_id[1];
writeSets = total_count_and_start_id[0] > 0;
@@ -1354,7 +1358,8 @@
for (i = 0; i < (int)remote_set_data.size(); ++i)
rval = negotiate_remote_set_contents( remote_set_data[i], data_offsets );
+ return rval;
remote_set_data.clear();
@@ -1364,12 +1369,14 @@
// Communicate counts for local sets
long data_counts[3];
rval = count_set_size( setSet.range, data_counts[0], data_counts[1], data_counts[2] );
+ return rval;
std::vector<long> set_counts(3*myPcomm->proc_config().proc_size());
result = MPI_Gather( data_counts, 3, MPI_LONG,
&set_counts[0], 3, MPI_LONG,
for (unsigned int j = 0; j < 3*myPcomm->proc_config().proc_size(); ++j)
long tmp = set_counts[j];
@@ -1380,7 +1387,7 @@
result = MPI_Scatter( &set_counts[0], 3, MPI_LONG,
data_offsets, 3, MPI_LONG,
setContentsOffset = data_offsets[0];
setChildrenOffset = data_offsets[1];
setParentsOffset = data_offsets[2];
@@ -1389,12 +1396,13 @@
if (myPcomm->proc_config().proc_rank() == 0)
rval = create_set_tables( all_counts[0], all_counts[1], all_counts[2] );
+ return rval;
// Send totals to all processors
result = MPI_Bcast( all_counts, 3, MPI_LONG, 0, myPcomm->proc_config().proc_comm() );
writeSetContents = all_counts[0] > 0;
writeSetChildren = all_counts[1] > 0;
writeSetParents = all_counts[2] > 0;
@@ -1534,8 +1542,9 @@
*sizes_iter = 0;
tmp_range.clear();
rval = iFace->get_entities_by_handle( *riter, tmp_range );
+ return rval;
remove_remote_entities( *riter, tmp_range );
for (MBRange::iterator iter = tmp_range.begin(); iter != tmp_range.end(); ++iter)
if (0 != idMap.find( *iter ))
++*sizes_iter;
@@ -1545,8 +1554,9 @@
*sizes_iter = 0;
child_list.clear();
rval = iFace->get_child_meshsets( *riter, child_list );
+ return rval;
remove_remote_sets( *riter, child_list );
for (std::vector<MBEntityHandle>::iterator iter = child_list.begin();
iter != child_list.end(); ++iter)
@@ -1557,8 +1567,9 @@
*sizes_iter = 0;
child_list.clear();
rval = iFace->get_parent_meshsets( *riter, child_list );
+ return rval;
@@ -1577,7 +1588,7 @@
result = MPI_Allgatherv( &local_sizes[0], 3*count, MPI_LONG,
&all_sizes[0], &counts[0], &displs[0], MPI_LONG,
// Update information in-place in the array from the Allgatherv.
@@ -1767,7 +1778,8 @@
// Get flag data
unsigned int flags;
rval = iFace->get_meshset_options( iter->handle, flags );
+ return rval;
// Write the data
long data[4] = { iter->contentsOffset + iter->contentsCount - 1,
@@ -1775,11 +1787,7 @@
iter->parentsOffset + iter->parentsCount - 1,
flags };
mhdf_writeSetMeta( table, file_id, 1, H5T_NATIVE_LONG, data, &status );
- if (mhdf_isError(&status)) {
- printdebug("Meshset %d : %s\n", ID_FROM_HANDLE(iter->handle), mhdf_message(&status));
- assert(0);
TPRINT( "finished write_shared_set_descriptions" );
@@ -1802,7 +1810,8 @@
handle_list.clear();
rval = iFace->get_entities_by_handle( iter->handle, handle_list );
+ return rval;
remove_remote_entities( iter->handle, handle_list );
id_list.clear();
@@ -1816,7 +1825,7 @@
id_type,
&id_list[0],
&status );
- assert(!mhdf_isError(&status));
@@ -1840,7 +1849,8 @@
rval = iFace->get_child_meshsets( iter->handle, handle_list );
+ return rval;
remove_remote_sets( iter->handle, handle_list );
id_list.clear();
@@ -1853,7 +1863,7 @@
id_type,
&id_list[0],
&status );
@@ -1877,7 +1887,8 @@
rval = iFace->get_parent_meshsets( iter->handle, handle_list );
+ return rval;
id_list.clear();
@@ -1890,7 +1901,7 @@
id_type,
&id_list[0],
&status );
