[MOAB-dev] r3060 - MOAB/trunk
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Mon Jul 27 13:05:43 CDT 2009
Author: kraftche
Date: 2009-07-27 13:05:42 -0500 (Mon, 27 Jul 2009)
New Revision: 3060
Modified:
   MOAB/trunk/MBRange.cpp
   MOAB/trunk/MBRange.hpp
   MOAB/trunk/MBTest.cpp
Log:
o Add more efficent range-based erase implementation for MBRange
o Fix exsiting single-value MBRange::erase such that all iterators
  pointing into a location in an MBRange previous to an erased
  value remain valid after the erase.
o Add unit tests for the above.
Modified: MOAB/trunk/MBRange.cpp
--- MOAB/trunk/MBRange.cpp	2009-07-27 15:29:51 UTC (rev 3059)
+++ MOAB/trunk/MBRange.cpp	2009-07-27 18:05:42 UTC (rev 3060)
@@ -424,14 +424,71 @@
   // split the range
   else
-    PairNode* new_node = alloc_pair(iter.mNode, iter.mNode->mPrev, kter->first, iter.mValue-1);
+    PairNode* new_node = alloc_pair(iter.mNode->mNext, iter.mNode, iter.mValue+1, kter->second);
     new_node->mPrev->mNext = new_node->mNext->mPrev = new_node;
-    iter.mNode->first = iter.mValue+1;
+    iter.mNode->second = iter.mValue - 1;
     return new_iter;
+  //! remove a range of items from the list
+MBRange::iterator MBRange::erase( iterator iter1, iterator iter2)
+  iterator result;
+  if (iter1.mNode == iter2.mNode) {
+    if (iter2.mValue <= iter1.mValue) {
+        // empty range OK, otherwise invalid input
+      return iter2;
+      // If both iterators reference the same pair node, then
+      // we're either removing values from the front of the
+      // node or splitting the node.  We can never be removing
+      // the last value in the node in this case because iter2
+      // points *after* the last entry to be removed.
+    PairNode* node = iter1.mNode;
+    if (iter1.mValue == node->first) {
+        node->first = iter2.mValue;
+        result = iter2;
+    else {
+      PairNode* new_node = alloc_pair( node->mNext, node, iter2.mValue, node->second );
+      new_node->mNext->mPrev = new_node;
+      new_node->mPrev->mNext = new_node;
+      node->second = iter1.mValue - 1;
+      result = iterator( new_node, new_node->first );
+  else {
+    if (iter1.mNode == &mHead)
+      return iter1;
+    PairNode* dn = iter1.mNode;
+    if (iter1.mValue > dn->first) {
+      dn->second = iter1.mValue-1;
+      dn = dn->mNext;
+    if (iter2.mNode != &mHead)
+      iter2.mNode->first = iter2.mValue;
+    while (dn != iter2.mNode) {
+      PairNode* dead = dn;
+      dn = dn->mNext;
+      dead->mPrev->mNext = dead->mNext;
+      dead->mNext->mPrev = dead->mPrev;
+      dead->mPrev = dead->mNext = 0;
+      delete dead;
+    result = iter2;
+  return result;
 void MBRange::delete_pair_node( PairNode* node )
   if (node != &mHead) { // pop_front() and pop_back() rely on this check
Modified: MOAB/trunk/MBRange.hpp
--- MOAB/trunk/MBRange.hpp	2009-07-27 15:29:51 UTC (rev 3059)
+++ MOAB/trunk/MBRange.hpp	2009-07-27 18:05:42 UTC (rev 3060)
@@ -759,14 +759,6 @@
   return (mHead.mNext == &mHead);
-  //! remove a range of items from the list
-inline MBRange::iterator MBRange::erase( iterator iter1, iterator iter2)
-  while( iter1 != iter2 )
-    erase( iter1++ );
-  return iter1;
   //! erases a value from this container
 inline MBRange::iterator MBRange::erase(MBEntityHandle val)
Modified: MOAB/trunk/MBTest.cpp
--- MOAB/trunk/MBTest.cpp	2009-07-27 15:29:51 UTC (rev 3059)
+++ MOAB/trunk/MBTest.cpp	2009-07-27 18:05:42 UTC (rev 3060)
@@ -62,6 +62,16 @@
             << __LINE__ << std::endl; \
   return A; } } while(false)
+#define CHECK_EQUAL( A, B ) do { if ((A) != (B)) { \
+            std::cerr << "Equality Test failed at " __FILE__ ":" << __LINE__ << std::endl; \
+            std::cerr << "  Expected: " << (A) << std::endl; \
+            std::cerr << "  Actual:   " << (B) << std::endl; \
+            return MB_FAILURE; } } while(false)
+#define CHECK( A ) do { if (!(A)) { \
+            std::cerr << "Test failed at " __FILE__ ":" << __LINE__ << std::endl; \
     @test
     Vertex Coordinates
@@ -5209,6 +5219,171 @@
   return result;
+MBErrorCode mb_range_erase_test(MBInterface *)
+  MBRange range;
+  MBRange::iterator result;
+    // test erase from first node
+  range.clear();
+  range.insert( 5, 10 );
+  range.insert( 12, 20 );
+  result = range.erase( range.begin(), range.begin()+2 );
+  CHECK_EQUAL(  7u, range.front() );
+  CHECK_EQUAL( 20u, range.back() );
+  CHECK_EQUAL( 13u, range.size() );
+  CHECK_EQUAL(  7u, *result );
+    // test erase first node
+  range.clear();
+  result = range.erase( range.begin(), range.begin()+6 );
+  CHECK_EQUAL( 12u, range.front() );
+  CHECK_EQUAL(  9u, range.size() );
+  CHECK_EQUAL( 12u, *result );
+    // test erase from back of first node
+  range.clear();
+  result = range.erase( range.begin()+2, range.begin()+6 );
+  CHECK_EQUAL(  5u, range.front() );
+  CHECK_EQUAL( 11u, range.size() );
+    // test erase from middle of first node
+  range.clear();
+  result = range.erase( range.begin()+2, range.begin()+5 );
+  CHECK_EQUAL( 12u, range.size() );
+  CHECK_EQUAL( 10u, *result );
+    // test erase spanning two nodes
+  range.clear();
+  result = range.erase( range.begin()+3, range.begin()+7 );
+  CHECK_EQUAL( 13u, *result );
+    // test erase of first node and part of second
+  range.clear();
+  result = range.erase( range.begin(), range.begin()+7 );
+  CHECK_EQUAL( 13u, range.front() );
+  CHECK_EQUAL(  8u, range.size() );
+    // test erase spanning three nodes
+  range.clear();
+  range.insert( 100, 101 );
+  result = range.erase( range.begin()+3, range.begin()+16 );
+  CHECK_EQUAL( 101u, range.back() );
+  CHECK_EQUAL(   4u, range.size() );
+  CHECK_EQUAL( 101u, *result );
+    // test erase from start of second node
+  range.clear();
+  result = range.erase( range.begin()+6, range.begin()+8 );
+  CHECK_EQUAL( 14u, *result );
+    // test erase from back of last node
+  range.clear();
+  result = range.erase( range.begin()+13, range.end() );
+  CHECK_EQUAL( 18u, range.back() );
+  CHECK( result == range.end() );
+    // test erase part of first node through end
+  range.clear();
+  result = range.erase( range.begin()+4, range.end() );
+  CHECK_EQUAL( 8u, range.back() );
+    // test erase of single node
+  range.clear();
+  result = range.erase( range.begin(), range.end() );
+  CHECK_EQUAL( 0u, range.size() );
+    // test erase of multi-node range
+  range.clear();
+    // test erase nothing
+  range.clear();
+  result = range.erase( range.begin()+3, range.begin()+3 );
+  CHECK_EQUAL( 15u, range.size() );
+  CHECK_EQUAL(  8u, *result );
+    // test iterators before erase remain valid
+  MBRange::iterator a, b, c;
+  range.clear();
+  a = range.begin();
+  b = range.begin() + 6;
+  c = range.begin() + 8;
+  result = range.erase( range.begin() + 9, range.end() );
+  CHECK( a == range.begin() );
+  CHECK( b == range.begin() + 6 );
+  CHECK( c == range.begin() + 8 );
+    // test iterators before erase remain valid, single value case
+  range.clear();
+  result = range.erase( range.begin() + 9 );
+  CHECK_EQUAL( 14u, range.size() );
+  CHECK_EQUAL( 16u, *result );
+  return MB_SUCCESS;
 MBErrorCode mb_topo_util_test(MBInterface *gMB)
   MeshTopoUtil mtu(gMB);
@@ -6514,6 +6689,7 @@
   RUN_TEST( mb_canon_number_test );
   RUN_TEST( mb_poly_test );
   RUN_TEST( mb_range_test );
+  RUN_TEST( mb_range_erase_test );
   RUN_TEST( mb_topo_util_test );
   RUN_TEST( mb_split_test );
   RUN_TEST( mb_range_seq_intersect_test );
