[MOAB-dev] Problem with MPI-based MOAB build
    Tim Tautges
    tautges at mcs.anl.gov
    Thu Jul 23 21:50:40 CDT 2009
All right, time to stop working so late.  Clean checkout works, serial
and parallel.  I swear I did make distclean's everywhere, but go figure.
  If you see a bunch of undefined references for MBParallelComm
functions, try making a clean build.
Sorry for the false alarm, Jason.
- tim
Tim Tautges wrote:
> Well, now I see -DUSE_MPI in the compile commands with a clean copy.
> Stay tuned.
> - tim
> Tim Tautges wrote:
>> Hi all (Jason?),
>>   The MPI-based build of MOAB is broken.  Looks like -DUSE_MPI is
>> getting dropped at some point.
>> Everyone, if you're going to commit something to the configure stuff,
>> or anything else that may have far-reaching influences, please check
>> the parallel build as well as the serial one (I do the same when I
>> commit the parallel work).
>> - tim
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
