[MOAB-dev] r3053 - MOAB/trunk/test/h5file
kraftche at mcs.anl.gov
Wed Jul 22 14:13:45 CDT 2009
Author: kraftche
Date: 2009-07-22 14:13:45 -0500 (Wed, 22 Jul 2009)
New Revision: 3053
Modified:
MOAB/trunk/test/h5file/h5sets_test.cpp
Log:
add smaller tree test that is always run and use smaller buffer size so that errors are more likely to be exposed with a smaller data set
Modified: MOAB/trunk/test/h5file/h5sets_test.cpp
--- MOAB/trunk/test/h5file/h5sets_test.cpp 2009-07-22 19:12:16 UTC (rev 3052)
+++ MOAB/trunk/test/h5file/h5sets_test.cpp 2009-07-22 19:13:45 UTC (rev 3053)
@@ -5,6 +5,7 @@
#include <algorithm>
#include <iostream>
+#include <sstream>
#include <stdlib.h>
#include <math.h>
@@ -118,15 +119,45 @@
-void recursive_build_tree( MBInterface& mb,
+int coords_by_idx( int idx, double coords[][3] )
+ coords[0][0] = idx;
+ coords[0][1] = 0;
+ coords[0][2] = 0;
+ coords[1][0] = 0;
+ coords[1][1] = idx;
+ coords[1][2] = 0;
+ coords[2][0] = 0;
+ coords[2][1] = 0;
+ coords[2][2] = idx;
+ coords[3][0] = 3.14*idx;
+ coords[3][1] = 1;
+ coords[3][2] = 1;
+ coords[4][0] = 1;
+ coords[4][1] = 3.14*idx;
+ coords[4][2] = 1;
+ coords[5][0] = 1;
+ coords[5][1] = 1;
+ coords[5][2] = 3.14*idx;
+ return idx % 5 + 1;
+void recursive_build_tree( int max_depth,
+ MBInterface& mb,
MBTag tag,
MBEntityHandle p,
int depth,
int& idx )
MBErrorCode rval = mb.tag_set_data( tag, &p, 1, &idx ); CHECK_ERR(rval);
+ MBRange verts;
+ double coords[6][3];
+ int num_vtx = coords_by_idx( idx, coords );
+ rval = mb.create_vertices( &coords[0][0], num_vtx, verts );
+ rval = mb.add_entities( p, verts );
++idx;
- if (depth == 20)
+ if (depth == max_depth)
return;
MBEntityHandle l, r;
@@ -135,11 +166,12 @@
rval = mb.add_parent_child( p, l ); CHECK_ERR(rval);
rval = mb.add_parent_child( p, r ); CHECK_ERR(rval);
- recursive_build_tree( mb, tag, l, depth+1, idx );
- recursive_build_tree( mb, tag, r, depth+1, idx );
+ recursive_build_tree( max_depth, mb, tag, l, depth+1, idx );
+ recursive_build_tree( max_depth, mb, tag, r, depth+1, idx );
-void recursive_check_tree( MBInterface& mb,
+void recursive_check_tree( int max_depth,
+ MBInterface& mb,
MBTag tag,
MBEntityHandle p,
int depth,
@@ -148,12 +180,44 @@
int id;
MBErrorCode rval = mb.tag_get_data( tag, &p, 1, &id); CHECK_ERR(rval);
CHECK_EQUAL( idx, id );
+ MBRange verts;
+ rval = mb.get_entities_by_handle( p, verts );
+ CHECK( verts.all_of_type( MBVERTEX ) );
+ CHECK_EQUAL( num_vtx, (int)verts.size() );
+ double coords2[6][3];
+ rval = mb.get_coords( verts, &coords2[0][0] );
+ std::vector<bool> match(6,true);
+ for (int i = 0; i < num_vtx; ++i) {
+ match[i] = false;
+ for (int j = 0; j < num_vtx; ++j) {
+ if (!match[j]) {
+ double d[3] = { coords[i][0] - coords2[j][0],
+ coords[i][1] - coords2[j][1],
+ coords[i][2] - coords2[j][2] };
+ double ds = d[0]*d[0] + d[1]*d[1] + d[2]*d[2];
+ if (ds < 1e-12) {
+ match[j] = true;
+ break;
+ CHECK( match[0] );
+ CHECK( match[1] );
+ CHECK( match[2] );
+ CHECK( match[3] );
+ CHECK( match[4] );
+ CHECK( match[5] );
++idx;
std::vector<MBEntityHandle> children, parents;
rval = mb.get_child_meshsets( p, children ); CHECK_ERR(rval);
- if (depth == 20) {
+ if (depth == max_depth) {
CHECK_EQUAL( (size_t)0, children.size() );
return;
@@ -171,12 +235,12 @@
CHECK_EQUAL( (size_t)1, parents.size() );
CHECK_EQUAL( p, parents.front() );
- recursive_check_tree( mb, tag, l, depth+1, idx );
- recursive_check_tree( mb, tag, r, depth+1, idx );
+ recursive_check_tree( max_depth, mb, tag, l, depth+1, idx );
+ recursive_check_tree( max_depth, mb, tag, r, depth+1, idx );
-void test_big_tree()
+void test_tree( int max_depth )
MBErrorCode rval;
MBCore moab;
@@ -191,16 +255,19 @@
// create a binary tree to a depth of 20 (about 1 million nodes)
rval = mb.create_meshset( MESHSET_SET, root ); CHECK_ERR(rval);
int idx = 0;
- recursive_build_tree( mb, tag, root, 1, idx );
+ recursive_build_tree( max_depth, mb, tag, root, 1, idx );
const int last_idx = idx;
std::cerr << "Created binary tree containing " << last_idx << " nodes." << std::endl;
+ std::ostringstream str;
+ str << "tree-" << max_depth << ".h5m";
// write file and read back in
- rval = mb.write_file( "big_tree.h5m" ); CHECK_ERR(rval);
+ rval = mb.write_file( str.str().c_str(), 0, "BUFFER_SIZE=1024" ); CHECK_ERR(rval);
mb.delete_mesh();
- rval = mb.load_file( "big_tree.h5m", root );
+ rval = mb.load_file( str.str().c_str(), root );
if (!keep_file)
- remove( "big_tree.h5m" );
+ remove( str.str().c_str() );
CHECK_ERR(rval);
// get tree root
@@ -214,10 +281,24 @@
// check that tree is as we expect it
idx = 0;
- recursive_check_tree( mb, tag, root, 1, idx );
+ recursive_check_tree( max_depth, mb, tag, root, 1, idx );
CHECK_EQUAL( last_idx, idx );
+void test_small_tree()
+ int max_depth = 5;
+ const char* str = getenv("MAX_DEPTH");
+ if (str) {
+ max_depth = atoi(str);
+ CHECK(max_depth > 0);
+ test_tree( max_depth );
+void test_big_tree()
+ { test_tree( 20 ); }
int main(int argc, char* argv[])
bool do_big_tree_test = false;
@@ -237,6 +318,7 @@
int exitval = 0;
exitval += RUN_TEST( test_ranged_set_with_holes );
exitval += RUN_TEST( test_file_set );
+ exitval += RUN_TEST( test_small_tree );
if (do_big_tree_test) {
exitval += RUN_TEST( test_big_tree );
