[MOAB-dev] r3050 - MOAB/trunk
    kraftche at mcs.anl.gov
    Wed Jul 22 12:29:11 CDT 2009
Author: kraftche
Date: 2009-07-22 12:29:11 -0500 (Wed, 22 Jul 2009)
New Revision: 3050
Modified:
   MOAB/trunk/MBTest.cpp
Log:
Test single-edge case and use_adj case for skinner
Modified: MOAB/trunk/MBTest.cpp
--- MOAB/trunk/MBTest.cpp	2009-07-22 17:28:40 UTC (rev 3049)
+++ MOAB/trunk/MBTest.cpp	2009-07-22 17:29:11 UTC (rev 3050)
@@ -6032,8 +6032,32 @@
   return MB_SUCCESS;
+MBErrorCode mb_skin_curve_test_common( bool use_adj );
+MBErrorCode mb_skin_curve_test( MBInterface* )
+  { return mb_skin_curve_test_common( false ); }
+MBErrorCode mb_skin_curve_adj_test( MBInterface* )
+  { return mb_skin_curve_test_common( true ); }
+MBErrorCode mb_skin_surface_test_common( bool use_adj );
+MBErrorCode mb_skin_surface_test( MBInterface* )
+  { return mb_skin_surface_test_common( false ); }
+MBErrorCode mb_skin_surface_adj_test( MBInterface* )
+  { return mb_skin_surface_test_common( true ); }
+MBErrorCode mb_skin_volume_test_common( bool use_adj );
+MBErrorCode mb_skin_volume_test( MBInterface* )
+  { return mb_skin_volume_test_common( false ); }
+MBErrorCode mb_skin_volume_adj_test( MBInterface* )
+  { return mb_skin_volume_test_common( true ); }
-MBErrorCode mb_skin_curve_test( MBInterface* )
   MBErrorCode rval;
   MBCore moab;
@@ -6056,7 +6080,7 @@
   MBRange skin;
   MBSkinner tool(mb);
-  rval = tool.find_skin( edges, 0, skin );
+  rval = tool.find_skin( edges, 0, skin, use_adj );
   if (MB_SUCCESS != rval) {
     std::cerr << "Skinner failure at " __FILE__ ":" << __LINE__ << std::endl;
     return MB_FAILURE;
@@ -6073,11 +6097,34 @@
     std::cerr << "Skinner bad result at " __FILE__ ":" << __LINE__ << std::endl;
     return MB_FAILURE;
+    // now test again with only one edge
+  MBEntityHandle edge = edges.front();
+  MBRange range(edge,edge);
+  skin.clear();
+  rval = tool.find_skin( range, 0, skin, use_adj );
+  if (MB_SUCCESS != rval) {
+    std::cerr << "Skinner failure at " __FILE__ ":" << __LINE__ << std::endl;
+    return MB_FAILURE;
+  if (skin.size() != 2) {
+    std::cerr << "Skinner bad result at " __FILE__ ":" << __LINE__ << std::endl;
+  MBRange verts2;
+  mb->get_connectivity( &edge, 1, verts2 );
+  if (skin.front() != verts2.front() ||
+      skin.back()  != verts2.back()) {
   return MB_SUCCESS;
-MBErrorCode mb_skin_surface_test( MBInterface* )
   MBErrorCode rval;
   MBCore moab;
@@ -6125,7 +6172,7 @@
   MBRange skin;
   MBSkinner tool(mb);
-  rval = tool.find_skin( source, 1, skin );
+  rval = tool.find_skin( source, 1, skin, use_adj );
     return MB_FAILURE;
@@ -6163,7 +6210,7 @@
   return MB_SUCCESS;
-MBErrorCode mb_skin_volume_test( MBInterface* )
   MBErrorCode rval;
   MBCore moab;
@@ -6218,7 +6265,7 @@
   MBRange skin;
   MBSkinner tool(mb);
-  rval = tool.find_skin( source, 2, skin );
+  rval = tool.find_skin( source, 2, skin, use_adj );
     return MB_FAILURE;
@@ -6352,8 +6399,11 @@
   RUN_TEST( mb_poly_adjacency_test );
   RUN_TEST( mb_memory_use_test );
   RUN_TEST( mb_skin_curve_test );
+  RUN_TEST( mb_skin_curve_adj_test );
   RUN_TEST( mb_skin_surface_test );
+  RUN_TEST( mb_skin_surface_adj_test );
   RUN_TEST( mb_skin_volume_test );
+  RUN_TEST( mb_skin_volume_adj_test );
   RUN_TEST( mb_merge_test );
   RUN_TEST( mb_merge_update_test );
   if (stress_test) RUN_TEST( mb_stress_test );
