[MOAB-dev] r3031 - MOAB/trunk
    kraftche at mcs.anl.gov
    Mon Jul 20 12:18:16 CDT 2009
Author: kraftche
Date: 2009-07-20 12:18:16 -0500 (Mon, 20 Jul 2009)
New Revision: 3031
Modified:
   MOAB/trunk/AEntityFactory.cpp
   MOAB/trunk/MBCore.cpp
   MOAB/trunk/MBTest.cpp
Log:
o Add unit test for merging that demonstrates bug updating references to
  merged vertices when vertices are contained in tracking sets.
o Fix above bug
o Fix incorrect error handling in MBCore::merge_entities: if updating
  of references fails, don't delete the entity.
Modified: MOAB/trunk/AEntityFactory.cpp
--- MOAB/trunk/AEntityFactory.cpp	2009-07-19 02:48:22 UTC (rev 3030)
+++ MOAB/trunk/AEntityFactory.cpp	2009-07-20 17:18:16 UTC (rev 3031)
@@ -1339,8 +1339,15 @@
     return result;
     // set them all, and if to_entity is a set, add to that one too
   for (unsigned int i = 0; i < adjs.size(); i++) {
-    if(ent_dim == 0)
+    if (TYPE_FROM_HANDLE(adjs[i]) == MBENTITYSET)
+      result = this->add_adjacency(entity_to_keep, adjs[i]);
+      if(result != MB_SUCCESS) return result;
+      result = thisMB->add_entities(adjs[i], &entity_to_keep, 1);
+    else if(ent_dim == 0)
       conn.clear();
       result = thisMB->get_connectivity(&adjs[i], 1, conn);
@@ -1355,10 +1362,6 @@
     else {
-      if (TYPE_FROM_HANDLE(adjs[i]) == MBENTITYSET) {
-        result = thisMB->add_entities(adjs[i], &entity_to_keep, 1);
-        if(result != MB_SUCCESS) return result;
Modified: MOAB/trunk/MBCore.cpp
--- MOAB/trunk/MBCore.cpp	2009-07-19 02:48:22 UTC (rev 3030)
+++ MOAB/trunk/MBCore.cpp	2009-07-20 17:18:16 UTC (rev 3031)
@@ -1934,7 +1934,7 @@
   result = aEntityFactory->merge_adjust_adjacencies(entity_to_keep, entity_to_remove);
-  if (delete_removed_entity)
+  if (MB_SUCCESS == result && delete_removed_entity)
     result = delete_entities(&entity_to_remove, 1);
   return result;
Modified: MOAB/trunk/MBTest.cpp
--- MOAB/trunk/MBTest.cpp	2009-07-19 02:48:22 UTC (rev 3030)
+++ MOAB/trunk/MBTest.cpp	2009-07-20 17:18:16 UTC (rev 3031)
@@ -4323,7 +4323,123 @@
   return result;
+MBErrorCode mb_merge_update_test(MBInterface*)
+  MBCore moab;
+  MBInterface* mb = &moab;
+  MBErrorCode rval;
+    // create two quads with a coincident edge pair
+  double coords[] = { 0, 0, 0,
+                      1, 0, 0,
+                      1, 1, 0,
+                      0, 1, 0,
+                      1, 1, 0,
+                      1, 0, 0,
+                      2, 0, 0,
+                      2, 1, 0 };
+  MBEntityHandle verts[8];
+  for (int i = 0; i < 8; ++i)
+    mb->create_vertex( coords + 3*i, verts[i] );
+  MBEntityHandle quad1, quad2, edge1, edge2;
+  mb->create_element( MBQUAD, verts, 4, quad1 );
+  mb->create_element( MBQUAD, verts+4, 4, quad2 );
+  mb->create_element( MBEDGE, verts+1, 2, edge1 );
+  mb->create_element( MBEDGE, verts+4, 2, edge2 );
+    // create two tracking sets containing the vertices
+    // and edge of each quad
+  MBEntityHandle set1, set2;
+  mb->create_meshset( MESHSET_TRACK_OWNER, set1 );
+  mb->create_meshset( MESHSET_TRACK_OWNER, set2 );
+  mb->add_entities( set1, verts, 4 );
+  mb->add_entities( set2, verts+4, 4 );
+  mb->add_entities( set1, &edge1, 1 );
+  mb->add_entities( set2, &edge2, 1 );
+    // now merge the coincident edges
+  rval = mb->merge_entities( verts[1], verts[5], false, true );
+  if (MB_SUCCESS != rval) {
+    std::cerr << "Merge failed at " << __FILE__ << ":" << __LINE__ << std::endl;
+    return rval;
+  rval = mb->merge_entities( verts[2], verts[4], false, true );
+    return rval;
+  rval = mb->merge_entities( edge1, edge2, false, true );
+    return rval;
+    // check that there is only one edge and that it has the correct connectivity
+  MBRange r;
+  mb->get_entities_by_type( 0, MBEDGE, r );
+  if (r.size() != 1 || r.front() != edge1) {
+    std::cerr << "Edge merge failed at " << __FILE__ << ":" << __LINE__ << std::endl;
+    return MB_FAILURE;
+  std::vector<MBEntityHandle> exp(verts+1, verts+3), act;
+  mb->get_connectivity( &edge1, 1, act );
+  if (exp != act) {
+    std::cerr << "Incorrect conn for edge at " << __FILE__ << ":" << __LINE__ << std::endl;
+    // check that quad connectivity is as expected
+  exp = std::vector<MBEntityHandle>(verts, verts+4);
+  act.clear();
+  mb->get_connectivity( &quad1, 1, act );
+  if (exp != act) {
+    std::cerr << "Incorrect conn for quad at " << __FILE__ << ":" << __LINE__ << std::endl;
+  exp.resize(4);
+  exp[0] = verts[2];
+  exp[1] = verts[1];
+  exp[2] = verts[6];
+  exp[3] = verts[7];
+  act.clear();
+  mb->get_connectivity( &quad2, 1, act );
+  if (exp != act) {
+    // check that set contents are correctly updated
+  exp.push_back( edge1 );
+  act.clear();
+  mb->get_entities_by_handle( set1, act );
+  std::sort( exp.begin(), exp.end() );
+  std::sort( act.begin(), act.end() );
+  if (exp != act) {
+    std::cerr << "Incorrect set contents at " << __FILE__ << ":" << __LINE__ << std::endl;
+  exp.resize(5);
+  exp[4] = edge1;
+  act.clear();
+  mb->get_entities_by_handle( set2, act );
+  if (exp != act) {
+  return MB_SUCCESS;
 MBErrorCode mb_stress_test(MBInterface *MB)
     // delete the existing mesh
@@ -6040,6 +6156,7 @@
   RUN_TEST( mb_poly_adjacency_test );
   RUN_TEST( mb_memory_use_test );
   RUN_TEST( mb_merge_test );
+  RUN_TEST( mb_merge_update_test );
   if (stress_test) RUN_TEST( mb_stress_test );
     // summary
