[MOAB-dev] r3029 - in MOAB/trunk: . tools/iMesh/python
    jvporter at mcs.anl.gov
    Sat Jul 18 21:46:51 CDT 2009
Author: jvporter
Date: 2009-07-18 21:46:51 -0500 (Sat, 18 Jul 2009)
New Revision: 3029
Modified:
   MOAB/trunk/configure.ac
   MOAB/trunk/tools/iMesh/python/Makefile
Log:
* Unbreak the nightly test
Modified: MOAB/trunk/configure.ac
--- MOAB/trunk/configure.ac	2009-07-18 03:02:44 UTC (rev 3028)
+++ MOAB/trunk/configure.ac	2009-07-19 02:46:51 UTC (rev 3029)
@@ -976,6 +976,7 @@
                  tools/iMesh/SIDL/iMesh-SIDL-Defs.inc
                  tools/iMesh/SIDL/Makefile
                  tools/iMesh/SIDL/common.make
+                 tools/iMesh/python/Makefile
                  tools/iMesh/python/setup.cfg
                  tools/mbperf/Makefile
                  tools/mbchaco/Makefile
Modified: MOAB/trunk/tools/iMesh/python/Makefile
--- MOAB/trunk/tools/iMesh/python/Makefile	2009-07-18 03:02:44 UTC (rev 3028)
+++ MOAB/trunk/tools/iMesh/python/Makefile	2009-07-19 02:46:51 UTC (rev 3029)
@@ -1,3 +1,380 @@
+# Makefile.in generated by automake 1.10.1 from Makefile.am.
+# tools/iMesh/python/Makefile.  Generated from Makefile.in by configure.
+# Copyright (C) 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002,
+# 2003, 2004, 2005, 2006, 2007, 2008  Free Software Foundation, Inc.
+# This Makefile.in is free software; the Free Software Foundation
+# gives unlimited permission to copy and/or distribute it,
+# with or without modifications, as long as this notice is preserved.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY, to the extent permitted by law; without
+# even the implied warranty of MERCHANTABILITY or FITNESS FOR A
+# PARTICULAR PURPOSE.
+pkgdatadir = $(datadir)/moab
+pkglibdir = $(libdir)/moab
+pkgincludedir = $(includedir)/moab
+am__cd = CDPATH="$${ZSH_VERSION+.}$(PATH_SEPARATOR)" && cd
+install_sh_DATA = $(install_sh) -c -m 644
+install_sh_PROGRAM = $(install_sh) -c
+install_sh_SCRIPT = $(install_sh) -c
+INSTALL_HEADER = $(INSTALL_DATA)
+transform = $(program_transform_name)
+NORMAL_INSTALL = :
+PRE_INSTALL = :
+POST_INSTALL = :
+NORMAL_UNINSTALL = :
+PRE_UNINSTALL = :
+POST_UNINSTALL = :
+build_triplet = x86_64-unknown-linux-gnu
+host_triplet = x86_64-unknown-linux-gnu
+target_triplet = x86_64-unknown-linux-gnu
+subdir = tools/iMesh/python
+DIST_COMMON = README $(srcdir)/Makefile.am $(srcdir)/Makefile.in \
+	$(srcdir)/setup.cfg.in
+ACLOCAL_M4 = $(top_srcdir)/aclocal.m4
+am__aclocal_m4_deps = $(top_srcdir)/m4/compiler.m4 \
+	$(top_srcdir)/m4/cplusplus.m4 $(top_srcdir)/m4/hdf5.m4 \
+	$(top_srcdir)/m4/makevar.m4 $(top_srcdir)/m4/netcdf.m4 \
+	$(top_srcdir)/configure.ac
+am__configure_deps = $(am__aclocal_m4_deps) $(CONFIGURE_DEPENDENCIES) \
+	$(ACLOCAL_M4)
+mkinstalldirs = $(install_sh) -d
+CONFIG_HEADER = $(top_builddir)/config.h $(top_builddir)/MBVersion.h \
+	$(top_builddir)/MBEntityHandle.h $(top_builddir)/MBCN_FCDefs.h
+CONFIG_CLEAN_FILES = setup.cfg
+SOURCES =
+DIST_SOURCES =
+DISTFILES = $(DIST_COMMON) $(DIST_SOURCES) $(TEXINFOS) $(EXTRA_DIST)
+ACLOCAL = ${SHELL} /home/porterj/svn/moab/missing --run aclocal-1.10
+AMTAR = ${SHELL} /home/porterj/svn/moab/missing --run tar
+AM_CFLAGS =
+AM_CPPFLAGS =   -I/usr/local/hdf5serial//include -isystem /usr/local/hdf5serial//include
+AM_CXXFLAGS =
+AM_LDFLAGS =       -L/usr/local/hdf5serial//lib
+AR = ar
+AUTOCONF = ${SHELL} /home/porterj/svn/moab/missing --run autoconf
+AUTOHEADER = ${SHELL} /home/porterj/svn/moab/missing --run autoheader
+AUTOMAKE = ${SHELL} /home/porterj/svn/moab/missing --run automake-1.10
+AWK = mawk
+BABEL_DIR =
+CC = cc
+CCDEPMODE = depmode=gcc3
+CFLAGS =  -Wall -pipe -O2 -DNDEBUG
+CGM_CPPFLAGS =
+CGM_LDFLAGS =
+CGM_LIBS =
+CGM_LTFLAGS =
+CHACO_INCLUDES =
+CHACO_LIBS =
+CPP = cc -E
+CPPFLAGS =  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map
+CXX = c++
+CXXCPP = c++ -E
+CXXDEPMODE = depmode=gcc3
+CXXFLAGS =  -Wall -pipe -O2 -DNDEBUG
+CYGPATH_W = echo
+DEFINES =  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE
+DEFS = -DHAVE_CONFIG_H
+DEPDIR = .deps
+DISTCHECK_CONFIGURE_FLAGS =  --with-hdf5="/usr/local/hdf5serial/"
+DOXYGEN =
+DSYMUTIL =
+ECHO = echo
+ECHO_C =
+ECHO_N = -n
+ECHO_T =
+EGREP = /bin/grep -E
+EXEEXT =
+EXPORT_LDFLAGS =     -L/usr/local/hdf5serial//lib
+EXPORT_LTFLAGS =
+F77 = gfortran
+FC = gfortran
+FCFLAGS = -g -O2 -O2 -DNDEBUG
+FCLIBS =  -L/usr/local/gcc-4.3/lib/gcc/x86_64-unknown-linux-gnu/4.3.0 -L/usr/local/gcc-4.3/lib/gcc/x86_64-unknown-linux-gnu/4.3.0/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/local/gcc-4.3/lib/gcc/x86_64-unknown-linux-gnu/4.3.0/../../.. -lgfortranbegin -lgfortran -lm
+FFLAGS = -g -O2
+GREP = /bin/grep
+HDF5_LIBS =  -lhdf5
+INCLUDES =
+INSTALL = /usr/bin/install -c
+INSTALL_DATA = ${INSTALL} -m 644
+INSTALL_PROGRAM = ${INSTALL}
+INSTALL_SCRIPT = ${INSTALL}
+INSTALL_STRIP_PROGRAM = $(install_sh) -c -s
+LDFLAGS =
+LIBOBJS =
+LIBS = -lm
+LIBTOOL = $(SHELL) $(top_builddir)/libtool
+LN_S = ln -s
+LTLIBOBJS =
+MAKEINFO = ${SHELL} /home/porterj/svn/moab/missing --run makeinfo
+MKDIR_P = /bin/mkdir -p
+MOAB_CGM_DEFINES =
+MOAB_CXX_LIBS = -lstdc++ -lm -lgcc_s -lc -lgcc_s
+MOAB_CXX_LINKFLAGS = -L/usr/lib/gcc/x86_64-linux-gnu/4.2.4 -L/usr/lib/gcc/x86_64-linux-gnu/4.2.4 -L/usr/lib/gcc/x86_64-linux-gnu/4.2.4/../../../../lib -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.2.4/../../..
+MOC =
+MPIEXEC =
+MPIEXEC_NP =
+NETCDF_LIBS = -lnetcdf_c++ -lnetcdf
+NMEDIT =
+NP =
+NUMPY_DIR = /home/porterj/python/lib/python/numpy/core/include/
+OBJEXT = o
+PACKAGE = moab
+PACKAGE_BUGREPORT =
+PACKAGE_NAME = MOAB
+PACKAGE_STRING = MOAB 3.99
+PACKAGE_TARNAME = moab
+PACKAGE_VERSION = 3.99
+PATH_SEPARATOR = :
+PYTHON_DIR = /home/porterj/python/include/
+QTDIR =
+QVDUAL_INCLUDES =
+QVDUAL_LIBS =
+RANLIB = ranlib
+SED = /bin/sed
+SET_MAKE =
+SHELL = /bin/bash
+STRIP = strip
+UIC =
+USE_BABEL = no
+VERSION = 3.99
+VTK_LIB_DIR =
+XMKMF =
+X_CFLAGS =
+X_EXTRA_LIBS =
+X_LIBS =
+X_PRE_LIBS =
+ZCAT = gunzip -c
+ZOLTAN_INC_FLAGS =
+ZOLTAN_LIBS =
+ZOLTAN_LIB_FLAGS =
+abs_builddir = /home/porterj/svn/moab/tools/iMesh/python
+abs_srcdir = /home/porterj/svn/moab/tools/iMesh/python
+abs_top_builddir = /home/porterj/svn/moab
+abs_top_srcdir = /home/porterj/svn/moab
+ac_ct_CC = cc
+ac_ct_CXX = c++
+ac_ct_F77 = gfortran
+ac_ct_FC = gfortran
+am__include = include
+am__leading_dot = .
+am__quote =
+am__tar = ${AMTAR} chof - "$$tardir"
+am__untar = ${AMTAR} xf -
+bindir = ${exec_prefix}/bin
+build = x86_64-unknown-linux-gnu
+build_alias =
+build_cpu = x86_64
+build_os = linux-gnu
+build_vendor = unknown
+builddir = .
+datadir = ${datarootdir}
+datarootdir = ${prefix}/share
+docdir = ${datarootdir}/doc/${PACKAGE_TARNAME}
+dvidir = ${docdir}
+exec_prefix = ${prefix}
+host = x86_64-unknown-linux-gnu
+host_alias =
+host_cpu = x86_64
+host_os = linux-gnu
+host_vendor = unknown
+htmldir = ${docdir}
+includedir = ${prefix}/include
+infodir = ${datarootdir}/info
+install_sh = $(SHELL) /home/porterj/svn/moab/install-sh
+libdir = ${exec_prefix}/lib
+libexecdir = ${exec_prefix}/libexec
+localedir = ${datarootdir}/locale
+localstatedir = ${prefix}/var
+mandir = ${datarootdir}/man
+mkdir_p = /bin/mkdir -p
+oldincludedir = /usr/include
+pdfdir = ${docdir}
+prefix = /home/porterj/moab
+program_transform_name = s,x,x,
+psdir = ${docdir}
+sbindir = ${exec_prefix}/sbin
+sharedstatedir = ${prefix}/com
+srcdir = .
+sysconfdir = ${prefix}/etc
+target = x86_64-unknown-linux-gnu
+target_alias =
+target_cpu = x86_64
+target_os = linux-gnu
+target_vendor = unknown
+top_builddir = ../../..
+top_srcdir = ../../..
+all: all-am
+.SUFFIXES:
+$(srcdir)/Makefile.in:  $(srcdir)/Makefile.am  $(am__configure_deps)
+	@for dep in $?; do \
+	  case '$(am__configure_deps)' in \
+	    *$$dep*) \
+	      cd $(top_builddir) && $(MAKE) $(AM_MAKEFLAGS) am--refresh \
+		&& exit 0; \
+	      exit 1;; \
+	  esac; \
+	done; \
+	echo ' cd $(top_srcdir) && $(AUTOMAKE) --gnu  tools/iMesh/python/Makefile'; \
+	cd $(top_srcdir) && \
+	  $(AUTOMAKE) --gnu  tools/iMesh/python/Makefile
+.PRECIOUS: Makefile
+Makefile: $(srcdir)/Makefile.in $(top_builddir)/config.status
+	@case '$?' in \
+	  *config.status*) \
+	    cd $(top_builddir) && $(MAKE) $(AM_MAKEFLAGS) am--refresh;; \
+	    echo ' cd $(top_builddir) && $(SHELL) ./config.status $(subdir)/$@ $(am__depfiles_maybe)'; \
+	    cd $(top_builddir) && $(SHELL) ./config.status $(subdir)/$@ $(am__depfiles_maybe);; \
+	esac;
+$(top_builddir)/config.status: $(top_srcdir)/configure $(CONFIG_STATUS_DEPENDENCIES)
+$(top_srcdir)/configure:  $(am__configure_deps)
+$(ACLOCAL_M4):  $(am__aclocal_m4_deps)
+setup.cfg: $(top_builddir)/config.status $(srcdir)/setup.cfg.in
+mostlyclean-libtool:
+	-rm -f *.lo
+clean-libtool:
+	-rm -rf .libs _libs
+tags: TAGS
+TAGS:
+ctags: CTAGS
+CTAGS:
+distdir: $(DISTFILES)
+	@srcdirstrip=`echo "$(srcdir)" | sed 's/[].[^$$\\*]/\\\\&/g'`; \
+	topsrcdirstrip=`echo "$(top_srcdir)" | sed 's/[].[^$$\\*]/\\\\&/g'`; \
+	list='$(DISTFILES)'; \
+	  dist_files=`for file in $$list; do echo $$file; done | \
+	  sed -e "s|^$$srcdirstrip/||;t" \
+	      -e "s|^$$topsrcdirstrip/|$(top_builddir)/|;t"`; \
+	case $$dist_files in \
+	  */*) $(MKDIR_P) `echo "$$dist_files" | \
+			   sed '/\//!d;s|^|$(distdir)/|;s,/[^/]*$$,,' | \
+			   sort -u` ;; \
+	esac; \
+	for file in $$dist_files; do \
+	  if test -f $$file || test -d $$file; then d=.; else d=$(srcdir); fi; \
+	  if test -d $$d/$$file; then \
+	    dir=`echo "/$$file" | sed -e 's,/[^/]*$$,,'`; \
+	    if test -d $(srcdir)/$$file && test $$d != $(srcdir); then \
+	      cp -pR $(srcdir)/$$file $(distdir)$$dir || exit 1; \
+	    fi; \
+	    cp -pR $$d/$$file $(distdir)$$dir || exit 1; \
+	  else \
+	    test -f $(distdir)/$$file \
+	    || cp -p $$d/$$file $(distdir)/$$file \
+	    || exit 1; \
+	  fi; \
+	done
+check-am: all-am
+check: check-am
+all-am: Makefile
+installdirs:
+install: install-am
+install-data: install-data-am
+uninstall: uninstall-am
+install-am: all-am
+	@$(MAKE) $(AM_MAKEFLAGS) install-exec-am install-data-am
+installcheck: installcheck-am
+install-strip:
+	$(MAKE) $(AM_MAKEFLAGS) INSTALL_PROGRAM="$(INSTALL_STRIP_PROGRAM)" \
+	  install_sh_PROGRAM="$(INSTALL_STRIP_PROGRAM)" INSTALL_STRIP_FLAG=-s \
+	  `test -z '$(STRIP)' || \
+	    echo "INSTALL_PROGRAM_ENV=STRIPPROG='$(STRIP)'"` install
+mostlyclean-generic:
+clean-generic:
+distclean-generic:
+	-test -z "$(CONFIG_CLEAN_FILES)" || rm -f $(CONFIG_CLEAN_FILES)
+maintainer-clean-generic:
+	@echo "This command is intended for maintainers to use"
+	@echo "it deletes files that may require special tools to rebuild."
+clean: clean-am
+clean-am: clean-generic clean-libtool mostlyclean-am
+distclean: distclean-am
+	-rm -f Makefile
+distclean-am: clean-am distclean-generic
+dvi: dvi-am
+dvi-am:
+html: html-am
+info: info-am
+info-am:
+install-data-am:
+install-dvi: install-dvi-am
+install-exec-am:
+install-html: install-html-am
+install-info: install-info-am
+install-man:
+install-pdf: install-pdf-am
+install-ps: install-ps-am
+installcheck-am:
+maintainer-clean: maintainer-clean-am
+	-rm -f Makefile
+maintainer-clean-am: distclean-am maintainer-clean-generic
+mostlyclean: mostlyclean-am
+mostlyclean-am: mostlyclean-generic mostlyclean-libtool
+pdf: pdf-am
+pdf-am:
+ps: ps-am
+ps-am:
+uninstall-am:
+.MAKE: install-am install-strip
+.PHONY: all all-am check check-am clean clean-generic clean-libtool \
+	distclean distclean-generic distclean-libtool distdir dvi \
+	dvi-am html html-am info info-am install install-am \
+	install-data install-data-am install-dvi install-dvi-am \
+	install-exec install-exec-am install-html install-html-am \
+	install-info install-info-am install-man install-pdf \
+	install-pdf-am install-ps install-ps-am install-strip \
+	installcheck installcheck-am installdirs maintainer-clean \
+	maintainer-clean-generic mostlyclean mostlyclean-generic \
+	mostlyclean-libtool pdf pdf-am ps ps-am uninstall uninstall-am
 all:
 	python setup.py build
@@ -3,2 +380,5 @@
 install-exec:
 	python setup.py install
+# Tell versions [3.59,3.63) of GNU make to not export all variables.
+# Otherwise a system limit (for SysV at least) may be exceeded.
+.NOEXPORT:
