[MOAB-dev] r3025 - in MOAB/trunk: . tools/iMesh tools/iMesh/python tools/iMesh/python/doc
jvporter at mcs.anl.gov jvporter at mcs.anl.gov
Fri Jul 17 14:30:21 CDT 2009
Author: jvporter
Date: 2009-07-17 14:30:21 -0500 (Fri, 17 Jul 2009)
New Revision: 3025
Added:
   MOAB/trunk/tools/iMesh/python/Makefile
   MOAB/trunk/tools/iMesh/python/setup.cfg.in
Modified:
   MOAB/trunk/configure.ac
   MOAB/trunk/tools/iMesh/Makefile.am
   MOAB/trunk/tools/iMesh/iMesh-Defs.inc.in
   MOAB/trunk/tools/iMesh/python/doc/build.rst
   MOAB/trunk/tools/iMesh/python/setup.py
Log:
* Begin integration of Python interface into autotools build system
* Minor adjustment to Python's lookup of iMesh-Defs.inc (see build.rst
  for info)
Modified: MOAB/trunk/configure.ac
--- MOAB/trunk/configure.ac	2009-07-17 04:03:34 UTC (rev 3024)
+++ MOAB/trunk/configure.ac	2009-07-17 19:30:21 UTC (rev 3025)
@@ -42,6 +42,31 @@
+#                           PyTAPS
+AC_ARG_ENABLE([pytaps],[
+AC_HELP_STRING([--enable-pytaps],[Build Python iMesh interface.])
+AC_HELP_STRING([--disable-pytaps],[Don't build Python iMesh interface.])
+[ENABLE_pytaps=yes],
+[ENABLE_pytaps=no]
+case $ENABLE_pytaps in
+  yes)
+    if test "x$with_pic" != "xyes"; then
+      AC_MSG_ERROR([Need PIC support for PyTAPS])
+    fi
+  no)
+    AC_MSG_ERROR([Invalid argument to --enable-pytaps : $ENABLE_pytaps])
+esac
+AM_CONDITIONAL([ENABLE_pytaps],[test "xyes" == "x$ENABLE_pytaps"])
 #                           Compilers
@@ -268,7 +293,7 @@
 #                           Optional Tools
   # Define a macro to avoid typing this for each individual tool
-  # Usage: MB_OPTIOANL_TOOL( name, default )
+  # Usage: MB_OPTIONAL_TOOL( name, default )
   #  name      - name of option
   #  default   - yes/no, $ENABLE_TOOLS overrides this if set
   # Actions:
@@ -900,6 +925,19 @@
 fi
 AM_CONDITIONAL(USE_BABEL, [test "xno" != "x$USE_BABEL"])
+#                           PyTAPS libraries (Python/Numpy)
+if test "x$ENABLE_pytaps" = "xyes"; then
+  AC_ARG_WITH(python,[AC_HELP_STRING([--with-python=DIR],
+          [Specify directory containing Python headers])],
+  [PYTHON_DIR=$withval])
+  AC_ARG_WITH(numpy,[AC_HELP_STRING([--with-numpy=DIR],
+          [Specify directory containing Numpy headers])],
+  [NUMPY_DIR=$withval])
+  AC_SUBST(PYTHON_DIR)
+  AC_SUBST(NUMPY_DIR)
+fi
 #                           Output Files
@@ -923,7 +961,7 @@
 AC_CONFIG_FILES([Makefile
                  moab.make
                  testdir.h
-		 parallel/Makefile
+                 parallel/Makefile
                  mhdf/Makefile
                  test/Makefile
                  test/h5file/Makefile
@@ -931,17 +969,18 @@
                  test/obb/Makefile
                  test/perf/Makefile
                  tools/Makefile
-		 tools/iMesh/Makefile
-		 tools/iMesh/iMesh-Defs.inc
-		 tools/iMesh/SIDL/iMesh-SIDL-Defs.inc
-		 tools/iMesh/SIDL/Makefile
+                 tools/iMesh/Makefile
+                 tools/iMesh/iMesh-Defs.inc
+                 tools/iMesh/SIDL/iMesh-SIDL-Defs.inc
+                 tools/iMesh/SIDL/Makefile
                  tools/iMesh/SIDL/common.make
+                 tools/iMesh/python/setup.cfg
                  tools/mbperf/Makefile
                  tools/mbchaco/Makefile
                  tools/mbcoupler/Makefile
-		 tools/mbzoltan/Config.moab
-		 tools/mbzoltan/Makefile
-		 tools/mcnpmit/Makefile
+                 tools/mbzoltan/Config.moab
+                 tools/mbzoltan/Makefile
+                 tools/mcnpmit/Makefile
                  tools/qvdual/Makefile
                  tools/dagmc/Makefile
                  doc/Makefile
Modified: MOAB/trunk/tools/iMesh/Makefile.am
--- MOAB/trunk/tools/iMesh/Makefile.am	2009-07-17 04:03:34 UTC (rev 3024)
+++ MOAB/trunk/tools/iMesh/Makefile.am	2009-07-17 19:30:21 UTC (rev 3025)
@@ -5,10 +5,16 @@
   babel_DIR = SIDL
 else
   babel_DIR =
-endif
+endif
-SUBDIRS = . $(babel_DIR)
+if ENABLE_pytaps
+  pytaps_DIR = python
+else
+  pytaps_DIR =
+endif
+SUBDIRS = . $(babel_DIR) $(pytaps_DIR)
 INCLUDES = -I$(top_srcdir) -I$(top_builddir) -I.
 DEFS += $(DEFINES) -DSRCDIR=$(srcdir)
Modified: MOAB/trunk/tools/iMesh/iMesh-Defs.inc.in
--- MOAB/trunk/tools/iMesh/iMesh-Defs.inc.in	2009-07-17 04:03:34 UTC (rev 3024)
+++ MOAB/trunk/tools/iMesh/iMesh-Defs.inc.in	2009-07-17 19:30:21 UTC (rev 3025)
@@ -12,7 +12,7 @@
 IMESH_INCLUDES = -I$(IMESH_INCLUDEDIR)
 IMESH_LIBS = $(IMESH_LDFLAGS) -L$(MOAB_LIBDIR) \
-             -L${IMESH_LIBDIR} -liMesh -lMOAB \
+             -L$(IMESH_LIBDIR) -liMesh -lMOAB \
              @NETCDF_LIBS@ @HDF5_LIBS@ @LIBS@ \
              $(IMESH_CXX_LDFLAGS) $(IMESH_CXX_LIBS) \
              @CGM_LDFLAGS@ @CGM_LIBS@
Added: MOAB/trunk/tools/iMesh/python/Makefile
--- MOAB/trunk/tools/iMesh/python/Makefile	                        (rev 0)
+++ MOAB/trunk/tools/iMesh/python/Makefile	2009-07-17 19:30:21 UTC (rev 3025)
@@ -0,0 +1,5 @@
+all:
+	python setup.py build
+install-exec:
+	python setup.py install
Modified: MOAB/trunk/tools/iMesh/python/doc/build.rst
--- MOAB/trunk/tools/iMesh/python/doc/build.rst	2009-07-17 04:03:34 UTC (rev 3024)
+++ MOAB/trunk/tools/iMesh/python/doc/build.rst	2009-07-17 19:30:21 UTC (rev 3025)
@@ -12,7 +12,8 @@
 options ``--imesh-dir=PATH`` to the `build_ext` and `perf_build` commands. For
 example, if your `iMesh-Defs.inc` is located in
 `/usr/local/iMesh/lib/iMesh-Defs.inc`, then ``--imesh-dir`` should be
-`/usr/local/iMesh`.  This options may also be specified in the `setup.cfg` file:
+`/usr/local/iMesh/lib`.  This options may also be specified in the `setup.cfg`
+file:
 .. literalinclude:: ../setup.cfg.example
    :language: ini
@@ -70,7 +71,7 @@
 | ``--libraries=LIBS``     | ``-l`` | list of libraries to link to          |
-| ``--imesh-dir=PATH``     | N/A    | root location of iMesh implementation |
+| ``--imesh-dir=PATH``     | N/A    | root location of iMesh libraries      |
 Running the Performance Test
Added: MOAB/trunk/tools/iMesh/python/setup.cfg.in
--- MOAB/trunk/tools/iMesh/python/setup.cfg.in	                        (rev 0)
+++ MOAB/trunk/tools/iMesh/python/setup.cfg.in	2009-07-17 19:30:21 UTC (rev 3025)
@@ -0,0 +1,3 @@
+[build_ext]
+imesh-dir = @abs_srcdir@/..
+include-dirs = @PYTHON_DIR@:@NUMPY_DIR@:@abs_top_srcdir@
Modified: MOAB/trunk/tools/iMesh/python/setup.py
--- MOAB/trunk/tools/iMesh/python/setup.py	2009-07-17 04:03:34 UTC (rev 3024)
+++ MOAB/trunk/tools/iMesh/python/setup.py	2009-07-17 19:30:21 UTC (rev 3025)
@@ -14,7 +14,7 @@
     return tmp
 def add_imesh_defs(imesh_dir, self):
-        defs = parse_makefile( os.path.join(imesh_dir, 'lib/iMesh-Defs.inc') )
+        defs = parse_makefile( os.path.join(imesh_dir, 'iMesh-Defs.inc') )
         lib_match = re.compile(r'(?:(?<=\s)|^)-([lL])\s*(\S*)')
         for match in lib_match.finditer( defs['IMESH_LIBS'] ):
