[MOAB-dev] r3019 - MOAB/trunk
kraftche at mcs.anl.gov
Thu Jul 16 16:16:28 CDT 2009
Author: kraftche
Date: 2009-07-16 16:16:27 -0500 (Thu, 16 Jul 2009)
New Revision: 3019
Modified:
MOAB/trunk/ReadHDF5.cpp
Log:
when reading in parallel, rather than scanning file on every proc and to read summary, read only on root and bcast to others
Modified: MOAB/trunk/ReadHDF5.cpp
--- MOAB/trunk/ReadHDF5.cpp 2009-07-16 20:45:50 UTC (rev 3018)
+++ MOAB/trunk/ReadHDF5.cpp 2009-07-16 21:16:27 UTC (rev 3019)
@@ -33,9 +33,10 @@
#include "MBCN.hpp"
#include "FileOptions.hpp"
#ifdef HDF5_PARALLEL
-#include "ReadParallel.hpp"
-#include <H5FDmpi.h>
-#include <H5FDmpio.h>
+# include "ReadParallel.hpp"
+# include "MBParallelComm.hpp"
+# include <H5FDmpi.h>
+# include <H5FDmpio.h>
#endif
//#include "WriteHDF5.hpp"
@@ -179,46 +180,88 @@
if (!dataBuffer)
return error(MB_MEMORY_ALLOCATION_FAILED);
- hid_t file_prop = H5P_DEFAULT;
if (use_mpio || native_parallel) {
#ifndef HDF5_PARALLEL
readUtil->report_error("MOAB not configured with parallel HDF5 support");
free(dataBuffer);
return MB_NOT_IMPLEMENTED;
#else
- file_prop = H5Pcreate(H5P_FILE_ACCESS);
- H5Pset_fapl_mpio(file_prop, MPI_COMM_WORLD, MPI_INFO_NULL);
+ MBParallelComm* myPcomm = MBParallelComm::get_pcomm(iFace, 0);
+ if (0 == myPcomm) {
+ myPcomm = new MBParallelComm(iFace);
+ const int rank = myPcomm->proc_config().proc_rank();
+ // Open the file in serial on root to read summary
+ fileInfo = 0;
+ unsigned long size = 0;
+ if (rank == 0) {
+ filePtr = mhdf_openFile( filename, 0, NULL, &status );
+ if (filePtr) {
+ fileInfo = mhdf_getFileSummary( filePtr, handleType, &status );
+ if (!is_error(status)) {
+ size = fileInfo->total_size;
+ fileInfo->offset = (unsigned char*)fileInfo;
+ mhdf_closeFile( filePtr, &status );
+ if (fileInfo && mhdf_isError(&status)) {
+ free(fileInfo);
+ fileInfo = 0;
+ // Broadcast the size of the struct (zero indicates an error)
+ int err = MPI_Bcast( &size, 1, MPI_UNSIGNED_LONG, 0, myPcomm->proc_config().proc_comm() );
+ if (err || !size)
+ return MB_FAILURE;
+ // allocate structure
+ if (rank != 0)
+ fileInfo = reinterpret_cast<mhdf_FileDesc*>( malloc( size ) );
+ // bcast file summary
+ MPI_Bcast( fileInfo, size, MPI_BYTE, 0, myPcomm->proc_config().proc_comm() );
+ // fix up internal pointers in file summary struct
+ if (rank != 0)
+ mhdf_fixFileDesc( fileInfo, reinterpret_cast<mhdf_FileDesc*>(fileInfo->offset) );
+ // configure HDF5 properties
+ hid_t file_prop = H5Pcreate(H5P_FILE_ACCESS);
+ H5Pset_fapl_mpio(file_prop, myPcomm->proc_config().proc_comm(), MPI_INFO_NULL);
collIO = H5Pcreate(H5P_DATASET_XFER);
H5Pset_dxpl_mpio(collIO, H5FD_MPIO_COLLECTIVE);
indepIO = native_parallel ? H5P_DEFAULT : collIO;
-#endif
- // Open the file
- filePtr = mhdf_openFileWithOpt( filename, 0, NULL, file_prop, &status );
- if (file_prop != H5P_DEFAULT)
+ // re-open file in parallel
+ filePtr = mhdf_openFileWithOpt( filename, 0, NULL, file_prop, &status );
H5Pclose( file_prop );
- if (!filePtr)
- readUtil->report_error( mhdf_message( &status ));
- free( dataBuffer );
- if (indepIO != H5P_DEFAULT)
+ if (!filePtr)
+ readUtil->report_error( mhdf_message( &status ));
+ free( dataBuffer );
H5Pclose( indepIO );
- if (collIO != indepIO)
- H5Pclose( collIO );
- return error(MB_FAILURE);
+ if (collIO != indepIO)
+ H5Pclose( collIO );
+ return error(MB_FAILURE);
+#endif
+ else {
+ // Open the file
+ if (!filePtr)
- // get file info
- fileInfo = mhdf_getFileSummary( filePtr, handleType, &status );
- if (is_error(status)) {
- H5Pclose( indepIO );
- mhdf_closeFile( filePtr, &status );
+ // get file info
+ if (is_error(status)) {
return MB_SUCCESS;
