[MOAB-dev] r3017 - MOAB/trunk/parallel
tautges at mcs.anl.gov tautges at mcs.anl.gov
Thu Jul 16 12:56:10 CDT 2009
Author: tautges
Date: 2009-07-16 12:56:10 -0500 (Thu, 16 Jul 2009)
New Revision: 3017
Modified:
   MOAB/trunk/parallel/MBParallelComm.cpp
   MOAB/trunk/parallel/MBParallelComm.hpp
Log:
During the resolv_shared_entities process for interface entities, we
infer which processors may share higher-dimensional (non-vertex)
entities based on which processors share the vertices in that entity.
In some cases, that results in a wrong guess, i.e. in reality some of
those processors may not share that entity.  That appears in the
implementation as the other processors having zero remote handles for
the processor(s) wrongly predicted to share the entity.  This commit
fixes up the sharing data for those entities, without requiring
sending extra messages.
This fixes the problem reported by Lukasz, at least on 4 procs.
There is a remaining issue in parallel sharing, where
higher-dimensional entities on the interface aren't marked with
ownership data (interface sets might not be marked either, can't
remember).
Parallel hdf5 write still fails too.
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp	2009-07-16 14:08:37 UTC (rev 3016)
+++ MOAB/trunk/parallel/MBParallelComm.cpp	2009-07-16 17:56:10 UTC (rev 3017)
@@ -16,6 +16,7 @@
 #include "MeshTopoUtil.hpp"
 #include <iostream>
+#include <sstream>
 #include <algorithm>
 #include <numeric>
@@ -3632,6 +3633,12 @@
   if (is_iface) {
+      // need to check over entities I sent and make sure I received
+      // handles for them from all expected procs; if not, need to clean
+      // them up
+    result = check_clean_iface(allsent);
+    RRA("Failed check.");
 #ifndef NDEBUG
     result = check_sent_ents(allsent);
     RRA("Failed check on shared entities.");
@@ -3742,6 +3749,88 @@
   return MB_SUCCESS;
+MBErrorCode MBParallelComm::check_clean_iface(MBRange &allsent)
+    // allsent is all entities I think are on interface; go over them, looking
+    // for zero-valued handles, and fix any I find
+  MBErrorCode result;
+  MBRange::iterator rit;
+  unsigned char pstatus;
+  int sharedp[MAX_SHARING_PROCS], nump;
+  MBEntityHandle sharedh[MAX_SHARING_PROCS];
+  for (rit = allsent.begin(); rit != allsent.end(); rit++) {
+    result = get_sharing_data(*rit, sharedp, sharedh, pstatus, nump);
+    RRA("");
+    assert("Should be shared with at least one other proc" &&
+           (nump > 1 || sharedp[0] != (int)procConfig.proc_rank()));
+    int numz = 0;
+    for (int i = 0; i < nump; i++) {
+      if (!sharedh[i]) numz++;
+      else if (numz) {
+          // shift downward
+        sharedh[i-numz] = sharedh[i];
+        sharedp[i-numz] = sharedp[i];
+    if (numz) {
+      result = set_sharing_data(*rit, pstatus, nump, nump-numz, sharedp, sharedh);
+      RRA("");
+  return result;
+MBErrorCode MBParallelComm::set_sharing_data(MBEntityHandle ent, unsigned char pstatus,
+                                             int old_nump, int new_nump,
+                                             int *ps, MBEntityHandle *hs)
+  assert("Should call this function only when reducing sharing procs." &&
+         new_nump < old_nump);
+    // set sharing data to what's passed in; may have to clean up existing sharing tags
+    // if things changed too much
+  if (pstatus & PSTATUS_MULTISHARED && new_nump < 3) {
+      // need to remove multishared tags
+    result = mbImpl->tag_delete_data(sharedps_tag(), &ent, 1);
+    RRA("");
+    result = mbImpl->tag_delete_data(sharedhs_tag(), &ent, 1);
+    RRA("");
+    pstatus ^= PSTATUS_MULTISHARED;
+    if (new_nump < 2) pstatus = 0x0;
+  else if (pstatus & PSTATUS_SHARED && new_nump < 2) {
+    hs[0] = 0;
+    ps[0] = -1;
+    pstatus = 0x0;
+  if (new_nump > 2) {
+    result = mbImpl->tag_set_data(sharedps_tag(), &ent, 1, ps);
+    RRA("");
+    result = mbImpl->tag_set_data(sharedhs_tag(), &ent, 1, hs);
+    RRA("");
+  else {
+    unsigned int j = (ps[0] == procConfig.proc_rank() ? 1 : 0);
+    assert(-1 != ps[j]);
+    result = mbImpl->tag_set_data(sharedp_tag(), &ent, 1, ps+j);
+    RRA("");
+    result = mbImpl->tag_set_data(sharedh_tag(), &ent, 1, hs+j);
+    RRA("");
+  result = mbImpl->tag_set_data(pstatus_tag(), &ent, 1, &pstatus);
+  RRA("");
+  if (old_nump > 1 && new_nump < 2) sharedEnts.erase(ent);
+  return result;
 MBErrorCode MBParallelComm::get_sent_ents(const bool is_iface,
                                           const int bridge_dim, const int ghost_dim,
                                           const int num_layers,
@@ -3896,6 +3985,14 @@
   if (is_iface) {
+      // them up
+    for (unsigned int p = 0; p < num_procs; p++) {
+      result = pcs[p]->check_clean_iface(allsent[p]);
+      RRAI(pcs[p]->get_moab(), "Failed check on shared entities.");
 #ifndef NDEBUG
       result = pcs[p]->check_sent_ents(allsent[p]);
@@ -5268,15 +5365,15 @@
                                                      int num_pcs)
   std::vector<std::vector<std::vector<SharedEntityData> > > shents, send_data;
-  MBErrorCode result;
+  MBErrorCode result = MB_SUCCESS, tmp_result;
     // get all shared ent data from each proc to all other procs
   send_data.resize(num_pcs);
   for (int p = 0; p < num_pcs; p++) {
-    result = pcs[p]->pack_shared_handles(send_data[p]);
-    if (MB_SUCCESS != result)
-      return result;
+    tmp_result = pcs[p]->pack_shared_handles(send_data[p]);
+    if (MB_SUCCESS != tmp_result) result = tmp_result;
+  if (MB_SUCCESS != result) return result;
     // move the data sorted by sending proc to data sorted by receiving proc
   shents.resize(num_pcs);
@@ -5294,15 +5391,18 @@
-    result = pcs[p]->check_my_shared_handles(shents[p]);
-    if (MB_SUCCESS != result) return result;
+    std::ostringstream ostr;
+    ostr << "Processor " << p << " bad entities:";
+    tmp_result = pcs[p]->check_my_shared_handles(shents[p], ostr.str().c_str());
-  return MB_SUCCESS;
+  return result;
 MBErrorCode MBParallelComm::check_my_shared_handles(
-    std::vector<std::vector<SharedEntityData> > &shents)
+    std::vector<std::vector<SharedEntityData> > &shents,
+                                                    const char *prefix)
     // now check against what I think data should be
     // get all shared entities
@@ -5325,11 +5425,16 @@
     if (!local_shared.empty())
-      return MB_FAILURE;
+      bad_ents.merge(local_shared);
-  if (!bad_ents.empty())
+  if (!bad_ents.empty()) {
+    if (prefix) {
+      std::cout << prefix << std::endl;
+      list_entities(bad_ents);
     return MB_FAILURE;
   else return MB_SUCCESS;
Modified: MOAB/trunk/parallel/MBParallelComm.hpp
--- MOAB/trunk/parallel/MBParallelComm.hpp	2009-07-16 14:08:37 UTC (rev 3016)
+++ MOAB/trunk/parallel/MBParallelComm.hpp	2009-07-16 17:56:10 UTC (rev 3017)
@@ -540,7 +540,8 @@
       std::vector<std::vector<SharedEntityData> > &send_data);
   MBErrorCode check_my_shared_handles(
-      std::vector<std::vector<SharedEntityData> > &shents);
+                                      const char *prefix = NULL);
     //! set rank for this pcomm; USED FOR TESTING ONLY!
   void set_rank(unsigned int r);
@@ -579,6 +580,12 @@
 private:
+  MBErrorCode set_sharing_data(MBEntityHandle ent, unsigned char pstatus,
+                               int *ps, MBEntityHandle *hs);
+  MBErrorCode check_clean_iface(MBRange &allsent);
   void define_mpe();
   MBErrorCode get_sent_ents(const bool is_iface,
