[MOAB-dev] r3014 - MOAB/trunk/parallel
    tautges at mcs.anl.gov
    Wed Jul 15 17:42:45 CDT 2009
Author: tautges
Date: 2009-07-15 17:42:45 -0500 (Wed, 15 Jul 2009)
New Revision: 3014
Modified:
   MOAB/trunk/parallel/ReadParallel.cpp
   MOAB/trunk/parallel/mbparallelcomm_test.cpp
Log:
<re-commit of earlier today's commit>
Added handling of PRINT_PARALLEL read option; this option tells ReadParallel
to print information about shared entities after parallel read is done.
Added -p option to mbparallelcomm_test to turn on above option.
Modified: MOAB/trunk/parallel/ReadParallel.cpp
--- MOAB/trunk/parallel/ReadParallel.cpp	2009-07-15 22:42:16 UTC (rev 3013)
+++ MOAB/trunk/parallel/ReadParallel.cpp	2009-07-15 22:42:45 UTC (rev 3014)
@@ -23,7 +23,7 @@
 enum ParallelActions {PA_READ=0, PA_BROADCAST, PA_DELETE_NONLOCAL,
                       PA_CHECK_GIDS_SERIAL, PA_GET_FILESET_ENTS,
                       PA_RESOLVE_SHARED_ENTS,
-                      PA_EXCHANGE_GHOSTS};
+                      PA_EXCHANGE_GHOSTS, PA_PRINT_PARALLEL};
 const char *ParallelActionsNames[] = {
     "PARALLEL READ",
     "PARALLEL BROADCAST",
@@ -31,7 +31,8 @@
     "PARALLEL CHECK_GIDS_SERIAL",
     "PARALLEL GET_FILESET_ENTS",
     "PARALLEL RESOLVE_SHARED_ENTS",
-    "PARALLEL EXCHANGE_GHOSTS"
+    "PARALLEL EXCHANGE_GHOSTS",
+    "PARALLEL PRINT_PARALLEL"
 const char* ReadParallel::parallelOptsNames[] = { "NONE", "BCAST", "BCAST_DELETE",
@@ -88,6 +89,11 @@
   result = opts.get_null_option("CPUTIME");
   if (MB_SUCCESS == result) cputime = true;
+    // see if we need to report times
+  bool print_parallel = false;
+  result = opts.get_null_option("PRINT_PARALLEL");
+  if (MB_SUCCESS == result) print_parallel = true;
     // get ghosting options
   std::string ghost_str;
   int bridge_dim, ghost_dim = -1, num_layers;
@@ -182,8 +188,9 @@
   if (-2 != resolve_dim) pa_vec.push_back(PA_RESOLVE_SHARED_ENTS);
   if (-1 != ghost_dim) pa_vec.push_back(PA_EXCHANGE_GHOSTS);
+  if (print_parallel) pa_vec.push_back(PA_PRINT_PARALLEL);
   return load_file(file_names, num_files, file_set, parallel_mode,
                    partition_tag_name,
                    partition_tag_vals, distrib, pa_vec, opts,
@@ -358,6 +365,14 @@
           break;
+      case PA_PRINT_PARALLEL:
+          if (debug)
+            std::cout << "Printing parallel information." << std::endl;
+          tmp_result = myPcomm->list_entities(0, -1);
+          break;
       default:
           return MB_FAILURE;
Modified: MOAB/trunk/parallel/mbparallelcomm_test.cpp
--- MOAB/trunk/parallel/mbparallelcomm_test.cpp	2009-07-15 22:42:16 UTC (rev 3013)
+++ MOAB/trunk/parallel/mbparallelcomm_test.cpp	2009-07-15 22:42:45 UTC (rev 3014)
@@ -47,7 +47,8 @@
 MBErrorCode read_file(MBInterface *mbImpl, std::vector<std::string> &filenames,
                       const char *tag_name, int tag_val, int distrib,
-                      int parallel_option, int resolve_shared, int with_ghosts, int use_mpio);
+                      int parallel_option, int resolve_shared, int with_ghosts,
+                      int use_mpio, bool print_parallel);
 MBErrorCode test_packing(MBInterface *mbImpl, const char *filename);
@@ -88,12 +89,16 @@
     return 1;
-  int npos = 1, tag_val, distrib, with_ghosts = 1, resolve_shared = 1, use_mpio = 0;
+  int npos = 1, tag_val, distrib, with_ghosts = 1, resolve_shared = 1,
+      use_mpio = 0;
   const char *tag_name;
   std::vector<std::string> filenames;
   int parallel_option = 0;
   int num_files;
+  if (!strcmp(argv[npos], "-p")) print_parallel = true;
   while (npos != argc) {
     MBErrorCode tmp_result;
     int nshared = -1;
@@ -128,7 +133,8 @@
           tmp_result = read_file(mbImpl, filenames, tag_name, tag_val,
                                  distrib, parallel_option,
-                                 resolve_shared, with_ghosts, use_mpio);
+                                 resolve_shared, with_ghosts, use_mpio,
+                                 print_parallel);
           if (MB_SUCCESS != tmp_result) {
             result = tmp_result;
             std::cerr << "Couldn't read mesh; error message:" << std::endl;
@@ -159,7 +165,7 @@
             filenames.push_back(std::string(argv[npos++]));
                                  distrib, parallel_option, resolve_shared,
-                                 with_ghosts, use_mpio);
+                                 with_ghosts, use_mpio, print_parallel);
@@ -291,7 +297,7 @@
                       int distrib, int parallel_option, int resolve_shared,
-                      int with_ghosts, int use_mpio)
+                      int with_ghosts, int use_mpio, bool print_parallel)
   std::ostringstream options;
   switch (parallel_option) {
@@ -328,6 +334,9 @@
   options << ";CPUTIME";
+    options << ";PRINT_PARALLEL";
   std::vector<MBEntityHandle> filesets(filenames.size());
   std::vector<MBParallelComm*> pcs(filenames.size());
   std::vector<ReadParallel*> rps(filenames.size());
