[MOAB-dev] r3006 - MOAB/trunk/tools/dagmc
wilsonp at engr.wisc.edu wilsonp at engr.wisc.edu
Tue Jul 14 11:49:39 CDT 2009
Author: wilsonp
Date: 2009-07-14 11:49:39 -0500 (Tue, 14 Jul 2009)
New Revision: 3006
Modified:
   MOAB/trunk/tools/dagmc/DagMC.cpp
   MOAB/trunk/tools/dagmc/DagMC.hpp
   MOAB/trunk/tools/dagmc/main.cc
Log:
MAJOR CHANGE to DagMC interface and user interaction
* replace cgm2moab function with ReadCGM in both DagMC & cgm2moab app
* allow default values for tags in get_tag
* separate load_file_and_init into two functions in preparation for
  parallel version
    * load_file (now based on ReadCGM)
    * init_OBBTree
* separate tight connection with MCNP in code base
    * rename and cleanup DagMC settings
    * separate write_log into two functions
        * parse_metadata
        * write_mcnp (this can be replicated for other codes)
* change parsing of group names
    * change some keywords to include '.' instead of '_' so that
      '_' can be used as delimiter for tokenizer
Modified: MOAB/trunk/tools/dagmc/DagMC.cpp
--- MOAB/trunk/tools/dagmc/DagMC.cpp	2009-07-14 14:57:15 UTC (rev 3005)
+++ MOAB/trunk/tools/dagmc/DagMC.cpp	2009-07-14 16:49:39 UTC (rev 3006)
@@ -4,6 +4,7 @@
 #include "MBRange.hpp"
 #include "MBCore.hpp"
 #include "MBGeomUtil.hpp"
+#include "FileOptions.hpp"
 #ifdef CGM
 #include "InitCGMA.hpp"
@@ -31,11 +32,25 @@
 #define MB_OBB_TREE_TAG_NAME "OBB_TREE"
 #define CATEGORY_TAG_LENGTH 32
+#define MAT_GROUP 0
+#define BC_SPEC 1
+#define BC_WHITE 2
+#define IMP_ZERO 3
+#define TALLY_GROUP 4
+#define MATERIAL_TAG_NAME "DAGMC_MATERIAL_ID"
+#define DENSITY_TAG_NAME  "DAGMC_MATERIAL_DENSITY"
+#define BC_TAG_NAME       "DAGMC_BOUNDARY_CONDITION"
+#define IMP_TAG_NAME      "DAGMC_IMPORTANCE"
+#define TALLY_TAG_NAME    "DAGMC_TALLY"
+#define MBI moab_instance()
 DagMC *DagMC::instance_ = NULL;
 const bool debug = false;
 unsigned int DagMC::interface_revision()
   unsigned int result = 0;
@@ -44,13 +59,17 @@
+void DagMC::create_instance(MBInterface *mb_impl)
+  if (NULL == mb_impl) mb_impl = new MBCore();
+  instance_ = new DagMC(mb_impl);
 DagMC::DagMC(MBInterface *mb_impl)
-    : mbImpl(mb_impl), obbTree(mb_impl),
-      discardDistTol(1e-8),
-      addDistTol(1e-6),
-      facetingTolerance(0.001),
-      moabMCNPSourceCell(0), moabMCNPUseDistLimit(false)
+  : mbImpl(mb_impl), obbTree(mb_impl), is_geom(false)
+    // This is the correct place to uniquely define default values for the dagmc settings
   options[0] = Option( "source_cell",        "source cell ID, or zero if unknown", "0" );
   options[1] = Option( "discard_distance_tolerance", "positive real value", "0.001" );
   options[2] = Option( "use_distance_limit", "one to enable distance limit optimization, zero otherwise", "0" );
@@ -58,6 +77,9 @@
   options[4] = Option( "faceting_tolerance", "graphics faceting tolerance", "0.001" );
   options[5] = Option( "add_distance_tolerance", "positive real value", "0.001" );
+    // call parse settings to initialize default values for settings from options
+  parse_settings();
   memset( specReflectName, 0, NAME_TAG_SIZE );
   strcpy( specReflectName, "spec_reflect" );
   memset( whiteReflectName, 0, NAME_TAG_SIZE );
@@ -67,7 +89,7 @@
   distanceLimit = std::numeric_limits<double>::max();
-  nameTag = get_tag(NAME_TAG_NAME, NAME_TAG_SIZE, MB_TAG_SPARSE, MB_TYPE_OPAQUE, false);
+  nameTag = get_tag(NAME_TAG_NAME, NAME_TAG_SIZE, MB_TAG_SPARSE, MB_TYPE_OPAQUE, NULL, false);
   idTag = get_tag( GLOBAL_ID_TAG_NAME, sizeof(int), MB_TAG_DENSE, MB_TYPE_INTEGER );
@@ -78,6 +100,17 @@
     // get sense of surfaces wrt volumes
   senseTag = get_tag( "GEOM_SENSE_2", 2*sizeof(MBEntityHandle), MB_TAG_DENSE, MB_TYPE_HANDLE );
+  int matid = 0;
+  const void *def_matid = &matid;
+  matTag   = get_tag(MATERIAL_TAG_NAME, sizeof(int), MB_TAG_DENSE, MB_TYPE_INTEGER, def_matid );
+  densTag  = get_tag(DENSITY_TAG_NAME, sizeof(double), MB_TAG_DENSE, MB_TYPE_DOUBLE );
+  bcTag    = get_tag(BC_TAG_NAME, sizeof(int), MB_TAG_SPARSE, MB_TYPE_INTEGER);
+  double imp_one = 1;
+  const void *def_imp = &imp_one;
+  impTag   = get_tag(IMP_TAG_NAME, sizeof(double), MB_TAG_DENSE, MB_TYPE_DOUBLE, def_imp );
+  tallyTag = get_tag(TALLY_TAG_NAME, sizeof(int), MB_TAG_SPARSE, MB_TYPE_INTEGER);
 MBErrorCode DagMC::ray_fire(const MBEntityHandle vol, const MBEntityHandle last_surf_hit,
@@ -183,24 +216,80 @@
   return MB_SUCCESS;
-void DagMC::create_instance(MBInterface *mb_impl)
-  if (NULL == mb_impl) mb_impl = new MBCore();
-  instance_ = new DagMC(mb_impl);
+// **** HANDLING FILES TO INPUT DAGMC SETTINGS ****
+// there is a movement away from using a settings file and, instead, incorporating this
+// information into the native input file of the calling application
-void DagMC::write_settings( FILE* fptr, bool desc ) {
+void DagMC::read_settings( const char* filename )
   int num_opt = sizeof(options) / sizeof(options[0]);
-  if (desc) for (int i = 0; i < num_opt; ++i)
-    fprintf( fptr, "%s = %s  # %s\n", options[i].name.c_str(), options[i].value.c_str(), options[i].desc.c_str() );
-  else for (int i = 0; i < num_opt; ++i)
-    fprintf( fptr, "%s = %s\n", options[i].name.c_str(), options[i].value.c_str() );
+  FILE* file;
+  if (filename && (file = fopen( filename, "r" ))) {
+    int line = 0;
+    char buffer[256];
+    bool havenl = true;
+    while ( fgets( buffer, sizeof(buffer), file ) ) {
+      if (havenl) {
+        havenl = false;
+        ++line;
+      int len = strlen(buffer);
+      if (len && buffer[len-1] == '\n')
+        havenl = true;
+        // chop off any thing after the '#' comman indicator
+      char* c = strchr( buffer, '#' );
+      if (c) *c = '\0';
+        // skip leading white space
+      char* p = buffer;
+      while (isspace(*p)) ++p;
+        // if empty line, done
+      if (!*p)
+        continue;
+        // find '='
+      c = strchr( p, '=' );
+      if (!c) {
+        fprintf(stderr, "Invalid option at line %d of config file '%s'\n", line, filename );
+        exit(2);
+        // get rid of white space around '='
+      char* v = c+1;
+      *c = ' ';
+      while (c > p && isspace(*c)) {
+        *c = '\0';
+        --c;
+      while (isspace(*v))
+        ++v;
+        // search for option
+      bool found = false;
+      for (int i = 0; i < num_opt; ++i) {
+        if (options[i].name == p) {
+          found = true;
+          options[i].value = v;
+          options[i].user_set = true;
+      if (!found)
+        fprintf(stderr,"Warning: unknown option at line %d of '%s': %s\n", line, filename, p );
+    } // while( fgets() )
+    fclose(file);
+  } // file(file)
+  // always do this, even if no file was found.
+  // it will either read the default values, or re-parse
+  // the values previously read from some other file.
+  parse_settings();
+  // this method sets the default values from options[] if none were read from file
 void DagMC::parse_settings() {
-  moabMCNPSourceCell = atoi( options[0].value.c_str() );
-  if (moabMCNPSourceCell < 0) {
-    std::cerr << "Invalid source_cell = " << moabMCNPSourceCell << std::endl;
+  sourceCell = atoi( options[0].value.c_str() );
+  if (sourceCell < 0) {
+    std::cerr << "Invalid source_cell = " << sourceCell << std::endl;
     exit(2);
@@ -216,7 +305,7 @@
     exit(2);
-  moabMCNPUseDistLimit = !!atoi( options[2].value.c_str() );
+  useDistLimit = !!atoi( options[2].value.c_str() );
   useCAD = !!atoi( options[3].value.c_str() );
 #ifndef HAVE_CGM_FIRE_RAY
@@ -235,16 +324,28 @@
+void DagMC::write_settings( FILE* fptr, bool desc ) {
+  int num_opt = sizeof(options) / sizeof(options[0]);
+  if (desc) for (int i = 0; i < num_opt; ++i)
+    fprintf( fptr, "%s = %s  # %s\n", options[i].name.c_str(), options[i].value.c_str(), options[i].desc.c_str() );
+  else for (int i = 0; i < num_opt; ++i)
+    fprintf( fptr, "%s = %s\n", options[i].name.c_str(), options[i].value.c_str() );
+// **** PASS SETTINGS FROM CALLING APPLICATION ****
+// This is the prefered way to set DAGMC settings
 void DagMC::set_settings(int source_cell, int use_cad, int use_dist_limit,
 			 double add_distance_tolerance,
 			 double discard_distance_tolerance) {
-  moabMCNPSourceCell = source_cell;
+  sourceCell = source_cell;
     exit(2);
-  std::cout << "Set Source Cell = " << moabMCNPSourceCell << std::endl;
+  std::cout << "Set Source Cell = " << sourceCell << std::endl;
   addDistTol = add_distance_tolerance;
   if (addDistTol <= 0 || addDistTol > 1) {
@@ -262,9 +363,9 @@
   std::cout << "Set distance tolerance 2 = " << discardDistTol << std::endl;
-  moabMCNPUseDistLimit = !!(use_dist_limit);
+  useDistLimit = !!(use_dist_limit);
-  std::cout << "Turned " << (moabMCNPUseDistLimit?"ON":"OFF") << " distance limit." << std::endl;
+  std::cout << "Turned " << (useDistLimit?"ON":"OFF") << " distance limit." << std::endl;
   useCAD = !!(use_cad);
   std::cout << "Turned " << (useCAD?"ON":"OFF") << " ray firing on full CAD model." << std::endl;
@@ -280,71 +381,8 @@
-void DagMC::read_settings( const char* filename )
-  int num_opt = sizeof(options) / sizeof(options[0]);
-  FILE* file;
-  if (filename && (file = fopen( filename, "r" ))) {
-    int line = 0;
-    char buffer[256];
-    bool havenl = true;
-    while ( fgets( buffer, sizeof(buffer), file ) ) {
-      if (havenl) {
-        havenl = false;
-        ++line;
-      int len = strlen(buffer);
-      if (len && buffer[len-1] == '\n')
-        havenl = true;
-        // chop off any thing after the '#' comman indicator
-      char* c = strchr( buffer, '#' );
-      if (c) *c = '\0';
-        // skip leading white space
-      char* p = buffer;
-      while (isspace(*p)) ++p;
-        // if empty line, done
-      if (!*p)
-        continue;
-        // find '='
-      c = strchr( p, '=' );
-      if (!c) {
-        fprintf(stderr, "Invalid option at line %d of config file '%s'\n", line, filename );
-        exit(2);
-        // get rid of white space around '='
-      char* v = c+1;
-      *c = ' ';
-      while (c > p && isspace(*c)) {
-        *c = '\0';
-        --c;
-      while (isspace(*v))
-        ++v;
-        // search for option
-      bool found = false;
-      for (int i = 0; i < num_opt; ++i) {
-        if (options[i].name == p) {
-          found = true;
-          options[i].value = v;
-          options[i].user_set = true;
-      if (!found)
-        fprintf(stderr,"Warning: unknown option at line %d of '%s': %s\n", line, filename, p );
-    } // while( fgets() )
-    fclose(file);
-  } // file(file)
-  // always do this, even if no file was found.
-  // it will either read the default values, or re-parse
-  // the values previously read from some other file.
-  parse_settings();
 // point_in_volume_slow, including poly_solid_angle helper subroutine
 // are adapted from "Point in Polyhedron Testing Using Spherical Polygons", Paulo Cezar
 // Pinto Carvalho and Paulo Roma Cavalcanti, _Graphics Gems V_, pg. 42.  Original algorithm
@@ -360,7 +398,7 @@
     // Get connectivity
   const MBEntityHandle* conn;
   int len;
-  rval = moab_instance()->get_connectivity( face, conn, len, true );
+  rval = MBI->get_connectivity( face, conn, len, true );
   if (MB_SUCCESS != rval)
     return rval;
@@ -374,7 +412,7 @@
     // get coordinates
-  rval = moab_instance()->get_coords( conn, len, coords->array() );
+  rval = MBI->get_coords( conn, len, coords->array() );
     return rval;
@@ -421,7 +459,7 @@
   double sum = 0.0;
   const MBCartVect point(x,y,z);
-  rval = moab_instance()->get_child_meshsets( volume, surfs );
+  rval = MBI->get_child_meshsets( volume, surfs );
     return rval;
@@ -436,7 +474,7 @@
     double surf_area = 0.0, face_area;
     faces.clear();
-    rval = moab_instance()->get_entities_by_dimension( surfs[i], 2, faces );
+    rval = MBI->get_entities_by_dimension( surfs[i], 2, faces );
       return rval;
@@ -562,10 +600,10 @@
   int len, sense;
   MBCartVect coords[3], normal;
   if (tris.size() == 1) {
-    rval = moab_instance()->get_connectivity( tris.front(), conn, len );
+    rval = MBI->get_connectivity( tris.front(), conn, len );
     if (MB_SUCCESS != rval || len != 3)
       return MB_FAILURE;
-    rval = moab_instance()->get_coords( conn, len, coords[0].array() );
+    rval = MBI->get_coords( conn, len, coords[0].array() );
     if (MB_SUCCESS != rval) return rval;
     rval = surface_sense( volume, surfs.front(), sense );
@@ -593,10 +631,10 @@
   for (unsigned i = 0; i < tris.size(); ++i) {
     some_above = some_below = false;
-    rval = moab_instance()->get_connectivity( tris[i], conn, len );
+    rval = MBI->get_connectivity( tris[i], conn, len );
       return MB_FAILURE;
     rval = surface_sense( volume, surfs[i], sense );
@@ -613,10 +651,10 @@
       if (j == i)
         continue;
-      rval = moab_instance()->get_connectivity( tris[j], conn, len );
+      rval = MBI->get_connectivity( tris[j], conn, len );
         return MB_FAILURE;
         return rval;
@@ -695,7 +733,7 @@
     // get surfaces from volume
-  rval = moab_instance()->get_child_meshsets( volume, surfaces );
+  rval = MBI->get_child_meshsets( volume, surfaces );
     // get surface senses
@@ -714,7 +752,7 @@
       // get triangles in surface
     MBRange triangles;
-    rval = moab_instance()->get_entities_by_dimension( surfaces[i], 2, triangles );
+    rval = MBI->get_entities_by_dimension( surfaces[i], 2, triangles );
       return rval;
     if (!triangles.all_of_type(MBTRI)) {
@@ -728,10 +766,10 @@
     int len;
     MBCartVect coords[3];
     for (MBRange::iterator j = triangles.begin(); j != triangles.end(); ++j) {
-      rval = moab_instance()->get_connectivity( *j, conn, len, true );
+      rval = MBI->get_connectivity( *j, conn, len, true );
       assert(3 == len);
-      rval = moab_instance()->get_coords( conn, 3, coords[0].array() );
+      rval = MBI->get_coords( conn, 3, coords[0].array() );
       coords[1] -= coords[0];
@@ -750,7 +788,7 @@
   MBRange triangles;
-  MBErrorCode rval = moab_instance()->get_entities_by_dimension( surface, 2, triangles );
+  MBErrorCode rval = MBI->get_entities_by_dimension( surface, 2, triangles );
     return rval;
@@ -764,10 +802,10 @@
   int len;
     assert(3 == len);
@@ -793,7 +831,7 @@
     volume = (MBEntityHandle) 0;
   std::vector<MBEntityHandle> surf_volumes( 2*num_surfaces );
-  MBErrorCode rval = moab_instance()->tag_get_data( sense_tag(), surfaces, num_surfaces, &surf_volumes[0] );
+  MBErrorCode rval = MBI->tag_get_data( sense_tag(), surfaces, num_surfaces, &surf_volumes[0] );
   const MBEntityHandle* end = surfaces + num_surfaces;
@@ -828,7 +866,7 @@
   MBEntityHandle surf_volumes[2];
-  MBErrorCode rval = moab_instance()->tag_get_data( sense_tag(), &surface, 1, surf_volumes );
+  MBErrorCode rval = MBI->tag_get_data( sense_tag(), &surface, 1, surf_volumes );
   if (surf_volumes[0] == volume)
@@ -841,93 +879,56 @@
   return MB_SUCCESS;
-MBErrorCode DagMC::load_file_and_init(const char* cfile,
-                                      const int clen,
-                                      const char* ffile,
-                                      const int flen,
-				      const double facet_tolerance)
+MBErrorCode DagMC::load_file(const char* cfile,
+			     const double facet_tolerance)
-    // Always do this first to make sure we have at least the
-    // default values if noone ever calls read_settings(). If
-    // read_settings() has already been called, it will just
-    // re-parse the same values.
-  read_settings(0);
+  MBErrorCode rval;
+  MBEntityHandle file_set;
+    // override default value of facetingTolerance with passed value
   if (facet_tolerance > 0 )
     facetingTolerance = facet_tolerance;
-  MBErrorCode rval;
-  std::string scfile = cfile;
+  char facetTolStr[16];
-    // save whether it's geometry or mesh, building obb later depends
-    // on this setting
-  bool is_geom = false;
-  if (scfile.find(".sat",0) > (unsigned int) 0 &&
-      scfile.find(".sat",0) <= scfile.length()) {
+  sprintf(facetTolStr,"%g",facetingTolerance);
-    is_geom = true;
+  // what if we are using default faceting tolerance???
+  char options[120] = "CGM_ATTRIBS=yes;FACET_DISTANCE_TOLERANCE=";
+  strcat(options,facetTolStr);
-#ifdef CGM
-      // initialize cgm
-    InitCGMA::initialize_cgma("ACIS");
-    CGMApp::instance()->attrib_manager()->set_all_auto_read_flags(true);
-    CGMApp::instance()->attrib_manager()->set_all_auto_actuate_flags(true);
-    CubitStatus s = GeometryQueryTool::instance()->import_solid_model( scfile.c_str(), "ACIS_SAT");
-    if (CUBIT_SUCCESS != s) {
-      std::cerr << "Failed to read '" << scfile << "' of type 'ACIS_SAT'"
-                << std::endl;
-      exit(2);
-    if (!cgm2moab(moab_instance(), facetingTolerance)) {
-      std::cerr << "Internal error copying geometry" << std::endl;
-      exit(5);
-    if (!useCAD) {
-      // ok, we're done with CGM
-      CGMApp::instance()->shutdown();
-#else
-    std::cerr << "CGM not supported in this version." << std::endl;
-#endif
+  rval = MBI->load_file(cfile, file_set, options, NULL, 0, 0);
+  if (MB_SUCCESS != rval) {
+    std::cerr << "Couldn't read file " << cfile << std::endl;
+    return rval;
-  else if (scfile.find(".cub",0) > (unsigned int) 0 &&
-           scfile.find(".cub",0) <= scfile.length()) {
-    std::cerr << "Error: can't read .cub files yet." << std::endl;
-    exit(7);
-  else {
-    rval = moab_instance()->load_mesh(scfile.c_str());
-    if (MB_SUCCESS != rval) {
-      std::cerr << "Couldn't read file " << scfile << std::endl;
-      return rval;
-    else if (useCAD) {
-      std::cerr << "useCAD parameter turned on but geometry read from "
-                << "a mesh file;" << std::endl
-                << " turning that parameter off for you." << std::endl;
-      useCAD = 0;
-    else if (options[4].user_set == true) {
-      std::cerr << "Warning: user-set tolerance won't apply to pre-generated mesh file."
-                << std::endl;
+  // How do we know what type of file we read for downstream issues:
+  // * useCad
+  // * is_geom in build_indices
+  return MB_SUCCESS;
+MBErrorCode DagMC::init_OBBTree()
+  MBErrorCode rval;
   MBRange surfs, vols;
   const int three = 3;
   const void* const three_val[] = {&three};
-  rval =
-    moab_instance()->get_entities_by_type_and_tag( 0, MBENTITYSET, &geomTag,
-                                                   three_val, 1, vols );
+  rval = MBI->get_entities_by_type_and_tag( 0, MBENTITYSET, &geomTag,
+				       three_val, 1, vols );
     return rval;
   const int two = 2;
   const void* const two_val[] = {&two};
-  rval = moab_instance()->get_entities_by_type_and_tag( 0, MBENTITYSET, &geomTag, two_val, 1, surfs );
+					    two_val, 1, surfs );
     return rval;
@@ -950,23 +951,32 @@
     // build the various index vectors used for efficiency
-  rval = build_indices(surfs, vols, is_geom);
+  rval = build_indices(surfs, vols);
     std::cerr << "Failed to build surface/volume indices." << std::endl;
     return rval;
-    // finally, if user entered a facet file name, export facets to
-    // that file
+MBErrorCode DagMC::write_mesh(const char* ffile,
+			      const int flen)
+  MBErrorCode rval;
+    // write out a mesh file if requested
   if (ffile && 0 < flen) {
-    rval = moab_instance()->write_mesh(ffile);
+    rval = MBI->write_mesh(ffile);
       std::cerr << "Failed to write mesh to " << ffile << "." << std::endl;
       return rval;
   return MB_SUCCESS;
 bool DagMC::have_obb_tree()
@@ -986,7 +996,7 @@
   MBErrorCode rval;
   MBRange results;
-  rval = moab_instance()->get_entities_by_type_and_tag( 0, MBENTITYSET, tags, vals, 2, results );
+  rval = MBI->get_entities_by_type_and_tag( 0, MBENTITYSET, tags, vals, 2, results );
   if (MB_SUCCESS != rval || results.empty())
     return 0;
@@ -1000,356 +1010,337 @@
     return 0;
   int result = 0;
-  moab_instance()->tag_get_data( idTag, &h, 1, &result );
+  MBI->tag_get_data( idTag, &h, 1, &result );
   return result;
-void DagMC::write_log(std::string ifile, const bool overwrite)
+// functionality in write_log
+// 1. for each group
+//    a) check for material assignment -> get list of member vols and set mat/dens array
+//    b) check for b.c. -> get list of surfaces and set bc array (incl. periodic???)
+//    c) check for graveyard -> set importance
+//    d) check for tallies
+//       * record tally ID
+// 2. write cell cards
+// 3. write surf cards
+// 4. if tallies
+//    a) loop through all groups to find tallies
+//       * parse tally type, etc
+//       * get list of cells or surfaces
+//       * write tally cards
+MBErrorCode DagMC::write_mcnp(std::string ifile, const bool overwrite)
+  std::map<std::string,int> tallyKeywords;
+  tallyKeywords["surf.current"] = 1;
+  tallyKeywords["surf.flux"]    = 2;
+  tallyKeywords["cell.flux"]    = 4;
+  tallyKeywords["cell.heating"] = 6;
+  tallyKeywords["cell.fission"] = 7;
+  tallyKeywords["pulse.height"] = 8;
+  std::vector<MBEntityHandle>::iterator iter;
   if (!overwrite) {
       // if not overwriting, test for file, and if it exists, just return;
       // this replaces the old inquir function
     std::ifstream testfile;
     testfile.open(ifile.c_str());
-    if (!testfile.fail()) return;
+    if (!testfile.fail()) return MB_SUCCESS;
   const char *cifile = ifile.c_str();
   std::ofstream cgmfile;
   cgmfile.open(cifile);
-  int ncells;
-  int nsurfs;
-  int ngroups;
-  int maxital;
-// Get the number of surfaces and cells for dynamic memory
-  ncells = vol_handles().size()-1;
-  nsurfs = surf_handles().size()-1;
-  ngroups = group_handles().size()-1;
-  MBRange vols_save, surfs_save;
-  std::copy(vol_handles().begin()+1, vol_handles().end(),
-            mb_range_inserter(vols_save));
-  std::copy(surf_handles().begin()+1, surf_handles().end(),
-            mb_range_inserter(surfs_save));
-  std::cout << "ncells: " << ncells << std::endl;
-  std::cout << "nsurfs: " << nsurfs << std::endl;
-  std::cout << "ngroups: " << ngroups << std::endl;
-  std::vector<int> mats(ncells);
-  std::vector<double> dens(ncells);
-  std::vector<int> imp(ncells);
-  std::vector<int> surflist(nsurfs);
-  std::vector<int> surfbcs(nsurfs);
-  std::vector<std::string> gruplist;
-// Zero out material and density info
-  for (int ii=1; ii <=ncells; ii++) {
-    mats[ii-1] = 0;
-    dens[ii-1] = 0.0;
-    imp[ii-1] = 1;
+  std::cout << "  # cells: " << vol_handles().size()-1 << std::endl;
+  std::cout << "  # surfs: " << surf_handles().size()-1 << std::endl;
+  std::cout << " # groups: " << group_handles().size()-1 << std::endl;
+  std::cout << "# tallies: " << tallyList.size() << std::endl;
+  MBRange grp_sets, grp_ents;
+  MBErrorCode rval;
+  MBRange surfs, vols;
+  // write cell information (skip first entry)
+  for (iter = vol_handles().begin()+1; iter != vol_handles().end(); iter++) {
+    int cellid,matid;
+    double imp, density;
+    MBI->tag_get_data( idTag , &(*iter), 1, &cellid   );
+    MBI->tag_get_data(impTag , &(*iter), 1, &imp      );
+    MBI->tag_get_data(matTag , &(*iter), 1, &matid    );
+    if (0 == matid) {
+      cgmfile << cellid << " " << matid << " imp:n=" << imp ;
+    } else {
+      MBI->tag_get_data(densTag, &(*iter), 1, &density  );
+      cgmfile << cellid << " " << matid << " " << density << " imp:n=" << imp ;
+    if (*iter == impl_compl_handle)
+      cgmfile << "   $ implicit complement ";
+    cgmfile << std::endl;
-  maxital = -1;
-  for (int ii=1; ii <=nsurfs; ii++)
-    surfbcs[ii-1] = 0;
-// Read in each group name, check if a material specification
-// or surface boundary condition
-    // get all the groups
+  // skip a line
+  // write surface info (skip first entry)
+  for (iter = surf_handles().begin()+1; iter != surf_handles().end(); iter++ ) {
+    int surfid, bc_id;
+    MBI->tag_get_data( idTag, &(*iter), 1, &surfid );
+    MBI->tag_get_data( bcTag, &(*iter), 1, &bc_id  );
+    if (BC_SPEC == bc_id)
+      cgmfile << "*";
+    if (BC_WHITE == bc_id)
+      cgmfile << "+";
+    cgmfile << surfid << std::endl;
+  // add a final blank line
   std::vector<std::string> grp_names;
-  for (int ii=1; ii <=ngroups; ii++) {
-      // get group & names
-    MBEntityHandle group = group_handles()[ii];
+  std::vector<std::string> tokens;
+  // write tally info
+  for (std::vector<int>::iterator grp = tallyList.begin(); grp != tallyList.end(); grp++) {
+    std::stringstream tallyCard;
+    MBEntityHandle group = group_handles()[*grp];
     grp_names.clear();
     bool success = get_group_names(group, grp_names);
     assert(success);
     if (grp_names.empty()) continue;
+    // get sets associated with this group
+    rval = MBI->get_entities_by_type(group, MBENTITYSET, grp_sets);
+    if (MB_SUCCESS != rval) continue;
-      // get sets in the group
-    MBRange grp_sets;
-    MBErrorCode result = moab_instance()->get_entities_by_type(group, MBENTITYSET, grp_sets);
-    if (MB_SUCCESS != result) continue;
-    if (grp_names[0].find("mat",0) == 0 && (grp_names[0].find("rho",0) > 0)) {
-        // Extract material ID and density
-      int cpos = grp_names[0].find("mat",0) + 4;
-      std::string matid_str;
-      while ((int(grp_names[0][cpos]) >= 48) && (int(grp_names[0][cpos]) <= 57)) {
-        matid_str += grp_names[0][cpos];
-        cpos++;
+    tokens.clear();
+    tokenize(grp_names[0],tokens,"_");
+    // Get user number for tally
+    int talNum = atoi(tokens[1].c_str());
+    char talMod = ' ';
+    // Get tally modifier
+    if ( 'e' == tokens[2][0] )
+      talMod = '*';
+    if ( 'q' == tokens[2][0] )
+      talMod = '+';
+    if (talMod != ' ')
+      tokens[2].erase(0,1);  // strip special character for modified tallies
+    // Get tally type
+    if ( tallyKeywords.count(tokens[2]) == 0) {
+      std::cout << "Invalid tally defined in geometry: " << grp_names[0] << std::endl;
+      continue;
+    // Create MCNP number for tally by combining user number and MCNP type code
+    talNum = talNum*10 + tallyKeywords[tokens[2]];
+    // get tally particles
+    std::string partList = "n";
+    if (tokens.size()>3)
+	partList = tokens[3].substr(0,1);
+	for (std::string::iterator pos = tokens[3].begin()+1; pos != tokens[3].end(); pos++)
+	    partList += ",";
+	    partList += *pos;
-      cpos = grp_names[0].find("rho",0) + 4;
-      std::string density_str;
-      while (((int(grp_names[0][cpos]) >= 48) && (int(grp_names[0][cpos]) <= 57)) ||
-             (int(grp_names[0][cpos]) == 46) || (int(grp_names[0][cpos]) == 45) ||
-             (int(grp_names[0][cpos]) == 69) || (int(grp_names[0][cpos]) == 101) ||
-             (int(grp_names[0][cpos]) == 68) || (int(grp_names[0][cpos]) == 100)) {
-        density_str += grp_names[0][cpos];
-        cpos++;
-      const char *cmatid = matid_str.c_str();
-      const char *cdensity = density_str.c_str();
-      int matid = atoi(cmatid);
-      double density = atof(cdensity);
+    // write tally type info
+    tallyCard << talMod << "f" << talNum << ":" << partList ;
+    int dim;
+    if (tallyKeywords[tokens[2]] < 3)
+      dim = 2;
+    else
+      dim = 3;
-        // check for material definition in complement
-      if (grp_names[0].find("comp",0) < 20) {
+    // get entities of correct dimension
+    const void* dim_val[] = {&dim};
+    MBRange ents;
+    rval = MBI->get_entities_by_type_and_tag( 0, MBENTITYSET, &geomTag, dim_val, 1, ents );
+      return rval;
+    MBRange  grp_ents = intersect(grp_sets,ents);
-        std::cout<<"write_log: complement material and density specified" << std::endl;
-        mats[ncells-1]=matid;
-        dens[ncells-1]=density;
+    for (MBRange::iterator ent = grp_ents.begin(); ent != grp_ents.end(); ent++)
+      tallyCard << " " << get_entity_id(*ent);
-      else {
+    tallyCard << " T";
-          // Get the volumes in the current group
-        MBRange grp_vols = intersect( grp_sets, vols_save);
-        for (MBRange::iterator rit = grp_vols.begin();
-             rit != grp_vols.end(); rit++) {
-          MBEntityHandle vol = *rit;
-          int cell_num = index_by_handle(vol);
-          mats[cell_num-1]=matid;
-          dens[cell_num-1]=density;
+    std::string tallyCardStr = tallyCard.str();
+    tallyCard.str("");
+    // write tallyCardStr with 80 char limit per line
+    while ( tallyCardStr.length() > 72 )
+	std::string::size_type pos = tallyCardStr.rfind(' ',72);
+	cgmfile << tallyCardStr.substr(0,pos) << " &" << std::endl;
+	tallyCardStr.erase(0,pos);
+	cgmfile << "     ";
+    cgmfile << tallyCardStr << std::endl;
+  cgmfile.close();
+// desired functionality
+//    a) check for material assignment -> get list of member vols and tag mat & dens
+//    b) check for b.c. -> get list of surfaces and tag b.c.
+//    c) check for graveyard -> tag imp
+MBErrorCode DagMC::parse_metadata()
+  std::vector<std::string> grp_names;
+  std::map<std::string,int> keywords;
+  MBEntityHandle group;
+  MBErrorCode rval;
+  MBRange vols, surfs;
+  std::copy(vol_handles().begin()+1,  vol_handles().end(),
+	    mb_range_inserter(vols));
+  std::copy(surf_handles().begin()+1, surf_handles().end(),
+	    mb_range_inserter(surfs));
+  keywords["mat"]           = MAT_GROUP;
+  keywords["spec.reflect"]  = BC_SPEC;
+  keywords["white.reflect"] = BC_WHITE;
+  keywords["graveyard"]     = IMP_ZERO;
+  keywords["outside.world"] = IMP_ZERO;
+  keywords["rest.of.world"] = IMP_ZERO;
+  keywords["tally"]         = TALLY_GROUP;
+  for (unsigned int grp=0; grp < group_handles().size(); grp++) {
+    // get group handle & names
+    group = group_handles()[grp];
+    grp_names.clear();
+    bool success = get_group_names(group, grp_names);
+    assert(success);
+    if (grp_names.empty()) continue;
+    grp_sets.clear();
+    tokens.clear();
+    // is this a keyword?
+    if (keywords.count(tokens[0]) == 0 ) {
+      std::cout << "Ignoring group with name: " << grp_names[0] << std:: endl;
+      continue;
-    else if ((grp_names[0].find("spec_reflect",0)==0) ||
-             (grp_names[0].find("white_reflect",0)==0)) {
-        // Check whether group is reflecing or white
-      int bc_id;
-      if (grp_names[0].find("spec_reflect",0)==0)
-        bc_id = 1;
-      else
-        bc_id = 2;
-        // Get the surfaces in the current group
-      MBRange grp_faces = intersect( grp_sets, surfs_save);
-      for (MBRange::iterator rit = grp_faces.begin(); rit != grp_faces.end(); rit++) {
-        MBEntityHandle surf = *rit;
-        int surf_num = index_by_handle(surf);
-        surfbcs[surf_num-1]=bc_id;
+    int matid, bc_id;
+    std::vector<int> matid_list, bc_id_list;
+    double density, imp_zero = 0;
+    std::vector<double> density_list, imp_zero_list;
+    // actions for each keyword
+    switch (keywords[tokens[0]]) {
+    case MAT_GROUP:
+      // missing density
+      if ( tokens[2].compare("rho") != 0 ) {
+	std::cout << "Specified material with no density " << grp_names[0] << std::endl;
+	continue;
-    else if (grp_names[0].find("periodic",0)==0) {
-        // Get the periodic surface id
-      int bc_id;
-      std::string bc_str;
-      int cpos = 9;
-      bc_str.clear();
-        bc_str += grp_names[0][cpos];
-        cpos++;
+        matid = atoi(tokens[1].c_str());
+      density = atof(tokens[3].c_str());
+      // check to see if this is the implicit complement
+      if ( tokens.size() > 4 && tokens[4].compare("comp") == 0 ) {
+        std::cout<<"parse_metadata: complement material and density specified" << std::endl;
+	// TAG IMPL COMPL WITH MAT & DENS
+ 	MBI->tag_set_data(matTag ,&impl_compl_handle,1,&matid);
+ 	MBI->tag_set_data(densTag,&impl_compl_handle,1,&density);
+      } else {
+	// apply tag to range of volumes
+	grp_ents.clear();
+	grp_ents = intersect(grp_sets.vols);
+	  matid_list.assign(grp_ents.size(),matid);
+	density_list.assign(grp_ents.size(),density);
+	MBI->tag_set_data(matTag ,grp_ents,&(*matid_list.begin()));
+	MBI->tag_set_data(densTag,grp_ents,&(*density_list.begin()));
-      const char *cbc_id = bc_str.c_str();
-      bc_id = -1*atoi(cbc_id);
+      break;
+    case BC_SPEC:
+    case BC_WHITE:
+      bc_id = keywords[tokens[0]];
+      grp_ents.clear();
+      grp_ents = intersect(grp_sets.surfs);
+      bc_id_list.assign(grp_ents.size(),bc_id);
+      MBI->tag_set_data(bcTag ,grp_ents, &(*bc_id_list.begin()));
+      break;
+    case IMP_ZERO:
+      grp_ents.clear();
+      grp_ents = intersect(grp_sets,vols);
+      imp_zero_list.assign(grp_ents.size(),imp_zero);
+      MBI->tag_set_data(impTag ,grp_ents, &(*imp_zero_list.begin()));
+      break;
+    case TALLY_GROUP:
+      // make list of groups that are tallies
+      grp_ents.clear();
+      tallyList.push_back(grp);
+      break;
-// Set graveyard to zero importance
-    else if ((grp_names[0].find("graveyard",0)==0)||(grp_names[0].find("outside_world",0)==0)
-             ||(grp_names[0].find("rest_of_world",0)==0)) {
-      for (MBRange::iterator rit = grp_vols.begin(); rit != grp_vols.end(); rit++) {
-        int vol_num = index_by_handle(vol);
-        imp[vol_num-1]=0;
-// Check for tally groups, assign maximum CUBIT index
-    else if (grp_names[0].find("tally_",0)==0) {
-      std::string stal;
-      int cpos = 6;
-        stal += grp_names[0][cpos];
-        cpos++;
-      const char *ctal = stal.c_str();
-      if (atoi(ctal) > maxital)
-        maxital = atoi(ctal);
-// Generate list of surfaces
-  for (int ii=1; ii <= nsurfs; ii++) {
-    MBEntityHandle surf = surf_handles()[ii];
-    surflist[ii-1] = get_entity_id(surf);
-//    cout << "surf#: " << ii << " = " << surflist[ii-1] << endl;
-    // write in cell information
-  for (int ii=1; ii <= ncells; ii++) {
-    if (mats[ii-1] == 0) {
-      cgmfile << id_by_index(3, ii) << " " << mats[ii-1] << " " <<
-        "imp:n=" << imp[ii-1] << std::endl;
+void DagMC::tokenize( const std::string& str,
+		      std::vector<std::string>& tokens,
+		      const char* delimiters )
+  std::string::size_type last = str.find_first_not_of( delimiters, 0 );
+  std::string::size_type pos  = str.find_first_of( delimiters, last );
+  if ( std::string::npos == pos )
+    tokens.push_back(str);
+  else
+    while (std::string::npos != pos && std::string::npos != last) {
+      tokens.push_back( str.substr( last, pos - last ) );
+      last = str.find_first_not_of( delimiters, pos );
+      pos  = str.find_first_of( delimiters, last );
+      if(std::string::npos == pos)
+	pos = str.size();
-    else {
-        dens[ii-1] << " " << "imp:n=" << imp[ii-1] << std::endl;
-    // skip a line
-  cgmfile << std::endl;
-    // write out surface information (need boundary conditions)
-    if (surfbcs[ii-1] == 1)
-      cgmfile << "*" << surflist[ii-1] << std::endl;
-    else if (surfbcs[ii-1] == 2)
-      cgmfile << "+" << surflist[ii-1] << std::endl;
-    else if (surfbcs[ii-1] < 0)
-      cgmfile << surflist[ii-1] << " " << surfbcs[ii-1] << std::endl;
-    else
-      cgmfile << surflist[ii-1] << std::endl;
-    // add a final blank line
-  cgmfile << " ";
-    // if tallies were specified, write those out at end of .cgm file
-  if (maxital >= 0) {
-      // loop through each possible CUBIT tally index, write information
-    for (int ii=0; ii <= maxital; ii++) {
-        // loop through each group name, check to see if the desired tally type
-      for (int jj=1; jj <= ngroups; jj++) {
-        MBEntityHandle group = group_handles()[jj];
-        grp_names.clear();
-        bool success = get_group_names(group, grp_names);
-        assert(success);
-        if (!success || grp_names.empty()) continue;
-        std::string talstr;
-        talstr = "tally_" + itos(ii) + "_";
-        const char *ctalstr = talstr.c_str();
-        if (grp_names[0].find(ctalstr,0)==0) {
-          unsigned int cpos = talstr.length();
-          int etal = 0;
-            // check if next character is "e" or "q" denoting energy or charge
-	  // need to also check if next character conforms to acceptable argument
-          if ((int(grp_names[0][cpos]) == 101) &&
-              ((int(grp_names[0][cpos+1]) == 115) ||
-               (int(grp_names[0][cpos+1]) == 99) || (int(grp_names[0][cpos+1]) == 112))) {
-            etal = 1;
-            cpos++;
-          else if ((int(grp_names[0][cpos]) == 113) && (int(grp_names[0][cpos+1]) == 112)) {
-            etal = -1;
-            cpos++;
-            // check to obtain tally type
-          int ital = 0;
-          int tidx = 0;
-          int tklen = 0;
-          if (grp_names[0].find("surf_current",cpos)==cpos) {
-            tidx = 1;
-            ital = 10*ii + tidx;
-            tklen = 13;
-          else if (grp_names[0].find("surf_flux",cpos)==cpos) {
-            tidx = 2;
-            tklen = 10;
-          else if (grp_names[0].find("cell_flux",cpos)==cpos) {
-            tidx = 4;
-            tklen = 10;
-          else if (grp_names[0].find("cell_heating",cpos)==cpos) {
-            tidx = 6;
-            tklen = 13;
-          else if (grp_names[0].find("cell_fission",cpos)==cpos) {
-            tidx = 7;
-            tklen = 13;
-          else if (grp_names[0].find("pulse_height",cpos)==cpos) {
-            tidx = 8;
-            tklen = 13;
-          if (tidx > 0) {
-            int ipos = 1;
-              // place the tally header in the .cgm file
-            if (etal == 1) {
-              cgmfile << "*";
-              ipos++;
-            else if ((etal == -1) && (tidx == 8)) {
-              cgmfile << "+";
-              ipos++;
-            cgmfile << "f" << ital << ":";
-            std::stringstream spos;
-            spos << ital;
-            ipos += spos.str().length() + 2;
-	    // get the particles the tally covers (default is n)
-            cpos += tklen;
-            std::string talptls;
-            while((cpos < grp_names[0].length()) && (int(grp_names[0][cpos]) >= 65) &&
-                  (int(grp_names[0][cpos]) <= 122) && (int(grp_names[0][cpos]) != 95)) {
-              talptls += grp_names[0][cpos];
-              cpos++;
-	    // read the tally particle string and place in .cgm file
-            if (talptls.empty()) {
-              cgmfile << "n" << " ";
-              ipos += 2;
-            else {
-              for(unsigned int kk=1; kk <= talptls.length(); kk++) {
-                cgmfile << talptls[kk-1];
-                if (kk < talptls.length())
-                  cgmfile << ",";
-                else
-                  cgmfile << " ";
-                ipos += 2*talptls.length();
-	    // begin read of surfaces in current group
-            MBRange grp_sets;
-            if ((tidx == 1) || (tidx == 2)) {
-                int jtal = get_entity_id(*rit);
-                std::stringstream spos1;
-                spos1 << jtal;
-                ipos += spos1.str().length() + 1;
-                if (ipos > 78) {
-                  cgmfile << "&" << std::endl << "     ";
-                  ipos = spos1.str().length() + 7;
-                cgmfile << jtal << " ";
-            else if ((tidx == 4) || ((tidx >= 6) && (tidx <= 8))) {
-                spos1 << jtal;
-                if (ipos > 78) {
-	    // set default behavior to provide total over all tally regions
-	    if (ipos+2 > 78) {
-            cgmfile << " T" << std::endl;
-  cgmfile.close();
 std::string DagMC::itos(int ival) {
@@ -1364,7 +1355,7 @@
     // get names
   char name0[NAME_TAG_SIZE];
   std::fill(name0, name0+NAME_TAG_SIZE, '\0');
-  MBErrorCode result = moab_instance()->tag_get_data(name_tag(), &group_set, 1,
+  MBErrorCode result = MBI->tag_get_data(name_tag(), &group_set, 1,
                                                      &name0);
   if (MB_SUCCESS != result && MB_TAG_NOT_FOUND != result) return false;
@@ -1378,7 +1369,7 @@
                              false);
     if (0 == this_tag) break;
-    result = moab_instance()->tag_get_data(this_tag, &group_set, 1, &name0);
+    result = MBI->tag_get_data(this_tag, &group_set, 1, &name0);
     if (MB_TAG_NOT_FOUND == result) break;
     else grp_names.push_back(std::string(name0));
@@ -1387,12 +1378,13 @@
   return true;
-MBTag DagMC::get_tag( const char* name, int size, MBTagType store, MBDataType type,
-                       bool create_if_missing)
+MBTag DagMC::get_tag( const char* name, int size, MBTagType store,
+		      MBDataType type, const void* def_value,
+		      bool create_if_missing)
   MBTag retval = 0;
-  MBErrorCode result = moab_instance()->tag_create(name, size, store, type,
-                                                   retval, NULL, create_if_missing);
+  MBErrorCode result = MBI->tag_create(name, size, store, type,
+                                                   retval, def_value, create_if_missing);
   if (create_if_missing && MB_SUCCESS != result)
     std::cerr << "Couldn't find nor create tag named " << name << std::endl;
@@ -1402,9 +1394,9 @@
 int DagMC::get_entity_id(MBEntityHandle this_ent)
   int id = 0;
-  MBErrorCode result = moab_instance()->tag_get_data(idTag, &this_ent, 1, &id);
+  MBErrorCode result = MBI->tag_get_data(idTag, &this_ent, 1, &id);
-    id = moab_instance()->id_from_handle(this_ent);
+    id = MBI->id_from_handle(this_ent);
   return id;
@@ -1501,8 +1493,7 @@
 #endif
-MBErrorCode DagMC::build_indices(MBRange &surfs, MBRange &vols,
-                                  bool is_geom)
+MBErrorCode DagMC::build_indices(MBRange &surfs, MBRange &vols)
   MBErrorCode rval = MB_SUCCESS;
@@ -1538,7 +1529,7 @@
   for (MBRange::iterator rit = vols.begin(); rit != vols.end(); rit++)    {
     entIndices[*rit-setOffset] = idx++;
     int result=0;
-    moab_instance()->tag_get_data( idTag, &*rit, 1, &result );
+    MBI->tag_get_data( idTag, &*rit, 1, &result );
     max_id = (max_id > result ? max_id : result);
     // add implicit complement to entity index
@@ -1546,7 +1537,7 @@
     // assign ID to implicit complement
   max_id++;
-  moab_instance()->tag_set_data(idTag, &impl_compl_handle, 1, &max_id);
+  MBI->tag_set_data(idTag, &impl_compl_handle, 1, &max_id);
@@ -1556,7 +1547,7 @@
       // get geometry entities by id and cache in this vector
     std::vector<int> ids;
     ids.resize(surfs.size());
-    rval = moab_instance()->tag_get_data(id_tag(), surfs, &ids[0]);
+    rval = MBI->tag_get_data(id_tag(), surfs, &ids[0]);
     if (MB_SUCCESS != rval) return MB_FAILURE;
     int i = 0;
     MBRange::iterator rit = surfs.begin();
@@ -1567,7 +1558,7 @@
       geomEntities[*rit - setOffset] = this_surf;
     ids.resize(vols.size());
-    rval = moab_instance()->tag_get_data(id_tag(), vols, &ids[0]);
+    rval = MBI->tag_get_data(id_tag(), vols, &ids[0]);
     i = 0;
     rit = vols.begin();
@@ -1588,8 +1579,8 @@
   sprintf(group_category, "%s", "Group");
   const void* const group_val[] = {&group_category};
   MBRange groups;
-  rval = moab_instance()->get_entities_by_type_and_tag(0, MBENTITYSET, &category_tag,
-                                                       group_val, 1, groups);
+  rval = MBI->get_entities_by_type_and_tag(0, MBENTITYSET, &category_tag,
+					   group_val, 1, groups);
     return rval;
   group_handles().resize(groups.size()+1);
@@ -1599,7 +1590,7 @@
     // populate root sets vector
   std::vector<MBEntityHandle> rsets;
   rsets.resize(surfs.size());
-  rval = moab_instance()->tag_get_data(obb_tag(), surfs, &rsets[0]);
+  rval = MBI->tag_get_data(obb_tag(), surfs, &rsets[0]);
   MBRange::iterator rit;
   int i;
@@ -1607,14 +1598,14 @@
     rootSets[*rit-setOffset] = rsets[i];
   rsets.resize(vols.size());
-  rval = moab_instance()->tag_get_data(obb_tag(), vols, &rsets[0]);
+  rval = MBI->tag_get_data(obb_tag(), vols, &rsets[0]);
   for (i = 0, rit = vols.begin(); rit != vols.end(); rit++, i++)
   // add implicit complement root set
   rsets.resize(1);
-  rval = moab_instance()->tag_get_data(obb_tag(), &impl_compl_handle, 1,
+  rval = MBI->tag_get_data(obb_tag(), &impl_compl_handle, 1,
                                        &rsets[0]);
   rootSets[impl_compl_handle-setOffset] = rsets[0];
@@ -1629,7 +1620,7 @@
   for (MBRange::iterator i = surfs.begin(); i != surfs.end(); ++i) {
     MBEntityHandle root;
     MBRange tris;
-    rval = moab_instance()->get_entities_by_dimension( *i, 2, tris );
+    rval = MBI->get_entities_by_dimension( *i, 2, tris );
       return rval;
     if (tris.empty())
@@ -1637,10 +1628,10 @@
     rval = obbTree.build( tris, root );
       return rval;
-    rval = moab_instance()->add_entities( root, &*i, 1 );
+    rval = MBI->add_entities( root, &*i, 1 );
       return rval;
-    rval = moab_instance()->tag_set_data( obbTag, &*i, 1, &root );
+    rval = MBI->tag_set_data( obbTag, &*i, 1, &root );
       return rval;
@@ -1648,7 +1639,7 @@
   for (MBRange::iterator i = vols.begin(); i != vols.end(); ++i) {
       // get all surfaces in volume
     MBRange tmp_surfs;
-    rval = moab_instance()->get_child_meshsets( *i, tmp_surfs );
+    rval = MBI->get_child_meshsets( *i, tmp_surfs );
       return rval;
@@ -1667,7 +1658,7 @@
       if (!sense)
         continue;
-      rval = moab_instance()->tag_get_data( obbTag, &*j, 1, &root );
+      rval = MBI->tag_get_data( obbTag, &*j, 1, &root );
       if (MB_SUCCESS != rval || !root)
         return MB_FAILURE;
       trees.insert( root );
@@ -1678,7 +1669,7 @@
       return rval;
       return rval;
@@ -1705,13 +1696,13 @@
     parent_vols.clear();
       // get parents of each surface
-    rval = moab_instance()->get_parent_meshsets( *surf_i, parent_vols );
+    rval = MBI->get_parent_meshsets( *surf_i, parent_vols );
       return rval;
       // if only one parent, get the OBB root for this surface
     if (parent_vols.size() == 1 ) {
-      rval = moab_instance()->tag_get_data( obbTag, &*surf_i, 1, &surf_obb_root );
+      rval = MBI->tag_get_data( obbTag, &*surf_i, 1, &surf_obb_root );
         return rval;
       if (!surf_obb_root)
@@ -1728,7 +1719,7 @@
     return rval;
     // tag the implicit complement handle with the handle for its own OBB tree
-  rval = moab_instance()->tag_set_data( obbTag, &impl_compl_handle, 1, &comp_root );
+  rval = MBI->tag_set_data( obbTag, &impl_compl_handle, 1, &comp_root );
     return rval;
@@ -1774,24 +1765,27 @@
   MBErrorCode rval = mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET,
                                                            &nameTag, tagdata, 1,
                                                            entities );
+  // query error
     std::cerr << "Unable to query for implicit complement." << std::endl;
     return rval;
+  // found too many
   if (entities.size() > 1) {
     std::cerr << "Too many implicit complement sets." << std::endl;
     return MB_MULTIPLE_ENTITIES_FOUND;
+  // found none
   if (entities.empty()) {
-    rval= moab_instance()->create_meshset(MESHSET_SET,impl_compl_handle);
+    rval= MBI->create_meshset(MESHSET_SET,impl_compl_handle);
       std::cerr << "Failed to create mesh set for implicit complement." << std::endl;
       return rval;
       // tag this entity with name for implicit complement
-    rval = moab_instance()->tag_set_data(nameTag,&impl_compl_handle,1,&implComplName);
+    rval = MBI->tag_set_data(nameTag,&impl_compl_handle,1,&implComplName);
       std::cerr << "Failed to tag new entity as implicit complement." << std::endl;
@@ -1799,9 +1793,11 @@
     return rval;
   } else {
+    // found a single implicit complement
     impl_compl_handle = entities.front();
     return MB_SUCCESS;
Modified: MOAB/trunk/tools/dagmc/DagMC.hpp
--- MOAB/trunk/tools/dagmc/DagMC.hpp	2009-07-14 14:57:15 UTC (rev 3005)
+++ MOAB/trunk/tools/dagmc/DagMC.hpp	2009-07-14 16:49:39 UTC (rev 3006)
@@ -74,13 +74,19 @@
     // {-1 -> reversed, 0 -> both, 1 -> forward}
   MBErrorCode surface_sense( MBEntityHandle volume, MBEntityHandle surface, int& sense_out );
-    // load mesh and initialize
-  MBErrorCode load_file_and_init(const char* cfile,
-                                 const int clen,
-                                 const int flen,
-				 const double facet_tolerance = 0);
+    // load mesh
+  MBErrorCode load_file(const char* cfile,
+			const double facet_tolerance = 0);
+  MBErrorCode init_OBBtree();
+  MBErrorCode write_mesh(const char* ffile,
+			 const int flen);
+    // initialize data structures and OBB tree
+  MBErrorCode init_OBBTree();
     // map between MBEntityHandle, base-1 index, and GLOBAL_ID
   MBEntityHandle entity_by_index( int dimension, int index );
   MBEntityHandle entity_by_id( int dimension, int id );
@@ -92,10 +98,12 @@
     // if dimension == 2).
   int num_entities( int dimension );
-    // read/write settings
+    // read/write settings from file
   void read_settings( const char* filename );
   void write_settings( FILE* filp, bool with_description = true );
   void parse_settings();
+    // pass settings from calling application
   void set_settings(int source_cell, int use_cad, int use_dist_limit,
 		    double discard_distance_tolerance);
@@ -125,7 +133,11 @@
   std::vector<MBEntityHandle>& group_handles() {return entHandles[4];}
-  void write_log(std::string ifile, const bool overwrite = true);
+  MBErrorCode write_mcnp(std::string ifile, const bool overwrite = true);
+  MBErrorCode parse_metadata();
+  void tokenize( const std::string& str,
+			const char* delimiters );
   MBErrorCode poly_solid_angle( MBEntityHandle face, const MBCartVect& point, double& area );
@@ -154,9 +166,9 @@
   double faceting_tolerance() {return facetingTolerance;}
-  int source_cell() {return moabMCNPSourceCell;}
+  int source_cell() {return sourceCell;}
-  bool use_dist_limit() {return moabMCNPUseDistLimit;}
+  bool use_dist_limit() {return useDistLimit;}
   bool use_cad() {return useCAD;}
@@ -181,15 +193,14 @@
   MBErrorCode get_impl_compl();
   MBTag get_tag( const char* name, int size, MBTagType store, MBDataType type,
-                 bool create_if_missing = true);
+                 const void* def_value = NULL, bool create_if_missing = true);
   bool get_group_names(MBEntityHandle group_set, std::vector<std::string> &grp_names);
   static void create_instance(MBInterface *mb_impl = NULL);
     // build internal index vectors that speed up handle-by-id, etc.
-  MBErrorCode build_indices(MBRange &surfs, MBRange &vols,
-                            bool is_geom);
+  MBErrorCode build_indices(MBRange &surfs, MBRange &vols);
     // build obb structure
   MBErrorCode build_obbs(MBRange &surfs, MBRange &vols);
@@ -204,12 +215,16 @@
     bool user_set;
+  std::vector<int> tallyList;
   std::string itos(int ival);
   MBInterface *mbImpl;
   MBOrientedBoxTreeTool obbTree;
   MBTag obbTag, geomTag, idTag, nameTag, senseTag;
+  // metadata
+  MBTag matTag, densTag, bcTag, impTag, tallyTag;
   Option options[6];
@@ -224,9 +239,10 @@
   double discardDistTol;
   double addDistTol;
   double facetingTolerance;
-  int moabMCNPSourceCell;
-  bool moabMCNPUseDistLimit;
+  int sourceCell;
+  bool useDistLimit;
   bool useCAD;
+  bool is_geom;
   double distanceLimit;
Modified: MOAB/trunk/tools/dagmc/main.cc
--- MOAB/trunk/tools/dagmc/main.cc	2009-07-14 14:57:15 UTC (rev 3005)
+++ MOAB/trunk/tools/dagmc/main.cc	2009-07-14 16:49:39 UTC (rev 3006)
@@ -42,6 +42,8 @@
   const char* input_name = 0;
   const char* output_name = 0;
+  char options[256];
   double dist_tol = 0.001, len_tol = 0.0;
   int norm_tol = 5;
   bool actuate_attribs = true;
@@ -112,21 +114,7 @@
   if (!output_name)
     usage(argv[0]);
-    // Initialize CGM
-  InitCGMA::initialize_cgma();
-  if (actuate_attribs) {
-    CGMApp::instance()->attrib_manager()->set_all_auto_read_flags( actuate_attribs );
-    CGMApp::instance()->attrib_manager()->set_all_auto_actuate_flags( actuate_attribs );
-    // Intitalize MOAB
-  MBCore moab;
-  MBInterface* iface = &moab;
-    // Get CGM file type
   if (!file_type) {
     file_type = get_geom_file_type( input_name );
     if (!file_type) {
@@ -135,8 +123,17 @@
-    // If CUB file, extract ACIS geometry
-  CubitStatus s;
+  sprintf(options,"CGM_ATTRIBS=%s;FACET_DISTANCE_TOLERANCE=%g;FACET_NORMAL_TOLERANCE=%d;MAX_FACET_EDGE_LENGTH=%g;",
+	  actuate_attribs?"yes":"no",dist_tol,norm_tol,len_tol);
+    // Intitalize MOAB
+  MBCore moab;
+  MBInterface* iface = &moab;
+  MBErrorCode rval;
+// If CUB file, extract ACIS geometry
   if (!strcmp( file_type, "CUBIT" )) {
     char* temp_name = tempnam( 0, "cgm" );
     if (!temp_name) {
@@ -158,36 +155,29 @@
       exit(2);
-    int rval = cub_file_type( cub_file, tmp_file, CUB_FILE_ACIS );
+    int crval = cub_file_type( cub_file, tmp_file, CUB_FILE_ACIS );
     fclose( cub_file );
     fclose( tmp_file );
-    if (rval) {
+    if (crval) {
       remove( temp_name );
       free( temp_name );
       exit(2);
-    s = GeometryQueryTool::instance()->import_solid_model( temp_name, "ACIS_SAT" );
+    rval = iface->load_file(temp_name,file_set,options,NULL,0,0);
     free( temp_name );
   else {
-    s = GeometryQueryTool::instance()->import_solid_model( input_name, file_type );
+    rval = iface->load_file(input_name,file_set,options,NULL,0,0);
     std::cerr << "Failed to read '" << input_name << "' of type '" << file_type << "'" << std::endl;
     exit(2);
-    // copy geometry facets into mesh database
-  if (!cgm2moab(iface, dist_tol, norm_tol,
-                len_tol, actuate_attribs)) {
-    exit(5);
     // write mesh database
-  MBErrorCode rval = iface->write_mesh( output_name );
+  rval = iface->write_mesh( output_name );
     std::cerr << "Failed to write '" << output_name << "'" << std::endl;
     exit(2);
