[MOAB-dev] r3004 - in MOAB/trunk: . parallel test/h5file tools tools/dagmc tools/iMesh tools/mbcoupler tools/qvdual
kraftche at cae.wisc.edu
Mon Jul 13 18:43:11 CDT 2009
Author: kraftche
Date: 2009-07-13 18:43:10 -0500 (Mon, 13 Jul 2009)
New Revision: 3004
Modified:
MOAB/trunk/DualTool.cpp
MOAB/trunk/MBCore.cpp
MOAB/trunk/MBMeshSet.cpp
MOAB/trunk/MBRange.cpp
MOAB/trunk/MBRange.hpp
MOAB/trunk/MBReadUtil.cpp
MOAB/trunk/MBSkinner.cpp
MOAB/trunk/MBTest.cpp
MOAB/trunk/MeshTopoUtil.cpp
MOAB/trunk/ReadCGM.cpp
MOAB/trunk/ReadGmsh.cpp
MOAB/trunk/ReadHDF5.cpp
MOAB/trunk/ReadNCDF.cpp
MOAB/trunk/TagServer.cpp
MOAB/trunk/TagTest.cpp
MOAB/trunk/Test_MBMeshSet.cpp
MOAB/trunk/Tqdcfr.cpp
MOAB/trunk/VtkTest.cpp
MOAB/trunk/WriteGmsh.cpp
MOAB/trunk/WriteHDF5.cpp
MOAB/trunk/WriteVtk.cpp
MOAB/trunk/cub_file_test.cc
MOAB/trunk/parallel/MBParallelComm.cpp
MOAB/trunk/parallel/ReadParallel.cpp
MOAB/trunk/parallel/WriteHDF5Parallel.cpp
MOAB/trunk/parallel/parallel_hdf5_test.cc
MOAB/trunk/parallel/parallel_unit_tests.cpp
MOAB/trunk/parallel/pcomm_unit.cpp
MOAB/trunk/test/h5file/h5varlen.cpp
MOAB/trunk/tools/convert.cpp
MOAB/trunk/tools/dagmc/DagMC.cpp
MOAB/trunk/tools/gsets.cc
MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp
MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp
MOAB/trunk/tools/qvdual/DrawDual.cpp
Log:
Remove MBRange::subtract and MBRange::intersect member functions with
functions in the top-level namespace: 'intersect' and 'subtract'. For
exaple, the rather ambiguous:
diff = from_this.subtract( some_range );
is now:
diff = subtract( from_this, some_range );
Modified: MOAB/trunk/DualTool.cpp
--- MOAB/trunk/DualTool.cpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/DualTool.cpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -916,7 +916,7 @@
// get the bridge adjacencies through higher dimension
result = mtu.get_bridge_adjacencies(this_ent, dim+1, dim, tmp_star); RR;
- tmp_range = star.subtract(tmp_star);
+ tmp_range = subtract( star, tmp_star);
for (MBRange::iterator rit = tmp_range.begin(); rit != tmp_range.end(); rit++) {
if (new_hyperplane_ents.find(*rit) != new_hyperplane_ents.end()) continue;
@@ -1343,7 +1343,7 @@
result = mbImpl->get_adjacencies(tcells, 0, false, verts);
if (MB_SUCCESS != result || verts.empty()) return 0;
- MBRange tmp_verts = other_verts.subtract(verts);
+ MBRange tmp_verts = subtract( other_verts, verts);
other_verts.swap(tmp_verts);
if (0 != last_v) other_verts.erase(last_v);
@@ -1582,11 +1582,11 @@
result = mbImpl->get_adjacencies(hexes, 2, 2, false, del_faces); RR;
assert(5 == del_faces.size());
std::copy(pcells[2].begin(), pcells[2].end(), mb_range_inserter(tmp_faces));
- tmp_faces = tmp_faces.subtract(del_faces);
+ tmp_faces = subtract( tmp_faces, del_faces);
del_faces.insert(*tmp_faces.rbegin());
result = mbImpl->get_adjacencies(tmp_faces, 0, false, tmp_verts); RR;
std::copy(pcells[0].begin(), pcells[0].end(), mb_range_inserter(del_verts));
- del_verts = del_verts.subtract(tmp_verts);
+ del_verts = subtract( del_verts, tmp_verts);
assert(4 == del_verts.size());
result = mbImpl->get_adjacencies(del_verts, 1, false, del_edges, MBInterface::UNION); RR;
assert(8 == del_edges.size());
@@ -1808,7 +1808,7 @@
result = mbImpl->get_adjacencies(&split_quads[i], 1, 1, false,
tmp_edges);
if (MB_SUCCESS != result) return result;
- tmp_edges = tmp_edges.subtract(common_edges);
+ tmp_edges = subtract( tmp_edges, common_edges);
assert(tmp_edges.size() == 1);
other_edges[i] = *tmp_edges.begin();
@@ -2079,7 +2079,7 @@
MBRange R1, R3;
result = mbImpl->get_adjacencies(&star_dp1[i][0], star_dp1[i].size(), 1, false,
R1, MBInterface::UNION); RR;
- R3 = R1.intersect(R2);
+ R3 = intersect( R1, R2);
for (int j = 0; j < 3; j++)
if (split_edges[j]) R3.erase(split_edges[j]);
addl_ents[i].merge(R3);
@@ -2392,7 +2392,7 @@
MBRange dum_connect, middle_connect;
result = mbImpl->get_connectivity(&middle_edge, 1, middle_connect); RR;
result = mbImpl->get_connectivity(&(*vit), 1, dum_connect); RR;
- dum_connect = dum_connect.subtract(middle_connect);
+ dum_connect = subtract( dum_connect, middle_connect);
if (dum_connect.size() != 1) {
std::cerr << "Trouble traversing chord." << std::endl;
return MB_FAILURE;
@@ -2407,7 +2407,7 @@
vit++;
dum_connect.clear();
return MB_FAILURE;
@@ -2993,7 +2993,7 @@
assert(quads.size() == 1);
result = mbImpl->get_adjacencies(&(*quads.begin()), 1, 0, false, tmp_verts); RR;
- tmp_verts = tmp_verts.subtract(start_verts);
+ tmp_verts = subtract( tmp_verts, start_verts);
assert(1 == tmp_verts.size());
connects[3].push_back(*tmp_verts.begin());
Modified: MOAB/trunk/MBCore.cpp
--- MOAB/trunk/MBCore.cpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/MBCore.cpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -1352,7 +1352,7 @@
return MB_SUCCESS;
else if (!entities.empty() && MBInterface::INTERSECT == condition) {
- entities = entities.intersect(tmp_range);
+ entities = intersect( entities, tmp_range);
if (entities.empty()) return MB_SUCCESS;
tmp_range = entities;
Modified: MOAB/trunk/MBMeshSet.cpp
--- MOAB/trunk/MBMeshSet.cpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/MBMeshSet.cpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -998,7 +998,7 @@
if (MB_SUCCESS != rval)
return rval;
rval = other->get_entities(other_ents);
- return remove_entities( my_ents.subtract(other_ents), my_handle, adj );
+ return remove_entities( ::subtract(my_ents, other_ents), my_handle, adj );
Modified: MOAB/trunk/MBRange.cpp
--- MOAB/trunk/MBRange.cpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/MBRange.cpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -590,16 +590,17 @@
// intersect two ranges, placing the results in the return range
#define MAX(a,b) (a < b ? b : a)
#define MIN(a,b) (a > b ? b : a)
-MBRange MBRange::intersect(const MBRange &range2) const
+MBRange intersect(const MBRange &range1, const MBRange &range2)
- pair_iterator r_it[2] = {pair_iterator(begin()), pair_iterator(range2.begin())};
+ MBRange::const_pair_iterator r_it[2] = { range1.const_pair_begin(),
+ range2.const_pair_begin() };
MBEntityHandle low_it, high_it;
MBRange lhs;
// terminate the while loop when at least one "start" iterator is at the
// end of the list
- while (r_it[0] != end() && r_it[1] != range2.end()) {
+ while (r_it[0] != range1.end() && r_it[1] != range2.end()) {
if (r_it[0]->second < r_it[1]->first)
// 1st subrange completely below 2nd subrange
@@ -625,58 +626,58 @@
return lhs;
-MBRange MBRange::subtract(const MBRange &range2) const
+MBRange subtract(const MBRange &range1, const MBRange &range2)
const bool braindead = false;
if (braindead) {
// brain-dead implementation right now
- MBRange res = *this;
+ MBRange res( range1 );
for (MBRange::const_iterator rit = range2.begin(); rit != range2.end(); rit++)
res.erase(*rit);
return res;
else {
- MBRange lhs = *this;
+ MBRange lhs( range1 );
- pair_iterator r_it[2] = {pair_iterator(lhs.begin()),
- pair_iterator(range2.begin())};
+ MBRange::pair_iterator r_it0 = lhs.pair_begin();
+ MBRange::const_pair_iterator r_it1 = range2.const_pair_begin();
// end of the list
- while (r_it[0] != lhs.end() && r_it[1] != range2.end()) {
+ while (r_it0 != lhs.end() && r_it1 != range2.end()) {
// case a: pair wholly within subtracted pair
- if (r_it[0]->first >= r_it[1]->first && r_it[0]->second <= r_it[1]->second) {
- PairNode *rtmp = r_it[0].mNode;
- r_it[0]++;
+ if (r_it0->first >= r_it1->first && r_it0->second <= r_it1->second) {
+ MBRange::PairNode *rtmp = r_it0.node();
+ r_it0++;
lhs.delete_pair_node(rtmp);
// case b: pair overlaps upper part of subtracted pair
- else if (r_it[0]->first <= r_it[1]->second &&
- r_it[0]->first >= r_it[1]->first) {
- r_it[0]->first = r_it[1]->second + 1;
- r_it[1]++;
+ else if (r_it0->first <= r_it1->second &&
+ r_it0->first >= r_it1->first) {
+ r_it0->first = r_it1->second + 1;
+ r_it1++;
// case c: pair overlaps lower part of subtracted pair
- else if (r_it[0]->second >= r_it[1]->first &&
- r_it[0]->second <= r_it[1]->second) {
- r_it[0]->second = r_it[1]->first - 1;
- r_it[0]++;
+ else if (r_it0->second >= r_it1->first &&
+ r_it0->second <= r_it1->second) {
+ r_it0->second = r_it1->first - 1;
+ r_it0++;
// case d: pair completely surrounds subtracted pair
- else if (r_it[0]->first < r_it[1]->first &&
- r_it[0]->second > r_it[1]->second) {
- PairNode* new_node = alloc_pair(r_it[0].mNode, r_it[0].mNode->mPrev,
- r_it[0]->first, r_it[1]->first - 1);
+ else if (r_it0->first < r_it1->first &&
+ r_it0->second > r_it1->second) {
+ MBRange::PairNode* new_node = alloc_pair(r_it0.node(), r_it0.node()->mPrev,
+ r_it0->first, r_it1->first - 1);
new_node->mPrev->mNext = new_node->mNext->mPrev = new_node;
- r_it[0].mNode->first = r_it[1]->second+1;
- r_it[1]++;
+ r_it0.node()->first = r_it1->second+1;
+ r_it1++;
else {
- while (r_it[0]->second < r_it[1]->first && r_it[0] != lhs.end()) r_it[0]++;
- if (r_it[0] == lhs.end()) break;
- while (r_it[1]->second < r_it[0]->first && r_it[1] != range2.end()) r_it[1]++;
+ while (r_it0->second < r_it1->first && r_it0 != lhs.end()) r_it0++;
+ if (r_it0 == lhs.end()) break;
+ while (r_it1->second < r_it0->first && r_it1 != range2.end()) r_it1++;
Modified: MOAB/trunk/MBRange.hpp
--- MOAB/trunk/MBRange.hpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/MBRange.hpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -197,12 +197,9 @@
typedef const_iterator iterator;
typedef const_reverse_iterator reverse_iterator;
- //! intersect two ranges, placing the results in the return range
- MBRange intersect(const MBRange &range2) const;
+ friend MBRange intersect( const MBRange&, const MBRange& );
+ friend MBRange subtract( const MBRange&, const MBRange& );
- //! subtract range2 from this, placing the results in the return range
- MBRange subtract(const MBRange &range2) const;
//! for short hand notation, lets typedef the
//! container class that holds the ranges
typedef MBEntityHandle value_type;
@@ -403,6 +400,8 @@
return mNode != other.mNode;
+ PairNode* node() { return mNode; }
private:
@@ -653,6 +652,18 @@
const_pair_iterator const_pair_end() const { return const_pair_iterator( &mHead ); }
+ //! intersect two ranges, placing the results in the return range
+MBRange intersect( const MBRange&, const MBRange& );
+ //! subtract range2 from this, placing the results in the return range
+MBRange subtract( const MBRange& from, const MBRange& );
+ //! unite two ranges, placing the results in the return range
+inline MBRange unite( const MBRange& r1, const MBRange& r2 )
+ { MBRange r(r1); r.merge(r2); return r; }
inline MBRange::const_iterator
operator+( const MBRange::const_iterator& it, MBEntityID step )
{ MBRange::const_iterator tmp(it); return tmp += step; }
Modified: MOAB/trunk/MBReadUtil.cpp
--- MOAB/trunk/MBReadUtil.cpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/MBReadUtil.cpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -239,7 +239,7 @@
tmp_ents.clear();
result = mMB->get_entities_by_handle(*rit, tmp_ents, true); RR;
- MBRange tmp_ents2 = tmp_ents.intersect(related_ents);
+ MBRange tmp_ents2 = intersect( tmp_ents, related_ents);
// if the intersection is not empty, set is related
if (!tmp_ents2.empty()) related_ents.insert(*rit);
Modified: MOAB/trunk/MBSkinner.cpp
--- MOAB/trunk/MBSkinner.cpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/MBSkinner.cpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -312,7 +312,7 @@
result = thisMB->get_adjacencies(sub_conn, num_sub_nodes, source_dim, false,
dum_elems);
- dum_elems = dum_elems.intersect( source_entities );
+ dum_elems = intersect( dum_elems, source_entities );
if (dum_elems.empty()) {
assert(false); // should never happen
return MB_FAILURE;
Modified: MOAB/trunk/MBTest.cpp
--- MOAB/trunk/MBTest.cpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/MBTest.cpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -4775,7 +4775,7 @@
r2.insert(h5, h10);
r2.insert(h15, h20);
- rhs = r1.intersect(r2);
+ rhs = intersect( r1, r2);
if (rhs.size() != 3) {
result = MB_FAILURE;
std::cout << "Range test equal start/end failed." << std::endl;
@@ -4785,7 +4785,7 @@
r1.clear(); r2.clear(); rhs.clear();
r1.insert(h1, h5); r1.insert(h10, h20);
r2.insert(h1, h5); r2.insert(h10, h20);
if (rhs.size() != r1.size() || rhs.size() != r2.size()) {
std::cout << "Range test identical ranges failed." << std::endl;
@@ -4795,7 +4795,7 @@
r1.insert(h1, h4); r1.insert(h10, h15);
r2.insert(h5, h9); r2.insert(h16, h20);
if (rhs.size() != 0) {
std::cout << "Range test off by one failed." << std::endl;
@@ -4805,7 +4805,7 @@
r1.insert(h1, h20);
r2.insert(h5, h10);
if (rhs.size() != r2.size()) {
std::cout << "Range test interior failed." << std::endl;
@@ -4815,7 +4815,7 @@
r1.insert(h1, h10);
r2.insert(h5, h20);
if (rhs.size() != h10-h5+1) {
std::cout << "Range test half-above failed." << std::endl;
@@ -4825,7 +4825,7 @@
r1.insert(h5, h20);
r2.insert(h1, h10);
std::cout << "Range test half-below failed." << std::endl;
@@ -4945,7 +4945,7 @@
r1.insert(h4);
r1.insert(h5);
r2.insert(h4);
- MBRange r3 = r1.subtract(r2);
+ MBRange r3 = subtract( r1, r2);
if (r3.size() != 2 ||
r3.find(h1) == r3.end() ||
r3.find(h5) == r3.end() ||
@@ -4961,7 +4961,7 @@
r1.insert(h1);
r1.insert(h4);
r1.insert(h5);
- r3 = r1.subtract(r2);
+ r3 = subtract( r1, r2);
if (r3.size() != 3 ||
r3.find(h4) == r3.end() ||
Modified: MOAB/trunk/MeshTopoUtil.cpp
--- MOAB/trunk/MeshTopoUtil.cpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/MeshTopoUtil.cpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -227,7 +227,7 @@
result = mbImpl->get_adjacencies(*star_candidates_dp1, dim+1, false,
from_ents, MBInterface::UNION);
- to_ents = to_ents.intersect(from_ents);
+ to_ents = intersect( to_ents, from_ents);
if (!to_ents.empty()) next_entity = *to_ents.begin();
@@ -430,7 +430,7 @@
// subtract last_toents to get new_toents
if (nl < num_layers-1)
- new_toents = to_ents.subtract(last_toents);
+ new_toents = subtract( to_ents, last_toents);
return MB_SUCCESS;
@@ -742,8 +742,8 @@
result = mbImpl->get_adjacencies(&split_ent, 1, i, false, other_adjs,
- other_adjs = other_adjs.subtract(old_adjs);
- other_adjs = other_adjs.subtract(new_adjs);
+ other_adjs = subtract( other_adjs, old_adjs);
+ other_adjs = subtract( other_adjs, new_adjs);
for (MBRange::iterator rit1 = other_adjs.begin(); rit1 != other_adjs.end(); rit1++) {
// find an adjacent lower-dimensional entity in old_ or new_ adjs
bool found = false;
Modified: MOAB/trunk/ReadCGM.cpp
--- MOAB/trunk/ReadCGM.cpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/ReadCGM.cpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -551,7 +551,7 @@
rval = mdbImpl->get_entities_by_handle(0, loaded_range);
if (MB_FAILURE == rval) return rval;
rval = mdbImpl->get_entities_by_handle(0, init_range);
- loaded_range = loaded_range.subtract(init_range);
+ loaded_range = subtract( loaded_range, init_range);
rval = mdbImpl->add_entities(mCurrentMeshHandle, loaded_range);
Modified: MOAB/trunk/ReadGmsh.cpp
--- MOAB/trunk/ReadGmsh.cpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/ReadGmsh.cpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -519,7 +519,7 @@
// Don't use existing geometry sets (from some other file)
if (1 == set_type) // geometry
- sets = sets.intersect( geomSets );
+ sets = intersect( sets, geomSets );
// Get set handle
MBEntityHandle set;
Modified: MOAB/trunk/ReadHDF5.cpp
--- MOAB/trunk/ReadHDF5.cpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/ReadHDF5.cpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -1213,7 +1213,7 @@
MBRange subset;
intersect( fileInfo->elems[i].desc, elem_ids, subset );
if (!subset.empty()) {
- elem_ids.subtract( subset );
+ subtract( elem_ids, subset );
rval = read_elems( fileInfo->elems[i], subset );
return error(rval);
@@ -1261,9 +1261,9 @@
all_elems.erase( all_elems.lower_bound( MBCN::TypeDimensionMap[max_dim].first ), all_elems.end() );
// remove explicit elements < max_dim
if (!explicit_elems[1].empty() && max_dim > 1)
- all_elems = all_elems.subtract( explicit_elems[1] );
+ all_elems = subtract( all_elems, explicit_elems[1] );
if (!explicit_elems[2].empty() && max_dim > 2)
- all_elems = all_elems.subtract( explicit_elems[2] );
+ all_elems = subtract( all_elems, explicit_elems[2] );
// remove any elements that are adjacent to some explicity specified element.
if (max_dim > 1 && !explicit_elems[2].empty()) {
@@ -1272,7 +1272,7 @@
return error(rval);
if (!adj.empty())
- all_elems = all_elems.subtract( adj );
+ all_elems = subtract( all_elems, adj );
if (max_dim == 3) {
MBRange adj;
@@ -1280,13 +1280,13 @@
return error(rval);
if (!adj.empty())
adj.clear();
rval = iFace->get_adjacencies( explicit_elems[3], 2, false, adj, MBInterface::UNION );
return error(rval);
if (!adj.empty())
// now delete anything remaining in all_elems
@@ -1462,7 +1462,7 @@
break;
- new_children = children.subtract( sets_in_out );
+ new_children = subtract( children, sets_in_out );
sets_in_out.merge( new_children );
} while (!new_children.empty());
@@ -1878,7 +1878,7 @@
#endif
// things will get messed up if this isn't true
- assert( ranged_ids_in.subtract( file_ids ).empty() );
+ assert( subtract( ranged_ids_in, file_ids ).empty() );
assert( file_ids.front() >= (MBEntityHandle)start_id );
assert( file_ids.back() - start_id < (MBEntityHandle)entity_count );
Modified: MOAB/trunk/ReadNCDF.cpp
--- MOAB/trunk/ReadNCDF.cpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/ReadNCDF.cpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -509,7 +509,7 @@
MBRange loaded_range;
status = mdbImpl->get_entities_by_handle(0, loaded_range);
if (MB_FAILURE == status) return status;
- loaded_range = loaded_range.subtract(initRange);
+ loaded_range = subtract( loaded_range, initRange);
status = mdbImpl->add_entities(mCurrentMeshHandle, loaded_range);
@@ -780,7 +780,7 @@
if(mdbImpl->get_entities_by_type(0, MBENTITYSET, child_meshsets ) != MB_SUCCESS )
return MB_FAILURE;
- child_meshsets = child_meshsets.subtract(initRange);
+ child_meshsets = subtract( child_meshsets, initRange);
MBTag tag_handle;
@@ -1147,7 +1147,7 @@
if( mdbImpl->get_entities_by_handle(0, child_meshsets ) != MB_SUCCESS )
return MB_FAILURE;
MBRange::iterator iter, end_iter;
iter = child_meshsets.begin();
@@ -1295,7 +1295,7 @@
return MB_FAILURE;
Modified: MOAB/trunk/TagServer.cpp
--- MOAB/trunk/TagServer.cpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/TagServer.cpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -797,7 +797,7 @@
case MB_TAG_DENSE: {
MBRange temp;
result = sequenceManager->get_tagged_entities(id, type, temp);
- entities.merge( range.intersect(temp) );
+ entities.merge( intersect( range, temp) );
break;
case MB_TAG_BIT:
@@ -919,14 +919,14 @@
// if we're doing a running intersection and we're just starting and
// the list comes in empty, the 1st result is the start
if (0 == it && condition == MBInterface::INTERSECT && entities.empty()) {
- entities = temp1.intersect(range);
+ entities = intersect( temp1, range);
// else if we're doing a running intersection, intersect this result (temp1)
// with the running result (entities) into temp2, then move that to the running
// result (entities)
else if (condition == MBInterface::INTERSECT) {
- entities = entities.intersect(temp1);
+ entities = intersect( entities, temp1);
// also restrict the range at which we look; entities has already been
Modified: MOAB/trunk/TagTest.cpp
--- MOAB/trunk/TagTest.cpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/TagTest.cpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -390,7 +390,7 @@
handle_range.insert( mid+1, i->second );
- entities = entities.subtract( handle_range );
+ entities = subtract( entities, handle_range );
for (unsigned i = 0; i < handle_list.size(); ++i)
entities.erase( handle_list[i] );
@@ -1391,7 +1391,7 @@
Modified: MOAB/trunk/Test_MBMeshSet.cpp
--- MOAB/trunk/Test_MBMeshSet.cpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/Test_MBMeshSet.cpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -846,7 +846,7 @@
remove.insert( 190, 200 );
remove.insert( 210, 220 );
remove.insert( 230, 240 );
- range = range.subtract( remove );
+ range = subtract( range, remove );
contents.clear();
std::copy( range.begin(), range.end(), std::back_inserter(contents) );
@@ -953,13 +953,13 @@
rval = mb.unite_meshset( set1, set2 );
break;
case INTERSECT:
- tmp_range = set1_ents.intersect( set2_ents );
+ tmp_range = intersect( set1_ents, set2_ents );
expected.resize(tmp_range.size());
std::copy( tmp_range.begin(), tmp_range.end(), expected.begin() );
rval = mb.intersect_meshset( set1, set2 );
break;
case SUBTRACT:
- tmp_range = set1_ents.subtract( set2_ents );
+ tmp_range = subtract( set1_ents, set2_ents );
rval = mb.subtract_meshset( set1, set2 );
Modified: MOAB/trunk/Tqdcfr.cpp
--- MOAB/trunk/Tqdcfr.cpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/Tqdcfr.cpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -384,7 +384,7 @@
return result;
- after_ents = after_ents.subtract(beforeEnts);
+ after_ents = subtract( after_ents, beforeEnts);
result = mdbImpl->add_entities(mFileSet, after_ents);
return result;
@@ -1069,7 +1069,7 @@
MBRange vrange, tmp_range(dum_range);
result = mdbImpl->get_entities_by_type(0, MBVERTEX, vrange); RR;
if (!beforeEnts.empty()) tmp_range.merge(beforeEnts.subset_by_type(MBVERTEX));
- vrange = vrange.subtract(tmp_range);
+ vrange = subtract( vrange, tmp_range);
// compute the max cid; map is indexed by cid, so size is max_cid+1
#define MAX(a,b) (a > b ? a : b)
#define MIN(a,b) (a < b ? a : b)
Modified: MOAB/trunk/VtkTest.cpp
--- MOAB/trunk/VtkTest.cpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/VtkTest.cpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -1335,7 +1335,7 @@
rval = moab.get_adjacencies( new_elems, 0, false, elem_verts, MBInterface::UNION );
MBCHECK(rval);
CHECK(elem_verts.size() == 6);
- MBRange free_verts( new_verts.subtract(elem_verts ) );
+ MBRange free_verts( subtract( new_verts, elem_verts ) );
CHECK(free_verts.size() == 1 );
double vcoords[3];
rval = moab.get_coords( free_verts, vcoords );
Modified: MOAB/trunk/WriteGmsh.cpp
--- MOAB/trunk/WriteGmsh.cpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/WriteGmsh.cpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -239,7 +239,7 @@
return rval;
- elems = elems.intersect( elements );
+ elems = intersect( elems, elements );
for (MBRange::iterator j = elems.begin(); j != elems.end(); ++j)
elem_sets[*j].set( s, id );
Modified: MOAB/trunk/WriteHDF5.cpp
--- MOAB/trunk/WriteHDF5.cpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/WriteHDF5.cpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -2092,19 +2092,19 @@
range.clear();
result = iFace->get_entities_by_type_and_tag( 0, e_iter->type, &handle, NULL, 1, range );
CHK_MB_ERR_0(result);
- td_iter->range.merge( range.intersect( e_iter->range ) );
+ td_iter->range.merge( intersect( range, e_iter->range ) );
range.clear();
result = iFace->get_entities_by_type_and_tag( 0, MBVERTEX, &handle, NULL, 1, range );
- td_iter->range.merge( range.intersect( nodeSet.range ) );
+ td_iter->range.merge( intersect( range, nodeSet.range ) );
range.clear();
result = iFace->get_entities_by_type_and_tag( 0, MBENTITYSET, &handle, NULL, 1, range );
- td_iter->range.merge( range.intersect( setSet.range ) );
+ td_iter->range.merge( intersect( range, setSet.range ) );
/* This breaks for variable-length tags, is slow, and is questionable.
Is it really better to not write the tag at all, as opposed to writing
Modified: MOAB/trunk/WriteVtk.cpp
--- MOAB/trunk/WriteVtk.cpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/WriteVtk.cpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -402,7 +402,7 @@
rval = mbImpl->get_entities_by_type_and_tag( 0, type, &*i, 0, 1, tmp_tagged );
return rval;
- tmp_tagged = tmp_tagged.intersect( entities );
+ tmp_tagged = intersect( tmp_tagged, entities );
tagged.merge( tmp_tagged );
Modified: MOAB/trunk/cub_file_test.cc
--- MOAB/trunk/cub_file_test.cc 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/cub_file_test.cc 2009-07-13 23:43:10 UTC (rev 3004)
@@ -705,7 +705,7 @@
tmp.clear();
rval = mb.get_adjacencies( ents, 0, false, tmp, MBInterface::UNION );
CHECK_ERR(rval);
- nodes = nodes.subtract( tmp );
+ nodes = subtract( nodes, tmp );
CHECK( nodes.empty() );
@@ -1058,7 +1058,7 @@
CHECK_ERR(rval);
CHECK( !file2_verts.empty() );
CHECK_EQUAL( file1_verts.size(), file2_verts.size() );
- CHECK( file1_verts.intersect( file2_verts ).empty() );
+ CHECK( intersect( file1_verts, file2_verts ).empty() );
// now check that we get the same number of elements from
// each file and that they are distinct
@@ -1070,7 +1070,7 @@
CHECK_ERR(rval);
CHECK( !file2_elems.empty() );
CHECK_EQUAL( file1_elems.size(), file2_elems.size() );
- CHECK( file1_elems.intersect( file2_elems ).empty() );
+ CHECK( intersect( file1_elems, file2_elems ).empty() );
// now check that the connectivity for each element is
// defined using the appropriate vertex instances
@@ -1080,8 +1080,8 @@
rval = mb.get_adjacencies( file2_elems, 0, false, file2_elem_verts, MBInterface::UNION );
CHECK_ERR(rval);
CHECK_EQUAL( file1_elem_verts.size(), file2_elem_verts.size() );
- CHECK( file1_elem_verts.intersect( file1_verts ) == file1_elem_verts );
- CHECK( file2_elem_verts.intersect( file2_verts ) == file2_elem_verts );
+ CHECK( intersect( file1_elem_verts, file1_verts ) == file1_elem_verts );
+ CHECK( intersect( file2_elem_verts, file2_verts ) == file2_elem_verts );
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/parallel/MBParallelComm.cpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -289,7 +289,7 @@
for (rit = entities[dim].begin(), i = 0; rit != entities[dim].end(); rit++, i++)
if (pstatus[i] & PSTATUS_NOT_OWNED)
dum_range.insert(*rit);
- entities[dim] = entities[dim].subtract(dum_range);
+ entities[dim] = subtract( entities[dim], dum_range);
local_num_elements[dim] = entities[dim].size();
@@ -2307,7 +2307,7 @@
MBRange tmp_range;
result = tagServer->get_entities(*tag_it, tmp_range);
RRA("Failed to get entities for tag in pack_tags.");
- tmp_range = tmp_range.intersect(whole_range);
+ tmp_range = intersect( tmp_range, whole_range);
if (tmp_range.empty()) continue;
@@ -3773,7 +3773,7 @@
buffProcs[ind], &tmp_range);
RRA("Couldn't filter on owner.");
if (!tmp_range.empty())
- sent_ents[ind] = sent_ents[ind].subtract(tmp_range);
+ sent_ents[ind] = subtract( sent_ents[ind], tmp_range);
allsent.merge(sent_ents[ind]);
@@ -4194,7 +4194,7 @@
if (tagServer->get_default_data_ref( *vit, ptr, size ) != MB_SUCCESS) {
MBRange tagged_ents;
tagServer->get_entities( *vit, tagged_ents );
- tag_ranges.push_back(tag_ents.intersect(tagged_ents));
+ tag_ranges.push_back( intersect( tag_ents, tagged_ents ) );
else {
tag_ranges.push_back(tag_ents);
@@ -5138,7 +5138,7 @@
rval = get_pstatus_entities(-1, 0, dum_range);
return rval;
- all_shared = all_shared.subtract(dum_range);
+ all_shared = subtract( all_shared, dum_range);
all_shared.erase(all_shared.upper_bound(MBPOLYHEDRON), all_shared.end());
assert(sharedEnts == all_shared);
Modified: MOAB/trunk/parallel/ReadParallel.cpp
--- MOAB/trunk/parallel/ReadParallel.cpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/parallel/ReadParallel.cpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -522,11 +522,11 @@
// get deletable entities by subtracting partition ents from file ents
- MBRange deletable_ents = file_ents.subtract(partition_ents);
+ MBRange deletable_ents = subtract( file_ents, partition_ents);
// cache deletable vs. keepable sets
- MBRange deletable_sets = all_sets.intersect(deletable_ents);
- MBRange keepable_sets = all_sets.subtract(deletable_sets);
+ MBRange deletable_sets = intersect( all_sets, deletable_ents);
+ MBRange keepable_sets = subtract( all_sets, deletable_sets);
if (debug) std::cout << "Removing deletable entities from keepable sets." << std::endl;
@@ -551,7 +551,7 @@
result = mbImpl->delete_entities(deletable_sets);
RR("Failure deleting sets in delete_nonlocal_entities.");
- deletable_ents = deletable_ents.subtract(deletable_sets);
+ deletable_ents = subtract( deletable_ents, deletable_sets);
if (debug && myPcomm->proc_config().proc_rank() == 0) {
std::cout << "Deletable entities: " << std::endl;
Modified: MOAB/trunk/parallel/WriteHDF5Parallel.cpp
--- MOAB/trunk/parallel/WriteHDF5Parallel.cpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/parallel/WriteHDF5Parallel.cpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -216,7 +216,7 @@
if (removed.size())
- MBRange tmp = from.subtract(removed);
+ MBRange tmp = subtract( from, removed);
from.swap( tmp );
@@ -316,7 +316,7 @@
result = myPcomm->filter_pstatus( nodeSet.range, PSTATUS_NOT_OWNED, PSTATUS_AND, -1, &nonowned);
return result;
- nodeSet.range = nodeSet.range.subtract(nonowned);
+ nodeSet.range = subtract( nodeSet.range, nonowned);
for (std::list<ExportSet>::iterator eiter = exportList.begin();
eiter != exportList.end(); ++eiter ) {
@@ -324,7 +324,7 @@
result = myPcomm->filter_pstatus( eiter->range, PSTATUS_NOT_OWNED, PSTATUS_AND, -1, &tmpset);
return result;
- eiter->range = eiter->range.subtract( tmpset );
+ eiter->range = subtract( eiter->range, tmpset );
nonowned.merge(tmpset);
@@ -333,7 +333,7 @@
// (on any processor.)
for (proc_iter i = interfaceMesh.begin(); i != interfaceMesh.end(); ++i)
if (i->first != myPcomm->proc_config().proc_rank())
- i->second = nonowned.intersect( i->second );
+ i->second = intersect( nonowned, i->second );
// For the 'interfaceMesh' list for this processor, just remove
// entities we aren't writing.
@@ -343,7 +343,7 @@
tmpset.merge( eiter->range );
MBRange& my_remote_mesh = interfaceMesh[myPcomm->proc_config().proc_rank()];
- my_remote_mesh = my_remote_mesh.intersect( tmpset );
+ my_remote_mesh = intersect( my_remote_mesh, tmpset );
// print some debug output summarizing what we've accomplished
printdebug("Remote mesh:\n");
@@ -483,6 +483,7 @@
std::vector<unsigned long>::iterator tag_off_iter = tag_counts.begin();
for (tag_iter = tagList.begin(); tag_iter != tagList.end(); ++tag_iter) {
int s;
+ assert(tag_off_iter < tag_counts.begin() + tag_counts.size());
*tag_off_iter = tag_iter->range.size();
++tag_off_iter;
if (MB_VARIABLE_DATA_LENGTH == iFace->tag_get_size( tag_iter->tag_id, s )) {
@@ -491,6 +492,7 @@
return rval;
*tag_off_iter = total_len;
assert(total_len == *tag_off_iter);
@@ -519,19 +521,26 @@
for (int i = 0; i < num_tags; ++i, ++tag_iter)
+ assert((unsigned)(2*i+1) < tag_counts.size());
tag_counts[2*i] = tag_counts[2*i+1] = 0;
unsigned long next_offset = 0;
unsigned long next_var_len_offset = 0;
for (unsigned int j = 0; j < myPcomm->proc_config().proc_size(); j++)
- unsigned long count = proc_tag_offsets[2*i + j*2*num_tags];
- proc_tag_offsets[2*i + j*2*num_tags] = next_offset;
+ unsigned idx = 2*i + j*2*num_tags;
+ assert(idx < proc_tag_offsets.size());
+ unsigned long count = proc_tag_offsets[idx];
+ proc_tag_offsets[idx] = next_offset;
next_offset += count;
+ assert((unsigned)(2*i) < tag_counts.size());
tag_counts[2*i] += count;
- count = proc_tag_offsets[2*i + 1 + j*2*num_tags];
- proc_tag_offsets[2*i + 1 + j*2*num_tags] = next_var_len_offset;
+ ++idx;
+ count = proc_tag_offsets[idx];
+ proc_tag_offsets[idx] = next_var_len_offset;
next_var_len_offset += count;
+ assert((unsigned)(2*i + 1) < tag_counts.size());
tag_counts[2*i + 1] += count;
@@ -560,6 +569,7 @@
tag_iter->offset = tag_offsets[2*i];
tag_iter->write = tag_counts[2*i] > 0;
tag_iter->varDataOffset = tag_offsets[2*i + 1];
@@ -1115,7 +1125,7 @@
2,
data.range );
if (rval != MB_SUCCESS) return rval;
- MBRange tmp = data.range.intersect( setSet.range );
+ MBRange tmp = intersect( data.range, setSet.range );
data.range.swap( tmp );
range_remove( setSet.range, data.range );
@@ -1405,14 +1415,14 @@
MBRange& range )
MBRange result;
- result.merge( range.intersect( nodeSet.range ) );
- result.merge( range.intersect( setSet.range ) );
+ result.merge( intersect( range, nodeSet.range ) );
+ result.merge( intersect( range, setSet.range ) );
- result.merge( range.intersect( eiter->range ) );
+ result.merge( intersect( range, eiter->range ) );
- //result.merge( range.intersect( myParallelSets ) );
+ //result.merge( intersect( range, myParallelSets ) );
MBRange sets;
int junk;
sets.merge( MBRange::lower_bound( range.begin(), range.end(), CREATE_HANDLE(MBENTITYSET, 0, junk )), range.end() );
@@ -1424,9 +1434,9 @@
void WriteHDF5Parallel::remove_remote_sets( MBEntityHandle relative,
MBRange& range )
- MBRange result( range.intersect( setSet.range ) );
- MBRange remaining( range.subtract( result ) );
+ MBRange result( intersect( range, setSet.range ) );
+ //result.merge( intersect( range, yParallelSets ) );
+ MBRange remaining( subtract( range, result ) );
for(MBRange::iterator i = remaining.begin(); i != remaining.end(); ++i)
Modified: MOAB/trunk/parallel/parallel_hdf5_test.cc
--- MOAB/trunk/parallel/parallel_hdf5_test.cc 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/parallel/parallel_hdf5_test.cc 2009-07-13 23:43:10 UTC (rev 3004)
@@ -125,7 +125,7 @@
for (MBRange::const_iterator j = children.begin(); j != children.end(); ++j) {
tmp_entities.clear();
rval = moab.get_entities_by_handle( *j, tmp_entities ); CHECK_ERR(rval);
- diff = entities.subtract( tmp_entities );
+ diff = subtract( entities, tmp_entities );
entities.swap( diff );
Modified: MOAB/trunk/parallel/parallel_unit_tests.cpp
--- MOAB/trunk/parallel/parallel_unit_tests.cpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/parallel/parallel_unit_tests.cpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -291,7 +291,7 @@
for (MBRange::iterator i = children.begin(); i != children.end(); ++i) {
child_ents.clear();
rval = get_set_contents( moab, *i, type, child_ents ); CHKERR(rval);
- tmp_range = contents_out.subtract( child_ents );
+ tmp_range = subtract( contents_out, child_ents );
contents_out.swap( tmp_range );
@@ -619,7 +619,7 @@
rval = moab.get_adjacencies( adj_proc_ents, d, false, tmprange, MBInterface::UNION );
CHKERR(rval);
- adj_proc_ents.merge( tmprange.subtract( all_iface_ents ) );
+ adj_proc_ents.merge( subtract( tmprange, all_iface_ents ) );
// get adjacent entities
MBRange iface_ghosts, iface_ents;
@@ -632,7 +632,7 @@
// intersect with entities in adjacent partitions
- ghosts.merge( iface_ghosts.intersect( adj_proc_ents ) );
+ ghosts.merge( intersect( iface_ghosts, adj_proc_ents ) );
// get ids
Modified: MOAB/trunk/parallel/pcomm_unit.cpp
--- MOAB/trunk/parallel/pcomm_unit.cpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/parallel/pcomm_unit.cpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -98,7 +98,7 @@
// get the necessary vertices too
MBRange tmp_range = entities.subset_by_type(MBENTITYSET);
- entities = entities.subtract(tmp_range);
+ entities = subtract( entities, tmp_range);
rval = moab.get_adjacencies(entities, 0, false, entities, MBInterface::UNION);
CHECK_ERR(rval);
entities.merge(tmp_range);
Modified: MOAB/trunk/test/h5file/h5varlen.cpp
--- MOAB/trunk/test/h5file/h5varlen.cpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/test/h5file/h5varlen.cpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -131,7 +131,7 @@
// remove sets created during read/write process
MBRange sets;
mb2.get_entities_by_type( 0, MBENTITYSET, sets );
- entities = entities.subtract(sets);
+ entities = subtract( entities, sets);
for (MBRange::const_iterator i = entities.begin(); i != entities.end(); ++i) {
// get data
const void* ptrarr[] = { NULL };
Modified: MOAB/trunk/tools/convert.cpp
--- MOAB/trunk/tools/convert.cpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/tools/convert.cpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -459,7 +459,7 @@
dead_entities.merge( empty_sets );
MBRange tmp_range;
remove_entities_from_sets( gMB, empty_sets, tmp_range );
- empty_sets = tmp_range.subtract( dead_entities );
+ empty_sets = subtract( tmp_range, dead_entities );
// Destroy dead entities
result = gMB->delete_entities( dead_entities );
@@ -752,7 +752,7 @@
for (MBRange::iterator i = sets.begin(); i != sets.end(); ++i) {
MBRange set_contents;
gMB->get_entities_by_handle( *i, set_contents, false );
- set_contents = set_contents.intersect( dead_entities );
+ set_contents = intersect( set_contents, dead_entities );
gMB->remove_entities( *i, set_contents );
set_contents.clear();
Modified: MOAB/trunk/tools/dagmc/DagMC.cpp
--- MOAB/trunk/tools/dagmc/DagMC.cpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/tools/dagmc/DagMC.cpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -1101,7 +1101,7 @@
else {
// Get the volumes in the current group
- MBRange grp_vols = grp_sets.intersect(vols_save);
+ MBRange grp_vols = intersect( grp_sets, vols_save);
for (MBRange::iterator rit = grp_vols.begin();
rit != grp_vols.end(); rit++) {
MBEntityHandle vol = *rit;
@@ -1121,7 +1121,7 @@
else
bc_id = 2;
// Get the surfaces in the current group
- MBRange grp_faces = grp_sets.intersect(surfs_save);
+ MBRange grp_faces = intersect( grp_sets, surfs_save);
for (MBRange::iterator rit = grp_faces.begin(); rit != grp_faces.end(); rit++) {
MBEntityHandle surf = *rit;
int surf_num = index_by_handle(surf);
@@ -1141,7 +1141,7 @@
const char *cbc_id = bc_str.c_str();
bc_id = -1*atoi(cbc_id);
@@ -1152,7 +1152,7 @@
else if ((grp_names[0].find("graveyard",0)==0)||(grp_names[0].find("outside_world",0)==0)
||(grp_names[0].find("rest_of_world",0)==0)) {
for (MBRange::iterator rit = grp_vols.begin(); rit != grp_vols.end(); rit++) {
int vol_num = index_by_handle(vol);
@@ -1312,7 +1312,7 @@
MBErrorCode result = moab_instance()->get_entities_by_type(group, MBENTITYSET, grp_sets);
if (MB_SUCCESS != result) continue;
if ((tidx == 1) || (tidx == 2)) {
int jtal = get_entity_id(*rit);
std::stringstream spos1;
@@ -1326,7 +1326,7 @@
else if ((tidx == 4) || ((tidx >= 6) && (tidx <= 8))) {
Modified: MOAB/trunk/tools/gsets.cc
--- MOAB/trunk/tools/gsets.cc 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/tools/gsets.cc 2009-07-13 23:43:10 UTC (rev 3004)
@@ -156,7 +156,7 @@
result_sets.clear();
mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &tag, &tag_val, 1, result_sets );
- result_sets = result_sets.subtract( curr_sets );
+ result_sets = subtract( result_sets, curr_sets );
curr_sets.merge( result_sets );
@@ -203,7 +203,7 @@
if (printAnonSets) {
mb.get_entities_by_type( 0, MBENTITYSET, other_sets );
- MBRange xsect = other_sets.subtract( sets );
+ MBRange xsect = subtract( other_sets, sets );
sets.swap(other_sets);
other_sets.swap(xsect);
@@ -257,7 +257,7 @@
MBRange parents;
mb.get_parent_meshsets( *i, parents );
- parents = parents.intersect( sets );
+ parents = intersect( parents, sets );
for (MBRange::iterator j = parents.begin(); j != parents.end(); ++j) {
const char* linklabel = 0;
@@ -276,7 +276,7 @@
MBRange contained;
mb.get_entities_by_type(*i, MBENTITYSET, contained );
- contained = contained.intersect( sets );
+ contained = intersect( contained, sets );
for (MBRange::iterator j = contained.begin(); j != contained.end(); ++j)
dot_down_link( s, *i, *j, dashed );
Modified: MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -254,7 +254,7 @@
CHKERR(rval);
rval = get_entities( MBI, itaps_cast<MBEntityHandle>(set2), type, topo, r2 );
CHKERR(rval);
- result.merge( r1.intersect(r2) );
+ result.merge( intersect( r1, r2) );
RETURN (iBase_SUCCESS);
Modified: MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp
--- MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -268,7 +268,7 @@
// then get non-owned verts and subtract
result = pcs[1]->get_pstatus_entities(0, PSTATUS_NOT_OWNED, tmp_verts);
PRINT_LAST_ERROR;
- targ_verts = targ_verts.subtract(tmp_verts);
+ targ_verts = subtract( targ_verts, tmp_verts);
// get position of these entities; these are the target points
std::vector<double> vpos(3*targ_verts.size());
Modified: MOAB/trunk/tools/qvdual/DrawDual.cpp
--- MOAB/trunk/tools/qvdual/DrawDual.cpp 2009-07-13 23:42:27 UTC (rev 3003)
+++ MOAB/trunk/tools/qvdual/DrawDual.cpp 2009-07-13 23:43:10 UTC (rev 3004)
@@ -678,8 +678,8 @@
MBRange adj_2cells;
result = MBI->get_connectivity(tcell1, connect, num_connect); RR;
result = MBI->get_adjacencies(connect, num_connect, 2, false, adj_2cells); RR;
- adj_2cells = degen_2cells.intersect(adj_2cells);
- if (!adj_2cells.empty()) degen_2cells = degen_2cells.subtract(adj_2cells);
+ adj_2cells = intersect( degen_2cells, adj_2cells);
+ if (!adj_2cells.empty()) degen_2cells = subtract( degen_2cells, adj_2cells);
// ok, have all the adjacent degen 2cells; get the 1cells
MBRange adj_1cells;
@@ -736,7 +736,7 @@
// get the other 2cell
MBRange dum = dcells;
result = MBI->get_adjacencies(&(*rit), 1, 2, false, dum);
- dum = dum.subtract(adj_2cells);
+ dum = subtract( dum, adj_2cells);
assert(1 == dum.size());
// get the vertices and points of them, and average their positions
const MBEntityHandle *connect2;
@@ -777,7 +777,7 @@
const MBEntityHandle *connect;
@@ -818,7 +818,7 @@
// check that 1cells are in proper order, i.e. they share 2cell with adj 1cell
MBRange dum;
result = MBI->get_adjacencies(&edges[0], 2, 2, false, dum); RR;
- dum = dum.intersect(adj_2cells);
+ dum = intersect( dum, adj_2cells);
if (dum.empty()) {
// not adjacent - switch list order
MBEntityHandle dum_h = edges[1];
@@ -1088,7 +1088,7 @@
result = MBI->get_adjacencies(tmp_verts, 1, false, shared_edges); RR;
if (shared_edges.size() > 1) {
// filter for ones in this cell
- shared_edges = shared_edges.intersect(cell_edges);
+ shared_edges = intersect( shared_edges, cell_edges);
assert(!shared_edges.empty());
// get the mid-pt of this edge and include in list; if we're inside a 2-edge
// cell and we're on the 2nd vertex, take the 2nd edge
@@ -1679,7 +1679,7 @@
loops.push_back(loop_vs);
// ok, we've got them all; first, remove them from face_verts
- MBRange temp_range = new_face_verts.subtract(temp_face_verts);
+ MBRange temp_range = subtract( new_face_verts, temp_face_verts);
new_face_verts.swap(temp_range);
@@ -1811,7 +1811,7 @@
MBRange tmp_verts;
result = MBI->get_entities_by_dimension(chords[1], 1, tmp_range); RR;
result = MBI->get_adjacencies(tmp_range, 0, false, tmp_verts, MBInterface::UNION); RR;
- tmp_verts = tmp_verts.subtract(face_verts);
+ tmp_verts = subtract( tmp_verts, face_verts);
assert(!tmp_verts.empty());
face_verts.insert(*tmp_verts.begin());
@@ -2315,7 +2315,7 @@
const int num_its = 10;
- dverts = dverts.subtract(face_verts);
+ dverts = subtract( dverts, face_verts);
double tmp_coords[12];
MeshTopoUtil mtu(vtkMOABUtils::mbImpl);
@@ -2417,7 +2417,7 @@
MBRange int_verts, face_verts;
MBErrorCode result = vtkMOABUtils::dualTool->get_dual_entities(dual_surf, NULL, NULL,
&int_verts, &face_verts, NULL);
- int_verts = int_verts.subtract(face_verts);
+ int_verts = subtract( int_verts, face_verts);
// get vertices on sheet drawing for that sheet, and their positions
std::vector<MBEntityHandle> int_points(int_verts.size());
