[MOAB-dev] r3001 - MOAB/trunk
tautges at mcs.anl.gov
Mon Jul 13 17:59:18 CDT 2009
Author: tautges
Date: 2009-07-13 17:59:17 -0500 (Mon, 13 Jul 2009)
New Revision: 3001
Modified:
MOAB/trunk/MBCore.cpp
MOAB/trunk/MeshTopoUtil.cpp
Log:
2 smallish changes motivated by Milad:
- in MeshTopoUtil::get_bridge_entities, if to_dim is -1, then all
entities (of all dimensions) adjacent to bridge entities are returned,
rather than just entities of to_dim. This is a hack for now; probably
need extra arg requesting aentities too
- fixed MBCore::SideNumber to work correctly with structured mesh
Passes make check.
Modified: MOAB/trunk/MBCore.cpp
--- MOAB/trunk/MBCore.cpp 2009-07-13 22:40:04 UTC (rev 3000)
+++ MOAB/trunk/MBCore.cpp 2009-07-13 22:59:17 UTC (rev 3001)
@@ -2152,6 +2152,10 @@
const MBEntityHandle *parent_conn, *child_conn;
int num_parent_vertices, num_child_vertices;
MBErrorCode result = get_connectivity(parent, parent_conn, num_parent_vertices, true);
+ if (MB_NOT_IMPLEMENTED == result) {
+ static std::vector<MBEntityHandle> tmp_connect(MBCN::MAX_NODES_PER_ELEMENT);
+ result = get_connectivity(parent, parent_conn, num_parent_vertices, true, &tmp_connect);
if (MB_SUCCESS != result) return result;
if (TYPE_FROM_HANDLE(child) == MBVERTEX) {
Modified: MOAB/trunk/MeshTopoUtil.cpp
--- MOAB/trunk/MeshTopoUtil.cpp 2009-07-13 22:40:04 UTC (rev 3000)
+++ MOAB/trunk/MeshTopoUtil.cpp 2009-07-13 22:59:17 UTC (rev 3001)
@@ -412,10 +412,22 @@
// get to_dim adjacencies, merge into to_ents
last_toents = to_ents;
- result = mbImpl->get_adjacencies(new_bridges, to_dim, false, to_ents,
- MBInterface::UNION);
- if (MB_SUCCESS != result) return result;
+ if (-1 == to_dim) {
+ result = mbImpl->get_adjacencies(new_bridges, 3, false, to_ents,
+ MBInterface::UNION);
+ if (MB_SUCCESS != result) return result;
+ for (int d = 2; d >= 1; d--) {
+ result = mbImpl->get_adjacencies(to_ents, d, true, to_ents,
+ else {
+ result = mbImpl->get_adjacencies(new_bridges, to_dim, false, to_ents,
// subtract last_toents to get new_toents
if (nl < num_layers-1)
new_toents = to_ents.subtract(last_toents);
