[MOAB-dev] MOAB check for *AMD64* failed.
    Nightly Test
    kraftche at cae.wisc.edu
    Fri Jul 10 02:00:59 CDT 2009
Making check in mhdf
make[1]: Entering directory `/home/jason/moab/test/AMD64/mhdf'
/bin/sh ../libtool --tag=CC   --mode=compile cc -I../../src/mhdf/include  -I. -I../../src/mhdf -I..   -DVALGRIND -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -g -MT tags.lo -MD -MP -MF .deps/tags.Tpo -c -o tags.lo `test -f 'src/tags.c' || echo '../../src/mhdf/'`src/tags.c
 cc -I../../src/mhdf/include -I. -I../../src/mhdf -I.. -DVALGRIND -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -g -MT tags.lo -MD -MP -MF .deps/tags.Tpo -c ../../src/mhdf/src/tags.c -o tags.o
../../src/mhdf/src/tags.c: In function âget_attrib_array_length_handleâ:
../../src/mhdf/src/tags.c:759: error: âpermâ undeclared (first use in this function)
../../src/mhdf/src/tags.c:759: error: (Each undeclared identifier is reported only once
../../src/mhdf/src/tags.c:759: error: for each function it appears in.)
../../src/mhdf/src/tags.c: In function âmhdf_getTagInfoâ:
../../src/mhdf/src/tags.c:991: error: âpermâ undeclared (first use in this function)
make[1]: *** [tags.lo] Error 1
make[1]: Leaving directory `/home/jason/moab/test/AMD64/mhdf'
make: *** [check-recursive] Error 1
