[MOAB-dev] r2959 - MOAB/branches/parallel_ghosting/parallel
tautges at mcs.anl.gov
Mon Jun 22 12:55:39 CDT 2009
Author: tautges
Date: 2009-06-22 12:55:39 -0500 (Mon, 22 Jun 2009)
New Revision: 2959
Modified:
MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp
MOAB/branches/parallel_ghosting/parallel/MBParallelComm.hpp
MOAB/branches/parallel_ghosting/parallel/parallel_unit_tests.cpp
MOAB/branches/parallel_ghosting/parallel/pcomm_unit.cpp
Log:
One major bug in unpacking (listed first); lots of other code for
convenience and testing. 2d tests in pcomm_unit now runs, 3d does
not.
- in unpack_entities, keep ALL entities, even the ones matching an
existing entity, in a vector; these are referenced in later entities
in this same message, and this vector is different from the new
entities coming from this message
- for sending back remote handles, added L1p, L1hloc and L1hrem,
instead of just L1h, because sometimes we're sending to a proc for
which we don't know the handle on that proc; in that case, we put
the owning proc in L1p, and the owner proc handle in L1hrem
- lots of debugging of processing of sharing data
- wrote variants of several functions in MBPC, allowing a program to
test initialization (through exchange_ghost_cells and
resolve_shared_entities) based on a vector of MBPC's, rather than
calling in a parallel program; will facilitate future debugging of
parallel communication too
- created 2d and 3d tests and calling them from pcomm_unit
Modified: MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp
--- MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp 2009-06-22 17:13:38 UTC (rev 2958)
+++ MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp 2009-06-22 17:55:39 UTC (rev 2959)
@@ -119,6 +119,12 @@
dynamic_cast<MBCore*>(mbImpl)->get_error_handler()->set_last_error(tmp_str.c_str()); \
return result;}
+#define RRAI(i, a) if (MB_SUCCESS != result) { \
+ std::string tmp_str; i->get_last_error(tmp_str);\
+ tmp_str.append("\n"); tmp_str.append(a);\
+ dynamic_cast<MBCore*>(i)->get_error_handler()->set_last_error(tmp_str.c_str()); \
+ return result;}
/** Name of tag used to store MBParallelComm Index on mesh paritioning sets */
const char* PARTITIONING_PCOMM_TAG_NAME = "__PRTN_PCOMM";
@@ -430,12 +436,12 @@
if ((int)procConfig.proc_rank() != from_proc) {
- std::vector<std::vector<MBEntityHandle> > dum1;
+ std::vector<std::vector<MBEntityHandle> > dum1a, dum1b;
std::vector<std::vector<int> > dum1p;
std::vector<MBEntityHandle> dum2;
std::vector<unsigned int> dum3;
result = unpack_buffer(&buff[0], false, from_proc, -1,
- dum1, dum1p, dum2, dum2, dum3, entities);
+ dum1a, dum1b, dum1p, dum2, dum2, dum3, entities);
RRA("Failed to unpack buffer in broadcast_entities.");
@@ -501,7 +507,8 @@
const bool store_remote_handles,
const int from_proc,
const int ind,
- std::vector<std::vector<MBEntityHandle> > &L1h,
+ std::vector<std::vector<MBEntityHandle> > &L1hloc,
+ std::vector<std::vector<MBEntityHandle> > &L1hrem,
std::vector<std::vector<int> > &L1p,
std::vector<MBEntityHandle> &L2hloc,
std::vector<MBEntityHandle> &L2hrem,
@@ -515,7 +522,7 @@
#endif
MBErrorCode result;
result = unpack_entities(buff_ptr, store_remote_handles,
- ind, false, L1h, L1p, L2hloc, L2hrem, L2p, new_ents);
+ ind, false, L1hloc, L1hrem, L1p, L2hloc, L2hrem, L2p, new_ents);
RRA("Unpacking entities failed.");
#ifdef DEBUG_PACKING
std::cerr << "unpack_entities buffer space: " << buff_ptr - tmp_buff << " bytes." << std::endl;
@@ -643,7 +650,8 @@
const int to_proc,
const bool is_iface,
- std::vector<std::set<unsigned int> > *entprocs)
+ std::vector<std::set<unsigned int> > *entprocs,
+ MBRange *allsent)
// packed information:
// 1. # entities = E
@@ -653,6 +661,11 @@
// c. for p in P (handle for e on p) (Note1)
// 3. vertex/entity info
+ // get an estimate of the buffer size & pre-allocate buffer size
+ unsigned int buff_size = estimate_ents_buffer_size(entities,
+ store_remote_handles);
+ CHECK_BUFF_SPACE(buff, buff_ptr, buff_size);
MBWriteUtilIface *wu;
MBErrorCode result = mbImpl->query_interface(std::string("MBWriteUtilIface"),
reinterpret_cast<void**>(&wu));
@@ -692,7 +705,7 @@
for (rit = entities.begin(), i = 0;
rit != entities.end(); rit++, i++) {
result = build_sharedhps_list(*rit, pstatus_vals[i], sharedp_vals[i],
- (entprocs ? (*entprocs)[i] : dumprocs),
+ (entprocs ? (*entprocs)[allsent->index(*rit)] : dumprocs),
num_ents, tmp_procs, tmp_handles);
RRA("Failed to build sharedhps.");
@@ -707,7 +720,6 @@
// pack vertices
MBRange these_ents = entities.subset_by_type(MBVERTEX);
num_ents = these_ents.size();
- int buff_size;
if (num_ents) {
buff_size = 2*sizeof(int) + 3*num_ents*sizeof(double);
@@ -1085,7 +1097,8 @@
const int from_ind,
@@ -1111,8 +1124,8 @@
// o if !iface, save new handle on L1 for all sharing procs
// lists of handles/procs to return to sending/other procs
- // L1h[p]: handle pairs [h, h'], where h' is the local proc handle
- // and h is either the remote proc handle (if that is known) or
+ // L1hloc[p], L1hrem[p]: handle pairs [h, h'], where h is the local proc handle
+ // and h' is either the remote proc handle (if that is known) or
// the owner proc handle (otherwise);
// L1p[p]: indicates whether h is remote handle (= -1) or owner (rank of owner)
// L2hloc, L2hrem: local/remote handles for entities shared by > 2 procs;
@@ -1146,6 +1159,8 @@
buff_ptr += j * (sizeof(int)+sizeof(MBEntityHandle));
+ std::vector<MBEntityHandle> msg_ents;
while (!done) {
MBEntityType this_type = MBMAXTYPE;
@@ -1197,7 +1212,7 @@
buff_ptr += verts_per_entity * sizeof(MBEntityHandle);
// update connectivity to local handles
- result = get_local_handles(connect, verts_per_entity, new_ents);
+ result = get_local_handles(connect, verts_per_entity, msg_ents);
RRA("Couldn't get local handles.");
@@ -1247,18 +1262,19 @@
L2p.push_back(ps[0]);
- if (!is_iface) {
- assert("New entity shouldn't be in new_ents list already" &&
- new_ents.find(new_h) == new_ents.end());
- new_ents.insert(new_h);
created_here = true;
// take care of sharing data
+ // need to save entities found in order, for interpretation of
+ // later parts of this message
+ if (!is_iface) msg_ents.push_back(new_h);
+ if (created_here) new_ents.insert(new_h);
if (store_remote_handles) {
// update sharing data and pstatus, adjusting order if iface
@@ -1272,21 +1288,41 @@
for (j = 0; j < num_ps; j++) {
if (ps[j] == (int)procConfig.proc_rank()) continue;
int idx = get_buffers(ps[j]);
- if (idx == (int)L1h.size()) {
- L1h.resize(idx+1);
+ if (idx == (int)L1hloc.size()) {
+ L1hloc.resize(idx+1);
+ L1hrem.resize(idx+1);
L1p.resize(idx+1);
- if (!hs[j]) {
- assert(-1 != ps[0] && num_ps > 2);
- L1p[idx].push_back(ps[0]);
- L1h[idx].push_back(hs[0]);
+ // don't bother adding if it's already in the list
+ std::vector<MBEntityHandle>::iterator vit =
+ std::find(L1hloc[idx].begin(), L1hloc[idx].end(), new_h);
+ if (vit != L1hloc[idx].end()) {
+ // if it's in the list but remote handle isn't known but we know
+ // it, replace in the list
+ if (L1p[idx][vit-L1hloc[idx].begin()] != -1 && hs[j]) {
+ L1hrem[idx][vit-L1hloc[idx].begin()] = hs[j];
+ L1p[idx][vit-L1hloc[idx].begin()] = -1;
+ else continue;
else {
- L1p[idx].push_back(-1);
- L1h[idx].push_back(hs[j]);
+ if (!hs[j]) {
+ assert(-1 != ps[0] && num_ps > 2);
+ L1p[idx].push_back(ps[0]);
+ L1hrem[idx].push_back(hs[0]);
+ else {
+ assert("either this remote handle isn't in the remote list, or it's for another proc" &&
+ (std::find(L1hrem[idx].begin(), L1hrem[idx].end(), hs[j]) ==
+ L1hrem[idx].end() ||
+ L1p[idx][std::find(L1hrem[idx].begin(), L1hrem[idx].end(), hs[j]) -
+ L1hrem[idx].begin()] != -1));
+ L1p[idx].push_back(-1);
+ L1hrem[idx].push_back(hs[j]);
+ L1hloc[idx].push_back(new_h);
- L1h[idx].push_back(new_h);
@@ -1391,13 +1427,11 @@
MBErrorCode MBParallelComm::list_entities(const MBEntityHandle *ents, int num_ents)
if (NULL == ents && 0 == num_ents) {
- return mbImpl->list_entities(0, 0);
+ return list_entities(NULL, 0);
else if (NULL == ents || 0 == num_ents) {
- MBRange dum_ents;
- mbImpl->get_entities_by_handle(0, dum_ents);
- return list_entities(dum_ents);
+ return list_entities(sharedEnts);
unsigned char pstat;
@@ -1484,7 +1518,7 @@
num_exist = num_ps;
// if it's only one, hopefully I'm not there yet...
assert("I shouldn't be the only proc there." &&
- (1 != num_exist || ps[0] != procConfig.proc_rank()));
+ (1 != num_exist || ps[0] != (int)procConfig.proc_rank()));
changed = true;
else {
@@ -1530,7 +1564,7 @@
// if it's multi-shared and we created the entity in this unpack,
// local handle probably isn't in handle list yet
- if (add_pstat & PSTATUS_GHOST && num_exist > 2) {
+ if (num_exist > 2) {
idx = std::find(tag_ps, tag_ps+num_exist, procConfig.proc_rank()) - tag_ps;
assert(idx < (int) num_exist);
if (!tag_hs[idx])
@@ -1571,6 +1605,7 @@
tag_ps[0] = tag_ps[1];
tag_hs[0] = tag_hs[1];
+ assert(tag_ps[0] != -1 && tag_hs[0] != 0);
result = mbImpl->tag_set_data(sharedp_tag(), &new_h, 1, tag_ps);
RRA("Couldn't set sharedp tag.");
result = mbImpl->tag_set_data(sharedh_tag(), &new_h, 1, tag_hs);
@@ -1598,23 +1633,27 @@
if (pstat & PSTATUS_MULTISHARED) {
result = mbImpl->tag_get_data(sharedps_tag(), &entity, 1, ps);
RRA("Couldn't get sharedps tag.");
- result = mbImpl->tag_get_data(sharedhs_tag(), &entity, 1, hs);
- RRA("Couldn't get sharedhs tag.");
+ if (hs) {
+ result = mbImpl->tag_get_data(sharedhs_tag(), &entity, 1, hs);
+ RRA("Couldn't get sharedhs tag.");
num_ps = std::find(ps, ps+MAX_SHARING_PROCS, -1) - ps;
else if (pstat & PSTATUS_SHARED) {
result = mbImpl->tag_get_data(sharedp_tag(), &entity, 1, ps);
RRA("Couldn't get sharedp tag.");
- result = mbImpl->tag_get_data(sharedh_tag(), &entity, 1, hs);
- RRA("Couldn't get sharedh tag.");
+ if (hs) {
+ result = mbImpl->tag_get_data(sharedh_tag(), &entity, 1, hs);
+ RRA("Couldn't get sharedh tag.");
+ hs[1] = 0;
// initialize past end of data
ps[1] = -1;
- hs[1] = 0;
num_ps = 1;
else {
ps[0] = -1;
- hs[0] = 0;
+ if (hs) hs[0] = 0;
num_ps = 0;
@@ -1635,6 +1674,7 @@
std::vector<unsigned int> &L2p,
MBEntityHandle &new_h)
+ new_h = 0;
if (!is_iface && num_ps > 2) {
for (unsigned int i = 0; i < L2hrem.size(); i++) {
if (L2hrem[i] == owner_h && owner_p == (int) L2p[i]) {
@@ -1677,16 +1717,21 @@
MBErrorCode MBParallelComm::get_local_handles(MBEntityHandle *from_vec,
int num_ents,
- const MBRange &new_ents,
- std::vector<MBEntityHandle> *no_ents)
+ const MBRange &new_ents)
+ std::vector<MBEntityHandle> tmp_ents;
+ std::copy(new_ents.begin(), new_ents.end(), std::back_inserter(tmp_ents));
+ return get_local_handles(from_vec, num_ents, tmp_ents);
+MBErrorCode MBParallelComm::get_local_handles(MBEntityHandle *from_vec,
+ int num_ents,
+ const std::vector<MBEntityHandle> &new_ents)
for (int i = 0; i < num_ents; i++) {
if (TYPE_FROM_HANDLE(from_vec[i]) == MBMAXTYPE) {
assert(ID_FROM_HANDLE(from_vec[i]) < (int) new_ents.size());
- if (no_ents && i < (int)no_ents->size() && (*no_ents)[i])
- from_vec[i] = (*no_ents)[i];
- else
- from_vec[i] = new_ents[ID_FROM_HANDLE(from_vec[i])];
+ from_vec[i] = new_ents[ID_FROM_HANDLE(from_vec[i])];
@@ -2542,7 +2587,7 @@
RRA("Trouble tagging shared verts.");
// get entities shared by 1 or n procs
- result = tag_shared_ents(resolve_dim, shared_dim, shared_verts, skin_ents,
+ result = tag_shared_ents(resolve_dim, shared_dim, skin_ents,
proc_nranges);
RRA("Trouble tagging shared entities.");
@@ -2561,7 +2606,7 @@
// create the sets for each interface; store them as tags on
// the interface instance
MBRange iface_sets;
- result = create_interface_sets(proc_nranges, this_set, resolve_dim, shared_dim);
+ result = create_interface_sets(proc_nranges, resolve_dim, shared_dim);
RRA("Trouble creating iface sets.");
// establish comm procs and buffers for them
@@ -2590,6 +2635,99 @@
return result;
+MBErrorCode MBParallelComm::resolve_shared_ents(MBParallelComm **pc,
+ const unsigned int np,
+ const int part_dim)
+ std::vector<MBRange> verts(np);
+ int tot_verts = 0;
+ unsigned int p, i, j, v, vtot;
+ MBErrorCode rval;
+ for (p = 0; p < np; p++) {
+ MBSkinner skinner(pc[p]->get_moab());
+ MBRange part_ents, skin_ents;
+ rval = pc[p]->get_moab()->get_entities_by_dimension(0, part_dim, part_ents);
+ if (MB_SUCCESS != rval) return rval;
+ rval = skinner.find_skin(part_ents, skin_ents, skin_ents, true);
+ rval = pc[p]->get_moab()->get_adjacencies(skin_ents, 0, true, verts[p],
+ MBInterface::UNION);
+ tot_verts += verts[p].size();
+ tuple_list shared_ents;
+ tuple_list_init_max(&shared_ents, 2, 0, 1, 0, tot_verts);
+ i = 0; j = 0;
+ std::vector<int> gids;
+ MBRange::iterator rit;
+ MBTag gid_tag;
+ int dum_default = -1;
+ rval = pc[p]->get_moab()->tag_create(GLOBAL_ID_TAG_NAME,
+ sizeof(int), MB_TAG_DENSE,
+ MB_TYPE_INTEGER, gid_tag,
+ &dum_default, true);
+ gids.resize(verts[p].size());
+ rval = pc[p]->get_moab()->tag_get_data(gid_tag, verts[p], &gids[0]);
+ for (v = 0, rit = verts[p].begin(); v < gids.size(); v++, rit++) {
+ shared_ents.vi[i++] = gids[v];
+ shared_ents.vi[i++] = p;
+ shared_ents.vul[j] = *rit;
+ j++;
+ shared_ents.n++;
+ buffer sort_buffer;
+ buffer_init(&sort_buffer, vtot);
+ tuple_list_sort(&shared_ents, 0, &sort_buffer);
+ buffer_free(&sort_buffer);
+ j = 0; i = 0;
+ std::vector<MBEntityHandle> handles;
+ std::vector<int> procs;
+ while (i < shared_ents.n) {
+ handles.clear();
+ procs.clear();
+ // count & accumulate sharing procs
+ int this_gid = shared_ents.vi[j];
+ while (i < shared_ents.n && shared_ents.vi[j] == this_gid) {
+ j++;
+ procs.push_back( shared_ents.vi[j++] );
+ handles.push_back( shared_ents.vul[i++] );
+ if (1 == procs.size()) continue;
+ for (v = 0; v < procs.size(); v++) {
+ rval = pc[procs[v]]->update_remote_data(handles[v],
+ &procs[0], &handles[0], procs.size(),
+ PSTATUS_INTERFACE);
+ std::set<unsigned int> psets;
+ rval = pc[p]->create_interface_sets(part_dim, part_dim-1);
+ // establish comm procs and buffers for them
+ psets.clear();
+ rval = pc[p]->get_interface_procs(psets);
+ for (std::set<unsigned int>::iterator sit = psets.begin(); sit != psets.end(); sit++)
+ pc[p]->get_buffers(*sit);
+ return MB_SUCCESS;
MBErrorCode MBParallelComm::tag_iface_entities()
MBErrorCode result = MB_SUCCESS;
@@ -2685,8 +2823,46 @@
return MB_SUCCESS;
+MBErrorCode MBParallelComm::create_interface_sets(int resolve_dim, int shared_dim)
+ std::map<std::vector<int>, MBRange> proc_nranges;
+ // build up the list of shared entities
+ int procs[MAX_SHARING_PROCS];
+ MBEntityHandle handles[MAX_SHARING_PROCS];
+ MBErrorCode result;
+ int nprocs;
+ unsigned char pstat;
+ for (MBRange::iterator rit = sharedEnts.begin(); rit != sharedEnts.end(); rit++) {
+ if (shared_dim != -1 && mbImpl->dimension_from_handle(*rit) > shared_dim)
+ continue;
+ result = get_sharing_data(*rit, procs, handles, pstat, nprocs);
+ RRA("");
+ std::sort(procs, procs+nprocs);
+ std::vector<int> tmp_procs(procs, procs + nprocs);
+ proc_nranges[tmp_procs].insert(*rit);
+ MBSkinner skinner(mbImpl);
+ MBRange skin_ents[4];
+ result = mbImpl->get_entities_by_dimension(0, resolve_dim, skin_ents[resolve_dim]);
+ RRA("");
+ result = skinner.find_skin(skin_ents[resolve_dim], skin_ents[resolve_dim-1],
+ skin_ents[resolve_dim-1], true);
+ RRA("Failed to find skin.");
+ if (shared_dim > 1) {
+ result = mbImpl->get_adjacencies(skin_ents[resolve_dim-1], resolve_dim-2, true,
+ skin_ents[resolve_dim-2], MBInterface::UNION);
+ RRA("");
+ proc_nranges);
+ return create_interface_sets(proc_nranges, resolve_dim, shared_dim);
MBErrorCode MBParallelComm::create_interface_sets(std::map<std::vector<int>, MBRange> &proc_nranges,
- MBEntityHandle this_set,
if (proc_nranges.empty()) return MB_SUCCESS;
@@ -2730,6 +2906,7 @@
int min_proc = (mit->first)[0];
unsigned char pval = (PSTATUS_SHARED | PSTATUS_INTERFACE);
if (min_proc < (int) procConfig.proc_rank()) pval |= PSTATUS_NOT_OWNED;
+ if (mit->first.size() > 1) pval |= PSTATUS_MULTISHARED;
result = mbImpl->tag_set_data(pstatus_tag, &new_set, 1, &pval);
RRA("Failed to tag interface set with pstatus.");
@@ -2816,7 +2993,6 @@
MBErrorCode MBParallelComm::tag_shared_ents(int resolve_dim,
int shared_dim,
- tuple_list &shared_verts,
MBRange *skin_ents,
std::map<std::vector<int>, MBRange> &proc_nranges)
@@ -2956,7 +3132,8 @@
proc_nranges[sharing_procs].insert(this_ent);
- unsigned char share_flag = PSTATUS_SHARED, ms_flag = PSTATUS_MULTISHARED;
+ unsigned char share_flag = PSTATUS_SHARED,
+ ms_flag = (PSTATUS_SHARED | PSTATUS_MULTISHARED);
if (sharing_procs.size() == 1) {
result = mbImpl->tag_set_data(sharedp_tag, &this_ent, 1,
&sharing_procs[0]);
@@ -3016,7 +3193,7 @@
for (j = 0; j < MAX_SHARING_PROCS; j++) {
if (-1 != tmp_iface_procs[j] && tmp_iface_procs[j] != (int)procConfig.proc_rank())
procs_set.insert((unsigned int) tmp_iface_procs[j]);
- else {
+ else if (-1 == tmp_iface_procs[j]) {
std::fill(tmp_iface_procs, tmp_iface_procs+j, -1);
break;
@@ -3124,7 +3301,7 @@
MBRange tmp_ents;
- if (ents.empty()) ents = sharedEnts;
+ assert(!ents.empty());
// Put into tmp_ents any entities which are not owned locally or
// who are already shared with to_proc
@@ -3250,53 +3427,12 @@
// get entities to be sent to neighbors
- // done in a separate loop over procs because sometimes later procs
- // need to add info to earlier procs' messages
MBRange sent_ents[MAX_SHARING_PROCS], allsent, tmp_range;
- for (ind = 0, proc_it = buffProcs.begin();
- proc_it != buffProcs.end(); proc_it++, ind++) {
- if (!is_iface) {
- result = get_ghosted_entities(bridge_dim, ghost_dim, buffProcs[ind],
- num_layers, sent_ents[ind]);
- RRA("Failed to get ghost layers.");
- else {
- result = get_iface_entities(buffProcs[ind], -1, sent_ents[ind]);
- RRA("Failed to get interface layers.");
- // remove vertices, since we know they're already shared
- std::pair<MBRange::const_iterator,MBRange::const_iterator> vert_it =
- sent_ents[ind].equal_range(MBVERTEX);
- sent_ents[ind].erase(vert_it.first, vert_it.second);
- // filter out entities already shared with destination
- tmp_range.clear();
- result = filter_pstatus(sent_ents[ind], PSTATUS_SHARED, PSTATUS_AND,
- buffProcs[ind], &tmp_range);
- RRA("Couldn't filter on owner.");
- if (!tmp_range.empty())
- sent_ents[ind] = sent_ents[ind].subtract(tmp_range);
- allsent.merge(sent_ents[ind]);
- // need to get procs each entity is sent to
- MBRange::iterator rit;
std::vector<std::set<unsigned int> > entprocs(allsent.size());
- for (rit = sent_ents[ind].begin(); rit != sent_ents[ind].end(); rit++) {
- int rind = allsent.index(*rit);
- assert(rind < (int) allsent.size() && rind >= 0);
- entprocs[rind].insert(*proc_it);
+ result = get_sent_ents(is_iface, bridge_dim, ghost_dim, num_layers,
+ sent_ents, allsent, entprocs);
+ RRA("get_sent_ents failed.");
// pack and send ents from this proc to others
@@ -3304,19 +3440,13 @@
- // get an estimate of the buffer size & pre-allocate buffer size
- unsigned int buff_size = estimate_ents_buffer_size(sent_ents[ind],
- store_remote_handles);
- ownerSBuffs[ind].clear();
- ownerSBuffs[ind].reserve(buff_size);
// buff_ptr points to the END (one past last occupied byte) of buffer
buff_ptr = &ownerSBuffs[ind][0];
// entities
result = pack_entities(sent_ents[ind], ownerSBuffs[ind], buff_ptr,
store_remote_handles, buffProcs[ind], is_iface,
- &entprocs);
+ &entprocs, &allsent);
RRA("Packing entities failed.");
// now we're ready to send the buffer
@@ -3334,7 +3464,7 @@
int num_incoming = buffProcs.size();
std::vector<MPI_Status> status(buffProcs.size());
std::vector<std::vector<MBEntityHandle> > recd_ents(num_incoming);
- std::vector<std::vector<MBEntityHandle> > L1h(buffProcs.size());
+ std::vector<std::vector<MBEntityHandle> > L1hloc(buffProcs.size()), L1hrem(buffProcs.size());
std::vector<std::vector<int> > L1p(buffProcs.size());
std::vector<MBEntityHandle> L2hloc, L2hrem;
std::vector<unsigned int> L2p;
@@ -3370,7 +3500,7 @@
unsigned char *buff_ptr = &ghostRBuffs[ind][0];
store_remote_handles, ind, is_iface,
- L1h, L1p, L2hloc, L2hrem, L2p, new_ents);
+ L1hloc, L1hrem, L1p, L2hloc, L2hrem, L2p, new_ents);
RRA("Failed to unpack entities.");
else {
@@ -3419,7 +3549,7 @@
// skip if iface layer and higher-rank proc
buff_ptr = &ghostSBuffs[ind][0];
- result = pack_remote_handles(L1h[ind], L1p[ind], *proc_it,
+ result = pack_remote_handles(L1hloc[ind], L1hrem[ind], L1p[ind], *proc_it,
ghostSBuffs[ind], buff_ptr);
RRA("Failed to pack remote handles.");
result = send_buffer(buffProcs[ind], &ghostSBuffs[ind][0],
@@ -3472,6 +3602,211 @@
return MB_SUCCESS;
+MBErrorCode MBParallelComm::get_sent_ents(const bool is_iface,
+ const int bridge_dim, const int ghost_dim,
+ const int num_layers,
+ MBRange *sent_ents, MBRange &allsent,
+ std::vector<std::set<unsigned int> > &entprocs)
+ int ind;
+ std::vector<unsigned int>::iterator proc_it;
+ MBRange tmp_range;
+ // done in a separate loop over procs because sometimes later procs
+ // need to add info to earlier procs' messages
+ for (ind = 0, proc_it = buffProcs.begin();
+ proc_it != buffProcs.end(); proc_it++, ind++) {
+ if (!is_iface) {
+ result = get_ghosted_entities(bridge_dim, ghost_dim, buffProcs[ind],
+ num_layers, sent_ents[ind]);
+ RRA("Failed to get ghost layers.");
+ else {
+ result = get_iface_entities(buffProcs[ind], -1, sent_ents[ind]);
+ RRA("Failed to get interface layers.");
+ // filter out entities already shared with destination
+ tmp_range.clear();
+ result = filter_pstatus(sent_ents[ind], PSTATUS_SHARED, PSTATUS_AND,
+ buffProcs[ind], &tmp_range);
+ RRA("Couldn't filter on owner.");
+ if (!tmp_range.empty())
+ sent_ents[ind] = sent_ents[ind].subtract(tmp_range);
+ allsent.merge(sent_ents[ind]);
+ // need to get procs each entity is sent to
+ entprocs.resize(allsent.size());
+ for (rit = sent_ents[ind].begin(); rit != sent_ents[ind].end(); rit++) {
+ int rind = allsent.index(*rit);
+ assert(rind < (int) allsent.size() && rind >= 0);
+ entprocs[rind].insert(*proc_it);
+MBErrorCode MBParallelComm::exchange_ghost_cells(MBParallelComm **pcs,
+ unsigned int num_procs,
+ int ghost_dim, int bridge_dim,
+ int num_layers,
+ bool store_remote_handles)
+ // static version of function, exchanging info through buffers rather
+ // than through messages
+ // if we're only finding out about existing ents, we have to be storing
+ // remote handles too
+ assert(num_layers > 0 || store_remote_handles);
+ const bool is_iface = !num_layers;
+ unsigned int ind;
+ unsigned char *buff_ptr;
+ MBParallelComm *pc;
+ MBErrorCode result = MB_SUCCESS;
+ // when this function is called, buffProcs should already have any
+ // communicating procs
+ // get entities to be sent to neighbors
+ MBRange sent_ents[MAX_SHARING_PROCS][MAX_SHARING_PROCS],
+ allsent[MAX_SHARING_PROCS];
+ std::vector<std::set<unsigned int> > entprocs[MAX_SHARING_PROCS];
+ for (unsigned int p = 0; p < num_procs; p++) {
+ pc = pcs[p];
+ result = pc->get_sent_ents(is_iface, bridge_dim, ghost_dim, num_layers,
+ sent_ents[p], allsent[p], entprocs[p]);
+ RRAI(pc->get_moab(), "get_sent_ents failed.");
+ // pack entities into buffers
+ for (ind = 0; ind < pc->buffProcs.size(); ind++) {
+ // buff_ptr points to the END (one past last occupied byte) of buffer
+ buff_ptr = &pc->ownerSBuffs[ind][0];
+ // entities
+ result = pc->pack_entities(sent_ents[p][ind], pc->ownerSBuffs[ind], buff_ptr,
+ store_remote_handles, pc->buffProcs[ind], is_iface,
+ &entprocs[p], &allsent[p]);
+ RRAI(pc->get_moab(), "Packing entities failed.");
+ // receive/unpack new entities
+ // number of incoming messages for ghosts is the number of procs we
+ // communicate with; for iface, it's the number of those with lower rank
+ std::vector<std::vector<MBEntityHandle> > L1hloc[MAX_SHARING_PROCS], L1hrem[MAX_SHARING_PROCS];
+ std::vector<std::vector<int> > L1p[MAX_SHARING_PROCS];
+ std::vector<MBEntityHandle> L2hloc[MAX_SHARING_PROCS], L2hrem[MAX_SHARING_PROCS];
+ std::vector<unsigned int> L2p[MAX_SHARING_PROCS];
+ MBRange new_ents[MAX_SHARING_PROCS];
+ L1hloc[p].resize(pcs[p]->buffProcs.size());
+ L1hrem[p].resize(pcs[p]->buffProcs.size());
+ L1p[p].resize(pcs[p]->buffProcs.size());
+ MBParallelComm *pc = pcs[p];
+ // incoming ghost entities; unpack; returns entities received
+ // both from sending proc and from owning proc (which may be different)
+ unsigned int to_p = pc->buffProcs[ind];
+ unsigned char *buff_ptr = &pc->ownerSBuffs[ind][0];
+ result = pcs[to_p]->unpack_entities(buff_ptr,
+ store_remote_handles, ind, is_iface,
+ L1hloc[to_p], L1hrem[to_p], L1p[to_p], L2hloc[to_p],
+ L2hrem[to_p], L2p[to_p], new_ents[to_p]);
+ RRAI(pc->get_moab(), "Failed to unpack entities.");
+ if (is_iface) {
+#ifdef NDEBUG
+ result = pcs[p]->check_sent_ents(allsent[p]);
+ RRAI(pcs[p]->get_moab(), "Failed check on shared entities.");
+ result = pcs[p]->check_all_shared_handles();
+ RRAI(pcs[p]->get_moab(), "Failed check on all shared handles.");
+#endif
+ // send local handles for new ghosts to owner, then add
+ // those to ghost list for that owner
+ pc = pcs[p];
+ for (ind = 0, proc_it = pc->buffProcs.begin();
+ proc_it != pc->buffProcs.end(); proc_it++, ind++) {
+ // skip if iface layer and higher-rank proc
+ unsigned char *buff_ptr = &pc->ghostSBuffs[ind][0];
+ result = pc->pack_remote_handles(L1hloc[p][ind], L1hrem[p][ind], L1p[p][ind], *proc_it,
+ pc->ghostSBuffs[ind], buff_ptr);
+ RRAI(pc->get_moab(), "Failed to pack remote handles.");
+ // process remote handles of my ghosteds
+ pc = pcs[p];
+ // incoming remote handles
+ result = pcs[to_p]->unpack_remote_handles(p, &pc->ghostSBuffs[ind][0],
+ L2hloc[to_p], L2hrem[to_p], L2p[to_p]);
+ RRAI(pc->get_moab(), "Failed to unpack remote handles.");
+#ifdef NDEBUG
+#endif
MBErrorCode MBParallelComm::get_iface_entities(int other_proc,
int dim,
MBRange &iface_ents)
@@ -3536,7 +3871,8 @@
return MB_SUCCESS;
-MBErrorCode MBParallelComm::pack_remote_handles(std::vector<MBEntityHandle> &L1h,
+MBErrorCode MBParallelComm::pack_remote_handles(std::vector<MBEntityHandle> &L1hloc,
+ std::vector<MBEntityHandle> &L1hrem,
std::vector<int> &L1p,
unsigned int to_proc,
std::vector<unsigned char> &buff,
@@ -3544,13 +3880,13 @@
// 2 vectors of handles plus ints
CHECK_BUFF_SPACE(buff, buff_ptr, ((L1p.size()+1)*sizeof(int) +
- L1h.size()*sizeof(MBEntityHandle)));
+ L1hloc.size()*sizeof(MBEntityHandle)));
// should be in pairs of handles
- assert(!(L1h.size()%2));
- PACK_INT(buff_ptr, L1h.size()/2);
+ PACK_INT(buff_ptr, L1hloc.size());
PACK_INTS(buff_ptr, &L1p[0], L1p.size());
- PACK_EH(buff_ptr, &L1h[0], L1h.size());
+ PACK_EH(buff_ptr, &L1hrem[0], L1hrem.size());
+ PACK_EH(buff_ptr, &L1hloc[0], L1hloc.size());
return MB_SUCCESS;
@@ -3567,20 +3903,22 @@
unsigned char *buff_proc = buff_ptr;
buff_ptr += num_eh * sizeof(int);
+ unsigned char *buff_rem = buff_ptr + num_eh * sizeof(MBEntityHandle);
MBErrorCode result;
- MBEntityHandle hpair[2];
+ MBEntityHandle hpair[2], dum_h;
int proc;
for (int i = 0; i < num_eh; i++) {
UNPACK_INT(buff_proc, proc);
- UNPACK_EH(buff_ptr, hpair, 2);
+ UNPACK_EH(buff_ptr, hpair, 1);
+ UNPACK_EH(buff_rem, hpair+1, 1);
if (-1 != proc) {
- MBEntityHandle dum_h;
result = find_existing_entity(false, proc, hpair[0], 3, NULL, 0,
mbImpl->type_from_handle(hpair[1]),
L2hloc, L2hrem, L2p, dum_h);
RRA("Didn't get existing entity.");
if (dum_h) hpair[0] = dum_h;
+ else hpair[0] = 0;
assert(hpair[0] && hpair[1]);
int this_proc = from_proc;
@@ -4350,44 +4688,40 @@
int &owner,
MBEntityHandle &handle)
- // I'm sure there's a much more efficient logic to this,
+ int sharing_procs[MAX_SHARING_PROCS];
+ MBEntityHandle sharing_handles[MAX_SHARING_PROCS];
- // but I'm tired...
- unsigned char pstat;
MBErrorCode result = mbImpl->tag_get_data(pstatus_tag(), &entity, 1,
&pstat);
if (!(pstat & PSTATUS_NOT_OWNED)) {
owner = proc_config().proc_rank();
handle = entity;
- return MB_SUCCESS;
- int sharing_procs[MAX_SHARING_PROCS];
- MBEntityHandle sharing_handles[MAX_SHARING_PROCS];
- result = mbImpl->tag_get_data(sharedp_tag(), &entity, 1,
- sharing_procs);
- RRA(" ");
- if (-1 != sharing_procs[0]) {
+ else if (pstat & PSTATUS_MULTISHARED) {
+ result = mbImpl->tag_get_data(sharedps_tag(), &entity, 1,
+ sharing_procs);
owner = sharing_procs[0];
sharing_handles);
handle = sharing_handles[0];
- result = mbImpl->tag_get_data(sharedps_tag(), &entity, 1,
- sharing_procs);
- if (MB_SUCCESS == result && -1 != sharing_procs[0]) {
+ else if (pstat & PSTATUS_SHARED) {
+ result = mbImpl->tag_get_data(sharedp_tag(), &entity, 1,
+ sharing_procs);
+ RRA(" ");
sharing_handles);
- owner = -1;
- handle = 0;
- return MB_FAILURE;
+ else {
+ owner = -1;
+ handle = 0;
MBErrorCode MBParallelComm::get_global_part_count( int& count_out ) const
@@ -4487,7 +4821,8 @@
int tmp[MAX_SHARING_PROCS], curr[MAX_SHARING_PROCS];
int *parts[2] = { neighbors_out, tmp };
for (MBRange::iterator i = iface.begin(); i != iface.end(); ++i) {
- rval = get_sharing_parts( *i, curr, n );
+ rval = get_sharing_data( *i, curr, NULL, pstat, n);
return rval;
std::sort( curr, curr+n );
@@ -4522,7 +4857,8 @@
int part_ids[MAX_SHARING_PROCS], num_parts;
MBRange::iterator i = iface_sets_out.begin();
while (i != iface_sets_out.end()) {
- MBErrorCode rval = get_sharing_parts( *i, part_ids, num_parts );
+ MBErrorCode rval = get_sharing_data( *i, part_ids, NULL, pstat, num_parts );
return rval;
@@ -4590,78 +4926,15 @@
return MB_SUCCESS;
-MBErrorCode MBParallelComm::get_sharing_parts( MBEntityHandle entity,
- int part_ids_out[MAX_SHARING_PROCS],
- int& num_part_ids_out,
- MBEntityHandle remote_handles[MAX_SHARING_PROCS] )
+MBErrorCode MBParallelComm::exchange_all_shared_handles(std::vector<std::vector<SharedEntityData> > &result)
- // FIXME : assumes one part per proc, and therefore part_id == rank
- // If entity is not shared, then we're the owner.
- MBErrorCode result = mbImpl->tag_get_data(pstatus_tag(), &entity, 1,
- &pstat);
- if (!(pstat & PSTATUS_SHARED)) {
- part_ids_out[0] = proc_config().proc_rank();
- if (remote_handles)
- remote_handles[0] = entity;
- num_part_ids_out = 1;
- // If entity is shared with one other proc, then
- // sharedp_tag will contain a positive value.
- result = mbImpl->tag_get_data( sharedp_tag(), &entity, 1, part_ids_out );
- if (MB_SUCCESS != result)
- return result;
- if (part_ids_out[0] != -1) {
- num_part_ids_out = 2;
- part_ids_out[1] = proc_config().proc_rank();
- // done?
- if (!remote_handles)
- // get handles on remote processors (and this one)
- remote_handles[1] = entity;
- return mbImpl->tag_get_data( sharedh_tag(), &entity, 1, remote_handles );
- // If here, then the entity is shared with at least two other processors.
- // Get the list from the sharedps_tag
- result = mbImpl->tag_get_data( sharedps_tag(), &entity, 1, part_ids_out );
- return result;
- // Count number of valid (positive) entries in sharedps_tag
- for (num_part_ids_out = 0; num_part_ids_out < MAX_SHARING_PROCS &&
- part_ids_out[num_part_ids_out] >= 0; ++num_part_ids_out);
- part_ids_out[num_part_ids_out++] = proc_config().proc_rank();
- // done?
- // get remote handles
- result = mbImpl->tag_get_data( sharedhs_tag(), &entity, 1, remote_handles );
- remote_handles[num_part_ids_out-1] = entity;
- return result;
-MBErrorCode MBParallelComm::exchange_all_shared_handles( shared_entity_map& result )
MBErrorCode rval;
int ierr;
const int tag = 0x4A41534E;
const MPI_Comm comm = procConfig.proc_comm();
- std::set<unsigned int> exch_procs;
- rval = get_comm_procs(exch_procs);
- if (MB_SUCCESS != rval)
- return rval;
- const int num_proc = exch_procs.size();
+ const int num_proc = buffProcs.size();
std::vector<MPI_Request> send_req(num_proc), recv_req(num_proc);
- const std::vector<int> procs( exch_procs.begin(), exch_procs.end() );
+ const std::vector<int> procs( buffProcs.begin(), buffProcs.end() );
// get all shared entities
MBRange all_shared, dum_range;
@@ -4673,9 +4946,10 @@
return rval;
all_shared = all_shared.subtract(dum_range);
all_shared.erase(all_shared.upper_bound(MBPOLYHEDRON), all_shared.end());
+ assert(sharedEnts == all_shared);
// build up send buffers
- shared_entity_map send_data;
+ std::vector<std::vector<SharedEntityData> > send_data(buffProcs.size());
int ent_procs[MAX_SHARING_PROCS];
int num_sharing;
@@ -4685,13 +4959,16 @@
rval = get_owner( *i, tmp.owner );
return rval;
- rval = get_sharing_parts( *i, ent_procs, num_sharing, handles );
+ rval = get_sharing_data( *i, ent_procs, handles, pstat, num_sharing );
for (int j = 0; j < num_sharing; ++j) {
if (ent_procs[j] == (int)proc_config().proc_rank())
continue;
tmp.local = handles[j];
- send_data[ent_procs[j]].push_back( tmp );
+ int ind = get_buffers(ent_procs[j]);
+ assert(-1 != ind);
+ send_data[ind].push_back( tmp );
@@ -4705,8 +4982,8 @@
// send sizes
for (int i = 0; i < num_proc; ++i) {
- sizes_send[i] = send_data[procs[i]].size();
- ierr = MPI_Isend( &sizes_send[i], 1, MPI_INT, procs[i], tag, comm, &send_req[i] );
+ sizes_send[i] = send_data[i].size();
+ ierr = MPI_Isend( &sizes_send[i], 1, MPI_INT, buffProcs[i], tag, comm, &send_req[i] );
if (ierr)
return MB_FILE_WRITE_ERROR;
@@ -4724,21 +5001,21 @@
// set up to receive data
- result[procs[i]].resize( sizes_recv[i] );
- ierr = MPI_Irecv( &result[procs[i]][0],
+ result[i].resize( sizes_recv[i] );
+ ierr = MPI_Irecv( &result[i][0],
sizeof(SharedEntityData)*sizes_recv[i],
MPI_UNSIGNED_CHAR,
- procs[i], tag, comm, &recv_req[i] );
+ buffProcs[i], tag, comm, &recv_req[i] );
if (ierr)
// send data
- ierr = MPI_Isend( &send_data[procs[i]][0],
+ ierr = MPI_Isend( &send_data[i][0],
sizeof(SharedEntityData)*sizes_send[i],
MPI_UNSIGNED_CHAR,
- procs[i], tag, comm, &send_req[i] );
+ buffProcs[i], tag, comm, &send_req[i] );
if (ierr)
@@ -4759,7 +5036,7 @@
MBErrorCode MBParallelComm::check_all_shared_handles()
// get all shared ent data from other procs
- shared_entity_map shents;
+ std::vector<std::vector<SharedEntityData> > shents(buffProcs.size());
MBErrorCode result;
result = exchange_all_shared_handles(shents);
@@ -4780,13 +5057,11 @@
MBRange bad_ents, local_shared;
- for (shared_entity_map::iterator mit = shents.begin(); mit != shents.end(); mit++) {
- int other_proc = (*mit).first;
- int ind = get_buffers(other_proc);
- if (-1 == ind) return MB_FAILURE;
+ std::vector<SharedEntityData>::iterator vit;
+ for (unsigned int i = 0; i < shents.size(); i++) {
+ int other_proc = buffProcs[i];
local_shared = all_shared;
- shared_entity_vec &shvec = (*mit).second;
- for (shared_entity_vec::iterator vit = shvec.begin(); vit != shvec.end(); vit++) {
+ for (vit = shents[i].begin(); vit != shents[i].end(); vit++) {
MBEntityHandle localh = vit->local, remoteh = vit->remote, dumh;
local_shared.erase(localh);
result = get_remote_handles(true, &localh, &dumh, 1, other_proc, dum_range);
Modified: MOAB/branches/parallel_ghosting/parallel/MBParallelComm.hpp
--- MOAB/branches/parallel_ghosting/parallel/MBParallelComm.hpp 2009-06-22 17:13:38 UTC (rev 2958)
+++ MOAB/branches/parallel_ghosting/parallel/MBParallelComm.hpp 2009-06-22 17:55:39 UTC (rev 2959)
@@ -169,6 +169,15 @@
bool wait_all = true);
+ /** \brief Static version of exchange_ghost_cells, exchanging info through
+ * buffers rather than messages
+ static MBErrorCode exchange_ghost_cells(MBParallelComm **pc,
+ int num_layers,
+ bool store_remote_handles);
/** \brief Exchange tags for all shared and ghosted entities
* This function should be called collectively over the communicator for this MBParallelComm.
* If this version is called, all ghosted/shared entities should have a value for this
@@ -246,6 +255,10 @@
int resolve_dim = 3,
int shared_dim = -1);
+ static MBErrorCode resolve_shared_ents(MBParallelComm **pc,
+ const int to_dim);
// \section GET PARALLEL DATA (shared/owned/iface entities, etc.)
@@ -390,11 +403,6 @@
MBErrorCode get_owning_part( MBEntityHandle entity,
int& owning_part_id_out,
MBEntityHandle* owning_handle = 0 );
- MBErrorCode get_sharing_parts( MBEntityHandle entity,
- MBEntityHandle remote_handles[MAX_SHARING_PROCS] = 0 );
// Propogate mesh modification amongst shared entities
// from the onwing processor to any procs with copies.
MBErrorCode update_shared_mesh();
@@ -450,7 +458,8 @@
const int ind,
@@ -463,14 +472,16 @@
const int to_proc,
- std::vector<std::set<unsigned int> > *entprocs = NULL);
+ std::vector<std::set<unsigned int> > *entprocs = NULL,
+ MBRange *allsent = NULL);
//! unpack entities in buff_ptr
MBErrorCode unpack_entities(unsigned char *&buff_ptr,
const int from_ind,
@@ -502,7 +513,8 @@
/* \brief Pack message with remote handles
* PUBLIC ONLY FOR TESTING!
- MBErrorCode pack_remote_handles(std::vector<MBEntityHandle> &entities,
+ MBErrorCode pack_remote_handles(std::vector<MBEntityHandle> &L1hloc,
std::vector<int> &procs,
@@ -514,6 +526,12 @@
private:
+ MBErrorCode get_sent_ents(const bool is_iface,
+ std::vector<std::set<unsigned int> > &entprocs);
/** \brief Set pstatus values on entities
* \param pstatus_ents Entities to be set
@@ -771,7 +789,6 @@
MBErrorCode tag_shared_ents(int resolve_dim,
int shared_dim,
MBRange *skin_ents,
std::map<std::vector<int>, MBRange> &proc_nranges);
@@ -781,9 +798,11 @@
// returned; NOTE: a subsequent step is used to verify entities on the interface
// and remove them if they're not shared
MBErrorCode create_interface_sets(std::map<std::vector<int>, MBRange> &proc_nranges,
int resolve_dim, int shared_dim);
+ // do the same but working straight from sharedEnts
+ MBErrorCode create_interface_sets(int resolve_dim, int shared_dim);
// after verifying shared entities, now parent/child links between sets can be established
MBErrorCode create_iface_pc_links();
@@ -819,19 +838,11 @@
int owner;
- typedef std::vector< SharedEntityData > shared_entity_vec;
- //! Map indexed by processor ID and containing, for each processor ID,
- //! a list of <local,remote> handle pairs, where the local handle is
- //! the handle on this processor and the remove handle is the handle on
- //! the processor ID indicated by the map index.
- typedef std::map< int, shared_entity_vec > shared_entity_map;
//! Every processor sends shared entity handle data to every other processor
//! that it shares entities with. Passed back map is all received data,
//! indexed by processor ID. This function is intended to be used for
//! debugging.
- MBErrorCode exchange_all_shared_handles( shared_entity_map& result );
+ MBErrorCode exchange_all_shared_handles(std::vector<std::vector<SharedEntityData> > &result);
//! replace handles in from_vec with corresponding handles on
//! to_proc (by checking shared[p/h]_tag and shared[p/h]s_tag;
@@ -865,14 +876,18 @@
//! new_ents value at index corresponding to id of entity in from_vec
MBErrorCode get_local_handles(MBEntityHandle *from_vec,
int num_ents,
- std::vector<MBEntityHandle> *no_ents = NULL);
+ const MBRange &new_ents);
//! same as above except puts results in range
MBErrorCode get_local_handles(const MBRange &remote_handles,
MBRange &local_handles,
+ //! same as above except gets new_ents from vector
+ MBErrorCode get_local_handles(MBEntityHandle *from_vec,
+ int num_ents,
+ const std::vector<MBEntityHandle> &new_ents);
MBErrorCode update_remote_data(MBRange &local_range,
MBRange &remote_range,
int other_proc,
Modified: MOAB/branches/parallel_ghosting/parallel/parallel_unit_tests.cpp
--- MOAB/branches/parallel_ghosting/parallel/parallel_unit_tests.cpp 2009-06-22 17:13:38 UTC (rev 2958)
+++ MOAB/branches/parallel_ghosting/parallel/parallel_unit_tests.cpp 2009-06-22 17:55:39 UTC (rev 2959)
@@ -484,6 +484,22 @@
"PARALLEL_RESOLVE_SHARED_ENTS" );
CHKERR(rval);
+ // test contents of interface sets against sharedEnts structure in pcomm;
+ int my_error = 0;
+ MBParallelComm* pcomm = MBParallelComm::get_pcomm(&moab, 0);
+ rval = pcomm->check_all_shared_handles();
+ if (MB_SUCCESS != rval) {
+ my_error = 1;
+ std::cerr << "check_all_shared_handles test failed on proc "
+ << pcomm->proc_config().proc_rank() << std::endl;
+ PCHECK(!my_error);
+ // check adjacencies just to make sure they're consistent
+ rval = mb_instance.check_adjacencies();
+ if (MB_SUCCESS != rval) my_error = 1;
MBTag geom_tag, id_tag;
rval = moab.tag_get_handle( GEOM_DIMENSION_TAG_NAME, geom_tag ); CHKERR(rval);
rval = moab.tag_get_handle( GLOBAL_ID_TAG_NAME, id_tag ); CHKERR(rval);
@@ -514,7 +530,6 @@
// if the vertices owned by any geometric entity do not
// have consistent shared processor ids, list the geometric
// entities and return failure.
- int my_error = 0;
if (!invalid_proc_ents.empty()) {
my_error = 1;
std::cerr << "Vertices owned by a single geometric entity are "
@@ -582,21 +597,6 @@
PCHECK(!my_error);
- // test contents of interface sets against sharedEnts structure in pcomm;
- MBParallelComm* pcomm = MBParallelComm::get_pcomm(&moab, 0);
- rval = pcomm->check_all_shared_handles();
- if (MB_SUCCESS != rval) {
- my_error = 1;
- std::cerr << "check_all_shared_handles test failed on proc "
- << pcomm->proc_config().proc_rank() << std::endl;
- PCHECK(!my_error);
- // finally, check adjacencies just to make sure they're consistent
- rval = mb_instance.check_adjacencies();
- if (MB_SUCCESS != rval) my_error = 1;
return MB_SUCCESS;
@@ -1337,8 +1337,9 @@
MBRange::iterator it = vertices.begin();
for (int idx = 0; it != vertices.end(); ++it, ++idx) {
int n;
- rval = pcomm.get_sharing_parts( *it, &vert_shared[idx*MAX_SHARING_PROCS],
- n, &vert_handles[idx*MAX_SHARING_PROCS] );
+ rval = pcomm.get_sharing_data( *it, &vert_shared[idx*MAX_SHARING_PROCS],
+ &vert_handles[idx*MAX_SHARING_PROCS], pstat, n );
break;
std::fill( vert_shared.begin() + idx*MAX_SHARING_PROCS + n,
Modified: MOAB/branches/parallel_ghosting/parallel/pcomm_unit.cpp
--- MOAB/branches/parallel_ghosting/parallel/pcomm_unit.cpp 2009-06-22 17:13:38 UTC (rev 2958)
+++ MOAB/branches/parallel_ghosting/parallel/pcomm_unit.cpp 2009-06-22 17:55:39 UTC (rev 2959)
@@ -38,8 +38,10 @@
void test_pack_variable_length_tag();
/** Test pack/unpack tag values*/
void test_pack_tag_handle_data();
-/** Test pack/unpack of shared entities*/
-void test_pack_shared_entities();
+/** Test pack/unpack of shared entities in 2d*/
+void test_pack_shared_entities_2d();
+/** Test pack/unpack of shared entities in 3d*/
+void test_pack_shared_entities_3d();
/** Test filter_pstatus function*/
void test_filter_pstatus();
@@ -64,7 +66,8 @@
//num_err += RUN_TEST( test_pack_bit_tag_data );
num_err += RUN_TEST( test_pack_variable_length_tag );
num_err += RUN_TEST( test_pack_tag_handle_data );
- num_err += RUN_TEST( test_pack_shared_entities );
+ num_err += RUN_TEST( test_pack_shared_entities_2d );
+ num_err += RUN_TEST( test_pack_shared_entities_3d );
num_err += RUN_TEST( test_filter_pstatus );
#ifdef USE_MPI
@@ -105,11 +108,11 @@
pcomm = new MBParallelComm( &moab);
entities.clear();
- std::vector<std::vector<MBEntityHandle> > L1h;
+ std::vector<std::vector<MBEntityHandle> > L1hloc, L1hrem;
std::vector<std::vector<int> > L1p;
- rval = pcomm->unpack_buffer( &buff[0], false, -1, -1, L1h, L1p, L2hloc,
+ rval = pcomm->unpack_buffer( &buff[0], false, -1, -1, L1hloc, L1hrem, L1p, L2hloc,
L2hrem, L2p, entities);
CHECK_ERR(rval);
@@ -310,7 +313,7 @@
result = moab->tag_create(GLOBAL_ID_TAG_NAME, sizeof(int), MB_TAG_DENSE,
MB_TYPE_INTEGER, gid_tag, &dum_default, true);
- if (MB_SUCCESS != result) return result;
+ if (MB_SUCCESS != result && MB_ALREADY_ALLOCATED != result) return result;
result = moab->tag_set_data(gid_tag, verts, gids);
@@ -391,7 +394,7 @@
return MB_SUCCESS;
-MBErrorCode create_shared_grid(MBParallelComm **pc, MBRange *verts, MBRange *quads)
+MBErrorCode create_shared_grid_2d(MBParallelComm **pc, MBRange *verts, MBRange *quads)
// P2______
@@ -442,11 +445,105 @@
create_patch(pc[i]->get_moab(), verts[i], quads[i], 3, xyztmp, &gids[9*i]);
- MBErrorCode rval = set_owners(pc, verts, quads, false);
+ MBErrorCode rval = MBParallelComm::resolve_shared_ents(pc, 4, 2);
CHECK_ERR(rval);
return rval;
+MBErrorCode create_shared_grid_3d(MBParallelComm **pc, MBRange *verts, MBRange *hexes)
+// 4 _____ _____
+// 3|__|__| |__|__|
+// |P1| | |P2| |
+// |__|__| |__|__|
+// 2 ___________ P3 - k = 2..4
+// / 1|__|__|__|__|
+// | | |P0| | |
+// J 0|__|__|__|__|
+// I-> 0 1 2 3 4
+ // create structured meshes
+ // ijkmin[p][ijk], ijkmax[p][ijk]
+#define P 4
+ int ijkmin[P][3] = { {0, 0, 0}, {0, 2, 0}, {2, 2, 0}, {0, 0, 2}};
+ int ijkmax[P][3] = { {4, 2, 2}, {2, 4, 2}, {4, 4, 2}, {4, 4, 4}};
+ int nijk[P][3];
+ int NIJK[3] = {0, 0, 0};
+#define INDEX(i, j, k) (k * NIJK[1] * NIJK[0] + j * NIJK[0] + i)
+ int p, i, j, k;
+ for (int p = 0; p < P; p++) {
+ for (int i = 0; i < 3; i++) {
+ nijk[p][i] = ijkmax[p][i] - ijkmin[p][i] + 1;
+ NIJK[i] = std::max(NIJK[i], nijk[p][i]);
+ std::vector<double> xyz;
+ MBErrorCode rval;
+ MBTag gid_tag;
+ for (p = 0; p < P; p++) {
+ if (MB_SUCCESS != rval && MB_ALREADY_ALLOCATED != rval) return rval;
+ // make vertices
+ int nverts = nijk[p][0] * nijk[p][1] * nijk[p][2];
+ xyz.resize(3*nverts);
+ gids.resize(nverts);
+ rval = pc[p]->get_moab()->create_vertices(&xyz[0], nverts, verts[p]);
+ CHECK_ERR(rval);
+ // set vertex gids
+ int nv = 0;
+ for (k = ijkmin[p][2]; k < ijkmax[p][2]; k++)
+ for (j = ijkmin[p][1]; j < ijkmax[p][1]; j++)
+ for (i = ijkmin[p][0]; i < ijkmax[p][0]; i++)
+ // gid
+ gids[nv++] = INDEX(i, j, k);
+ rval = pc[p]->get_moab()->tag_set_data(gid_tag, verts[p], &gids[0]);
+ // make elements
+ nv = 0;
+ MBEntityHandle connect[8], dum_hex;
+ for (k = ijkmin[p][2]; k < ijkmax[p][2]-1; k++)
+ for (j = ijkmin[p][1]; j < ijkmax[p][1]-1; j++)
+ for (i = ijkmin[p][0]; i < ijkmax[p][0]-1; i++) {
+ // gid
+ connect[0] = verts[p][INDEX(i, j, k)];
+ connect[1] = verts[p][INDEX(i+1, j, k)];
+ connect[2] = verts[p][INDEX(i+1, j+1, k)];
+ connect[3] = verts[p][INDEX(i, j+1, k)];
+ connect[4] = verts[p][INDEX(i, j, k+1)];
+ connect[5] = verts[p][INDEX(i+1, j, k+1)];
+ connect[6] = verts[p][INDEX(i+1, j+1, k+1)];
+ connect[7] = verts[p][INDEX(i, j+1, k+1)];
+ rval = pc[p]->get_moab()->create_element(MBHEX, connect, 8, dum_hex);
+ hexes[p].insert(dum_hex);
+ rval = pc[p]->get_moab()->tag_set_data(gid_tag, hexes[p], &gids[0]);
+ rval = MBParallelComm::resolve_shared_ents(pc, 3, 3);
+ CHECK_ERR(rval);
+ return rval;
void test_pack_vertices()
MBCore moab;
@@ -1282,6 +1379,7 @@
MB_TYPE_INTEGER,
sparse_2_int_tag,
0 );
+ if (MB_ALREADY_ALLOCATED == rval) rval = MB_SUCCESS;
CHECK_ERR(rval);
bool skip = false;
for (i = elems.begin(); i != elems.end(); ++i, skip = !skip) {
@@ -1825,275 +1923,50 @@
return MB_SUCCESS;
MBCore moab[4];
- MBInterface *mb[] = {&moab[0], &moab[1], &moab[2], &moab[3]};
MBParallelComm *pc[4];
for (unsigned int i = 0; i < 4; i++) {
pc[i] = new MBParallelComm(&moab[i]);
pc[i]->set_rank(i);
- for (unsigned int j = 0; j < 4; j++) {
- if (j == i) continue;
- else pc[i]->get_buffers(j);
MBRange verts[4], quads[4];
- MBErrorCode rval = create_shared_grid(pc, verts, quads);
+ MBErrorCode rval = create_shared_grid_2d(pc, verts, quads);
- std::vector<std::vector<MBEntityHandle> > L1h[4];
- std::vector<std::vector<int> > L1p[4];
- for (unsigned int i = 0; i < 4; i++) {
- L1h[i].resize(4);
- L1p[i].resize(4);
- std::vector<MBEntityHandle> L2hloc[4];
- std::vector<MBEntityHandle> L2hrem[4];
- std::vector<unsigned int> L2p[4];
- MBRange new_ents[4];
- MBRange sent_ents;
- std::vector<MBEntityHandle> ent_verts, dum_handles;
- std::vector<int> dum_procs;
- std::vector<std::set<unsigned int> > entprocs(4);
- std::vector<unsigned char> buffer;
- buffer.reserve(1);
- unsigned char *buff_ptr = &buffer[0];
- // interface, shared, 0->2
- // get edges that we want
- ent_verts.push_back(verts[0][6]); ent_verts.push_back(verts[0][7]);
- ent_verts.push_back(verts[0][7]); ent_verts.push_back(verts[0][8]);
- rval = get_entities(mb[0], ent_verts, 2, 1, sent_ents);
+ // exchange interface cells
+ rval = MBParallelComm::exchange_ghost_cells(pc, 4, -1, -1, 0, true);
CHECK_ERR(rval);
- assert(2 == sent_ents.size());
- // set entprocs
- entprocs[0].insert(2); entprocs[1].insert(2);
- rval = pc[0]->pack_entities(sent_ents, buffer, buff_ptr, true, 2,
- true, &entprocs);
+ // now 1 layer of hex ghosts
+ rval = MBParallelComm::exchange_ghost_cells(pc, 4, 2, 0, 1, true);
CHECK_ERR(rval);
- // now unpack the buffer
- buff_ptr = &buffer[0];
- rval = pc[2]->unpack_entities(buff_ptr, true, 0, true,
- L1h[2], L1p[2], L2hloc[2], L2hrem[2], L2p[2], new_ents[2]);
- // all L1h lists should be empty, since we're dealing with iface
- if (!L1h[2][0].empty() || !L1h[2][1].empty() ||
- !L1h[2][2].empty() || !L1h[2][3].empty() ||
- !L2p[2].empty() || !new_ents[2].empty()) rval = MB_FAILURE;
- CHECK_ERR(rval);
+ MBCore moab[4];
+ MBParallelComm *pc[4];
+ for (unsigned int i = 0; i < 4; i++) {
+ pc[i] = new MBParallelComm(&moab[i]);
+ pc[i]->set_rank(i);
+ for (unsigned int j = 0; j < 4; j++) {
+ if (j == i) continue;
+ else pc[i]->get_buffers(j);
- buffer.clear(); buff_ptr = &buffer[0];
- ent_verts.clear(); sent_ents.clear();
+ MBRange verts[4], hexes[4];
+ MBErrorCode rval = create_shared_grid_3d(pc, verts, hexes);
- // interface, multishared, 1st message, 0->1
- ent_verts.push_back(verts[0][8]); ent_verts.push_back(verts[0][5]);
- ent_verts.push_back(verts[0][5]); ent_verts.push_back(verts[0][2]);
CHECK_ERR(rval);
- // sending these edges to 1 and 3
- entprocs[0].insert(1); entprocs[0].insert(3);
- entprocs[1].insert(1); entprocs[1].insert(3);
- rval = pc[0]->pack_entities(sent_ents, buffer, buff_ptr, true, 1,
- true, &entprocs);
- CHECK_ERR(rval);
- rval = pc[1]->unpack_entities(buff_ptr, true, 0, true,
- L1h[1], L1p[1], L2hloc[1], L2hrem[1], L2p[1], new_ents[1]);
- if (!L1h[1][0].empty() || !L1h[1][1].empty() ||
- !L1h[1][2].empty() || !L1h[1][3].empty() ||
- !L2p[1].empty() || !new_ents[1].empty()) rval = MB_FAILURE;
- CHECK_ERR(rval);
- entprocs[0].clear(); entprocs[1].clear();
- // interface, multishared, 2nd message, 3->1
- // sending these edges to 0 and 1
- ent_verts.push_back(verts[3][6]); ent_verts.push_back(verts[3][3]);
- ent_verts.push_back(verts[3][3]); ent_verts.push_back(verts[3][0]);
- rval = get_entities(mb[3], ent_verts, 2, 1, sent_ents);
+ rval = MBParallelComm::exchange_ghost_cells(pc, 4, 3, 0, 1, true);
CHECK_ERR(rval);
- entprocs[0].insert(0); entprocs[0].insert(1);
- entprocs[1].insert(0); entprocs[1].insert(1);
- rval = pc[3]->pack_entities(sent_ents, buffer, buff_ptr, true, 1,
- true, &entprocs);
- CHECK_ERR(rval);
- rval = pc[1]->unpack_entities(buff_ptr, true, 3, true,
- !L1h[1][2].empty() || !L1h[1][3].empty())
- rval = MB_FAILURE;
- CHECK_ERR(rval);
- // prepare for ghost communication; set all iface entities ownership
- // stuff, so we don't need to do it explicitly using pack/unpack;
- // passing true makes it happen for edges too
- rval = set_owners(pc, verts, quads, true);
- CHECK_ERR(rval);
- // ghost, unshared, 2->1
- sent_ents.insert(quads[2][3]);
- // add vertices not already shared
- sent_ents.insert(verts[2][4]);
- sent_ents.insert(verts[2][7]);
- // entprocs lists are all just 1
- entprocs.resize(sent_ents.size());
- entprocs[2].insert(1);
- rval = pc[2]->pack_entities(sent_ents, buffer, buff_ptr, true, 1,
- true, &entprocs);
- CHECK_ERR(rval);
- rval = pc[1]->unpack_entities(buff_ptr, true, 2, false,
- if (
- // to P2: 2 handles per 3 entities = 6
- L1h[1][1].size() != 6 ||
- // to all others, 0
- !L1h[1][0].empty() || !L1h[1][2].empty() || !L1h[1][3].empty())
- CHECK_ERR(rval);
- rval = pc[1]->pack_remote_handles(L1h[1][1], L1p[1][1], 2, buffer, buff_ptr);
- CHECK_ERR(rval);
- rval = pc[2]->unpack_remote_handles(1, buff_ptr, L2hloc[2], L2hrem[2], L2p[2]);
- CHECK_ERR(rval);
- entprocs[0].clear(); entprocs[1].clear(); entprocs[2].clear();
- buffer.clear(); buff_ptr = &buffer[0]; L1h[1][1].clear();
- // ghost, multishared, 1st message, 2->0
- // sent: v3, v4, v5, q0, q1
- sent_ents.insert(quads[2][0]); sent_ents.insert(quads[2][1]);
- sent_ents.insert(verts[2][3]); sent_ents.insert(verts[2][4]);
- sent_ents.insert(verts[2][5]);
- // entprocs lists are entity-dependent
- // v3, v4, v5, q1: only to 0 (v4, v5 already on 1)
- entprocs[2].insert(0);
- entprocs[3].insert(0);
- // q2: P0 and P1
- entprocs[4].insert(0); entprocs[4].insert(1);
- rval = pc[2]->pack_entities(sent_ents, buffer, buff_ptr, true, 0,
- true, &entprocs);
- CHECK_ERR(rval);
- rval = pc[0]->unpack_entities(buff_ptr, true, 2, false,
- L1h[0], L1p[0], L2hloc[0], L2hrem[0], L2p[0], new_ents[0]);
- if (
- // 2 handles per 5 entities = 10
- L1h[0][1].size() != 10 ||
- // 2 handles per 3 entities
- L1h[0][0].size() != 6 ||
- // none received from 3, no 4th proc
- !L1h[0][2].empty() || !L1h[0][3].empty())
- CHECK_ERR(rval);
- for (int i = 0; i < 5; i++) entprocs[i].clear();
- L1p[0][1].clear(); L1h[0][1].clear();
- L1p[0][0].clear(); L1h[0][0].clear();
- // ghost, multishared, 2nd message, 1->0
- // sent: v1, v4, v7, q0, q2
- sent_ents.insert(quads[1][0]); sent_ents.insert(quads[1][2]);
- sent_ents.insert(verts[1][1]); sent_ents.insert(verts[1][4]);
- sent_ents.insert(verts[1][7]);
- // v1, q0: only to 0
- // v4, v7, q2: P0 and P2
- entprocs[1].insert(0); entprocs[1].insert(2);
- entprocs[4].insert(0); entprocs[4].insert(2);
- rval = pc[1]->pack_entities(sent_ents, buffer, buff_ptr, true, 0,
- true, &entprocs);
- CHECK_ERR(rval);
- rval = pc[0]->unpack_entities(buff_ptr, true, 1, false,
- if (
- L1h[0][0].size() != 10 ||
- L1h[0][1].size() != 6 ||
- CHECK_ERR(rval);
- // now pack/unpack the handles
- // P0 -> P2
- // xxx moved pack/unpack handles to after P2, P1 send
- rval = pc[0]->pack_remote_handles(L1h[0][1], L1p[0][1], 2, buffer, buff_ptr);
- CHECK_ERR(rval);
- rval = pc[2]->unpack_remote_handles(0, buff_ptr, L2hloc[2], L2hrem[2], L2p[2]);
- CHECK_ERR(rval);
- // P0 -> P1
- rval = pc[0]->pack_remote_handles(L1h[0][0], L1p[0][0], 1, buffer, buff_ptr);
- CHECK_ERR(rval);
- rval = pc[1]->unpack_remote_handles(0, buff_ptr, L2hloc[1], L2hrem[1], L2p[1]);
- CHECK_ERR(rval);
