[MOAB-dev] [Fwd: Fw: user: resolve_shared_ents]
Lukasz Kaczmarczyk
likask at civil.gla.ac.uk
Sat Jun 20 16:41:12 CDT 2009
FYI, by changing create_vert_elem_adjs from true to false for function
MBSkinner::find_skin(const MBRange &source_entities,
MBRange &forward_target_entities,
MBRange &reverse_target_entities,
bool create_vert_elem_adjs)
in file MBParallelComm.cpp line 2491 fix the problem. However I am not
aware of all consequences of this change.
Lukasz
On 19 Jun 2009, at 20:58, Tim Tautges wrote:
> FYI, I haven't answered in detail because I'm working on a re-design
> of the whole parallel shared entity and ghosting stuff. Hopefully
> your problem will go away once it's done. I'll keep this example as
> a test.
> - tim
> Lukasz Kaczmarczyk wrote:
>> Hi
>> This is different problem. In attachment you can find a test file
>> with generating a bug.
>> MBInterface gMB = new MBCore();
>> MBParallelComm *pcMB = new MBParallelComm(gMB);
>> gMB->load_mesh(argv[1]); MBRange tets;
>> result = gMB->get_entities_by_type( 0, MBTET, tets );
>> result = pcMB->resolve_shared_ents( 0, tets, 3, 0 );
>> If I find a bug I send solution.
>> Regards
>> Lukasz
>>> -------- Original Message --------
>>> Subject: Fw: [MOAB-dev] user: resolve_shared_ents
>>> Date: Thu, 18 Jun 2009 16:59:21 -0700 (PDT)
>>> From: Brandon Smith <bsmith82 at yahoo.com>
>>> To: Tim Tautges <tautges at mcs.anl.gov>
>>> CC: kraftche at cae.wisc.edu
>>> Hi Tim,
>>> I found a similar problem (the same problem?) a while ago and
>>> fixed it by adding this to MBSkinner.cpp at line 312.
>>> dum_elems = dum_elems.intersect(source_entities);
>>> This limits the dum_elems to entities that were input to the
>>> Skinner.
>>> Brandon
>>> ----- Forwarded Message ----
>>> From: Lukasz Kaczmarczyk <likask at civil.gla.ac.uk>
>>> To: moab-dev at mcs.anl.gov
>>> Sent: Thursday, June 18, 2009 4:43:02 PM
>>> Subject: [MOAB-dev] user: resolve_shared_ents
>>> Hello
>>> I am new user of moab. I use Zoltan to partition a mesh. After
>>> that I like to resolve shared ents. Function
>>> MBErrorCode resolve_shared_ents(MBEntityHandle this_set,
>>> MBRange &proc_ents,
>>> int resolve_dim = -1,
>>> int shared_dim = -1);
>>> works ok for some meshes. However for tetrahedral mesh imported
>>> form Gmsh I have following error:
>>> Resolving shared entities.
>>> Assertion failed: (0 < dum_elems.size() && 3 > dum_elems.size()),
>>> function find_skin, file MBSkinner.cpp, line 315.
>>> For my case dum_elems.size()==4.
>>> Can You give me a tip how to solve this problem?
>>> Regards,
>>> Lukasz
>>> "You will keep in perfect peace him whose mind is
>>> steadfast, because he trusts in you." Isaiah 26:3
>>> Tim Tautges Argonne National Laboratory
>>> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
>>> phone: (608) 263-8485 1500 Engineering Dr.
>>> fax: (608) 263-4499 Madison, WI 53706
