[MOAB-dev] [Fwd: Fw:  user: resolve_shared_ents]
    Tim Tautges
    tautges at mcs.anl.gov
    Fri Jun 19 11:38:14 CDT 2009
Jason, can you verify this and commit a fix?  Thanks.
- tim
-------- Original Message --------
Subject: Fw: [MOAB-dev] user: resolve_shared_ents
Date: Thu, 18 Jun 2009 16:59:21 -0700 (PDT)
To: Tim Tautges <tautges at mcs.anl.gov>
CC: kraftche at cae.wisc.edu
Hi Tim,
I found a similar problem (the same problem?) a while ago and fixed it
by adding this to MBSkinner.cpp at line 312.
dum_elems = dum_elems.intersect(source_entities);
This limits the dum_elems to entities that were input to the Skinner.
Brandon
----- Forwarded Message ----
From: Lukasz Kaczmarczyk <likask at civil.gla.ac.uk>
To: moab-dev at mcs.anl.gov
Sent: Thursday, June 18, 2009 4:43:02 PM
Subject: [MOAB-dev] user: resolve_shared_ents
Hello
I am new user of moab.  I use Zoltan to partition a mesh. After that I
like to resolve shared ents. Function
MBErrorCode resolve_shared_ents(MBEntityHandle this_set,
                                   MBRange &proc_ents,
                                   int resolve_dim = -1,
                                   int shared_dim = -1);
works ok for some meshes. However for tetrahedral mesh imported form
Gmsh I have following error:
Resolving shared entities.
Assertion failed: (0 < dum_elems.size() && 3 > dum_elems.size()),
function find_skin, file MBSkinner.cpp, line 315.
For my case dum_elems.size()==4.
Can You give me a tip how to solve this problem?
Lukasz
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
