[MOAB-dev] r2952 - MOAB/trunk
bmsmith6 at wisc.edu
Thu Jun 18 12:33:52 CDT 2009
Author: bmsmith
Date: 2009-06-18 12:33:51 -0500 (Thu, 18 Jun 2009)
New Revision: 2952
Modified:
MOAB/trunk/ReadMCNP5.cpp
Log:
swapped out asserts
Modified: MOAB/trunk/ReadMCNP5.cpp
--- MOAB/trunk/ReadMCNP5.cpp 2009-06-18 17:22:23 UTC (rev 2951)
+++ MOAB/trunk/ReadMCNP5.cpp 2009-06-18 17:33:51 UTC (rev 2952)
@@ -74,7 +74,7 @@
input_meshset,
options,
average );
- assert(MB_SUCCESS==result);
+ if(MB_SUCCESS != result) return result;
// get the root filename
std::string root_filename(filename);
@@ -91,7 +91,7 @@
input_meshset,
options,
average );
// if not averaging, read a single file
@@ -100,7 +100,7 @@
input_meshset,
options,
average );
- assert(MB_SUCCESS == result);
return MB_SUCCESS;
@@ -141,7 +141,7 @@
tally_coord_sys_tag,
tally_tag,
error_tag );
// This info exists only at the top of each meshtal file
@@ -161,7 +161,7 @@
date_and_time,
title,
nps );
// blank line
file.getline(line, 10000);
@@ -171,7 +171,7 @@
MBEntityHandle output_meshset;
if (!average) {
result = MBI->create_meshset( MESHSET_SET, output_meshset );
result = set_header_tags( output_meshset,
date_and_time,
title,
@@ -179,7 +179,7 @@
date_and_time_tag,
title_tag,
nps_tag );
@@ -204,7 +204,7 @@
tally_number,
tally_comment,
tally_particle );
// blank line
@@ -214,7 +214,7 @@
debug,
planes,
tally_coord_sys );
// get energy boundaries
@@ -269,7 +269,7 @@
tally_particle,
values,
errors );
// blank line
@@ -282,7 +282,7 @@
if (!average) {
MBEntityHandle tally_meshset;
result = MBI->create_meshset(MESHSET_SET, tally_meshset);
// set tags on the tally
result = set_tally_tags( tally_meshset,
@@ -294,7 +294,7 @@
tally_comment_tag,
tally_particle_tag,
tally_coord_sys_tag );
// The only info needed to build elements is the mesh plane boundaries.
// Build vertices...
@@ -304,7 +304,7 @@
start_vert,
tally_coord_sys,
tally_meshset );
// Build elements and tag them with tally values and errors, then add
// them to the tally_meshset.
@@ -318,12 +318,12 @@
tally_tag,
error_tag,
tally_meshset );
// add this tally's meshset to the output meshset
if (debug) std::cout << "not averaging tally" << std::endl;
result = MBI->add_entities( output_meshset, &tally_meshset, 1);
// average the tally values, then delete stuff that was created
} else {
@@ -339,7 +339,7 @@
values,
errors,
n_elements );
// clean up
@@ -354,12 +354,12 @@
MBRange matching_nps_sets;
result = MBI->get_entities_by_type_and_tag( 0, MBENTITYSET, &nps_tag,
0, 1, matching_nps_sets );
if (debug) std::cout << "number of matching nps meshsets="
<< matching_nps_sets.size() << std::endl;
assert(1 == matching_nps_sets.size());
result = MBI->tag_set_data( nps_tag, matching_nps_sets, &new_nps );
// If this file is not being averaged, return the output meshset.
} else {
@@ -383,31 +383,31 @@
MBErrorCode result;
result = MBI->tag_create("DATE_AND_TIME_TAG", sizeof(char[100]), MB_TAG_SPARSE,
MB_TYPE_OPAQUE, date_and_time_tag, 0);
- assert(MB_SUCCESS==result || MB_ALREADY_ALLOCATED==result);
+ if(MB_SUCCESS!=result && MB_ALREADY_ALLOCATED!=result) return result;
result = MBI->tag_create("TITLE_TAG", sizeof(char[100]), MB_TAG_SPARSE,
MB_TYPE_OPAQUE, title_tag, 0);
result = MBI->tag_create("NPS_TAG", sizeof(unsigned long int),
MB_TAG_SPARSE, MB_TYPE_OPAQUE, nps_tag, 0);
result = MBI->tag_create("TALLY_NUMBER_TAG", sizeof(int), MB_TAG_SPARSE,
MB_TYPE_INTEGER, tally_number_tag, 0);
result = MBI->tag_create("TALLY_COMMENT_TAG", sizeof(char[100]), MB_TAG_SPARSE,
MB_TYPE_OPAQUE, tally_comment_tag, 0);
result = MBI->tag_create("TALLY_PARTICLE_TAG", sizeof(particle), MB_TAG_SPARSE,
MB_TYPE_OPAQUE, tally_particle_tag, 0);
result = MBI->tag_create("TALLY_COORD_SYS_TAG", sizeof(coordinate_system), MB_TAG_SPARSE,
MB_TYPE_OPAQUE, tally_coord_sys_tag, 0);
result = MBI->tag_create("TALLY_TAG", sizeof(double), MB_TAG_DENSE,
MB_TYPE_DOUBLE, tally_tag, 0);
result = MBI->tag_create("ERROR_TAG", sizeof(double), MB_TAG_DENSE,
MB_TYPE_DOUBLE, error_tag, 0);
return MB_SUCCESS;
@@ -454,11 +454,11 @@
MBTag nps_tag ) {
MBErrorCode result;
result = MBI->tag_set_data( data_and_time_tag, &output_meshset, 1, &date_and_time);
result = MBI->tag_set_data( title_tag, &output_meshset, 1, &title);
result = MBI->tag_set_data( nps_tag, &output_meshset, 1, &nps);
return MB_SUCCESS;
@@ -470,7 +470,7 @@
// get tally number
// Mesh Tally Number 104
- MBEntityHandle result;
+ MBErrorCode result;
char line[100];
file.getline(line, 100);
std::string a = line;
@@ -500,7 +500,7 @@
a = line;
result = get_tally_particle(a, debug, tally_particle);
if (debug) std::cout << "tally_comment=| " << tally_comment << std::endl;
return MB_SUCCESS;
@@ -578,7 +578,7 @@
if (std::string::npos != b) {
std::istringstream ss(a.substr(b+sizeof("R direction"),10000));
result = get_mesh_plane( ss, debug, planes[0] );
} else return MB_FAILURE;
// get z planes
@@ -589,7 +589,7 @@
std::istringstream ss(a.substr(b+sizeof("Z direction"),10000));
result = get_mesh_plane( ss, debug, planes[1] );
// get theta planes
@@ -600,7 +600,7 @@
std::istringstream ss(a.substr(b+sizeof("Theta direction (revolutions):"),10000));
result = get_mesh_plane( ss, debug, planes[2] );
// Cartesian coordinate system:
@@ -612,7 +612,7 @@
std::istringstream ss(a.substr(b+sizeof("X direction"),10000));
// get y planes
@@ -623,7 +623,7 @@
std::istringstream ss(a.substr(b+sizeof("Y direction"),10000));
// get z planes
@@ -634,7 +634,7 @@
// Spherical coordinate system not yet implemented:
@@ -720,13 +720,13 @@
MBTag tally_coord_sys_tag ) {
MBErrorCode result;
result = MBI->tag_set_data( tally_number_tag, &tally_meshset, 1, &tally_number);
result = MBI->tag_set_data( tally_comment_tag, &tally_meshset, 1, &tally_comment);
result = MBI->tag_set_data( tally_particle_tag, &tally_meshset, 1, &tally_particle);
result = MBI->tag_set_data( tally_coord_sys_tag, &tally_meshset, 1, &tally_coord_sys);
return MB_SUCCESS;
@@ -743,7 +743,7 @@
std::vector<double*> coord_arrays(3);
result = readMeshIface->get_node_arrays( 3, n_verts, MB_START_ID,
start_vert, coord_arrays );
assert(0 != start_vert); // check for NULL
for (unsigned int k=0; k < planes[2].size(); k++) {
@@ -757,7 +757,7 @@
in[1] = planes[1][j];
in[2] = planes[2][k];
result = transform_point_to_cartesian( in, out, coord_sys );
coord_arrays[0][idx] = out[0];
coord_arrays[1][idx] = out[1];
@@ -767,7 +767,7 @@
MBRange vert_range(start_vert, start_vert+n_verts-1);
result = MBI->add_entities( tally_meshset, vert_range );
return MB_SUCCESS;
@@ -789,7 +789,7 @@
MBEntityHandle *connect;
result = readMeshIface->get_element_array( n_elements, 8, MBHEX, MB_START_ID,
start_element, connect );
assert(0 != start_element); // check for NULL
unsigned int counter = 0;
@@ -818,13 +818,13 @@
MBRange element_range(start_element, start_element+n_elements-1);
result = MBI->tag_set_data(tally_tag, element_range, values);
result = MBI->tag_set_data(error_tag, element_range, errors);
// add the elements to the tally set
result = MBI->add_entities( tally_meshset, element_range );
if (debug) std::cout << "Read " << n_elements << " elements from tally." << std::endl;
return MB_SUCCESS;
@@ -852,7 +852,7 @@
result = MBI->get_entities_by_type_and_tag( 0, MBENTITYSET, &tally_number_tag,
tally_number_val, 1,
matching_tally_number_sets );
if (debug) std::cout << "number of matching meshsets="
<< matching_tally_number_sets.size() << std::endl;
assert(1 == matching_tally_number_sets.size());
@@ -864,7 +864,7 @@
// get the existing elements from the set
MBRange existing_elements;
result = MBI->get_entities_by_type( existing_meshset, MBHEX, existing_elements );
assert(existing_elements.size() == n_elements);
// get the nps of the existing and new tally
@@ -872,11 +872,11 @@
MBRange sets_with_this_tag;
result = MBI->get_entities_by_type_and_tag( 0, MBENTITYSET, &nps_tag, 0, 1,
sets_with_this_tag);
if (debug) std::cout << "number of nps sets=" << sets_with_this_tag.size() << std::endl;
assert(1 == sets_with_this_tag.size());
result = MBI->tag_get_data( nps_tag, &sets_with_this_tag.front(), 1, &nps0);
if (debug) std::cout << "nps0=" << nps0 << " nps1=" << nps1 << std::endl;
new_nps = nps0 + nps1;
@@ -884,20 +884,20 @@
double *values0 = new double [existing_elements.size()];
double *errors0 = new double [existing_elements.size()];
result = MBI->tag_get_data( tally_tag, existing_elements, values0 );
result = MBI->tag_get_data( error_tag, existing_elements, errors0 );
// average the values and errors
result = average_tally_values( nps0, nps1, values0, values1,
errors0, errors1, n_elements );
// set the averaged information back onto the existing elements
result = MBI->tag_set_data( tally_tag, existing_elements, values0 );
result = MBI->tag_set_data( error_tag, existing_elements, errors0 );
// cleanup
delete[] values0;
