[MOAB-dev] r2944 - MOAB/trunk
bmsmith6 at wisc.edu
Mon Jun 15 11:49:43 CDT 2009
Author: bmsmith
Date: 2009-06-15 11:49:43 -0500 (Mon, 15 Jun 2009)
New Revision: 2944
Modified:
MOAB/trunk/ReadMCNP5.cpp
MOAB/trunk/ReadMCNP5.hpp
Log:
Fixed connectivity, added averaging functionality, removed extra code.
Modified: MOAB/trunk/ReadMCNP5.cpp
--- MOAB/trunk/ReadMCNP5.cpp 2009-06-12 22:56:39 UTC (rev 2943)
+++ MOAB/trunk/ReadMCNP5.cpp 2009-06-15 16:49:43 UTC (rev 2944)
@@ -1,5 +1,5 @@
- * \class ReadMCNP5
+ * \class ReadMCNP5
* \brief Read output from MCNP5
* \author Brandon Smith
@@ -18,16 +18,16 @@
#include "assert.h"
#include "math.h"
-// Parameters
+// parameters
const double ReadMCNP5::PI = 3.141592653589793;
const double ReadMCNP5::C2PI = 0.1591549430918954;
const double ReadMCNP5::CPI = 0.3183098861837907;
-// this setup is mostly copied from ReadSms.cpp
MBReaderIface* ReadMCNP5::factory( MBInterface* iface ) {
return new ReadMCNP5( iface );
+// constructor
ReadMCNP5::ReadMCNP5(MBInterface* impl)
: MBI(impl) {
assert( NULL!=impl);
@@ -37,6 +37,7 @@
readMeshIface = reinterpret_cast<MBReadUtilIface*>(ptr);
+// destructor
ReadMCNP5::~ReadMCNP5() {
if (readMeshIface) {
MBI->release_interface("MBReadUtilIface", readMeshIface);
@@ -44,36 +45,83 @@
-MBErrorCode ReadMCNP5::load_file(const char* fname,
- MBEntityHandle& input_meshset,
- const FileOptions& options,
- const char* set_tag_name, // not used
- const int* material_set_list, // not used
- const int num_material_sets ) { // not used
- std::cout << "begin MCNP5 reader" << std::endl;
+// load the file as called by the MBInterface function
+MBErrorCode ReadMCNP5::load_file(const char *filename,
+ MBEntityHandle &input_meshset,
+ const FileOptions &options,
+ const char *set_tag_name, // not used
+ const int *material_set_list, // not used
+ const int num_material_sets ) { // not used
- // no support for reading a subset of the file
+ // at this time there is no support for reading a subset of the file
if (set_tag_name) {
readMeshIface->report_error( "Reading subset of files not supported for meshtal." );
return MB_UNSUPPORTED_OPERATION;
- bool debug=true;
+ // Average several meshtal files if the AVERAGE_TALLY option is givin.
+ // In this case, the integer value is the number of files to average.
+ // If averaging, the filename passed to load_file is assumed to be the
+ // root filename. The files are indexed as "root_filename""index".meshtal.
+ // Indices start with 1.
+ int n_files;
+ bool average = false;
MBErrorCode result;
+ if(MB_SUCCESS == options.get_int_option("AVERAGE_TALLY", n_files)) {
+ // read the first file (but do not average -> can't average a single file)
+ result = load_one_file( filename,
+ input_meshset,
+ options,
+ average );
+ assert(MB_SUCCESS==result);
+ // get the root filename
+ std::string root_filename(filename);
+ int length = root_filename.length();
+ root_filename.erase(length - sizeof(".meshtal"));
+ // average the first file with the rest of the files
+ average = true;
+ for(int i=2; i<=n_files; i++) {
+ std::stringstream index;
+ index << i;
+ std::string subsequent_filename = root_filename + index.str() + ".meshtal";
+ result = load_one_file( subsequent_filename.c_str(),
+ input_meshset,
+ options,
+ average );
+ // if not averaging, read a single file
+ } else {
+ input_meshset,
+ options,
+ average );
+ assert(MB_SUCCESS == result);
+ return MB_SUCCESS;
+// This actually reads the file. It creates the mesh elements unless
+// the file is being averaged with a pre-existing mesh.
+MBErrorCode ReadMCNP5::load_one_file(const char *fname,
+ const bool average ) {
+ bool debug = false;
+ if (debug) std::cout << "begin ReadMCNP5::load_one_file" << std::endl;
+ MBErrorCode result;
std::fstream file;
file.open( fname, std::fstream::in );
char line[10000];
- // Options specify if this file will be averaged with a file already existing in
- // the interface.
- bool average;
- if ( MB_SUCCESS ==options.get_null_option("AVERAGE_TALLY") )
- average = true;
- else
- average = false;
- // Create tags
+ // create tags
MBTag date_and_time_tag,
title_tag,
nps_tag,
@@ -93,7 +141,7 @@
tally_coord_sys_tag,
tally_tag,
error_tag );
- assert(MB_SUCCESS == result);
// This info exists only at the top of each meshtal file
@@ -113,7 +161,7 @@
date_and_time,
title,
nps );
// blank line
file.getline(line, 10000);
@@ -123,7 +171,7 @@
MBEntityHandle output_meshset;
if (!average) {
result = MBI->create_meshset( MESHSET_SET, output_meshset );
result = set_header_tags( output_meshset,
date_and_time,
title,
@@ -131,7 +179,7 @@
date_and_time_tag,
title_tag,
nps_tag );
@@ -146,8 +194,9 @@
char tally_comment[100] = "";
particle tally_particle;
coordinate_system tally_coord_sys;
- std::vector<double> planes[3];
- int n_chopped_x2_planes;
+ std::vector<double> planes[3];
+ unsigned int n_chopped_x0_planes;
+ unsigned int n_chopped_x2_planes;
// read tally header
result = read_tally_header( file,
@@ -155,7 +204,7 @@
tally_number,
tally_comment,
tally_particle );
// blank line
@@ -165,7 +214,7 @@
debug,
planes,
tally_coord_sys );
// get energy boundaries
@@ -184,8 +233,8 @@
// because the hex elements are a linear approximation to the cylindrical elements.
// Chopping off the last plane is problem-dependent, and due to MCNP5's mandate
// that the cylidrical mesh must span 360 degrees.
- if ( CYLINDRICAL==tally_coord_sys &&
- MB_SUCCESS ==options.get_null_option("REMOVE_LAST_CYLIDRICAL_PLANE") ) {
+ if (CYLINDRICAL==tally_coord_sys &&
+ MB_SUCCESS ==options.get_null_option("REMOVE_LAST_AZIMUTHAL_PLANE")) {
planes[2].pop_back();
n_chopped_x2_planes = 1;
if (debug) std::cout << "remove last cylindrical plane option found" << std::endl;
@@ -193,7 +242,21 @@
n_chopped_x2_planes = 0;
- // read the values and errors of each element from the file.
+ // If using cylindrical mesh, it may be necessary to chop off the first radial element.
+ // These elements extend from the axis and often do not cover areas of interest. For
+ // example, if the mesh was meant to cover r=390-400, the first layer will go from
+ // 0-390 and serve as incorrect source elements for interpolation.
+ MB_SUCCESS ==options.get_null_option("REMOVE_FIRST_RADIAL_PLANE")) {
+ std::vector<double>::iterator front=planes[0].begin();
+ planes[0].erase( front );
+ n_chopped_x0_planes = 1;
+ if (debug) std::cout << "remove first radial plane option found" << std::endl;
+ } else {
+ n_chopped_x0_planes = 0;
+ // Read the values and errors of each element from the file.
// Do not read values that are chopped off.
unsigned int n_elements = (planes[0].size()-1)*(planes[1].size()-1)*(planes[2].size()-1);
double *values = new double [n_elements];
@@ -201,26 +264,25 @@
result = read_element_values_and_errors( file,
debug,
planes,
+ n_chopped_x0_planes,
n_chopped_x2_planes,
tally_particle,
values,
errors );
// blank line
// This tally has been read. If it is not being averaged, build tags,
- // vertices
- // and elements. If it is being averaged, average the data with a
- // tally already existing in the MOAB instance.
+ // vertices and elements. If it is being averaged, average the data
+ // with a tally already existing in the MOAB instance.
if (!average) {
MBEntityHandle tally_meshset;
result = MBI->create_meshset(MESHSET_SET, tally_meshset);
- if (MB_SUCCESS != result) return result;
// set tags on the tally
result = set_tally_tags( tally_meshset,
@@ -232,28 +294,24 @@
tally_comment_tag,
tally_particle_tag,
tally_coord_sys_tag );
// The only info needed to build elements is the mesh plane boundaries.
// Build vertices...
- //MBRange vert_handles;
- //result = create_vertices( planes,
- // vert_handles,
- // tally_coord_sys,
- // tally_meshset );
- MBEntityHandle start_vert = 0;
+ MBEntityHandle start_vert = NULL;
+ debug,
start_vert,
tally_coord_sys,
tally_meshset );
// Build elements and tag them with tally values and errors, then add
// them to the tally_meshset.
result = create_elements( debug,
- planes,
+ planes,
- //vert_handles,
start_vert,
values,
errors,
@@ -263,15 +321,15 @@
// add this tally's meshset to the output meshset
- std::cout << "not averaging tally" << std::endl;
+ if (debug) std::cout << "not averaging tally" << std::endl;
result = MBI->add_entities( output_meshset, &tally_meshset, 1);
- if (MB_SUCCESS != result) std::cout << "error=" << result << std::endl;
// average the tally values, then delete stuff that was created
} else {
- std::cout << "averaging tally" << std::endl;
- result = average_with_existing_tally( new_nps,
+ if (debug) std::cout << "averaging tally" << std::endl;
+ result = average_with_existing_tally( debug,
+ new_nps,
nps,
tally_number,
tally_number_tag,
@@ -281,7 +339,7 @@
values,
errors,
n_elements );
- assert( MB_SUCCESS == result );
// clean up
@@ -296,12 +354,12 @@
MBRange matching_nps_sets;
result = MBI->get_entities_by_type_and_tag( 0, MBENTITYSET, &nps_tag,
0, 1, matching_nps_sets );
- std::cout << "number of matching nps meshsets=" << matching_nps_sets.size() << std::endl;
- assert( 1 == matching_nps_sets.size() );
+ if (debug) std::cout << "number of matching nps meshsets="
+ << matching_nps_sets.size() << std::endl;
+ assert(1 == matching_nps_sets.size());
result = MBI->tag_set_data( nps_tag, matching_nps_sets, &new_nps );
- if (MB_SUCCESS != result) std::cout<< "result=" << result << std::endl;
// If this file is not being averaged, return the output meshset.
} else {
@@ -312,7 +370,7 @@
return MB_SUCCESS;
-// Create tags needed for this reader
+// create tags needed for this reader
MBErrorCode ReadMCNP5::create_tags( MBTag &date_and_time_tag,
MBTag &title_tag,
MBTag &nps_tag,
@@ -325,31 +383,31 @@
MBErrorCode result;
result = MBI->tag_create("DATE_AND_TIME_TAG", sizeof(char[100]), MB_TAG_SPARSE,
MB_TYPE_OPAQUE, date_and_time_tag, 0);
- assert(MB_SUCCESS==result || MB_ALREADY_ALLOCATED==result);
+ assert(MB_SUCCESS==result || MB_ALREADY_ALLOCATED==result);
result = MBI->tag_create("TITLE_TAG", sizeof(char[100]), MB_TAG_SPARSE,
MB_TYPE_OPAQUE, title_tag, 0);
result = MBI->tag_create("NPS_TAG", sizeof(unsigned long int),
MB_TAG_SPARSE, MB_TYPE_OPAQUE, nps_tag, 0);
result = MBI->tag_create("TALLY_NUMBER_TAG", sizeof(int), MB_TAG_SPARSE,
MB_TYPE_INTEGER, tally_number_tag, 0);
result = MBI->tag_create("TALLY_COMMENT_TAG", sizeof(char[100]), MB_TAG_SPARSE,
MB_TYPE_OPAQUE, tally_comment_tag, 0);
result = MBI->tag_create("TALLY_PARTICLE_TAG", sizeof(particle), MB_TAG_SPARSE,
MB_TYPE_OPAQUE, tally_particle_tag, 0);
result = MBI->tag_create("TALLY_COORD_SYS_TAG", sizeof(coordinate_system), MB_TAG_SPARSE,
MB_TYPE_OPAQUE, tally_coord_sys_tag, 0);
result = MBI->tag_create("TALLY_TAG", sizeof(double), MB_TAG_DENSE,
MB_TYPE_DOUBLE, tally_tag, 0);
result = MBI->tag_create("ERROR_TAG", sizeof(double), MB_TAG_DENSE,
MB_TYPE_DOUBLE, error_tag, 0);
return MB_SUCCESS;
@@ -387,7 +445,6 @@
return MB_SUCCESS;
MBErrorCode ReadMCNP5::set_header_tags( MBEntityHandle output_meshset,
char date_and_time[100],
char title[100],
@@ -397,12 +454,11 @@
MBTag nps_tag ) {
MBErrorCode result;
result = MBI->tag_set_data( data_and_time_tag, &output_meshset, 1, &date_and_time);
result = MBI->tag_set_data( title_tag, &output_meshset, 1, &title);
result = MBI->tag_set_data( nps_tag, &output_meshset, 1, &nps);
- if(MB_SUCCESS != result) std::cout << "result=" << result << std::endl;
return MB_SUCCESS;
@@ -423,8 +479,11 @@
std::istringstream tally_number_ss( a.substr(b+sizeof("Mesh Tally Number"),100) );
tally_number_ss >> tally_number;
if (debug) std::cout << "tally_number=| " << tally_number << std::endl;
- } else return MB_FAILURE;
+ } else {
+ std::cout << "tally number not found" << std::endl;
+ return MB_FAILURE;
// next get the tally comment (optional) and particle type
// 3mm neutron heating in Be (W/cc)
// This is a neutron mesh tally.
@@ -441,7 +500,7 @@
file.getline(line, 100);
a = line;
result = get_tally_particle(a, debug, tally_particle);
- assert(MB_SUCCESS==result);
if (debug) std::cout << "tally_comment=| " << tally_comment << std::endl;
return MB_SUCCESS;
@@ -453,9 +512,9 @@
if (std::string::npos != a.find("This is a neutron mesh tally.")) {
tally_particle = NEUTRON;
- } else if (std::string::npos != a.find("This is a photon mesh tally.") ) {
+ } else if (std::string::npos != a.find("This is a photon mesh tally.")) {
tally_particle = PHOTON;
- } else if (std::string::npos != a.find("This is an electron mesh tally.") ) {
+ } else if (std::string::npos != a.find("This is an electron mesh tally.")) {
tally_particle = ELECTRON;
@@ -463,10 +522,10 @@
return MB_SUCCESS;
-MBErrorCode ReadMCNP5::read_mesh_planes( std::fstream &file,
- bool debug,
- std::vector<double> planes[3],
- coordinate_system &coord_sys ) {
+MBErrorCode ReadMCNP5::read_mesh_planes( std::fstream &file,
+ bool debug,
+ std::vector<double> planes[3],
+ coordinate_system &coord_sys ) {
// Tally bin boundaries:
MBErrorCode result;
@@ -477,7 +536,7 @@
return MB_FAILURE;
// decide what coordinate system the tally is using
- // First check for Cylindrical coordinates:
+ // first check for Cylindrical coordinates:
a = line;
std::string::size_type b = a.find("Cylinder origin at");
@@ -485,27 +544,31 @@
coord_sys = CYLINDRICAL;
if (debug) std::cout << "origin, axis, direction=| " << a << std::endl;
std::istringstream ss(a.substr(b+sizeof("Cylinder origin at"),10000));
+ // The meshtal file does not contain sufficient information to transform
+ // the particle. Although origin, axs, and vec is needed only origin and
+ // axs appear in the meshtal file. Why was vec omitted?.
// get origin (not used)
- // Cylinder origin at 0.00E+00 0.00E+00 0.00E+00, axis in 0.000E+00 0.000E+00 1.000E+00 direction
+ // Cylinder origin at 0.00E+00 0.00E+00 0.00E+00,
+ // axis in 0.000E+00 0.000E+00 1.000E+00 direction
double origin[3];
- std::cout << "origin=| ";
+ if (debug) std::cout << "origin=| ";
for (int i=0; i<3; i++) {
ss >> origin[i];
- std::cout << origin[i] << " ";
+ if (debug) std::cout << origin[i] << " ";
- std::cout << std::endl;
+ if (debug) std::cout << std::endl;
int length_of_string = 10;
ss.ignore( length_of_string, ' ');
// get axis (not used)
double axis[3];
- std::cout << "axis=| ";
+ if (debug) std::cout << "axis=| ";
ss >> axis[i];
- std::cout << axis[i] << " ";
+ if (debug) std::cout << axis[i] << " ";
a = line;
@@ -514,8 +577,8 @@
b = a.find("R direction:");
if (std::string::npos != b) {
std::istringstream ss(a.substr(b+sizeof("R direction"),10000));
- result = get_mesh_plane( ss, planes[0] );
+ result = get_mesh_plane( ss, debug, planes[0] );
// get z planes
@@ -525,8 +588,8 @@
b = a.find("Z direction:");
std::istringstream ss(a.substr(b+sizeof("Z direction"),10000));
- result = get_mesh_plane( ss, planes[1] );
+ result = get_mesh_plane( ss, debug, planes[1] );
// get theta planes
@@ -536,8 +599,8 @@
b = a.find("Theta direction (revolutions):");
std::istringstream ss(a.substr(b+sizeof("Theta direction (revolutions):"),10000));
- result = get_mesh_plane( ss, planes[2] );
+ result = get_mesh_plane( ss, debug, planes[2] );
// Cartesian coordinate system:
@@ -548,8 +611,8 @@
b = a.find("X direction:");
std::istringstream ss(a.substr(b+sizeof("X direction"),10000));
// get y planes
@@ -559,8 +622,8 @@
b = a.find("Y direction:");
std::istringstream ss(a.substr(b+sizeof("Y direction"),10000));
// get z planes
@@ -570,8 +633,8 @@
// Spherical coordinate system not yet implemented:
@@ -581,36 +644,39 @@
// Given a stringstream, return a vector of values in the string.
-MBErrorCode ReadMCNP5::get_mesh_plane( std::istringstream &ss,
+MBErrorCode ReadMCNP5::get_mesh_plane( std::istringstream &ss,
+ bool debug,
std::vector<double> &plane) {
double value;
plane.clear();
while (!ss.eof()) {
ss >> value;
plane.push_back( value );
- std::cout << value << " ";
+ if (debug) std::cout << value << " ";
return MB_SUCCESS;
-MBErrorCode ReadMCNP5::read_element_values_and_errors( std::fstream &file,
- bool debug,
- int n_chopped_x2_planes,
- particle tally_particle,
- double values[],
- double errors[] ) {
+MBErrorCode ReadMCNP5::read_element_values_and_errors(
+ std::fstream &file,
+ bool debug,
+ unsigned int n_chopped_x0_planes,
+ unsigned int n_chopped_x2_planes,
+ particle tally_particle,
+ double values[],
+ double errors[] ) {
unsigned int index = 0;
- for (unsigned int i=0; i<planes[0].size()-1; i++) {
+ // need to read every line in the file, even if we chop off some elements
+ for (unsigned int i=0; i<planes[0].size()-1+n_chopped_x0_planes; i++) {
for (unsigned int j=0; j<planes[1].size()-1; j++) {
for (unsigned int k=0; k<planes[2].size()-1+n_chopped_x2_planes; k++) {
- // need to read every line in the file, even if we chop off some elements
char line[100];
// if this element has been chopped off, skip it
+ if (i<n_chopped_x0_planes) continue;
if (k>=planes[2].size()-1 && k<planes[2].size()-1+n_chopped_x2_planes) continue;
std::string a=line;
std::stringstream ss(a);
@@ -625,6 +691,17 @@
// only the tally values and errors are used
ss >> values[index];
ss >> errors[index];
+ // make sure that input data is good
+ if( !finite(errors[index]) ) {
+ std::cerr << "found nan error while reading file" << std::endl;
+ errors[index] = 1.0;
+ if( !finite(values[index]) ) {
+ std::cerr << "found nan value while reading file" << std::endl;
+ values[index] = 0.0;
index++;
@@ -643,37 +720,36 @@
MBTag tally_coord_sys_tag ) {
MBErrorCode result;
result = MBI->tag_set_data( tally_number_tag, &tally_meshset, 1, &tally_number);
result = MBI->tag_set_data( tally_comment_tag, &tally_meshset, 1, &tally_comment);
result = MBI->tag_set_data( tally_particle_tag, &tally_meshset, 1, &tally_particle);
result = MBI->tag_set_data( tally_coord_sys_tag, &tally_meshset, 1, &tally_coord_sys);
return MB_SUCCESS;
MBErrorCode ReadMCNP5::create_vertices( std::vector<double> planes[3],
- MBEntityHandle &start_vert,
- coordinate_system coord_sys,
- MBEntityHandle tally_meshset) {
+ bool debug,
+ MBEntityHandle &start_vert,
+ coordinate_system coord_sys,
+ MBEntityHandle tally_meshset) {
MBErrorCode result;
int n_verts = planes[0].size() * planes[1].size() * planes[2].size();
- std::cout << "n_verts=" << n_verts << std::endl;
+ if (debug) std::cout << "n_verts=" << n_verts << std::endl;
std::vector<double*> coord_arrays(3);
- //int start_id = 10000; // MB_START_ID
- result = readMeshIface->get_node_arrays( 3, n_verts, MB_START_ID, start_vert, coord_arrays );
- assert( NULL != start_vert );
+ result = readMeshIface->get_node_arrays( 3, n_verts, MB_START_ID,
+ start_vert, coord_arrays );
+ assert(0 != start_vert); // check for NULL
- //double *coords;
- //coords = new double [3*n_verts];
for (unsigned int k=0; k < planes[2].size(); k++) {
for (unsigned int j=0; j < planes[1].size(); j++) {
for (unsigned int i=0; i < planes[0].size(); i++) {
- //unsigned int ijk = 3*(k*planes[0].size()*planes[1].size() + j*planes[0].size() + i);
unsigned int idx = (k*planes[0].size()*planes[1].size() + j*planes[0].size() + i);
double in[3], out[3];
@@ -681,114 +757,84 @@
in[1] = planes[1][j];
in[2] = planes[2][k];
result = transform_point_to_cartesian( in, out, coord_sys );
- //coords[ ijk ] = out[0];
- //coords[ ijk+1 ] = out[1];
- //coords[ ijk+2 ] = out[2];
coord_arrays[0][idx] = out[0];
coord_arrays[1][idx] = out[1];
coord_arrays[2][idx] = out[2];
- //result = MBI->create_vertices(coords, n_verts, vert_handles);
- // assert( MB_SUCCESS == result );
- //delete[] coords;
MBRange vert_range(start_vert, start_vert+n_verts-1);
- // add the vertices to the tally_meshset
- //result = MBI->add_entities( tally_meshset, vert_handles );
- //result = MBI->add_entities( tally_meshset, &start_vert, n_verts );
result = MBI->add_entities( tally_meshset, vert_range );
return MB_SUCCESS;
MBErrorCode ReadMCNP5::create_elements( bool debug,
- //MBRange vert_handles,
MBEntityHandle start_vert,
- //double values[],
double *values,
double *errors,
MBTag tally_tag,
MBTag error_tag,
MBEntityHandle tally_meshset ) {
MBErrorCode result;
- //MBEntityHandle connect[8], start_vert, index, hex_handle;
- //MBEntityHandle connect[8], index, hex_handle;
- //MBRange element_handles;
- //start_vert = *(vert_handles.begin());
- unsigned int index, idx;
- MBEntityHandle start_element, elem_handle;
- unsigned int n_elements = (planes[0].size()-1) * (planes[1].size()-1) * (planes[2].size()-1);
+ unsigned int index;
+ MBEntityHandle start_element = 0;
+ unsigned int n_elements = (planes[0].size()-1) * (planes[1].size()-1)
+ * (planes[2].size()-1);
MBEntityHandle *connect;
- //MBEntityHandle *connect = new MBEntityHandle[n_elements];
- result = readMeshIface->get_element_array( n_elements, 8, MBHEX, MB_START_ID, start_element, connect );
- assert( NULL != start_element );
+ result = readMeshIface->get_element_array( n_elements, 8, MBHEX, MB_START_ID,
+ start_element, connect );
+ assert(0 != start_element); // check for NULL
unsigned int counter = 0;
- for (unsigned int k=0; k<planes[2].size()-1+n_chopped_x2_planes; k++) {
+ for (unsigned int k=0; k<planes[2].size()-1; k++) {
- idx = i + j*planes[0].size() + k*planes[0].size()*planes[1].size();
- index = start_vert + idx;
+ index = start_vert + i + j*planes[0].size() + k*planes[0].size()*planes[1].size();
- // if this element has been chopped off, skip it
- if (k>=planes[2].size()-1 && k<planes[2].size()-1+n_chopped_x2_planes) continue;
- // set connectivity and create the element
connect[0] = index;
connect[1] = index + 1;
- connect[2] = index + 1 + planes[0].size();
- connect[3] = index + planes[0].size();
- connect[4] = index + planes[0].size()*planes[1].size();
- connect[5] = index + 1 + planes[0].size()*planes[1].size();
+ connect[2] = index + 1 + planes[0].size()*planes[1].size();
+ connect[3] = index + planes[0].size()*planes[1].size();
+ connect[4] = index + planes[0].size();
+ connect[5] = index + 1 + planes[0].size();
connect[6] = index + 1 + planes[0].size() + planes[0].size()*planes[1].size();
connect[7] = index + planes[0].size() + planes[0].size()*planes[1].size();
connect += 8;
- //result = MBI->create_element(MBHEX, connect, 8, hex_handle);
- // assert(MB_SUCCESS == result);
- //if (MB_SUCCESS != result) return MB_FAILURE;
- //element_handles.insert(hex_handle);
- // assign parsed data to the element
- //MBEntityHandle elem_handle = start_element + counter;
counter++;
- if ( counter != n_elements ) std::cout << "counter=" << counter << " n_elements=" << n_elements << std::endl;
+ if (counter != n_elements) std::cout << "counter=" << counter << " n_elements="
+ << n_elements << std::endl;
MBRange element_range(start_element, start_element+n_elements-1);
- //result = MBI->tag_set_data(tally_tag, &start_element, n_elements, values);
result = MBI->tag_set_data(tally_tag, element_range, values);
- //result = MBI->tag_set_data(error_tag, &start_element, n_elements, errors);
result = MBI->tag_set_data(error_tag, element_range, errors);
// add the elements to the tally set
- //result = MBI->add_entities( tally_meshset, element_handles );
- //result = MBI->add_entities( tally_meshset, &start_hex, n_elements );
result = MBI->add_entities( tally_meshset, element_range );
- //std::cout << "Read " << element_handles.size() << " elements from tally." << std::endl;
- std::cout << "Read " << n_elements << " elements from tally." << std::endl;
+ if (debug) std::cout << "Read " << n_elements << " elements from tally." << std::endl;
return MB_SUCCESS;
// Average a tally that was recently read in with one that alread exists in
// the interface. Only the existing values will be updated.
-MBErrorCode ReadMCNP5::average_with_existing_tally( unsigned long int &new_nps,
+MBErrorCode ReadMCNP5::average_with_existing_tally( bool debug,
+ unsigned long int &new_nps,
unsigned long int nps1,
- unsigned int tally_number,
+ unsigned int tally_number,
MBTag tally_number_tag,
MBTag nps_tag,
MBTag tally_tag,
@@ -799,99 +845,59 @@
// get the tally number
MBErrorCode result;
- //MBTag tally_number_tag, nps_tag, tally_tag, error_tag;
- //result = MBI->tag_create("TALLY_NUMBER_TAG", sizeof(int), MB_TAG_DENSE,
- // MB_TYPE_INTEGER, tally_number_tag, 0);
- // assert(MB_SUCCESS==result || MB_ALREADY_ALLOCATED==result);
- //int tally_number;
- //result = MBI->tag_get_data( tally_number_tag, &tally_meshset, 1, &tally_number);
// match the tally number with one from the existing meshtal file
MBRange matching_tally_number_sets;
const void* const tally_number_val[] = {&tally_number};
result = MBI->get_entities_by_type_and_tag( 0, MBENTITYSET, &tally_number_tag,
- tally_number_val, 1, matching_tally_number_sets );
- std::cout << "number of matching meshsets=" << matching_tally_number_sets.size() << std::endl;
- assert( 1 == matching_tally_number_sets.size() );
+ tally_number_val, 1,
+ matching_tally_number_sets );
+ if (debug) std::cout << "number of matching meshsets="
+ << matching_tally_number_sets.size() << std::endl;
+ assert(1 == matching_tally_number_sets.size());
// identify which of the meshsets is existing
MBEntityHandle existing_meshset;
- //if ( tally_meshset == matching_tally_number_sets.front() )
- //existing_meshset = matching_tally_number_sets.back();
- //else
- existing_meshset = matching_tally_number_sets.front();
+ existing_meshset = matching_tally_number_sets.front();
// get the existing elements from the set
MBRange existing_elements;
result = MBI->get_entities_by_type( existing_meshset, MBHEX, existing_elements );
+ assert(existing_elements.size() == n_elements);
- // get this tally's elements
- //MBRange new_elements;
- //result = MBI->get_entities_by_type( tally_meshset, MBHEX, new_elements );
- // check to make sure they have the same number of elements
- //assert( existing_elements.size() == new_elements.size() );
- assert( existing_elements.size() == n_elements );
// get the nps of the existing and new tally
- //result = MBI->tag_create("NPS_TAG", sizeof(unsigned long long int), MB_TAG_SPARSE,
- // MB_TYPE_OPAQUE, nps_tag, 0);
- //unsigned long long int nps0, nps1;
unsigned long int nps0;
MBRange sets_with_this_tag;
- result = MBI->get_entities_by_type_and_tag( 0, MBENTITYSET, &nps_tag, 0, 1, sets_with_this_tag);
- std::cout << "number of nps sets=" << sets_with_this_tag.size() << std::endl;
- //assert( 2 == sets_with_this_tag.size() );
- assert( 1 == sets_with_this_tag.size() );
+ result = MBI->get_entities_by_type_and_tag( 0, MBENTITYSET, &nps_tag, 0, 1,
+ sets_with_this_tag);
+ if (debug) std::cout << "number of nps sets=" << sets_with_this_tag.size() << std::endl;
+ assert(1 == sets_with_this_tag.size());
result = MBI->tag_get_data( nps_tag, &sets_with_this_tag.front(), 1, &nps0);
- //result = MBI->tag_get_data( nps_tag, &sets_with_this_tag.back(), 1, &nps1);
- std::cout << "nps0=" << nps0 << " nps1=" << nps1 << std::endl;
+ if (debug) std::cout << "nps0=" << nps0 << " nps1=" << nps1 << std::endl;
new_nps = nps0 + nps1;
// get tally values from the existing elements
- //result = MBI->tag_create("TALLY_TAG", sizeof(double), MB_TAG_DENSE,
- // MB_TYPE_DOUBLE, tally_tag, 0);
- //result = MBI->tag_create("ERROR_TAG", sizeof(double), MB_TAG_DENSE,
- // MB_TYPE_DOUBLE, error_tag, 0);
double *values0 = new double [existing_elements.size()];
double *errors0 = new double [existing_elements.size()];
- //double values0[existing_elements.size()];
- //double errors0[existing_elements.size()];
result = MBI->tag_get_data( tally_tag, existing_elements, values0 );
- //result = MBI->tag_get_data( error_tag, existing_elements, errors0 ); this worked with erros0 = new double [size];
- // get the tally values from the new elements
- //values1 = new double [new_elements.size()];
- //errors1 = new double [new_elements.size()];
- //result = MBI->tag_get_data( tally_tag, new_elements, values1 );
- //result = MBI->tag_get_data( error_tag, new_elements, errors1 );
// average the values and errors
result = average_tally_values( nps0, nps1, values0, values1,
errors0, errors1, n_elements );
// set the averaged information back onto the existing elements
result = MBI->tag_set_data( tally_tag, existing_elements, values0 );
result = MBI->tag_set_data( error_tag, existing_elements, errors0 );
// cleanup
delete[] values0;
@@ -900,30 +906,17 @@
return MB_SUCCESS;
MBErrorCode ReadMCNP5::transform_point_to_cartesian(double *in, double *out,
coordinate_system coord_sys ) {
- //coordinate_system coord_sys, double *rmat) {
- //double q[3];
- // Apply the rotation matrix
- //for (unsigned int i=0; i < 3; i++) {
- // q[i] = p[0] * rmat[4*i ] + p[1] * rmat[4*i+1]
- // + p[2] * rmat[4*i+2] + rmat[4*i+3];
// Transform coordinate system
- switch( coord_sys ) {
+ switch(coord_sys) {
case CARTESIAN :
- out[0] = in[0]; out[1] = in[1]; out[2] = in[2]; // x, y, z
+ out[0] = in[0]; // x
+ out[1] = in[1]; // y
+ out[2] = in[2]; // z
break;
+ // theta is in rotations
case CYLINDRICAL :
- //r[0] = sqrt( q[0]*q[0] + q[1]*q[1] ); // r
- //r[1] = q[2]; // z
- //r[2] = c2pi * ( atan2( q[1], q[0] ) ); // theta (in rotations)
- //std::cout << "r=" << p[0] << " z=" << p[1] << " theta=" << p[2] << std::endl;
out[0] = in[0]*cos( 2*PI*in[2] ); // x
out[1] = in[0]*sin( 2*PI*in[2] ); // y
out[2] = in[1]; // z
@@ -957,6 +950,9 @@
pow(values1[i]*errors1[i]*nps1,2) ) /
(values0[i]*nps0 + values1[i]*nps1);
+ // It is possible to introduce nans if the values are zero.
+ if(!finite(errors0[i])) errors0[i] = 1.0;
values0[i] = ( values0[i]*nps0 + values1[i]*nps1 ) / (nps0 + nps1);
//std::cout << " values0=" << values0[i] << " errors0=" << errors0[i] << std::endl;
Modified: MOAB/trunk/ReadMCNP5.hpp
--- MOAB/trunk/ReadMCNP5.hpp 2009-06-12 22:56:39 UTC (rev 2943)
+++ MOAB/trunk/ReadMCNP5.hpp 2009-06-15 16:49:43 UTC (rev 2944)
@@ -21,16 +21,16 @@
const int num_material_sets );
- // Constructor
+ // constructor
ReadMCNP5(MBInterface* impl = NULL);
- // Destructor
+ // destructor
virtual ~ReadMCNP5();
protected:
private:
- // Constants
+ // constants
static const double PI;
static const double C2PI;
static const double CPI;
@@ -43,11 +43,17 @@
PHOTON,
ELECTRON };
- // Read mesh interface
+ // read mesh interface
MBReadUtilIface* readMeshIface;
// MOAB Interface
MBInterface* MBI;
+ // reads the meshtal file
+ MBErrorCode load_one_file( const char *fname,
+ const bool average );
MBErrorCode create_tags( MBTag &date_and_time_tag,
MBTag &title_tag,
@@ -88,12 +94,15 @@
coordinate_system &coord_sys);
- MBErrorCode get_mesh_plane( std::istringstream &ss, std::vector<double> &plane);
+ MBErrorCode get_mesh_plane( std::istringstream &ss,
+ bool debug,
+ std::vector<double> &plane);
MBErrorCode read_element_values_and_errors( std::fstream &file,
bool debug,
double values[],
double errors[] );
@@ -109,15 +118,15 @@
MBTag tally_coord_sys_tag );
MBErrorCode create_vertices( std::vector<double> planes[3],
- //MBRange &vert_handles,
+ bool debug,
MBEntityHandle tally_meshset );
MBErrorCode create_elements( bool debug,
double values[],
double errors[],
@@ -125,7 +134,8 @@
MBTag error_tag,
- MBErrorCode average_with_existing_tally( unsigned long int &new_nps,
+ MBErrorCode average_with_existing_tally( bool debug,
unsigned long int nps,
@@ -147,5 +157,4 @@
double *errors0,
const double *errors1,
const unsigned long int n_values);
