[MOAB-dev] moab new user
Tim Tautges
tautges at mcs.anl.gov
Sun Jun 14 11:36:46 CDT 2009
Yes, I think that will work with iMeshP too. Note that applications
written that way won't interoperate with other implementations of iMesh,
but you probably already knew that.
Note, you probably want to make sure the MOAB instance is created
through iMesh or iMeshP, using the newMesh function; there may be static
structures in iMesh or iMeshP that wouldn't get initialized otherwise.
- tim
Lukasz Kaczmarczyk wrote:
> Hello
> I have another question. I found useful method to access to iMesh
> interface:
> iMesh_Instance mesh;
> mesh = reinterpret_cast<iMesh_Instance>(gMB);
> However how it will work for partitioned meshes in MOAB? Can I use
> iMeshP when I created and partitioned mesh in MOAB? I considering to use
> mixture of C and C++ code. In C part I like to use iMesh interface and
> in C++ MOAB interface.
> Regards
> Lukasz
> On 9 Jun 2009, at 23:59, Tim Tautges wrote:
>> PS - they aren't basic questions if the behavior isn't documented;
>> thanks for being persistent, and keep the questions coming if you have
>> them.
>> - tim
>>> Hello
>>> I start to look at parallel version. I like to know more about
>>> currently implemented futures and what you plan to do in future.
>>> "PARALLEL=READ_DELETE;"
>>> "PARTITION=GEOM_DIMENSION;PARTITION_VAL=3;"
>>> "PARTITION_DISTRIBUTE;"
>>> "PARALLEL_RESOLVE_SHARED_ENTS"
>>> I can learn by reading code, however maybe is easy way to learn
>>> meaning of reading options. Do you have specification?
>>> I apologize for basic questions and taking your time,
>>> regards,
>>> Lukasz
>>>>> Hello
>>>>> I know about user guide and short course notes. I hope that there
>>>>> is something more.
>>>> For now there isn't more, though in the source code there are
>>>> various tests that might help. Look in test directory and
>>>> subdirectories of that.
>>>>> I make some progress with version moab-3.99. Do You think that is
>>>>> worth to use new svn version with is currently under development?
>>>>> How fast you make working reader for TetGen?
>>>> Very recommended to use latest svn version. No plans to make tetgen
>>>> reader, are there standard formats tetgen writes, like vtk?
>>>> Otherwise, I'm also developing MeshKit, which will have an interface
>>>> to tetgen (and ability to evaluate solid geometry from
>>>> OpenCascade). It's not quite ready yet, though.
>>>> - tim
>>>>> I working on multi-grid and solution strategies for brittle and
>>>>> heterogeneous materials using non standard approximation techniques
>>>>> based on hybrid-trefftz elements. Know I plan revolution in my code
>>>>> and MOAB is part of it.
>>>>> Lukasz
>>>>> On 8 Jun 2009, at 16:48, Tim Tautges wrote:
>>>>>> Hi Lukasz,
>>>>>> Probably the best place to start is the user's guide in the doc
>>>>>> subdirectory, then the short course notes on the moab wiki page.
>>>>>> What kinds of applications are you working on?
>>>>>> - tim
>>>>>>> Hello
>>>>>>> I write to let you know that we start new project in which MOAB
>>>>>>> implementation and iMesh interface is going to be used. If you
>>>>>>> have documentation which allow us fast and easy start pleas let
>>>>>>> me known.
>>>>>>> Kin regards,
>>>>>>> Dr. Lukasz Kaczmarczyk
>>>>>>> University of Glasgow
>>>>>> "You will keep in perfect peace him whose mind is
>>>>>> steadfast, because he trusts in you." Isaiah 26:3
>>>>>> Tim Tautges Argonne National Laboratory
>>>>>> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
>>>>>> phone: (608) 263-8485 1500 Engineering Dr.
>>>>>> fax: (608) 263-4499 Madison, WI 53706
