[MOAB-dev] moab new user
Tim Tautges tautges at mcs.anl.gov
Tue Jun 9 17:58:14 CDT 2009
Hi Lukasz,
   See the attached document, which is very preliminary but does explain
some of these things.  One major difference with what's in the code is
that what the document refers to as the MBParallelData class is now
MBParallelComm.  Note, I'm right in the middle of fixing some of the
parallel ghost exchange code, which will also change some of the
behavior in MBParallelComm; that's the class (in the parallel
subdirectory) which you can use to get parallel information about the mesh.
I'll post to the wiki when I've merged these changes into the trunk,
right now they're in a branch.
- tim
Lukasz Kaczmarczyk wrote:
> Hello
> I start to look at parallel version. I like to know more about currently
> implemented futures and what you plan to do in future.
> "PARALLEL=READ_DELETE;"
> "PARTITION=GEOM_DIMENSION;PARTITION_VAL=3;"
> "PARTITION_DISTRIBUTE;"
> "PARALLEL_RESOLVE_SHARED_ENTS"
> I can learn by reading code, however maybe is easy way to learn meaning
> of reading options. Do you have specification?
> I apologize for basic questions and taking your time,
> regards,
> Lukasz
>>> Hello
>>> I know about user guide and short course notes. I hope that there is
>>> something more.
>> For now there isn't more, though in the source code there are various
>> tests that might help.  Look in test directory and subdirectories of
>> that.
>>> I make some progress with version moab-3.99.  Do You think that is
>>> worth to use new svn version with is currently under development? How
>>> fast you make working reader for TetGen?
>> Very recommended to use latest svn version.  No plans to make tetgen
>> reader, are there standard formats tetgen writes, like vtk?
>> Otherwise, I'm also developing MeshKit, which will have an interface
>> to tetgen (and ability to evaluate solid geometry from OpenCascade).
>> It's not quite ready yet, though.
>> - tim
>>> I working on multi-grid and solution strategies for brittle and
>>> heterogeneous materials using non standard approximation techniques
>>> based on hybrid-trefftz elements. Know I plan revolution in my code
>>> and MOAB is part of it.
>>> Lukasz
>>> On 8 Jun 2009, at 16:48, Tim Tautges wrote:
>>>> Hi Lukasz,
>>>> Probably the best place to start is the user's guide in the doc
>>>> subdirectory, then the short course notes on the moab wiki page.
>>>> What kinds of applications are you working on?
>>>> - tim
>>>>> Hello
>>>>> I write to let you know that we start new project in which MOAB
>>>>> implementation and iMesh interface is going to be used. If you have
>>>>> documentation which allow us fast and easy start pleas let me known.
>>>>> Kin regards,
>>>>> Dr. Lukasz Kaczmarczyk
>>>>> University of Glasgow
>>>> "You will keep in perfect peace him whose mind is
>>>> steadfast, because he trusts in you."               Isaiah 26:3
>>>>            Tim Tautges            Argonne National Laboratory
>>>>        (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>>>>        phone: (608) 263-8485      1500 Engineering Dr.
>>>>          fax: (608) 263-4499      Madison, WI 53706
Type: application/pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20090609/536aec37/attachment-0001.pdf>
