[MOAB-dev] r2938 - MOAB/branches/parallel_ghosting/parallel
tautges at mcs.anl.gov
Tue Jun 9 08:55:33 CDT 2009
Author: tautges
Date: 2009-06-09 08:55:32 -0500 (Tue, 09 Jun 2009)
New Revision: 2938
Modified:
MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp
MOAB/branches/parallel_ghosting/parallel/MBParallelComm.hpp
MOAB/branches/parallel_ghosting/parallel/pcomm_unit.cpp
Log:
These changes make pcomm_unit run correctly, even for tricky ghosting
cases.
- added L1p list to unpack args, for cases where proc doesn't yet know
handle on destination proc (e.g. when one proc sends a new entity to
2 or more procs, and those procs need to exchange handles for the new entity)
- added MBParallelComm::list_entities, which calls the MOAB version of the
function then also prints sharing info for the entities
- implemented ghost exchange function testing to pcomm_unit, including
packing/unpacking of multishared entities and remote handles
- consolidated some code to use get_sharing_data then process the data
- add new handle and ghost status to sharing data for new multishared entities
- find_existing_entity changed to take single proc/handle instead of lists
- corrected pack/unpack_remote_handles to add passing of proc list; also
implemented unpack for cases indexed by owner handle
Modified: MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp
--- MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp 2009-06-09 02:00:08 UTC (rev 2937)
+++ MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp 2009-06-09 13:55:32 UTC (rev 2938)
@@ -431,10 +431,11 @@
if ((int)procConfig.proc_rank() != from_proc) {
std::vector<std::vector<MBEntityHandle> > dum1;
+ std::vector<std::vector<int> > dum1p;
std::vector<MBEntityHandle> dum2;
std::vector<unsigned int> dum3;
result = unpack_buffer(&buff[0], false, from_proc, -1,
- dum1, dum2, dum2, dum3, entities);
+ dum1, dum1p, dum2, dum2, dum3, entities);
RRA("Failed to unpack buffer in broadcast_entities.");
@@ -501,6 +502,7 @@
const int from_proc,
const int ind,
std::vector<std::vector<MBEntityHandle> > &L1h,
+ std::vector<std::vector<int> > &L1p,
std::vector<MBEntityHandle> &L2hloc,
std::vector<MBEntityHandle> &L2hrem,
std::vector<unsigned int> &L2p,
@@ -513,7 +515,7 @@
#endif
MBErrorCode result;
result = unpack_entities(buff_ptr, store_remote_handles,
- ind, false, L1h, L2hloc, L2hrem, L2p, new_ents);
+ ind, false, L1h, L1p, L2hloc, L2hrem, L2p, new_ents);
RRA("Unpacking entities failed.");
#ifdef DEBUG_PACKING
std::cerr << "unpack_entities buffer space: " << buff_ptr - tmp_buff << " bytes." << std::endl;
@@ -796,44 +798,35 @@
int *tmp_procs,
MBEntityHandle *tmp_handles)
- MBErrorCode result = MB_SUCCESS;
- MBEntityHandle zeroh = 0, sharedh;
+ num_ents = 0;
+ unsigned char pstat;
+ MBErrorCode result = get_sharing_data(entity, tmp_procs, tmp_handles,
+ pstat, num_ents);
+ RRA("Failed in get_sharing_data.");
+ assert(pstat == pstatus);
// build shared proc/handle lists
- num_ents = 0;
// start with multi-shared, since if it is the owner will be first
if (pstatus & PSTATUS_MULTISHARED) {
- result = mbImpl->tag_get_data(sharedps_tag(), &entity, 1, tmp_procs);
- RRA("Failed to get sharedps tag.");
- result = mbImpl->tag_get_data(sharedhs_tag(), &entity, 1, tmp_handles);
- RRA("Failed to get sharedhs tag.");
- assert(-1 != tmp_procs[2] && 0 != tmp_handles[2] &&
- "Shared procs/handles should have at least 3 non-zeros for multi-shared ents");
- int j = 3;
- // scan forward to first unoccupied shared proc or end of shared proc tag
- while (j < MAX_SHARING_PROCS && tmp_procs[j] != -1)
- j++;
- num_ents += j;
- assert(num_ents < MAX_SHARING_PROCS);
else if (pstatus & PSTATUS_NOT_OWNED) {
// if not multishared and not owned, other sharing proc is owner, put that
// one first
assert("If not owned, I should be shared too" &&
- pstatus & PSTATUS_SHARED);
- tmp_procs[0] = sharedp;
+ pstatus & PSTATUS_SHARED &&
+ num_ents == 1);
tmp_procs[1] = procConfig.proc_rank();
- tmp_handles[0] = sharedh;
tmp_handles[1] = entity;
num_ents = 2;
else if (pstatus & PSTATUS_SHARED) {
// if not multishared and owned, I'm owner
+ assert("shared and owned, should be only 1 sharing proc" &&
+ 1 == num_ents);
+ tmp_procs[1] = tmp_procs[0];
tmp_procs[0] = procConfig.proc_rank();
- tmp_procs[1] = sharedp;
+ tmp_handles[1] = tmp_handles[0];
tmp_handles[0] = entity;
- result = mbImpl->tag_get_data(sharedh_tag(), &entity, 1, tmp_handles+1);
- RRA("Failed to get sharedh tag.");
num_ents = 2;
else {
@@ -843,11 +836,15 @@
num_ents = 1;
+ int tmp_ps = num_ents;
// now add others, with zero handle for now
for (std::set<unsigned int>::iterator sit = entprocs.begin();
sit != entprocs.end(); sit++) {
+ assert("these procs shouldn't already be in the shared list" &&
+ std::find(tmp_procs, tmp_procs+tmp_ps, *sit) == tmp_procs+tmp_ps);
tmp_procs[num_ents] = *sit;
- tmp_handles[num_ents] = zeroh;
+ tmp_handles[num_ents] = 0;
num_ents++;
@@ -1089,6 +1086,7 @@
const int from_ind,
const bool is_iface,
@@ -1113,9 +1111,10 @@
// o if !iface, save new handle on L1 for all sharing procs
// lists of handles/procs to return to sending/other procs
- // L1h[p]: handle pairs [h, h'], where h is the sending proc handle
- // and h' is the receiving proc handle; this list only for
- // entities shared only between 2 procs, i.e. new shared entities
+ // L1h[p]: handle pairs [h, h'], where h' is the local proc handle
+ // and h is either the remote proc handle (if that is known) or
+ // the owner proc handle (otherwise);
+ // L1p[p]: indicates whether h is remote handle (= -1) or owner (rank of owner)
// L2hloc, L2hrem: local/remote handles for entities shared by > 2 procs;
// remote handles are on owning proc
// L2p: owning procs for handles in L2hrem
@@ -1207,7 +1206,7 @@
// entity, if there is one
if (store_remote_handles) {
- result = find_existing_entity(is_iface, &ps[0], &hs[0], num_ps,
+ result = find_existing_entity(is_iface, ps[0], hs[0], num_ps,
connect, verts_per_entity,
this_type,
@@ -1218,6 +1217,8 @@
// if we didn't find one, we'll have to create one
+ bool created_here = false;
if (!new_h) {
if (MBVERTEX == this_type) {
@@ -1251,6 +1252,8 @@
new_ents.find(new_h) == new_ents.end());
new_ents.insert(new_h);
+ created_here = true;
@@ -1259,7 +1262,8 @@
// update sharing data and pstatus, adjusting order if iface
- result = update_remote_data(new_h, &ps[0], &hs[0], num_ps, is_iface);
+ result = update_remote_data(new_h, &ps[0], &hs[0], num_ps, is_iface,
+ created_here);
RRA("");
// need to send this new handle to all sharing procs
@@ -1267,10 +1271,20 @@
for (j = 0; j < num_ps; j++) {
if (ps[j] == (int)procConfig.proc_rank()) continue;
int idx = get_buffers(ps[j]);
- if (idx == (int)L1h.size()) L1h.resize(idx+1);
- assert("Returned handles should always be non-zero" &&
- hs[j] && new_h);
- L1h[idx].push_back(hs[j]);
+ if (idx == (int)L1h.size()) {
+ L1h.resize(idx+1);
+ L1p.resize(idx+1);
+ if (!hs[j]) {
+ assert(-1 != ps[0] && num_ps > 2);
+ L1p[idx].push_back(ps[0]);
+ L1h[idx].push_back(hs[0]);
+ else {
+ L1p[idx].push_back(-1);
+ L1h[idx].push_back(hs[j]);
L1h[idx].push_back(new_h);
@@ -1373,22 +1387,65 @@
return MB_SUCCESS;
+MBErrorCode MBParallelComm::list_entities(const MBEntityHandle *ents, int num_ents)
+ MBEntityHandle tmp_handles[MAX_SHARING_PROCS];
+ int tmp_procs[MAX_SHARING_PROCS];
+ unsigned int num_ps;
+ MBErrorCode result;
+ for (int i = 0; i < num_ents; i++) {
+ result = get_sharing_data(ents[i], tmp_procs, tmp_handles, pstat, num_ps);
+ RRA("Failed to get sharing data.");
+ result = mbImpl->list_entities(ents+i, 1);
+ std::cout << "Pstatus: ";
+ if (!num_ps)
+ std::cout << "local " << std::endl;
+ else {
+ if (pstat & PSTATUS_NOT_OWNED) std::cout << "NOT_OWNED; ";
+ if (pstat & PSTATUS_SHARED) std::cout << "SHARED; ";
+ if (pstat & PSTATUS_MULTISHARED) std::cout << "MULTISHARED; ";
+ if (pstat & PSTATUS_INTERFACE) std::cout << "INTERFACE; ";
+ if (pstat & PSTATUS_GHOST) std::cout << "GHOST; ";
+ std::cout << std::endl;
+ for (unsigned int j = 0; j < num_ps; j++) {
+ std::cout << " proc " << tmp_procs[j] << " id (handle) "
+ << mbImpl->id_from_handle(tmp_handles[j])
+ << "(" << tmp_handles[j] << ")" << std::endl;
+ return MB_SUCCESS;
+MBErrorCode MBParallelComm::list_entities(const MBRange &ents)
+ for (MBRange::iterator rit = ents.begin(); rit != ents.end(); rit++)
+ list_entities(&(*rit), 1);
MBErrorCode MBParallelComm::update_remote_data(MBEntityHandle new_h,
int *ps,
MBEntityHandle *hs,
int num_ps,
- const bool is_iface)
+ const bool is_iface,
+ const bool created_here)
MBEntityHandle tag_hs[MAX_SHARING_PROCS];
int tag_ps[MAX_SHARING_PROCS];
// get initial sharing data; tag_ps and tag_hs get terminated with -1 and 0
// in this function, so no need to initialize
- MBErrorCode result = get_sharing_data(new_h, tag_ps, tag_hs, pstat);
+ unsigned int num_exist;
+ MBErrorCode result = get_sharing_data(new_h, tag_ps, tag_hs, pstat, num_exist);
RRA("");
// add any new sharing data
- int num_exist = std::find(tag_ps, tag_ps+MAX_SHARING_PROCS, -1) - tag_ps;
bool changed = false;
int idx;
if (!num_exist) {
@@ -1400,7 +1457,7 @@
else {
for (int i = 0; i < num_ps; i++) {
idx = std::find(tag_ps, tag_ps+num_exist, ps[i]) - tag_ps;
- if (idx == num_exist) {
+ if (idx == (int) num_exist) {
tag_ps[num_exist] = ps[i];
tag_hs[num_exist] = hs[i];
num_exist++;
@@ -1432,6 +1489,22 @@
if (changed) {
+ if (is_iface && num_exist > 1)
+ pstat |= PSTATUS_INTERFACE;
+ // if we created the entity in this unpack and it's shared,
+ // that means it's a ghost and we don't own it
+ else if (!is_iface && created_here && num_exist > 1)
+ pstat |= (PSTATUS_GHOST | PSTATUS_NOT_OWNED);
+ // if it's multi-shared and we created the entity in this unpack,
+ // local handle probably isn't in handle list yet
+ if (created_here && num_exist > 2) {
+ idx = std::find(tag_ps, tag_ps+num_exist, procConfig.proc_rank()) - tag_ps;
+ assert(idx < (int) num_exist);
+ if (!tag_hs[idx])
+ tag_hs[idx] = new_h;
int tag_p;
MBEntityHandle tag_h;
if (num_exist > 2 && !(pstat & PSTATUS_MULTISHARED) &&
@@ -1463,9 +1536,6 @@
pstat |= PSTATUS_SHARED;
- if (is_iface && num_exist > 1)
- pstat |= PSTATUS_INTERFACE;
// now set new pstatus
result = mbImpl->tag_set_data(pstatus_tag(), &new_h, 1, &pstat);
RRA("Couldn't set pstatus tag.");
@@ -1479,7 +1549,8 @@
MBErrorCode MBParallelComm::get_sharing_data(MBEntityHandle entity,
int *ps,
MBEntityHandle *hs,
- unsigned char &pstat)
+ unsigned char &pstat,
+ unsigned int &num_ps)
MBErrorCode result = mbImpl->tag_get_data(pstatus_tag(), &entity, 1, &pstat);
RRA("Couldn't get pstatus tag.");
@@ -1488,6 +1559,7 @@
RRA("Couldn't get sharedps tag.");
result = mbImpl->tag_get_data(sharedhs_tag(), &entity, 1, hs);
RRA("Couldn't get sharedhs tag.");
+ num_ps = std::find(ps, ps+MAX_SHARING_PROCS, -1) - ps;
else if (pstat & PSTATUS_SHARED) {
result = mbImpl->tag_get_data(sharedp_tag(), &entity, 1, ps);
@@ -1497,30 +1569,34 @@
// initialize past end of data
ps[1] = -1;
hs[1] = 0;
+ num_ps = 1;
else {
ps[0] = -1;
hs[0] = 0;
+ num_ps = 0;
+ assert(0 <= num_ps && MAX_SHARING_PROCS >= num_ps);
return MB_SUCCESS;
MBErrorCode MBParallelComm::find_existing_entity(const bool is_iface,
- const int *ps,
- const MBEntityHandle *hs,
+ const int owner_p,
+ const MBEntityHandle owner_h,
const int num_ps,
const MBEntityHandle *connect,
const int num_connect,
const MBEntityType this_type,
- std::vector<MBEntityHandle> &L2p,
+ std::vector<unsigned int> &L2p,
MBEntityHandle &new_h)
if (!is_iface && num_ps > 2) {
for (unsigned int i = 0; i < L2hrem.size(); i++) {
- if (L2hrem[i] == hs[0] && ps[0] == (int) L2p[i]) {
+ if (L2hrem[i] == owner_h && owner_p == (int) L2p[i]) {
new_h = L2hloc[i];
return MB_SUCCESS;
@@ -1528,7 +1604,7 @@
// if we got here and it's a vertex, we don't need to look further
- if (MBVERTEX == this_type) return MB_SUCCESS;
+ if (MBVERTEX == this_type || !connect || !num_connect) return MB_SUCCESS;
MBRange tmp_range;
MBErrorCode result = mbImpl->get_adjacencies(connect, num_connect,
@@ -3412,6 +3488,7 @@
std::vector<MPI_Status> status(buffProcs.size());
std::vector<std::vector<MBEntityHandle> > recd_ents(num_incoming);
std::vector<std::vector<MBEntityHandle> > L1h(buffProcs.size());
+ std::vector<std::vector<int> > L1p(buffProcs.size());
std::vector<MBEntityHandle> L2hloc, L2hrem;
std::vector<unsigned int> L2p;
MBRange new_ents;
@@ -3446,7 +3523,7 @@
unsigned char *buff_ptr = &ghostRBuffs[ind][0];
store_remote_handles, ind, is_iface,
- L1h, L2hloc, L2hrem, L2p, new_ents);
+ L1h, L1p, L2hloc, L2hrem, L2p, new_ents);
RRA("Failed to unpack entities.");
else {
@@ -3495,7 +3572,7 @@
proc_it != buffProcs.end(); proc_it++, ind++) {
// skip if iface layer and higher-rank proc
buff_ptr = &ghostSBuffs[ind][0];
- result = pack_remote_handles(L1h[ind], *proc_it,
+ result = pack_remote_handles(L1h[ind], L1p[ind], *proc_it,
ghostSBuffs[ind], buff_ptr);
RRA("Failed to pack remote handles.");
result = send_buffer(buffProcs[ind], &ghostSBuffs[ind][0],
@@ -3531,7 +3608,8 @@
else if (MB_MESG_REMOTE_HANDLES == status[0].MPI_TAG) {
// incoming remote handles
- result = unpack_remote_handles(buffProcs[ind], &ghostRBuffs[ind][0], is_iface, ind);
+ result = unpack_remote_handles(buffProcs[ind], &ghostRBuffs[ind][0], is_iface,
+ L2hloc, L2hrem, L2p);
RRA("Failed to unpack remote handles.");
else assert(false);
@@ -3612,16 +3690,19 @@
MBErrorCode MBParallelComm::pack_remote_handles(std::vector<MBEntityHandle> &L1h,
+ std::vector<int> &L1p,
unsigned int to_proc,
std::vector<unsigned char> &buff,
unsigned char *&buff_ptr)
- // 2 vectors of handles
- CHECK_BUFF_SPACE(buff, buff_ptr, sizeof(int) + L1h.size()*sizeof(MBEntityHandle));
+ // 2 vectors of handles plus ints
+ CHECK_BUFF_SPACE(buff, buff_ptr, ((L1p.size()+1)*sizeof(int) +
+ L1h.size()*sizeof(MBEntityHandle)));
// should be in pairs of handles
assert(!(L1h.size()%2));
PACK_INT(buff_ptr, L1h.size()/2);
+ PACK_INTS(buff_ptr, &L1p[0], L1p.size());
PACK_EH(buff_ptr, &L1h[0], L1h.size());
return MB_SUCCESS;
@@ -3630,16 +3711,31 @@
MBErrorCode MBParallelComm::unpack_remote_handles(unsigned int from_proc,
unsigned char *&buff_ptr,
- const int ind)
+ std::vector<MBEntityHandle> &L2hloc,
+ std::vector<MBEntityHandle> &L2hrem,
+ std::vector<unsigned int> &L2p)
// incoming remote handles; use to set remote handles
int num_eh;
UNPACK_INT(buff_ptr, num_eh);
+ unsigned char *buff_proc = buff_ptr;
+ buff_ptr += num_eh * sizeof(int);
MBErrorCode result;
MBEntityHandle hpair[2];
+ int proc;
for (int i = 0; i < num_eh; i++) {
+ UNPACK_INT(buff_proc, proc);
UNPACK_EH(buff_ptr, hpair, 2);
+ if (-1 != proc) {
+ MBEntityHandle dum_h;
+ result = find_existing_entity(is_iface, proc, hpair[0], 3, NULL, 0,
+ mbImpl->type_from_handle(hpair[1]),
+ L2hloc, L2hrem, L2p, dum_h);
+ RRA("Didn't get existing entity.");
+ if (dum_h) hpair[0] = dum_h;
assert(hpair[0] && hpair[1]);
result = add_remote_data(hpair[0], from_proc, hpair[1]);
RRA("Trouble setting remote data range on sent entities in ghost exchange.");
Modified: MOAB/branches/parallel_ghosting/parallel/MBParallelComm.hpp
--- MOAB/branches/parallel_ghosting/parallel/MBParallelComm.hpp 2009-06-09 02:00:08 UTC (rev 2937)
+++ MOAB/branches/parallel_ghosting/parallel/MBParallelComm.hpp 2009-06-09 13:55:32 UTC (rev 2938)
@@ -283,7 +283,14 @@
MBErrorCode get_sharing_data(MBEntityHandle entity,
int *ps,
MBEntityHandle *hs,
- unsigned char &pstat);
+ unsigned int &num_ps);
+ MBErrorCode get_sharing_data(MBEntityHandle entity,
+ int *ps,
+ MBEntityHandle *hs,
+ int &num_ps);
/** \brief Get entities on an inter-processor interface and of specified dimension
* If other_proc is -1, any interface entities are returned. If dim is -1,
@@ -444,6 +451,7 @@
const int ind,
@@ -463,6 +471,7 @@
const int from_ind,
@@ -475,6 +484,35 @@
//! set rank for this pcomm; USED FOR TESTING ONLY!
void set_rank(unsigned int r);
+ //! get (and possibly allocate) buffers for messages to/from to_proc; returns
+ //! index of to_proc in buffProcs vector; if is_new is non-NULL, sets to
+ //! whether new buffer was allocated
+ //! PUBLIC ONLY FOR TESTING!
+ int get_buffers(int to_proc, bool *is_new = NULL);
+ /* \brief Unpack message with remote handles
+ * PUBLIC ONLY FOR TESTING!
+ MBErrorCode unpack_remote_handles(unsigned int from_proc,
+ unsigned char *&buff_ptr,
+ std::vector<unsigned int> &L2p);
+ /* \brief Pack message with remote handles
+ MBErrorCode pack_remote_handles(std::vector<MBEntityHandle> &entities,
+ std::vector<int> &procs,
+ unsigned int to_proc,
+ std::vector<unsigned char> &buff,
+ unsigned char *&buff_ptr);
+ MBErrorCode list_entities(const MBEntityHandle *ents, int num_ents);
+ MBErrorCode list_entities(const MBRange &ents);
private:
/** \brief Set pstatus values on entities
@@ -520,11 +558,6 @@
int estimate_sets_buffer_size(MBRange &entities,
const bool store_remote_handles);
- //! get (and possibly allocate) buffers for messages to/from to_proc; returns
- //! index of to_proc in buffProcs vector; if is_new is non-NULL, sets to
- //! whether new buffer was allocated
- int get_buffers(int to_proc, bool *is_new = NULL);
//! send the indicated buffer, possibly sending size first
MBErrorCode send_buffer(const unsigned int to_proc,
const unsigned char *send_buff,
@@ -584,38 +617,19 @@
const int from_proc);
- /* \brief Pack message with remote handles
- MBErrorCode pack_remote_handles(MBRange &entities,
- unsigned int to_proc,
- std::vector<unsigned char> &buff,
- unsigned char *&buff_ptr);
- MBErrorCode pack_remote_handles(std::vector<MBEntityHandle> &entities,
- /* \brief Unpack message with remote handles
- MBErrorCode unpack_remote_handles(unsigned int from_proc,
- unsigned char *&buff_ptr,
- const bool is_iface,
- const int ind);
/* \brief Unpack message with remote handles (const pointer to buffer)
const unsigned char *buff_ptr,
- const int ind);
//! given connectivity and type, find an existing entity, if there is one
MBErrorCode find_existing_entity(const bool is_iface,
- const int *ps,
const int num_ents,
@@ -882,7 +896,8 @@
int *ps,
MBEntityHandle *hs,
int num_ps,
- const bool is_iface);
+ const bool created_here);
MBErrorCode add_remote_data(MBEntityHandle this_h,
int other_proc,
@@ -1020,11 +1035,13 @@
inline MBErrorCode MBParallelComm::unpack_remote_handles(unsigned int from_proc,
- const int ind)
// cast away const-ness, we won't be passing back a modified ptr
unsigned char *tmp_buff = const_cast<unsigned char*>(buff_ptr);
- return unpack_remote_handles(from_proc, tmp_buff, is_iface, ind);
+ return unpack_remote_handles(from_proc, tmp_buff, is_iface, L2hloc, L2hrem, L2p);
inline void MBParallelComm::set_rank(unsigned int r)
@@ -1033,4 +1050,16 @@
if (procConfig.proc_size() < r) procConfig.proc_size(r+1);
+inline MBErrorCode MBParallelComm::get_sharing_data(MBEntityHandle entity,
+ int *ps,
+ int &num_ps)
+ unsigned int dum_int;
+ MBErrorCode result = get_sharing_data(entity, ps, hs, pstat, dum_int);
+ num_ps = dum_int;
+ return result;
#endif
Modified: MOAB/branches/parallel_ghosting/parallel/pcomm_unit.cpp
--- MOAB/branches/parallel_ghosting/parallel/pcomm_unit.cpp 2009-06-09 02:00:08 UTC (rev 2937)
+++ MOAB/branches/parallel_ghosting/parallel/pcomm_unit.cpp 2009-06-09 13:55:32 UTC (rev 2938)
@@ -2,6 +2,7 @@
#include "MBParallelConventions.h"
#include "MBTagConventions.hpp"
#include "MBCore.hpp"
+#include "MeshTopoUtil.hpp"
#include "TestUtil.hpp"
#include <algorithm>
#include <vector>
@@ -105,9 +106,10 @@
entities.clear();
std::vector<std::vector<MBEntityHandle> > L1h;
+ std::vector<std::vector<int> > L1p;
- rval = pcomm->unpack_buffer( &buff[0], false, -1, -1, L1h, L2hloc,
+ rval = pcomm->unpack_buffer( &buff[0], false, -1, -1, L1h, L1p, L2hloc,
L2hrem, L2p, entities);
CHECK_ERR(rval);
@@ -315,6 +317,80 @@
return result;
+MBErrorCode set_owners(MBParallelComm **pc, MBRange *verts, MBRange *quads,
+ const bool edges_too)
+ // P0-P2
+ unsigned char pstat = PSTATUS_SHARED | PSTATUS_INTERFACE;
+ MBErrorCode rval = set_owners(pstat, pc[0], verts[0][6], pc[2], verts[2][0]);
+ rval = set_owners(pstat, pc[0], verts[0][7], pc[2], verts[2][1]); CHECK_ERR(rval);
+ // P1-P2
+ rval = set_owners(pstat, pc[1], verts[1][7], pc[2], verts[2][5]); CHECK_ERR(rval);
+ rval = set_owners(pstat, pc[1], verts[1][8], pc[2], verts[2][8]); CHECK_ERR(rval);
+ // P0-P1-P3
+ pstat |= PSTATUS_MULTISHARED;
+ rval = set_owners(pstat, pc[0], verts[0][2], pc[1], verts[1][0], pc[3], verts[3][0]); CHECK_ERR(rval);
+ rval = set_owners(pstat, pc[0], verts[0][5], pc[1], verts[1][3], pc[3], verts[3][3]); CHECK_ERR(rval);
+ // P0-P1-P2-P3
+ rval = set_owners(pstat, pc[0], verts[0][8], pc[1], verts[1][6],
+ pc[2], verts[2][2], pc[3], verts[3][6]); CHECK_ERR(rval);
+ if (edges_too) {
+ MeshTopoUtil *mtu[4];
+ MBInterface *mb[4];
+ MBRange dum_range;
+ // create mtu's and explicit edges
+ for (unsigned int i = 0; i < 4; i++) {
+ mb[i] = pc[i]->get_moab();
+ assert(mb[i]);
+ mtu[i] = new MeshTopoUtil(mb[i]);
+ rval = mb[i]->get_adjacencies(quads[i], 1, true, dum_range,
+ MBInterface::UNION);
+ CHECK_ERR(rval);
+ dum_range.clear();
+ MBEntityHandle edge1, edge2, edge3;
+ pstat = PSTATUS_SHARED | PSTATUS_INTERFACE;
+ // P0-P2
+ edge1 = mtu[0]->common_entity(verts[0][6], verts[0][7], 1);
+ edge2 = mtu[2]->common_entity(verts[2][0], verts[2][1], 1);
+ assert(edge1 && edge2);
+ rval = set_owners(pstat, pc[0], edge1, pc[2], edge2); CHECK_ERR(rval);
+ edge1 = mtu[0]->common_entity(verts[0][7], verts[0][8], 1);
+ edge2 = mtu[2]->common_entity(verts[2][1], verts[2][2], 1);
+ // P1-P2
+ edge1 = mtu[1]->common_entity(verts[1][6], verts[1][7], 1);
+ edge2 = mtu[2]->common_entity(verts[2][2], verts[2][5], 1);
+ rval = set_owners(pstat, pc[1], edge1, pc[2], edge2); CHECK_ERR(rval);
+ edge1 = mtu[1]->common_entity(verts[1][7], verts[1][8], 1);
+ edge2 = mtu[2]->common_entity(verts[2][5], verts[2][8], 1);
+ // P0-P1-P3
+ edge1 = mtu[0]->common_entity(verts[0][2], verts[0][5], 1);
+ edge2 = mtu[1]->common_entity(verts[1][0], verts[1][3], 1);
+ edge3 = mtu[3]->common_entity(verts[3][0], verts[3][3], 1);
+ assert(edge1 && edge2 && edge3);
+ rval = set_owners(pstat, pc[0], edge1, pc[1], edge2, pc[3], edge3); CHECK_ERR(rval);
+ edge1 = mtu[0]->common_entity(verts[0][5], verts[0][8], 1);
+ edge2 = mtu[1]->common_entity(verts[1][3], verts[1][6], 1);
+ edge3 = mtu[3]->common_entity(verts[3][3], verts[3][6], 1);
+ delete mtu[i];
MBErrorCode create_shared_grid(MBParallelComm **pc, MBRange *verts, MBRange *quads)
@@ -366,22 +442,9 @@
create_patch(pc[i]->get_moab(), verts[i], quads[i], 3, xyztmp, &gids[9*i]);
- // P0-P2
- unsigned char pstat = PSTATUS_SHARED | PSTATUS_INTERFACE;
- MBErrorCode rval = set_owners(pstat, pc[0], verts[0][6], pc[2], verts[2][0]);
- rval = set_owners(pstat, pc[0], verts[0][7], pc[2], verts[2][1]);
- // P1-P2
- rval = set_owners(pstat, pc[1], verts[1][7], pc[2], verts[2][5]);
- rval = set_owners(pstat, pc[1], verts[1][8], pc[2], verts[2][8]);
- // P0-P1-P3
- pstat |= PSTATUS_MULTISHARED;
- rval = set_owners(pstat, pc[0], verts[0][2], pc[1], verts[1][0], pc[3], verts[3][0]);
- rval = set_owners(pstat, pc[0], verts[0][5], pc[1], verts[1][3], pc[3], verts[3][3]);
- // P0-P1-P2-P3
- rval = set_owners(pstat, pc[0], verts[0][8], pc[1], verts[1][6],
- pc[2], verts[3][2], pc[3], verts[0][6]);
- return MB_SUCCESS;
+ MBErrorCode rval = set_owners(pc, verts, quads, false);
+ CHECK_ERR(rval);
+ return rval;
void test_pack_vertices()
@@ -1770,12 +1833,22 @@
pc[i] = new MBParallelComm(&moab[i]);
pc[i]->set_rank(i);
+ for (unsigned int j = 0; j < 4; j++) {
+ if (j == i) continue;
+ else pc[i]->get_buffers(j);
MBRange verts[4], quads[4];
MBErrorCode rval = create_shared_grid(pc, verts, quads);
std::vector<std::vector<MBEntityHandle> > L1h[4];
+ std::vector<std::vector<int> > L1p[4];
+ L1h[i].resize(4);
+ L1p[i].resize(4);
std::vector<MBEntityHandle> L2hloc[4];
std::vector<MBEntityHandle> L2hrem[4];
std::vector<unsigned int> L2p[4];
@@ -1797,7 +1870,7 @@
CHECK_ERR(rval);
assert(2 == sent_ents.size());
// set entprocs
- entprocs[0].insert(1); entprocs[1].insert(1);
+ entprocs[0].insert(2); entprocs[1].insert(2);
rval = pc[0]->pack_entities(sent_ents, buffer, buff_ptr, true, 2,
true, &entprocs);
@@ -1806,8 +1879,11 @@
// now unpack the buffer
buff_ptr = &buffer[0];
rval = pc[2]->unpack_entities(buff_ptr, true, 0, true,
- L1h[2], L2hloc[2], L2hrem[2], L2p[2], new_ents[2]);
- if (!L1h[2].empty() || !L2p[2].empty() || !new_ents[2].empty()) rval = MB_FAILURE;
+ L1h[2], L1p[2], L2hloc[2], L2hrem[2], L2p[2], new_ents[2]);
+ // all L1h lists should be empty, since we're dealing with iface
+ if (!L1h[2][0].empty() || !L1h[2][1].empty() ||
+ !L1h[2][2].empty() || !L1h[2][3].empty() ||
+ !L2p[2].empty() || !new_ents[2].empty()) rval = MB_FAILURE;
CHECK_ERR(rval);
buffer.clear(); buff_ptr = &buffer[0];
@@ -1831,8 +1907,11 @@
rval = pc[1]->unpack_entities(buff_ptr, true, 0, true,
- L1h[1], L2hloc[1], L2hrem[1], L2p[1], new_ents[1]);
- if (!L1h[1].empty() || !L2p[1].empty() || !new_ents[1].empty()) rval = MB_FAILURE;
+ L1h[1], L1p[1], L2hloc[1], L2hrem[1], L2p[1], new_ents[1]);
+ if (!L1h[1][0].empty() || !L1h[1][1].empty() ||
+ !L1h[1][2].empty() || !L1h[1][3].empty() ||
+ !L2p[1].empty() || !new_ents[1].empty()) rval = MB_FAILURE;
CHECK_ERR(rval);
entprocs[0].clear(); entprocs[1].clear();
@@ -1856,28 +1935,164 @@
rval = pc[1]->unpack_entities(buff_ptr, true, 3, true,
- if (!L1h[1].empty()) rval = MB_FAILURE;
+ !L1h[1][2].empty() || !L1h[1][3].empty())
+ rval = MB_FAILURE;
CHECK_ERR(rval);
ent_verts.clear(); sent_ents.clear();
+ // prepare for ghost communication; set all iface entities ownership
+ // stuff, so we don't need to do it explicitly using pack/unpack;
+ // passing true makes it happen for edges too
+ rval = set_owners(pc, verts, quads, true);
+ CHECK_ERR(rval);
// ghost, unshared, 2->1
+ sent_ents.insert(quads[2][3]);
+ // add vertices not already shared
+ sent_ents.insert(verts[2][4]);
+ sent_ents.insert(verts[2][7]);
+ // entprocs lists are all just 1
+ entprocs.resize(sent_ents.size());
+ entprocs[0].insert(1);
+ entprocs[1].insert(1);
+ entprocs[2].insert(1);
+ rval = pc[2]->pack_entities(sent_ents, buffer, buff_ptr, true, 1,
+ true, &entprocs);
+ CHECK_ERR(rval);
+ // now unpack the buffer
+ buff_ptr = &buffer[0];
+ rval = pc[1]->unpack_entities(buff_ptr, true, 2, false,
+ if (
+ // to P2: 2 handles per 3 entities = 6
+ L1h[1][1].size() != 6 ||
+ // to all others, 0
+ !L1h[1][0].empty() || !L1h[1][2].empty() || !L1h[1][3].empty())
+ CHECK_ERR(rval);
+ buffer.clear(); buff_ptr = &buffer[0];
+ rval = pc[1]->pack_remote_handles(L1h[1][1], L1p[1][1], 2, buffer, buff_ptr);
+ CHECK_ERR(rval);
+ rval = pc[2]->unpack_remote_handles(1, buff_ptr, false, L2hloc[2], L2hrem[2], L2p[2]);
+ CHECK_ERR(rval);
+ ent_verts.clear(); sent_ents.clear();
+ entprocs[0].clear(); entprocs[1].clear(); entprocs[2].clear();
+ buffer.clear(); buff_ptr = &buffer[0]; L1h[1][1].clear();
- // ghost, multishared, 1st message, 0->2
+ // ghost, multishared, 1st message, 2->0
+ // sent: v3, v4, v5, q0, q1
+ sent_ents.insert(quads[2][0]); sent_ents.insert(quads[2][1]);
+ sent_ents.insert(verts[2][3]); sent_ents.insert(verts[2][4]);
+ sent_ents.insert(verts[2][5]);
+ // entprocs lists are entity-dependent
+ // v3, v4, v5, q1: only to 0 (v4, v5 already on 1)
+ entprocs[0].insert(0);
+ entprocs[1].insert(0);
+ entprocs[2].insert(0);
+ entprocs[3].insert(0);
+ // q2: P0 and P1
+ entprocs[4].insert(0); entprocs[4].insert(1);
+ rval = pc[2]->pack_entities(sent_ents, buffer, buff_ptr, true, 0,
+ true, &entprocs);
+ CHECK_ERR(rval);
+ rval = pc[0]->unpack_entities(buff_ptr, true, 2, false,
+ L1h[0], L1p[0], L2hloc[0], L2hrem[0], L2p[0], new_ents[0]);
+ if (
+ // 2 handles per 5 entities = 10
+ L1h[0][1].size() != 10 ||
+ // 2 handles per 3 entities
+ L1h[0][0].size() != 6 ||
+ // none received from 3, no 4th proc
+ !L1h[0][2].empty() || !L1h[0][3].empty())
+ CHECK_ERR(rval);
+ for (int i = 0; i < 5; i++) entprocs[i].clear();
+ L1p[0][1].clear(); L1h[0][1].clear();
+ L1p[0][0].clear(); L1h[0][0].clear();
- // ghost, multishared, 2nd message, 1->2
+ // ghost, multishared, 2nd message, 1->0
+ // sent: v1, v4, v7, q0, q2
+ sent_ents.insert(quads[1][0]); sent_ents.insert(quads[1][2]);
+ sent_ents.insert(verts[1][1]); sent_ents.insert(verts[1][4]);
+ sent_ents.insert(verts[1][7]);
+ // v1, q0: only to 0
+ // v4, v7, q2: P0 and P2
+ entprocs[1].insert(0); entprocs[1].insert(2);
+ entprocs[4].insert(0); entprocs[4].insert(2);
+ rval = pc[1]->pack_entities(sent_ents, buffer, buff_ptr, true, 0,
+ true, &entprocs);
+ CHECK_ERR(rval);
+ rval = pc[0]->unpack_entities(buff_ptr, true, 1, false,
+ if (
+ L1h[0][0].size() != 10 ||
+ L1h[0][1].size() != 6 ||
+ CHECK_ERR(rval);
- // pack and unpack
+ // now pack/unpack the handles
+ // P0 -> P2
+ // xxx moved pack/unpack handles to after P2, P1 send
+ rval = pc[0]->pack_remote_handles(L1h[0][1], L1p[0][1], 2, buffer, buff_ptr);
+ CHECK_ERR(rval);
+ rval = pc[2]->unpack_remote_handles(0, buff_ptr, false, L2hloc[2], L2hrem[2], L2p[2]);
+ CHECK_ERR(rval);
+ // P0 -> P1
+ rval = pc[0]->pack_remote_handles(L1h[0][0], L1p[0][0], 1, buffer, buff_ptr);
+ CHECK_ERR(rval);
+ rval = pc[1]->unpack_remote_handles(0, buff_ptr, false, L2hloc[1], L2hrem[1], L2p[1]);
+ CHECK_ERR(rval);
void test_filter_pstatus()
