[MOAB-dev] r2927 - MOAB/branches/parallel_ghosting/parallel
tautges at mcs.anl.gov
Wed Jun 3 15:49:15 CDT 2009
Author: tautges
Date: 2009-06-03 15:49:14 -0500 (Wed, 03 Jun 2009)
New Revision: 2927
Modified:
MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp
MOAB/branches/parallel_ghosting/parallel/pcomm_unit.cpp
Log:
- in pcomm_unit:test_pack_shared_entities, create/maintain multiple
instances of moab; test packing by having one pack a message, and
another unpack it
- bug in MBParallelComm::unpack_entities, in call to update_adj's
was passing total no. of ents in message, rather than 1
Modified: MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp
--- MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp 2009-06-03 17:17:40 UTC (rev 2926)
+++ MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp 2009-06-03 20:49:14 UTC (rev 2927)
@@ -1231,7 +1231,7 @@
RRA("Couldn't make new vertex.");
// update adjacencies
- result = ru->update_adjacencies(new_h, num_ents,
+ result = ru->update_adjacencies(new_h, 1,
verts_per_entity, connect);
RRA("Failed to update adjacencies.");
Modified: MOAB/branches/parallel_ghosting/parallel/pcomm_unit.cpp
--- MOAB/branches/parallel_ghosting/parallel/pcomm_unit.cpp 2009-06-03 17:17:40 UTC (rev 2926)
+++ MOAB/branches/parallel_ghosting/parallel/pcomm_unit.cpp 2009-06-03 20:49:14 UTC (rev 2927)
@@ -219,10 +219,104 @@
delete [] elems;
-#define NVERTS 25
-#define NQUADS 16
-MBErrorCode create_shared_grid(MBInterface &moab, MBRange &verts, MBRange &quads)
+MBErrorCode set_owners(unsigned char pstatus,
+ MBParallelComm *pc0, MBEntityHandle ent0,
+ MBParallelComm *pc1, MBEntityHandle ent1,
+ MBParallelComm *pc2 = NULL, MBEntityHandle ent2 = 0,
+ MBParallelComm *pc3 = NULL, MBEntityHandle ent3 = 0)
+ int owners[MAX_SHARING_PROCS];
+ MBEntityHandle tmp_handles[MAX_SHARING_PROCS];
+ MBErrorCode result = MB_SUCCESS;
+ std::fill(owners, owners+MAX_SHARING_PROCS, -1);
+ std::fill(tmp_handles, tmp_handles+MAX_SHARING_PROCS, 0);
+ owners[0] = pc0->proc_config().proc_rank(); owners[1] = pc1->proc_config().proc_rank();
+ tmp_handles[0] = ent0; tmp_handles[1] = ent1;
+ int np = 2;
+ if (pc2) {
+ owners[2] = pc2->proc_config().proc_rank();
+ tmp_handles[2] = ent2;
+ np++;
+ if (pc3) {
+ owners[3] = pc3->proc_config().proc_rank();
+ tmp_handles[3] = ent3;
+ np++;
+ if (np > 2) {
+ result = pc0->get_moab()->tag_set_data(pc0->sharedps_tag(), &ent0, 1, owners);
+ result = pc0->get_moab()->tag_set_data(pc0->sharedhs_tag(), &ent0, 1, tmp_handles);
+ result = pc0->get_moab()->tag_set_data(pc0->pstatus_tag(), &ent0, 1, &pstatus);
+ // 2nd and greater don't own them
+ pstatus |= PSTATUS_NOT_OWNED;
+ result = pc1->get_moab()->tag_set_data(pc1->sharedps_tag(), &ent1, 1, owners);
+ result = pc1->get_moab()->tag_set_data(pc1->sharedhs_tag(), &ent1, 1, tmp_handles);
+ result = pc1->get_moab()->tag_set_data(pc1->pstatus_tag(), &ent1, 1, &pstatus);
+ if (pc2) {
+ result = pc2->get_moab()->tag_set_data(pc2->sharedps_tag(), &ent2, 1, owners);
+ result = pc2->get_moab()->tag_set_data(pc2->sharedhs_tag(), &ent2, 1, tmp_handles);
+ result = pc2->get_moab()->tag_set_data(pc2->pstatus_tag(), &ent2, 1, &pstatus);
+ if (pc3) {
+ result = pc3->get_moab()->tag_set_data(pc3->sharedps_tag(), &ent3, 1, owners);
+ result = pc3->get_moab()->tag_set_data(pc3->sharedhs_tag(), &ent3, 1, tmp_handles);
+ result = pc3->get_moab()->tag_set_data(pc3->pstatus_tag(), &ent3, 1, &pstatus);
+ else {
+ result = pc0->get_moab()->tag_set_data(pc0->sharedp_tag(), &ent0, 1, &owners[1]);
+ result = pc0->get_moab()->tag_set_data(pc0->sharedh_tag(), &ent0, 1, &tmp_handles[1]);
+ result = pc1->get_moab()->tag_set_data(pc1->sharedp_tag(), &ent1, 1, owners);
+ result = pc1->get_moab()->tag_set_data(pc1->sharedh_tag(), &ent1, 1, tmp_handles);
+ return result;
+MBErrorCode create_patch(MBInterface *moab, MBRange &verts, MBRange &quads,
+ unsigned int n, double *xyz, int *gids)
+ // create vertices/quads in square array
+ MBErrorCode result = moab->create_vertices(xyz, n*n, verts);
+ if (MB_SUCCESS != result) return result;
+ std::vector<MBEntityHandle> connect;
+ for (unsigned int j = 0; j < n-1; j++) {
+ for (unsigned int i = 0; i < n-1; i++) {
+ connect.push_back(verts[n*j+i]);
+ connect.push_back(verts[n*j+i+1]);
+ connect.push_back(verts[n*(j+1)+i+1]);
+ connect.push_back(verts[n*(j+1)+i]);
+ unsigned int nquads = (n-1)*(n-1);
+ for (unsigned int i = 0; i < nquads; i++) {
+ MBEntityHandle dum_quad;
+ result = moab->create_element(MBQUAD, &connect[4*i], 4, dum_quad);
+ quads.insert(dum_quad);
+ // global ids
+ MBTag gid_tag;
+ int dum_default = -1;
+ result = moab->tag_create(GLOBAL_ID_TAG_NAME, sizeof(int), MB_TAG_DENSE,
+ MB_TYPE_INTEGER, gid_tag, &dum_default, true);
+ result = moab->tag_set_data(gid_tag, verts, gids);
+ return result;
+MBErrorCode create_shared_grid(MBParallelComm **pc, MBRange *verts, MBRange *quads)
// P2______
// /__/__/ /|P1
@@ -243,11 +337,11 @@
// 3 4 5 2 5 21 22
// P0 0 1 2 2 19 20
- int connecti[] = {
- 0, 1, 4, 3, 1, 2, 5, 4, 3, 4, 7, 6, 4, 5, 8, 7, // P0
- 2, 9, 11, 5, 9, 10, 12, 11, 5, 11, 13, 8, 11, 12, 14, 13, // P1
- 6, 7, 15, 17, 7, 8, 13, 15, 17, 15, 16, 18, 15, 13, 14, 16, // P2
- 2, 19, 21, 5, 19, 20, 22, 21, 5, 21, 23, 8, 21, 22, 24, 23 // P3
+ int gids[] = {
+ 0, 1, 2, 3, 4, 5, 6, 7, 8, // P0
+ 2, 9, 10, 5, 11, 12, 8, 13, 14, // P1
+ 6, 7, 8, 17, 15, 13, 18, 16, 14, // P2
+ 2, 19, 20, 5, 21, 22, 8, 23, 24 // P3
double xyz[] = {
-1.0, 0.0, 0.0, -0.5, 0.0, 0.0, 0.0, 0.0, 0.0, -1.0, 0.5, 0.0,
@@ -259,244 +353,35 @@
0.5, 0.0, 0.0, 1.0, 0.0, 0.0, 0.5, 0.5, 0.0, 1.0, 0.5, 0.0,
0.5, 1.0, 0.0, 1.0, 1.0, 0.0, // n19-24
+ double xyztmp[27];
- // create vertices/quads
- MBErrorCode result = moab.create_vertices(xyz, NVERTS, verts);
- if (MB_SUCCESS != result) return result;
- MBEntityHandle connect[4*NQUADS];
- for (unsigned int i = 0; i < 4*NQUADS; i++) connect[i] = verts[connecti[i]];
- for (unsigned int i = 0; i < NQUADS; i++) {
- MBEntityHandle dum_quad;
- result = moab.create_element(MBQUAD, connect+4*i, 4, dum_quad);
- quads.insert(dum_quad);
- // global ids
- int gids[4*NQUADS];
- for (unsigned int i = 0; i < 4*NQUADS; i++) gids[i] = i;
- MBTag gid_tag;
- int dum_default = -1;
- result = moab.tag_create(GLOBAL_ID_TAG_NAME, sizeof(int), MB_TAG_DENSE,
- MB_TYPE_INTEGER, gid_tag, &dum_default, true);
- result = moab.tag_set_data(gid_tag, verts, gids);
- result = moab.tag_set_data(gid_tag, quads, gids);
- return result;
-MBErrorCode set_owners(MBInterface &moab,
- MBParallelComm &pcomm,
- MBRange &verts,
- bool edges_too)
- unsigned int owner = pcomm.proc_config().proc_rank();
- // vert owners
- MBEntityHandle dum_verts[9];
- int dum_owners[MAX_SHARING_PROCS];
- MBEntityHandle dum_handles[MAX_SHARING_PROCS];
- unsigned char pstatus[MAX_SHARING_PROCS];
- unsigned char dum_status;
- MBErrorCode result = MB_FAILURE;
- std::fill(dum_owners, dum_owners+MAX_SHARING_PROCS, -1);
- std::fill(dum_handles, dum_handles+MAX_SHARING_PROCS, 0);
- std::fill(pstatus, pstatus+MAX_SHARING_PROCS, 0x0);
- // multi-shared vertices, P0-P1-P3
- if (owner == 0)
- dum_status = (PSTATUS_INTERFACE | PSTATUS_SHARED | PSTATUS_MULTISHARED);
- else
- dum_status = (PSTATUS_INTERFACE | PSTATUS_NOT_OWNED | PSTATUS_SHARED | PSTATUS_MULTISHARED);
- dum_owners[0] = 0; dum_owners[1] = 1; dum_owners[2] = 2; dum_owners[3] = 3;
- dum_handles[0] = verts[8]; dum_handles[1] = verts[8]; dum_handles[2] = verts[8]; dum_handles[3] = verts[8];
- result = moab.tag_set_data(pcomm.sharedps_tag(), dum_handles, 1, dum_owners);
- result = moab.tag_set_data(pcomm.sharedhs_tag(), dum_handles, 1, dum_handles);
- result = moab.tag_set_data(pcomm.pstatus_tag(), dum_handles, 1, &dum_status);
- dum_owners[3] = -1;
- dum_handles[3] = 0;
- dum_handles[0] = verts[5]; dum_handles[1] = verts[5]; dum_handles[2] = verts[5];
- dum_handles[0] = verts[2]; dum_handles[1] = verts[2]; dum_handles[2] = verts[2];
- // shared, P0-P2
- dum_verts[0] = verts[6]; dum_verts[1] = verts[7]; dum_verts[2] = 0; dum_verts[3] = 0;
- if (owner == 0) {
- dum_status = (PSTATUS_INTERFACE | PSTATUS_SHARED);
- dum_owners[0] = 2; dum_owners[1] = 2; dum_owners[2] = -1;
- else {
- dum_owners[0] = 0; dum_owners[1] = 0; dum_owners[2] = -1;
- dum_status = (PSTATUS_INTERFACE | PSTATUS_SHARED | PSTATUS_NOT_OWNED);
- result = moab.tag_set_data(pcomm.sharedp_tag(), dum_verts, 2, dum_owners);
- result = moab.tag_set_data(pcomm.sharedh_tag(), dum_verts, 2, dum_verts);
- // shared, P1-P2
- dum_verts[0] = verts[13]; dum_verts[1] = verts[14]; dum_verts[2] = 0;
- if (owner == 1) {
- else {
- dum_owners[0] = 1; dum_owners[1] = 1; dum_owners[2] = -1;
- if (edges_too) {
- MBRange tmpr;
- // P0 - P1 - P3
- pstatus[0] = (PSTATUS_INTERFACE | PSTATUS_SHARED | PSTATUS_MULTISHARED);
- dum_verts[0] = verts[8]; dum_verts[1] = verts[5];
- result = moab.get_adjacencies(verts, 1, true, tmpr);
- if (MB_SUCCESS != result || tmpr.size() != 1) return MB_FAILURE;
- dum_handles[0] = dum_handles[1] = dum_handles[2] = *tmpr.begin(); tmpr.clear();
- if (owner != 0)
- pstatus[0] |= PSTATUS_NOT_OWNED;
- dum_owners[0] = 0; dum_owners[1] = 1; dum_owners[2] = 3;
- result = moab.tag_set_data(pcomm.pstatus_tag(), dum_handles, 1, pstatus);
- dum_verts[0] = verts[5]; dum_verts[1] = verts[2];
- // P0 - P2
- pstatus[0] = (PSTATUS_INTERFACE | PSTATUS_SHARED);
- dum_handles[0] = *tmpr.begin(); tmpr.clear();
- dum_verts[0] = verts[7]; dum_verts[1] = verts[8];
- dum_handles[1] = *tmpr.begin(); tmpr.clear();
- dum_handles[2] = 0;
- if (owner == 0) {
+ // create the test mesh above
+ for (unsigned int i = 0; i < 4; i++) {
+ for (unsigned int j = 0; j < 9; j++) {
+ xyztmp[3*j] = xyz[3*gids[9*i+j]];
+ xyztmp[3*j+1] = xyz[3*gids[9*i+j]+1];
+ xyztmp[3*j+2] = xyz[3*gids[9*i+j]+2];
- else {
- result = moab.tag_set_data(pcomm.sharedp_tag(), dum_handles, 2, dum_owners);
- result = moab.tag_set_data(pcomm.sharedh_tag(), dum_handles, 2, dum_handles);
- result = moab.tag_set_data(pcomm.pstatus_tag(), dum_handles, 2, pstatus);
- // P1 - P2
- dum_verts[0] = verts[8]; dum_verts[1] = verts[13];
- if (owner == 1) {
- else {
+ create_patch(pc[i]->get_moab(), verts[i], quads[i], 3, xyztmp, &gids[9*i]);
- return result;
- MBRange &ents,
- unsigned char pstat,
- std::vector<int> &procs,
- std::vector<MBEntityHandle> &handles)
- int owners[MAX_SHARING_PROCS];
- MBEntityHandle tmp_handles[MAX_SHARING_PROCS];
- int negone = -1;
- MBEntityHandle zeroh = 0;
- assert(handles.size() == ents.size()*procs.size());
- MBErrorCode result = MB_SUCCESS;
- std::fill(owners, owners+MAX_SHARING_PROCS, -1);
- std::fill(tmp_handles, tmp_handles+MAX_SHARING_PROCS, 0);
- std::copy(procs.begin(), procs.end(), owners);
- std::vector<MBEntityHandle>::iterator vit = handles.begin();
- for (MBRange::iterator rit = ents.begin(); rit != ents.end(); rit++) {
- if (procs.size() > 1 || procs.empty()) {
- result = moab.tag_set_data(pcomm.sharedp_tag(), &(*rit), 1, &negone);
- result = moab.tag_set_data(pcomm.sharedh_tag(), &(*rit), 1, &zeroh);
- if (procs.size() > 1) {
- result = moab.tag_set_data(pcomm.sharedps_tag(), &(*rit), 1, owners);
- for (unsigned int i = 0; i < procs.size(); i++) {
- assert(vit != handles.end());
- tmp_handles[i] = *vit++;
- result = moab.tag_set_data(pcomm.sharedhs_tag(), &(*rit), 1, tmp_handles);
- else {
- result = moab.tag_set_data(pcomm.sharedp_tag(), &(*rit), 1, owners);
- if (vit != handles.end()) tmp_handles[0] = *vit++;
- result = moab.tag_set_data(pcomm.sharedh_tag(), &(*rit), 1, tmp_handles);
- result = moab.tag_delete_data(pcomm.sharedps_tag(), &(*rit), 1);
- result = moab.tag_delete_data(pcomm.sharedhs_tag(), &(*rit), 1);
- result = moab.tag_set_data(pcomm.pstatus_tag(), &(*rit), 1, &pstat);
- std::fill(owners, owners+procs.size(), -1);
- std::fill(tmp_handles, tmp_handles+procs.size(), 0);
+ // P0-P2
+ unsigned char pstat = PSTATUS_SHARED | PSTATUS_INTERFACE;
+ MBErrorCode rval = set_owners(pstat, pc[0], verts[0][6], pc[2], verts[2][0]);
+ rval = set_owners(pstat, pc[0], verts[0][7], pc[2], verts[2][1]);
+ // P1-P2
+ rval = set_owners(pstat, pc[1], verts[1][7], pc[2], verts[2][5]);
+ rval = set_owners(pstat, pc[1], verts[1][8], pc[2], verts[2][8]);
+ // P0-P1-P3
+ pstat |= PSTATUS_MULTISHARED;
+ rval = set_owners(pstat, pc[0], verts[0][2], pc[1], verts[1][0], pc[3], verts[3][0]);
+ rval = set_owners(pstat, pc[0], verts[0][5], pc[1], verts[1][3], pc[3], verts[3][3]);
+ // P0-P1-P2-P3
+ rval = set_owners(pstat, pc[0], verts[0][8], pc[1], verts[1][6],
+ pc[2], verts[3][2], pc[3], verts[0][6]);
- return result;
+ return MB_SUCCESS;
void test_pack_vertices()
@@ -1857,7 +1742,7 @@
-MBErrorCode get_entities(MBInterface &mb,
+MBErrorCode get_entities(MBInterface *mb,
std::vector<MBEntityHandle> &ent_verts,
int verts_per_entity, int dim,
MBRange &ents)
@@ -1867,7 +1752,7 @@
MBRange dum_ents;
MBErrorCode result;
for (unsigned int i = 0; i < num_ents; i++) {
- result = mb.get_adjacencies(&ent_verts[verts_per_entity*i], verts_per_entity,
+ result = mb->get_adjacencies(&ent_verts[verts_per_entity*i], verts_per_entity,
dim, true, dum_ents);
CHECK_ERR(result);
assert(dum_ents.size() == 1);
@@ -1879,20 +1764,22 @@
void test_pack_shared_entities()
- MBRange::iterator i;
- MBCore moab;
- MBInterface& mb = moab;
- MBParallelComm *pcomm = new MBParallelComm( &moab );
- MBErrorCode rval;
- std::vector<std::vector<MBEntityHandle> > L1h;
- std::vector<MBEntityHandle> L2hloc;
- std::vector<MBEntityHandle> L2hrem;
- std::vector<unsigned int> L2p;
- MBRange new_ents;
- // create some mesh, from proc 0's perspective
- MBRange verts, quads;
- create_shared_grid(mb, verts, quads);
+ MBCore moab[4];
+ MBInterface *mb[] = {&moab[0], &moab[1], &moab[2], &moab[3]};
+ MBParallelComm *pc[4];
+ pc[i] = new MBParallelComm(&moab[i]);
+ pc[i]->set_rank(i);
+ MBRange verts[4], quads[4];
+ MBErrorCode rval = create_shared_grid(pc, verts, quads);
+ std::vector<std::vector<MBEntityHandle> > L1h[4];
+ std::vector<MBEntityHandle> L2hloc[4];
+ std::vector<MBEntityHandle> L2hrem[4];
+ std::vector<unsigned int> L2p[4];
+ MBRange new_ents[4];
MBRange sent_ents;
std::vector<MBEntityHandle> ent_verts, dum_handles;
std::vector<int> dum_procs;
@@ -1903,94 +1790,77 @@
// interface, shared, 0->2
- pcomm->set_rank(0);
- rval = set_owners(moab, *pcomm, verts, false);
- CHECK_ERR(rval);
// get edges that we want
- ent_verts.push_back(verts[6]); ent_verts.push_back(verts[7]);
- ent_verts.push_back(verts[7]); ent_verts.push_back(verts[8]);
- rval = get_entities(mb, ent_verts, 2, 1, sent_ents);
+ ent_verts.push_back(verts[0][6]); ent_verts.push_back(verts[0][7]);
+ ent_verts.push_back(verts[0][7]); ent_verts.push_back(verts[0][8]);
+ rval = get_entities(mb[0], ent_verts, 2, 1, sent_ents);
CHECK_ERR(rval);
assert(2 == sent_ents.size());
// set entprocs
entprocs[0].insert(1); entprocs[1].insert(1);
- rval = pcomm->pack_entities(sent_ents, buffer, buff_ptr, true, 2,
+ rval = pc[0]->pack_entities(sent_ents, buffer, buff_ptr, true, 2,
true, &entprocs);
CHECK_ERR(rval);
// now unpack the buffer
- pcomm->set_rank(2);
- CHECK_ERR(rval);
buff_ptr = &buffer[0];
- rval = pcomm->unpack_entities(buff_ptr, true, 0, true,
- L1h, L2hloc, L2hrem, L2p, new_ents);
- if (!L1h.empty() || !L2p.empty() || !new_ents.empty()) rval = MB_FAILURE;
+ rval = pc[2]->unpack_entities(buff_ptr, true, 0, true,
+ L1h[2], L2hloc[2], L2hrem[2], L2p[2], new_ents[2]);
+ if (!L1h[2].empty() || !L2p[2].empty() || !new_ents[2].empty()) rval = MB_FAILURE;
CHECK_ERR(rval);
- ent_verts.clear(); sent_ents.clear();
- entprocs[0].clear(); entprocs[1].clear();
buffer.clear(); buff_ptr = &buffer[0];
// interface, multishared, 1st message, 0->1
- ent_verts.push_back(verts[8]); ent_verts.push_back(verts[5]);
- ent_verts.push_back(verts[5]); ent_verts.push_back(verts[2]);
+ ent_verts.clear();
+ ent_verts.push_back(verts[0][8]); ent_verts.push_back(verts[0][5]);
+ ent_verts.push_back(verts[0][5]); ent_verts.push_back(verts[0][2]);
CHECK_ERR(rval);
// sending these edges to 1 and 3
entprocs[0].insert(1); entprocs[0].insert(3);
entprocs[1].insert(1); entprocs[1].insert(3);
- rval = pcomm->pack_entities(sent_ents, buffer, buff_ptr, true, 1,
+ rval = pc[0]->pack_entities(sent_ents, buffer, buff_ptr, true, 1,
true, &entprocs);
CHECK_ERR(rval);
- pcomm->set_rank(1);
- CHECK_ERR(rval);
+ rval = pc[1]->unpack_entities(buff_ptr, true, 0, true,
+ L1h[1], L2hloc[1], L2hrem[1], L2p[1], new_ents[1]);
+ if (!L1h[1].empty() || !L2p[1].empty() || !new_ents[1].empty()) rval = MB_FAILURE;
CHECK_ERR(rval);
+ sent_ents.clear();
// interface, multishared, 2nd message, 3->1
- pcomm->set_rank(3);
// sending these edges to 0 and 1
+ ent_verts.push_back(verts[3][6]); ent_verts.push_back(verts[3][3]);
+ ent_verts.push_back(verts[3][3]); ent_verts.push_back(verts[3][0]);
+ rval = get_entities(mb[3], ent_verts, 2, 1, sent_ents);
+ CHECK_ERR(rval);
+ assert(2 == sent_ents.size());
entprocs[0].insert(0); entprocs[0].insert(1);
entprocs[1].insert(0); entprocs[1].insert(1);
- // need to reset sharing data on edges, since it was set in prev unpack
- rval = set_owners(moab, *pcomm, sent_ents, 0x0, dum_procs, dum_handles);
+ rval = pc[3]->pack_entities(sent_ents, buffer, buff_ptr, true, 1,
true, &entprocs);
CHECK_ERR(rval);
- dum_procs.push_back(0); dum_procs.push_back(1); dum_procs.push_back(3);
- dum_handles.push_back(*sent_ents.begin()); dum_handles.push_back(*sent_ents.begin()); dum_handles.push_back(0);
- dum_handles.push_back(*sent_ents.rbegin()); dum_handles.push_back(*sent_ents.rbegin()); dum_handles.push_back(0);
- unsigned char pstat =
- PSTATUS_SHARED | PSTATUS_MULTISHARED | PSTATUS_INTERFACE | PSTATUS_NOT_OWNED;
- rval = set_owners(moab, *pcomm, sent_ents, pstat, dum_procs, dum_handles);
- CHECK_ERR(rval);
- rval = pcomm->unpack_entities(buff_ptr, true, 3, true,
- if (!L1h.empty()) rval = MB_FAILURE;
+ rval = pc[1]->unpack_entities(buff_ptr, true, 3, true,
+ if (!L1h[1].empty()) rval = MB_FAILURE;
CHECK_ERR(rval);
- ent_verts.clear(); sent_ents.clear(); dum_procs.clear(); dum_handles.clear();
+ ent_verts.clear(); sent_ents.clear();
