[MOAB-dev] r2902 - MOAB/trunk/tools/iMesh/python
jvporter at wisc.edu jvporter at wisc.edu
Wed May 20 15:42:55 CDT 2009
Author: jvporter
Date: 2009-05-20 15:42:54 -0500 (Wed, 20 May 2009)
New Revision: 2902
Modified:
   MOAB/trunk/tools/iMesh/python/iMesh.c
   MOAB/trunk/tools/iMesh/python/iMesh_Python.h
   MOAB/trunk/tools/iMesh/python/iMesh_entSet.c
   MOAB/trunk/tools/iMesh/python/iMesh_iter.c
Log:
* Added slightly friendlier Numpy array creation
* Fixed issues with incorrect base for some Numpy arrays
Modified: MOAB/trunk/tools/iMesh/python/iMesh.c
--- MOAB/trunk/tools/iMesh/python/iMesh.c	2009-05-20 18:48:43 UTC (rev 2901)
+++ MOAB/trunk/tools/iMesh/python/iMesh.c	2009-05-20 20:42:54 UTC (rev 2902)
@@ -162,7 +162,7 @@
         return NULL;
     npy_intp dims[] = {4,4};
-    return PyArray_NewFromMallocData(2,dims,NPY_INT,adjtable);
+    return PyArray_NewFromMalloc(2,dims,NPY_INT,adjtable);
 static PyObject *
@@ -229,7 +229,7 @@
         return NULL;
     npy_intp dims[] = {size};
-    return PyArray_NewFromMallocData(1,dims,NPY_IBASEENT,entities);
+    return PyArray_NewFromMalloc(1,dims,NPY_IBASEENT,entities);
 static PyObject *
@@ -272,7 +272,7 @@
             outer = size;
         /* TODO: think about this */
         npy_intp dims[] = {outer,coords_size/outer};
-        return PyArray_NewFromMallocData(2,dims,NPY_DOUBLE,coords);
+        return PyArray_NewFromMalloc(2,dims,NPY_DOUBLE,coords);
     else if(iBaseEntity_Check(obj))
@@ -283,7 +283,7 @@
             return NULL;
         npy_intp dims[] = {3};
-        return PyArray_NewFromMallocData(1,dims,NPY_DOUBLE,v);
+        return PyArray_NewFromMalloc(1,dims,NPY_DOUBLE,v);
     else
@@ -319,7 +319,7 @@
             return NULL;
         npy_intp dims[] = {topo_size};
-        return PyArray_NewFromMallocData(1,dims,NPY_UINT,topos);
+        return PyArray_NewFromMalloc(1,dims,NPY_UINT,topos);
@@ -366,7 +366,7 @@
             return NULL;
         npy_intp dims[] = {type_size};
-        return PyArray_NewFromMallocData(1,dims,NPY_UINT,types);
+        return PyArray_NewFromMalloc(1,dims,NPY_UINT,types);
@@ -421,11 +421,11 @@
         dims[0] = adj_size;
         PyTuple_SET_ITEM(pair, 0,
-            PyArray_NewFromMallocData(1,dims,NPY_IBASEENT,adj));
+            PyArray_NewFromMalloc(1,dims,NPY_IBASEENT,adj));
         dims[0] = offsets_size;
         PyTuple_SET_ITEM(pair, 1,
-            PyArray_NewFromMallocData(1,dims,NPY_INT,offsets));
+            PyArray_NewFromMalloc(1,dims,NPY_INT,offsets));
         return pair;
@@ -441,7 +441,7 @@
             return NULL;
         npy_intp dims[] = {adj_size};
-        return PyArray_NewFromMallocData(1,dims,NPY_IBASEENT,adj);
+        return PyArray_NewFromMalloc(1,dims,NPY_IBASEENT,adj);
     else
@@ -486,11 +486,11 @@
         dims[0] = adj_size;
         return pair;
@@ -506,7 +506,7 @@
             return NULL;
     else
@@ -551,19 +551,19 @@
     dims[0] = ent_size;
     PyTuple_SET_ITEM(tup, 0,
-        PyArray_NewFromMallocData(1,dims,NPY_IBASEENT,entities));
+        PyArray_NewFromMalloc(1,dims,NPY_IBASEENT,entities));
     dims[0] = adj_size;
     PyTuple_SET_ITEM(tup, 1,
-        PyArray_NewFromMallocData(1,dims,NPY_IBASEENT,adj_ents));
+        PyArray_NewFromMalloc(1,dims,NPY_IBASEENT,adj_ents));
     dims[0] = ind_size;
     PyTuple_SET_ITEM(tup, 2,
-        PyArray_NewFromMallocData(1,dims,NPY_INT,indices));
+        PyArray_NewFromMalloc(1,dims,NPY_INT,indices));
     dims[0] = off_size;
     PyTuple_SET_ITEM(tup, 3,
     return tup;
@@ -714,7 +714,7 @@
             return NULL;
         npy_intp dims[] = {ent_size};
     else if( (vertices = PyArray_TryFromObject(data,NPY_DOUBLE,1,1)) != NULL)
@@ -811,11 +811,11 @@
     dims[0] = ent_size;
     dims[0] = stat_size;
-        PyArray_NewFromMallocData(1,dims,NPY_INT,status));
+        PyArray_NewFromMalloc(1,dims,NPY_INT,status));
     return pair;
@@ -1166,7 +1166,7 @@
             if(!checkError(self->mesh,err))
-                ret = PyArray_NewFromMallocData(1,dims,NPY_INT,data);
+                ret = PyArray_NewFromMalloc(1,dims,NPY_INT,data);
         else if(type == iBase_DOUBLE)
@@ -1179,7 +1179,7 @@
-                ret = PyArray_NewFromMallocData(1,dims,NPY_DOUBLE,data);
+                ret = PyArray_NewFromMalloc(1,dims,NPY_DOUBLE,data);
         else if(type == iBase_ENTITY_HANDLE)
@@ -1192,7 +1192,7 @@
-                ret = PyArray_NewFromMallocData(1,dims,NPY_IBASEENT,data);
+                ret = PyArray_NewFromMalloc(1,dims,NPY_IBASEENT,data);
         else /* iBase_BYTES */
@@ -1205,7 +1205,7 @@
-                ret = PyArray_NewFromMallocData(1,dims,NPY_BYTE,data);
+                ret = PyArray_NewFromMalloc(1,dims,NPY_BYTE,data);
@@ -1253,7 +1253,7 @@
             if(checkError(self->mesh,err))
                 return NULL;
-            return PyArray_NewFromMallocData(1,dims,NPY_BYTE,data);
+            return PyArray_NewFromMalloc(1,dims,NPY_BYTE,data);
@@ -1296,7 +1296,7 @@
                 return NULL;
     else
@@ -1340,10 +1340,8 @@
-    PyObject *arr = PyArray_NewFromMallocData(1,dims,NPY_IMESHTAG,tags);
-    Py_INCREF(self);
-    PyArray_BASE(arr) = (PyObject*)self;
-    return arr;
+    return PyArray_NewFromMallocBase(1,dims,NPY_IMESHTAG,tags,
+                                     (PyObject*)self);
 static PyObject *
@@ -1371,7 +1369,7 @@
-        iBase_EntityHandle entity =iBaseEntity_GetHandle(obj);
+        iBase_EntityHandle entity = iBaseEntity_GetHandle(obj);
         iMesh_rmvTag(self->mesh,entity,tag->handle,&err);
     else
@@ -1540,7 +1538,8 @@
 static PyObject *
 iMeshEntSetArr_getitem(void *data,void *arr)
-    iMeshObject *mesh = (iMeshObject*)PyArray_BASE(arr);
+    ArrDealloc_Object *b = (ArrDealloc_Object*)PyArray_BASE(arr);
+    iMeshObject *mesh = (iMeshObject*)b->base;
     iMeshEntitySet_Object *o = iMeshEntitySet_New();
     o->set.handle = *(iBase_EntitySetHandle*)data;
@@ -1552,7 +1551,8 @@
 static PyObject *
 iMeshTagArr_getitem(void *data,void *arr)
     iMeshTag_Object *o = iMeshTag_New();
     o->tag.handle = *(iBase_TagHandle*)data;
@@ -1574,13 +1574,15 @@
 ArrDeallocObj_dealloc(ArrDealloc_Object *self)
     free(self->memory);
+    Py_XDECREF(self->base);
     self->ob_type->tp_free((PyObject *)self);
 static PyTypeObject ArrDealloc_Type = {
     PyObject_HEAD_INIT(NULL)
     0,                                          /* ob_size */
-    "mydeallocator",                            /* tp_name */
+    "arrdealloc",                               /* tp_name */
     sizeof(ArrDealloc_Object),                  /* tp_basicsize */
     0,                                          /* tp_itemsize */
     (destructor)ArrDeallocObj_dealloc,          /* tp_dealloc */
@@ -1603,13 +1605,18 @@
 PyObject *
-PyArray_NewFromMallocData(int nd,npy_intp *dims,int typenum,void *data)
+PyArray_NewFromMallocBaseStrided(int nd,npy_intp *dims,npy_intp *strides,
+                                 int typenum,void *data,PyObject *base)
     ArrDealloc_Object *newobj;
-    PyObject *arr =  PyArray_New(&PyArray_Type, nd, dims, typenum, NULL,
-                                 data, 0, NPY_CARRAY, NULL);
-    newobj = PyObject_New(ArrDealloc_Object, &ArrDealloc_Type);
+    PyObject *arr = PyArray_New(&PyArray_Type,nd,dims,typenum,strides,data,0,
+                                NPY_CARRAY,NULL);
+    newobj = PyObject_New(ArrDealloc_Object,&ArrDealloc_Type);
     newobj->memory = data;
+    Py_XINCREF(base);
+    newobj->base = base;
     PyArray_BASE(arr) = (PyObject*)newobj;
     return arr;
Modified: MOAB/trunk/tools/iMesh/python/iMesh_Python.h
--- MOAB/trunk/tools/iMesh/python/iMesh_Python.h	2009-05-20 18:48:43 UTC (rev 2901)
+++ MOAB/trunk/tools/iMesh/python/iMesh_Python.h	2009-05-20 20:42:54 UTC (rev 2902)
@@ -14,13 +14,23 @@
 typedef struct
     PyObject_HEAD
+    PyObject *base;
     void *memory;
 } ArrDealloc_Object;
+#define PyArray_NewFromMalloc(nd,dims,typenum,data) \
+    PyArray_NewFromMallocBaseStrided(nd,dims,NULL,typenum,data,0)
+#define PyArray_NewFromMallocBase(nd,dims,typenum,data,base) \
+    PyArray_NewFromMallocBaseStrided(nd,dims,NULL,typenum,data,base)
+#define PyArray_NewFromMallocStrided(nd,dims,strides,typenum,data) \
+    PyArray_NewFromMallocBaseStrided(nd,dims,strides,typenum,data,0)
 PyObject *
-PyArray_NewFromMallocData(int nd,npy_intp *dims,int typenum,void *data);
+                                 int typenum,void *data,PyObject *base);
 PyObject *
 PyArray_TryFromObject(PyObject *obj,int typenum,int min_depth,int max_depth);
Modified: MOAB/trunk/tools/iMesh/python/iMesh_entSet.c
--- MOAB/trunk/tools/iMesh/python/iMesh_entSet.c	2009-05-20 18:48:43 UTC (rev 2901)
+++ MOAB/trunk/tools/iMesh/python/iMesh_entSet.c	2009-05-20 20:42:54 UTC (rev 2902)
@@ -47,7 +47,8 @@
         return NULL;
     npy_intp dims[] = {sets_size};
-    return PyArray_NewFromMallocData(1,dims,NPY_IBASEENTSET,sets);
+    return PyArray_NewFromMallocBase(1,dims,NPY_IMESHENTSET,sets,
+                                     (PyObject*)self->mesh);
 static PyObject *
@@ -153,8 +154,7 @@
         npy_intp dims[] = {contains_size};
         npy_intp strides[] = {sizeof(int)/sizeof(npy_bool)};
-        return PyArray_New(&PyArray_Type,1,dims,NPY_BOOL,strides,contains,
-                           0,NPY_CARRAY|NPY_OWNDATA,NULL); /* TODO: careful! */
+        return PyArray_NewFromMallocStrided(1,dims,strides,NPY_BOOL,contains);
     else if(iBaseEntitySet_Check(obj))
@@ -283,10 +283,8 @@
         return NULL;
-    PyObject *o = PyArray_NewFromMallocData(1,dims,NPY_IMESHENTSET,sets);
-    Py_INCREF(self->mesh);
-    PyArray_BASE(o) = (PyObject*)self->mesh;
-    return o;
 static PyObject *
@@ -304,10 +302,8 @@
         return NULL;
-    return o;
 static PyObject *
Modified: MOAB/trunk/tools/iMesh/python/iMesh_iter.c
--- MOAB/trunk/tools/iMesh/python/iMesh_iter.c	2009-05-20 18:48:43 UTC (rev 2901)
+++ MOAB/trunk/tools/iMesh/python/iMesh_iter.c	2009-05-20 20:42:54 UTC (rev 2902)
@@ -89,7 +89,7 @@
             return NULL;
     else
