[MOAB-dev] MOAB check for *AMD64-32* failed.
    Nightly Test
    kraftche at cae.wisc.edu
    Tue May 19 02:01:56 CDT 2009
Making check in mhdf
make[1]: Entering directory `/home/jason/moab/test/AMD64-32/mhdf'
make[1]: Nothing to be done for `check'.
make[1]: Leaving directory `/home/jason/moab/test/AMD64-32/mhdf'
Making check in .
make[1]: Entering directory `/home/jason/moab/test/AMD64-32'
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT MBReaderWriterSet.lo -MD -MP -MF .deps/MBReaderWriterSet.Tpo -c -o MBReaderWriterSet.lo ../src/MBReaderWriterSet.cpp
 c++ -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBReaderWriterSet.lo -MD -MP -MF .deps/MBReaderWriterSet.Tpo -c ../src/MBReaderWriterSet.cpp -o MBReaderWriterSet.o
In file included from ../src/MBReaderWriterSet.cpp:27:
../src/ReadMCNP5.hpp:34: error: floating-point literal cannot appear in a constant-expression
../src/ReadMCNP5.hpp:34: error: ISO C++ forbids initialization of member constant âpiâ of non-integral type âconst doubleâ
../src/ReadMCNP5.hpp:35: error: floating-point literal cannot appear in a constant-expression
../src/ReadMCNP5.hpp:35: error: ISO C++ forbids initialization of member constant âc2piâ of non-integral type âconst doubleâ
../src/ReadMCNP5.hpp:36: error: floating-point literal cannot appear in a constant-expression
../src/ReadMCNP5.hpp:36: error: ISO C++ forbids initialization of member constant âcpiâ of non-integral type âconst doubleâ
../src/ReadMCNP5.hpp:66: error: ISO C++ 1998 does not support âlong longâ
../src/ReadMCNP5.hpp:71: error: ISO C++ 1998 does not support âlong longâ
../src/ReadMCNP5.hpp:127: error: ISO C++ 1998 does not support âlong longâ
../src/ReadMCNP5.hpp:128: error: ISO C++ 1998 does not support âlong longâ
../src/ReadMCNP5.hpp:142: error: ISO C++ 1998 does not support âlong longâ
../src/ReadMCNP5.hpp:143: error: ISO C++ 1998 does not support âlong longâ
make[1]: *** [MBReaderWriterSet.lo] Error 1
make[1]: Leaving directory `/home/jason/moab/test/AMD64-32'
make: *** [check-recursive] Error 1
