[MOAB-dev] r2898 - MOAB/trunk
bmsmith6 at wisc.edu bmsmith6 at wisc.edu
Mon May 18 21:01:04 CDT 2009
Author: bmsmith
Date: 2009-05-18 21:01:04 -0500 (Mon, 18 May 2009)
New Revision: 2898
Added:
   MOAB/trunk/ReadMCNP5.cpp
   MOAB/trunk/ReadMCNP5.hpp
Modified:
   MOAB/trunk/MBReaderWriterSet.cpp
   MOAB/trunk/Makefile.am
Log:
first attempt at MCNP5 mesh tally reader
Modified: MOAB/trunk/MBReaderWriterSet.cpp
--- MOAB/trunk/MBReaderWriterSet.cpp	2009-05-18 23:06:12 UTC (rev 2897)
+++ MOAB/trunk/MBReaderWriterSet.cpp	2009-05-19 02:01:04 UTC (rev 2898)
@@ -24,6 +24,7 @@
 #include "ReadSTL.hpp"
 #include "ReadGmsh.hpp"
 #include "ReadIDEAS.hpp"
+#include "ReadMCNP5.hpp"
 #include "ReadSms.hpp"
 #include "Tqdcfr.hpp"
 #include "ReadTetGen.hpp"
@@ -75,6 +76,8 @@
   register_factory( ReadIDEAS::factory, NULL, "IDEAS format", "unv", "UNV" );
+  register_factory( ReadMCNP5::factory, NULL, "MCNP5 format", "meshtal", "MESHTAL" );
   register_factory( ReadVtk::factory, WriteVtk::factory, "Kitware VTK", "vtk", "VTK" );
   register_factory( ReadSms::factory, NULL, "RPI SMS", "sms", "SMS" );
Modified: MOAB/trunk/Makefile.am
--- MOAB/trunk/Makefile.am	2009-05-18 23:06:12 UTC (rev 2897)
+++ MOAB/trunk/Makefile.am	2009-05-19 02:01:04 UTC (rev 2898)
@@ -174,6 +174,8 @@
   ReadVtk.hpp \
   ReadIDEAS.cpp \
   ReadIDEAS.hpp \
+  ReadMCNP5.cpp \
+  ReadMCNP5.hpp \
   ReadTetGen.cpp \
   ReadTetGen.hpp \
   ScdElementData.cpp \
Added: MOAB/trunk/ReadMCNP5.cpp
--- MOAB/trunk/ReadMCNP5.cpp	                        (rev 0)
+++ MOAB/trunk/ReadMCNP5.cpp	2009-05-19 02:01:04 UTC (rev 2898)
@@ -0,0 +1,958 @@
+ * \class ReadMCNP5
+ * \brief  Read output from MCNP5
+ * \author Brandon Smith
+#include "MBInterface.hpp"
+#include "MBReadUtilIface.hpp"
+#include "MBInternals.hpp" // for MB_START_ID
+#include "MBRange.hpp"
+#include "FileOptions.hpp"
+#include <iostream>
+#include <sstream>
+#include <fstream>
+#include <vector>
+#include <cstdlib>
+#include "assert.h"
+#include "math.h"
+// this setup is mostly copied from ReadSms.cpp
+MBReaderIface* ReadMCNP5::factory( MBInterface* iface ) {
+  return new ReadMCNP5( iface );
+ReadMCNP5::ReadMCNP5(MBInterface* impl)
+  : MBI(impl) {
+    assert( NULL!=impl);
+    void *ptr = 0;
+    MBI->query_interface("MBReadUtilIface", &ptr);
+    assert( NULL!=ptr );
+    readMeshIface = reinterpret_cast<MBReadUtilIface*>(ptr);
+ReadMCNP5::~ReadMCNP5() {
+  if (readMeshIface) {
+    MBI->release_interface("MBReadUtilIface", readMeshIface);
+    readMeshIface = 0;
+MBErrorCode ReadMCNP5::load_file(const char* fname,
+                                 MBEntityHandle& input_meshset,
+                                 const FileOptions& options,
+                                 const char* set_tag_name,       // not used
+				 const int* material_set_list,   // not used
+                                 const int num_material_sets ) { // not used
+  std::cout << "begin MCNP5 reader" << std::endl;
+  // no support for reading a subset of the file
+  if (set_tag_name) {
+    readMeshIface->report_error( "Reading subset of files not supported for meshtal." );
+    return MB_UNSUPPORTED_OPERATION;
+  bool debug=true;
+  MBErrorCode result;
+  std::fstream file;
+  file.open( fname, std::fstream::in );
+  char line[10000];
+  // Options specify if this file will be averaged with a file already existing in
+  // the interface.
+  bool average;
+  if ( MB_SUCCESS ==options.get_null_option("AVERAGE_TALLY") )
+    average = true;
+  else
+    average = false;
+  // Create tags
+  MBTag date_and_time_tag,
+        title_tag,
+	nps_tag,
+	tally_number_tag,
+	tally_comment_tag,
+        tally_particle_tag,
+	tally_coord_sys_tag,
+	tally_tag,
+	error_tag;
+  result = create_tags( date_and_time_tag,
+                        title_tag,
+			nps_tag,
+                        tally_number_tag,
+			tally_tag,
+			error_tag );
+    assert(MB_SUCCESS == result);
+  // This info exists only at the top of each meshtal file
+  // define characteristics of the entire file
+  char date_and_time[100] = "";
+  char title[100] = "";
+  // this file's number of particles
+  unsigned long long int nps;
+  // sum of this file's and existing file's nps for averaging
+  unsigned long long int new_nps;
+  // read the file header
+  result = read_file_header( file,
+                             debug,
+                             date_and_time,
+			     title,
+			     nps );
+  // blank line
+  file.getline(line, 10000);
+  // Everything stored in the file being read will be in the output_meshset.
+  // if this is being saved in MOAB, set header tags
+  MBEntityHandle output_meshset;
+  if (!average) {
+    result = MBI->create_meshset( MESHSET_SET, output_meshset );
+    result = set_header_tags( output_meshset,
+                              date_and_time,
+                              title,
+		              nps,
+			      date_and_time_tag,
+                              title_tag,
+		              nps_tag );
+  // This info is repeated for each tally in the meshtal file.
+  // If averaging, nps will hold the sum of particles simulated in both tallies.
+  while( !file.eof() ) {
+    // define characteristics of this tally
+    unsigned int        tally_number;
+    char                tally_comment[100] = "";
+    particle            tally_particle;
+    coordinate_system   tally_coord_sys;
+    std::vector<double> planes[3];
+    int                 n_chopped_x2_planes;
+    // read tally header
+    result = read_tally_header( file,
+                                debug,
+                                tally_number,
+				tally_comment,
+                                tally_particle );
+    // blank line
+    // read mesh planes
+    result = read_mesh_planes( file,
+                               debug,
+			       planes,
+			       tally_coord_sys );
+    // get energy boundaries
+    std::string a = line;
+    if (debug) std::cout << "Energy bin boundaries:=| " << a << std::endl;
+    // blank
+    // column headers
+    // If using cylidrical mesh, it may be necessary to chop off the last theta element.
+    // We chop off the last theta plane because the elements will be wrong and skew up
+    // the tree building code. This is
+    // because the hex elements are a linear approximation to the cylindrical elements.
+    // Chopping off the last plane is problem-dependent, and due to MCNP5's mandate
+    // that the cylidrical mesh must span 360 degrees.
+    if ( CYLINDRICAL==tally_coord_sys &&
+         MB_SUCCESS ==options.get_null_option("REMOVE_LAST_CYLIDRICAL_PLANE") ) {
+      planes[2].pop_back();
+      n_chopped_x2_planes = 1;
+      if (debug) std::cout << "remove last cylindrical plane option found" << std::endl;
+    } else {
+      n_chopped_x2_planes = 0;
+    // read the values and errors of each element from the file.
+    // Do not read values that are chopped off.
+    unsigned int n_elements = (planes[0].size()-1) * (planes[1].size()-1) * (planes[2].size()-1);
+    double *values, *errors;
+    values = new double [n_elements];
+    errors = new double [n_elements];
+    result = read_element_values_and_errors( file,
+                                             debug,
+					     planes,
+					     n_chopped_x2_planes,
+					     values,
+					     errors );
+    // blank line
+    // This tally has been read. If it is not being averaged, build tags,
+    // vertices
+    // and elements. If it is being averaged, average the data with a
+    // tally already existing in the MOAB instance.
+    if (!average) {
+      MBEntityHandle tally_meshset;
+      result = MBI->create_meshset(MESHSET_SET, tally_meshset);
+      if (MB_SUCCESS != result) return result;
+      // set tags on the tally
+      result = set_tally_tags( tally_meshset,
+                               tally_number,
+			       tally_comment,
+			       tally_particle,
+			       tally_coord_sys,
+                               tally_number_tag,
+                               tally_coord_sys_tag );
+      // The only info needed to build elements is the mesh plane boundaries.
+      // Build vertices...
+      //MBRange vert_handles;
+      //result = create_vertices( planes,
+      //                          vert_handles,
+      //        	          tally_coord_sys,
+      //                          tally_meshset );
+      MBEntityHandle start_vert = 0;
+      result = create_vertices( planes,
+                                start_vert,
+                                tally_coord_sys,
+                                tally_meshset );
+      // Build elements and tag them with tally values and errors, then add
+      // them to the tally_meshset.
+      result = create_elements( debug,
+                                planes,
+                                //vert_handles,
+                                start_vert,
+			        values,
+			        errors,
+			        tally_tag,
+			        error_tag,
+			        tally_meshset );
+      // add this tally's meshset to the output meshset
+      std::cout << "not averaging tally" << std::endl;
+      result = MBI->add_entities( output_meshset, &tally_meshset, 1);
+        if (MB_SUCCESS != result) std::cout << "error=" << result << std::endl;
+    // average the tally values, then delete stuff that was created
+    } else {
+      std::cout << "averaging tally" << std::endl;
+      result = average_with_existing_tally( new_nps,
+                                            nps,
+					    tally_number,
+				            tally_number_tag,
+				            nps_tag,
+				            tally_tag,
+				            error_tag,
+					    values,
+					    errors,
+					    n_elements );
+        assert( MB_SUCCESS == result );
+    // clean up
+    delete[] values;
+    delete[] errors;
+  // If we are averaging, delete the remainder of this file's information.
+  // Add the new nps to the existing file's nps if we are averaging.
+  // This is calculated during every tally averaging but only used after the last one.
+  if (average) {
+    MBRange matching_nps_sets;
+    result = MBI->get_entities_by_type_and_tag( 0, MBENTITYSET, &nps_tag,
+                                                0, 1, matching_nps_sets );
+    std::cout << "number of matching nps  meshsets=" << matching_nps_sets.size() << std::endl;
+    assert( 1 == matching_nps_sets.size() );
+    result = MBI->tag_set_data( nps_tag, matching_nps_sets, &new_nps );
+      if (MB_SUCCESS != result) std::cout<< "result=" << result << std::endl;
+  // If this file is not being averaged, add it to the meshset that was input after we create it.
+  } else {
+    result = MBI->create_meshset( MESHSET_SET, input_meshset );
+    result = MBI->add_entities( input_meshset, &output_meshset, 1 );
+  file.close();
+  return MB_SUCCESS;
+// Create tags needed for this reader
+MBErrorCode ReadMCNP5::create_tags( MBTag &date_and_time_tag,
+                                    MBTag &title_tag,
+                                    MBTag &nps_tag,
+				    MBTag &tally_number_tag,
+				    MBTag &tally_comment_tag,
+				    MBTag &tally_particle_tag,
+				    MBTag &tally_coord_sys_tag,
+				    MBTag &tally_tag,
+				    MBTag &error_tag ) {
+  result = MBI->tag_create("DATE_AND_TIME_TAG", sizeof(char[100]), MB_TAG_SPARSE,
+                           MB_TYPE_OPAQUE, date_and_time_tag, 0);
+    assert(MB_SUCCESS==result || MB_ALREADY_ALLOCATED==result);
+  result = MBI->tag_create("TITLE_TAG", sizeof(char[100]), MB_TAG_SPARSE,
+                           MB_TYPE_OPAQUE, title_tag, 0);
+  result = MBI->tag_create("NPS_TAG", sizeof(unsigned long long int),
+                           MB_TAG_SPARSE, MB_TYPE_OPAQUE, nps_tag, 0);
+  result = MBI->tag_create("TALLY_NUMBER_TAG", sizeof(int), MB_TAG_SPARSE,
+                           MB_TYPE_INTEGER, tally_number_tag, 0);
+  result = MBI->tag_create("TALLY_COMMENT_TAG", sizeof(char[100]), MB_TAG_SPARSE,
+                           MB_TYPE_OPAQUE, tally_comment_tag, 0);
+  result = MBI->tag_create("TALLY_PARTICLE_TAG", sizeof(particle), MB_TAG_SPARSE,
+                           MB_TYPE_OPAQUE, tally_particle_tag, 0);
+  result = MBI->tag_create("TALLY_COORD_SYS_TAG", sizeof(coordinate_system), MB_TAG_SPARSE,
+                           MB_TYPE_OPAQUE, tally_coord_sys_tag, 0);
+  result = MBI->tag_create("TALLY_TAG", sizeof(double), MB_TAG_DENSE,
+                           MB_TYPE_DOUBLE, tally_tag, 0);
+  result = MBI->tag_create("ERROR_TAG", sizeof(double), MB_TAG_DENSE,
+                           MB_TYPE_DOUBLE, error_tag, 0);
+MBErrorCode ReadMCNP5::read_file_header( std::fstream           &file,
+                                         bool                   debug,
+                                         char                   date_and_time[100],
+				         char                   title[100],
+				         unsigned long long int &nps ) {
+  // get simulation date and time
+  // mcnp   version 5     ld=11242008  probid =  03/23/09 13:38:56
+  char line[100];
+  file.getline(line, 100);
+  date_and_time = line;
+  if (debug) std::cout << "date_and_time=| " << date_and_time << std::endl;
+  // get simulation title
+  // iter Module 4
+  title = line;
+  if (debug) std::cout << "title=| " << title  << std::endl;
+  // get number of histories
+  // Number of histories used for normalizing tallies =      50000000.00
+  unsigned int b = a.find("Number of histories used for normalizing tallies =");
+  if (std::string::npos!=b) {
+    //std::cout << b << std::endl;
+    //std::string nps_string = a.substr(b+52,100);
+    //std::cout << nps_string << std::endl;
+    std::istringstream nps_ss(
+      a.substr(b+sizeof("Number of histories used for normalizing tallies = "),100) );
+    nps_ss >> nps;
+    if (debug) std::cout << "nps=| " << nps << std::endl;
+  } else return MB_FAILURE;
+MBErrorCode ReadMCNP5::set_header_tags( MBEntityHandle         output_meshset,
+                                        char                   title[100],
+				        unsigned long long int nps,
+				        MBTag                  data_and_time_tag,
+                                        MBTag                  title_tag,
+				        MBTag                  nps_tag ) {
+  result = MBI->tag_set_data( data_and_time_tag, &output_meshset, 1, &date_and_time);
+  result = MBI->tag_set_data( title_tag, &output_meshset, 1, &title);
+  result = MBI->tag_set_data( nps_tag, &output_meshset, 1, &nps);
+  if(MB_SUCCESS != result) std::cout << "result=" << result << std::endl;
+MBErrorCode ReadMCNP5::read_tally_header( std::fstream   &file,
+                                          bool           debug,
+					  unsigned int   &tally_number,
+					  char           tally_comment[100],
+					  particle       &tally_particle ) {
+  // get tally number
+  // Mesh Tally Number 104
+  MBEntityHandle result;
+  char line[100];
+  unsigned int b = a.find("Mesh Tally Number");
+  if (std::string::npos != b) {
+    //std::istringstream tally_number_ss( a.substr(b+18,100) );
+    std::istringstream tally_number_ss( a.substr(b+sizeof("Mesh Tally Number "),100) );
+    tally_number_ss >> tally_number;
+    if (debug) std::cout << "tally_number=| " << tally_number << std::endl;
+  // next get the tally comment (optional) and particle type
+  // 3mm neutron heating in Be (W/cc)
+  // This is a neutron mesh tally.
+  // std::string tally_comment;
+  // get tally particle
+  a = line;
+  result = get_tally_particle(a, debug, tally_particle);
+  if (MB_FAILURE == result) {
+    // If this line does not specify the particle type, then it is a tally comment.
+    // Get the comment, then get the particle type from the next line.
+    tally_comment = line;
+    a = line;
+      assert(MB_SUCCESS==result);
+  if (debug) std::cout << "tally_comment=| " << tally_comment << std::endl;
+MBErrorCode ReadMCNP5::get_tally_particle( std::string    a,
+                                           bool           debug,
+  if        (std::string::npos != a.find("This is a neutron mesh tally.")) {
+    tally_particle = NEUTRON;
+  } else if (std::string::npos != a.find("This is a photon mesh tally.") ) {
+    tally_particle = PHOTON;
+  } else if (std::string::npos != a.find("This is an electron mesh tally.") ) {
+    tally_particle = ELECTRON;
+  if (debug) std::cout << "tally_particle=| " << tally_particle << std::endl;
+MBErrorCode ReadMCNP5::read_mesh_planes( std::fstream         &file,
+                                         bool                 debug,
+					 std::vector<double>  planes[3],
+					 coordinate_system    &coord_sys ) {
+  // Tally bin boundaries:
+  char line[10000];
+  if (std::string::npos == a.find("Tally bin boundaries:"))
+    return MB_FAILURE;
+  // decide what coordinate system the tally is using
+  // First check for Cylindrical coordinates:
+  a = line;
+  unsigned int b = a.find("Cylinder origin at");
+    coord_sys = CYLINDRICAL;
+    if (debug) std::cout << "origin, axis, direction=| " << a << std::endl;
+    std::istringstream ss(a.substr(b+sizeof("Cylinder origin at"),10000));
+    // get origin (not used)
+    // Cylinder origin at   0.00E+00  0.00E+00  0.00E+00, axis in  0.000E+00 0.000E+00 1.000E+00 direction
+    double origin[3];
+    std::cout << "origin=| ";
+    for (int i=0; i<3; i++) {
+      ss >> origin[i];
+      std::cout << origin[i] << " ";
+    std::cout << std::endl;
+    int length_of_string = 10;
+    ss.ignore( length_of_string, ' ');
+    // get acis (not used)
+    double axis[3];
+    std::cout << "axis=| ";
+      ss >> axis[i];
+      std::cout << axis[i] << " ";
+    a = line;
+    // get r planes
+    if (debug) std::cout << "R direction:=| "; // << a << std::endl;
+    b = a.find("R direction:");
+      std::istringstream ss(a.substr(b+sizeof("R direction"),10000));
+      result = get_mesh_plane( ss, planes[0] );
+    // get z planes
+    a = line;
+    if (debug) std::cout << "Z direction:=| "; // << a << std::endl;
+    b = a.find("Z direction:");
+      std::istringstream ss(a.substr(b+sizeof("Z direction"),10000));
+      result = get_mesh_plane( ss, planes[1] );
+    // get theta planes
+    a = line;
+    if (debug) std::cout << "Theta direction:=| "; // << a << std::endl;
+    b = a.find("Theta direction (revolutions):");
+      std::istringstream ss(a.substr(b+sizeof("Theta direction (revolutions):"),10000));
+      result = get_mesh_plane( ss, planes[2] );
+  // Cartesian coordinate system:
+  }  else if (std::string::npos != a.find("X direction:") ) {
+    coord_sys = CARTESIAN;
+    // get x planes
+    b = a.find("X direction:");
+      std::istringstream ss(a.substr(b+sizeof("X direction"),10000));
+    // get y planes
+    a = line;
+    if (debug) std::cout << "Y direction:=| "; // << a << std::endl;
+    b = a.find("Y direction:");
+      std::istringstream ss(a.substr(b+sizeof("Y direction"),10000));
+    // get z planes
+    a = line;
+  // Spherical coordinate system not yet implemented:
+// Given a stringstream, return a vector of values in the string.
+MBErrorCode ReadMCNP5::get_mesh_plane( std::istringstream &ss,
+                                       std::vector<double> &plane) {
+  double value;
+  plane.clear();
+  while (!ss.eof()) {
+    ss >> value;
+    plane.push_back( value );
+    std::cout << value << " ";
+MBErrorCode ReadMCNP5::read_element_values_and_errors( std::fstream        &file,
+                                                       bool                debug,
+						       int                 n_chopped_x2_planes,
+						       double              values[],
+						       double              errors[] ) {
+  unsigned int index = 0;
+  for (unsigned int i=0; i<planes[0].size()-1; i++) {
+    for (unsigned int j=0; j<planes[1].size()-1; j++) {
+      for (unsigned int k=0; k<planes[2].size()-1+n_chopped_x2_planes; k++) {
+	// need to read every line in the file, even if we chop off some elements
+        char line[100];
+	// if this element has been chopped off, skip it
+	if (k>=planes[2].size()-1 && k<planes[2].size()-1+n_chopped_x2_planes) continue;
+        std::string a=line;
+        std::stringstream ss(a);
+        double centroid[3];
+        ss >> centroid[0];
+        ss >> centroid[1];
+        ss >> centroid[2];
+        ss >> values[index];
+        ss >> errors[index];
+	index++;
+MBErrorCode ReadMCNP5::set_tally_tags( MBEntityHandle    tally_meshset,
+                                       unsigned int      tally_number,
+			               particle          tally_particle,
+			               coordinate_system tally_coord_sys,
+                                       MBTag             tally_number_tag,
+			               MBTag             tally_comment_tag,
+                                       MBTag             tally_particle_tag,
+                                       MBTag             tally_coord_sys_tag ) {
+  result = MBI->tag_set_data( tally_number_tag,    &tally_meshset, 1, &tally_number);
+  result = MBI->tag_set_data( tally_comment_tag,   &tally_meshset, 1, &tally_comment);
+  result = MBI->tag_set_data( tally_particle_tag,  &tally_meshset, 1, &tally_particle);
+  result = MBI->tag_set_data( tally_coord_sys_tag, &tally_meshset, 1, &tally_coord_sys);
+//MBErrorCode ReadMCNP5::create_vertices( std::vector<double> planes[3],
+//                                          MBRange           &vert_handles,
+//					  coordinate_system coord_sys,
+//					  MBEntityHandle    tally_meshset) {
+MBErrorCode ReadMCNP5::create_vertices( std::vector<double> planes[3],
+                                          MBEntityHandle    &start_vert,
+					  coordinate_system coord_sys,
+					  MBEntityHandle    tally_meshset) {
+  unsigned int n_verts = planes[0].size() * planes[1].size() * planes[2].size();
+  //int n_verts = planes[0].size() * planes[1].size() * planes[2].size();
+  std::vector<double*> coord_arrays;
+  int start_id = 10000; // MB_START_ID
+  result = readMeshIface->get_node_arrays( 3, n_verts, start_id, start_vert, coord_arrays );
+  //double *coords;
+  //coords = new double [3*n_verts];
+  for (unsigned int k=0; k < planes[2].size(); k++) {
+    for (unsigned int j=0; j < planes[1].size(); j++) {
+      for (unsigned int i=0; i < planes[0].size(); i++) {
+        //unsigned int ijk = 3*(k*planes[0].size()*planes[1].size() + j*planes[0].size() + i);
+        unsigned int idx = (k*planes[0].size()*planes[1].size() + j*planes[0].size() + i);
+        double in[3], out[3];
+        in[0] = planes[0][i];
+        in[1] = planes[1][j];
+        in[2] = planes[2][k];
+        result = transform_point_to_cartesian( in, out, coord_sys );
+        //coords[ ijk   ] = out[0];
+        //coords[ ijk+1 ] = out[1];
+	//coords[ ijk+2 ] = out[2];
+	*(coord_arrays[0]+idx) = out[0];
+	*(coord_arrays[1]+idx) = out[1];
+	*(coord_arrays[2]+idx) = out[2];
+  //result = MBI->create_vertices(coords, n_verts, vert_handles);
+  //  assert( MB_SUCCESS == result );
+  //delete[] coords;
+  // add the vertices to the tally_meshset
+  //result = MBI->add_entities( tally_meshset, vert_handles );
+  result = MBI->add_entities( tally_meshset, &start_vert, n_verts );
+MBErrorCode ReadMCNP5::create_elements( bool                debug,
+					//MBRange             vert_handles,
+					MBEntityHandle      start_vert,
+					double              values[],
+					double              errors[],
+					MBTag               tally_tag,
+					MBTag               error_tag,
+					MBEntityHandle      tally_meshset ) {
+  //MBEntityHandle connect[8], start_vert, index, hex_handle;
+  //MBEntityHandle connect[8], index, hex_handle;
+  //MBRange element_handles;
+  //start_vert = *(vert_handles.begin());
+  unsigned int index, idx;
+  MBEntityHandle start_hex, *connect;
+  result = readMeshIface->get_element_array( n_elements, 8, MBHEX, 1, start_hex, connect );
+        idx = i + j*planes[0].size() + k*planes[0].size()*planes[1].size();
+        index = start_vert + idx;
+        // set connectivity and create the element
+        connect[0] = index;
+        connect[1] = index + 1;
+	connect[2] = index + 1 + planes[0].size();
+	connect[3] = index +     planes[0].size();
+	connect[4] = index +                        planes[0].size()*planes[1].size();
+	connect[5] = index + 1 +                    planes[0].size()*planes[1].size();
+	connect[6] = index + 1 + planes[0].size() + planes[0].size()*planes[1].size();
+	connect[7] = index +     planes[0].size() + planes[0].size()*planes[1].size();
+        //result = MBI->create_element(MBHEX, connect, 8, hex_handle);
+        //  assert(MB_SUCCESS == result);
+	//if (MB_SUCCESS != result) return MB_FAILURE;
+        //element_handles.insert(hex_handle);
+        // assign parsed data to the element
+        //result = MBI->tag_set_data(tally_tag, &hex_handle, 1, &values[idx]);
+        result = MBI->tag_set_data(tally_tag, &index, 1, &values[idx]);
+        //result = MBI->tag_set_data(error_tag, &hex_handle, 1, &errors[idx]);
+        result = MBI->tag_set_data(error_tag, &index, 1, &errors[idx]);
+  // add the elements to the tally set
+  //result = MBI->add_entities( tally_meshset, element_handles );
+  result = MBI->add_entities( tally_meshset, &start_hex, n_elements );
+  //std::cout << "Read " << element_handles.size() << " elements from tally." << std::endl;
+  std::cout << "Read " << n_elements << " elements from tally." << std::endl;
+// Average a tally that was recently read in with one that alread exists in
+// the interface. Only the existing values will be updated.
+MBErrorCode ReadMCNP5::average_with_existing_tally( unsigned long long int &new_nps,
+                                                    unsigned long long int nps1,
+						     MBTag        nps_tag,
+						     MBTag        tally_tag,
+						     MBTag        error_tag,
+						     double       values1[],
+						     double       errors1[],
+						     unsigned int n_elements ) {
+  // get the tally number
+  //MBTag tally_number_tag, nps_tag, tally_tag, error_tag;
+  //result = MBI->tag_create("TALLY_NUMBER_TAG", sizeof(int), MB_TAG_DENSE,
+  //                         MB_TYPE_INTEGER, tally_number_tag, 0);
+  //  assert(MB_SUCCESS==result || MB_ALREADY_ALLOCATED==result);
+  //int tally_number;
+  //result = MBI->tag_get_data( tally_number_tag, &tally_meshset, 1, &tally_number);
+  // match the tally number with one from the existing meshtal file
+  MBRange matching_tally_number_sets;
+  const void* const tally_number_val[] = {&tally_number};
+  result = MBI->get_entities_by_type_and_tag( 0, MBENTITYSET, &tally_number_tag,
+                                              tally_number_val, 1, matching_tally_number_sets );
+  std::cout << "number of matching meshsets=" << matching_tally_number_sets.size() << std::endl;
+    assert( 1 == matching_tally_number_sets.size() );
+  // identify which of the meshsets is existing
+  MBEntityHandle existing_meshset;
+  //if ( tally_meshset == matching_tally_number_sets.front() )
+    //existing_meshset = matching_tally_number_sets.back();
+  //else
+    existing_meshset = matching_tally_number_sets.front();
+  // get the existing elements from the set
+  MBRange existing_elements;
+  result = MBI->get_entities_by_type( existing_meshset, MBHEX, existing_elements );
+  // get this tally's elements
+  //MBRange new_elements;
+  //result = MBI->get_entities_by_type( tally_meshset, MBHEX, new_elements );
+  // check to make sure they have the same number of elements
+  //assert( existing_elements.size() == new_elements.size() );
+  assert( existing_elements.size() == n_elements );
+  // get the nps of the existing and new tally
+  //result = MBI->tag_create("NPS_TAG", sizeof(unsigned long long int), MB_TAG_SPARSE,
+  //                         MB_TYPE_OPAQUE, nps_tag, 0);
+  //unsigned long long int nps0, nps1;
+  unsigned long long int nps0;
+  MBRange sets_with_this_tag;
+  result = MBI->get_entities_by_type_and_tag( 0, MBENTITYSET, &nps_tag, 0, 1, sets_with_this_tag);
+    std::cout << "number of nps sets=" << sets_with_this_tag.size() << std::endl;
+    //assert( 2 == sets_with_this_tag.size() );
+    assert( 1 == sets_with_this_tag.size() );
+  result = MBI->tag_get_data( nps_tag, &sets_with_this_tag.front(), 1, &nps0);
+  //result = MBI->tag_get_data( nps_tag, &sets_with_this_tag.back(), 1, &nps1);
+  std::cout << "nps0=" << nps0 << " nps1=" << nps1 << std::endl;
+  new_nps = nps0 + nps1;
+  // get tally values from the existing elements
+  //result = MBI->tag_create("TALLY_TAG", sizeof(double), MB_TAG_DENSE,
+  //                         MB_TYPE_DOUBLE, tally_tag, 0);
+  //result = MBI->tag_create("ERROR_TAG", sizeof(double), MB_TAG_DENSE,
+  //                         MB_TYPE_DOUBLE, error_tag, 0);
+  //double *values0, *values1, *errors0, *errors1;
+  //double *values1, *errors1;
+  //values0 = new double [existing_elements.size()];
+  //errors0 = new double [existing_elements.size()];
+  double values0[existing_elements.size()];
+  double errors0[existing_elements.size()];
+  result = MBI->tag_get_data( tally_tag, existing_elements, &values0 );
+  //result = MBI->tag_get_data( error_tag, existing_elements, errors0 ); this worked with erros0 = new double [size];
+  result = MBI->tag_get_data( error_tag, existing_elements, &errors0 );
+  // get the tally values from the new elements
+  //values1 = new double [new_elements.size()];
+  //errors1 = new double [new_elements.size()];
+  //result = MBI->tag_get_data( tally_tag, new_elements, values1 );
+  //result = MBI->tag_get_data( error_tag, new_elements, errors1 );
+  // average the values and errors
+  result = average_tally_values( nps0, nps1, values0, values1,
+                                 errors0, errors1, n_elements );
+  // set the averaged information back onto the existing elements
+  result = MBI->tag_set_data( tally_tag, existing_elements, &values0 );
+  result = MBI->tag_set_data( error_tag, existing_elements, &errors0 );
+  // cleanup
+  //delete[] values1;
+  //delete[] errors1;
+MBErrorCode ReadMCNP5::transform_point_to_cartesian(double *in, double *out,
+                                                    coordinate_system coord_sys ) {
+                  //coordinate_system coord_sys, double *rmat) {
+      //double q[3];
+      // Apply the rotation matrix
+      //for (unsigned int i=0; i < 3; i++) {
+      //  q[i] =  p[0] * rmat[4*i  ] + p[1] * rmat[4*i+1]
+      //        + p[2] * rmat[4*i+2] +        rmat[4*i+3];
+  // Transform coordinate system
+  switch( coord_sys ) {
+    case CARTESIAN :
+      out[0] = in[0]; out[1] = in[1]; out[2] = in[2];  // x, y, z
+      break;
+    case CYLINDRICAL :
+      //r[0] = sqrt( q[0]*q[0] + q[1]*q[1] );   // r
+      //r[1] = q[2];                            // z
+      //r[2] = c2pi * ( atan2( q[1], q[0] ) );  // theta (in rotations)
+      //std::cout << "r=" << p[0] << " z=" << p[1] << " theta=" << p[2] << std::endl;
+      out[0] = in[0]*cos( 2*pi*in[2] ); // x
+      out[1] = in[0]*sin( 2*pi*in[2] ); // y
+      out[2] = in[1];                  // z
+      break;
+    case SPHERICAL :
+      return MB_NOT_IMPLEMENTED;
+      break;
+    default :
+      break;
+// Average two tally values and their error. Return average values in the
+// place of first tally values.
+MBErrorCode ReadMCNP5::average_tally_values(const unsigned long long int nps0,
+                                            const unsigned long long int nps1,
+					    double *values0,
+					    const double *values1,
+					    double *errors0,
+					    const double *errors1,
+					    const unsigned long int n_values) {
+  for(unsigned long int i=0; i<n_values; i++) {
+    //std::cout << " values0=" << values0[i] << " values1=" << values1[i]
+    //          << " errors0=" << errors0[i] << " errors1=" << errors1[i] << " nps0=" << nps0 << " nps1=" << nps1 << std::endl;
+    errors0[i] = sqrt( pow(values0[i]*errors0[i]*nps0,2) +
+                       pow(values1[i]*errors1[i]*nps1,2) ) /
+		 (values0[i]*nps0 + values1[i]*nps1);
+    values0[i] = ( values0[i]*nps0 + values1[i]*nps1 ) / (nps0 + nps1);
+    //std::cout << " values0=" << values0[i] << " errors0=" << errors0[i] << std::endl;
+  // REMEMBER TO UPDATE NPS0 = NPS0 + NPS1 after this
Added: MOAB/trunk/ReadMCNP5.hpp
--- MOAB/trunk/ReadMCNP5.hpp	                        (rev 0)
+++ MOAB/trunk/ReadMCNP5.hpp	2009-05-19 02:01:04 UTC (rev 2898)
@@ -0,0 +1,150 @@
+#include "MBReaderIface.hpp"
+#include <fstream>
+#include <sstream>
+#include <vector>
+class MBReadUtilIface;
+class ReadMCNP5 : public MBReaderIface
+public:
+  // factory method
+  static MBReaderIface* factory( MBInterface* );
+  MBErrorCode load_file(const char*       fname,
+                        MBEntityHandle    &input_meshset,
+	                const FileOptions &options,
+			const char*       set_tag_name, /* not used */
+                        const int         num_material_sets );
+  // Constructor
+  ReadMCNP5(MBInterface* impl = NULL);
+  // Destructor
+  virtual ~ReadMCNP5();
+protected:
+private:
+  // Parameters
+  static const double pi   = 3.141592653589793;
+  static const double c2pi = 0.1591549430918954;
+  static const double cpi  = 0.3183098861837907;
+  enum coordinate_system { NO_SYSTEM,
+                           CARTESIAN,
+		           CYLINDRICAL,
+		           SPHERICAL };
+  enum particle { NEUTRON,
+   	          PHOTON,
+                  ELECTRON };
+  // Read mesh interface
+  MBReadUtilIface* readMeshIface;
+  // MOAB Interface
+  MBInterface* MBI;
+  MBErrorCode create_tags( MBTag &date_and_time_tag,
+                           MBTag &title_tag,
+                           MBTag &nps_tag,
+		           MBTag &tally_tag,
+			   MBTag &error_tag );
+  MBErrorCode read_file_header( std::fstream           &file,
+                                bool                   debug,
+			        char                   title[100],
+			        unsigned long long int &nps );
+  MBErrorCode set_header_tags( MBEntityHandle                  output_meshset,
+                                        char                   title[100],
+                                        MBTag                  title_tag,
+				        MBTag                  nps_tag );
+  MBErrorCode read_tally_header( std::fstream &file,
+                                 bool         debug,
+			         particle     &tally_particle );
+  MBErrorCode get_tally_particle( std::string a,
+                                  bool        debug,
+  MBErrorCode read_mesh_planes( std::fstream         &file,
+                                bool                 debug,
+				coordinate_system    &coord_sys);
+  MBErrorCode get_mesh_plane( std::istringstream &ss, std::vector<double> &plane);
+  MBErrorCode read_element_values_and_errors( std::fstream        &file,
+                                              bool                debug,
+					      double              values[],
+					      double              errors[] );
+  MBErrorCode set_tally_tags( MBEntityHandle    tally_meshset,
+                              MBTag             tally_coord_sys_tag );
+  MBErrorCode create_vertices( std::vector<double> planes[3],
+                               //MBRange             &vert_handles,
+			       MBEntityHandle      tally_meshset );
+  MBErrorCode create_elements( bool                debug,
+			       double              values[],
+			       double              errors[],
+			       MBTag               tally_tag,
+			       MBTag               error_tag,
+  MBErrorCode average_with_existing_tally( unsigned long long int &new_nps,
+				           MBTag                  nps_tag,
+				           MBTag                  tally_tag,
+				           MBTag                  error_tag,
+					   double                 values[],
+					   double                 errors[],
+					   unsigned int           n_elements );
+  MBErrorCode transform_point_to_cartesian(double *in,
+                                           double *out,
+					   coordinate_system coord_sys);
+  MBErrorCode average_tally_values(const unsigned long long int nps0,
+					          double* values0,
+					    const double* values1,
+					          double* errors0,
+					    const double* errors1,
+					    const unsigned long int n_values);
