[MOAB-dev] r2885 - in MOAB/trunk: . tools/iMesh
kraftche at cae.wisc.edu
Fri May 15 11:40:02 CDT 2009
Author: kraftche
Date: 2009-05-15 11:40:02 -0500 (Fri, 15 May 2009)
New Revision: 2885
Modified:
MOAB/trunk/MBCore.cpp
MOAB/trunk/MBCore.hpp
MOAB/trunk/MBInterface.hpp
MOAB/trunk/MeshSetSequence.cpp
MOAB/trunk/MeshSetSequence.hpp
MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
Log:
o Add MBInterface::get_contained_meshsets and MBInterface::num_contained_meshset
analogous to get_parent_meshsets, num_parent_meshsets.
o Use get_contained_meshsets for complete implementation of iMesh_getEntSets
o Use num_contained_meshsets for complete implementation of iMesh_getNumEntSets
Modified: MOAB/trunk/MBCore.cpp
--- MOAB/trunk/MBCore.cpp 2009-05-15 16:39:48 UTC (rev 2884)
+++ MOAB/trunk/MBCore.cpp 2009-05-15 16:40:02 UTC (rev 2885)
@@ -2578,6 +2578,39 @@
return MB_SUCCESS;
+MBErrorCode MBCore::get_contained_meshsets( const MBEntityHandle meshset,
+ std::vector<MBEntityHandle> &children,
+ const int num_hops) const
+ if (0 == meshset) {
+ return get_entities_by_type( meshset, MBENTITYSET, children );
+ const EntitySequence *seq;
+ MBErrorCode rval = sequence_manager()->find( meshset, seq );
+ if (MB_SUCCESS != rval)
+ return MB_ENTITY_NOT_FOUND;
+ const MeshSetSequence* mseq = reinterpret_cast<const MeshSetSequence*>(seq);
+ return mseq->get_contained_sets( sequence_manager(), meshset, children, num_hops );
+ MBRange &children,
+ std::vector<MBEntityHandle> child_vec;
+ MBErrorCode result = get_contained_meshsets(meshset, child_vec, num_hops);
+ if (MB_SUCCESS != result) return result;
+ std::sort( child_vec.begin(), child_vec.end() );
+ std::copy(child_vec.rbegin(), child_vec.rend(), mb_range_inserter(children));
+ return MB_SUCCESS;
MBErrorCode MBCore::num_parent_meshsets(const MBEntityHandle meshset, int* number,
@@ -2612,7 +2645,23 @@
return mseq->num_children( sequence_manager(), meshset, *number, num_hops );
+MBErrorCode MBCore::num_contained_meshsets(const MBEntityHandle meshset, int* number,
+ return get_number_entities_by_type( 0, MBENTITYSET, *number );
+ return mseq->num_contained_sets( sequence_manager(), meshset, *number, num_hops );
MBErrorCode MBCore::add_parent_meshset( MBEntityHandle meshset,
const MBEntityHandle parent_meshset)
Modified: MOAB/trunk/MBCore.hpp
--- MOAB/trunk/MBCore.hpp 2009-05-15 16:39:48 UTC (rev 2884)
+++ MOAB/trunk/MBCore.hpp 2009-05-15 16:40:02 UTC (rev 2885)
@@ -900,6 +900,16 @@
MBRange &children,
const int num_hops = 1) const;
+ //! get contained meshsets
+ virtual MBErrorCode get_contained_meshsets(const MBEntityHandle meshset,
+ std::vector<MBEntityHandle> &contained,
+ const int num_hops = 1) const;
+ MBRange &contained,
//! gets number of parent meshsets
virtual MBErrorCode num_parent_meshsets(const MBEntityHandle meshset,
int *number,
@@ -910,6 +920,11 @@
int *number,
+ //! gets number of contained meshsets
+ virtual MBErrorCode num_contained_meshsets(const MBEntityHandle meshset,
+ int *number,
//! add a parent meshset
virtual MBErrorCode add_parent_meshset(MBEntityHandle meshset,
const MBEntityHandle parent_meshset);
Modified: MOAB/trunk/MBInterface.hpp
--- MOAB/trunk/MBInterface.hpp 2009-05-15 16:39:48 UTC (rev 2884)
+++ MOAB/trunk/MBInterface.hpp 2009-05-15 16:40:02 UTC (rev 2885)
@@ -1458,6 +1458,36 @@
MBRange &children,
const int num_hops = 1) const = 0;
+ /**\brief Get mesh sets contained in a mesh set
+ * If <em>num_hops</em> is 1, only immediate contents are returned.
+ * Otherwise a recursive query of all contained sets is performed,
+ * returning every visted set. The value of num_hops limites the
+ * depth of the search, with zero indicating no depth limit.
+ *\param meshset The mesh set whose contents are being queried
+ *\param contained The result list.
+ *\param num_hops Number of generations to traverse (0 = all)
+ const int num_hops = 1) const = 0;
//! Get the number of parent mesh sets of a mesh set
/** Identical to get_parent_meshsets, only number is returned instead of actual parents.
\param meshset The mesh set whose parents are being queried
@@ -1476,6 +1506,18 @@
int *number,
+ /**\brief Get the number of mesh sets contained in a mesh set
+ * Return the number of sets that would be returned by get_contained_meshsets
+ *\param meshset The initial set to begin the query from.
+ *\param number (Output) The result count.
+ *\param num_hops Search depth (0 => unbounded).
+ int *number,
//! Add a parent mesh set to a mesh set
/** Make <em>parent_meshset</em> a new parent of <em>child_meshset</em>. This function does
<em>not</em> add a corresponding child link to <em>parent_meshset</em>.
Modified: MOAB/trunk/MeshSetSequence.cpp
--- MOAB/trunk/MeshSetSequence.cpp 2009-05-15 16:39:48 UTC (rev 2884)
+++ MOAB/trunk/MeshSetSequence.cpp 2009-05-15 16:40:02 UTC (rev 2885)
@@ -391,12 +391,14 @@
MBErrorCode MeshSetSequence::get_parent_child_meshsets( MBEntityHandle meshset,
const SequenceManager* seq_sets,
std::vector<MBEntityHandle>& results,
- int num_hops, bool parents ) const
+ int num_hops, SearchType link_type ) const
MBErrorCode result = MB_SUCCESS;
std::vector<MBEntityHandle>::iterator i;
- const MBEntityHandle* array;
- int k, count;
+ const MBEntityHandle *array, *end;
+ MBEntityHandle s, e;
+ int count;
+ size_t n;
// Skip any meshsets already in input vector (yes, don't
// get their children either even if num_hops would indicate
@@ -422,12 +424,50 @@
return rval;
const MBMeshSet *ms_ptr = reinterpret_cast<const MeshSetSequence*>(seq)->get_set( *i );
- // querying for parents or children?
- array = parents ? ms_ptr->get_parents(count) : ms_ptr->get_children(count);
+ switch (link_type) {
+ case CONTAINED:
+ array = ms_ptr->get_contents(n);
+ end = array + n;
+ if (ms_ptr->vector_based()) {
+ for (; array != end; ++array)
+ if (MBENTITYSET == TYPE_FROM_HANDLE(*array) &&
+ visited.insert(*array).second)
+ lists[1-index].push_back(*array);
+ else {
+ assert(n%2 == 0);
+ array = std::lower_bound( array, array+n, FIRST_HANDLE(MBENTITYSET) );
+ // only part of first block is of type
+ if ((end - array)%2) {
+ ++array;
+ s = FIRST_HANDLE(MBENTITYSET);
+ e = *array;
+ for (; s <= e; ++s)
+ if (visited.insert(s).second)
+ lists[1-index].push_back(s);
+ while (array < end) {
+ s = *array++;
+ e = *array++;
+ continue;
+ case PARENTS:
+ array = ms_ptr->get_parents(count);
+ break;
+ case CHILDREN:
+ array = ms_ptr->get_children(count);
+ break;
// copy any parents/children we haven't visited yet into list
- for (k = 0; k < count; ++k)
- if (visited.insert(array[k]).second)
- lists[1-index].push_back(array[k]);
+ for (end = array+count; array != end; ++array)
+ if (visited.insert(*array).second)
// iterate
@@ -463,9 +503,9 @@
if (num_hops > 0)
- return get_parent_child_meshsets( handle, seqman, parents, num_hops, true );
+ return get_parent_child_meshsets( handle, seqman, parents, num_hops, PARENTS );
else
- return get_parent_child_meshsets( handle, seqman, parents, -1, true );
+ return get_parent_child_meshsets( handle, seqman, parents, -1, PARENTS );
MBErrorCode MeshSetSequence::get_children( const SequenceManager* seqman,
@@ -487,11 +527,26 @@
if (num_hops > 0)
- return get_parent_child_meshsets( handle, seqman, children, num_hops, false );
+ return get_parent_child_meshsets( handle, seqman, children, num_hops, CHILDREN );
else
- return get_parent_child_meshsets( handle, seqman, children, -1, false );
+ return get_parent_child_meshsets( handle, seqman, children, -1, CHILDREN );
+MBErrorCode MeshSetSequence::get_contained_sets( const SequenceManager* seqman,
+ MBEntityHandle handle,
+ std::vector<MBEntityHandle>& contained,
+ int num_hops ) const
+ if (num_hops == 1 && contained.empty()) {
+ return get_set(handle)->get_entities_by_type( MBENTITYSET, contained );
+ if (num_hops > 0)
+ return get_parent_child_meshsets( handle, seqman, contained, num_hops, CONTAINED );
+ else
+ return get_parent_child_meshsets( handle, seqman, contained, -1, CONTAINED );
MBErrorCode MeshSetSequence::num_parents( const SequenceManager* seqman,
int& number,
@@ -524,3 +579,19 @@
number = children.size();
return result;
+MBErrorCode MeshSetSequence::num_contained_sets( const SequenceManager* seqman,
+ int& number,
+ if (num_hops == 1) {
+ number = get_set( handle )->num_entities_by_type(MBENTITYSET);
+ std::vector<MBEntityHandle> contained;
+ MBErrorCode result = get_contained_sets( seqman, handle, contained, num_hops );
+ number = contained.size();
+ return result;
Modified: MOAB/trunk/MeshSetSequence.hpp
--- MOAB/trunk/MeshSetSequence.hpp 2009-05-15 16:39:48 UTC (rev 2884)
+++ MOAB/trunk/MeshSetSequence.hpp 2009-05-15 16:40:02 UTC (rev 2885)
@@ -83,13 +83,17 @@
MBErrorCode num_dimension( SequenceManager const* seqman, MBEntityHandle set, int dim, int& count, bool recursive ) const;
MBErrorCode num_type( SequenceManager const* seqman, MBEntityHandle set, MBEntityType type, int& count, bool recursive ) const;
- MBErrorCode get_parents ( SequenceManager const* seqman, MBEntityHandle of, std::vector<MBEntityHandle>& parents, int num_hops ) const;
- MBErrorCode get_children( SequenceManager const* seqman, MBEntityHandle of, std::vector<MBEntityHandle>& children, int num_hops ) const;
- MBErrorCode num_parents ( SequenceManager const* seqman, MBEntityHandle of, int& number, int num_hops ) const;
- MBErrorCode num_children( SequenceManager const* seqman, MBEntityHandle of, int& number, int num_hops ) const;
+ MBErrorCode get_parents ( SequenceManager const* seqman, MBEntityHandle of, std::vector<MBEntityHandle>& parents, int num_hops ) const;
+ MBErrorCode get_children ( SequenceManager const* seqman, MBEntityHandle of, std::vector<MBEntityHandle>& children, int num_hops ) const;
+ MBErrorCode get_contained_sets( SequenceManager const* seqman, MBEntityHandle of, std::vector<MBEntityHandle>& contents, int num_hops ) const;
+ MBErrorCode num_parents ( SequenceManager const* seqman, MBEntityHandle of, int& number, int num_hops ) const;
+ MBErrorCode num_children ( SequenceManager const* seqman, MBEntityHandle of, int& number, int num_hops ) const;
+ MBErrorCode num_contained_sets( SequenceManager const* seqman, MBEntityHandle of, int& number, int num_hops ) const;
private:
+ enum SearchType { PARENTS, CHILDREN, CONTAINED };
MeshSetSequence( MeshSetSequence& split_from, MBEntityHandle split_at )
: EntitySequence( split_from, split_at )
@@ -99,7 +103,7 @@
MBErrorCode get_parent_child_meshsets( MBEntityHandle meshset,
SequenceManager const* set_sequences,
- int num_hops, bool parents ) const;
+ int num_hops, SearchType link_type ) const;
static MBErrorCode recursive_get_sets( MBEntityHandle start_set,
Modified: MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp 2009-05-15 16:39:48 UTC (rev 2884)
+++ MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp 2009-05-15 16:40:02 UTC (rev 2885)
@@ -1023,25 +1023,17 @@
/*in*/ const int num_hops,
int *num_sets, int *err)
- if (num_hops > 1) {
- iMesh_processError(iBase_NOT_SUPPORTED,
- "iMesh_getNumEntSets: not currently implemented for num_hops > 1.");
- *num_sets = 0;
- RETURN(iBase_NOT_SUPPORTED);
- MBErrorCode result = MBI->get_number_entities_by_type
- (ENTITY_HANDLE(entity_set_handle), MBENTITYSET,
- *num_sets, (num_hops == -1 ? true : false));
- if (result != MB_SUCCESS) {
+ MBErrorCode rval = MBI->num_contained_meshsets( ENTITY_HANDLE(entity_set_handle),
+ num_sets,
+ std::max(0,num_hops) );
+ if (rval != MB_SUCCESS) {
std::string msg("iMesh_entitysetGetNumberEntitySets:ERROR getting number of entitysets "
"in EntitySet, with error type: ");
- msg += MBI->get_error_string(result);
- iMesh_processError(iBase_ERROR_MAP[result], msg.c_str());
+ msg += MBI->get_error_string(rval);
+ iMesh_processError(iBase_ERROR_MAP[rval], msg.c_str());
- RETURN(iBase_ERROR_MAP[result]);
+ RETURN(iBase_ERROR_MAP[rval]);
void iMesh_getEntSets(iMesh_Instance instance,
@@ -1051,29 +1043,18 @@
/*inout*/ int* contained_entset_handles_allocated,
/*inout*/ int* contained_entset_handles_size, int *err)
- iMesh_processError(iBase_NOT_SUPPORTED, "iMesh_getEntSets: not currently implemented for num_hops > 1.");
+ std::vector<MBEntityHandle> sets;
+ MBErrorCode rval = MBI->get_contained_meshsets( ENTITY_HANDLE(entity_set_handle),
+ sets,
+ std::max( num_hops, 0 ) );
+ if (MB_SUCCESS != rval) {
+ iMesh_processError(iBase_ERROR_MAP[rval], "iMesh_entitysetGetEntitySets: problem getting entities by type.");
- MBRange sets;
- MBErrorCode result = MBI->get_entities_by_type
- (ENTITY_HANDLE(entity_set_handle), MBENTITYSET, sets, (num_hops == -1 ? true : false));
- if (MB_SUCCESS != result) {
- iMesh_processError(iBase_ERROR_MAP[result], "iMesh_entitysetGetEntitySets: problem getting entities by type.");
CHECK_SIZE(*contained_entset_handles, *contained_entset_handles_allocated,
(int)sets.size(), iBase_EntitySetHandle, iBase_MEMORY_ALLOCATION_FAILED);
- MBRange::iterator iter = sets.begin();
- MBRange::iterator end_iter = sets.end();
- int k = 0;
- for (; iter != end_iter; iter++)
- (*contained_entset_handles)[k++] = (iBase_EntitySetHandle)*iter;
+ std::copy( sets.begin(), sets.end(), (MBEntityHandle*)*contained_entset_handles );
*contained_entset_handles_size = sets.size();
RETURN(iBase_SUCCESS);
