[MOAB-dev] r2882 - in MOAB/trunk/tools/iMesh/python: . test
jvporter at wisc.edu jvporter at wisc.edu
Mon May 11 14:46:20 CDT 2009
Author: jvporter
Date: 2009-05-11 14:46:19 -0500 (Mon, 11 May 2009)
New Revision: 2882
Removed:
   MOAB/trunk/tools/iMesh/python/iBase_module.h
Modified:
   MOAB/trunk/tools/iMesh/python/iBase.c
   MOAB/trunk/tools/iMesh/python/iBase_Python.h
   MOAB/trunk/tools/iMesh/python/iMesh.c
   MOAB/trunk/tools/iMesh/python/iMesh_Python.h
   MOAB/trunk/tools/iMesh/python/iMesh_entSet.c
   MOAB/trunk/tools/iMesh/python/iMesh_iter.c
   MOAB/trunk/tools/iMesh/python/iMesh_tag.c
   MOAB/trunk/tools/iMesh/python/test/tags.py
Log:
* Fix indentation/tabs in C code
* Fix test code for raw data tags for entity arrays
* Remove unnecessary iBase_module.h
Modified: MOAB/trunk/tools/iMesh/python/iBase.c
--- MOAB/trunk/tools/iMesh/python/iBase.c	2009-05-09 16:36:05 UTC (rev 2881)
+++ MOAB/trunk/tools/iMesh/python/iBase.c	2009-05-11 19:46:19 UTC (rev 2882)
@@ -5,33 +5,33 @@
 SIMPLE_TYPE(iBaseEntity_Object,iBaseEntity_Type,"itaps.iBase.iBaseEntity","");
 SIMPLE_TYPE(iBaseEntitySet_Object,iBaseEntitySet_Type,
-	    "itaps.iBase.iBaseEntitySet","");
+            "itaps.iBase.iBaseEntitySet","");
 SIMPLE_TYPE(iBaseTag_Object,iBaseTag_Type,"itaps.iBase.iBaseTag","");
 static PyObject *
 iBaseEntity_FromHandle(iBase_EntityHandle h)
-  iBaseEntity_Object *o = iBaseEntity_New();
-  o->handle = h;
-  return (PyObject*)o;
+    iBaseEntity_Object *o = iBaseEntity_New();
+    o->handle = h;
+    return (PyObject*)o;
 static int NPY_IBASEENT;
 static PyObject *
 iBaseEntitySet_FromHandle(iBase_EntitySetHandle h)
-  iBaseEntitySet_Object *o = iBaseEntitySet_New();
-  o->handle = h;
+    iBaseEntitySet_Object *o = iBaseEntitySet_New();
+    o->handle = h;
 static int NPY_IBASEENTSET;
 static PyObject *
 iBaseTag_FromHandle(iBase_TagHandle h)
-  iBaseTag_Object *o = iBaseTag_New();
-  o->handle = h;
+    iBaseTag_Object *o = iBaseTag_New();
+    o->handle = h;
 static int NPY_IBASETAG;
@@ -40,28 +40,28 @@
 ENUM_TYPE(storageOrder, "iBase.storageOrder", "");
 static PyMethodDef module_methods[] = {
-  {0}
+    {0}
 static PyObject *
 iBaseEntArr_getitem(void *data,void *arr)
-  return iBaseEntity_FromHandle(*(iBase_EntityHandle*)data);
+    return iBaseEntity_FromHandle(*(iBase_EntityHandle*)data);
 static int
 iBaseEntArr_setitem(PyObject *item,void *data,void *arr)
-  if(!iBaseEntity_Check(item))
-    return -1;
-  *(iBase_EntityHandle*)data = iBaseEntity_GetHandle(item);
-  return 0;
+    if(!iBaseEntity_Check(item))
+        return -1;
+    *(iBase_EntityHandle*)data = iBaseEntity_GetHandle(item);
+    return 0;
 static void
 iBaseEntArr_copyswapn(void *dest,npy_intp dstride,void *src,npy_intp sstride,
-		      npy_intp n,int swap,void *arr)
+                      npy_intp n,int swap,void *arr)
 static void
@@ -71,62 +71,61 @@
 static npy_bool
 iBaseEntArr_nonzero(void *data,void *arr)
-  printf("nonzero");
-  return *(iBase_EntityHandle*)data != 0;
+    return *(iBase_EntityHandle*)data != 0;
 static PyObject *
 iBaseEntObj_repr(iBaseEntity_Object *self)
-  char foo[64];
-  snprintf(foo,64,"<iBase_EntityHandle %p>",self->handle);
-  return Py_BuildValue("s",foo);
+    char out[64];
+    snprintf(out,64,"<iBase_EntityHandle %p>",self->handle);
+    return Py_BuildValue("s",out);
 static PyObject *
 iBaseEntObj_richcompare(iBaseEntity_Object *lhs,iBaseEntity_Object *rhs,int op)
-  switch(op)
-  case Py_EQ:
-    return PyBool_FromLong(lhs->handle == rhs->handle);
-  case Py_NE:
-    return PyBool_FromLong(lhs->handle != rhs->handle);
-  default:
-    return Py_NotImplemented;
+    switch(op)
+    case Py_EQ:
+        return PyBool_FromLong(lhs->handle == rhs->handle);
+    case Py_NE:
+        return PyBool_FromLong(lhs->handle != rhs->handle);
+    default:
+        return Py_NotImplemented;
 static PyArray_ArrFuncs iBaseEntArr_funcs = {
-  {0},
-  iBaseEntArr_getitem,
-  iBaseEntArr_setitem,
-  iBaseEntArr_copyswapn,
-  iBaseEntArr_copyswap,
-  0,
-  0,
-  0,
-  0,
-  0,
-  iBaseEntArr_nonzero
+    {0},
+    iBaseEntArr_getitem,
+    iBaseEntArr_setitem,
+    iBaseEntArr_copyswapn,
+    iBaseEntArr_copyswap,
+    0,
+    0,
+    0,
+    0,
+    0,
+    iBaseEntArr_nonzero
 static PyObject *
 iBaseEntSetArr_getitem(void *data,void *arr)
-  return iBaseEntitySet_FromHandle(*(iBase_EntitySetHandle*)data);
+    return iBaseEntitySet_FromHandle(*(iBase_EntitySetHandle*)data);
 static int
 iBaseEntSetArr_setitem(PyObject *item,void *data,void *arr)
-  return 0;
+    return 0;
 static void
 iBaseEntSetArr_copyswapn(void *dest,npy_intp dstride,void *src,
-			 npy_intp sstride,npy_intp n,int swap,void *arr)
+                         npy_intp sstride,npy_intp n,int swap,void *arr)
 static void
@@ -136,44 +135,44 @@
 static npy_bool
 iBaseEntSetArr_nonzero(void *data,void *arr)
-  return *(iBase_EntitySetHandle*)data != 0;
+    return *(iBase_EntitySetHandle*)data != 0;
 static PyObject *
 iBaseEntSetObj_repr(iBaseEntitySet_Object *self)
-  char foo[64];
-  snprintf(foo,64,"<iBase_EntitySetHandle %p>",self->handle);
+    char out[64];
+    snprintf(out,64,"<iBase_EntitySetHandle %p>",self->handle);
 static PyObject *
 iBaseEntSetObj_richcompare(iBaseEntitySet_Object *lhs,
-			   iBaseEntitySet_Object *rhs,int op)
+                           iBaseEntitySet_Object *rhs,int op)
-  switch(op)
-  case Py_EQ:
-  case Py_NE:
-  default:
+    switch(op)
+    case Py_EQ:
+    case Py_NE:
+    default:
 static PyArray_ArrFuncs iBaseEntSetArr_funcs = {
-  {0},
-  iBaseEntSetArr_getitem,
-  iBaseEntSetArr_setitem,
-  iBaseEntSetArr_copyswapn,
-  iBaseEntSetArr_copyswap,
-  0,
-  0,
-  0,
-  0,
-  0,
-  iBaseEntSetArr_nonzero
+    {0},
+    iBaseEntSetArr_getitem,
+    iBaseEntSetArr_setitem,
+    iBaseEntSetArr_copyswapn,
+    iBaseEntSetArr_copyswap,
+    0,
+    0,
+    0,
+    0,
+    0,
+    iBaseEntSetArr_nonzero
@@ -181,13 +180,13 @@
 static PyObject *
 iBaseTagArr_getitem(void *data,void *arr)
-  return iBaseTag_FromHandle(*(iBase_TagHandle*)data);
+    return iBaseTag_FromHandle(*(iBase_TagHandle*)data);
 static int
 iBaseTagArr_setitem(PyObject *item,void *data,void *arr)
-  return 0;
+    return 0;
 static void
@@ -202,134 +201,135 @@
 static npy_bool
 iBaseTagArr_nonzero(void *data,void *arr)
-  return *(iBase_TagHandle*)data != 0;
+    return *(iBase_TagHandle*)data != 0;
 static PyArray_ArrFuncs iBaseTagArr_funcs = {
-  {0},
-  iBaseTagArr_getitem,
-  iBaseTagArr_setitem,
-  iBaseTagArr_copyswapn,
-  iBaseTagArr_copyswap,
-  0,
-  0,
-  0,
-  0,
-  0,
-  iBaseTagArr_nonzero
+    {0},
+    iBaseTagArr_getitem,
+    iBaseTagArr_setitem,
+    iBaseTagArr_copyswapn,
+    iBaseTagArr_copyswap,
+    0,
+    0,
+    0,
+    0,
+    0,
+    iBaseTagArr_nonzero
 PyMODINIT_FUNC initiBase(void)
-  PyArray_Descr *descr;
-  PyObject *m = Py_InitModule("iBase",module_methods);
-  import_array();
+    PyArray_Descr *descr;
+    PyObject *m = Py_InitModule("iBase",module_methods);
+    import_array();
-  /* register C API */
-  static void *IBase_API[6];
-  PyObject *api_obj;
+    /***** register C API *****/
+    static void *IBase_API[6];
+    PyObject *api_obj;
-  /* Initialize the C API pointer array */
-  IBase_API[0] = &iBaseEntity_Type;
-  IBase_API[1] = &NPY_IBASEENT;
-  IBase_API[2] = &iBaseEntitySet_Type;
-  IBase_API[3] = &NPY_IBASEENTSET;
-  IBase_API[4] = &iBaseTag_Type;
-  IBase_API[5] = &NPY_IBASETAG;
+    /* Initialize the C API pointer array */
+    IBase_API[0] = &iBaseEntity_Type;
+    IBase_API[1] = &NPY_IBASEENT;
+    IBase_API[2] = &iBaseEntitySet_Type;
+    IBase_API[3] = &NPY_IBASEENTSET;
+    IBase_API[4] = &iBaseTag_Type;
+    IBase_API[5] = &NPY_IBASETAG;
-  /* Create a CObject containing the API pointer array's address */
-  api_obj = PyCObject_FromVoidPtr(IBase_API,NULL);
+    /* Create a CObject containing the API pointer array's address */
+    api_obj = PyCObject_FromVoidPtr(IBase_API,NULL);
-  if(api_obj != NULL)
-    PyModule_AddObject(m, "_C_API", api_obj);
+    if(api_obj != NULL)
+        PyModule_AddObject(m, "_C_API", api_obj);
-  /***** initialize type enum *****/
-  REGISTER_SIMPLE(m,type);
+    /***** initialize type enum *****/
+    REGISTER_SIMPLE(m,type);
-  ADD_ENUM(&type_Type,"vertex", iBase_VERTEX);
-  ADD_ENUM(&type_Type,"edge",   iBase_EDGE);
-  ADD_ENUM(&type_Type,"face",   iBase_FACE);
-  ADD_ENUM(&type_Type,"region", iBase_REGION);
-  ADD_ENUM(&type_Type,"all",    iBase_ALL_TYPES);
+    ADD_ENUM(&type_Type,"vertex", iBase_VERTEX);
+    ADD_ENUM(&type_Type,"edge",   iBase_EDGE);
+    ADD_ENUM(&type_Type,"face",   iBase_FACE);
+    ADD_ENUM(&type_Type,"region", iBase_REGION);
+    ADD_ENUM(&type_Type,"all",    iBase_ALL_TYPES);
-  /***** initialize adjacency cost enum *****/
-  REGISTER_SIMPLE(m,adjCost);
+    /***** initialize adjacency cost enum *****/
+    REGISTER_SIMPLE(m,adjCost);
-  ADD_ENUM(&adjCost_Type,"unavailable",     iBase_UNAVAILABLE);
-  ADD_ENUM(&adjCost_Type,"all_order_1",     iBase_ALL_ORDER_1);
-  ADD_ENUM(&adjCost_Type,"all_order_logn",  iBase_ALL_ORDER_LOGN);
-  ADD_ENUM(&adjCost_Type,"all_order_n",     iBase_ALL_ORDER_N);
-  ADD_ENUM(&adjCost_Type,"some_order_1",    iBase_SOME_ORDER_1);
-  ADD_ENUM(&adjCost_Type,"some_order_logn", iBase_SOME_ORDER_LOGN);
-  ADD_ENUM(&adjCost_Type,"some_order_n",    iBase_SOME_ORDER_N);
+    ADD_ENUM(&adjCost_Type,"unavailable",     iBase_UNAVAILABLE);
+    ADD_ENUM(&adjCost_Type,"all_order_1",     iBase_ALL_ORDER_1);
+    ADD_ENUM(&adjCost_Type,"all_order_logn",  iBase_ALL_ORDER_LOGN);
+    ADD_ENUM(&adjCost_Type,"all_order_n",     iBase_ALL_ORDER_N);
+    ADD_ENUM(&adjCost_Type,"some_order_1",    iBase_SOME_ORDER_1);
+    ADD_ENUM(&adjCost_Type,"some_order_logn", iBase_SOME_ORDER_LOGN);
+    ADD_ENUM(&adjCost_Type,"some_order_n",    iBase_SOME_ORDER_N);
-  /***** initialize storage order enum *****/
-  REGISTER_SIMPLE(m,storageOrder);
+    /***** initialize storage order enum *****/
+    REGISTER_SIMPLE(m,storageOrder);
-  ADD_ENUM(&storageOrder_Type,"blocked",    iBase_BLOCKED);
-  ADD_ENUM(&storageOrder_Type,"interleaved",iBase_INTERLEAVED);
+    ADD_ENUM(&storageOrder_Type,"blocked",    iBase_BLOCKED);
+    ADD_ENUM(&storageOrder_Type,"interleaved",iBase_INTERLEAVED);
-  /***** initialize iBaseEntity handle *****/
-  iBaseEntity_Type.tp_repr = (reprfunc)iBaseEntObj_repr;
-  iBaseEntity_Type.tp_richcompare = (richcmpfunc)iBaseEntObj_richcompare;
-  iBaseEntity_Type.tp_new = PyType_GenericNew;
-  if(PyType_Ready(&iBaseEntity_Type) < 0)
-    return;
-  Py_INCREF(&iBaseEntity_Type);
-  PyModule_AddObject(m,"iBaseEntity",(PyObject *)&iBaseEntity_Type);
+    /***** initialize iBaseEntity handle *****/
+    iBaseEntity_Type.tp_repr = (reprfunc)iBaseEntObj_repr;
+    iBaseEntity_Type.tp_richcompare = (richcmpfunc)iBaseEntObj_richcompare;
+    iBaseEntity_Type.tp_new = PyType_GenericNew;
+    if(PyType_Ready(&iBaseEntity_Type) < 0)
+        return;
+    Py_INCREF(&iBaseEntity_Type);
+    PyModule_AddObject(m,"iBaseEntity",(PyObject *)&iBaseEntity_Type);
-  /***** initialize iBaseEntitySet handle *****/
-  iBaseEntitySet_Type.tp_repr = (reprfunc)iBaseEntSetObj_repr;
-  iBaseEntitySet_Type.tp_richcompare = (richcmpfunc)iBaseEntSetObj_richcompare;
-  iBaseEntitySet_Type.tp_new = PyType_GenericNew;
-  if(PyType_Ready(&iBaseEntitySet_Type) < 0)
-    return;
-  Py_INCREF(&iBaseEntitySet_Type);
-  PyModule_AddObject(m,"iBaseEntitySet",(PyObject *)&iBaseEntitySet_Type);
+    /***** initialize iBaseEntitySet handle *****/
+    iBaseEntitySet_Type.tp_repr = (reprfunc)iBaseEntSetObj_repr;
+    iBaseEntitySet_Type.tp_richcompare =
+        (richcmpfunc)iBaseEntSetObj_richcompare;
+    iBaseEntitySet_Type.tp_new = PyType_GenericNew;
+    if(PyType_Ready(&iBaseEntitySet_Type) < 0)
+        return;
+    Py_INCREF(&iBaseEntitySet_Type);
+    PyModule_AddObject(m,"iBaseEntitySet",(PyObject *)&iBaseEntitySet_Type);
-  /***** initialize iBaseTag handle *****/
-  iBaseTag_Type.tp_new = PyType_GenericNew;
-  if(PyType_Ready(&iBaseTag_Type) < 0)
-    return;
-  Py_INCREF(&iBaseTag_Type);
-  PyModule_AddObject(m,"iBaseTag",(PyObject *)&iBaseTag_Type);
+    /***** initialize iBaseTag handle *****/
+    iBaseTag_Type.tp_new = PyType_GenericNew;
+    if(PyType_Ready(&iBaseTag_Type) < 0)
+        return;
+    Py_INCREF(&iBaseTag_Type);
+    PyModule_AddObject(m,"iBaseTag",(PyObject *)&iBaseTag_Type);
-  /***** initialize iBaseEntity array type *****/
-  descr = PyArray_DescrNewFromType(NPY_INTP);
-  descr->f = &iBaseEntArr_funcs;
+    /***** initialize iBaseEntity array type *****/
+    descr = PyArray_DescrNewFromType(NPY_INTP);
+    descr->f = &iBaseEntArr_funcs;
-  descr->typeobj = &iBaseEntity_Type;
-  descr->kind = 'V';
-  descr->type = 'j';
-  descr->hasobject = NPY_USE_GETITEM|NPY_USE_SETITEM;
-  descr->elsize = sizeof(iBase_EntityHandle);
+    descr->typeobj = &iBaseEntity_Type;
+    descr->kind = 'V';
+    descr->type = 'j';
+    descr->hasobject = NPY_USE_GETITEM|NPY_USE_SETITEM;
+    descr->elsize = sizeof(iBase_EntityHandle);
-  NPY_IBASEENT = PyArray_RegisterDataType(descr);
+    NPY_IBASEENT = PyArray_RegisterDataType(descr);
-  /***** initialize iBaseEntitySet array type *****/
-  descr->f = &iBaseEntSetArr_funcs;
+    /***** initialize iBaseEntitySet array type *****/
+    descr->f = &iBaseEntSetArr_funcs;
-  descr->typeobj = &iBaseEntitySet_Type;
-  descr->type = 'J';
-  descr->elsize = sizeof(iBase_EntitySetHandle);
+    descr->typeobj = &iBaseEntitySet_Type;
+    descr->type = 'J';
+    descr->elsize = sizeof(iBase_EntitySetHandle);
-  NPY_IBASEENTSET = PyArray_RegisterDataType(descr);
+    NPY_IBASEENTSET = PyArray_RegisterDataType(descr);
-  /***** initialize iBaseTag array type *****/
-  descr->f = &iBaseTagArr_funcs;
+    /***** initialize iBaseTag array type *****/
+    descr->f = &iBaseTagArr_funcs;
-  descr->typeobj = &iBaseTag_Type;
-  descr->type = 'T';
-  descr->elsize = sizeof(iBase_TagHandle);
+    descr->typeobj = &iBaseTag_Type;
+    descr->type = 'T';
+    descr->elsize = sizeof(iBase_TagHandle);
-  NPY_IBASETAG = PyArray_RegisterDataType(descr);
+    NPY_IBASETAG = PyArray_RegisterDataType(descr);
Modified: MOAB/trunk/tools/iMesh/python/iBase_Python.h
--- MOAB/trunk/tools/iMesh/python/iBase_Python.h	2009-05-09 16:36:05 UTC (rev 2881)
+++ MOAB/trunk/tools/iMesh/python/iBase_Python.h	2009-05-11 19:46:19 UTC (rev 2882)
@@ -7,34 +7,34 @@
 typedef struct
-  PyObject_HEAD
-  iBase_EntityHandle handle;
+    PyObject_HEAD
+    iBase_EntityHandle handle;
 } iBaseEntity_Object;
-#define iBaseEntity_New()			 \
-  (iBaseEntity_Object*)PyObject_CallObject(	 \
-    (PyObject*)&iBaseEntity_Type,NULL)
+#define iBaseEntity_New()                               \
+    (iBaseEntity_Object*)PyObject_CallObject(           \
+        (PyObject*)&iBaseEntity_Type,NULL)
-#define iBaseEntity_Check(o)			 \
-  PyObject_TypeCheck((o),&iBaseEntity_Type)
+#define iBaseEntity_Check(o)                            \
+    PyObject_TypeCheck((o),&iBaseEntity_Type)
-#define iBaseEntity_GetHandle(o)		 \
-  ((iBaseEntity_Object*)(o))->handle
+#define iBaseEntity_GetHandle(o)                        \
+    ((iBaseEntity_Object*)(o))->handle
 typedef struct
-  PyObject_HEAD
-  iBase_EntitySetHandle handle;
+    PyObject_HEAD
+    iBase_EntitySetHandle handle;
 } iBaseEntitySet_Object;
-#define iBaseEntitySet_New()			\
-  (iBaseEntitySet_Object*)PyObject_CallObject(  \
-    (PyObject*)&iBaseEntitySet_Type,NULL)
+#define iBaseEntitySet_New()                            \
+    (iBaseEntitySet_Object*)PyObject_CallObject(        \
+        (PyObject*)&iBaseEntitySet_Type,NULL)
-#define iBaseEntitySet_Check(o)			\
+#define iBaseEntitySet_Check(o)                         \
   PyObject_TypeCheck((o),&iBaseEntitySet_Type)
-#define iBaseEntitySet_GetHandle(o)		\
+#define iBaseEntitySet_GetHandle(o)                     \
   ((iBaseEntitySet_Object*)(o))->handle
 typedef struct
@@ -43,15 +43,15 @@
   iBase_TagHandle handle;
 } iBaseTag_Object;
-#define iBaseTag_New()				\
-  (iBaseTag_Object*)PyObject_CallObject(	\
-    (PyObject*)&iBaseTag_Type,NULL)
+#define iBaseTag_New()                                  \
+    (iBaseTag_Object*)PyObject_CallObject(              \
+        (PyObject*)&iBaseTag_Type,NULL)
-#define iBaseTag_Check(o)			\
-  PyObject_TypeCheck((o),&iBaseTag_Type)
+#define iBaseTag_Check(o)                               \
+    PyObject_TypeCheck((o),&iBaseTag_Type)
-#define iBaseTag_GetHandle(o)			\
-  ((iBaseTag_Object*)(o))->handle
+#define iBaseTag_GetHandle(o)                           \
+    ((iBaseTag_Object*)(o))->handle
@@ -81,28 +81,28 @@
 #if !defined(NO_IMPORT_ARRAY) && !defined(NO_IMPORT)
 static int import_iBase(void)
-  PyObject *module = PyImport_ImportModule("itaps.iBase");
-  PyObject *c_api = NULL;
+    PyObject *module = PyImport_ImportModule("itaps.iBase");
+    PyObject *c_api = NULL;
-  if(module == NULL)
-    return -1;
+    if(module == NULL)
+        return -1;
-  c_api = PyObject_GetAttrString(module,"_C_API");
-  if(c_api == NULL)
+    c_api = PyObject_GetAttrString(module,"_C_API");
+    if(c_api == NULL)
-      Py_DECREF(module);
-      return -1;
+        Py_DECREF(module);
+        return -1;
-  if(PyCObject_Check(c_api))
-    IBase_API = (void **)PyCObject_AsVoidPtr(c_api);
+    if(PyCObject_Check(c_api))
+        IBase_API = (void **)PyCObject_AsVoidPtr(c_api);
-  Py_DECREF(c_api);
+    Py_DECREF(c_api);
-  if(IBase_API == NULL)
-    return -1;
-  return 0;
+    if(IBase_API == NULL)
+        return -1;
+    return 0;
 #endif
Deleted: MOAB/trunk/tools/iMesh/python/iBase_module.h
--- MOAB/trunk/tools/iMesh/python/iBase_module.h	2009-05-09 16:36:05 UTC (rev 2881)
+++ MOAB/trunk/tools/iMesh/python/iBase_module.h	2009-05-11 19:46:19 UTC (rev 2882)
@@ -1,53 +0,0 @@
-#pragma once
-#ifndef _IBASE_MODULE
-#if defined(PY_IBASE_UNIQUE_SYMBOL)
-#define IBase_API PY_IBASE_UNIQUE_SYMBOL
-#endif
-#if defined(NO_IMPORT) || defined(NO_IMPORT_IBASE)
-extern void **IBase_API;
-#elif defined(PY_IBASE_UNIQUE_SYMBOL)
-void **IBase_API;
-#else
-static void **IBase_API = NULL;
-#endif
-#define iBaseEntity_Type    (*(PyTypeObject*)IBase_API[0])
-#define NPY_IBASEENT        (*(int*)         IBase_API[1])
-#define iBaseEntitySet_Type (*(PyTypeObject*)IBase_API[2])
-#define NPY_IBASEENTSET     (*(int*)         IBase_API[3])
-#define iBaseTag_Type       (*(PyTypeObject*)IBase_API[4])
-#define NPY_IBASETAG        (*(int*)         IBase_API[5])
-#if !defined(NO_IMPORT_ARRAY) && !defined(NO_IMPORT)
-static int import_iBase(void)
-    return -1;
-  if(c_api == NULL)
-    return -1;
-  Py_DECREF(c_api);
-    return -1;
-  return 0;
-#endif
-#endif
Modified: MOAB/trunk/tools/iMesh/python/iMesh.c
--- MOAB/trunk/tools/iMesh/python/iMesh.c	2009-05-09 16:36:05 UTC (rev 2881)
+++ MOAB/trunk/tools/iMesh/python/iMesh.c	2009-05-11 19:46:19 UTC (rev 2882)
@@ -5,1540 +5,1560 @@
 int checkError(iMesh_Instance mesh,int err)
-  if(err)
-    char descr[512];
-    iMesh_getDescription(mesh,descr,&err,sizeof(descr));
+    if(err)
+        char descr[512];
+        iMesh_getDescription(mesh,descr,&err,sizeof(descr));
-    PyErr_SetString(PyExc_RuntimeError,descr);
-    return 1;
-  else
-    return 0;
+        PyErr_SetString(PyExc_RuntimeError,descr);
+        return 1;
+    else
+        return 0;
 PyObject *
 PyArray_TryFromObject(PyObject *obj,int typenum,int min_depth,int max_depth)
-  PyObject *ret = PyArray_FromAny(obj,PyArray_DescrFromType(typenum),min_depth,
-                                  max_depth,NPY_C_CONTIGUOUS,NULL);
-  PyErr_Clear();
-  return ret;
+    PyObject *ret = PyArray_FromAny(obj,PyArray_DescrFromType(typenum),
+                                    min_depth,max_depth,NPY_C_CONTIGUOUS,NULL);
+    PyErr_Clear();
+    return ret;
 static int
 iMeshObj_init(iMeshObject *self,PyObject *args,PyObject *kwds)
-  static char *kwlist[] = {"options",0};
-  const char *options = "";
+    static char *kwlist[] = {"options",0};
+    const char *options = "";
-  if( !PyArg_ParseTupleAndKeywords(args,kwds,"|s",kwlist,&options) )
-    return -1;
+    if( !PyArg_ParseTupleAndKeywords(args,kwds,"|s",kwlist,&options) )
+        return -1;
-  int err;
-  iMesh_newMesh(options,&self->mesh,&err,strlen(options));
-  if(checkError(self->mesh,err))
-    return -1;
+    int err;
+    iMesh_newMesh(options,&self->mesh,&err,strlen(options));
+    if(checkError(self->mesh,err))
+        return -1;
-  return 0;
+    return 0;
 static void
 iMeshObj_dealloc(iMeshObject *self)
-  if(self->mesh)
-    int err;
-    iMesh_dtor(self->mesh,&err);
+    if(self->mesh)
+        int err;
+        iMesh_dtor(self->mesh,&err);
-  self->ob_type->tp_free((PyObject*)self);
+    self->ob_type->tp_free((PyObject*)self);
 static PyObject *
 iMeshObj_load(iMeshObject *self,PyObject *args)
-  iBaseEntitySet_Object *set;
-  const char *name = 0;
-  if(!PyArg_ParseTuple(args,"Os|s",&set,&name,&options))
-    return NULL;
+    iBaseEntitySet_Object *set;
+    const char *name = 0;
+    if(!PyArg_ParseTuple(args,"Os|s",&set,&name,&options))
+        return NULL;
-  int err;
-  iMesh_load(self->mesh,set->handle,name,options,&err,strlen(name),
-	     strlen(options));
-    return NULL;
+    int err;
+    iMesh_load(self->mesh,set->handle,name,options,&err,strlen(name),
+               strlen(options));
+        return NULL;
-  Py_RETURN_NONE;
+    Py_RETURN_NONE;
 static PyObject *
 iMeshObj_save(iMeshObject *self,PyObject *args)
-    return NULL;
+        return NULL;
-  int err;
-  iMesh_save(self->mesh,set->handle,name,options,&err,strlen(name),
-	     strlen(options));
-    return NULL;
+    int err;
+    iMesh_save(self->mesh,set->handle,name,options,&err,strlen(name),
+               strlen(options));
+        return NULL;
-  Py_RETURN_NONE;
+    Py_RETURN_NONE;
 static PyObject *
 iMeshObj_getRootSet(iMeshObject *self,void *closure)
-  iMeshEntitySet_Object *rootset = iMeshEntitySet_New();
-  rootset->mesh = self; /* TODO: incref? */
+    iMeshEntitySet_Object *rootset = iMeshEntitySet_New();
+    rootset->mesh = self; /* TODO: incref? */
-  int err;
-  iMesh_getRootSet(self->mesh,&rootset->set.handle,&err);
-    Py_DECREF((PyObject*)rootset);
-    return NULL;
+    int err;
+    iMesh_getRootSet(self->mesh,&rootset->set.handle,&err);
+        Py_DECREF((PyObject*)rootset);
+        return NULL;
-  return (PyObject*)rootset;
+    return (PyObject*)rootset;
 static PyObject *
 iMeshObj_getGeometricDimension(iMeshObject *self,void *closure)
-  int dim,err;
-  iMesh_getGeometricDimension(self->mesh,&dim,&err);
-    return NULL;
+    int dim,err;
+    iMesh_getGeometricDimension(self->mesh,&dim,&err);
+        return NULL;
-  return Py_BuildValue("i",dim);
+    return Py_BuildValue("i",dim);
 static int
 iMeshObj_setGeometricDimension(iMeshObject *self,PyObject *value,void *closure)
-  if (value == NULL) {
-    PyErr_SetString(PyExc_TypeError, "Cannot delete the geometricDimension "
-		    "attribute");
-    return -1;
+    if(value == NULL)
+        PyErr_SetString(PyExc_TypeError, "Cannot delete the "
+                        "geometricDimension attribute");
+        return -1;
-  int dim,err;
-  if(!PyArg_Parse(value,"i",&dim))
-    return -1;
-  iMesh_setGeometricDimension(self->mesh,dim,&err);
-    return -1;
+    int dim,err;
+    if(!PyArg_Parse(value,"i",&dim))
+        return -1;
+    iMesh_setGeometricDimension(self->mesh,dim,&err);
+        return -1;
-  return 0;
+    return 0;
 static PyObject *
 iMeshObj_getDfltStorage(iMeshObject *self,void *closure)
-  int order,err;
-  iMesh_getDfltStorage(self->mesh,&order,&err);
-    return NULL;
+    int order,err;
+    iMesh_getDfltStorage(self->mesh,&order,&err);
+        return NULL;
-  return Py_BuildValue("i",order);
+    return Py_BuildValue("i",order);
 static PyObject *
 iMeshObj_getAdjTable(iMeshObject *self,void *closure)
-  int *adjtable=0;
-  int alloc=0,size,err;
+    int *adjtable=0;
+    int alloc=0,size,err;
-  iMesh_getAdjTable(self->mesh,&adjtable,&alloc,&size,&err);
-    return NULL;
+    iMesh_getAdjTable(self->mesh,&adjtable,&alloc,&size,&err);
+        return NULL;
-  npy_intp dims[] = {4,4};
-  return PyArray_NewFromMallocData(2,dims,NPY_INT,adjtable);
+    npy_intp dims[] = {4,4};
+    return PyArray_NewFromMallocData(2,dims,NPY_INT,adjtable);
 static PyObject *
 iMeshObj_getNumOfType(iMeshObject *self,PyObject *args)
-  enum iBase_EntityType type;
-  int num,err;
-  if(!PyArg_ParseTuple(args,"O!i",&iBaseEntitySet_Type,&set,&type))
-    return NULL;
+    enum iBase_EntityType type;
+    int num,err;
+    if(!PyArg_ParseTuple(args,"O!i",&iBaseEntitySet_Type,&set,&type))
+        return NULL;
-  iMesh_getNumOfType(self->mesh,set->handle,type,&num,&err);
-    return NULL;
+    iMesh_getNumOfType(self->mesh,set->handle,type,&num,&err);
+        return NULL;
-  return Py_BuildValue("i",num);
+    return Py_BuildValue("i",num);
 static PyObject *
 iMeshObj_getNumOfTopo(iMeshObject *self,PyObject *args)
-  enum iMesh_EntityTopology topo;
-  int num,err;
-  if(!PyArg_ParseTuple(args,"O!i",&iBaseEntitySet_Type,&set,&topo))
-    return NULL;
+    enum iMesh_EntityTopology topo;
+    int num,err;
+    if(!PyArg_ParseTuple(args,"O!i",&iBaseEntitySet_Type,&set,&topo))
+        return NULL;
-  iMesh_getNumOfTopo(self->mesh,set->handle,topo,&num,&err);
-    return NULL;
+    iMesh_getNumOfTopo(self->mesh,set->handle,topo,&num,&err);
+        return NULL;
 static PyObject *
 iMeshObj_areEHValid(iMeshObject *self,PyObject *args)
-  int doReset,areInv,err;
-  if(!PyArg_ParseTuple(args,"i",&doReset))
-    return NULL;
+    int doReset,areInv,err;
+    if(!PyArg_ParseTuple(args,"i",&doReset))
+        return NULL;
-  iMesh_areEHValid(self->mesh,doReset,&areInv,&err);
-    return NULL;
+    iMesh_areEHValid(self->mesh,doReset,&areInv,&err);
+        return NULL;
-  return Py_BuildValue("i",areInv);
+    return Py_BuildValue("i",areInv);
 static PyObject *
 iMeshObj_getEntities(iMeshObject *self,PyObject *args)
-  iBase_EntityHandle *entities=0;
+    iBase_EntityHandle *entities=0;
-  if(!PyArg_ParseTuple(args,"O!ii",&iBaseEntitySet_Type,&set,&type,&topo))
-    return NULL;
+    if(!PyArg_ParseTuple(args,"O!ii",&iBaseEntitySet_Type,&set,&type,&topo))
+        return NULL;
-  iMesh_getEntities(self->mesh,set->handle,type,topo,&entities,&alloc,&size,
-		    &err);
-    return NULL;
+    iMesh_getEntities(self->mesh,set->handle,type,topo,&entities,&alloc,&size,
+                      &err);
+        return NULL;
-  npy_intp dims[] = {size};
-  return PyArray_NewFromMallocData(1,dims,NPY_IBASEENT,entities);
+    npy_intp dims[] = {size};
+    return PyArray_NewFromMallocData(1,dims,NPY_IBASEENT,entities);
 static PyObject *
 iMeshObj_getVtxCoords(iMeshObject *self,PyObject *args)
-  PyObject *obj;
-  int storage_order=-1;
-  int err;
+    PyObject *obj;
+    int storage_order=-1;
+    int err;
-  if(!PyArg_ParseTuple(args,"O|i",&obj,&storage_order))
-    return NULL;
+    if(!PyArg_ParseTuple(args,"O|i",&obj,&storage_order))
+        return NULL;
-  PyObject *ents = PyArray_TryFromObject(obj,NPY_IBASEENT,1,1);
-  if(ents)
-    if(storage_order == -1)
+    PyObject *ents = PyArray_TryFromObject(obj,NPY_IBASEENT,1,1);
+    if(ents)
-      PyErr_SetString(PyExc_ValueError,ERR_STORAGE_ORDER);
-      return NULL;
+        if(storage_order == -1)
+            PyErr_SetString(PyExc_ValueError,ERR_STORAGE_ORDER);
+            return NULL;
-    int size;
-    double *coords=0;
-    int coords_alloc=0,coords_size;
+        int size;
+        double *coords=0;
+        int coords_alloc=0,coords_size;
-    size = PyArray_SIZE(ents);
-    iBase_EntityHandle *data = PyArray_DATA(ents);
+        size = PyArray_SIZE(ents);
+        iBase_EntityHandle *data = PyArray_DATA(ents);
-    iMesh_getVtxArrCoords(self->mesh,data,size,storage_order,&coords,
-			  &coords_alloc,&coords_size,&err);
-    Py_DECREF(ents);
+        iMesh_getVtxArrCoords(self->mesh,data,size,storage_order,&coords,
+                              &coords_alloc,&coords_size,&err);
+        Py_DECREF(ents);
-      return NULL;
+            return NULL;
-    npy_intp outer;
-    if(storage_order == iBase_BLOCKED)
-      outer = 3;
+        npy_intp outer;
+        if(storage_order == iBase_BLOCKED)
+            outer = 3;
+        else
+            outer = size;
+        /* TODO: think about this */
+        npy_intp dims[] = {outer,coords_size/outer};
+        return PyArray_NewFromMallocData(2,dims,NPY_DOUBLE,coords);
+    else if(iBaseEntity_Check(obj))
+        double *v = malloc(3*sizeof(double));
+        iMesh_getVtxCoord(self->mesh,iBaseEntity_GetHandle(obj), v+0,v+1,v+2,
+                          &err);
+            return NULL;
+        npy_intp dims[] = {3};
+        return PyArray_NewFromMallocData(1,dims,NPY_DOUBLE,v);
     else
-      outer = size;
-    npy_intp dims[] = {outer,coords_size/outer}; /* TODO: think about this */
-    return PyArray_NewFromMallocData(2,dims,NPY_DOUBLE,coords);
-  else if(iBaseEntity_Check(obj))
-    double *v = malloc(3*sizeof(double));
-    iMesh_getVtxCoord(self->mesh,iBaseEntity_GetHandle(obj), v+0,v+1,v+2,
-		      &err);
-      return NULL;
-    npy_intp dims[] = {3};
-    return PyArray_NewFromMallocData(1,dims,NPY_DOUBLE,v);
-  else
-    PyErr_SetString(PyExc_ValueError,ERR_ENT_OR_ENTARR);
-    return NULL;
+        PyErr_SetString(PyExc_ValueError,ERR_ENT_OR_ENTARR);
+        return NULL;
 static PyObject *
 iMeshObj_getEntTopo(iMeshObject *self,PyObject *args)
-  PyObject *obj;
-  int err;
+    PyObject *obj;
+    int err;
-  if(!PyArg_ParseTuple(args,"O",&obj))
-    return NULL;
+    if(!PyArg_ParseTuple(args,"O",&obj))
+        return NULL;
-  if(ents)
-    int size;
-    iBase_EntityHandle *data;
-    int *topos=0;
-    int topo_alloc=0,topo_size;
+    if(ents)
+        int size;
+        iBase_EntityHandle *data;
+        int *topos=0;
+        int topo_alloc=0,topo_size;
-    data = PyArray_DATA(ents);
+        data = PyArray_DATA(ents);
-    iMesh_getEntArrTopo(self->mesh,data,size,&topos,&topo_alloc,&topo_size,
-			&err);
-    Py_DECREF(ents);
-      return NULL;
+        iMesh_getEntArrTopo(self->mesh,data,size,&topos,&topo_alloc,&topo_size,
+                            &err);
+        Py_DECREF(ents);
+            return NULL;
-    npy_intp dims[] = {topo_size};
-    return PyArray_NewFromMallocData(1,dims,NPY_UINT,topos);
-    int topo;
-    iBase_EntityHandle handle = ((iBaseEntity_Object*)obj)->handle;
+        npy_intp dims[] = {topo_size};
+        return PyArray_NewFromMallocData(1,dims,NPY_UINT,topos);
+        int topo;
+        iBase_EntityHandle handle = ((iBaseEntity_Object*)obj)->handle;
-    iMesh_getEntTopo(self->mesh,handle,&topo,&err);
-      return NULL;
+        iMesh_getEntTopo(self->mesh,handle,&topo,&err);
+            return NULL;
-    return PyInt_FromLong(topo);
-  else
-    return NULL;
+        return PyInt_FromLong(topo);
+    else
+        return NULL;
 static PyObject *
 iMeshObj_getEntType(iMeshObject *self,PyObject *args)
-  PyObject *obj;
-  int err;
+    PyObject *obj;
+    int err;
-    return NULL;
+        return NULL;
-  if(ents)
-    int size;
-    int *types=0;
-    int type_alloc=0,type_size;
+    if(ents)
+        int size;
+        int *types=0;
+        int type_alloc=0,type_size;
-    iMesh_getEntArrType(self->mesh,data,size,&types,&type_alloc,&type_size,
-			&err);
-    Py_DECREF(ents);
-      return NULL;
+        iMesh_getEntArrType(self->mesh,data,size,&types,&type_alloc,&type_size,
+                            &err);
+        Py_DECREF(ents);
+            return NULL;
-    npy_intp dims[] = {type_size};
-    return PyArray_NewFromMallocData(1,dims,NPY_UINT,types);
-    int type;
-    iMesh_getEntType(self->mesh,handle,&type,&err);
-      return NULL;
+        npy_intp dims[] = {type_size};
+        return PyArray_NewFromMallocData(1,dims,NPY_UINT,types);
+        int type;
+        iMesh_getEntType(self->mesh,handle,&type,&err);
+            return NULL;
-    return PyInt_FromLong(type);
-  else
-    return NULL;
+        return PyInt_FromLong(type);
+    else
+        return NULL;
 static PyObject *
 iMeshObj_getEntAdj(iMeshObject *self,PyObject *args)
-  PyObject *obj;
-  int type_req;
-  int err;
+    PyObject *obj;
+    int type_req;
+    int err;
-  if(!PyArg_ParseTuple(args,"Oi",&obj,&type_req))
-    return NULL;
+    if(!PyArg_ParseTuple(args,"Oi",&obj,&type_req))
+        return NULL;
-  if(ents)
-    int size;
-    iBase_EntityHandle *adj=0;
-    int adj_alloc=0,adj_size;
-    int *offsets;
-    int offsets_alloc=0,offsets_size;
+    if(ents)
+        int size;
+        iBase_EntityHandle *adj=0;
+        int adj_alloc=0,adj_size;
+        int *offsets;
+        int offsets_alloc=0,offsets_size;
-    iMesh_getEntArrAdj(self->mesh,data,size,type_req,&adj,&adj_alloc,&adj_size,
-		       &offsets,&offsets_alloc,&offsets_size,&err);
-    Py_DECREF(ents);
-      return NULL;
+        iMesh_getEntArrAdj(self->mesh,data,size,type_req,&adj,&adj_alloc,
+                           &adj_size,&offsets,&offsets_alloc,&offsets_size,
+                           &err);
+        Py_DECREF(ents);
+            return NULL;
-    /* TODO: this is clunky */
-    PyObject *pair = PyTuple_New(2);
-    npy_intp dims[1];
+        /* TODO: this is clunky */
+        PyObject *pair = PyTuple_New(2);
+        npy_intp dims[1];
-    dims[0] = adj_size;
-    PyTuple_SET_ITEM(pair, 0, PyArray_NewFromMallocData(
-      1,dims,NPY_IBASEENT,adj));
+        dims[0] = adj_size;
+        PyTuple_SET_ITEM(pair, 0,
+            PyArray_NewFromMallocData(1,dims,NPY_IBASEENT,adj));
-    dims[0] = offsets_size;
-    PyTuple_SET_ITEM(pair, 1, PyArray_NewFromMallocData(
-      1,dims,NPY_INT,offsets));
+        dims[0] = offsets_size;
+        PyTuple_SET_ITEM(pair, 1,
+            PyArray_NewFromMallocData(1,dims,NPY_INT,offsets));
-    return pair;
-    iBase_EntityHandle handle = iBaseEntity_GetHandle(obj);
+        return pair;
+        iBase_EntityHandle handle = iBaseEntity_GetHandle(obj);
-    iMesh_getEntAdj(self->mesh,handle,type_req,&adj,&adj_alloc,&adj_size,&err);
-      return NULL;
+        iMesh_getEntAdj(self->mesh,handle,type_req,&adj,&adj_alloc,&adj_size,
+                        &err);
+            return NULL;
-    npy_intp dims[] = {adj_size};
-    return PyArray_NewFromMallocData(1,dims,NPY_IBASEENT,adj);
-  else
-    return NULL;
+        npy_intp dims[] = {adj_size};
+        return PyArray_NewFromMallocData(1,dims,NPY_IBASEENT,adj);
+    else
+        return NULL;
 static PyObject *
 iMeshObj_getEnt2ndAdj(iMeshObject *self,PyObject *args)
-  PyObject *obj;
-  int bridge_type,type_req;
-  int err;
+    PyObject *obj;
+    int bridge_type,type_req;
+    int err;
-  if(!PyArg_ParseTuple(args,"Oii",&obj,&bridge_type,&type_req))
-    return NULL;
+    if(!PyArg_ParseTuple(args,"Oii",&obj,&bridge_type,&type_req))
+        return NULL;
-  if(ents)
-    int size;
-    int *offsets;
+    if(ents)
+        int size;
+        int *offsets;
-    iMesh_getEntArr2ndAdj(self->mesh,data,size,bridge_type,type_req,&adj,
-			  &adj_alloc,&adj_size,&offsets,&offsets_alloc,
-			  &offsets_size,&err);
-    Py_DECREF(ents);
-      return NULL;
+        iMesh_getEntArr2ndAdj(self->mesh,data,size,bridge_type,type_req,&adj,
+                              &adj_alloc,&adj_size,&offsets,&offsets_alloc,
+                              &offsets_size,&err);
+        Py_DECREF(ents);
+            return NULL;
-    npy_intp dims[1];
+        npy_intp dims[1];
-    return pair;
+        return pair;
-    iMesh_getEnt2ndAdj(self->mesh,handle,bridge_type,type_req,&adj,&adj_alloc,
-		       &adj_size,&err);
-      return NULL;
+        iMesh_getEnt2ndAdj(self->mesh,handle,bridge_type,type_req,&adj,
+                           &adj_alloc,&adj_size,&err);
+            return NULL;
-  else
-    return NULL;
+    else
+        return NULL;
 static PyObject *
 iMeshObj_getAdjEntIndices(iMeshObject *self,PyObject *args)
-  int type_requestor,topo_requestor,type_requested;
-  int err;
+    int type_requestor,topo_requestor,type_requested;
+    int err;
-  if(!PyArg_ParseTuple(args,"O!iii",&iBaseEntitySet_Type,&set,
-		       &type_requestor,&topo_requestor,&type_requested))
-    return NULL;
+    if(!PyArg_ParseTuple(args,"O!iii",&iBaseEntitySet_Type,&set,
+                         &type_requestor,&topo_requestor,&type_requested))
+        return NULL;
-  int ent_alloc=0,ent_size;
-  iBase_EntityHandle *adj_ents=0;
-  int *indices=0;
-  int ind_alloc=0,ind_size;
-  int *offsets=0;
-  int off_alloc=0,off_size;
+    int ent_alloc=0,ent_size;
+    iBase_EntityHandle *adj_ents=0;
+    int *indices=0;
+    int ind_alloc=0,ind_size;
+    int *offsets=0;
+    int off_alloc=0,off_size;
-  iMesh_getAdjEntIndices(self->mesh,set->handle,type_requestor,topo_requestor,
-			 type_requested,
-			 &entities,&ent_alloc,&ent_size,
-			 &adj_ents,&adj_alloc,&adj_size,
-			 &indices, &ind_alloc,&ind_size,
-			 &offsets, &off_alloc,&off_size,
-			 &err);
-    return NULL;
+    iMesh_getAdjEntIndices(self->mesh,set->handle,type_requestor,
+                           topo_requestor,type_requested,
+                           &entities,&ent_alloc,&ent_size,
+                           &adj_ents,&adj_alloc,&adj_size,
+                           &indices, &ind_alloc,&ind_size,
+                           &offsets, &off_alloc,&off_size,
+                           &err);
+        return NULL;
-  PyObject *tup = PyTuple_New(4);
-  npy_intp dims[1];
+    PyObject *tup = PyTuple_New(4);
+    npy_intp dims[1];
-  dims[0] = ent_size;
-  PyTuple_SET_ITEM(tup, 0, PyArray_NewFromMallocData(
-    1,dims,NPY_IBASEENT,entities));
+    dims[0] = ent_size;
+    PyTuple_SET_ITEM(tup, 0,
+        PyArray_NewFromMallocData(1,dims,NPY_IBASEENT,entities));
-  PyTuple_SET_ITEM(tup, 1, PyArray_NewFromMallocData(
-    1,dims,NPY_IBASEENT,adj_ents));
+    PyTuple_SET_ITEM(tup, 1,
+        PyArray_NewFromMallocData(1,dims,NPY_IBASEENT,adj_ents));
-  dims[0] = ind_size;
-  PyTuple_SET_ITEM(tup, 2, PyArray_NewFromMallocData(
-    1,dims,NPY_INT,indices));
+    dims[0] = ind_size;
+    PyTuple_SET_ITEM(tup, 2,
+        PyArray_NewFromMallocData(1,dims,NPY_INT,indices));
-  dims[0] = off_size;
-  PyTuple_SET_ITEM(tup, 3, PyArray_NewFromMallocData(
+    dims[0] = off_size;
+    PyTuple_SET_ITEM(tup, 3,
-  return tup;
+    return tup;
 static PyObject *
 iMeshObj_createEntSet(iMeshObject *self,PyObject *args)
-  int isList,err;
-  PyObject *obj;
-  iMeshEntitySet_Object *set;
+    int isList,err;
+    PyObject *obj;
+    iMeshEntitySet_Object *set;
-  if(!PyArg_ParseTuple(args,"O!",&PyBool_Type,&obj))
-    return NULL;
+    if(!PyArg_ParseTuple(args,"O!",&PyBool_Type,&obj))
+        return NULL;
-  set = iMeshEntitySet_New();
-  set->mesh = self;
-  /*Py_INCREF(self); TODO?? */
+    set = iMeshEntitySet_New();
+    set->mesh = self;
+    /*Py_INCREF(self); TODO?? */
-  isList = (obj == Py_True);
+    isList = (obj == Py_True);
-  iMesh_createEntSet(self->mesh,isList,&set->set.handle,&err);
-    Py_DECREF((PyObject*)set);
-    return NULL;
+    iMesh_createEntSet(self->mesh,isList,&set->set.handle,&err);
+        Py_DECREF((PyObject*)set);
+        return NULL;
-  return (PyObject*)set;
+    return (PyObject*)set;
 static PyObject *
 iMeshObj_destroyEntSet(iMeshObject *self,PyObject *args)
-  int err;
+    int err;
-  if(!PyArg_ParseTuple(args,"O!",&iBaseEntitySet_Type,&set))
-    return NULL;
+    if(!PyArg_ParseTuple(args,"O!",&iBaseEntitySet_Type,&set))
+        return NULL;
-  iMesh_destroyEntSet(self->mesh,set->handle,&err);
-    return NULL;
+    iMesh_destroyEntSet(self->mesh,set->handle,&err);
+        return NULL;
-  Py_RETURN_NONE;
+    Py_RETURN_NONE;
 static PyObject *
 iMeshObj_setVtxCoords(iMeshObject *self,PyObject *args)
-  PyObject *obj;
-  PyObject *data;
-  PyObject *ents = 0;
-  PyObject *verts = 0;
-  int err;
+    PyObject *obj;
+    int storage_order = -1;
+    PyObject *data;
+    PyObject *ents = 0;
+    PyObject *verts = 0;
+    int err;
-  if(!PyArg_ParseTuple(args,"OO|i",&obj,&data,&storage_order))
-    return NULL;
+    if(!PyArg_ParseTuple(args,"OO|i",&obj,&data,&storage_order))
+        return NULL;
-  ents = PyArray_TryFromObject(obj,NPY_IBASEENT,1,1);
-  if(ents)
+    ents = PyArray_TryFromObject(obj,NPY_IBASEENT,1,1);
+    if(ents)
-      goto err;
+            goto err;
+        verts = PyArray_FROMANY(data,NPY_DOUBLE,2,2,NPY_C_CONTIGUOUS);
+        if(verts == NULL)
+            goto err;
+        int ent_size = PyArray_SIZE(ents);
+        iBase_EntityHandle *entities = PyArray_DATA(ents);
+        int coord_size = PyArray_SIZE(verts);
+        double *coords = PyArray_DATA(verts);
+        iMesh_setVtxArrCoords(self->mesh,entities,ent_size,storage_order,
+                              coords,coord_size,&err);
+        Py_DECREF(ents);
+        Py_DECREF(verts);
+        verts = PyArray_FROMANY(data,NPY_DOUBLE,1,1,NPY_C_CONTIGUOUS);
+        if(verts == NULL)
+            goto err;
-    verts = PyArray_FROMANY(data,NPY_DOUBLE,2,2,NPY_C_CONTIGUOUS);
-    if(verts == NULL)
-      goto err;
+        if(PyArray_SIZE(verts) != 3)
+            PyErr_SetString(PyExc_ValueError,ERR_ARR_SIZE);
+            goto err;
-    int ent_size = PyArray_SIZE(ents);
-    iBase_EntityHandle *entities = PyArray_DATA(ents);
-    int coord_size = PyArray_SIZE(verts);
-    double *coords = PyArray_DATA(verts);
+        double *v = PyArray_DATA(verts);
+        iBase_EntityHandle entity = iBaseEntity_GetHandle(obj);
-    iMesh_setVtxArrCoords(self->mesh,entities,ent_size,storage_order,coords,
-			  coord_size,&err);
-    Py_DECREF(ents);
-    Py_DECREF(verts);
-    verts = PyArray_FROMANY(data,NPY_DOUBLE,1,1,NPY_C_CONTIGUOUS);
-    if(verts == NULL)
-      goto err;
-    if(PyArray_SIZE(verts) != 3)
+        iMesh_setVtxCoord(self->mesh,entity, v[0],v[1],v[2], &err);
+        Py_DECREF(verts);
+    else
-      PyErr_SetString(PyExc_ValueError,ERR_ARR_SIZE);
-      goto err;
+        return NULL;
-    double *v = PyArray_DATA(verts);
-    iBase_EntityHandle entity = iBaseEntity_GetHandle(obj);
+        return NULL;
+    Py_RETURN_NONE;
-    iMesh_setVtxCoord(self->mesh,entity, v[0],v[1],v[2], &err);
-    Py_DECREF(verts);
-  else
+err:
+    Py_XDECREF(ents);
+    Py_XDECREF(verts);
     return NULL;
-    return NULL;
-  Py_RETURN_NONE;
- err:
-  Py_XDECREF(ents);
-  Py_XDECREF(verts);
-  return NULL;
 static PyObject *
 iMeshObj_createVtx(iMeshObject *self,PyObject *args)
-  PyObject *data;
-  PyObject *vertices;
-  int err;
+    PyObject *data;
+    PyObject *vertices;
+    int err;
-  if(!PyArg_ParseTuple(args,"O|i",&data,&storage_order))
-    return NULL;
+    if(!PyArg_ParseTuple(args,"O|i",&data,&storage_order))
+        return NULL;
-  if( (vertices = PyArray_TryFromObject(data,NPY_DOUBLE,2,2)) != NULL)
+    if( (vertices = PyArray_TryFromObject(data,NPY_DOUBLE,2,2)) != NULL)
-      Py_DECREF(vertices);
-      return NULL;
+            Py_DECREF(vertices);
+            return NULL;
-    int index = storage_order == iBase_BLOCKED;
-    int count = PyArray_DIM(vertices,index); /* this is a bit odd! */
-    int coord_size = PyArray_SIZE(vertices);
-    double *coords = PyArray_DATA(vertices);
+        int index = storage_order == iBase_BLOCKED;
+        int count = PyArray_DIM(vertices,index); /* this is a bit odd! */
+        int coord_size = PyArray_SIZE(vertices);
+        double *coords = PyArray_DATA(vertices);
-    iMesh_createVtxArr(self->mesh,count,storage_order,coords,coord_size,
-		       &entities,&ent_alloc,&ent_size,&err);
-      return NULL;
+        iMesh_createVtxArr(self->mesh,count,storage_order,coords,coord_size,
+                           &entities,&ent_alloc,&ent_size,&err);
+            return NULL;
-    npy_intp dims[] = {ent_size};
-  else if( (vertices = PyArray_TryFromObject(data,NPY_DOUBLE,1,1)) != NULL)
-    if(PyArray_SIZE(vertices) != 3)
+        npy_intp dims[] = {ent_size};
+    else if( (vertices = PyArray_TryFromObject(data,NPY_DOUBLE,1,1)) != NULL)
-      return NULL;
+        if(PyArray_SIZE(vertices) != 3)
+            return NULL;
-    double *v = PyArray_DATA(vertices);
+        double *v = PyArray_DATA(vertices);
-    iBaseEntity_Object *entity = iBaseEntity_New();
-    iMesh_createVtx(self->mesh, v[0],v[1],v[2], &entity->handle,&err);
+        iBaseEntity_Object *entity = iBaseEntity_New();
+        iMesh_createVtx(self->mesh, v[0],v[1],v[2], &entity->handle,&err);
+            Py_DECREF((PyObject*)entity);
+            return NULL;
+        return (PyObject*)entity;
+    else
-      Py_DECREF((PyObject*)entity);
-      return NULL;
+        PyErr_SetString(PyExc_ValueError,ERR_ARR_DIMS);
+        return NULL;
-    return (PyObject*)entity;
-  else
-    PyErr_SetString(PyExc_ValueError,ERR_ARR_DIMS);
-    return NULL;
 static PyObject *
 iMeshObj_createEnt(iMeshObject *self,PyObject *args)
-  int topo,status,err;
-  PyObject *obj;
+    int topo,status,err;
+    PyObject *obj;
-  if(!PyArg_ParseTuple(args,"iO",&topo,&obj))
-    return NULL;
+    if(!PyArg_ParseTuple(args,"iO",&topo,&obj))
+        return NULL;
-  PyObject *ents = PyArray_FROMANY(obj,NPY_IBASEENT,1,1,NPY_C_CONTIGUOUS);
-  if(ents == NULL)
-    return NULL;
+    PyObject *ents = PyArray_FROMANY(obj,NPY_IBASEENT,1,1,NPY_C_CONTIGUOUS);
+    if(ents == NULL)
+        return NULL;
-  int lower_size = PyArray_SIZE(ents);
-  iBase_EntityHandle *lower = PyArray_DATA(ents);
+    int lower_size = PyArray_SIZE(ents);
+    iBase_EntityHandle *lower = PyArray_DATA(ents);
-  iMesh_createEnt(self->mesh,topo,lower,lower_size,&entity->handle,&status,
-		  &err);
-  Py_DECREF(ents);
-    Py_DECREF(pair);
-    return NULL;
+    iMesh_createEnt(self->mesh,topo,lower,lower_size,&entity->handle,&status,
+                    &err);
+    Py_DECREF(ents);
+        Py_DECREF(pair);
+        return NULL;
-  PyTuple_SET_ITEM(pair,0,(PyObject*)entity);
-  PyTuple_SET_ITEM(pair,1,Py_BuildValue("i",status));
-  return pair;
+    PyTuple_SET_ITEM(pair,0,(PyObject*)entity);
+    PyTuple_SET_ITEM(pair,1,Py_BuildValue("i",status));
+    return pair;
 static PyObject *
 iMeshObj_createEntArr(iMeshObject *self,PyObject *args)
-  int topo,err;
-  PyObject *obj;
+    int topo,err;
+    PyObject *obj;
-    return NULL;
+        return NULL;
-  if(ents == NULL)
-    return NULL;
+    if(ents == NULL)
+        return NULL;
-  int *status;
-  int stat_alloc=0,stat_size;
+    int *status;
+    int stat_alloc=0,stat_size;
-  iMesh_createEntArr(self->mesh,topo,lower,lower_size,&entities,&ent_alloc,
-		     &ent_size,&status,&stat_alloc,&stat_size,&err);
-  Py_DECREF(ents);
-    return NULL;
+    iMesh_createEntArr(self->mesh,topo,lower,lower_size,&entities,&ent_alloc,
+                       &ent_size,&status,&stat_alloc,&stat_size,&err);
+    Py_DECREF(ents);
+        return NULL;
-  npy_intp dims[1];
+    npy_intp dims[1];
-  dims[0] = stat_size;
-    1,dims,NPY_INT,status));
+    dims[0] = stat_size;
+        PyArray_NewFromMallocData(1,dims,NPY_INT,status));
-  return pair;
+    return pair;
 static PyObject *
 iMeshObj_deleteEnt(iMeshObject *self,PyObject *args)
-  PyObject *obj;
-  int err;
+    PyObject *obj;
+    int err;
-    return NULL;
+        return NULL;
-  if(ents)
-    int size = PyArray_SIZE(ents);
-    iMesh_deleteEntArr(self->mesh,entities,size,&err);
-    Py_DECREF(ents);
-    iMesh_deleteEnt(self->mesh,entity,&err);
-  else
-    return NULL;
+    if(ents)
+        int size = PyArray_SIZE(ents);
+        iMesh_deleteEntArr(self->mesh,entities,size,&err);
+        Py_DECREF(ents);
+        iMesh_deleteEnt(self->mesh,entity,&err);
+    else
+        return NULL;
-    return NULL;
-  Py_RETURN_NONE;
+        return NULL;
+    Py_RETURN_NONE;
 static PyObject *
 iMeshObj_createTag(iMeshObject *self,PyObject *args)
-  char *name;
-  char typechar;
-  int size,type,err;
-  iMeshTag_Object *tag;
+    char *name;
+    char typechar;
+    int size,type,err;
+    iMeshTag_Object *tag;
-  if(!PyArg_ParseTuple(args,"sic",&name,&size,&typechar))
-    return NULL;
+    if(!PyArg_ParseTuple(args,"sic",&name,&size,&typechar))
+        return NULL;
-  type = char_to_type(typechar);
-  if(type == -1)
-    PyErr_SetString(PyExc_ValueError,ERR_TYPE_CODE);
-    return NULL;
+    type = char_to_type(typechar);
+    if(type == -1)
+        PyErr_SetString(PyExc_ValueError,ERR_TYPE_CODE);
+        return NULL;
-  tag = iMeshTag_New();
-  tag->mesh = self;
+    tag = iMeshTag_New();
+    tag->mesh = self;
-  iMesh_createTag(self->mesh,name,size,type,&tag->tag.handle,&err,
-		  strlen(name));
-    Py_DECREF((PyObject*)tag);
-    return NULL;
+    iMesh_createTag(self->mesh,name,size,type,&tag->tag.handle,&err,
+                    strlen(name));
+        Py_DECREF((PyObject*)tag);
+        return NULL;
-  return (PyObject*)tag;
+    return (PyObject*)tag;
 static PyObject *
 iMeshObj_destroyTag(iMeshObject *self,PyObject *args)
-  int forced,err;
-  iBaseTag_Object *tag;
-  PyObject *obj;
+    int forced,err;
+    iBaseTag_Object *tag;
+    PyObject *obj;
-  if(!PyArg_ParseTuple(args,"O!O!",&iBaseTag_Type,&tag,
-		       &PyBool_Type,&obj))
-    return NULL;
+    if(!PyArg_ParseTuple(args,"O!O!",&iBaseTag_Type,&tag,&PyBool_Type,&obj))
+        return NULL;
-  forced = (obj == Py_True);
+    forced = (obj == Py_True);
-  iMesh_destroyTag(self->mesh,tag->handle,forced,&err);
-    return NULL;
+    iMesh_destroyTag(self->mesh,tag->handle,forced,&err);
+        return NULL;
-  Py_RETURN_NONE;
+    Py_RETURN_NONE;
 static PyObject *
 iMeshObj_getTagHandle(iMeshObject *self,PyObject *args)
-  char *name;
-  int err;
+    char *name;
+    int err;
-  if(!PyArg_ParseTuple(args,"s",&name))
-    return NULL;
+    if(!PyArg_ParseTuple(args,"s",&name))
+        return NULL;
-  tag->mesh = self;
+    tag->mesh = self;
-  iMesh_getTagHandle(self->mesh,name,&tag->tag.handle,&err,strlen(name));
-    return NULL;
+    iMesh_getTagHandle(self->mesh,name,&tag->tag.handle,&err,strlen(name));
+        return NULL;
 static PyObject *
 iMeshObj_setData(iMeshObject *self,PyObject *args)
-  PyObject *obj;
-  PyObject *data_obj;
-  char typechar=0;
-  int type;
-  int err;
+    PyObject *obj;
+    PyObject *data_obj;
+    char typechar=0;
+    int type;
+    int err;
-  if(!PyArg_ParseTuple(args,"OO!O|c",&obj,&iBaseTag_Type,&tag,&data_obj,
-		       &typechar))
-    return NULL;
+    if(!PyArg_ParseTuple(args,"OO!O|c",&obj,&iBaseTag_Type,&tag,&data_obj,
+                         &typechar))
+        return NULL;
-  if(typechar == 0)
-    /* infer the type of the data */
-    iMesh_getTagType(self->mesh,tag->handle,&type,&err);
-      return NULL;
-  else
-    if(type == -1)
+    if(typechar == 0)
-      return NULL;
+        /* infer the type of the data */
+        iMesh_getTagType(self->mesh,tag->handle,&type,&err);
+            return NULL;
+    else
+        if(type == -1)
+            return NULL;
-  if(ents)
-    int ent_size;
-    iBase_EntityHandle *entities;
-    int data_size;
-    PyObject *data_arr=0;
+    if(ents)
+        int ent_size;
+        iBase_EntityHandle *entities;
+        int data_size;
+        PyObject *data_arr=0;
-    ent_size = PyArray_SIZE(ents);
-    entities = PyArray_DATA(ents);
+        ent_size = PyArray_SIZE(ents);
+        entities = PyArray_DATA(ents);
-    if(type == iBase_INTEGER)
-      data_arr = PyArray_FROMANY(data_obj,NPY_INT,1,1,NPY_C_CONTIGUOUS);
-      if(data_arr == NULL)
-	return NULL;
+        if(type == iBase_INTEGER)
+            data_arr = PyArray_FROMANY(data_obj,NPY_INT,1,1,NPY_C_CONTIGUOUS);
+            if(data_arr == NULL)
+                return NULL;
-      data_size = PyArray_SIZE(data_arr);
-      int *data = PyArray_DATA(data_arr);
-      iMesh_setIntArrData(self->mesh,entities,ent_size,tag->handle,data,
-                          data_size,&err);
-    else if(type == iBase_DOUBLE)
-      data_arr = PyArray_FROMANY(data_obj,NPY_DOUBLE,1,1,NPY_C_CONTIGUOUS);
-        return NULL;
+            data_size = PyArray_SIZE(data_arr);
+            int *data = PyArray_DATA(data_arr);
+            iMesh_setIntArrData(self->mesh,entities,ent_size,tag->handle,data,
+                                data_size,&err);
+        else if(type == iBase_DOUBLE)
+            data_arr = PyArray_FROMANY(data_obj,NPY_DOUBLE,1,1,
+                                       NPY_C_CONTIGUOUS);
+                return NULL;
-      double *data = PyArray_DATA(data_arr);
-      iMesh_setDblArrData(self->mesh,entities,ent_size,tag->handle,data,
-                          data_size,&err);
+            double *data = PyArray_DATA(data_arr);
+            iMesh_setDblArrData(self->mesh,entities,ent_size,tag->handle,data,
+                                data_size,&err);
+        else if(type == iBase_ENTITY_HANDLE)
+            data_arr = PyArray_FROMANY(data_obj,NPY_IBASEENT,1,1,
+                return NULL;
+            iBase_EntityHandle *data = PyArray_DATA(data_arr);
+            iMesh_setEHArrData(self->mesh,entities,ent_size,tag->handle,data,
+                               data_size,&err);
-    else if(type == iBase_ENTITY_HANDLE)
-      data_arr = PyArray_FROMANY(data_obj,NPY_IBASEENT,1,1,NPY_C_CONTIGUOUS);
-        return NULL;
+        else /* iBase_BYTES */
+            /* TODO: I have no idea if this is right */
+            data_arr = PyArray_FROMANY(data_obj,NPY_BYTE,1,1,NPY_C_CONTIGUOUS);
+                return NULL;
-      iBase_EntityHandle *data = PyArray_DATA(data_arr);
-      iMesh_setEHArrData(self->mesh,entities,ent_size,tag->handle,data,
-                         data_size,&err);
+            char *data = PyArray_DATA(data_arr);
+            iMesh_setArrData(self->mesh,entities,ent_size,tag->handle,data,
+                             data_size,&err);
+        Py_DECREF(ents);
+        Py_XDECREF(data_arr);
-    else /* iBase_BYTES */
+    else if(iBaseEntitySet_Check(obj))
-      /* TODO: I have no idea if this is right */
-      data_arr = PyArray_FROMANY(data_obj,NPY_BYTE,1,1,NPY_C_CONTIGUOUS);
-        return NULL;
+        iBase_EntitySetHandle set = iBaseEntitySet_GetHandle(obj);
-      char *data = PyArray_DATA(data_arr);
-      iMesh_setArrData(self->mesh,entities,ent_size,tag->handle,data,
-                       data_size,&err);
+            PyObject *o = PyNumber_Int(data_obj);
+            if(o == NULL)
+                return NULL;
+            iMesh_setEntSetIntData(self->mesh,set,tag->handle,PyInt_AsLong(o),
+                                   &err);
+            Py_DECREF(o);
+            PyObject *o = PyNumber_Float(data_obj);
+            if(o == NULL)
+                return NULL;
+            iMesh_setEntSetDblData(self->mesh,set,tag->handle,
+                                   PyFloat_AsDouble(o),&err);
+            Py_DECREF(o);
+            if(!iBaseEntity_Check(data_obj))
+                return NULL;
+            iMesh_setEntSetEHData(self->mesh,set,tag->handle,
+                                  iBaseEntity_GetHandle(data_obj),&err);
+            PyObject *data_arr = PyArray_FROMANY(data_obj,NPY_BYTE,1,1,
+                return NULL;
-    Py_DECREF(ents);
-    Py_XDECREF(data_arr);
-  else if(iBaseEntitySet_Check(obj))
-    iBase_EntitySetHandle set = iBaseEntitySet_GetHandle(obj);
-      PyObject *o = PyNumber_Int(data_obj);
-      if(o == NULL)
-	return NULL;
-      iMesh_setEntSetIntData(self->mesh,set,tag->handle,PyInt_AsLong(o),&err);
-      Py_DECREF(o);
+            int data_size = PyArray_SIZE(data_arr);
+            iMesh_setEntSetData(self->mesh,set,tag->handle,data,data_size,
+                                &err);
+            Py_DECREF(data_arr);
-      PyObject *o = PyNumber_Float(data_obj);
-      if(o == NULL)
-        return NULL;
-      iMesh_setEntSetDblData(self->mesh,set,tag->handle,PyFloat_AsDouble(o),
-			     &err);
-      Py_DECREF(o);
-      if(!iBaseEntity_Check(data_obj))
-	return NULL;
-      iMesh_setEntSetEHData(self->mesh,set,tag->handle,
+            if(o == NULL)
+                return NULL;
+            iMesh_setIntData(self->mesh,entity,tag->handle,PyInt_AsLong(o),
+                             &err);
+            Py_DECREF(o);
+            if(o == NULL)
+                return NULL;
+            iMesh_setDblData(self->mesh,entity,tag->handle,
+            Py_DECREF(o);
+                return NULL;
+            iMesh_setEHData(self->mesh,entity,tag->handle,
-      PyObject *data_arr = PyArray_FROMANY(data_obj,NPY_BYTE,1,1,
-					   NPY_C_CONTIGUOUS);
-	return NULL;
+                return NULL;
-      int data_size = PyArray_SIZE(data_arr);
-      iMesh_setEntSetData(self->mesh,set,tag->handle,data,data_size,&err);
-      Py_DECREF(data_arr);
+            iMesh_setData(self->mesh,entity,tag->handle,data,data_size,&err);
+    else
-      if(o == NULL)
-	return NULL;
-      iMesh_setIntData(self->mesh,entity,tag->handle,PyInt_AsLong(o),&err);
-      Py_DECREF(o);
+        PyErr_SetString(PyExc_ValueError,ERR_ANY_ENT);
+        return NULL;
-      if(o == NULL)
-	return NULL;
-      iMesh_setDblData(self->mesh,entity,tag->handle,PyFloat_AsDouble(o),&err);
-      Py_DECREF(o);
-	return NULL;
-      iMesh_setEHData(self->mesh,entity,tag->handle,
-		      iBaseEntity_GetHandle(data_obj),&err);
-	return NULL;
-      iMesh_setData(self->mesh,entity,tag->handle,data,data_size,&err);
-  else
-    PyErr_SetString(PyExc_ValueError,ERR_ANY_ENT);
-    return NULL;
-    return NULL;
-  Py_RETURN_NONE;
+        return NULL;
+    Py_RETURN_NONE;
 static PyObject *
 iMeshObj_getData(iMeshObject *self,PyObject *args)
-  PyObject *obj;
-  char typechar=0;
-  int type;
-  int err;
+    PyObject *obj;
+    char typechar=0;
+    int type;
+    int err;
-  if(!PyArg_ParseTuple(args,"OO!|c",&obj,&iBaseTag_Type,&tag,&typechar))
-    return NULL;
+    if(!PyArg_ParseTuple(args,"OO!|c",&obj,&iBaseTag_Type,&tag,&typechar))
+        return NULL;
-  if(typechar == 0)
-      return NULL;
-  else
-    if(type == -1)
+    if(typechar == 0)
-      PyErr_SetString(PyExc_ValueError,"invalid type code");
-      return NULL;
+            return NULL;
-  if(ents)
-    PyObject *ret = 0;
+    else
-      int *data=0;
-      int alloc=0,size;
-      iMesh_getIntArrData(self->mesh,entities,ent_size,tag->handle,&data,
-			  &alloc,&size,&err);
-      if(!checkError(self->mesh,err))
-	ret = PyArray_NewFromMallocData(1,dims,NPY_INT,data);
+        if(type == -1)
+            PyErr_SetString(PyExc_ValueError,"invalid type code");
+            return NULL;
-      double *data=0;
-      int alloc=0,size;
-      iMesh_getDblArrData(self->mesh,entities,ent_size,tag->handle,&data,
-	ret = PyArray_NewFromMallocData(1,dims,NPY_DOUBLE,data);
+    if(ents)
-      iBase_EntityHandle *data=0;
-      int alloc=0,size;
+        PyObject *ret = 0;
-      iMesh_getEHArrData(self->mesh,entities,ent_size,tag->handle,&data,
-	ret = PyArray_NewFromMallocData(1,dims,NPY_IBASEENT,data);
-      char *data=0;
-      int alloc=0,size;
+            int *data=0;
+            int alloc=0,size;
-      iMesh_getArrData(self->mesh,entities,ent_size,tag->handle,&data,
-	ret = PyArray_NewFromMallocData(1,dims,NPY_BYTE,data);
+            iMesh_getIntArrData(self->mesh,entities,ent_size,tag->handle,&data,
+                                &alloc,&size,&err);
+            if(!checkError(self->mesh,err))
+                ret = PyArray_NewFromMallocData(1,dims,NPY_INT,data);
+            double *data=0;
+            int alloc=0,size;
-    Py_DECREF(ents);
-    return ret;
+            iMesh_getDblArrData(self->mesh,entities,ent_size,tag->handle,&data,
+                ret = PyArray_NewFromMallocData(1,dims,NPY_DOUBLE,data);
+            iBase_EntityHandle *data=0;
+            int alloc=0,size;
-      int data;
-      iMesh_getEntSetIntData(self->mesh,set,tag->handle,&data,&err);
-	return NULL;
-      return Py_BuildValue("i",data);
+            iMesh_getEHArrData(self->mesh,entities,ent_size,tag->handle,&data,
+                ret = PyArray_NewFromMallocData(1,dims,NPY_IBASEENT,data);
+            char *data=0;
+            int alloc=0,size;
+            iMesh_getArrData(self->mesh,entities,ent_size,tag->handle,&data,
+                ret = PyArray_NewFromMallocData(1,dims,NPY_BYTE,data);
+        Py_DECREF(ents);
+        return ret;
-      double data;
-      iMesh_getEntSetDblData(self->mesh,set,tag->handle,&data,&err);
-        return NULL;
-      return Py_BuildValue("d",data);
+            int data;
+            iMesh_getEntSetIntData(self->mesh,set,tag->handle,&data,&err);
+                return NULL;
+            return Py_BuildValue("i",data);
+            double data;
+            iMesh_getEntSetDblData(self->mesh,set,tag->handle,&data,&err);
+                return NULL;
+            return Py_BuildValue("d",data);
+            iBaseEntity_Object *data = iBaseEntity_New();
+            iMesh_getEntSetEHData(self->mesh,set,tag->handle,&data->handle,
+                                  &err);
+                Py_DECREF(data);
+                return NULL;
+            return (PyObject*)data;
+            char *data=0;
+            int alloc=0,size;
+            iMesh_getEntSetData(self->mesh,set,tag->handle,&data,&alloc,&size,
+                                &err);
+                return NULL;
+            return PyArray_NewFromMallocData(1,dims,NPY_BYTE,data);
-      iBaseEntity_Object *data = iBaseEntity_New();
-      iMesh_getEntSetEHData(self->mesh,set,tag->handle,&data->handle,&err);
-	Py_DECREF(data);
-	return NULL;
-      return (PyObject*)data;
-      char *data=0;
-      int alloc=0,size;
-      iMesh_getEntSetData(self->mesh,set,tag->handle,&data,&alloc,&size,&err);
-        return NULL;
-      return PyArray_NewFromMallocData(1,dims,NPY_BYTE,data);
-      int data;
-      iMesh_getIntData(self->mesh,entity,tag->handle,&data,&err);
-        return NULL;
+            int data;
+            iMesh_getIntData(self->mesh,entity,tag->handle,&data,&err);
+                return NULL;
+            double data;
+            iMesh_getDblData(self->mesh,entity,tag->handle,&data,&err);
+                return NULL;
+            iMesh_getEHData(self->mesh,entity,tag->handle,&data->handle,&err);
+                Py_DECREF(data);
+                return NULL;
+            char *data=0;
+            int alloc=0,size;
+            iMesh_getData(self->mesh,entity,tag->handle,&data,&alloc,&size,
+                          &err);
+                return NULL;
+    else
-      double data;
-      iMesh_getDblData(self->mesh,entity,tag->handle,&data,&err);
         return NULL;
-      iMesh_getEHData(self->mesh,entity,tag->handle,&data->handle,&err);
-	Py_DECREF(data);
-	return NULL;
-      char *data=0;
-      int alloc=0,size;
-      iMesh_getData(self->mesh,entity,tag->handle,&data,&alloc,&size,&err);
-	return NULL;
-  else
-    return NULL;
 static PyObject *
 iMeshObj_getAllTags(iMeshObject *self,PyObject *args)
-  PyObject *ents;
-  iBase_TagHandle *tags=0;
-  int alloc=0,size;
-  int err;
+    PyObject *ents;
+    iBase_TagHandle *tags=0;
+    int alloc=0,size;
+    int err;
-  if(!PyArg_ParseTuple(args,"O",&ents))
-    return NULL;
+    if(!PyArg_ParseTuple(args,"O",&ents))
+        return NULL;
-  if(iBaseEntitySet_Check(ents))
-    iBase_EntitySetHandle set = iBaseEntitySet_GetHandle(ents);
+    if(iBaseEntitySet_Check(ents))
+        iBase_EntitySetHandle set = iBaseEntitySet_GetHandle(ents);
-    iMesh_getAllEntSetTags(self->mesh,set,&tags,&alloc,&size,&err);
-      return NULL;
-  else if(iBaseEntity_Check(ents))
-    iBase_EntityHandle entity = iBaseEntity_GetHandle(ents);
+        iMesh_getAllEntSetTags(self->mesh,set,&tags,&alloc,&size,&err);
+            return NULL;
+    else if(iBaseEntity_Check(ents))
+        iBase_EntityHandle entity = iBaseEntity_GetHandle(ents);
-    iMesh_getAllTags(self->mesh,entity,&tags,&alloc,&size,&err);
-      return NULL;
-  else
-    PyErr_SetString(PyExc_ValueError,ERR_ENT_OR_ENTSET);
-    return NULL;
+        iMesh_getAllTags(self->mesh,entity,&tags,&alloc,&size,&err);
+            return NULL;
+    else
+        PyErr_SetString(PyExc_ValueError,ERR_ENT_OR_ENTSET);
+        return NULL;
-  PyObject *arr = PyArray_NewFromMallocData(1,dims,NPY_IMESHTAG,tags);
-  Py_INCREF(self);
-  PyArray_BASE(arr) = (PyObject*)self;
-  return arr;
+    PyObject *arr = PyArray_NewFromMallocData(1,dims,NPY_IMESHTAG,tags);
+    Py_INCREF(self);
+    PyArray_BASE(arr) = (PyObject*)self;
+    return arr;
 static PyObject *
 iMeshObj_rmvTag(iMeshObject *self,PyObject *args)
-  PyObject *obj;
-  int err;
+    PyObject *obj;
+    int err;
-  if(!PyArg_ParseTuple(args,"OO!",&obj,&iBaseTag_Type,&tag))
-    return NULL;
+    if(!PyArg_ParseTuple(args,"OO!",&obj,&iBaseTag_Type,&tag))
+        return NULL;
-  if(ents)
-    iMesh_rmvArrTag(self->mesh,entities,ent_size,tag->handle,&err);
-    Py_DECREF(ents);
-    iMesh_rmvEntSetTag(self->mesh,set,tag->handle,&err);
-    iBase_EntityHandle entity =iBaseEntity_GetHandle(obj);
-    iMesh_rmvTag(self->mesh,entity,tag->handle,&err);
-  else
-    return NULL;
+    if(ents)
+        iMesh_rmvArrTag(self->mesh,entities,ent_size,tag->handle,&err);
+        Py_DECREF(ents);
+        iMesh_rmvEntSetTag(self->mesh,set,tag->handle,&err);
+        iBase_EntityHandle entity =iBaseEntity_GetHandle(obj);
+        iMesh_rmvTag(self->mesh,entity,tag->handle,&err);
+    else
+        return NULL;
-    return NULL;
-  Py_RETURN_NONE;
+        return NULL;
+    Py_RETURN_NONE;
 static PyMethodDef iMesh_methods[] = {
-  { "load", (PyCFunction)iMeshObj_load, METH_VARARGS,
-    "Load a mesh"
-  { "save", (PyCFunction)iMeshObj_save, METH_VARARGS,
-    "Save the mesh"
-  { "getNumOfType", (PyCFunction)iMeshObj_getNumOfType, METH_VARARGS,
-    "Get the number of entities with the specified type in the instance or set"
-  { "getNumOfTopo", (PyCFunction)iMeshObj_getNumOfTopo, METH_VARARGS,
-    "Get the number of entities with the specified topology in the instance "
-    "or set"
-  { "areEHValid", (PyCFunction)iMeshObj_areEHValid, METH_VARARGS,
-    "Return whether entity handles have changed since last reset or since "
-    "instance construction"
-  { "getEntities", (PyCFunction)iMeshObj_getEntities, METH_VARARGS,
-    "Get entities of specific type and/or topology in set or instance"
-  { "getVtxCoords", (PyCFunction)iMeshObj_getVtxCoords, METH_VARARGS,
-    "Get coordinates of specified vertex(ices)"
-  { "getEntTopo", (PyCFunction)iMeshObj_getEntTopo, METH_VARARGS,
-    "Get the entity topology(ies) for the specified entity(ies)"
-  { "getEntType", (PyCFunction)iMeshObj_getEntType, METH_VARARGS,
-    "Get the entity type(s) for the specified entity(ies)"
-  { "getEntAdj", (PyCFunction)iMeshObj_getEntAdj, METH_VARARGS,
-    "Get entities of specified type adjacent to entity(ies)"
-  { "getEnt2ndAdj", (PyCFunction)iMeshObj_getEnt2ndAdj, METH_VARARGS,
-    "Get \"2nd order\" adjacencies to entity(ies)"
-  { "getAdjEntIndices", (PyCFunction)iMeshObj_getAdjEntIndices, METH_VARARGS,
-    "Get indexed representation of mesh or subset of mesh"
-  { "createEntSet", (PyCFunction)iMeshObj_createEntSet, METH_VARARGS,
-    "Create an entity set"
-  { "destroyEntSet", (PyCFunction)iMeshObj_destroyEntSet, METH_VARARGS,
-    "Destroy an entity set"
-  { "setVtxCoords", (PyCFunction)iMeshObj_setVtxCoords, METH_VARARGS,
-    "Set coordinates for a vertex or array of vertices"
-  { "createVtx", (PyCFunction)iMeshObj_createVtx, METH_VARARGS,
-    "Create a new vertex or array of vertices at specified coordinates"
-  { "createEnt", (PyCFunction)iMeshObj_createEnt, METH_VARARGS,
-    "Create a new entity with specified lower-order topology"
-  { "createEntArr", (PyCFunction)iMeshObj_createEntArr, METH_VARARGS,
-    "Create an array of entities with specified lower-order topology"
-  { "deleteEnt", (PyCFunction)iMeshObj_deleteEnt, METH_VARARGS,
-    "Delete specified entity(ies)"
-  { "createTag", (PyCFunction)iMeshObj_createTag, METH_VARARGS,
-    "Create a tag with specified name, size, and type"
-  { "destroyTag", (PyCFunction)iMeshObj_destroyTag, METH_VARARGS,
-    "Destroy a tag"
-  { "getTagHandle", (PyCFunction)iMeshObj_getTagHandle, METH_VARARGS,
-    "Get the handle of an existing tag with the specified name"
-  { "setData", (PyCFunction)iMeshObj_setData, METH_VARARGS,
-    "Set tag values on an entity (or array/set of entities)"
-  { "getData", (PyCFunction)iMeshObj_getData, METH_VARARGS,
-    "Get tag values on an entity (or array/set of entities)"
-  { "getAllTags", (PyCFunction)iMeshObj_getAllTags, METH_VARARGS,
-    "Get all the tags associated with a specified entity handle (or "
-    "array/set of entities)"
-  { "rmvTag", (PyCFunction)iMeshObj_rmvTag, METH_VARARGS,
-    "Remove a tag value from an entity (or array/set of entities)"
+    { "load", (PyCFunction)iMeshObj_load, METH_VARARGS,
+      "Load a mesh"
+    { "save", (PyCFunction)iMeshObj_save, METH_VARARGS,
+      "Save the mesh"
+    { "getNumOfType", (PyCFunction)iMeshObj_getNumOfType, METH_VARARGS,
+      "Get the number of entities with the specified type in the instance or "
+      "set"
+    { "getNumOfTopo", (PyCFunction)iMeshObj_getNumOfTopo, METH_VARARGS,
+      "Get the number of entities with the specified topology in the instance "
+      "or set"
+    { "areEHValid", (PyCFunction)iMeshObj_areEHValid, METH_VARARGS,
+      "Return whether entity handles have changed since last reset or since "
+      "instance construction"
+    { "getEntities", (PyCFunction)iMeshObj_getEntities, METH_VARARGS,
+      "Get entities of specific type and/or topology in set or instance"
+    { "getVtxCoords", (PyCFunction)iMeshObj_getVtxCoords, METH_VARARGS,
+      "Get coordinates of specified vertex(ices)"
+    { "getEntTopo", (PyCFunction)iMeshObj_getEntTopo, METH_VARARGS,
+      "Get the entity topology(ies) for the specified entity(ies)"
+    { "getEntType", (PyCFunction)iMeshObj_getEntType, METH_VARARGS,
+      "Get the entity type(s) for the specified entity(ies)"
+    { "getEntAdj", (PyCFunction)iMeshObj_getEntAdj, METH_VARARGS,
+      "Get entities of specified type adjacent to entity(ies)"
+    { "getEnt2ndAdj", (PyCFunction)iMeshObj_getEnt2ndAdj, METH_VARARGS,
+      "Get \"2nd order\" adjacencies to entity(ies)"
+    { "getAdjEntIndices", (PyCFunction)iMeshObj_getAdjEntIndices, METH_VARARGS,
+      "Get indexed representation of mesh or subset of mesh"
+    { "createEntSet", (PyCFunction)iMeshObj_createEntSet, METH_VARARGS,
+      "Create an entity set"
+    { "destroyEntSet", (PyCFunction)iMeshObj_destroyEntSet, METH_VARARGS,
+      "Destroy an entity set"
+    { "setVtxCoords", (PyCFunction)iMeshObj_setVtxCoords, METH_VARARGS,
+      "Set coordinates for a vertex or array of vertices"
+    { "createVtx", (PyCFunction)iMeshObj_createVtx, METH_VARARGS,
+      "Create a new vertex or array of vertices at specified coordinates"
+    { "createEnt", (PyCFunction)iMeshObj_createEnt, METH_VARARGS,
+      "Create a new entity with specified lower-order topology"
+    { "createEntArr", (PyCFunction)iMeshObj_createEntArr, METH_VARARGS,
+      "Create an array of entities with specified lower-order topology"
+    { "deleteEnt", (PyCFunction)iMeshObj_deleteEnt, METH_VARARGS,
+      "Delete specified entity(ies)"
+    { "createTag", (PyCFunction)iMeshObj_createTag, METH_VARARGS,
+      "Create a tag with specified name, size, and type"
+    { "destroyTag", (PyCFunction)iMeshObj_destroyTag, METH_VARARGS,
+      "Destroy a tag"
+    { "getTagHandle", (PyCFunction)iMeshObj_getTagHandle, METH_VARARGS,
+      "Get the handle of an existing tag with the specified name"
+    { "setData", (PyCFunction)iMeshObj_setData, METH_VARARGS,
+      "Set tag values on an entity (or array/set of entities)"
+    { "getData", (PyCFunction)iMeshObj_getData, METH_VARARGS,
+      "Get tag values on an entity (or array/set of entities)"
+    { "getAllTags", (PyCFunction)iMeshObj_getAllTags, METH_VARARGS,
+      "Get all the tags associated with a specified entity handle (or "
+      "array/set of entities)"
+    { "rmvTag", (PyCFunction)iMeshObj_rmvTag, METH_VARARGS,
+      "Remove a tag value from an entity (or array/set of entities)"
   {0}
 static PyGetSetDef iMesh_getset[] = {
-  { "rootSet", (getter)iMeshObj_getRootSet, 0, "root set", 0 },
-  { "geometricDimension", (getter)iMeshObj_getGeometricDimension,
-    (setter)iMeshObj_setGeometricDimension, "geometric dimension", 0 },
-  { "dfltStorage",(getter)iMeshObj_getDfltStorage, 0, "default storage order",
-    0 },
-  { "adjTable",(getter)iMeshObj_getAdjTable, 0, "get adjacency table", 0},
-  {0}
+    { "rootSet", (getter)iMeshObj_getRootSet, 0,
+      "root set", 0
+    { "geometricDimension", (getter)iMeshObj_getGeometricDimension,
+      (setter)iMeshObj_setGeometricDimension,
+      "geometric dimension", 0
+    { "dfltStorage",(getter)iMeshObj_getDfltStorage, 0,
+      "default storage order", 0
+    { "adjTable",(getter)iMeshObj_getAdjTable, 0,
+      "get adjacency table", 0
+    {0}
 static PyTypeObject iMeshType = {
-  PyObject_HEAD_INIT(NULL)
-  0,                            /* ob_size */
-  "itaps.iMesh",                /* tp_name */
-  sizeof(iMeshObject),          /* tp_basicsize */
-  0,                            /* tp_itemsize */
-  (destructor)iMeshObj_dealloc, /* tp_dealloc */
-  0,                            /* tp_print */
-  0,                            /* tp_getattr */
-  0,                            /* tp_setattr */
-  0,                            /* tp_compare */
-  0,                            /* tp_repr */
-  0,                            /* tp_as_number */
-  0,                            /* tp_as_sequence */
-  0,                            /* tp_as_mapping */
-  0,                            /* tp_hash */
-  0,                            /* tp_call */
-  0,                            /* tp_str */
-  0,                            /* tp_getattro */
-  0,                            /* tp_setattro */
-  0,                            /* tp_as_buffer */
-  Py_TPFLAGS_DEFAULT |
-  Py_TPFLAGS_BASETYPE,          /* tp_flags */
-  "iMesh objects",              /* tp_doc */
-  0,                            /* tp_traverse */
-  0,                            /* tp_clear */
-  0,                            /* tp_richcompare */
-  0,                            /* tp_weaklistoffset */
-  0,                            /* tp_iter */
-  0,                            /* tp_iternext */
-  iMesh_methods,                /* tp_methods */
-  0,                            /* tp_members */
-  iMesh_getset,                 /* tp_getset */
-  0,                            /* tp_base */
-  0,                            /* tp_dict */
-  0,                            /* tp_descr_get */
-  0,                            /* tp_descr_set */
-  0,                            /* tp_dictoffset */
-  (initproc)iMeshObj_init,      /* tp_init */
-  0,                            /* tp_alloc */
-  0,                            /* tp_new */
+    PyObject_HEAD_INIT(NULL)
+    0,                            /* ob_size */
+    "itaps.iMesh",                /* tp_name */
+    sizeof(iMeshObject),          /* tp_basicsize */
+    0,                            /* tp_itemsize */
+    (destructor)iMeshObj_dealloc, /* tp_dealloc */
+    0,                            /* tp_print */
+    0,                            /* tp_getattr */
+    0,                            /* tp_setattr */
+    0,                            /* tp_compare */
+    0,                            /* tp_repr */
+    0,                            /* tp_as_number */
+    0,                            /* tp_as_sequence */
+    0,                            /* tp_as_mapping */
+    0,                            /* tp_hash */
+    0,                            /* tp_call */
+    0,                            /* tp_str */
+    0,                            /* tp_getattro */
+    0,                            /* tp_setattro */
+    0,                            /* tp_as_buffer */
+    Py_TPFLAGS_DEFAULT |
+    Py_TPFLAGS_BASETYPE,          /* tp_flags */
+    "iMesh objects",              /* tp_doc */
+    0,                            /* tp_traverse */
+    0,                            /* tp_clear */
+    0,                            /* tp_richcompare */
+    0,                            /* tp_weaklistoffset */
+    0,                            /* tp_iter */
+    0,                            /* tp_iternext */
+    iMesh_methods,                /* tp_methods */
+    0,                            /* tp_members */
+    iMesh_getset,                 /* tp_getset */
+    0,                            /* tp_base */
+    0,                            /* tp_dict */
+    0,                            /* tp_descr_get */
+    0,                            /* tp_descr_set */
+    0,                            /* tp_dictoffset */
+    (initproc)iMeshObj_init,      /* tp_init */
+    0,                            /* tp_alloc */
+    0,                            /* tp_new */
 static PyMethodDef module_methods[] = {
-  {0}
+    {0}
 static PyObject *
 iMeshEntSetArr_getitem(void *data,void *arr)
-  iMeshObject *mesh = (iMeshObject*)PyArray_BASE(arr);
-  iMeshEntitySet_Object *o = iMeshEntitySet_New();
+    iMeshObject *mesh = (iMeshObject*)PyArray_BASE(arr);
+    iMeshEntitySet_Object *o = iMeshEntitySet_New();
-  o->set.handle = *(iBase_EntitySetHandle*)data;
-  o->mesh = mesh; /* TODO: incref? */
+    o->set.handle = *(iBase_EntitySetHandle*)data;
+    o->mesh = mesh; /* TODO: incref? */
-  return (PyObject*)o;
+    return (PyObject*)o;
 static PyObject *
 iMeshTagArr_getitem(void *data,void *arr)
-  iMeshTag_Object *o = iMeshTag_New();
+    iMeshTag_Object *o = iMeshTag_New();
-  o->tag.handle = *(iBase_TagHandle*)data;
+    o->tag.handle = *(iBase_TagHandle*)data;
 static PyArray_ArrFuncs iMeshEntSetArr_Funcs;
@@ -1551,73 +1571,73 @@
 PyMODINIT_FUNC initiMesh(void)
-  PyObject *m;
-  PyArray_Descr *descr;
+    PyObject *m;
+    PyArray_Descr *descr;
-  m = Py_InitModule("iMesh",module_methods);
-  import_array();
-  import_iBase();
+    m = Py_InitModule("iMesh",module_methods);
+    import_array();
+    import_iBase();
-  iMeshType.tp_new = PyType_GenericNew;
-  if(PyType_Ready(&iMeshType) < 0)
-    return;
-  Py_INCREF(&iMeshType);
-  PyModule_AddObject(m,"iMesh",(PyObject *)&iMeshType);
+    iMeshType.tp_new = PyType_GenericNew;
+    if(PyType_Ready(&iMeshType) < 0)
+        return;
+    Py_INCREF(&iMeshType);
+    PyModule_AddObject(m,"iMesh",(PyObject *)&iMeshType);
-  /***** initialize topology enum *****/
-  REGISTER_SIMPLE_SUB(iMeshType,topology);
+    /***** initialize topology enum *****/
+    REGISTER_SIMPLE_SUB(iMeshType,topology);
-  ADD_ENUM(&topology_Type,"point",          iMesh_POINT);
-  ADD_ENUM(&topology_Type,"line_segment",   iMesh_LINE_SEGMENT);
-  ADD_ENUM(&topology_Type,"polygon",        iMesh_POLYGON);
-  ADD_ENUM(&topology_Type,"triangle",       iMesh_TRIANGLE);
-  ADD_ENUM(&topology_Type,"quadrilateral",  iMesh_QUADRILATERAL);
-  ADD_ENUM(&topology_Type,"polyhedron",     iMesh_POLYHEDRON);
-  ADD_ENUM(&topology_Type,"tetrahedron",    iMesh_TETRAHEDRON);
-  ADD_ENUM(&topology_Type,"hexahedron",     iMesh_HEXAHEDRON);
-  ADD_ENUM(&topology_Type,"prism",          iMesh_PRISM);
-  ADD_ENUM(&topology_Type,"pyramid",        iMesh_PYRAMID);
-  ADD_ENUM(&topology_Type,"septahedron",    iMesh_SEPTAHEDRON);
-  ADD_ENUM(&topology_Type,"all",            iMesh_ALL_TOPOLOGIES);
+    ADD_ENUM(&topology_Type,"point",         iMesh_POINT);
+    ADD_ENUM(&topology_Type,"line_segment",  iMesh_LINE_SEGMENT);
+    ADD_ENUM(&topology_Type,"polygon",       iMesh_POLYGON);
+    ADD_ENUM(&topology_Type,"triangle",      iMesh_TRIANGLE);
+    ADD_ENUM(&topology_Type,"quadrilateral", iMesh_QUADRILATERAL);
+    ADD_ENUM(&topology_Type,"polyhedron",    iMesh_POLYHEDRON);
+    ADD_ENUM(&topology_Type,"tetrahedron",   iMesh_TETRAHEDRON);
+    ADD_ENUM(&topology_Type,"hexahedron",    iMesh_HEXAHEDRON);
+    ADD_ENUM(&topology_Type,"prism",         iMesh_PRISM);
+    ADD_ENUM(&topology_Type,"pyramid",       iMesh_PYRAMID);
+    ADD_ENUM(&topology_Type,"septahedron",   iMesh_SEPTAHEDRON);
+    ADD_ENUM(&topology_Type,"all",           iMesh_ALL_TOPOLOGIES);
-  iMeshIter_Type.tp_new = PyType_GenericNew;
-  if(PyType_Ready(&iMeshIter_Type) < 0)
-    return;
-  PyDict_SetItemString(iMeshType.tp_dict,"iterator",
-                       (PyObject *)&iMeshIter_Type);
+    iMeshIter_Type.tp_new = PyType_GenericNew;
+    if(PyType_Ready(&iMeshIter_Type) < 0)
+        return;
+    PyDict_SetItemString(iMeshType.tp_dict,"iterator",
+                         (PyObject *)&iMeshIter_Type);
-  iMeshEntitySet_Type.tp_base = &iBaseEntitySet_Type;
-  if(PyType_Ready(&iMeshEntitySet_Type) < 0)
-    return;
-  PyDict_SetItemString(iMeshType.tp_dict,"entitySet",
-		       (PyObject *)&iMeshEntitySet_Type);
+    iMeshEntitySet_Type.tp_base = &iBaseEntitySet_Type;
+    if(PyType_Ready(&iMeshEntitySet_Type) < 0)
+        return;
+    PyDict_SetItemString(iMeshType.tp_dict,"entitySet",
+                         (PyObject *)&iMeshEntitySet_Type);
-  iMeshTag_Type.tp_base = &iBaseTag_Type;
-  if(PyType_Ready(&iMeshTag_Type) < 0)
-    return;
-  PyDict_SetItemString(iMeshType.tp_dict,"tag",
-		       (PyObject *)&iMeshTag_Type);
+    iMeshTag_Type.tp_base = &iBaseTag_Type;
+    if(PyType_Ready(&iMeshTag_Type) < 0)
+        return;
+    PyDict_SetItemString(iMeshType.tp_dict,"tag",
+                         (PyObject *)&iMeshTag_Type);
-  /***** initialize iMeshEntitySet array *****/
-  descr = PyArray_DescrNewFromType(NPY_IBASEENTSET);
-  memcpy(&iMeshEntSetArr_Funcs,descr->f,sizeof(PyArray_ArrFuncs));
-  descr->f = &iMeshEntSetArr_Funcs;
+    /***** initialize iMeshEntitySet array *****/
+    descr = PyArray_DescrNewFromType(NPY_IBASEENTSET);
+    memcpy(&iMeshEntSetArr_Funcs,descr->f,sizeof(PyArray_ArrFuncs));
+    descr->f = &iMeshEntSetArr_Funcs;
-  descr->typeobj = &iMeshEntitySet_Type;
-  descr->type = 'M';
-  descr->f->getitem = iMeshEntSetArr_getitem;
+    descr->typeobj = &iMeshEntitySet_Type;
+    descr->type = 'M';
+    descr->f->getitem = iMeshEntSetArr_getitem;
-  NPY_IMESHENTSET = PyArray_RegisterDataType(descr);
+    NPY_IMESHENTSET = PyArray_RegisterDataType(descr);
-  /***** initialize iMeshTag array *****/
-  descr = PyArray_DescrNewFromType(NPY_IBASETAG);
-  memcpy(&iMeshTagArr_Funcs,descr->f,sizeof(PyArray_ArrFuncs));
-  descr->f = &iMeshTagArr_Funcs;
+    /***** initialize iMeshTag array *****/
+    descr = PyArray_DescrNewFromType(NPY_IBASETAG);
+    memcpy(&iMeshTagArr_Funcs,descr->f,sizeof(PyArray_ArrFuncs));
+    descr->f = &iMeshTagArr_Funcs;
-  descr->typeobj = &iMeshTag_Type;
-  descr->f->getitem = iMeshTagArr_getitem;
+    descr->typeobj = &iMeshTag_Type;
+    descr->f->getitem = iMeshTagArr_getitem;
-  NPY_IMESHTAG = PyArray_RegisterDataType(descr);
+    NPY_IMESHTAG = PyArray_RegisterDataType(descr);
Modified: MOAB/trunk/tools/iMesh/python/iMesh_Python.h
--- MOAB/trunk/tools/iMesh/python/iMesh_Python.h	2009-05-09 16:36:05 UTC (rev 2881)
+++ MOAB/trunk/tools/iMesh/python/iMesh_Python.h	2009-05-11 19:46:19 UTC (rev 2882)
@@ -12,8 +12,8 @@
 #include <numpy/arrayobject.h>
 #define PyArray_NewFromMallocData(nd, dims, typenum, data)      \
-  PyArray_New(&PyArray_Type, nd, dims, typenum, NULL,           \
-              data, 0, NPY_CARRAY|NPY_OWNDATA, NULL)
+    PyArray_New(&PyArray_Type, nd, dims, typenum, NULL,         \
+                data, 0, NPY_CARRAY|NPY_OWNDATA, NULL)
 PyObject *
 PyArray_TryFromObject(PyObject *obj,int typenum,int min_depth,int max_depth);
@@ -25,59 +25,59 @@
 typedef struct
-  PyObject_HEAD
-  iMesh_Instance mesh;
+    PyObject_HEAD
+    iMesh_Instance mesh;
 } iMeshObject;
 typedef struct
-  PyObject_HEAD
-  int is_arr;
-  union
-    iMesh_EntityIterator    iter;
-    iMesh_EntityArrIterator arr_iter;
+    PyObject_HEAD
+    int is_arr;
+    union
+        iMesh_EntityIterator    iter;
+        iMesh_EntityArrIterator arr_iter;
 } iMeshIter_Object;
 extern PyTypeObject iMeshIter_Type;
 typedef struct
-  iBaseEntitySet_Object set;
-  iMeshObject *mesh;
+    iBaseEntitySet_Object set;
+    iMeshObject *mesh;
 } iMeshEntitySet_Object;
 extern PyTypeObject iMeshEntitySet_Type;
 extern int NPY_IMESHENTSET;
-#define iMeshEntitySet_New()                    \
-  (iMeshEntitySet_Object*)PyObject_CallObject(  \
-    (PyObject*)&iMeshEntitySet_Type,NULL)
+#define iMeshEntitySet_New()                            \
+    (iMeshEntitySet_Object*)PyObject_CallObject(        \
+        (PyObject*)&iMeshEntitySet_Type,NULL)
-#define iMeshEntitySet_Check(o)                 \
-  PyObject_TypeCheck((o),&iMeshEntitySet_Type)
+#define iMeshEntitySet_Check(o)                         \
+    PyObject_TypeCheck((o),&iMeshEntitySet_Type)
-#define iMeshEntitySet_GetMesh(o)               \
-  ((iMeshEntitySet_Object*)(o))->mesh
+#define iMeshEntitySet_GetMesh(o)                       \
+    ((iMeshEntitySet_Object*)(o))->mesh
 typedef struct
-  iBaseTag_Object tag;
+    iBaseTag_Object tag;
 } iMeshTag_Object;
 extern PyTypeObject iMeshTag_Type;
 extern int NPY_IMESHTAG;
-#define iMeshTag_New()				\
-  (iMeshTag_Object*)PyObject_CallObject(	\
-    (PyObject*)&iMeshTag_Type,NULL)
+#define iMeshTag_New()                                  \
+    (iMeshTag_Object*)PyObject_CallObject(              \
+        (PyObject*)&iMeshTag_Type,NULL)
-#define iMeshTag_Check(o)			\
-  PyObject_TypeCheck((o),&iMeshTag_Type)
+#define iMeshTag_Check(o)                               \
+    PyObject_TypeCheck((o),&iMeshTag_Type)
-#define iMeshTag_GetMesh(o)			\
-  ((iMeshTag_Object*)(o))->mesh
+#define iMeshTag_GetMesh(o)                             \
+    ((iMeshTag_Object*)(o))->mesh
Modified: MOAB/trunk/tools/iMesh/python/iMesh_entSet.c
--- MOAB/trunk/tools/iMesh/python/iMesh_entSet.c	2009-05-09 16:36:05 UTC (rev 2881)
+++ MOAB/trunk/tools/iMesh/python/iMesh_entSet.c	2009-05-11 19:46:19 UTC (rev 2882)
@@ -8,179 +8,181 @@
 static PyObject *
 iMeshEntSetObj_isList(iMeshEntitySet_Object *self,void *closure)
-  int is_list,err;
-  iMesh_isList(self->mesh->mesh,self->set.handle,&is_list,&err);
-  if(checkError(self->mesh->mesh,err))
-    return NULL;
+    int is_list,err;
+    iMesh_isList(self->mesh->mesh,self->set.handle,&is_list,&err);
+    if(checkError(self->mesh->mesh,err))
+        return NULL;
-  return PyBool_FromLong(is_list);
+    return PyBool_FromLong(is_list);
 static PyObject *
 iMeshEntSetObj_getNumEntSets(iMeshEntitySet_Object *self,PyObject *args)
-  int num_hops,num_sets,err;
+    int num_hops,num_sets,err;
-  if(!PyArg_ParseTuple(args,"i",&num_hops))
-    return NULL;
+    if(!PyArg_ParseTuple(args,"i",&num_hops))
+        return NULL;
-  iMesh_getNumEntSets(self->mesh->mesh,self->set.handle,num_hops,&num_sets,
-		      &err);
-    return NULL;
+    iMesh_getNumEntSets(self->mesh->mesh,self->set.handle,num_hops,&num_sets,
+                        &err);
+        return NULL;
-  return Py_BuildValue("i",num_sets);
+    return Py_BuildValue("i",num_sets);
 static PyObject *
 iMeshEntSetObj_getEntSets(iMeshEntitySet_Object *self,PyObject *args)
-  int num_hops,sets_alloc=0,sets_size,err;
-  iBase_EntitySetHandle *sets;
+    int num_hops,sets_alloc=0,sets_size,err;
+    iBase_EntitySetHandle *sets;
-    return NULL;
+        return NULL;
-  iMesh_getEntSets(self->mesh->mesh,self->set.handle,num_hops,&sets,
-		   &sets_alloc,&sets_size,&err);
-    return NULL;
+    iMesh_getEntSets(self->mesh->mesh,self->set.handle,num_hops,&sets,
+                     &sets_alloc,&sets_size,&err);
+        return NULL;
-  npy_intp dims[] = {sets_size};
-  return PyArray_NewFromMallocData(1,dims,NPY_IBASEENTSET,sets);
+    npy_intp dims[] = {sets_size};
+    return PyArray_NewFromMallocData(1,dims,NPY_IBASEENTSET,sets);
 static PyObject *
 iMeshEntSetObj_add(iMeshEntitySet_Object *self,PyObject *args)
-  int err;
-  PyObject *obj;
+    int err;
+    PyObject *obj;
-    return NULL;
+        return NULL;
-  if(ents)
-    iMesh_addEntArrToSet(self->mesh->mesh,data,size,self->set.handle,&err);
-    Py_DECREF(ents);
-    iBaseEntitySet_Object *set = (iBaseEntitySet_Object*)obj;
-    iMesh_addEntSet(self->mesh->mesh,set->handle,self->set.handle,&err);
-    iBaseEntity_Object *ent = (iBaseEntity_Object*)obj;
-    iMesh_addEntToSet(self->mesh->mesh,ent->handle,self->set.handle,&err);
-  else
-    return NULL;
+    if(ents)
+        iMesh_addEntArrToSet(self->mesh->mesh,data,size,self->set.handle,&err);
+        Py_DECREF(ents);
+        iBaseEntitySet_Object *set = (iBaseEntitySet_Object*)obj;
+        iMesh_addEntSet(self->mesh->mesh,set->handle,self->set.handle,&err);
+        iBaseEntity_Object *ent = (iBaseEntity_Object*)obj;
+        iMesh_addEntToSet(self->mesh->mesh,ent->handle,self->set.handle,&err);
+    else
+        return NULL;
-    return NULL;
-  Py_RETURN_NONE;
+        return NULL;
+    Py_RETURN_NONE;
 static PyObject *
 iMeshEntSetObj_remove(iMeshEntitySet_Object *self,PyObject *args)
-  int err;
-  PyObject *obj;
+    int err;
+    PyObject *obj;
-    return NULL;
+        return NULL;
-  if(ents)
-    iMesh_rmvEntArrFromSet(self->mesh->mesh,data,size,self->set.handle,&err);
-    Py_DECREF(ents);
-    iMesh_rmvEntSet(self->mesh->mesh,set->handle,self->set.handle,&err);
-    iMesh_rmvEntFromSet(self->mesh->mesh,ent->handle,self->set.handle,&err);
-  else
-    return NULL;
+    if(ents)
+        iMesh_rmvEntArrFromSet(self->mesh->mesh,data,size,self->set.handle,
+                               &err);
+        Py_DECREF(ents);
+        iMesh_rmvEntSet(self->mesh->mesh,set->handle,self->set.handle,&err);
+        iMesh_rmvEntFromSet(self->mesh->mesh,ent->handle,self->set.handle,
+                            &err);
+    else
+        return NULL;
-    return NULL;
-  Py_RETURN_NONE;
+        return NULL;
+    Py_RETURN_NONE;
 static PyObject *
 iMeshEntSetObj_contains(iMeshEntitySet_Object *self,PyObject *args)
-  int err;
-  PyObject *obj;
+    int err;
+    PyObject *obj;
-    return NULL;
+        return NULL;
-  if(ents)
-    int *contains=0;
-    int contains_alloc=0,contains_size;
+    if(ents)
+        int *contains=0;
+        int contains_alloc=0,contains_size;
-    iMesh_isEntArrContained(self->mesh->mesh,self->set.handle,data,size,
-			    &contains,&contains_alloc,&contains_size,&err);
-    Py_DECREF(ents);
-      return NULL;
+        iMesh_isEntArrContained(self->mesh->mesh,self->set.handle,data,size,
+                                &contains,&contains_alloc,&contains_size,&err);
+        Py_DECREF(ents);
+            return NULL;
-    npy_intp dims[] = {contains_size};
-    npy_intp strides[] = {sizeof(int)/sizeof(npy_bool)};
-    return PyArray_New(&PyArray_Type,1,dims,NPY_BOOL,strides,contains,
-		       0,NPY_CARRAY|NPY_OWNDATA,NULL); /* TODO: careful! */
-    int contains;
-    iMesh_isEntSetContained(self->mesh->mesh,self->set.handle,set->handle,
-			    &contains,&err);
-      return NULL;
+        npy_intp dims[] = {contains_size};
+        npy_intp strides[] = {sizeof(int)/sizeof(npy_bool)};
+        return PyArray_New(&PyArray_Type,1,dims,NPY_BOOL,strides,contains,
+                           0,NPY_CARRAY|NPY_OWNDATA,NULL); /* TODO: careful! */
+        int contains;
+        iMesh_isEntSetContained(self->mesh->mesh,self->set.handle,set->handle,
+                                &contains,&err);
+            return NULL;
-    return PyBool_FromLong(contains);
-    int contains;
-    iMesh_isEntContained(self->mesh->mesh,self->set.handle,ent->handle,
-			 &contains,&err);
-      return NULL;
+        return PyBool_FromLong(contains);
+        int contains;
+        iMesh_isEntContained(self->mesh->mesh,self->set.handle,ent->handle,
+                             &contains,&err);
+            return NULL;
-  else
-    return NULL;
+    else
+        return NULL;
 /* TODO: add/removeParent? */
@@ -188,364 +190,365 @@
 static PyObject *
 iMeshEntSetObj_addChild(iMeshEntitySet_Object *self,PyObject *args)
-  int err;
-  iBaseEntitySet_Object *set;
+    int err;
+    iBaseEntitySet_Object *set;
-    return NULL;
+        return NULL;
-  iMesh_addPrntChld(self->mesh->mesh,self->set.handle,set->handle,&err);
-    return NULL;
+    iMesh_addPrntChld(self->mesh->mesh,self->set.handle,set->handle,&err);
+        return NULL;
-  Py_RETURN_NONE;
+    Py_RETURN_NONE;
 static PyObject *
 iMeshEntSetObj_removeChild(iMeshEntitySet_Object *self,PyObject *args)
-  int err;
+    int err;
-    return NULL;
+        return NULL;
-  iMesh_rmvPrntChld(self->mesh->mesh,self->set.handle,set->handle,&err);
-    return NULL;
+    iMesh_rmvPrntChld(self->mesh->mesh,self->set.handle,set->handle,&err);
+        return NULL;
-  Py_RETURN_NONE;
+    Py_RETURN_NONE;
 static PyObject *
 iMeshEntSetObj_isChild(iMeshEntitySet_Object *self,PyObject *args)
-  int is_child,err;
+    int is_child,err;
-    return NULL;
+        return NULL;
-  iMesh_isChildOf(self->mesh->mesh,self->set.handle,set->handle,&is_child,
-		  &err);
-    return NULL;
+    iMesh_isChildOf(self->mesh->mesh,self->set.handle,set->handle,&is_child,
+                    &err);
+        return NULL;
-  return PyBool_FromLong(is_child);
+    return PyBool_FromLong(is_child);
 static PyObject *
 iMeshEntSetObj_getNumChildren(iMeshEntitySet_Object *self,PyObject *args)
-  int num_hops,num_children,err;
+    int num_hops,num_children,err;
-    return NULL;
+        return NULL;
-  iMesh_getNumChld(self->mesh->mesh,self->set.handle,num_hops,&num_children,
-		   &err);
-    return NULL;
+    iMesh_getNumChld(self->mesh->mesh,self->set.handle,num_hops,&num_children,
+                     &err);
+        return NULL;
-  return Py_BuildValue("i",num_children);
+    return Py_BuildValue("i",num_children);
 static PyObject *
 iMeshEntSetObj_getNumParents(iMeshEntitySet_Object *self,PyObject *args)
-  int num_hops,num_parents,err;
+    int num_hops,num_parents,err;
-    return NULL;
+        return NULL;
-  iMesh_getNumPrnt(self->mesh->mesh,self->set.handle,num_hops,&num_parents,
-		   &err);
-    return NULL;
+    iMesh_getNumPrnt(self->mesh->mesh,self->set.handle,num_hops,&num_parents,
+                     &err);
+        return NULL;
-  return Py_BuildValue("i",num_parents);
+    return Py_BuildValue("i",num_parents);
 static PyObject *
 iMeshEntSetObj_getChildren(iMeshEntitySet_Object *self,PyObject *args)
-    return NULL;
+        return NULL;
-  iMesh_getChldn(self->mesh->mesh,self->set.handle,num_hops,&sets,&sets_alloc,
-                   &sets_size,&err);
-    return NULL;
+    iMesh_getChldn(self->mesh->mesh,self->set.handle,num_hops,&sets,
+        return NULL;
-  PyObject *o = PyArray_NewFromMallocData(1,dims,NPY_IMESHENTSET,sets);
-  Py_INCREF(self->mesh);
-  PyArray_BASE(o) = (PyObject*)self->mesh;
-  return o;
+    PyObject *o = PyArray_NewFromMallocData(1,dims,NPY_IMESHENTSET,sets);
+    Py_INCREF(self->mesh);
+    PyArray_BASE(o) = (PyObject*)self->mesh;
+    return o;
 static PyObject *
 iMeshEntSetObj_getParents(iMeshEntitySet_Object *self,PyObject *args)
-    return NULL;
+        return NULL;
-  iMesh_getPrnts(self->mesh->mesh,self->set.handle,num_hops,&sets,&sets_alloc,
-		 &sets_size,&err);
-    return NULL;
+    iMesh_getPrnts(self->mesh->mesh,self->set.handle,num_hops,&sets,
+        return NULL;
-  return o;
+    return o;
 static PyObject *
 iMeshEntSetObj_iterate(iMeshEntitySet_Object *self,PyObject *args)
-  Py_ssize_t size = PyTuple_Size(args);
-  PyObject *type,*topo,*count,*tuple,*ret;
+    Py_ssize_t size = PyTuple_Size(args);
+    PyObject *type,*topo,*count,*tuple,*ret;
-  if(!PyArg_UnpackTuple(args,"iterate",2,3,&type,&topo,&count))
-    return NULL;
-  tuple = PyTuple_Pack(size+2,self->mesh,self,type,topo,count);
+    if(!PyArg_UnpackTuple(args,"iterate",2,3,&type,&topo,&count))
+        return NULL;
+    tuple = PyTuple_Pack(size+2,self->mesh,self,type,topo,count);
-  ret = PyObject_CallObject((PyObject*)&iMeshIter_Type,tuple);
-  Py_DECREF(tuple);
-  return ret;
+    ret = PyObject_CallObject((PyObject*)&iMeshIter_Type,tuple);
+    Py_DECREF(tuple);
+    return ret;
 static PyObject *
 iMeshEntSetObj_sub(iMeshEntitySet_Object *lhs,iMeshEntitySet_Object *rhs)
-  int err;
-  iMeshEntitySet_Object *result;
+    int err;
+    iMeshEntitySet_Object *result;
-  if(lhs->mesh->mesh != rhs->mesh->mesh)
-    return NULL;
+    if(lhs->mesh->mesh != rhs->mesh->mesh)
+        return NULL;
-  result = iMeshEntitySet_New();
-  result->mesh = lhs->mesh; /* TODO: incref? */
-  iMesh_subtract(lhs->mesh->mesh,lhs->set.handle,rhs->set.handle,
-		 &result->set.handle,&err);
-  if(checkError(lhs->mesh->mesh,err))
-    Py_DECREF((PyObject*)result);
-    return NULL;
+    result = iMeshEntitySet_New();
+    result->mesh = lhs->mesh; /* TODO: incref? */
+    iMesh_subtract(lhs->mesh->mesh,lhs->set.handle,rhs->set.handle,
+                   &result->set.handle,&err);
+    if(checkError(lhs->mesh->mesh,err))
+        Py_DECREF((PyObject*)result);
+        return NULL;
-  return (PyObject*)result;
+    return (PyObject*)result;
 static PyObject *
 iMeshEntSetObj_bitand(iMeshEntitySet_Object *lhs,iMeshEntitySet_Object *rhs)
-  int err;
+    int err;
-    return NULL;
+        return NULL;
-  iMesh_intersect(lhs->mesh->mesh,lhs->set.handle,rhs->set.handle,
-    return NULL;
+    iMesh_intersect(lhs->mesh->mesh,lhs->set.handle,rhs->set.handle,
+        return NULL;
 static PyObject *
 iMeshEntSetObj_bitor(iMeshEntitySet_Object *lhs,iMeshEntitySet_Object *rhs)
-  int err;
+    int err;
-    return NULL;
+        return NULL;
-  iMesh_unite(lhs->mesh->mesh,lhs->set.handle,rhs->set.handle,
-    return NULL;
+    iMesh_unite(lhs->mesh->mesh,lhs->set.handle,rhs->set.handle,
+        return NULL;
 static PyObject *
 iMeshEntSetObj_difference(iMeshEntitySet_Object *self,PyObject *args)
-  iMeshEntitySet_Object *rhs;
-  if(!PyArg_ParseTuple(args,"O!",&iMeshEntitySet_Type,&rhs))
-    return NULL;
+    iMeshEntitySet_Object *rhs;
+    if(!PyArg_ParseTuple(args,"O!",&iMeshEntitySet_Type,&rhs))
+        return NULL;
-  return iMeshEntSetObj_sub(self,rhs);
+    return iMeshEntSetObj_sub(self,rhs);
 static PyObject *
 iMeshEntSetObj_intersection(iMeshEntitySet_Object *self,PyObject *args)
-    return NULL;
+        return NULL;
-  return iMeshEntSetObj_bitand(self,rhs);
+    return iMeshEntSetObj_bitand(self,rhs);
 static PyObject *
 iMeshEntSetObj_union(iMeshEntitySet_Object *self,PyObject *args)
-    return NULL;
+        return NULL;
-  return iMeshEntSetObj_bitor(self,rhs);
+    return iMeshEntSetObj_bitor(self,rhs);
 static PyMethodDef iMeshEntSetObj_methods[] = {
-  { "getNumEntSets", (PyCFunction)iMeshEntSetObj_getNumEntSets, METH_VARARGS,
-    "Get the number of entity sets contained in the set or interface"
-  { "getEntSets", (PyCFunction)iMeshEntSetObj_getEntSets, METH_VARARGS,
-    "Get the entity sets contained in the set or interface"
-  { "add", (PyCFunction)iMeshEntSetObj_add, METH_VARARGS,
-    "Add an entity (or array of entities or entity set) to the set"
-  { "remove", (PyCFunction)iMeshEntSetObj_remove, METH_VARARGS,
-    "Remove an entity (or array of entities or entity set) from the set"
-  { "contains", (PyCFunction)iMeshEntSetObj_contains, METH_VARARGS,
-    "Return whether an entity (or array of entities or entity set) are "
-    "contained in the set"
-  { "addChild", (PyCFunction)iMeshEntSetObj_addChild, METH_VARARGS,
-    "Add parent/child links between two sets"
-  { "removeChild", (PyCFunction)iMeshEntSetObj_removeChild, METH_VARARGS,
-    "Remove parent/child links between two sets"
-  { "isChild", (PyCFunction)iMeshEntSetObj_isChild, METH_VARARGS,
-    "Return whether a set is a child of this set"
-  { "getNumChildren", (PyCFunction)iMeshEntSetObj_getNumChildren, METH_VARARGS,
-    "Get the number of child sets linked from this set"
-  { "getNumParents", (PyCFunction)iMeshEntSetObj_getNumParents, METH_VARARGS,
-    "Get the number of parent sets linked from this set"
-  { "getChildren", (PyCFunction)iMeshEntSetObj_getChildren, METH_VARARGS,
-    "Get the child sets linked from this set"
-  { "getParents", (PyCFunction)iMeshEntSetObj_getParents, METH_VARARGS,
-    "Get the parent sets linked from this set"
-  { "iterate", (PyCFunction)iMeshEntSetObj_iterate, METH_VARARGS,
-    "Initialize an iterator over specified entity type, topology, and size"
-  { "difference", (PyCFunction)iMeshEntSetObj_difference, METH_VARARGS,
-    "Get the difference of the two sets"
-  { "intersection", (PyCFunction)iMeshEntSetObj_intersection, METH_VARARGS,
-    "Get the intersection of the two sets"
-  { "union", (PyCFunction)iMeshEntSetObj_union, METH_VARARGS,
-    "Get the union of the two sets"
-  {0}
+    { "getNumEntSets", (PyCFunction)iMeshEntSetObj_getNumEntSets, METH_VARARGS,
+      "Get the number of entity sets contained in the set or interface"
+    { "getEntSets", (PyCFunction)iMeshEntSetObj_getEntSets, METH_VARARGS,
+      "Get the entity sets contained in the set or interface"
+    { "add", (PyCFunction)iMeshEntSetObj_add, METH_VARARGS,
+      "Add an entity (or array of entities or entity set) to the set"
+    { "remove", (PyCFunction)iMeshEntSetObj_remove, METH_VARARGS,
+      "Remove an entity (or array of entities or entity set) from the set"
+    { "contains", (PyCFunction)iMeshEntSetObj_contains, METH_VARARGS,
+      "Return whether an entity (or array of entities or entity set) are "
+      "contained in the set"
+    { "addChild", (PyCFunction)iMeshEntSetObj_addChild, METH_VARARGS,
+      "Add parent/child links between two sets"
+    { "removeChild", (PyCFunction)iMeshEntSetObj_removeChild, METH_VARARGS,
+      "Remove parent/child links between two sets"
+    { "isChild", (PyCFunction)iMeshEntSetObj_isChild, METH_VARARGS,
+      "Return whether a set is a child of this set"
+    { "getNumChildren", (PyCFunction)iMeshEntSetObj_getNumChildren,
+      METH_VARARGS,
+      "Get the number of child sets linked from this set"
+    { "getNumParents", (PyCFunction)iMeshEntSetObj_getNumParents, METH_VARARGS,
+      "Get the number of parent sets linked from this set"
+    { "getChildren", (PyCFunction)iMeshEntSetObj_getChildren, METH_VARARGS,
+      "Get the child sets linked from this set"
+    { "getParents", (PyCFunction)iMeshEntSetObj_getParents, METH_VARARGS,
+      "Get the parent sets linked from this set"
+    { "iterate", (PyCFunction)iMeshEntSetObj_iterate, METH_VARARGS,
+      "Initialize an iterator over specified entity type, topology, and size"
+    { "difference", (PyCFunction)iMeshEntSetObj_difference, METH_VARARGS,
+      "Get the difference of the two sets"
+    { "intersection", (PyCFunction)iMeshEntSetObj_intersection, METH_VARARGS,
+      "Get the intersection of the two sets"
+    { "union", (PyCFunction)iMeshEntSetObj_union, METH_VARARGS,
+      "Get the union of the two sets"
+    {0}
 static PyGetSetDef iMeshEntSetObj_getset[] = {
-  { "isList", (getter)iMeshEntSetObj_isList, 0,
-    "Return whether a specified set is ordered or unordered", 0 },
-  {0}
+    { "isList", (getter)iMeshEntSetObj_isList, 0,
+      "Return whether a specified set is ordered or unordered", 0 },
+    {0}
 static PyNumberMethods iMeshEntSetObj_num = {
-  0,                                   /* nb_add */
-  (binaryfunc)iMeshEntSetObj_sub,      /* nb_subtract */
-  0,                                   /* nb_multiply */
-  0,                                   /* nb_divide */
-  0,                                   /* nb_remainder */
-  0,                                   /* nb_divmod */
-  0,                                   /* nb_power */
-  0,                                   /* nb_negative */
-  0,                                   /* nb_positive */
-  0,                                   /* nb_absolute */
-  0,                                   /* nb_nonzero */
-  0,                                   /* nb_invert */
-  0,                                   /* nb_lshift */
-  0,                                   /* nb_rshift */
-  (binaryfunc)iMeshEntSetObj_bitand,   /* nb_and */
-  0,                                   /* nb_xor */
-  (binaryfunc)iMeshEntSetObj_bitor,    /* nb_or */
-  0,                                   /* nb_coerce */
-  0,                                   /* nb_int */
-  0,                                   /* nb_long */
-  0,                                   /* nb_float */
-  0,                                   /* nb_oct */
-  0,                                   /* nb_hex */
+    0,                                   /* nb_add */
+    (binaryfunc)iMeshEntSetObj_sub,      /* nb_subtract */
+    0,                                   /* nb_multiply */
+    0,                                   /* nb_divide */
+    0,                                   /* nb_remainder */
+    0,                                   /* nb_divmod */
+    0,                                   /* nb_power */
+    0,                                   /* nb_negative */
+    0,                                   /* nb_positive */
+    0,                                   /* nb_absolute */
+    0,                                   /* nb_nonzero */
+    0,                                   /* nb_invert */
+    0,                                   /* nb_lshift */
+    0,                                   /* nb_rshift */
+    (binaryfunc)iMeshEntSetObj_bitand,   /* nb_and */
+    0,                                   /* nb_xor */
+    (binaryfunc)iMeshEntSetObj_bitor,    /* nb_or */
+    0,                                   /* nb_coerce */
+    0,                                   /* nb_int */
+    0,                                   /* nb_long */
+    0,                                   /* nb_float */
+    0,                                   /* nb_oct */
+    0,                                   /* nb_hex */
 PyTypeObject iMeshEntitySet_Type = {
-  0,                                   /* ob_size */
-  "itaps.iMesh.entitySet",             /* tp_name */
-  sizeof(iMeshEntitySet_Object),       /* tp_basicsize */
-  0,                                   /* tp_dealloc */
-  0,                                   /* tp_print */
-  0,                                   /* tp_repr */
-  &iMeshEntSetObj_num,                 /* tp_as_number */
-  0,                                   /* tp_hash */
-  0,                                   /* tp_call */
-  0,                                   /* tp_str */
-  "iMesh entity set object",           /* tp_doc */
-  0,                                   /* tp_clear */
-  0,                                   /* tp_iter */
-  iMeshEntSetObj_methods,              /* tp_methods */
-  iMeshEntSetObj_getset,               /* tp_getset */
-  0,                                   /* tp_base */
-  0,                                   /* tp_dict */
-  0,                                   /* tp_init */
-  0,                                   /* tp_alloc */
-  0,                                   /* tp_new */
+    0,                                   /* ob_size */
+    "itaps.iMesh.entitySet",             /* tp_name */
+    sizeof(iMeshEntitySet_Object),       /* tp_basicsize */
+    0,                                   /* tp_dealloc */
+    0,                                   /* tp_print */
+    0,                                   /* tp_repr */
+    &iMeshEntSetObj_num,                 /* tp_as_number */
+    0,                                   /* tp_hash */
+    0,                                   /* tp_call */
+    0,                                   /* tp_str */
+    "iMesh entity set object",           /* tp_doc */
+    0,                                   /* tp_clear */
+    0,                                   /* tp_iter */
+    iMeshEntSetObj_methods,              /* tp_methods */
+    iMeshEntSetObj_getset,               /* tp_getset */
+    0,                                   /* tp_base */
+    0,                                   /* tp_dict */
+    0,                                   /* tp_init */
+    0,                                   /* tp_alloc */
+    0,                                   /* tp_new */
Modified: MOAB/trunk/tools/iMesh/python/iMesh_iter.c
--- MOAB/trunk/tools/iMesh/python/iMesh_iter.c	2009-05-09 16:36:05 UTC (rev 2881)
+++ MOAB/trunk/tools/iMesh/python/iMesh_iter.c	2009-05-11 19:46:19 UTC (rev 2882)
@@ -7,145 +7,145 @@
 static int
 iMeshIterObj_init(iMeshIter_Object *self,PyObject *args,PyObject *kwds)
-  static char *kwlist[] = {"mesh","entity_set","type","topology",
-                           "array_size",0};
-  int type,topo,array_size=1,err;
+    static char *kwlist[] = {"mesh","entity_set","type","topology",
+                             "array_size",0};
+    int type,topo,array_size=1,err;
-  if( !PyArg_ParseTupleAndKeywords(args,kwds,"OOii|i",kwlist,&mesh,&set,&type,
-                                   &topo,&array_size) )
-    return -1;
+    if( !PyArg_ParseTupleAndKeywords(args,kwds,"OOii|i",kwlist,&mesh,&set,
+                                     &type,&topo,&array_size) )
+        return -1;
-  self->mesh = mesh->mesh;
-  if(array_size == 1)
-    self->is_arr = 0;
-    iMesh_initEntIter(self->mesh,set->handle,type,topo,&self->iter,&err);
-  else
-    self->is_arr = 1;
-    iMesh_initEntArrIter(self->mesh,set->handle,type,topo,array_size,
-			 &self->arr_iter,&err);
-  if(checkError(self->mesh,err))
-    return -1;
+    self->mesh = mesh->mesh;
+    if(array_size == 1)
+        self->is_arr = 0;
+        iMesh_initEntIter(self->mesh,set->handle,type,topo,&self->iter,&err);
+    else
+        self->is_arr = 1;
+        iMesh_initEntArrIter(self->mesh,set->handle,type,topo,array_size,
+                             &self->arr_iter,&err);
+    if(checkError(self->mesh,err))
+        return -1;
-  return 0;
+    return 0;
 static void
 iMeshIterObj_dealloc(iMeshIter_Object *self)
-  if(self->mesh && self->iter)
-    int err;
-    if(self->is_arr)
-      iMesh_endEntArrIter(self->mesh,self->arr_iter,&err);
-    else
-      iMesh_endEntIter(self->mesh,self->iter,&err);
+    if(self->mesh && self->iter)
+        int err;
+        if(self->is_arr)
+            iMesh_endEntArrIter(self->mesh,self->arr_iter,&err);
+        else
+            iMesh_endEntIter(self->mesh,self->iter,&err);
-  self->ob_type->tp_free((PyObject*)self);
+    self->ob_type->tp_free((PyObject*)self);
 static PyObject *
 iMeshIterObj_reset(iMeshIter_Object *self,PyObject *args)
-  int err;
-  if(self->is_arr)
-    iMesh_resetEntArrIter(self->mesh,self->arr_iter,&err);
-  else
-    iMesh_resetEntIter(self->mesh,self->iter,&err);
+    int err;
+    if(self->is_arr)
+        iMesh_resetEntArrIter(self->mesh,self->arr_iter,&err);
+    else
+        iMesh_resetEntIter(self->mesh,self->iter,&err);
-    return NULL;
-  Py_RETURN_NONE;
+        return NULL;
+    Py_RETURN_NONE;
 static PyMethodDef iMeshIter_methods[] = {
-  { "reset", (PyCFunction)iMeshIterObj_reset, METH_NOARGS,
-    "Reset the iterator"
-  {0}
+    { "reset", (PyCFunction)iMeshIterObj_reset, METH_NOARGS,
+      "Reset the iterator"
+    {0}
 static PyObject *
 iMeshIterObj_iternext(iMeshIter_Object *self)
-  int has_data,err;
+    int has_data,err;
-  if(self->is_arr)
-    iBase_EntityHandle *entities=0;
-    int alloc=0,size;
+    if(self->is_arr)
+        iBase_EntityHandle *entities=0;
+        int alloc=0,size;
-    iMesh_getNextEntArrIter(self->mesh,self->arr_iter,&entities,&alloc,&size,
-			    &has_data,&err);
-      return NULL;
-    if(!has_data)
-      return NULL;
+        iMesh_getNextEntArrIter(self->mesh,self->arr_iter,&entities,&alloc,
+                                &size,&has_data,&err);
+            return NULL;
+        if(!has_data)
+            return NULL;
-    npy_intp dims[] = {size};
-    return PyArray_NewFromMallocData(1,dims,NPY_IBASEENT,entities);
-  else
-    iBase_EntityHandle entity;
-    iMesh_getNextEntIter(self->mesh,self->iter,&entity,&has_data,&err);
-      return NULL;
-    if(!has_data)
-      return NULL;
+        npy_intp dims[] = {size};
+        return PyArray_NewFromMallocData(1,dims,NPY_IBASEENT,entities);
+    else
+        iBase_EntityHandle entity;
+        iMesh_getNextEntIter(self->mesh,self->iter,&entity,&has_data,&err);
+            return NULL;
+        if(!has_data)
+            return NULL;
-    iBaseEntity_Object *o = iBaseEntity_New();
-    o->handle = entity;
+        iBaseEntity_Object *o = iBaseEntity_New();
+        o->handle = entity;
 PyTypeObject iMeshIter_Type = {
-  0,                                   /* ob_size */
-  "itaps.iMesh.iterator",              /* tp_name */
-  sizeof(iMeshIter_Object),            /* tp_basicsize */
-  (destructor)iMeshIterObj_dealloc,    /* tp_dealloc */
-  0,                                   /* tp_print */
-  0,                                   /* tp_repr */
-  0,                                   /* tp_hash */
-  0,                                   /* tp_call */
-  0,                                   /* tp_str */
-  Py_TPFLAGS_HAVE_ITER |
-  "iMesh iterator object",             /* tp_doc */
-  0,                                   /* tp_clear */
-  PyObject_SelfIter,                   /* tp_iter */
-  (iternextfunc)iMeshIterObj_iternext, /* tp_iternext */
-  iMeshIter_methods,                   /* tp_methods */
-  0,                                   /* tp_getset */
-  0,                                   /* tp_base */
-  0,                                   /* tp_dict */
-  (initproc)iMeshIterObj_init,         /* tp_init */
-  0,                                   /* tp_alloc */
-  0,                                   /* tp_new */
+    0,                                   /* ob_size */
+    "itaps.iMesh.iterator",              /* tp_name */
+    sizeof(iMeshIter_Object),            /* tp_basicsize */
+    (destructor)iMeshIterObj_dealloc,    /* tp_dealloc */
+    0,                                   /* tp_print */
+    0,                                   /* tp_repr */
+    0,                                   /* tp_hash */
+    0,                                   /* tp_call */
+    0,                                   /* tp_str */
+    Py_TPFLAGS_HAVE_ITER |
+    "iMesh iterator object",             /* tp_doc */
+    0,                                   /* tp_clear */
+    PyObject_SelfIter,                   /* tp_iter */
+    (iternextfunc)iMeshIterObj_iternext, /* tp_iternext */
+    iMeshIter_methods,                   /* tp_methods */
+    0,                                   /* tp_getset */
+    0,                                   /* tp_base */
+    0,                                   /* tp_dict */
+    (initproc)iMeshIterObj_init,         /* tp_init */
+    0,                                   /* tp_alloc */
+    0,                                   /* tp_new */
Modified: MOAB/trunk/tools/iMesh/python/iMesh_tag.c
--- MOAB/trunk/tools/iMesh/python/iMesh_tag.c	2009-05-09 16:36:05 UTC (rev 2881)
+++ MOAB/trunk/tools/iMesh/python/iMesh_tag.c	2009-05-11 19:46:19 UTC (rev 2882)
@@ -9,129 +9,129 @@
 enum iBase_TagValueType
 char_to_type(char c)
-  int i;
-  for(i=0; i<sizeof(typechars); i++)
+    int i;
+    for(i=0; i<sizeof(typechars); i++)
-      if(typechars[i] == c)
-	return i;
+        if(typechars[i] == c)
+            return i;
-  return -1;
+    return -1;
 char
 type_to_char(enum iBase_TagValueType t)
-  return typechars[t];
+    return typechars[t];
 static PyObject *
 iMeshTagObj_getName(iMeshTag_Object *self,void *closure)
-  char name[512];
-  int err;
-  iMesh_getTagName(self->mesh->mesh,self->tag.handle,name,&err,sizeof(name));
-    return NULL;
+    char name[512];
+    int err;
+    iMesh_getTagName(self->mesh->mesh,self->tag.handle,name,&err,sizeof(name));
+        return NULL;
-  return Py_BuildValue("s",name);
+    return Py_BuildValue("s",name);
 static PyObject *
 iMeshTagObj_getSizeValues(iMeshTag_Object *self,void *closure)
-  int size,err;
-  iMesh_getTagSizeValues(self->mesh->mesh,self->tag.handle,&size,&err);
-    return NULL;
+    int size,err;
+    iMesh_getTagSizeValues(self->mesh->mesh,self->tag.handle,&size,&err);
+        return NULL;
-  return Py_BuildValue("i",size);
+    return Py_BuildValue("i",size);
 static PyObject *
 iMeshTagObj_getSizeBytes(iMeshTag_Object *self,void *closure)
-  int size,err;
-  iMesh_getTagSizeBytes(self->mesh->mesh,self->tag.handle,&size,&err);
-    return NULL;
+    int size,err;
+    iMesh_getTagSizeBytes(self->mesh->mesh,self->tag.handle,&size,&err);
+        return NULL;
 static PyObject *
 iMeshTagObj_getType(iMeshTag_Object *self,void *closure)
-  int type,err;
-  iMesh_getTagType(self->mesh->mesh,self->tag.handle,&type,&err);
-    return NULL;
+    int type,err;
+    iMesh_getTagType(self->mesh->mesh,self->tag.handle,&type,&err);
+        return NULL;
-  return Py_BuildValue("c",type_to_char(type));
+    return Py_BuildValue("c",type_to_char(type));
 static PyMethodDef iMeshTagObj_methods[] = {
-  {0}
+    {0}
 static PyGetSetDef iMeshTagObj_getset[] = {
-  { "name", (getter)iMeshTagObj_getName, 0,
+    { "name", (getter)iMeshTagObj_getName, 0,
       "Get the name for a given tag handle", 0
-  { "sizeValues", (getter)iMeshTagObj_getSizeValues, 0,
-    "Get size of a tag in units of numbers of tag data type", 0
-  { "sizeBytes", (getter)iMeshTagObj_getSizeBytes, 0,
-    "Get size of a tag in units of bytes", 0
-  { "type", (getter)iMeshTagObj_getType, 0,
-    "Get the data type of the specified tag handle", 0
-  {0}
+    { "sizeValues", (getter)iMeshTagObj_getSizeValues, 0,
+      "Get size of a tag in units of numbers of tag data type", 0
+    { "sizeBytes", (getter)iMeshTagObj_getSizeBytes, 0,
+      "Get size of a tag in units of bytes", 0
+    { "type", (getter)iMeshTagObj_getType, 0,
+      "Get the data type of the specified tag handle", 0
+    {0}
 PyTypeObject iMeshTag_Type = {
-  0,                                   /* ob_size */
-  "itaps.iMesh.tag",                   /* tp_name */
-  sizeof(iMeshTag_Object),             /* tp_basicsize */
-  0,                                   /* tp_print */
-  0,                                   /* tp_repr */
-  0,                                   /* tp_hash */
-  0,                                   /* tp_call */
-  0,                                   /* tp_str */
-  "iMesh tag object",                  /* tp_doc */
-  0,                                   /* tp_clear */
-  0,                                   /* tp_iter */
-  iMeshTagObj_methods,                 /* tp_methods */
-  iMeshTagObj_getset,                  /* tp_getset */
-  0,                                   /* tp_base */
-  0,                                   /* tp_dict */
-  0,                                   /* tp_init */
-  0,                                   /* tp_alloc */
-  0,                                   /* tp_new */
+    0,                                   /* ob_size */
+    "itaps.iMesh.tag",                   /* tp_name */
+    sizeof(iMeshTag_Object),             /* tp_basicsize */
+    0,                                   /* tp_print */
+    0,                                   /* tp_repr */
+    0,                                   /* tp_hash */
+    0,                                   /* tp_call */
+    0,                                   /* tp_str */
+    "iMesh tag object",                  /* tp_doc */
+    0,                                   /* tp_clear */
+    0,                                   /* tp_iter */
+    iMeshTagObj_methods,                 /* tp_methods */
+    iMeshTagObj_getset,                  /* tp_getset */
+    0,                                   /* tp_base */
+    0,                                   /* tp_dict */
+    0,                                   /* tp_init */
+    0,                                   /* tp_alloc */
+    0,                                   /* tp_new */
Modified: MOAB/trunk/tools/iMesh/python/test/tags.py
--- MOAB/trunk/tools/iMesh/python/test/tags.py	2009-05-09 16:36:05 UTC (rev 2881)
+++ MOAB/trunk/tools/iMesh/python/test/tags.py	2009-05-11 19:46:19 UTC (rev 2882)
@@ -109,14 +109,13 @@
                           self.ents,self.etag)
     def testRawArrData(self):
-        data = array([1,2,3], int8)
+        data = array(3*[1,2,3], int8)
         self.mesh.setData(self.ents, self.btag, data)
-        cmp = array([1,2,3, 0,0,0, 0,0,0], int8) # Huh??
         self.assert_((self.mesh.getData(self.ents, self.btag, 'b') ==
-                      cmp).all())
-        self.assert_((self.mesh.getData(self.ents[0], self.btag, 'b') == data).
-                     all())
+                      data).all())
+        self.assert_((self.mesh.getData(self.ents[0], self.btag, 'b') ==
+                      data[0:3]).all())
         self.mesh.rmvTag(self.ents, self.btag)
         self.assertRaises(RuntimeError, self.mesh.getData,
