[MOAB-dev] r2874 - in MOAB/trunk: . test/h5file
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Mon May 4 12:14:30 CDT 2009
Author: kraftche
Date: 2009-05-04 12:14:29 -0500 (Mon, 04 May 2009)
New Revision: 2874
Modified:
   MOAB/trunk/README.IO
   MOAB/trunk/ReadHDF5.cpp
   MOAB/trunk/ReadHDF5.hpp
   MOAB/trunk/test/h5file/h5partial.cpp
Log:
during partial read of H5M file, read any explicitly defined element sides
Modified: MOAB/trunk/README.IO
--- MOAB/trunk/README.IO	2009-05-01 22:15:22 UTC (rev 2873)
+++ MOAB/trunk/README.IO	2009-05-04 17:14:29 UTC (rev 2874)
@@ -134,13 +134,15 @@
 MOAB Native (HDF5-based MHDF) format
-   ELEMENTS={EXPLICIT|NODES}
+   ELEMENTS={EXPLICIT|NODES|SIDES}
 If reading only part of a file, specify which additional elements to read
 in addition to those contained in the specified set.  The options are:
    EXPLICIT    - read only explicitly designated elements
    NODES       - read any element for which all the nodes are being read.
-Default is EXPLICIT unless only nodesa are explicitly specified, in which
+   SIDES       - read explicilty specified elements and any elements that
+                 are sides of those elements.
+Default is SIDES unless only nodes are explicitly specified, in which
 case NODES will be used.
    CHILDREN={NONE|SETS|CONTENTS}
Modified: MOAB/trunk/ReadHDF5.cpp
--- MOAB/trunk/ReadHDF5.cpp	2009-05-01 22:15:22 UTC (rev 2873)
+++ MOAB/trunk/ReadHDF5.cpp	2009-05-04 17:14:29 UTC (rev 2874)
@@ -472,59 +472,63 @@
 DEBUGOUT( "READING ELEMENTS" );
     // decide if we need to read additional elements
-  int mode;
-  const char* const options[] = { "EXPLICIT", "ADJACENT", 0 };
-  rval = opts.match_option( "ELEMENTS", options, mode );
-  bool read_adjacent_elements;
-  if (MB_SUCCESS == rval) {
-    read_adjacent_elements = (mode == 1);
+  int side_mode;
+  const char* const options[] = { "EXPLICIT", "NODES", "SIDES", 0 };
+  rval = opts.match_option( "ELEMENTS", options, side_mode );
   if (MB_ENTITY_NOT_FOUND == rval) {
       // Chose default based on whether or not any elements have been
       // specified.
     MBRange tmp;
     intersect( fileInfo->nodes, file_ids, tmp );
-    if (tmp.empty()) // can't do 'ADJACENT' mode if no nodes
-      read_adjacent_elements = false;
-    else {  // check if we have any elements, default to 'ADJACENT' only if no
-            // explicitly specified elements
-      tmp.merge( sets );
-      MBRange elems = file_ids.subtract( tmp );
-      read_adjacent_elements = elems.empty();
+      // If only nodes were specified, then default to "NODES", otherwise
+      // default to "SIDES".
+    if (!tmp.empty() && (tmp.size() + sets.size()) == file_ids.size())
+      side_mode = 1;
+    else
+      side_mode = 2;
-  else {
+  else if (MB_SUCCESS != rval) {
     readUtil->report_error( "Invalid value for 'ELEMENTS' option" );
     return error(rval);
-  if (read_adjacent_elements) {
+  switch (side_mode) {
+    case 0: // ELEMENTS=EXPLICIT : read only specified element IDS
     for (int dim = 1; dim <= 3; ++dim) {
       for (int i = 0; i < fileInfo->num_elem_desc; ++i) {
         MBEntityType type = MBCN::EntityTypeFromName( fileInfo->elems[i].type );
         if (MBCN::Dimension(type) == dim) {
-          rval = read_node_adj_elems( fileInfo->elems[i] );
+          MBRange subset;
+          intersect( fileInfo->elems[i].desc, file_ids, subset );
+          rval = read_elems( fileInfo->elems[i],  subset );
             return error(rval);
-  else {
+    break;
+    case 1: // ELEMENTS=NODES : read all elements for which all nodes have been read
-          MBRange subset;
-          intersect( fileInfo->elems[i].desc, file_ids, subset );
-          rval = read_elems( fileInfo->elems[i],  subset );
+          rval = read_node_adj_elems( fileInfo->elems[i] );
             return error(rval);
+    break;
+    case 2: // ELEMENTS=SIDES : read explicitly specified elems and any sides of those elems
+    rval = read_elements_and_sides( file_ids );
+    if (MB_SUCCESS != rval)
+      return error(rval);
+    break;
 DEBUGOUT( "READING SETS" );
     // If reading contained/child sets but not their contents then find
@@ -1155,6 +1159,163 @@
+MBErrorCode ReadHDF5::read_elements_and_sides( const MBRange& file_ids )
+  MBErrorCode rval;
+  MBEntityType type;
+    // determine largest element dimension
+  int max_dim = 0;
+  for (int i = 0; i < fileInfo->num_elem_desc; ++i) {
+    type = MBCN::EntityTypeFromName( fileInfo->elems[i].type );
+    int dim = MBCN::Dimension(type);
+    if (dim > max_dim) {
+      MBEntityHandle start = (MBEntityHandle)fileInfo->elems[i].desc.start_id;
+      MBRange::iterator it = file_ids.lower_bound( start );
+      if (it != file_ids.end() && (long)(*it - start ) < fileInfo->elems[i].desc.count)
+        max_dim = dim;
+    // Get MBRange of element IDs only
+  MBRange elem_ids( file_ids );
+  MBRange::iterator s, e;
+  if (fileInfo->nodes.count) {
+    MBEntityHandle first = (MBEntityHandle)fileInfo->nodes.start_id;
+    s = elem_ids.lower_bound( first );
+    e = MBRange::lower_bound( s, elem_ids.end(), first + fileInfo->nodes.count );
+    elem_ids.erase( s, e );
+  if (fileInfo->sets.count) {
+    MBEntityHandle first = (MBEntityHandle)fileInfo->sets.start_id;
+    e = MBRange::lower_bound( s, elem_ids.end(), first + fileInfo->sets.count );
+    // read all node-adjacent elements of smaller dimensions
+    MBEntityType type = MBCN::EntityTypeFromName( fileInfo->elems[i].type );
+    if (MBCN::Dimension(type) < max_dim) {
+    // Read the subset of the explicitly sepecified elements that are of the
+    // largest dimension.   We could read all explicitly specified elements,
+    // but then the lower-dimension elements will be read a second when reading
+    // node-adjacent elements.
+    if (MBCN::Dimension(type) == max_dim) {
+      MBRange subset;
+      intersect( fileInfo->elems[i].desc, elem_ids, subset );
+      if (!subset.empty()) {
+        elem_ids.subtract( subset );
+    // delete anything we read in that we should not have
+    // (e.g. an edge spanning two disjoint blocks of elements)
+    // get MBRange of all explicitly specified elements, grouped by dimension
+  MBRange explicit_elems[4];
+  MBRange::iterator hints[4] = { explicit_elems[0].begin(),
+                                explicit_elems[1].begin(),
+                                explicit_elems[2].begin(),
+                                explicit_elems[3].begin() };
+  RangeMap<long, MBEntityHandle>::iterator rit;
+  while (!elem_ids.empty()) {
+    long start = elem_ids.front();
+    long count = elem_ids.const_pair_begin()->second - start + 1;
+    rit = idMap.lower_bound( start );
+    assert( rit->begin <= start && rit->begin + rit->count > start );
+    long offset = start - rit->begin;
+    long avail = rit->count - offset;
+    if (avail > count)
+      count = avail;
+    MBEntityHandle start_h = rit->value + offset;
+    int d = MBCN::Dimension( TYPE_FROM_HANDLE( start_h ) );
+    if (MBCN::Dimension( TYPE_FROM_HANDLE( start_h + count - 1 ) ) != d)
+      count = start - LAST_HANDLE( TYPE_FROM_HANDLE(start_h) ) + 1;
+    elem_ids.erase( elem_ids.begin(), elem_ids.begin() + count );
+    hints[d] = explicit_elems[d].insert( hints[d], rit->value + offset, rit->value + offset + count - 1 );
+    // get MBRange of all read elements, and remove any that were explicity specified
+    // get handles for everything we've read
+  MBRange all_elems;
+  MBRange::iterator hint = all_elems.begin();
+  for (rit = idMap.begin(); rit != idMap.end(); ++rit)
+    hint = all_elems.insert( hint, rit->value, rit->value + rit->count - 1 );
+    // remove any vertex handles
+  all_elems.erase( all_elems.begin(), all_elems.upper_bound( MBVERTEX ) );
+    // remove any set handles and any handles for elements >= max_dim
+  all_elems.erase( all_elems.lower_bound( MBCN::TypeDimensionMap[max_dim].first ), all_elems.end() );
+    // remove explicit elements < max_dim
+  if (!explicit_elems[1].empty() && max_dim > 1)
+    all_elems = all_elems.subtract( explicit_elems[1] );
+  if (!explicit_elems[2].empty() && max_dim > 2)
+    all_elems = all_elems.subtract( explicit_elems[2] );
+    // remove any elements that are adjacent to some explicity specified element.
+  if (max_dim > 1 && !explicit_elems[2].empty()) {
+    MBRange adj;
+    rval = iFace->get_adjacencies( explicit_elems[2], 1, false, adj, MBInterface::UNION );
+    if (!adj.empty())
+      all_elems = all_elems.subtract( adj );
+  if (max_dim == 3) {
+    MBRange adj;
+    rval = iFace->get_adjacencies( explicit_elems[3], 1, false, adj, MBInterface::UNION );
+    if (!adj.empty())
+    adj.clear();
+    rval = iFace->get_adjacencies( explicit_elems[3], 2, false, adj, MBInterface::UNION );
+    if (!adj.empty())
+    // now delete anything remaining in all_elems
+  rval = iFace->delete_entities( all_elems );
+    // remove dead entities from ID map
+  while (!all_elems.empty()) {
+    MBEntityHandle start = all_elems.front();
+    MBEntityID count = all_elems.const_pair_begin()->second - start + 1;
+      if (rit->value <= start && (long)(start - rit->value) < rit->count)
+        break;
+    if (rit == idMap.end())
+      return error(MB_FAILURE);
+    MBEntityID offset = start - rit->value;
+    MBEntityID avail = rit->count - offset;
+    if (avail < count)
+      count = avail;
+    all_elems.erase( all_elems.begin(), all_elems.begin() + count );
+    idMap.erase( rit->begin + offset, count );
+  return MB_SUCCESS;
 MBErrorCode ReadHDF5::read_sets( const MBRange& file_ids )
   mhdf_Status status;
Modified: MOAB/trunk/ReadHDF5.hpp
--- MOAB/trunk/ReadHDF5.hpp	2009-05-01 22:15:22 UTC (rev 2873)
+++ MOAB/trunk/ReadHDF5.hpp	2009-05-04 17:14:29 UTC (rev 2874)
@@ -132,6 +132,9 @@
   //! Read poly(gons|hedra)
   MBErrorCode read_poly( const mhdf_ElemDesc& elems, const MBRange& file_ids );
+  //! Read specified elements and any adjacent elemnets of lower dimension
+  MBErrorCode read_elements_and_sides( const MBRange& file_ids );
   //! Read sets
   MBErrorCode read_sets( const MBRange& set_file_ids );
Modified: MOAB/trunk/test/h5file/h5partial.cpp
--- MOAB/trunk/test/h5file/h5partial.cpp	2009-05-01 22:15:22 UTC (rev 2873)
+++ MOAB/trunk/test/h5file/h5partial.cpp	2009-05-04 17:14:29 UTC (rev 2874)
@@ -132,6 +132,7 @@
 void test_read_tagged_nodes();
+void test_read_sides();
 int main( int argc, char* argv[] )
@@ -167,6 +168,7 @@
   result += RUN_TEST(test_read_adjacencies);
   result += RUN_TEST(test_read_tagged_elems);
   result += RUN_TEST(test_read_tagged_nodes);
+  result += RUN_TEST(test_read_sides);
   if (argc == 1)
     remove( TEST_FILE );
@@ -1396,3 +1398,85 @@
+  MBErrorCode rval;
+  MBCore instance;
+  MBInterface& mb = instance;
+    // create 4x4 grid of quads with edges
+  const int INT = 4;
+  MBEntityHandle verts[INT+1][INT+1];
+  for (int j = 0; j <= INT; ++j) {
+    for (int i = 0; i <= INT; ++i) {
+      double coords[3] = { i, j, 0 };
+      rval = mb.create_vertex( coords, verts[INT-j][i] );
+      CHECK_ERR(rval);
+  MBEntityHandle quads[INT][INT];
+  for (int j = 0; j < INT; ++j) {
+    for (int i = 0; i < INT; ++i) {
+      MBEntityHandle conn[4] = { verts[INT-j][i],
+                                 verts[INT-j][i+1],
+                                 verts[INT-j-1][i+1],
+                                 verts[INT-j-1][i] };
+      rval = mb.create_element( MBQUAD, conn, 4, quads[INT-j-1][i] );
+      CHECK_ERR(rval);
+  MBRange edges;
+  rval = mb.get_adjacencies( &quads[0][0], INT*INT, 1, true, edges, MBInterface::UNION );
+  CHECK_ERR(rval);
+  CHECK_EQUAL( 40, (int)edges.size() );
+    // group quads into two sets
+  MBEntityHandle sets[2];
+  rval = mb.create_meshset( MESHSET_SET, sets[0] ); CHECK_ERR(rval);
+  rval = mb.create_meshset( MESHSET_SET, sets[1] ); CHECK_ERR(rval);
+  rval = mb.add_entities( sets[0], quads[0], INT ); CHECK_ERR(rval);
+  rval = mb.add_entities( sets[1], quads[1], INT ); CHECK_ERR(rval);
+  rval = mb.add_entities( sets[0], quads[2], INT ); CHECK_ERR(rval);
+  rval = mb.add_entities( sets[1], quads[3], INT ); CHECK_ERR(rval);
+    // assign IDS
+  MBTag id_tag;
+  rval = mb.tag_create( ID_TAG_NAME, sizeof(int), MB_TAG_SPARSE, MB_TYPE_INTEGER, id_tag, 0 );
+  CHECK_ERR(rval);
+  int ids[2] = { 4, 5 };
+  rval = mb.tag_set_data( id_tag, sets, 2, ids );
+  CHECK_ERR(rval);
+    // write mesh
+  rval = mb.write_file( TEST_FILE, "MOAB" );
+  CHECK_ERR(rval);
+    // read first set back in
+  rval = mb.delete_mesh(); CHECK_ERR(rval);
+  MBEntityHandle file;
+  rval = mb.load_file( TEST_FILE, file, READ_OPTS, ID_TAG_NAME, ids, 1 );
+  CHECK_ERR(rval);
+    // check expected counts
+  int count;
+  rval = mb.get_number_entities_by_type( 0, MBVERTEX, count );
+  CHECK_ERR(rval);
+  CHECK_EQUAL( (INT+1)*INT, count );
+  rval = mb.get_number_entities_by_type( 0, MBQUAD, count );
+  CHECK_ERR(rval);
+  CHECK_EQUAL( INT*INT/2, count );
+  rval = mb.get_number_entities_by_type( 0, MBEDGE, count );
+  CHECK_ERR(rval);
+  CHECK_EQUAL( 2*(INT+1) + INT*INT, count );
+    // check edges adjacent to each quad
+  MBRange elems;
+  rval = mb.get_entities_by_type( 0, MBQUAD, elems );
+  CHECK_ERR(rval);
+  for (MBRange::iterator it = elems.begin(); it != elems.end(); ++it) {
+    edges.clear();
+    rval = mb.get_adjacencies( &*it, 1, 1, false, edges );
+    CHECK_ERR(rval);
+    CHECK_EQUAL( 4, (int)edges.size() );
