[MOAB-dev] r2860 - MOAB/trunk/mhdf/src
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Thu Apr 30 16:00:56 CDT 2009
Author: kraftche
Date: 2009-04-30 16:00:56 -0500 (Thu, 30 Apr 2009)
New Revision: 2860
Modified:
   MOAB/trunk/mhdf/src/file-desc.c
   MOAB/trunk/mhdf/src/sets.c
Log:
fix bugs
Modified: MOAB/trunk/mhdf/src/file-desc.c
--- MOAB/trunk/mhdf/src/file-desc.c	2009-04-28 22:36:42 UTC (rev 2859)
+++ MOAB/trunk/mhdf/src/file-desc.c	2009-04-30 21:00:56 UTC (rev 2860)
@@ -180,7 +180,8 @@
   void* ptr;
   int have_default, have_global;
-  int valsize, size;
+  int valsize, size, close_type = 0;
+  hsize_t array_len;
   ptr = realloc_data( &result, strlen(name)+1, status );
   if (NULL == ptr) return NULL;
@@ -226,7 +227,7 @@
       type = H5T_NATIVE_UCHAR;
       break;
     case mhdf_INTEGER:
-      type = H5T_INTEGER;
+      type = H5T_NATIVE_INT;
       have_default *= sizeof(int);
       have_global *= sizeof(int);
       valsize *= sizeof(int);
@@ -267,6 +268,7 @@
         mhdf_setFail( status, "Cannot create a bit tag larger than 64-bits.  %d bits requested.\n", (int)valsize);
         return NULL;
+      close_type = 1;
       break;
     case mhdf_ENTITY_ID:
       if (0 == type)
@@ -287,13 +289,27 @@
       return NULL;
   result->tags[index].bytes = valsize;
+  if (result->tags[index].type != mhdf_OPAQUE &&
+      result->tags[index].type != mhdf_BITFIELD &&
+      result->tags[index].size > 1) {
+    close_type = 1;
+    array_len = result->tags[index].size;
+    type = H5Tarray_create( type, 1, &array_len, 0 );
+    if (type < 0) {
+      mhdf_setFail( status, "H5Tarray_create failed for tag (\"%s\")", name );
+      free( result );
+      return NULL;
   if (have_default || have_global) {
     if (have_default) {
       ptr = realloc_data( &result, have_default, status );
       if (NULL == ptr) {
-        if (result->tags[index].type == mhdf_BITFIELD)
+        if (close_type) {
           H5Tclose( type );
         return NULL;
       result->tags[index].default_value = ptr;
@@ -301,8 +317,9 @@
     if (have_global) {
       ptr = realloc_data( &result, have_global, status );
       if (NULL == ptr) {
+        if (close_type) {
           H5Tclose( type );
         return NULL;
       result->tags[index].global_value = ptr;
@@ -313,8 +330,9 @@
                        result->tags[index].default_value,
                        result->tags[index].global_value,
                        status );
+    if (close_type) {
       H5Tclose( type );
     if (mhdf_isError(status)) {
       free( result );
       return NULL;
@@ -324,6 +342,14 @@
   return result;
+static void free_string_list( char** list, int count )
+  int i;
+  for (i = 0; i < count; ++i)
+    free( list[i] );
+  free( list );
 struct mhdf_FileDesc*
 mhdf_getFileSummary( mhdf_FileHandle file_handle,
                      hid_t file_id_type,
@@ -437,7 +463,7 @@
   ptr = realloc_data( &result, size, status );
   if (NULL == ptr) {
     free( elem_handles );
-    free( tag_names );
+    free_string_list( tag_names, result->num_tag_desc );
     return NULL;
   memset( ptr, 0, size );
@@ -448,7 +474,7 @@
     result = get_tag_desc( file_handle, result, tag_names[i], i, file_id_type, status );
     if (NULL == result) {
       return NULL;
@@ -459,7 +485,7 @@
   array = mhdf_malloc( size, status );
   if (NULL == array) {
     free( result );
     return NULL;
@@ -476,7 +502,7 @@
         matrix[i*result->num_tag_desc+j] = 1;
     /* Populate dense tag lists for element types */
   for (i = -2; i < result->num_elem_desc; ++i) {
Modified: MOAB/trunk/mhdf/src/sets.c
--- MOAB/trunk/mhdf/src/sets.c	2009-04-28 22:36:42 UTC (rev 2859)
+++ MOAB/trunk/mhdf/src/sets.c	2009-04-30 21:00:56 UTC (rev 2860)
@@ -493,7 +493,7 @@
     H5Sclose( slab_id );
       "Requested read of rows %ld to %ld of a %ld row table.\n",
-      offset, offset+count-1, (long)counts[dims-1]);
+      offset, offset+count-1, (long)counts[0]);
     return 0;
