[MOAB-dev] r2857 - in MOAB/trunk: . mhdf/src test/h5file
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Tue Apr 28 15:47:09 CDT 2009
Author: kraftche
Date: 2009-04-28 15:47:09 -0500 (Tue, 28 Apr 2009)
New Revision: 2857
Modified:
   MOAB/trunk/Makefile.am
   MOAB/trunk/README.IO
   MOAB/trunk/RangeMap.hpp
   MOAB/trunk/ReadHDF5.cpp
   MOAB/trunk/ReadHDF5.hpp
   MOAB/trunk/mhdf/src/file-desc.c
   MOAB/trunk/test/h5file/Makefile.am
   MOAB/trunk/test/h5file/h5file_test.cpp
Log:
install MBBSPTree.hpp
Modified: MOAB/trunk/Makefile.am
--- MOAB/trunk/Makefile.am	2009-04-24 18:28:14 UTC (rev 2856)
+++ MOAB/trunk/Makefile.am	2009-04-28 20:47:09 UTC (rev 2857)
@@ -135,7 +135,6 @@
   MBBits.cpp \
   MBBits.hpp \
   MBBSPTree.cpp \
-  MBBSPTree.hpp \
   MBCN.cpp \
   MBCNArrays.hpp \
   MBCartVect.cpp \
@@ -240,6 +239,7 @@
   HigherOrderFactory.hpp \
   HomXform.hpp \
   MBAdaptiveKDTree.hpp \
+  MBBSPTree.hpp \
   MBCN.hpp \
   MBCN_FCDefs.h \
   MBCN_protos.h \
Modified: MOAB/trunk/README.IO
--- MOAB/trunk/README.IO	2009-04-24 18:28:14 UTC (rev 2856)
+++ MOAB/trunk/README.IO	2009-04-28 20:47:09 UTC (rev 2857)
@@ -129,3 +129,30 @@
 Force byte ordering of binary data.  Default is BIG_ENDIAN for writing
 and autodetection for reading (BIG_ENDIAN if autodetect fails).
+MOAB Native (HDF5-based MHDF) format
+   ELEMENTS={EXPLICIT|NODES}
+If reading only part of a file, specify which additional elements to read
+in addition to those contained in the specified set.  The options are:
+   EXPLICIT    - read only explicitly designated elements
+   NODES       - read any element for which all the nodes are being read.
+Default is EXPLICIT unless only nodesa are explicitly specified, in which
+case NODES will be used.
+   CHILDREN={NONE|SETS|CONTENTS}
+If reading only part of a file, specify which whether or not child sets
+of input sets are to be read.  The options are:
+   NONE     - Do not read sets because they are children of designated sets.
+   SETS     - Read all child sets of designated input sets.
+   CONTENTS - (Default).  Read all child sets and any entities contained
+              in those sets.
+   BUFFER_SIZE=<BYTES>
+Reduce buffer size for debugging purposes.
Modified: MOAB/trunk/RangeMap.hpp
--- MOAB/trunk/RangeMap.hpp	2009-04-24 18:28:14 UTC (rev 2856)
+++ MOAB/trunk/RangeMap.hpp	2009-04-28 20:47:09 UTC (rev 2857)
@@ -44,6 +44,9 @@
   typedef typename std::vector<Range> RangeList;
   typedef typename RangeList::const_iterator iterator;
+  inline bool empty() const
+    { return data.empty(); }
   /**\brief Insert mapping between range of keys and range of values
    * Insert mapping from [first_key, first_key+count) to [first_val, first_val+count)
Modified: MOAB/trunk/ReadHDF5.cpp
--- MOAB/trunk/ReadHDF5.cpp	2009-04-24 18:28:14 UTC (rev 2856)
+++ MOAB/trunk/ReadHDF5.cpp	2009-04-28 20:47:09 UTC (rev 2857)
@@ -44,6 +44,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include <limits>
+#include <functional>
 #undef DEBUG
@@ -56,6 +57,27 @@
 #define READ_HDF5_BUFFER_SIZE (40*1024*1024)
+static void copy_sorted_file_ids( const MBEntityHandle* sorted_ids,
+                                  long num_ids,
+                                  MBRange& results )
+  MBRange::iterator hint = results.begin();
+  long i = 0;
+  while (i < num_ids) {
+    MBEntityHandle start = sorted_ids[i];
+    for (++i; i < num_ids && sorted_ids[i] == 1+sorted_ids[i-1]; ++i);
+    hint = results.insert( hint, start, sorted_ids[i-1] );
+static void intersect( const mhdf_EntDesc& group, const MBRange& range, MBRange& result )
+  MBRange::const_iterator s, e;
+  s = MBRange::lower_bound( range.begin(), range.end(), group.start_id );
+  e = MBRange::lower_bound( s, range.end(), group.start_id + group.count );
+  result.merge( s, e );
 MBReaderIface* ReadHDF5::factory( MBInterface* iface )
   { return new ReadHDF5( iface ); }
@@ -64,6 +86,7 @@
     dataBuffer( 0 ),
     iFace( iface ),
     filePtr( 0 ),
+    fileInfo( 0 ),
     readUtil( 0 ),
     handleType( 0 ),
     ioProp( H5P_DEFAULT )
@@ -99,12 +122,8 @@
   readUtil = reinterpret_cast<MBReadUtilIface*>(ptr);
-  setSet.first_id = 0;
-  setSet.type2 = mhdf_set_type_handle();
-  setSet.type = MBENTITYSET;
-  nodeSet.first_id = 0;
-  nodeSet.type2 = mhdf_node_type_handle();
-  nodeSet.type = MBVERTEX;
+  idMap.clear();
+  fileInfo = 0;
   return MB_SUCCESS;
@@ -123,17 +142,13 @@
                                  MBEntityHandle& file_set,
                                  const FileOptions& opts,
                                  const char* name,
-                                 const int*, const int )
+                                 const int* id_list,
+                                 const int num_ids )
   MBErrorCode rval;
   mhdf_Status status;
   ioProp = H5P_DEFAULT;
-  if (name) {
-    readUtil->report_error( "Reading subset of files not supported for HDF5." );
-    return MB_UNSUPPORTED_OPERATION;
   if (MB_SUCCESS != init())
     return MB_FAILURE;
@@ -157,6 +172,18 @@
 #endif
+  // This option is intended for testing purposes only, and thus
+  // is not documented anywhere.  Decreasing the buffer size can
+  // expose bugs that would otherwise only be seen when reading
+  // very large files.
+  rval = opts.get_int_option( "BUFFER_SIZE", bufferSize );
+  if (MB_SUCCESS != rval) {
+    bufferSize = READ_HDF5_BUFFER_SIZE;
+  else if (bufferSize < (int)std::max( sizeof(MBEntityHandle), sizeof(void*) )) {
+    return MB_INVALID_SIZE;
   dataBuffer = (char*)malloc( bufferSize );
   if (!dataBuffer)
     return MB_MEMORY_ALLOCATION_FAILED;
@@ -191,186 +218,488 @@
     iFace->delete_entities( &file_set, 1 );
     return MB_FAILURE;
-  rval = load_file_impl( file_set, use_mpio );
+    // get file info
+  fileInfo = mhdf_getFileSummary( filePtr, handleType, &status );
+  if (is_error(status)) {
+    free( dataBuffer );
+    if (ioProp != H5P_DEFAULT)
+      H5Pclose( ioProp );
+    mhdf_closeFile( filePtr, &status );
+    iFace->delete_entities( &file_set, 1 );
+    return MB_FAILURE;
+  if (name)
+    rval = load_file_partial( file_set, name, id_list, num_ids, opts );
+  else
+    rval = load_file_impl( file_set, opts );
   filePtr = 0;
     H5Pclose( ioProp );
-  if (mhdf_isError( &status )) {
-    if (MB_SUCCESS == rval)
-      rval = MB_FAILURE;
-    readUtil->report_error( mhdf_message( &status ));
+  if (MB_SUCCESS == rval && is_error(status))
+    rval = MB_FAILURE;
+  if (file_set && MB_SUCCESS == rval) {
+    DEBUGOUT("Creating entity set for file contents\n")
+    MBRange range;
+    MBRange::iterator hint = range.begin();
+    for (IDMap::iterator j = idMap.begin(); j != idMap.end(); ++j)
+      hint = range.insert( hint, j->value, j->value + j->count - 1);
+    rval = iFace->add_entities( file_set, range );
       // delete everything that was read in if read failed part-way through
-    iFace->delete_entities( &file_set, 1 );
-    file_set = 0;
-    iFace->delete_entities( setSet.range );
-    for (std::list<ElemSet>::reverse_iterator rel_itor = elemList.rbegin();
-         rel_itor != elemList.rend(); ++rel_itor)
-      iFace->delete_entities( rel_itor->range );
-    iFace->delete_entities( nodeSet.range );
+    MBRange range;
+    range.insert( file_set );
+    for (IDMap::iterator i = idMap.begin(); i != idMap.end(); ++i)
+      range.insert( i->value, i->value + i->count - 1 );
+    iFace->delete_entities( range );
-  elemList.clear();
-  nodeSet.range.clear();
-  setSet.range.clear();
   free( dataBuffer );
+  free( fileInfo );
   return rval;
-MBErrorCode ReadHDF5::load_file_impl(
-                                 MBEntityHandle file_set,
-                                 bool use_mpio )
+MBErrorCode ReadHDF5::load_file_impl( MBEntityHandle file_set, const FileOptions& opts )
   MBErrorCode rval;
   mhdf_Status status;
   std::string tagname;
-  int num_tags = 0;
-  char** tag_names = NULL;
-  char** groups = NULL;
-  std::list<ElemSet>::iterator el_itor;
-  unsigned int i, num_groups;
-  bool have_nodes = true;
+  int i;
 DEBUGOUT("Reading Nodes.\n");
-  rval = read_nodes();
-  if (MB_FILE_WRITE_ERROR == rval) {
-    DEBUGOUT("No nodes in file.!\n");
-    have_nodes = false;
+  MBRange ids;
+  if (fileInfo->nodes.count) {
+    ids.insert( fileInfo->nodes.start_id,
+                fileInfo->nodes.start_id + fileInfo->nodes.count - 1);
+    rval = read_nodes( ids );
+      return rval;
-  else if (MB_SUCCESS != rval)
-    return rval;
 DEBUGOUT("Reading element connectivity.\n");
-  groups = mhdf_getElemHandles( filePtr, &num_groups, &status );
-    return MB_FAILURE;
+  std::vector<int> polyhedra; // need to do these last so that faces are loaded
+  for (i = 0; i < fileInfo->num_elem_desc; ++i) {
+    if (MBCN::EntityTypeFromName(fileInfo->elems[i].type) == MBPOLYHEDRON) {
+      polyhedra.push_back(i);
+      continue;
+    rval = read_elems( i );
+      return rval;
+  for (std::vector<int>::iterator it = polyhedra.begin();
+       it != polyhedra.end(); ++it) {
+    rval = read_elems( *it );
+      return rval;
+DEBUGOUT("Reading sets.\n");
+  ids.clear();
+  if (fileInfo->sets.count) {
+    ids.insert( fileInfo->sets.start_id,
+                fileInfo->sets.start_id + fileInfo->sets.count - 1);
+    rval = read_sets( ids );
+    if (rval != MB_SUCCESS) {
+      return rval;
+DEBUGOUT("Reading adjacencies.\n");
-  for (i = 0; i < num_groups; ++i)
-    int poly = mhdf_isPolyElement( filePtr, groups[i], &status );
-      free(groups);
+    if (!fileInfo->elems[i].have_adj)
+      continue;
+    long table_len;
+    hid_t table = mhdf_openAdjacency( filePtr,
+                                      fileInfo->elems[i].handle,
+                                      &table_len,
+                                      &status );
       return MB_FAILURE;
-    if (poly)
-      rval = read_poly( groups[i] );
-    else
-      rval = read_elems( groups[i] );
-    if (MB_SUCCESS != rval) {
-      free( groups );
+    rval = read_adjacencies( table, table_len );
+    mhdf_closeData( filePtr, table, &status );
       return rval;
+DEBUGOUT("Reading tags.\n");
-DEBUGOUT("Reading sets.\n");
+  for (i = 0; i < fileInfo->num_tag_desc; ++i) {
+    rval = read_tag( i );
+      return rval;
-  rval = read_sets();
-  if (rval != MB_SUCCESS) {
-    free( groups );
+DEBUGOUT("Finishing read.\n");
+  rval = read_qa( file_set );
+  return rval;
+MBErrorCode ReadHDF5::load_file_partial( MBEntityHandle file_set,
+                                         const char* name,
+                                         int num_ids,
+                                         const FileOptions& opts )
+  mhdf_Status status;
+DEBUGOUT( "RETREIVING TAGGED ENTITIES" );
+  int tag_index;
+  for (tag_index = 0; tag_index < fileInfo->num_tag_desc; ++tag_index)
+    if (!strcmp( name, fileInfo->tags[tag_index].name))
+      break;
+  if (tag_index == fileInfo->num_tag_desc) {
+    readUtil->report_error( "File does not contain subset tag '%s'", name );
+    return MB_TAG_NOT_FOUND;
+  if (fileInfo->tags[tag_index].type != mhdf_INTEGER ||
+      fileInfo->tags[tag_index].size != 1) {
+    readUtil->report_error( "Tag '%s' does not containa single integer value", name );
+    return MB_TYPE_OUT_OF_RANGE;
+  MBErrorCode rval;
+  MBRange file_ids;
+  std::vector<int> ids( id_list, id_list+num_ids );
+  std::sort( ids.begin(), ids.end() );
+  rval = search_tag_values( tag_index, ids, file_ids );
     return rval;
-DEBUGOUT("Reading adjacencies.\n");
+DEBUGOUT( "GATHERING ADDITIONAL ENTITIES" );
-  rval = read_adjacencies( nodeSet );
-    free( groups );
+  int set_mode;
+  const char* const set_opts[] = { "NONE", "SETS", "CONTENTS" };
+  rval = opts.match_option( "CHILDREN", set_opts, set_mode );
+  if (MB_ENTITY_NOT_FOUND == rval)
+    set_mode = 2;
+  else if (MB_SUCCESS != rval) {
+    readUtil->report_error( "Invalid value for 'CHILDREN' option" );
     return rval;
-  for (el_itor = elemList.begin(); el_itor != elemList.end(); ++el_itor) {
-    rval = read_adjacencies( *el_itor );
-      free( groups );
+  MBRange sets;
+  intersect( fileInfo->sets, file_ids, sets );
+  if (set_mode == 2) {
+    rval = read_child_sets( sets );
       return rval;
+    // get elements and vertices contained in sets
+  rval = get_set_contents( sets, file_ids );
+    return rval;
-DEBUGOUT("Reading tags.\n");
+DEBUGOUT( "READING NODES" );
-  tag_names = mhdf_getTagNames( filePtr, &num_tags, &status );
-    free( groups );
+    // if input contained any polyhedra, need to get faces
+  for (int i = 0; i < fileInfo->num_elem_desc; ++i) {
+    MBEntityType type = MBCN::EntityTypeFromName( fileInfo->elems[i].type );
+    if (type != MBPOLYHEDRON)
+      continue;
+    MBRange polyhedra;
+    intersect( fileInfo->elems[i].desc, file_ids, polyhedra );
+    rval = read_elems( i, polyhedra, file_ids );
+      return rval;
-  for (int t = 0; t < num_tags; ++t)
-    rval = read_tag( tag_names[t] );
-    free( tag_names[t] );
-      for (; t < num_tags; ++t)
-      free( tag_names );
-      free( groups );
+    // get node file ids for all elements
+  MBRange nodes;
+  intersect( fileInfo->nodes, file_ids, nodes );
+    if (type <= MBVERTEX || type >= MBENTITYSET) {
+      assert( false ); // for debug code die for unknown element tyoes
+      continue; // for release code, skip unknown element types
+    if (MBPOLYHEDRON == type)
+      continue;
+    MBRange subset;
+    intersect( fileInfo->elems[i].desc, file_ids, subset );
+    rval = read_elems( i, subset, nodes );
+      return rval;
+    // Read node coordinates and create vertices in MOAB
+    // NOTE:  This populates the RangeMap with node file ids,
+    //        which is expected by read_node_adj_elems.
+  rval = read_nodes( nodes );
+    return rval;
-  free( groups );
-  if (file_set) {
-    DEBUGOUT("Creating entity set for file contents\n")
-    rval = iFace->add_entities( file_set, nodeSet.range );
+DEBUGOUT( "READING ELEMENTS" );
+    // decide if we need to read additional elements
+  int mode;
+  const char* const options[] = { "EXPLICIT", "ADJACENT", 0 };
+  rval = opts.match_option( "ELEMENTS", options, mode );
+  bool read_adjacent_elements;
+  if (MB_SUCCESS == rval) {
+    read_adjacent_elements = (mode == 1);
+  if (MB_ENTITY_NOT_FOUND == rval) {
+      // Chose default based on whether or not any elements have been
+      // specified.
+    MBRange tmp;
+    intersect( fileInfo->nodes, file_ids, tmp );
+    if (tmp.empty()) // can't do 'ADJACENT' mode if no nodes
+      read_adjacent_elements = false;
+    else {  // check if we have any elements, default to 'ADJACENT' only if no
+            // explicitly specified elements
+      tmp.merge( sets );
+      MBRange elems = file_ids.subtract( tmp );
+      read_adjacent_elements = elems.empty();
+  else {
+    readUtil->report_error( "Invalid value for 'ELEMENTS' option" );
+    return rval;
+  if (read_adjacent_elements) {
+    for (int dim = 1; dim <= 3; ++dim) {
+        if (MBCN::Dimension(type) == dim) {
+          rval = read_node_adj_elems( fileInfo->elems[i] );
+            return rval;
+  else {
+          MBRange subset;
+          rval = read_elems( fileInfo->elems[i],  subset );
+            return rval;
+DEBUGOUT( "READING SETS" );
+    // If reading child sets, but not all contents of child sets,
+    // need to get child sets after having read other entity types.
+  if (set_mode == 1) {
       return rval;
-      rval = iFace->add_entities( file_set, el_itor->range);
+    // Append file IDs of sets containing any of the nodes or elements
+    // we've read up to this point.
+  rval = find_sets_containing( sets );
+    return rval;
+    // Now actually read all set data and instantiate sets in MOAB.
+  rval = read_sets( sets );
+    return rval;
+DEBUGOUT( "READING ADJACENCIES" );
+    if (fileInfo->elems[i].have_adj &&
+        idMap.intersects( fileInfo->elems[i].desc.start_id, fileInfo->elems[i].desc.count )) {
+      long len;
+      hid_t th = mhdf_openAdjacency( filePtr, fileInfo->elems[i].handle, &len, &status );
+      rval = read_adjacencies( th, len );
+      mhdf_closeData( filePtr, th, &status );
         return rval;
-    rval = iFace->add_entities( file_set, setSet.range );
+DEBUGOUT( "READING TAGS" );
+  for (int i = 0; i < fileInfo->num_tag_desc; ++i) {
       return rval;
-DEBUGOUT("Finishing read.\n");
-  rval = read_qa( file_set );
-  return rval;
+  return MB_SUCCESS;
-MBErrorCode ReadHDF5::read_nodes()
+MBErrorCode ReadHDF5::search_tag_values( int tag_index,
+                                         const std::vector<int>& sorted_values,
+                                         MBRange& file_ids )
   MBErrorCode rval;
   mhdf_Status status;
-  long count, first_id;
-  int dim;
+  std::vector<long>::iterator iter;
+  const mhdf_TagDesc& tag = fileInfo->tags[tag_index];
+  long size;
+  long start_id;
+    // do dense data
+  hid_t table;
+  const char* name;
+  std::vector<long> indices;
+    // These are probably in order of dimension, so iterate
+    // in reverse order to make MBRange insertions more efficient.
+  std::vector<int> grp_indices( tag.dense_elem_indices, tag.dense_elem_indices+tag.num_dense_indices );
+  for (std::vector<int>::reverse_iterator i = grp_indices.rbegin(); i != grp_indices.rend(); ++i)
+    int idx = *i;
+    if (idx == -2) {
+      name = mhdf_set_type_handle();
+      start_id = fileInfo->sets.start_id;
+    else if (idx == -1) {
+      name = mhdf_node_type_handle();
+     start_id = fileInfo->nodes.start_id;
+    else {
+      if (idx < 0 || idx >= fileInfo->num_elem_desc)
+      name = fileInfo->elems[idx].handle;
+      start_id = fileInfo->elems[idx].desc.start_id;
+    table = mhdf_openDenseTagData( filePtr, tag.name, name, &size, &status );
+    rval = search_tag_values( table, size, sorted_values, indices );
+    if (MB_SUCCESS != rval || is_error(status))
+      // Convert from table indices to file IDs and add to result list
+    std::sort( indices.begin(), indices.end(), std::greater<long>() );
+    std::transform( indices.begin(), indices.end(), mb_range_inserter(file_ids),
+                    std::bind1st( std::plus<long>(), start_id ) );
+    indices.clear();
+  if (!tag.have_sparse)
+    // do sparse data
+  hid_t tables[2];
+  long junk; // redundant value for non-variable-length tags
+  mhdf_openSparseTagData( filePtr, tag.name, &size, &junk, tables, &status );
+  rval = search_tag_values( tables[1], size, sorted_values, indices );
+  mhdf_closeData( filePtr, tables[1], &status );
+  if (MB_SUCCESS != rval || is_error(status)) {
+    mhdf_closeData( filePtr, tables[0], &status );
+    // convert to ranges
+  std::sort( indices.begin(), indices.end() );
+  std::vector<long> ranges;
+  iter = indices.begin();
+  while (iter != indices.end()) {
+    ranges.push_back( *iter );
+    long last = *iter;
+    for (++iter; iter != indices.end() && (last + 1) == *iter; ++iter, ++last);
+    ranges.push_back( last );
+    // read file ids
+  iter = ranges.begin();
+  unsigned long offset = 0;
+  while (iter != ranges.end()) {
+    long begin = *iter; ++iter;
+    long end   = *iter; ++iter;
+    mhdf_readSparseTagEntities( tables[0], begin, end - begin + 1,
+                                H5T_NATIVE_LONG, &indices[offset], &status );
+    offset += end - begin + 1;
+  assert( offset == indices.size() );
+  copy_sorted_file_ids( (MBEntityHandle*)&indices[0], indices.size(), file_ids );
+MBErrorCode ReadHDF5::search_tag_values( hid_t tag_table,
+                                         unsigned long table_size,
+                                         std::vector<long>& value_indices )
+  size_t chunk_size = bufferSize / sizeof(unsigned);
+  unsigned * buffer = reinterpret_cast<unsigned*>(dataBuffer);
+  size_t remaining = table_size, offset = 0;
+  while (remaining) {
+      // Get a block of tag values
+    size_t count = std::min( chunk_size, remaining );
+    mhdf_readDenseTag( tag_table, offset, count, H5T_NATIVE_UINT, buffer, &status );
+      // search tag values
+    for (size_t i = 0; i < count; ++i)
+      if (std::binary_search( sorted_values.begin(), sorted_values.end(), buffer[i] ))
+        value_indices.push_back( i + offset );
+    offset += count;
+    remaining -= count;
+MBErrorCode ReadHDF5::read_nodes( const MBRange& node_file_ids )
+  MBErrorCode rval;
+  const int dim = fileInfo->nodes.vals_per_ent;
   MBRange range;
+  if (node_file_ids.empty())
   int cdim;
   rval = iFace->get_dimension( cdim );
     return rval;
-  hid_t data_id = mhdf_openNodeCoords( filePtr, &count, &dim, &first_id, &status );
-    //readUtil->report_error( mhdf_message( &status ));
-    // Failed because no node data in file?
-    nodeSet.first_id = std::numeric_limits<long>::max();
-    return MB_FILE_WRITE_ERROR;
   if (cdim < dim)
     rval = iFace->set_dimension( dim );
@@ -378,33 +707,45 @@
       return rval;
+  hid_t data_id = mhdf_openNodeCoordsSimple( filePtr, &status );
   MBEntityHandle handle;
   std::vector<double*> arrays(dim);
-  rval = readUtil->get_node_arrays( dim, (int)count, (int)first_id,
-                                    handle, arrays );
+  rval = readUtil->get_node_arrays( dim, (int)node_file_ids.size(), 0, handle, arrays );
     mhdf_closeData( filePtr, data_id, &status );
     return rval;
-  nodeSet.range.insert( handle, handle + count - 1 );
-  nodeSet.first_id = first_id;
-  for (int i = 0; i < dim; i++)
+    // read blocks of coordinates
+  MBRange::const_pair_iterator p;
+  for (p = node_file_ids.const_pair_begin(); p != node_file_ids.const_pair_end(); ++p)
-    mhdf_readNodeCoordWithOpt( data_id, 0, count, i, arrays[i], ioProp, &status );
-      readUtil->report_error( mhdf_message(&status) );
+    long count = p->second - p->first + 1;
+    long offset = p->first - fileInfo->nodes.start_id;
+    for (int i = 0; i < dim; ++i) {
+      mhdf_readNodeCoord( data_id, offset, count, i, arrays[i], &status );
+        mhdf_closeData( filePtr, data_id, &status );
+      arrays[i] += count;
+    for (int i = dim; i < cdim; ++i) {
+      memset( arrays[i], 0, count*sizeof(double) );
+    IDMap::iterator ins = idMap.insert( p->first, handle, count );
+    if (ins == idMap.end()) {
       return MB_FAILURE;
+    handle += count;
-  for (int j = dim; j < cdim; j++)
-    memset( arrays[j], 0, count * sizeof(double) );
@@ -416,95 +757,289 @@
   return MB_SUCCESS;
-MBErrorCode ReadHDF5::read_elems( const char* elem_group )
+MBErrorCode ReadHDF5::read_elems( int i )
+  MBRange ids;
+  ids.insert( fileInfo->elems[i].desc.start_id,
+              fileInfo->elems[i].desc.start_id + fileInfo->elems[i].desc.count - 1);
+  return read_elems( i, ids );
+MBErrorCode ReadHDF5::read_elems( int i, const MBRange& file_ids )
+  if (fileInfo->elems[i].desc.vals_per_ent < 0)
+    return read_poly( fileInfo->elems[i], file_ids );
+  else
+    return read_elems( fileInfo->elems[i], file_ids );
+MBErrorCode ReadHDF5::read_elems( const mhdf_ElemDesc& elems, const MBRange& file_ids )
   MBErrorCode rval;
   mhdf_Status status;
-  char name[64];
-    // Put elem set in list early so clean up code can
-    // get rid of them if we fail.
-  ElemSet empty_set;
-  empty_set.type2 = elem_group;
-  elemList.push_back( empty_set );
-  std::list<ElemSet>::iterator it = elemList.end();
-  --it;
-  ElemSet& elems = *it;
-  mhdf_getElemTypeName( filePtr, elem_group, name, sizeof(name), &status );
+  MBEntityType type = MBCN::EntityTypeFromName( elems.type );
+  if (type == MBMAXTYPE)
-    readUtil->report_error( mhdf_message( &status ) );
+    readUtil->report_error( "Unknown element type: \"%s\".\n", elems.type );
     return MB_FAILURE;
-  elems.type = MBCN::EntityTypeFromName( name );
-  if (elems.type == MBMAXTYPE)
-    readUtil->report_error( "Unknown element type: \"%s\".\n", name );
+  const int nodes_per_elem = elems.desc.vals_per_ent;
+  const long first_id = elems.desc.start_id;
+  hid_t data_id = mhdf_openConnectivitySimple( filePtr, elems.handle, &status );
     return MB_FAILURE;
+  for (p = file_ids.const_pair_begin(); p != file_ids.const_pair_end(); ++p) {
+    const long count = p->second - p->first + 1;
+    MBEntityHandle handle;
+    MBEntityHandle* array;
+    rval = readUtil->get_element_array( (int)count,
+                                         nodes_per_elem,
+                                         type,
+                                         0,
+                                         handle,
+                                         array );
+      break;
+      { rval = MB_FAILURE; break; }
+    mhdf_readConnectivityWithOpt( data_id, p->first - first_id, count, handleType, array, ioProp, &status );
+      break;
+    rval = convert_id_to_handle( array, (size_t)(nodes_per_elem*count) );
+      break;
+      // notify MOAB of the new elements
+    rval = readUtil->update_adjacencies(handle, count, nodes_per_elem, array);
+      break;
+  if (is_error(status) && MB_SUCCESS == rval)
+  return rval;
+MBErrorCode ReadHDF5::read_node_adj_elems( const mhdf_ElemDesc& group )
+  MBErrorCode rval;
-  int nodes_per_elem;
-  hid_t data_id = mhdf_openConnectivity( filePtr,
-                                         elem_group,
-                                         &nodes_per_elem,
-                                         &count,
-                                         &first_id,
-                                         &status );
+  hid_t table = mhdf_openConnectivitySimple( filePtr, group.handle, &status );
     return MB_FAILURE;
-  elems.first_id = first_id;
+  rval = read_node_adj_elems( group, table );
-  MBEntityHandle handle;
-  MBEntityHandle* array;
-  rval = readUtil->get_element_array( (int)count,
-                                       nodes_per_elem,
-                                       elems.type,
-                                      (int)first_id,
-                                       handle,
-                                       array );
-    mhdf_closeData( filePtr, data_id, &status );
-    return rval;
+    return rval = MB_FAILURE;
+  return rval;
+MBErrorCode ReadHDF5::read_node_adj_elems( const mhdf_ElemDesc& group,
+                                           hid_t table_handle )
+  MBErrorCode rval;
+    // copy data to local variables (makes other code clearer)
+  const int node_per_elem = group.desc.vals_per_ent;
+  long start_id = group.desc.start_id;
+  long remaining = group.desc.count;
+  const MBEntityType type = MBCN::EntityTypeFromName( group.type );
+    // figure out how many elements we can read in each pass
+  long* const buffer = reinterpret_cast<long*>( dataBuffer );
+  const long buffer_size = bufferSize / (node_per_elem * sizeof(buffer[0]));
+    // read all element connectivity in buffer_size blocks
+  long offset = 0;
+      // read a block of connectivity data
+    const long count = std::min( remaining, buffer_size );
+    mhdf_readConnectivity( table_handle, offset, count, H5T_NATIVE_LONG, buffer, &status );
+    offset += count;
+      // count the number of elements in the block that we want,
+      // zero connectivity for other elements
+    long num_elem = 0;
+    long* iter = buffer;
+    for (long i = 0; i < count; ++i) {
+      for (int j = 0; j < node_per_elem; ++j) {
+        iter[j] = (long)idMap.find( iter[j] );
+        if (!iter[j]) {
+          iter[0] = 0;
+          break;
+      if (iter[0])
+        ++num_elem;
+      iter += node_per_elem;
+    if (!num_elem) {
+      start_id += count;
+      continue;
+      // create elements
+    rval = readUtil->get_element_array( (int)num_elem,
+                                         node_per_elem,
+                                         type,
+                                         0,
+                                         handle,
+                                         array );
+      return rval;
+      // copy all non-zero connectivity values
+    iter = buffer;
+    MBEntityHandle* iter2 = array;
+    MBEntityHandle h = handle;
+      if (!*iter) {
+        continue;
+      IDMap::iterator ins = idMap.insert( start_id + i, h++, 1 );
+      long* const end = iter + node_per_elem;
+      for (; iter != end; ++iter, ++iter2)
+        *iter2 = (MBEntityHandle)*iter;
+    assert( iter2 - array == num_elem * node_per_elem );
-  elems.range.insert( handle, handle + count - 1 );
-  mhdf_readConnectivityWithOpt( data_id, 0, count, handleType, array, ioProp, &status );
+MBErrorCode ReadHDF5::read_elems( int i, const MBRange& elems_in, MBRange& nodes )
+  MBEntityHandle* const buffer = reinterpret_cast<MBEntityHandle*>(dataBuffer);
+  const size_t buffer_size = bufferSize / sizeof(MBEntityHandle);
+  int node_per_elem = fileInfo->elems[i].desc.vals_per_ent;
+  if (elems_in.empty())
+  assert( (long)elems_in.front() >= fileInfo->elems[i].desc.start_id );
+  assert( (long)elems_in.back() - fileInfo->elems[i].desc.start_id < fileInfo->elems[i].desc.count );
+    // we don't support version 3 style poly element data
+  if (fileInfo->elems[i].desc.vals_per_ent <= 0)
+  hid_t table = mhdf_openConnectivitySimple( filePtr, fileInfo->elems[i].handle, &status );
     return MB_FAILURE;
+  MBRange elements( elems_in );
+  while (!elements.empty()) {
+    MBEntityHandle file_id = elements.front();
+    long count = elements.const_pair_begin()->second - file_id + 1;
+    long offset = file_id - fileInfo->elems[i].desc.start_id;
+    if (count*node_per_elem > (long)buffer_size)
+      count = buffer_size/node_per_elem;
+    elements.erase( elements.begin(), elements.begin()+count );
+      // read element connectivity
+    mhdf_readConnectivity( table, offset, count, handleType, buffer, &status );
+    count *= node_per_elem;
+    std::sort( buffer, buffer + count );
+    count = std::unique( buffer, buffer + count ) - buffer;
+    copy_sorted_file_ids( buffer, count, nodes );
+  return is_error(status) ? MB_FAILURE : MB_SUCCESS;
+MBErrorCode ReadHDF5::read_poly( const mhdf_ElemDesc& elems, const MBRange& file_ids )
+  class PolyReader : public ContentReader {
+    private:
+      const MBEntityType type;
+      hid_t indexHandle, connHandle, handleType;
+      MBInterface *const mb;
+      IDMap& idMap;
+    public:
+    PolyReader( MBEntityType elem_type, hid_t idx, hid_t conn,
+                hid_t handle_type, MBInterface* iface, IDMap& id_map )
+               : type(elem_type), indexHandle(idx), connHandle(conn),
+                 handleType(handle_type), mb(iface), idMap(id_map)
+    void read_indices( long offset, long count, long* buffer, mhdf_Status& status )
+      { mhdf_readPolyConnIndices( indexHandle, offset, count, H5T_NATIVE_LONG, buffer, &status ); }
+    void read_contents( long offset, long count, MBEntityHandle* buffer, mhdf_Status& status )
+      { mhdf_readPolyConnIDs( connHandle, offset, count, handleType, buffer, &status ); }
+    MBErrorCode store_data( MBEntityHandle, long file_id, MBEntityHandle* conn, long len, bool )
+      size_t valid = len;
+      convert_id_to_handle( conn, valid, idMap );
+      MBErrorCode rval = mb->create_element( type, conn, len, handle );
+        return rval;
+      IDMap::iterator ins = idMap.insert( file_id, handle, 1 );
     return MB_FAILURE;
-  if (elems.type == MBPOLYHEDRON)
-    rval = convert_id_to_handle( array, (size_t)(nodes_per_elem*count) );
-  else
-    rval = convert_id_to_handle( nodeSet, array, (size_t)(nodes_per_elem*count) );
+  hid_t handles[2];
+  long num_poly, num_conn, first_id;
+  mhdf_openPolyConnectivity( filePtr, elems.handle, &num_poly, &num_conn, &first_id,
+                             handles, &status );
-  if (MB_SUCCESS != rval) return rval;
-    // notify MOAB of the new elements
-  MBErrorCode result = readUtil->update_adjacencies(handle, count,
-                                                    nodes_per_elem, array);
-  if (MB_SUCCESS != result) return result;
+  PolyReader tool( type, handles[0], handles[1], handleType, iFace, idMap );
+  MBRange empty;
+  MBErrorCode rval = read_contents( tool, file_ids, first_id, 0, num_poly, num_conn, empty );
+  mhdf_closeData( filePtr, handles[0], &status );
+  mhdf_closeData( filePtr, handles[1], &status );
   return rval;
 MBErrorCode ReadHDF5::read_poly( const char* elem_group )
   MBErrorCode rval;
@@ -560,8 +1095,7 @@
     rval= convert_id_to_handle( &connectivity[0], connectivity.size() );
       return rval;
@@ -596,512 +1130,751 @@
   return result;
-template <typename T>
-class auto_array {
-private:
-  T* data;
-public:
-  auto_array( size_t s ) : data(new T[s]) {}
-  auto_array()           : data(0)        {}
-  ~auto_array()                         { delete [] data; }
-  T*       get       ()                 { return data;    }
-  const T* get       ()           const { return data;    }
-  T&       operator[]( size_t i )       { return data[i]; }
-  const T& operator[]( size_t i ) const { return data[i]; }
-  T&       operator* ()                 { return *data;   }
-  const T* operator* ()           const { return *data;   }
-  T*       operator->()                 { return data;    }
-  const T* operator->()           const { return data;    }
-// auto_ptr-style destrutive assigment
-  auto_array( auto_array<T>& c ) {
-    data = c.data;
-    const_cast<auto_array<T>&>(c).data = 0;
+MBErrorCode ReadHDF5::read_sets( const MBRange& file_ids )
+  MBErrorCode rval;
+  if (fileInfo->sets.count == 0 || file_ids.empty()) {
+    assert(file_ids.empty());
-  auto_array<T>& operator=( auto_array<T>& c ) {
-    data = c.data;
+  hid_t meta_handle = mhdf_openSetMetaSimple( filePtr, &status );
-MBErrorCode ReadHDF5::read_set_contents( hid_t meta_id, hid_t data_id,
-                                         const unsigned long data_len )
-  MBErrorCode rval;
-  mhdf_Status status;
+    // create sets
+  MBRange ranged_set_ids;
+  MBEntityHandle start_handle;
+  rval = read_sets( file_ids, meta_handle, ranged_set_ids, start_handle );
+    mhdf_closeData( filePtr, meta_handle, &status );
+    return rval;
+    // read contents
+  if (fileInfo->have_set_contents) {
+    long len = 0;
+    hid_t handle = mhdf_openSetData( filePtr, &len, &status );
+    rval = read_contents( file_ids, start_handle, meta_handle, handle, len,
+                          ranged_set_ids );
+    mhdf_closeData( filePtr, handle, &status );
+      return rval;
-    // create extra buffers for storing end indices and flags
-  const unsigned long offset_size = bufferSize / sizeof(long);
-  auto_array<long> offsets(offset_size);
-  auto_array<unsigned short> flags(offset_size);
-  MBEntityHandle* buffer = (MBEntityHandle*)dataBuffer;
-  size_t chunk_size = bufferSize / sizeof(MBEntityHandle);
-  if (chunk_size % 2)
-    --chunk_size; // makes reading range data easier.
-  unsigned long set_offset = 0;  /* running offset into description table */
-  unsigned long sets_remaining = setSet.range.size();
-  unsigned long file_offset = 0; /* running offset into child table */
-  MBRange::const_iterator set_iter = setSet.range.begin();
-  while (sets_remaining) {
-      // read end indices from meta data
-    unsigned long set_count = sets_remaining < offset_size ? sets_remaining : offset_size;
-    mhdf_readSetContentEndIndicesWithOpt( meta_id, set_offset, set_count,
-                                   H5T_NATIVE_LONG, offsets.get(), ioProp, &status );
+    // read set child lists
+  if (fileInfo->have_set_children) {
+    long len = 0;
+    hid_t handle = mhdf_openSetChildren( filePtr, &len, &status );
       return MB_FAILURE;
-    mhdf_readSetFlagsWithOpt( meta_id, set_offset, set_count, H5T_NATIVE_USHORT,
-                       flags.get(), ioProp, &status );
+    rval = read_children( file_ids, start_handle, meta_handle, handle, len );
+      return rval;
+    // read set parent lists
+  if (fileInfo->have_set_parents) {
+    long len = 0;
+    hid_t handle = mhdf_openSetParents( filePtr, &len, &status );
       return MB_FAILURE;
-      // now iterate over sets, reading set content lists
-    unsigned long i, r = 0; // number of sets for which data has been read.
-    while (r < set_count) {
-        // figure out how many we can read at once
-      for (i = r; i < set_count; ++i)
-        if ((unsigned long)(offsets[i] + 1 - file_offset) > chunk_size)
-          break;
+    rval = read_parents( file_ids, start_handle, meta_handle, handle, len );
+      return rval;
-        // special case: set content list for single set greater than buffer
-      if (i == r) {
-           // Check if set contents are stored as ranges or a simple list
-        bool ranged = (0 != (flags[r] & (unsigned short)mhdf_SET_RANGE_BIT));
-        assert( set_iter != setSet.range.end() );
-        MBEntityHandle h = *set_iter; ++set_iter;
-        size_t remaining = offsets[r] + 1 - file_offset;
-        if (remaining > data_len - file_offset) {
-          readUtil->report_error( "Invalid set contents offset read from file." );
-        while (remaining)
-          size_t count = remaining > chunk_size ? chunk_size : remaining;
-          remaining -= count;
-          mhdf_readSetDataWithOpt( data_id, file_offset, count, handleType, buffer, ioProp, &status );
-          file_offset += count;
+MBErrorCode ReadHDF5::read_child_sets( MBRange& sets_in_out )
+  if (!fileInfo->have_set_children)
-            // convert data from file ids to MBEntityHandles and add to set
-          if (ranged)
-            if (count % 2 != 0) {
-              readUtil->report_error( "Invalid ranged set contents spec." );
-            MBRange range;
-            rval = convert_range_to_handle( buffer, count / 2, range );
-              readUtil->report_error( "Invalid entities in set contents" );
-              return rval;
-            rval = iFace->add_entities( h, range );
-              return rval;
-          else
-            rval = convert_id_to_handle( buffer, count );
-              return rval;
-            rval = iFace->add_entities( h, buffer, count );
-              return rval;
-        } // while(remaining)
-        ++r;
-      } // end special case (really big set)
-        // normal case - read data for several sets
-      else {
-          // read data for sets in [r,i)
-        size_t count = offsets[i-1] + 1 - file_offset;
-        if (count > data_len - file_offset) {
-          // add contents to each set
-        size_t mem_offset = 0;
-        for (; r < i; ++r) {
-          bool ranged = (0 != (flags[r] & (long)mhdf_SET_RANGE_BIT));
-          count = offsets[r] + 1 - file_offset;
+    // open data tables
+  if (fileInfo->sets.count == 0) {
+    assert( sets_in_out.empty() );
+  long child_len = 0;
+  hid_t child_handle = mhdf_openSetChildren( filePtr, &child_len, &status );
+  MBErrorCode rval = read_child_ids_recursive( sets_in_out, meta_handle, child_handle );
+  mhdf_closeData( filePtr, child_handle, &status );
+  return rval;
-          if (ranged)
-              readUtil->report_error( "Invalid ranged set contenst spec." );
-            MBRange range;
-            rval = convert_range_to_handle( buffer+mem_offset, count / 2, range );
-              return rval;
-              return rval;
-          else
-            rval = convert_id_to_handle( buffer+mem_offset, count );
-              return rval;
-            rval = iFace->add_entities( h, buffer+mem_offset, count );
-              return rval;
+MBErrorCode ReadHDF5::find_sets_containing( MBRange& sets_out )
+  MBErrorCode rval;
-          mem_offset += count;
-    } // while(r < num_sets)
+  if (!fileInfo->have_set_contents)
+  assert( fileInfo->sets.count );
+  long content_len = 0;
+  hid_t content_handle = mhdf_openSetData( filePtr, &content_len, &status );
+  rval = find_sets_containing( meta_handle, content_handle, content_len, sets_out );
+  mhdf_closeData( filePtr, content_handle, &status );
+  if(MB_SUCCESS == rval && is_error(status))
-    set_offset += set_count;
-    sets_remaining -= set_count;
-  } // while (sets_remaining)
+  return rval;
-  assert( set_iter == setSet.range.end() );
-  return MB_SUCCESS;
+static bool set_map_intersect( unsigned short flags,
+                               const long* contents,
+                               int content_len,
+                               const RangeMap<long,MBEntityHandle>& id_map  )
+  if (flags & mhdf_SET_RANGE_BIT) {
+    if (!content_len || id_map.empty())
+      return false;
+    const long* j = contents;
+    const long* const end = contents + content_len;
+    assert(content_len % 2 == 0);
+    while (j != end) {
+      long start = *(j++);
+      long count = *(j++);
+      if (id_map.intersects( start, count ))
+        return true;
+  else {
+    for (const long* i = contents; i != end; ++i)
+      if (id_map.exists( *i ))
+        return true;
+  return false;
-MBErrorCode ReadHDF5::read_parents_children( bool parents,
-                                             hid_t meta_id,
-                                             hid_t data_id,
+MBErrorCode ReadHDF5::find_sets_containing( hid_t meta_handle,
+                                            hid_t contents_handle,
+                                            long contents_len,
-  MBErrorCode rval;
+  const long avg_set_len = contents_len / fileInfo->sets.count;
+  long sets_per_buffer = bufferSize / (sizeof(short) + sizeof(long) * (2+avg_set_len));
+    // round to down multiple of 8 to avoid alignment issues
+  sets_per_buffer = 8 * (sets_per_buffer / 8);
+  if (sets_per_buffer < 10) // just in case there's one huge set
+    sets_per_buffer = 10;
+  unsigned short* flag_buffer = (unsigned short*)dataBuffer;
+  long* offset_buffer = (long*)(flag_buffer + sets_per_buffer);
+  long* content_buffer = offset_buffer + sets_per_buffer;
+  assert(bufferSize % sizeof(long) == 0);
+  long content_len = (long*)(dataBuffer + bufferSize) - content_buffer;
+  assert(dataBuffer + bufferSize >= (char*)(content_buffer + content_len));
+    // scan set table
   mhdf_Status status;
-  // create an extra buffer for storing offsets
-  auto_array<long> offsets( offset_size );
-  // use the existing buffer for storing set child lists
-  const size_t total_sets = setSet.range.size();
-    if (parents)
-      mhdf_readSetParentEndIndicesWithOpt( meta_id, set_offset, set_count,
-                                    ioProp, &status );
-    else
-      mhdf_readSetChildEndIndicesWithOpt(  meta_id, set_offset, set_count,
+  MBRange::iterator hint = file_ids.begin();
+  long remaining = fileInfo->sets.count;
+  long offset = 0;
+  long prev_idx = -1;
+    long count = std::min( remaining, sets_per_buffer );
+    mhdf_readSetFlags( meta_handle, offset, count, H5T_NATIVE_USHORT, flag_buffer, &status );
       return MB_FAILURE;
+    mhdf_readSetContentEndIndices( meta_handle, offset, count, H5T_NATIVE_LONG, offset_buffer, &status );
-      // now iterate over sets, reading parent/child lists
-          break;
-        // special case: children of one set greater than buffer
-      if (i == r) {
-          readUtil->report_error( "Invalid set %s offset read from file.",
-                                  parents ? "parent" : "child" );
-        while (remaining)
-          mhdf_readSetParentsChildrenWithOpt( data_id, file_offset, count, handleType,
-                                              buffer, ioProp, &status );
+    long sets_remaining = remaining;
+    long sets_offset = 0;
+    while (sets_remaining) {
+        // figure how many of the remaining sets are required to
+        // fill the set contents buffer.
+      long sets_count = std::lower_bound( offset_buffer + sets_offset,
+                          offset_buffer + count, content_len + prev_idx )
+                          - offset_buffer - sets_offset;
+      if (!sets_count) { // contents of single set don't fit in buffer
+        long content_remaining = offset_buffer[sets_offset] - prev_idx;
+        long content_offset = prev_idx+1;
+        while (content_remaining) {
+          long content_count = content_len < content_remaining ?
+                               2*(content_len/2) : content_remaining;
+          mhdf_readSetData( contents_handle, content_offset,
+                            content_count, H5T_NATIVE_LONG,
+                            content_buffer, &status );
             return MB_FAILURE;
+          if (set_map_intersect( flag_buffer[sets_offset],
+                                 content_buffer, content_count, idMap )) {
+            long id = fileInfo->sets.start_id + offset + sets_offset;
+            hint = file_ids.insert( hint, id, id );
+            break;
-            // convert from file_ids to set handles
-          for (size_t j = 0; j < count; ++j) {
-            buffer[j] -= setSet.first_id;
-            if (buffer[j] >= total_sets) {
-              readUtil->report_error("Invalid set %s ID", parents ? "parent" : "child" );
-            buffer[j] += setSet.range.front();
-          if (parents)
-            rval = iFace->add_parent_meshsets( h, buffer, count );
-          else
-            rval = iFace->add_child_meshsets( h, buffer, count );
-            return rval;
-        ++r;
+          content_remaining -= content_count;
+          content_offset += content_count;
+        prev_idx = offset_buffer[sets_offset];
+        sets_count = 1;
       else {
+        assert(sets_count > 0);
+        mhdf_readSetData( contents_handle, prev_idx+1,
+                         offset_buffer[sets_offset + sets_count - 1] - prev_idx,
+                         H5T_NATIVE_LONG, content_buffer, &status );
           return MB_FAILURE;
+        for (long i = 0; i < sets_count; prev_idx = offset_buffer[i++]) {
+          if (set_map_intersect( flag_buffer[sets_offset+i],
+                                 content_buffer + (1 + prev_idx),
+                                 offset_buffer[i] - prev_idx,
+                                 idMap )) {
+            long id = fileInfo->sets.start_id + offset + sets_offset + i;
-          // add children to each set
-          if (parents)
-            rval = iFace->add_parent_meshsets( h, buffer+mem_offset, count );
-          else
-            rval = iFace->add_child_meshsets(  h, buffer+mem_offset, count );
-            return rval;
+      sets_offset += sets_count;
+      sets_remaining -= sets_count;
+    offset += count;
   return MB_SUCCESS;
+MBErrorCode ReadHDF5::read_child_ids_recursive( MBRange& file_ids,
+                                                hid_t meta_handle,
+                                                hid_t child_handle )
+  MBErrorCode rval = MB_SUCCESS;
+  MBRange children, new_children(file_ids);
+  do {
+    children.clear();
+    rval = read_child_ids( new_children, meta_handle, child_handle, children );
+      break;
+    new_children = children.subtract( file_ids );
+    file_ids.merge( new_children );
+  } while (!new_children.empty());
+  return rval;
-MBErrorCode ReadHDF5::read_sets()
+MBErrorCode ReadHDF5::read_child_ids( const MBRange& input_file_ids,
+                                      hid_t child_handle,
+                                      MBRange& child_file_ids )
-  MBErrorCode rval;
   mhdf_Status status;
+  long* buffer = reinterpret_cast<long*>(dataBuffer);
+  long buffer_size = bufferSize / sizeof(long);
+  long first, range[2], count, remaining;
+  MBRange sets(input_file_ids);
+  MBRange::iterator hint;
+  while (!sets.empty()) {
+    first = (long)sets.front() - fileInfo->sets.start_id;
+    count = (long)sets.const_pair_begin()->second - first + 1;
+    sets.erase( sets.begin(), sets.begin() + count );
+    if (!first) {
+      range[0] = -1;
+      mhdf_readSetChildEndIndices( meta_handle, first+count-1, 1, H5T_NATIVE_LONG, range+1, &status );
+    else if (count == 1) {
+      mhdf_readSetChildEndIndices( meta_handle, first-1, 2, H5T_NATIVE_LONG, range, &status );
+    else {
+      mhdf_readSetChildEndIndices( meta_handle, first-1, 1, H5T_NATIVE_LONG, range+1, &status );
+    remaining = range[1] - range[0];
+    long offset = range[0] + 1;
+      count = std::min( buffer_size, remaining );
+      mhdf_readSetParentsChildren( child_handle, offset, count, H5T_NATIVE_LONG, buffer, &status );
-    // Check what data is in the file for sets
-  int have_sets, have_data, have_children, have_parents;
-  have_sets = mhdf_haveSets( filePtr, &have_data, &have_children, &have_parents, &status );
+      hint = child_file_ids.begin();
+        MBEntityHandle h = (MBEntityHandle)buffer[i];
+        hint = child_file_ids.insert( hint, h, h );
-  if (!have_sets)
+MBErrorCode ReadHDF5::read_sets( const MBRange& file_ids,
+                                 MBRange& ranged_file_ids,
+                                 MBEntityHandle& start_handle,
+                                 bool create )
+  MBErrorCode rval;
+  size_t count = file_ids.size();
+  if (!count)
     return MB_SUCCESS;
-    // Open the list of sets
-  long num_sets, first_id;
-  hid_t meta_id = mhdf_openSetMeta( filePtr, &num_sets, &first_id, &status );
-    // Initialize internal bookkeeping
-  setSet.first_id = first_id;
-  if (!num_sets) { // shouldn't happen if have_sets == true, but...
-    mhdf_closeData( filePtr, meta_id, &status );
+  std::vector<unsigned> tmp_buffer;
+  unsigned* buffer;
+  if (count > (bufferSize/sizeof(unsigned))) {
+    tmp_buffer.resize( count );
+    buffer = &tmp_buffer[0];
+  else {
+    buffer = reinterpret_cast<unsigned*>(dataBuffer);
-    // Get last used MeshSet handle
-  MBRange junk;
-  iFace->get_entities_by_type( 0, MBENTITYSET, junk );
-  MBEntityHandle start_handle = junk.empty() ? 1 : junk.back() + 1;
-  junk.clear();
-  bool first = true;
+  unsigned* buff_iter = buffer;
+    long offset = p->first - fileInfo->sets.start_id;
+    mhdf_readSetFlags( meta_handle, offset, count, H5T_NATIVE_UINT, buff_iter, &status );
+    offset += count;
+    buff_iter += count;
+  buff_iter = buffer;
+  MBRange::iterator hint = ranged_file_ids.begin();
+  for (MBRange::iterator i = file_ids.begin(); i != file_ids.end(); ++i, ++buff_iter) {
+    if ((*buff_iter) & mhdf_SET_RANGE_BIT) {
+      *buff_iter &= ~(unsigned)mhdf_SET_RANGE_BIT;
+      hint = ranged_file_ids.insert( hint, *i, *i );
-    // Iterate over set metadata, creating all the sets.
-    // Don't read any contents or parent/child links yet.
-    // Create all the sets first, so all the contents
-    // and parent/child links are valid.
-  size_t chunk_size = bufferSize / sizeof(unsigned);
-  unsigned * buffer = reinterpret_cast<unsigned*>(dataBuffer);
-  size_t remaining = num_sets, offset = 0;
-  MBRange::iterator insert_iter = setSet.range.begin();
-  while (remaining) {
-      // Get a block of set flags
-    mhdf_readSetFlagsWithOpt( meta_id, offset, count, H5T_NATIVE_UINT,
+  if (create) {
+    rval = readUtil->create_entity_sets( count, buffer, 0, start_handle );
+      return rval;
+    MBEntityHandle h = start_handle;
+      IDMap::iterator ins = idMap.insert( p->first, h, count );
+      h += count;
-    offset += count;
+MBErrorCode ReadHDF5::read_contents( ContentReader& tool,
+                                     const MBRange& file_ids,
+                                     const long start_id,
+                                     const MBEntityHandle start_handle,
+                                     const long entity_count,
+                                     const long content_len,
+                                     const MBRange& ranged_ids_in )
+  MBErrorCode rval;
+  if (file_ids.empty())
-      // clear ranged-storage bit.  Its internal data for the file
-      // format, not one of MOAB's set flags.
-    for (size_t i = 0;i < count; ++i)
-      buffer[i] &= ~(unsigned)mhdf_SET_RANGE_BIT;
-      // create block of sets
-    rval = readUtil->create_entity_sets( count,
-                                         buffer,
-                                         ID_FROM_HANDLE(start_handle),
-                                         handle );
-      return rval;
+    // things will get messed up if this isn't true
+  assert( ranged_ids_in.subtract( file_ids ).empty() );
+  assert( file_ids.front() >= (MBEntityHandle)start_id );
+  assert( file_ids.back() - start_id < (MBEntityHandle)entity_count );
+  const long avg_set_len = content_len / entity_count;
+  long sets_per_buffer = bufferSize / (sizeof(long) + (avg_set_len+1)*sizeof(MBEntityHandle));
+  long* offset_buffer = (long*)dataBuffer;
+  MBEntityHandle* content_buffer = (MBEntityHandle*)(offset_buffer + sets_per_buffer);
+  long content_size = (MBEntityHandle*)(dataBuffer + bufferSize) - content_buffer;
+  assert(dataBuffer + bufferSize >= (char*)(content_buffer + content_size));
+  MBRange ranged_ids(ranged_ids_in);
+  MBRange sets(file_ids), range;
+  long prev_start = start_id;
+  long prev_count = 0;
+    long start = sets.front();
+    long count = sets.const_pair_begin()->second - start + 1;
+    long file_id = start;
+    if (count >= sets_per_buffer)
+      count = sets_per_buffer - 1; // less one because we need the previous offset
+    if (start == start_id) {
+      offset_buffer[0] = -1;
+      tool.read_indices( 0, count, offset_buffer + 1, status );
-      // We are careful to request start IDs such that the
-      // resulting MBEntityHandles are always increasing.
-      // We are relying on increasing handles, so make sure
-      // that's what we get.
-    if (!first && handle < start_handle) {
-      readUtil->report_error( "Non-increasing handle space for mesh sets" );
+    else if (prev_start + prev_count == start) {
+      offset_buffer[0] = offset_buffer[prev_count];
+      tool.read_indices( start - start_id, count, offset_buffer + 1, status );
+    else {
+      tool.read_indices( start - start_id - 1, count+1, offset_buffer, status );
       return MB_FAILURE;
+    prev_start = start;
+    prev_count = count;
+      // read set contents
+    long remaining = count; //offset_buffer[count] - offset_buffer[0];
+    long offset = 0;
+        // Figure out how many set contents list we can fit in the
+        // buffer.
+      long read_count;
+      for (read_count = 1; read_count < remaining; ++read_count)
+        if (offset_buffer[read_count+offset+1] - offset_buffer[offset] >= content_size)
+          break;
+        // If no set contents list fit in the buffer, special case:
+        // iteratively read subsets of the content list.
+      if (read_count == 1) {
+        assert( 0 == content_size % 2 ); // otherwise problems with ranged data
+        long rem_contents = offset_buffer[offset+1] - offset_buffer[offset];
+        long set_offset = 0;
+        const bool ranged = !ranged_ids.empty() && ((long)ranged_ids.front() == start);
+        if (ranged)
+          ranged_ids.pop_front();
+        while (rem_contents) {
+          long content_count = std::min( content_size, rem_contents );
+          tool.read_contents( offset_buffer[offset]+1 + set_offset, content_count, content_buffer, status );
+          rval = tool.store_data( h, file_id, content_buffer, content_count, ranged );
+            return rval;
+          set_offset += content_count;
+          rem_contents -= content_count;
+        ++h;
+        ++file_id;
+        // Read contents for 'read_count' sets.
+      else {
+        tool.read_contents( offset_buffer[offset]+1,
+                            offset_buffer[read_count+offset] - offset_buffer[offset],
+                            content_buffer, status );
+        MBEntityHandle* content_iter = content_buffer;
+        for (long i = 0; i < read_count; ++i) {
+          long content_count = offset_buffer[i+1] - offset_buffer[i];
+          bool ranged = !ranged_ids.empty() && ((long)ranged_ids.front() == file_id);
+          rval = tool.store_data( h, file_id, content_iter, content_count, ranged );
+            return rval;
+          content_iter += content_count;
+          ++file_id;
+          ++h;
+          if (ranged)
+      remaining -= read_count;
+      offset += read_count;
-    first = false;
-    start_handle = handle + count;
-    insert_iter = setSet.range.insert( insert_iter, handle, handle + count - 1 );
-  assert( setSet.range.size() == (size_t)num_sets );
-  MBErrorCode result = MB_SUCCESS;
-  if (have_data) {
-    long data_len;
-    hid_t data_id = mhdf_openSetData( filePtr, &data_len, &status );
-    if (mhdf_isError(&status)) {
-      result = MB_FAILURE;
+MBErrorCode ReadHDF5::read_contents( const MBRange& set_file_ids,
+                                     MBEntityHandle start_handle,
+                                     hid_t set_meta_data_table,
+                                     hid_t set_contents_table,
+                                     long set_contents_length,
+                                     const MBRange& ranged_set_file_ids )
+  class ReadSetContents : public ReadHDF5::ContentReader {
+    const hid_t metaHandle, contentHandle, handleType;
+    const IDMap& idMap;
+  public:
+    ReadSetContents( hid_t meta, hid_t content, hid_t handle_type, MBInterface* iface,
+                    const IDMap& id_map )
+                    : metaHandle(meta), contentHandle(content),
+      { mhdf_readSetContentEndIndices( metaHandle, offset, count, H5T_NATIVE_LONG, buffer, &status ); }
+      { mhdf_readSetData( contentHandle, offset, count, handleType, buffer, &status ); }
+    MBErrorCode store_data( MBEntityHandle set, long, MBEntityHandle* array, long len, bool ranged )
+      if (ranged) {
+        assert(len % 2 == 0);
+        MBRange range;
+        convert_range_to_handle( array, len/2, idMap, range );
+        return mb->add_entities( set, range );
+      else {
+        assert(len >= 0);
+        convert_id_to_handle( array, valid, idMap );
+        return mb->add_entities( set, array, valid );
-    else {
-      rval = read_set_contents( meta_id, data_id, data_len );
-        result = rval;
+  ReadSetContents tool( set_meta_data_table, set_contents_table,
+                        handleType, iFace, idMap );
+  return read_contents( tool, set_file_ids, fileInfo->sets.start_id, start_handle,
+                        fileInfo->sets.count, set_contents_length, ranged_set_file_ids );
+MBErrorCode ReadHDF5::read_children( const MBRange& set_file_ids,
+                                     long set_contents_length )
+  class ReadSetChildren : public ReadHDF5::ContentReader {
+  public:
+    ReadSetChildren( hid_t meta, hid_t content, hid_t handle_type, MBInterface* iface,
+      { mhdf_readSetChildEndIndices( metaHandle, offset, count, H5T_NATIVE_LONG, buffer, &status ); }
+      { mhdf_readSetParentsChildren( contentHandle, offset, count, handleType, buffer, &status ); }
+      assert(!ranged);
+      return mb->add_child_meshsets( set, array, valid );
-  if (have_children) {
-    long data_len;
-    hid_t data_id = mhdf_openSetChildren( filePtr, &data_len, &status );
+  MBRange empty;
+  ReadSetChildren tool( set_meta_data_table, set_contents_table,
+                        fileInfo->sets.count, set_contents_length, empty );
+MBErrorCode ReadHDF5::read_parents( const MBRange& set_file_ids,
+  class ReadSetParents : public ReadHDF5::ContentReader {
+  public:
+    ReadSetParents( hid_t meta, hid_t content, hid_t handle_type, MBInterface* iface,
+      { mhdf_readSetParentEndIndices( metaHandle, offset, count, H5T_NATIVE_LONG, buffer, &status ); }
+      assert(!ranged);
+      return mb->add_parent_meshsets( set, array, valid );
-    else {
-      rval = read_parents_children( false, meta_id, data_id, data_len );
-        result = rval;
+  MBRange empty;
+  ReadSetParents tool( set_meta_data_table, set_contents_table,
+static void copy_set_contents( int ranged,
+                               const MBEntityHandle* contents,
+                               long length,
+  if (ranged) {
+    assert( length%2 == 0 );
+    for (long i = 0; i < length; i += 2)
+      hint = results.insert( hint, contents[i], contents[i] + contents[i+1] - 1 );
+  else {
+    for (long i = 0; i < length; ++i)
+      results.insert( contents[i] );
-  if (have_parents) {
-    long data_len;
-    hid_t data_id = mhdf_openSetParents( filePtr, &data_len, &status );
+MBErrorCode ReadHDF5::get_set_contents( const MBRange& sets, MBRange& file_ids )
+  class GetContentList : public ReadHDF5::ContentReader {
+    MBRange *const resultList;
+  public:
+    GetContentList( hid_t meta, hid_t content, hid_t handle_type, MBRange* result_set )
+                      handleType(handle_type), resultList(result_set)
+      if (ranged) {
+        copy_set_contents( 1, array, len, *resultList );
+      else {
+        std::sort( array, array+len );
+        copy_sorted_file_ids( array, len, *resultList );
-    else {
-      rval = read_parents_children( true, meta_id, data_id, data_len );
-        result = rval;
+  MBErrorCode rval;
+  if (sets.empty())
+  long content_len;
+  hid_t meta, contents;
+  meta = mhdf_openSetMetaSimple( filePtr, &status );
+  contents = mhdf_openSetData( filePtr, &content_len, &status );
+    mhdf_closeData( filePtr, meta, &status );
+  MBEntityHandle junk;
+  MBRange ranged;
+  rval = read_sets( sets, meta, ranged, junk, false );
+    mhdf_closeData( filePtr, contents, &status );
+    return rval;
-  return result;
+  GetContentList tool( meta, contents, handleType, &file_ids );
+  rval = read_contents( tool, sets, fileInfo->sets.start_id, junk,
+                        fileInfo->sets.count, content_len, ranged );
+  return rval;
-MBErrorCode ReadHDF5::read_adjacencies( ElemSet& elems )
+MBErrorCode ReadHDF5::read_adjacencies( hid_t adjacency_table, long table_len )
   MBErrorCode rval;
   mhdf_Status status;
   hid_t table;
   long data_len;
-  int adj = mhdf_haveAdjacency( filePtr, elems.type2, &status );
-  if (!adj)
-  table = mhdf_openAdjacency( filePtr, elems.type2, &data_len, &status );
   size_t remaining = data_len;
@@ -1109,57 +1882,42 @@
   size_t offset = 0;
   while (remaining)
     count -= leading;
     remaining -= count;
     mhdf_readAdjacencyWithOpt( table, offset, count, handleType, buffer + leading,
                                ioProp, &status );
-      mhdf_closeData( filePtr, table, &status );
       return MB_FAILURE;
     MBEntityHandle* iter = buffer;
     MBEntityHandle* end = buffer + count + leading;
     while (end - iter >= 3)
-      rval = convert_id_to_handle( elems, iter, 1 );
-      MBEntityHandle entity = *iter;
-      MBEntityHandle count = *++iter;
-      if (MB_SUCCESS != rval || count < 1)
-        assert(0);
-        return rval == MB_SUCCESS ? MB_FAILURE : rval;
+      MBEntityHandle h = idMap.find( *iter );
+      MBEntityHandle count2 = *++iter;
+      if (!h) {
+        iter += count2;
+        continue;
+      if (count2 < 1)
       ++iter;
-      if (end < count + iter)
+      if (end < count2 + iter)
         iter -= 2;
         break;
-      rval = convert_id_to_handle( iter, count );
+      convert_id_to_handle( iter, count2, idMap );
+      rval = iFace->add_adjacencies( h, iter, count2, false );
-        assert(0);
         return rval;
-      rval = iFace->add_adjacencies( entity, iter, count, false );
-        assert(0);
-        return rval;
-      iter += count;
+      iter += count2;
     leading = end - iter;
@@ -1169,201 +1927,245 @@
   assert(!leading);  // unexpected truncation of data
     return MB_FAILURE;
   return MB_SUCCESS;
-MBErrorCode ReadHDF5::read_tag( const char* name )
+MBErrorCode ReadHDF5::read_tag( int tag_index )
   MBErrorCode rval;
   mhdf_Status status;
-  std::string tag_type_name;
+  MBTag tag = 0;
+  hid_t read_type;
+  rval = create_tag( fileInfo->tags[tag_index], tag, read_type );
+    return rval;
+  if (fileInfo->tags[tag_index].have_sparse) {
+    hid_t handles[3];
+    long num_ent, num_val;
+                            fileInfo->tags[tag_index].name,
+                            &num_ent, &num_val,
+      if (read_type) H5Tclose( read_type );
+    if (fileInfo->tags[tag_index].size > 0)
+      rval = read_sparse_tag( tag, read_type, handles[0], handles[1], num_ent );
+    else
+      rval = read_var_len_tag( tag, read_type, handles[0], handles[1], handles[2], num_ent, num_val );
+    if (fileInfo->tags[tag_index].size <= 0) {
+      mhdf_closeData( filePtr, handles[2], &status );
+      return rval;
-  mhdf_TagDataType mhdf_type;  // Enum for tag data type
-  int tag_size;                // Size of tag
-  int mhdf_storage;            // TSTT storage type (dense vs. sparse)
-  int have_default;            // File contains default value for tag
-  int have_global;             // File contains global value for tag
-  int have_sparse;             // File contains sparse data table for tag
-  hid_t hdf_type = 0;          // Type to use when reading tag data.
-  int elem_size;               // Bytes required for one elem of array
-  int array_size;              // If tag is not opaque, the number of data per entity
-  MBTag handle;                // The handle for the tag
-  MBDataType mb_type;          // The MOAB data type for the data
+  for (int j = 0; j < fileInfo->tags[tag_index].num_dense_indices; ++j) {
+    long count;
+    const char* name = 0;
+    mhdf_EntDesc* desc;
+    int elem_idx = fileInfo->tags[tag_index].dense_elem_indices[j];
+    if (elem_idx == -2) {
+      desc = &fileInfo->sets;
+    else if (elem_idx == -1) {
+      desc = &fileInfo->nodes;
+    else if (elem_idx >= 0 && elem_idx < fileInfo->num_elem_desc) {
+      desc = &fileInfo->elems[elem_idx].desc;
+      name = fileInfo->elems[elem_idx].handle;
+    hid_t handle = mhdf_openDenseTagData( filePtr,
+                                          name,
+                                          &count, &status );
+      break;
+    if (count > desc->count) {
+      readUtil->report_error( "Invalid data length for dense tag data: %s/%s\n",
+                              name, fileInfo->tags[tag_index].name );
+      break;
+    rval = read_dense_tag( tag, read_type, handle, desc->start_id, count );
+      break;
+      break;
+  if (read_type)
+    H5Tclose( read_type );
+  return rval;
+MBErrorCode ReadHDF5::create_tag( const mhdf_TagDesc& info,
+                                  MBTag& handle,
+                                  hid_t& hdf_type )
+  MBErrorCode rval;
   MBTagType storage;
-    // Get description of tag
-  mhdf_getTagInfo( filePtr, name, &mhdf_type, &tag_size, &mhdf_storage,
-                   &have_default, &have_global, &have_sparse, &status );
-  switch (mhdf_storage) {
+  MBDataType mb_type;
+  bool re_read_default = false;
+  switch (info.storage) {
     case mhdf_DENSE_TYPE : storage = MB_TAG_DENSE ; break;
     case mhdf_SPARSE_TYPE: storage = MB_TAG_SPARSE; break;
     case mhdf_BIT_TYPE   : storage = MB_TAG_BIT;    break;
     case mhdf_MESH_TYPE  : storage = MB_TAG_MESH;   break;
     default:
-      readUtil->report_error( "Invalid storage type for tag '%s': %d\n", name, mhdf_storage );
+      readUtil->report_error( "Invalid storage type for tag '%s': %d\n", info.name, info.storage );
       return MB_FAILURE;
     // Type-specific stuff
-  switch (mhdf_type)
-    case mhdf_BITFIELD:
-      if (!tag_size || tag_size > 8)
-        readUtil->report_error( "Invalid bit tag:  class is MB_TAG_BIT, num bits = %d\n", tag_size );
-      elem_size = tag_size;
-      tag_size = 1;
-      array_size = 1;
-      hdf_type = H5T_NATIVE_B8;
-      mb_type = MB_TYPE_BIT;
-      break;
-    case mhdf_INTEGER:
-      elem_size = sizeof(int);
-      array_size = tag_size;
-      hdf_type = H5T_NATIVE_INT;
-      tag_size = elem_size * array_size;
-      mb_type = MB_TYPE_INTEGER;
-      break;
-    case mhdf_FLOAT:
-      elem_size = sizeof(double);
-      hdf_type = H5T_NATIVE_DOUBLE;
-      mb_type = MB_TYPE_DOUBLE;
-      break;
-    case mhdf_BOOLEAN:
-      hdf_type = H5T_NATIVE_UINT;
-      break;
-    case mhdf_ENTITY_ID:
-      elem_size = sizeof(MBEntityHandle);
-      hdf_type = handleType;
-      mb_type = MB_TYPE_HANDLE;
-      break;
-    case mhdf_OPAQUE:
-    default:
+  if (info.type == mhdf_BITFIELD) {
+    if (info.size < 1 || info.size > 8)
+      readUtil->report_error( "Invalid bit tag:  class is MB_TAG_BIT, num bits = %d\n", info.size );
+    hdf_type = H5Tcopy(H5T_NATIVE_B8);
+    mb_type = MB_TYPE_BIT;
+    if (hdf_type < 0)
+  else if (info.type == mhdf_OPAQUE) {
+    mb_type = MB_TYPE_OPAQUE;
-      if (tag_size < 0) { // variable-length
-        elem_size = 1;
-        array_size = -1;
-      else {
-        array_size = 1;
-      mb_type = MB_TYPE_OPAQUE;
-      hdf_type = (hid_t)0;
+      // Check for user-provided type
+    MBTag type_handle;
+    std::string tag_type_name = "__hdf5_tag_type_";
+    tag_type_name += info.name;
+    rval = iFace->tag_get_handle( tag_type_name.c_str(), type_handle );
+      rval = iFace->tag_get_data( type_handle, 0, 0, &hdf_type );
+        return rval;
+      hdf_type = H5Tcopy( hdf_type );
+      re_read_default = true;
+    else if (MB_TAG_NOT_FOUND == rval) {
+      hdf_type = 0;
+    else
+      return rval;
-        // Check for user-provided type
-      MBTag type_handle;
-      tag_type_name = "__hdf5_tag_type_";
-      tag_type_name += name;
-      rval = iFace->tag_get_handle( tag_type_name.c_str(), type_handle );
-        rval = iFace->tag_get_data( type_handle, 0, 0, &hdf_type );
-          elem_size = H5Tget_size( hdf_type );
-        else if (MB_TAG_NOT_FOUND != rval)
-          return rval;
-        return rval;
-      break;
+    if (hdf_type < 0)
-  if (tag_size < 0)  // variable length
-    tag_size = MB_VARIABLE_LENGTH;
+  else {
+    switch (info.type)
+      case mhdf_INTEGER:
+        hdf_type = H5T_NATIVE_INT;
+        mb_type = MB_TYPE_INTEGER;
+        break;
-    // Create array type from base type if array
-  if (array_size > 1)
-    hsize_t tmpsize = array_size;
+      case mhdf_FLOAT:
+        hdf_type = H5T_NATIVE_DOUBLE;
+        mb_type = MB_TYPE_DOUBLE;
+        break;
+      case mhdf_BOOLEAN:
+        hdf_type = H5T_NATIVE_UINT;
+        break;
+      case mhdf_ENTITY_ID:
+        hdf_type = handleType;
+        mb_type = MB_TYPE_HANDLE;
+        break;
+      default:
+    if (info.size > 1) { // array
+        hsize_t tmpsize = info.size;
 #if defined(H5Tarray_create_vers) && H5Tarray_create_vers > 1
-    hdf_type = H5Tarray_create2( hdf_type, 1, &tmpsize );
+        hdf_type = H5Tarray_create2( hdf_type, 1, &tmpsize );
 #else
-    hdf_type = H5Tarray_create( hdf_type, 1, &tmpsize, NULL );
+        hdf_type = H5Tarray_create( hdf_type, 1, &tmpsize, NULL );
 #endif
+    else {
     if (hdf_type < 0)
       return MB_FAILURE;
     // If default or global/mesh value in file, read it.
-  void *default_ptr = 0, *global_ptr = 0;
-  int default_size = 0, global_size = 0;
-  if (have_default || have_global)
+  if (info.default_value || info.global_value)
-    if (array_size == -1) { // variable-length tag
-      default_size = have_default;
-      global_size = have_global;
+    if (re_read_default) {
+      mhdf_getTagValues( filePtr, info.name, hdf_type, info.default_value, info.global_value, &status );
+      if (mhdf_isError( &status ))
+        readUtil->report_error( mhdf_message( &status ) );
+        if (hdf_type) H5Tclose( hdf_type );
-    else {
-      default_size = global_size = array_size;
-    assert( (default_size + global_size) * elem_size <= bufferSize );
-    default_ptr = dataBuffer;
-    global_ptr = dataBuffer + default_size*elem_size;
-    mhdf_getTagValues( filePtr, name, hdf_type, default_ptr, global_ptr, &status );
     if (MB_TYPE_HANDLE == mb_type) {
-      if (have_default) {
-        rval = convert_id_to_handle( (MBEntityHandle*)default_ptr, default_size );
-          have_default = 0;
+      if (info.default_value) {
+        rval = convert_id_to_handle( (MBEntityHandle*)info.default_value, info.default_value_size );
+          return rval;
-      if (have_global) {
-        rval = convert_id_to_handle( (MBEntityHandle*)global_ptr, global_size );
-          have_global = 0;
+      if (info.global_value) {
+        rval = convert_id_to_handle( (MBEntityHandle*)info.global_value, info.global_value_size );
+          return rval;
-  global_size *= elem_size;
-  default_size *= elem_size;
     // Check if tag already exists
-  rval = iFace->tag_get_handle( name, handle );
+  rval = iFace->tag_get_handle( info.name, handle );
     // If tag exists, make sure it is consistant with the type in the file
     int curr_size;
     MBDataType curr_type;
@@ -1372,250 +2174,169 @@
     rval = iFace->tag_get_size( handle, curr_size );
     if (MB_VARIABLE_DATA_LENGTH == rval)
       curr_size = -1;
       return rval;
     rval = iFace->tag_get_data_type( handle, curr_type );
       return rval;
     rval = iFace->tag_get_type( handle, curr_store );
       return rval;
-    if ((curr_store != MB_TAG_BIT && curr_size != tag_size) || curr_type != mb_type ||
+    if ((curr_store != MB_TAG_BIT && curr_size != info.bytes) || curr_type != mb_type ||
         ((curr_store == MB_TAG_BIT || storage == MB_TAG_BIT) &&
           curr_store != storage))
       readUtil->report_error( "Tag type in file does not match type in "
-                              "database for \"%s\"\n", name );
+                              "database for \"%s\"\n", info.name );
       return MB_FAILURE;
     // Create the tag if it doesn't exist
-    if (tag_size == MB_VARIABLE_LENGTH)
-      rval = iFace->tag_create_variable_length( name, storage, mb_type,
-                                                handle, default_ptr, default_size );
+    if (info.size < 0) {
+      size_t size = hdf_type ? H5Tget_size(hdf_type) : 1;
+      rval = iFace->tag_create_variable_length( info.name, storage, mb_type,
+                                                handle, info.default_value,
+                                                info.default_value_size * size );
     else
-      rval = iFace->tag_create( name, tag_size, storage, mb_type,
-                                handle, default_ptr );
+      rval = iFace->tag_create( info.name, info.bytes, storage, mb_type,
+                                handle, info.default_value );
       return rval;
     // error
-  else
+  else {
     return rval;
-    rval = iFace->tag_set_data( handle, 0, 0, &global_ptr, &global_size );
+    int type_size = hdf_type ? H5Tget_size(hdf_type) : 1;
+    int tag_size = info.global_value_size * type_size;
+    rval = iFace->tag_set_data( handle, 0, 0, &info.global_value, &tag_size );
       return rval;
-    // Read tag data
-  MBErrorCode tmp = MB_SUCCESS;
-  if (have_sparse) {
-      tmp = read_var_len_tag( handle, hdf_type, mb_type == MB_TYPE_HANDLE );
-    else
-      tmp = read_sparse_tag( handle, hdf_type, tag_size, mb_type == MB_TYPE_HANDLE );
-  rval = read_dense_tag( handle, hdf_type, tag_size, mb_type == MB_TYPE_HANDLE );
-    // If an array type, need to release the type object created above.
-    H5Tclose( hdf_type );
-  return MB_SUCCESS == tmp ? rval : tmp;
 MBErrorCode ReadHDF5::read_dense_tag( MBTag tag_handle,
                                       hid_t hdf_read_type,
-                                      size_t read_size,
-                                      bool is_handle_type )
+                                      hid_t data,
+                                      long start_id,
+                                      long num_values )
-  std::list<ElemSet>::iterator iter;
-  const std::list<ElemSet>::iterator end = elemList.end();
   mhdf_Status status;
-  std::string name;
   MBErrorCode rval;
-  int have;
-  rval = iFace->tag_get_name( tag_handle, name );
+  rval = iFace->tag_get_data_type( tag_handle, mb_type );
+  if (MB_SUCCESS != rval)
     return rval;
-  have = mhdf_haveDenseTag( filePtr, name.c_str(), nodeSet.type2, &status );
+  hsize_t read_size = 0;
+  if (mb_type == MB_TYPE_HANDLE) {
+    read_size = H5Tget_size( hdf_read_type );
+    if (!read_size)
+      return MB_FAILURE;
-  if (have)
-    rval = read_dense_tag( nodeSet, tag_handle, hdf_read_type, read_size, is_handle_type );
-    if (!rval)
-      return rval;
-  have = mhdf_haveDenseTag( filePtr, name.c_str(), setSet.type2, &status );
-  if (mhdf_isError( &status ))
-  if (have)
-    rval = read_dense_tag( setSet, tag_handle, hdf_read_type, read_size, is_handle_type );
-    if (!rval)
-      return rval;
-  for (iter = elemList.begin(); iter != end; ++iter)
-    have = mhdf_haveDenseTag( filePtr, name.c_str(), iter->type2, &status );
+    // get actual entities read from file
+  MBRange file_ids;
+  IDMap::iterator l, u;
+  l = idMap.lower_bound( start_id );
+  u = idMap.lower_bound( start_id + num_values - 1 );
+  if (l != idMap.end() && start_id + num_values > l->begin) {
+    if (l == u) {
+      file_ids.insert( std::max(start_id, l->begin),
+                       std::min(start_id + num_values, u->begin + u->count) - 1 );
-    if (have)
-      rval = read_dense_tag( *iter, tag_handle, hdf_read_type, read_size, is_handle_type );
-      if (!rval)
-        return rval;
+    else {
+      file_ids.insert( std::max(start_id, l->begin), l->begin + l->count - 1 );
+      if (u != idMap.end() && u->begin < start_id + num_values)
+        file_ids.insert( u->begin, std::min( start_id + num_values, u->begin + u->count) - 1 );
+      for (++l; l != u; ++l)
+        file_ids.insert( l->begin, l->begin + l->count - 1 );
-MBErrorCode ReadHDF5::read_dense_tag( ElemSet& set,
-                                      MBTag tag_handle,
-                                      hid_t hdf_read_type,
-                                      size_t read_size,
-  std::string name;
-  MBErrorCode rval;
-  long num_values;
-    return rval;
-  hid_t data = mhdf_openDenseTagData( filePtr, name.c_str(),
-                                      set.type2, &num_values, &status );
-  if (mhdf_isError( &status ) )
-  if ((unsigned long)num_values != set.range.size())
-    assert( 0 );
-  MBRange::const_iterator iter = set.range.begin();
-  MBRange subrange;
-  assert ((hdf_read_type == 0) || (H5Tget_size(hdf_read_type) == read_size));
-  size_t chunk_size = bufferSize / read_size;
-  size_t remaining = set.range.size();
-  size_t offset = 0;
-  while (remaining)
+  long buffer_size = bufferSize / read_size;
+  while (!file_ids.empty()) {
+    long first = file_ids.front();
+    long count = file_ids.const_pair_begin()->second - first + 1;
+    if (buffer_size < count)
+      count = buffer_size;
+    file_ids.erase( file_ids.begin(), file_ids.begin() + (count - 1) );
-    MBRange::const_iterator stop = iter;
-    stop += count;
-    subrange.clear();
-    subrange.merge( iter, stop );
-    iter = stop;
-    mhdf_readDenseTagWithOpt( data, offset, count, hdf_read_type, dataBuffer,
-    offset += count;
-      mhdf_closeData( filePtr, data, &status );
+    mhdf_readDenseTagWithOpt( data, first - start_id, count, hdf_read_type,
+                              dataBuffer, ioProp, &status );
+    if (is_error(status))
       return MB_FAILURE;
-    if (is_handle_type)
+    if (MB_TYPE_HANDLE == mb_type) {
       rval = convert_id_to_handle( (MBEntityHandle*)dataBuffer, count * read_size / sizeof(MBEntityHandle) );
         return rval;
-    rval = iFace->tag_set_data( tag_handle, subrange, dataBuffer );
+    MBRange ents;
+    ents.insert( idMap.find( first ), idMap.find( first + count - 1 ) );
+    rval = iFace->tag_set_data( tag_handle, ents, dataBuffer );
       return MB_FAILURE;
-    return MB_FAILURE;
   return MB_SUCCESS;
 MBErrorCode ReadHDF5::read_sparse_tag( MBTag tag_handle,
-                                       size_t read_size,
+                                       hid_t id_table,
+                                       hid_t value_table,
+                                       long num_values )
   mhdf_Status status;
-  std::string name;
   MBErrorCode rval;
-  long num_values, data_size;
-  hid_t data[3];
-  MBTagType mbtype;
+  MBDataType mbtype;
+  rval = iFace->tag_get_data_type( tag_handle, mbtype );
     return rval;
-  rval = iFace->tag_get_type( tag_handle, mbtype );
+  int read_size;
+  rval = iFace->tag_get_size( tag_handle, read_size );
+  if (MB_SUCCESS != rval) // wrong function for variable-length tags
     return rval;
-  mhdf_openSparseTagData( filePtr, name.c_str(), &num_values, &data_size, data, &status );
+  if (MB_TYPE_BIT == mbtype)
+    read_size = (read_size + 7)/8; // convert bits to bytes, plus 7 for ceiling
+  if (hdf_read_type) { // if not opaque
+    hsize_t hdf_size = H5Tget_size( hdf_read_type );
+    if (hdf_size != (hsize_t)read_size)
-    // fixed-length tag
-  assert( num_values == data_size );
+  const int handles_per_tag = read_size/sizeof(MBEntityHandle);
     // Split buffer into two portions: one for handles and one for data.
     // We want to read the same number of handles as data values for each
@@ -1623,7 +2344,7 @@
     // pass as the size of the buffer over the sum of the size of a handle
     // and value.  Subtract off the size of one value so we reserve space
     // for adjusting for data alignment.
-  size_t chunk_size = (bufferSize - read_size) / (sizeof(MBEntityHandle) + read_size);
+  long chunk_size = (bufferSize - read_size) / (sizeof(MBEntityHandle) + read_size);
     // Use the first half of the buffer for the handles.
   MBEntityHandle* idbuf = (MBEntityHandle*)dataBuffer;
@@ -1635,80 +2356,99 @@
       // Make sure the above calculations are correct
   assert( databuf + chunk_size*read_size < dataBuffer + bufferSize );
-  size_t remaining = (size_t)num_values;
+  long remaining = num_values;
+  long offset = 0;
   while (remaining)
+    long count = std::min( chunk_size, remaining );
+    long next_offset = offset + count;
     remaining -= count;
-    mhdf_readSparseTagEntitiesWithOpt( data[0], offset, count, handleType, idbuf,
+    mhdf_readSparseTagEntitiesWithOpt( id_table, offset, count, handleType, idbuf,
                                        ioProp, &status );
-      mhdf_closeData( filePtr, data[0], &status );
-      mhdf_closeData( filePtr, data[1], &status );
       return MB_FAILURE;
-    mhdf_readSparseTagValuesWithOpt( data[1], offset, count, hdf_read_type,
-                                     databuf, ioProp, &status );
-    offset += count;
     rval = convert_id_to_handle( idbuf, count );
-      return rval;
-      rval = convert_id_to_handle( (MBEntityHandle*)databuf, count * read_size / sizeof(MBEntityHandle) );
+     return rval;
+      // Find contiguous blocks of values to read.
+      // (convert_id_to_handle will return zero-valued handles for entities
+      //  not read from the file--i.e. values to skip).
+    long i = 0, j;
+    for (;;) {
+        // skip initial zeros
+      while (i < count && 0 == idbuf[i])
+        ++i;
+        // if no more, stop
+      if (i == count)
+        break;
+        // advance to end of range of non-zero handles
+      j = i +1;
+      while (j < count && 0 != idbuf[j])
+        ++j;
+        // if we've reached the end and the chunk is fairly small,
+        // shift to the front of the buffer and read more to avoid
+        // small data reads when blocks get split due to the buffer
+        // size
+      if (j == count && 2*i >= count && remaining > count) {
+        long keep = j - i;
+        memmove( idbuf, idbuf + i, sizeof(MBEntityHandle)*keep );
+        long count2 = std::min( remaining - keep, count - keep );
+        mhdf_readSparseTagEntitiesWithOpt( id_table, next_offset, count2, handleType,
+                                           idbuf+keep, ioProp, &status );
+        offset += i;
+        next_offset += count2;
+        remaining -= count2;
+        i = 0;
+        rval = convert_id_to_handle( idbuf + keep, count2 );
+         return rval;
+        j = keep;
+          ++j;
+        // read tag values
+      mhdf_readSparseTagValuesWithOpt( value_table, offset + i, j - i,
+                                       hdf_read_type, databuf + i*read_size,
+                                       ioProp, &status );
+      if (MB_TYPE_HANDLE == mbtype) {
+        rval = convert_id_to_handle( (MBEntityHandle*)databuf + i*handles_per_tag,
+                                     (j-i) * handles_per_tag );
+          return rval;
+/*** FIX ME - need to do one at a time for BIT tags!  This is stupid. ***/
+      if (mbtype == MB_TYPE_BIT)
+        rval = MB_SUCCESS;
+        for ( ; MB_SUCCESS == rval && i < j; ++i)
+          rval = iFace->tag_set_data( tag_handle, idbuf + i, 1, databuf + i );
+      else
+        rval = iFace->tag_set_data( tag_handle, idbuf + i, j - i, databuf + i*read_size );
+        i = j;
         return rval;
-/*** FIX ME - need to do one at a time for BIT tags!  This is stupid. ***/
-    if (mbtype == MB_TAG_BIT)
-      rval = MB_SUCCESS;
-      for (size_t i = 0; MB_SUCCESS == rval && i < count; ++i)
-        rval = iFace->tag_set_data( tag_handle, idbuf + i, 1, databuf + i );
-    else
-      rval = iFace->tag_set_data( tag_handle, idbuf, count, databuf );
-      return rval;
+    } // for(ever)
+    offset = next_offset;
+  } // while(remaining)
   return MB_SUCCESS;
@@ -1717,50 +2457,58 @@
 MBErrorCode ReadHDF5::read_var_len_tag( MBTag tag_handle,
+                                        hid_t ent_table,
+                                        hid_t val_table,
+                                        hid_t off_table,
+                                        long num_entities,
+                                        long num_values )
+  std::vector<char> tmp_buffer;
   mhdf_Status status;
-  std::string name;
   MBErrorCode rval;
-  long num_values, num_data;
-  hid_t data[3];
-  MBTagType mbtype;
-    // hdf_read_type is NULL (zero) for opaque tag data.
-  long elem_size = hdf_read_type ? H5Tget_size( hdf_read_type ) : 1;
-  if (elem_size < 1) // invalid type handle?
     return rval;
+    // can't do variable-length bit tags
+    return MB_VARIABLE_DATA_LENGTH;
+    // if here, MOAB tag must be variable-length
+  int mbsize;
+  if (MB_VARIABLE_DATA_LENGTH != iFace->tag_get_size( tag_handle, mbsize )) {
+    assert(false);
-    return rval;
+  int read_size;
+    if (hdf_size < 1)
+    read_size = hdf_size;
+  else {
+    // opaque
+    read_size = 1;
-  mhdf_openSparseTagData( filePtr, name.c_str(), &num_values, &num_data, data, &status );
-    // Subdivide buffer into 5 chunks:
+    // Subdivide buffer into 4 chunks:
     // Be careful of order so alignment is valid
-    // 1) pointer array (input for MOAB)
-    // 2) offset array (read from file)
-    // 3) entity handles
-    // 4) tag sizes (calculated from file data)
-    // 5) tag data
-  const size_t avg_data_size = (num_data * elem_size) / num_values;
-  const size_t per_ent_size = sizeof(void*) + sizeof(long) + sizeof(MBEntityHandle) + sizeof(int);
-  long num_ent = bufferSize / (per_ent_size + 2*avg_data_size);
+    // 1) pointer array (input for MOAB) / offset array (read from file)
+    // 2) entity handles (read as file IDs and converted to handles)
+    // 3) tag sizes (calculated from file data)
+    // 4) tag data
+  const long avg_data_size = (num_values * read_size) / num_entities;
+  const long per_ent_size = sizeof(long) + sizeof(MBEntityHandle) + sizeof(int);
+  long num_ent = bufferSize / (per_ent_size + avg_data_size + avg_data_size/2);
   if (num_ent == 0)
     num_ent = bufferSize / 4 / sizeof(void*);
-  const size_t data_buffer_size = (bufferSize - num_ent * per_ent_size) / elem_size;
-  const void** const pointer_buffer = reinterpret_cast<const void**>(dataBuffer);
-  long* const end_idx_buffer = reinterpret_cast<long*>(pointer_buffer + num_ent);
-  char* handle_buffer_start = reinterpret_cast<char*>(end_idx_buffer + num_ent);
+  const long data_buffer_size = (bufferSize - num_ent * per_ent_size) / read_size;
+  long* const end_idx_buffer = reinterpret_cast<long*>(dataBuffer);
+  char* handle_buffer_start = reinterpret_cast<char*>(end_idx_buffer + num_ent+1);
   if (((size_t)handle_buffer_start) % sizeof(MBEntityHandle))
     handle_buffer_start += sizeof(MBEntityHandle) - ((size_t)handle_buffer_start);
   MBEntityHandle* const handle_buffer = reinterpret_cast<MBEntityHandle*>(handle_buffer_start);
@@ -1769,312 +2517,205 @@
     // do num_ent blocks of entities
-  long remaining = num_values;
+  long remaining = num_entities;
   long offset = 0;
-  long data_offset = 0;
+  long prev_end_idx = -1;
+  long prev_end = 0;
   while (remaining) {
-    const long count = remaining < num_ent ? remaining : num_ent;
+    const long count = std::min( remaining, num_ent );
     remaining -= count;
       // read entity IDs
     assert_range( handle_buffer, count * sizeof(MBEntityHandle) );
+    mhdf_readSparseTagEntitiesWithOpt( ent_table, offset, count, handleType,
                                        handle_buffer, ioProp, &status );
-      mhdf_closeData( filePtr, data[2], &status );
       return MB_FAILURE;
       // convert entity ID to MBEntityHandle
     rval = convert_id_to_handle( handle_buffer, count );
       return rval;
-      // read end index of tag value
-    assert_range( end_idx_buffer, count * sizeof(long) );
-    mhdf_readSparseTagIndicesWithOpt( data[2], offset, count, H5T_NATIVE_LONG,
-                                      end_idx_buffer, ioProp, &status );
-      // update entity offset
-    offset += count;
-    char* pointer = data_buffer;
-    long finished = 0;
-    while (finished < count) {
+      //  not read from the file--i.e. tag values to skip).
+    long i = 0, j;
+    for (;;) {
+      while (i < count && 0 == handle_buffer[i])
+        ++i;
+      if (i == count)
+        break;
+      j = i +1;
+      while (j < count && 0 != handle_buffer[j])
+        ++j;
+        // size
+        memmove( handle_buffer, handle_buffer + i, sizeof(MBEntityHandle)*keep );
+          // read more entity IDs
+        mhdf_readSparseTagEntitiesWithOpt( ent_table, next_offset, count2, handleType,
+                                           handle_buffer+i, ioProp, &status );
+        offset += i;
+        i = 0;
+        rval = convert_id_to_handle( handle_buffer + keep, count2 );
+         return rval;
-        // iterate over entities until we have enough to fill the data buffer
-      long i = finished;
-      long prev_end_idx = data_offset - 1;
-      for (; i < count && end_idx_buffer[i] - data_offset < (long)data_buffer_size; ++i) {
-          // calculate tag size for entity
-        const int size = (end_idx_buffer[i] - prev_end_idx);
-        if (size < 0 || (long)size != (end_idx_buffer[i] - prev_end_idx)) {
-          readUtil->report_error( "Invalid end index in variable length tag data for tag: \"%s\"", name.c_str() );
-        assert_range( size_buffer + i - finished, sizeof(int) );
-        size_buffer[i-finished] = size * elem_size;
-        assert_range( pointer_buffer + i - finished, sizeof(void*) );
-        pointer_buffer[i-finished] = pointer;
-        assert_range( pointer_buffer[i-finished], size_buffer[i - finished] );
-        pointer += size_buffer[i-finished];
-        prev_end_idx = end_idx_buffer[i];
+        j = keep;
+          ++j;
-      const size_t num_val = prev_end_idx - data_offset + 1;
-      if (num_val) {
-          // read data
-        assert( num_val <= data_buffer_size );
-        assert_range( data_buffer, num_val * elem_size );
-        mhdf_readSparseTagValuesWithOpt( data[1], data_offset, num_val,
-                                         hdf_read_type, data_buffer,
-        if (mhdf_isError( &status )) {
+        // Read end-indices for each tagged entity.  Also need the
+        // end of the previous entity.  If no previous entity, then -1.
+      long remaining_ent = j - i;
+      if (offset + i == prev_end) {
+        end_idx_buffer[0] = prev_end_idx;
+        mhdf_readSparseTagIndicesWithOpt( off_table, offset + i,
+                                          remaining_ent, H5T_NATIVE_LONG,
+                                          end_idx_buffer + 1, ioProp, &status );
+      else {
+        mhdf_readSparseTagIndicesWithOpt( off_table, offset + i - 1,
+                                          remaining_ent + 1, H5T_NATIVE_LONG,
+                                          end_idx_buffer, ioProp, &status );
+      prev_end = offset + i + remaining_ent;
+      prev_end_idx = end_idx_buffer[0];
+      long* idx_buffer = end_idx_buffer + 1;
+      while (remaining_ent) {
+          // Count the subset of remaining_ent entities for which the
+          // concatentated tag data will fit in the data buffer.
+        long tag_count = 0;
+        while (tag_count < remaining_ent &&
+               idx_buffer[tag_count] - prev_end_idx < data_buffer_size)
+          ++tag_count;
+          // If the tag value for a single entity doesn't fit in the buffer,
+          // then we need to allocate a temporary buffer for it.
+        long val_count;
+        char* memptr = data_buffer;
+        if (tag_count == 0) {
+          tag_count = 1;
+          val_count = idx_buffer[0] - prev_end_idx;
+          tmp_buffer.resize(val_count * read_size);
+          memptr = &tmp_buffer[0];
-        data_offset += num_val;
-        if (is_handle_type) {
-          rval = convert_id_to_handle( reinterpret_cast<MBEntityHandle*>(data_buffer), num_val );
-          if (MB_SUCCESS != rval) {
-            return rval;
+        else {
+          val_count = idx_buffer[tag_count-1] - prev_end_idx;
-          // put data in tags
-        rval = iFace->tag_set_data( tag_handle, handle_buffer + finished, i - finished, pointer_buffer, size_buffer );
-          return rval;
-        finished = i;
-      else if (finished < i) { // zero-length tag values???
-        finished = i;
-        // if tag value to big for buffer
-      else {
-        std::vector<char*> tmp_buffer( size * elem_size );
-        mhdf_readSparseTagValuesWithOpt( data[1], data_offset, size,
-                                         hdf_read_type, &tmp_buffer[0],
+          // Read the tag data
+        mhdf_readSparseTagValues( val_table, prev_end_idx + 1,
+                                  val_count, hdf_read_type, memptr, &status );
           return MB_FAILURE;
+          rval = convert_id_to_handle( (MBEntityHandle*)memptr, val_count );
+            return rval;
-        data_offset += size;
-          rval = convert_id_to_handle( reinterpret_cast<MBEntityHandle*>(&tmp_buffer[0]), size );
-            return rval;
+          // Calculate sizes from end indices
+        size_buffer[0] = read_size * (idx_buffer[0] - prev_end_idx);
+        for (long k = 1; k < tag_count; ++k)
+          size_buffer[k] = read_size * (idx_buffer[k] - idx_buffer[k-1]);
+          // save prev_end_index for next iteration because it will
+          // get overwritten in the buffer next.
+        prev_end_idx = idx_buffer[tag_count-1];
+          // store pointers to individual tag values in end_idx_buffer
+        assert(sizeof(long) == sizeof(void*));
+        const void** ptr_buffer = reinterpret_cast<const void**>(idx_buffer);
+        const char* ptr_iter = memptr;
+        ptr_buffer[0] = ptr_iter;
+        ptr_iter += size_buffer[0];
+        for (long k = 1; k < tag_count; ++k) {
+          ptr_buffer[k] = ptr_iter;
+          ptr_iter += size_buffer[k];
-        pointer_buffer[0] = &tmp_buffer[0];
-        size_buffer[0] = size * elem_size;
-        rval = iFace->tag_set_data( tag_handle, handle_buffer + i, 1, pointer_buffer, size_buffer );
+          // Pass data to MOAB to store for each tag
+        rval = iFace->tag_set_data( tag_handle, handle_buffer+i, tag_count,
+                                    ptr_buffer, size_buffer );
           return rval;
+        remaining_ent -= tag_count;
+        i +=  tag_count;
+        idx_buffer += tag_count;
-        ++finished;
+    } // for(ever)
-    readUtil->report_error( mhdf_message( &status ) );
   return MB_SUCCESS;
-MBErrorCode ReadHDF5::convert_id_to_handle( const ElemSet& elems,
-                                            MBEntityHandle* array,
+MBErrorCode ReadHDF5::convert_id_to_handle( MBEntityHandle* array,
                                             size_t size )
-  MBEntityHandle offset = elems.first_id;
-  MBEntityHandle last = offset + elems.range.size();
-  for (MBEntityHandle *const end = array + size; array != end; ++array)
-    if (*array >= last || *array < (MBEntityHandle)offset)
-    MBRange:: const_iterator iter = elems.range.begin();
-    iter += *array - offset;
-    *array = *iter;
+  convert_id_to_handle( array, size, idMap );
   return MB_SUCCESS;
-MBErrorCode ReadHDF5::convert_id_to_handle( MBEntityHandle* array,
-                                            size_t size )
+void ReadHDF5::convert_id_to_handle( MBEntityHandle* array,
+                                     size_t size,
-  MBEntityHandle offset = 1;
-  MBEntityHandle last = 0;
-  ElemSet* set = 0;
-  const std::list<ElemSet>::iterator i_end = elemList.end();
+  for (MBEntityHandle* const end = array + size; array != end; ++array)
+    *array = id_map.find( *array );
-      // special case for ZERO
-    if (!*array)
-      continue;
-    if (nodeSet.first_id && (*array < offset || *array >= last))
-      offset = nodeSet.first_id;
-      last = offset + nodeSet.range.size();
-      set = &nodeSet;
+void ReadHDF5::convert_range_to_handle( const MBEntityHandle* ranges,
+                                        size_t num_ranges,
+                                        const RangeMap<long,MBEntityHandle>& id_map,
+                                        MBRange& merge )
+  RangeMap<long,MBEntityHandle>::iterator it = id_map.begin();
+  for (size_t i = 0; i < num_ranges; ++i) {
+    long id = ranges[2*i];
+    const long end = id + ranges[2*i+1];
+    it = id_map.lower_bound( it, id_map.end(), id );
+    if (id < it->begin)
+      id = it->begin;
+    const long off = id - it->begin;
+    while (id < end) {
+      long count = std::min( it->count - off,  end - id );
+      merge.insert( it->value + off, it->value + off + count - 1 );
+      id += count;
+      if (id < end)
+        ++it;
-    if (setSet.first_id && (*array < offset || *array >= last))
-      offset = setSet.first_id;
-      last = offset + setSet.range.size();
-      set = &setSet;
-    iter = elemList.begin();
-    while (*array < offset || *array >= last)
-      if (iter == i_end)
-      set = &*iter;
-      offset = set->first_id;
-      last = offset + set->range.size();
-      ++iter;
-    MBRange:: const_iterator riter = set->range.begin();
-    riter += *array - offset;
-    *array = *riter;
 MBErrorCode ReadHDF5::convert_range_to_handle( const MBEntityHandle* array,
                                                size_t num_ranges,
                                                MBRange& range )
-  const MBEntityHandle *const end = array + 2*num_ranges;
-  ElemSet* set = 0;
-  MBEntityHandle start = *(array++);
-  MBEntityHandle count = *(array++);
-  while (true)
-    if (nodeSet.first_id && (start < offset || start >= last))
-      set = &nodeSet;
-    if (setSet.first_id && (start < offset || start >= last))
-      set = &setSet;
-    while (start < offset || start >= last)
-      set = &*iter;
-      ++iter;
-    MBEntityHandle s_rem = set->range.size() - (start - offset);
-    MBEntityHandle num = count > s_rem ? s_rem : count;
-    MBRange::const_iterator riter = set->range.begin();
-    riter += (start - offset);
-    MBRange::const_iterator rend = riter;
-    rend += num;
-    assert( riter != rend );
-    MBEntityHandle h_start = *riter++;
-    MBEntityHandle h_prev = h_start;
-    while (riter != rend)
-      if (h_prev + 1 != *riter)
-        range.insert( h_start, h_prev );
-        h_start = *riter;
-      h_prev = *riter;
-      ++riter;
-    count -= num;
-    start += num;
-    if (count == 0)
-      if (array == end)
-        break;
-      start = *(array++);
-      count = *(array++);
+  convert_range_to_handle( array, num_ranges, idMap, range );
   return MB_SUCCESS;
Modified: MOAB/trunk/ReadHDF5.hpp
--- MOAB/trunk/ReadHDF5.hpp	2009-04-24 18:28:14 UTC (rev 2856)
+++ MOAB/trunk/ReadHDF5.hpp	2009-04-28 20:47:09 UTC (rev 2857)
@@ -30,6 +30,7 @@
 #include "MBReadUtilIface.hpp"
 #include "MBRange.hpp"
 #include "MBReaderIface.hpp"
+#include "RangeMap.hpp"
 class MB_DLL_EXPORT ReadHDF5 : public MBReaderIface
@@ -54,27 +55,27 @@
                          int num_set_tag_values );
 protected:
-  MBErrorCode load_file_impl( MBEntityHandle file_set,
-                              bool use_mpio );
+  MBErrorCode load_file_impl( MBEntityHandle file_set,
+                              const FileOptions& opts );
+  MBErrorCode load_file_partial( MBEntityHandle file_set,
+                                 const char* set_tag_name,
+                                 const int* set_tag_values,
+                                 int num_set_tag_values,
 private:
   MBErrorCode init();
-  //! Range of entities, grouped by type
-  struct ElemSet
-    //! The range of entities.
-    MBRange range;
-    //! The type of the entities in the range
-    MBEntityType type;
-    //! The type handle for the mhdf library.
-    const char* type2;
-    //! The first Id allocated by the mhdf library.  Entities in range have sequential IDs.
-    MBEntityHandle first_id;
+  inline int is_error( mhdf_Status& status ) {
+    int i;
+    if ((i = mhdf_isError(&status)))
+      readUtil->report_error( mhdf_message(&status) );
+    return i;
   //! The size of the data buffer (<code>dataBuffer</code>).
-  const int bufferSize;
+  int bufferSize;
   //! A memory buffer to use for all I/O operations.
   char* dataBuffer;
@@ -84,35 +85,55 @@
   //! The file handle from the mhdf library
   mhdf_FileHandle filePtr;
+  //! File summary
+  mhdf_FileDesc* fileInfo;
+  //! Map from File ID to MOAB handle
+  typedef RangeMap< long, MBEntityHandle > IDMap;
+  IDMap idMap;
   //! Cache pointer to read util
   MBReadUtilIface* readUtil;
-  //! The list elements to export.
-  std::list<ElemSet> elemList;
-  //! The list of nodes to export
-  ElemSet nodeSet;
-  //! The list of sets to export
-  ElemSet setSet;
   //! The type of an MBEntityHandle
   hid_t handleType;
   //! read/write property handle
   hid_t ioProp;
-  //! Read node coordinates.
-  MBErrorCode read_nodes( );
+  MBErrorCode read_nodes( const MBRange& node_file_ids );
+    // Read elements in fileInfo->elems[index]
+  MBErrorCode read_elems( int index );
+    // Read subset of elements in fileInfo->elems[index]
+  MBErrorCode read_elems( int index, const MBRange& file_ids );
   //! Read element connectivity.
-  MBErrorCode read_elems( const char* elem_group );
+  MBErrorCode read_elems( const mhdf_ElemDesc& elems, const MBRange& file_ids );
+    // Read connectivity data for a list of element file ids.
+    // passing back the file IDs for the element connectivity
+    // w/out actually creating any elements in MOAB.
+  MBErrorCode read_elems( int index, const MBRange& element_file_ids, MBRange& node_file_ids );
+    // Scan all elements in group.  For each element for which all vertices
+    // are contained in idMap (class member), read the element.  All new
+    // elements are added to idMap.
+  MBErrorCode read_node_adj_elems( const mhdf_ElemDesc& group );
+    // Scan all elements in specified file table.  For each element for
+    // which all vertices are contained in idMap (class member), read the
+    // element.  All new elements are added to idMap.
+  MBErrorCode read_node_adj_elems( const mhdf_ElemDesc& group,
+                                   hid_t connectivity_handle );
   //! Read poly(gons|hedra)
-  MBErrorCode read_poly( const char* elem_group );
+  MBErrorCode read_poly( const mhdf_ElemDesc& elems, const MBRange& file_ids );
   //! Read sets
-  MBErrorCode read_sets( );
+  MBErrorCode read_sets( const MBRange& set_file_ids );
   //! Read set contents
   MBErrorCode read_set_contents( hid_t set_description_handle,
@@ -125,48 +146,213 @@
                                      hid_t set_contents_handle,
                                      const unsigned long data_len );
-  //! Read element adjacencies
-  MBErrorCode read_adjacencies( ElemSet& for_this_set );
+  MBErrorCode read_adjacencies( hid_t adjacency_table,
+                                long table_length );
   //! Create tag and read all data.
-  MBErrorCode read_tag( const char* name );
+  MBErrorCode read_tag( int index );
+  //! Create new tag or varify type matches existing tag
+  MBErrorCode create_tag( const mhdf_TagDesc& info, MBTag& handle, hid_t& type );
   //! Read dense tag for all entities
   MBErrorCode read_dense_tag( MBTag tag_handle,
-                              size_t read_size,
-                              bool is_handle_type );
+                              hid_t data_table,
+                              long start_id,
+                              long count );
-  //! Read dense tag for specified entity set
-  MBErrorCode read_dense_tag( ElemSet& set,
-                              MBTag tag_handle,
-                              size_t read_size,
   //! Read sparse tag for all entities.
   MBErrorCode read_sparse_tag( MBTag tag_handle,
-                               size_t read_size,
+                               hid_t ent_table,
+                               hid_t val_table,
+                               long num_entities );
   //! Read variable-length tag for all entities.
   MBErrorCode read_var_len_tag( MBTag tag_handle,
+                                hid_t ent_table,
+                                hid_t val_table,
+                                hid_t off_table,
+                                long num_values );
   MBErrorCode read_qa( MBEntityHandle file_set );
-  MBErrorCode convert_id_to_handle( const ElemSet& elems_in_this_set,
-                                    MBEntityHandle* in_out_array,
-                                    size_t array_length );
   MBErrorCode convert_id_to_handle( MBEntityHandle* in_out_array,
   MBErrorCode convert_range_to_handle( const MBEntityHandle* ranges,
                                        size_t num_ranges,
                                        MBRange& merge );
+  static
+  void convert_id_to_handle( MBEntityHandle* in_out_array,
+                             size_t array_length,
+                             const RangeMap<long,MBEntityHandle>& id_map );
+  static
+  void convert_range_to_handle( const MBEntityHandle* ranges,
+                                MBRange& merge );
+  /**\brief Search for entities with specified tag values
+   *\param tag_index  Index into info->tags specifying which tag to search.
+   *\param sorted_values  List of tag values to check for, in ascending sorted
+   *                  order.
+   *\param file_ids_out  File IDs for entities with specified tag values.
+  MBErrorCode search_tag_values( int tag_index,
+                                 const std::vector<int>& sorted_values,
+                                 MBRange& file_ids_out );
+  /**\brief Search a table of tag data for a specified set of values.
+   * Search a table of tag values, returning the indices into the table
+   * at which matches were found.
+   *\param info       Summary of data contained in file.
+   *\param tag_table     HDF5/mhdf handle for tag values
+   *\param table_size    Number of values in table
+   *\param sorted_values Sorted list of values to search for.
+   *\param value_indices Output: Offsets into the table of data at which
+   *                       matching values were found.
+  MBErrorCode search_tag_values( hid_t tag_table,
+                                 unsigned long table_size,
+                                 std::vector<long>& value_indices );
+  /**\brief Get the file IDs for nodes and elements contained in sets.
+   * Read the contents for the specified sets and return the file IDs
+   * of all nodes and elements contained within those sets.
+   *\param sets       Container of file IDs designating entity sets.
+   *\param file_ids   Output: File IDs of entities contained in sets.
+  MBErrorCode get_set_contents( const MBRange& sets, MBRange& file_ids );
+  /** Given a list of file IDs for entity sets, find all child sets
+   *  (at any depth) and append them to the MBRange of file IDs.
+  MBErrorCode read_child_sets( MBRange& sets_in_out );
+  /** Find all sets containing one or more entities read from the file
+   *  and added to idMap
+  MBErrorCode find_sets_containing( MBRange& sets_out );
+  /**\brief Read sets from file into MOAB for partial read of file.
+   * Given the file IDs for entity sets (sets_in) and elements and
+   * nodes (id_map), read in all sets containing any of the elements
+   * or nodes and all sets that are (recursively) children of any
+   * other set to be read (those in sets_in or those containging any
+   * already-read element or node.)
+   *\param sets_in    File IDs for sets to read (unconditionally)
+  MBErrorCode read_sets_partial( const MBRange& sets_in );
+  /** Find file IDs of sets containing any entities in the passed id_map */
+  MBErrorCode find_sets_containing( hid_t meta_handle,
+                                    hid_t content_handle,
+                                    long content_len,
+                                    MBRange& file_ids );
+  /** Recursively find all child sets contained in file */
+  MBErrorCode read_child_ids_recursive( MBRange& file_ids,
+                                        hid_t child_handle );
+  /** Given a list of file IDs for entity sets, read the list of
+   *  file IDs for all child entity sets.
+  MBErrorCode read_child_ids( const MBRange& set_file_ids,
+                              MBRange& child_file_ids );
+    /**\brief Create sets
+     * For the list of entity sets designated by the file IDs contained
+     * in file_ids, instantiate the sets in MOAB with consecutive handles.
+     *\param info      Summary of data contained in the file.
+     *\param file_ids  List of file IDs designating which sets will be read.
+     *\param set_meta_handle HDF5/mhdf handle for set metadata table.
+     *\parma id_map    Map from file IDs to MBEntityHandle for entities read
+     *                 from file.  Sets created by this function will be appended.
+     *\param ranged_file_ids_out This function will add to this container
+     *                 the file IDs for any sets for which the contents are
+     *                 stored using ranged compression (any set for which
+     *                 mhdf_SET_RANGE_BIT is set in the flags.)
+  MBErrorCode read_sets( const MBRange& file_ids,
+                         hid_t set_meta_handle,
+                         MBRange& ranged_file_ids_out,
+                         bool create = true );
+   MBErrorCode read_contents( const MBRange& set_file_ids,
+                              const MBRange& ranged_set_file_ids );
+   MBErrorCode read_parents( const MBRange& set_file_ids,
+                             hid_t set_parents_table,
+                             long set_parents_length );
+   MBErrorCode read_children( const MBRange& set_file_ids,
+                              hid_t set_children_table,
+                              long set_children_length );
+  class ContentReader {
+    public:
+      virtual void
+      read_indices( long, long, long*, mhdf_Status& ) = 0;
+      virtual void
+      read_contents( long, long, MBEntityHandle*, mhdf_Status& ) = 0;
+      virtual MBErrorCode
+      store_data( MBEntityHandle, long file_id, MBEntityHandle*, long len, bool ranged = false ) = 0;
+   /**\brief Read end-indexed variable length handle lists such as
+     *       set parents, set children, set contents, and old-format
+     *       poly connectivity.
+     * Read the contents of each entity set from the file, and add to
+     * the corresponding entity set in MOAB any contained entities that
+     * have been read from the file.
+     *\param file_ids        File IDs of entity sets to read.
+     *\param start_id        ID of first entity in table.
+     *\param start_handle    MBEntityHandle for first entity set in file_ids
+     *                       (assumes all sets in file_ids have sequential
+     *                        handles.)
+     *\param set_content_len Length of set contents table.
+     *\param ranged_file_ids Subset of file_ids for which set contents
+     *                       are stored in ranged format.
+  MBErrorCode read_contents( ContentReader& tool,
+                             const long num_sets,
+                             const long set_content_len,
+                             const MBRange& ranged_file_ids );
 #endif
Modified: MOAB/trunk/mhdf/src/file-desc.c
--- MOAB/trunk/mhdf/src/file-desc.c	2009-04-24 18:28:14 UTC (rev 2856)
+++ MOAB/trunk/mhdf/src/file-desc.c	2009-04-28 20:47:09 UTC (rev 2857)
@@ -180,7 +180,8 @@
   void* ptr;
   int have_default, have_global;
-  int valsize, size;
+  int valsize, size, close_type = 0;
+  hsize_t array_len;
   ptr = realloc_data( &result, strlen(name)+1, status );
   if (NULL == ptr) return NULL;
@@ -226,7 +227,7 @@
       type = H5T_NATIVE_UCHAR;
       break;
     case mhdf_INTEGER:
-      type = H5T_INTEGER;
+      type = H5T_NATIVE_INT;
       have_default *= sizeof(int);
       have_global *= sizeof(int);
       valsize *= sizeof(int);
@@ -267,6 +268,7 @@
         mhdf_setFail( status, "Cannot create a bit tag larger than 64-bits.  %d bits requested.\n", (int)valsize);
         return NULL;
+      close_type = 1;
       break;
       if (0 == type)
@@ -287,13 +289,27 @@
       return NULL;
   result->tags[index].bytes = valsize;
+  if (result->tags[index].type != mhdf_OPAQUE &&
+      result->tags[index].type != mhdf_BITFIELD &&
+      result->tags[index].size > 1) {
+    close_type = 1;
+    array_len = result->tags[index].size;
+    type = H5Tarray_create( type, 1, &array_len, 0 );
+    if (type < 0) {
+      mhdf_setFail( status, "H5Tarray_create failed for tag (\"%s\")", name );
+      free( result );
+      return NULL;
   if (have_default || have_global) {
     if (have_default) {
       ptr = realloc_data( &result, have_default, status );
       if (NULL == ptr) {
-        if (result->tags[index].type == mhdf_BITFIELD)
+        if (close_type) {
           H5Tclose( type );
         return NULL;
       result->tags[index].default_value = ptr;
@@ -301,8 +317,9 @@
     if (have_global) {
       ptr = realloc_data( &result, have_global, status );
       if (NULL == ptr) {
+        if (close_type) {
           H5Tclose( type );
         return NULL;
       result->tags[index].global_value = ptr;
@@ -313,8 +330,9 @@
                        result->tags[index].default_value,
                        result->tags[index].global_value,
                        status );
+    if (close_type) {
       H5Tclose( type );
     if (mhdf_isError(status)) {
       free( result );
       return NULL;
Modified: MOAB/trunk/test/h5file/Makefile.am
--- MOAB/trunk/test/h5file/Makefile.am	2009-04-24 18:28:14 UTC (rev 2856)
+++ MOAB/trunk/test/h5file/Makefile.am	2009-04-28 20:47:09 UTC (rev 2857)
@@ -3,7 +3,7 @@
 DEFS = $(DEFINES)
 INCLUDES += -I$(top_srcdir) -I$(top_srcdir)/mhdf/include -I$(top_builddir)
-check_PROGRAMS = h5test h5legacy h5varlen h5sets_test h5regression
+check_PROGRAMS = h5test h5legacy h5varlen h5sets_test h5regression h5partial
 TESTS = $(check_PROGRAMS)
 LDADD = $(top_builddir)/libMOAB.la
@@ -17,3 +17,4 @@
 h5varlen_SOURCES = h5varlen.cpp
 h5sets_test_SOURCES = h5sets_test.cpp
 h5regression_SOURCES = h5regression.cpp
+h5partial_SOURCES = h5partial.cpp
Modified: MOAB/trunk/test/h5file/h5file_test.cpp
--- MOAB/trunk/test/h5file/h5file_test.cpp	2009-04-24 18:28:14 UTC (rev 2856)
+++ MOAB/trunk/test/h5file/h5file_test.cpp	2009-04-28 20:47:09 UTC (rev 2857)
@@ -469,8 +469,8 @@
   if (opt1 != opt2)
     fprintf(stderr, "Sets with id %d do not have matching options.\n"
-                    "Set 1: track_onwer=%s set=%s ordered=%s\n"
-                    "Set 2: track_onwer=%s set=%s ordered=%s\n",
+                    "Set 1: track_owner=%s set=%s ordered=%s\n"
+                    "Set 2: track_owner=%s set=%s ordered=%s\n",
                     id,
                     opt1 & MESHSET_TRACK_OWNER ? "yes" : "no",
                     opt1 & MESHSET_SET         ? "yes" : "no",
