[MOAB-dev] r2841 - in MOAB/trunk: . test/perf
kraftche at cae.wisc.edu
Fri Apr 17 16:17:04 CDT 2009
Author: kraftche
Date: 2009-04-17 16:17:03 -0500 (Fri, 17 Apr 2009)
New Revision: 2841
Added:
MOAB/trunk/test/perf/point_in_elem.cpp
Modified:
MOAB/trunk/MBAdaptiveKDTree.cpp
MOAB/trunk/MBAdaptiveKDTree.hpp
MOAB/trunk/test/perf/Makefile.am
Log:
tool for measuring performance of element-containing-point search
Modified: MOAB/trunk/MBAdaptiveKDTree.cpp
--- MOAB/trunk/MBAdaptiveKDTree.cpp 2009-04-17 20:11:06 UTC (rev 2840)
+++ MOAB/trunk/MBAdaptiveKDTree.cpp 2009-04-17 21:17:03 UTC (rev 2841)
@@ -2032,6 +2032,24 @@
return MB_SUCCESS;
+MBErrorCode MBAdaptiveKDTree::depth( MBEntityHandle root,
+ unsigned int& min_depth,
+ unsigned int& max_depth )
+ MBAdaptiveKDTreeIter iter;
+ get_tree_iterator( root, iter );
+ iter.step_to_first_leaf(MBAdaptiveKDTreeIter::LEFT);
+ min_depth = max_depth = iter.depth();
+ while (MB_SUCCESS == iter.step()) {
+ if (iter.depth() > max_depth)
+ max_depth = iter.depth();
+ else if (iter.depth() < min_depth)
+ min_depth = iter.depth();
+ return MB_SUCCESS;
MBErrorCode MBAdaptiveKDTree::get_info(MBEntityHandle root,
double min[3], double max[3],
@@ -2040,11 +2058,7 @@
MBErrorCode result = get_tree_box(root, min, max);
if (MB_SUCCESS != result) return result;
- MBAdaptiveKDTreeIter iter;
- get_tree_iterator( root, iter );
- iter.step_to_first_leaf(MBAdaptiveKDTreeIter::LEFT);
- dep = iter.depth();
- return MB_SUCCESS;
+ unsigned min_depth;
+ return depth( root, min_depth, dep );
Modified: MOAB/trunk/MBAdaptiveKDTree.hpp
--- MOAB/trunk/MBAdaptiveKDTree.hpp 2009-04-17 20:11:06 UTC (rev 2840)
+++ MOAB/trunk/MBAdaptiveKDTree.hpp 2009-04-17 21:17:03 UTC (rev 2841)
@@ -175,10 +175,14 @@
MBEntityHandle& root_set_out,
const Settings* settings = 0 );
+ MBErrorCode depth( MBEntityHandle root,
+ unsigned int& max_depth );
//! get some information about the tree
MBErrorCode get_info(MBEntityHandle root,
- unsigned int &dep);
+ unsigned int &max_dep);
//! Find triangle closest to input position.
//!\param from_coords The input position to test against
Modified: MOAB/trunk/test/perf/Makefile.am
--- MOAB/trunk/test/perf/Makefile.am 2009-04-17 20:11:06 UTC (rev 2840)
+++ MOAB/trunk/test/perf/Makefile.am 2009-04-17 21:17:03 UTC (rev 2841)
@@ -15,6 +15,7 @@
endif
check_PROGRAMS = perf seqperf adj_time
+noinst_PROGRAMS = point_in_elem
perf_SOURCES = perf.cpp
seqperf_SOURCES = seqperf.cpp
Added: MOAB/trunk/test/perf/point_in_elem.cpp
--- MOAB/trunk/test/perf/point_in_elem.cpp (rev 0)
+++ MOAB/trunk/test/perf/point_in_elem.cpp 2009-04-17 21:17:03 UTC (rev 2841)
@@ -0,0 +1,344 @@
+#include "MBCore.hpp"
+#include "MBAdaptiveKDTree.hpp"
+#include "MBRange.hpp"
+#include "MBCartVect.hpp"
+#include "MBGeomUtil.hpp"
+#include <iostream>
+#include <time.h>
+#include <stdlib.h>
+#include <assert.h>
+#define CHK(ErrorCode) do { if (MB_SUCCESS != (ErrorCode)) fail( (ErrorCode), __FILE__, __LINE__ ); } while(false)
+void fail( MBErrorCode error_code, const char* file_name, int line_number );
+enum TreeType { UseKDTree, UseNoTree, UseDefaultTree = UseKDTree };
+const char* default_str = "(default)";
+const char* empty_str = "";
+inline const char* is_default_tree( TreeType type ) {
+ return type == UseDefaultTree ? default_str : empty_str;
+const long DEFAULT_NUM_TEST = 100000;
+const long HARD_MAX_UNIQUE_POINTS = 100000;
+const long HARD_MIN_UNIQUE_POINTS = 1000;
+const long FRACTION_UNIQUE_POINTS = 100;
+void usage( char* argv0, bool help = false )
+ const char* usage_str = "[-k|-v] [-n <N>] [-d <N>] [-e <N>] <input_mesh>";
+ if (!help) {
+ std::cerr << "Usage: " << argv0 << " " << usage_str << std::endl;
+ std::cerr << " : " << argv0 << " -h" << std::endl;
+ exit(1);
+ std::cout << "Usage: " << argv0 << " " << usage_str << std::endl
+ << " -k : Use kD Tree " << is_default_tree(UseKDTree) << std::endl
+ << " -v : Use no tree" << is_default_tree(UseNoTree) << std::endl
+ << " -n : Specify number of test points (default = " << DEFAULT_NUM_TEST << ")" << std::endl
+ << " -d : Specify maximum tree depth" << std::endl
+ << " -e : Specify maximum elements per leaf" << std::endl
+ << " <input_mesh> : Mesh to build and query." << std::endl
+ << std::endl;
+ exit(0);
+void generate_random_points( MBInterface& mesh, size_t num_points,
+ std::vector<MBCartVect>& points,
+ std::vector<MBEntityHandle>& point_elems );
+void do_kdtree_test( MBInterface& mesh, int tree_depth, int elem_per_leaf,
+ long num_test, const std::vector<MBCartVect>& points,
+ std::vector<MBEntityHandle>& point_elems,
+ clock_t& build_time, clock_t& test_time, size_t& depth );
+void do_linear_test( MBInterface& mesh, int tree_depth, int elem_per_leaf,
+int main( int argc, char* argv[] )
+ const char* input_file = 0;
+ long tree_depth = -1;
+ long elem_per_leaf = -1;
+ long num_points = DEFAULT_NUM_TEST;
+ TreeType type = UseDefaultTree;
+ char* endptr;
+ // PARSE ARGUMENTS
+ long* valptr = 0;
+ for (int i = 1; i < argc; ++i) {
+ if (valptr) {
+ *valptr = strtol( argv[i], &endptr, 0 );
+ if (*valptr < 1 || *endptr) {
+ std::cerr << "Invalid value for '" << argv[i-1] << "' flag: " << argv[i] << std::endl;
+ exit(1);
+ valptr = 0;
+ else if (argv[i][0] == '-' && argv[i][1] && !argv[i][2]) {
+ switch (argv[i][1]) {
+ case 'h': usage(argv[0],true); break;
+ case 'k': type = UseKDTree; break;
+ case 'v': type = UseNoTree; break;
+ case 'd': valptr = &tree_depth; break;
+ case 'e': valptr = &elem_per_leaf; break;
+ case 'n': valptr = &num_points; break;
+ default:
+ std::cerr << "Invalid flag: " << argv[i] << std::endl;
+ usage(argv[0]);
+ break;
+ else if (!input_file) {
+ input_file = argv[i];
+ else {
+ std::cerr << "Unexpected argument: " << argv[i] << std::endl;
+ usage(argv[0]);
+ if (valptr) {
+ std::cerr << "Expected value following '" << argv[argc-1] << "' flag" << std::endl;
+ usage(argv[0]);
+ if (!input_file) {
+ std::cerr << "No input file specified." << std::endl;
+ usage(argv[0]);
+ // LOAD MESH
+ MBCore moab;
+ MBInterface& mb = moab;
+ MBErrorCode rval;
+ MBEntityHandle file_set;
+ std::string init_msg, msg;
+ mb.get_last_error( init_msg );
+ rval = mb.load_file( input_file, file_set );
+ if (MB_SUCCESS != rval) {
+ std::cerr << input_file << " : failed to read file." << std::endl;
+ mb.get_last_error( msg );
+ if (msg != init_msg)
+ std::cerr << "message : " << msg << std::endl;
+ // GENERATE TEST POINTS
+ int num_unique = num_points / FRACTION_UNIQUE_POINTS;
+ if (num_unique > HARD_MAX_UNIQUE_POINTS)
+ num_unique = HARD_MAX_UNIQUE_POINTS;
+ else if (num_unique < HARD_MIN_UNIQUE_POINTS)
+ num_unique = num_points;
+ std::vector<MBCartVect> points;
+ std::vector<MBEntityHandle> elems;
+ generate_random_points( mb, num_unique, points, elems );
+ // GET MEMORY USE BEFORE BUILDING TREE
+ unsigned long init_total_storage;
+ mb.estimated_memory_use( 0, 0, &init_total_storage );
+ // RUN TIMING TEST
+ clock_t build_time, test_time;
+ size_t actual_depth;
+ std::vector<MBEntityHandle> results(points.size());
+ switch (type) {
+ case UseKDTree:
+ do_kdtree_test( mb, tree_depth, elem_per_leaf, num_points, points, results, build_time, test_time, actual_depth );
+ break;
+ case UseNoTree:
+ do_linear_test( mb, tree_depth, elem_per_leaf, num_points, points, results, build_time, test_time, actual_depth );
+ break;
+ unsigned long fini_total_storage;
+ mb.estimated_memory_use( 0, 0, &fini_total_storage );
+ // VALIDATE RESULTS
+ int fail = 0;
+ if (results != elems) {
+ std::cout << "WARNING: Test produced invalid results" << std::endl;
+ fail = 1;
+ // SUMMARIZE RESULTS
+ std::cout << "Number of test queries: " << num_points << std::endl;
+ std::cout << "Tree build time: " << ((double)build_time)/CLOCKS_PER_SEC << " seconds" << std::endl;
+ std::cout << "Total query time: " << ((double)test_time)/CLOCKS_PER_SEC << " seconds" << std::endl;
+ std::cout << "Time per query: " << ((double)test_time)/CLOCKS_PER_SEC/num_points << " seconds" << std::endl;
+ std::cout << "Tree depth: " << actual_depth << std::endl;
+ if (actual_depth)
+ std::cout << "Total query time/depth: " << ((double)test_time)/CLOCKS_PER_SEC/actual_depth << " seconds" << std::endl;
+ std::cout << std::endl;
+ std::cout << "Bytes before tree construction: " << init_total_storage << std::endl;
+ std::cout << "Bytes after tree construction: " << fini_total_storage <<std::endl;
+ std::cout << "Difference: " << fini_total_storage - init_total_storage << " bytes" << std::endl;
+ return fail;
+void fail( MBErrorCode error_code, const char* file, int line )
+ std::cerr << "Internal error (error code " << error_code << ") at " << file << ":" << line << std::endl;
+ abort();
+const int HexSign[8][3] = { { -1, -1, -1 },
+ { 1, -1, -1 },
+ { 1, 1, -1 },
+ { -1, 1, -1 },
+ { -1, -1, 1 },
+ { 1, -1, 1 },
+ { 1, 1, 1 },
+ { -1, 1, 1 } };
+MBCartVect random_point_in_hex( MBInterface& mb, MBEntityHandle hex )
+ const double f = RAND_MAX/2;
+ MBCartVect xi( ((double)rand() - f)/f,
+ ((double)rand() - f)/f,
+ ((double)rand() - f)/f );
+ MBCartVect coords[8];
+ const MBEntityHandle* conn;
+ int len;
+ MBErrorCode rval = mb.get_connectivity( hex, conn, len, true );
+ if (len != 8 && MB_SUCCESS != rval) {
+ std::cerr << "Invalid element" << std::endl;
+ assert(false);
+ abort();
+ rval = mb.get_coords( conn, 8, reinterpret_cast<double*>(coords) );
+ CHK(rval);
+ MBCartVect point(0,0,0);
+ for (unsigned i = 0; i < 8; ++i) {
+ double coeff = 0.125;
+ for (unsigned j = 0; j < 3; ++j)
+ coeff *= 1 + HexSign[i][j] * xi[j];
+ point += coeff * coords[i];
+ return point;
+void generate_random_points( MBInterface& mb, size_t num_points,
+ MBRange elems;
+ MBErrorCode rval;
+ rval = mb.get_entities_by_dimension( 0, 3, elems );
+ CHK(rval);
+ if (!elems.all_of_type(MBHEX)) {
+ std::cerr << "Warning: ignoring non-hexahedral elements." << std::endl;
+ std::pair< MBRange::iterator, MBRange::iterator > p = elems.equal_range(MBHEX);
+ elems.erase( p.second, elems.end() );
+ elems.erase( elems.begin(), p.first );
+ if (elems.empty()) {
+ std::cerr << "Input file contains no hexahedral elements." << std::endl;
+ exit(1);
+ points.resize( num_points );
+ point_elems.resize( num_points );
+ const size_t num_elem = elems.size();
+ for (size_t i = 0; i < num_points; ++i) {
+ size_t offset = 0;
+ for (size_t x = num_elem; x > 0; x /= RAND_MAX)
+ offset += rand();
+ offset %= num_elem;
+ point_elems[i] = elems[offset];
+ points[i] = random_point_in_hex( mb, point_elems[i] );
+void do_kdtree_test( MBInterface& mb, int tree_depth, int elem_per_leaf,
+ MBErrorCode rval;
+ clock_t init = clock();
+ MBAdaptiveKDTree tool( &mb );
+ MBEntityHandle root;
+ MBAdaptiveKDTree::Settings settings;
+ if (tree_depth > 0)
+ settings.maxTreeDepth = tree_depth;
+ if (elem_per_leaf > 0)
+ settings.maxEntPerLeaf = elem_per_leaf;
+ MBRange all_hexes;
+ rval = mb.get_entities_by_type( 0, MBHEX, all_hexes );
+ CHK(rval);
+ rval = tool.build_tree( all_hexes, root, &settings );
+ CHK(rval);
+ all_hexes.clear();
+ build_time = clock() - init;
+ MBEntityHandle leaf;
+ std::vector<MBEntityHandle> hexes;
+ std::vector<MBEntityHandle>::iterator j;
+ int len;
+ for (long i = 0; i < num_test; ++i) {
+ const size_t idx = (size_t)i % points.size();
+ rval = tool.leaf_containing_point( root, points[idx].array(), leaf ); CHK(rval);
+ hexes.clear();
+ rval = mb.get_entities_by_handle( leaf, hexes ); CHK(rval);
+ for (j = hexes.begin(); j != hexes.end(); ++j) {
+ rval = mb.get_connectivity( *j, conn, len, true ); CHK(rval);
+ rval = mb.get_coords( conn, 8, reinterpret_cast<double*>(coords) ); CHK(rval);
+ if (MBGeomUtil::point_in_trilinear_hex( coords, points[idx], 1e-12 )) {
+ point_elems[idx] = *j;
+ break;
+ if (j == hexes.end())
+ point_elems[idx] = 0;
+ test_time = clock() - build_time;
+ unsigned min_d, max_d;
+ tool.depth( root, min_d, max_d );
+ depth = max_d;
+void do_linear_test( MBInterface& mb, int , int ,
+ MBRange hexes;
+ MBErrorCode rval = mb.get_entities_by_type( 0, MBHEX, hexes );
+ CHK(rval);
+ depth = 0;
+ point_elems.resize( points.size() );
+ int len;
+ for (MBRange::iterator h = hexes.begin(); h != hexes.end(); ++h) {
+ rval = mb.get_connectivity( *h, conn, len, true ); CHK(rval);
+ point_elems[idx] = *h;
+ break;
