[MOAB-dev] r2819 - MOAB/trunk
pppebay at sandia.gov pppebay at sandia.gov
Tue Apr 14 19:57:28 CDT 2009
Author: pebay
Date: 2009-04-14 19:57:28 -0500 (Tue, 14 Apr 2009)
New Revision: 2819
Added:
   MOAB/trunk/SweptElementData.cpp
   MOAB/trunk/SweptElementData.hpp
   MOAB/trunk/SweptVertexData.cpp
   MOAB/trunk/SweptVertexData.hpp
Modified:
   MOAB/trunk/ScdElementData.hpp
   MOAB/trunk/SweptElementSeq.cpp
Log:
ENH: swept element data and sequence classes
Modified: MOAB/trunk/ScdElementData.hpp
--- MOAB/trunk/ScdElementData.hpp	2009-04-14 21:13:40 UTC (rev 2818)
+++ MOAB/trunk/ScdElementData.hpp	2009-04-15 00:57:28 UTC (rev 2819)
@@ -17,7 +17,7 @@
 #define SCD_ELEMENT_DATA_HPP
-// Class: ScdElementSeq
+// Class: ScdElementData
 // Purpose: represent a rectangular element of mesh
Added: MOAB/trunk/SweptElementData.cpp
--- MOAB/trunk/SweptElementData.cpp	                        (rev 0)
+++ MOAB/trunk/SweptElementData.cpp	2009-04-15 00:57:28 UTC (rev 2819)
@@ -0,0 +1,151 @@
+ * MOAB, a Mesh-Oriented datABase, is a software component for creating,
+ * storing and accessing finite element mesh data.
+ * Copyright 2004 Sandia Corporation.  Under the terms of Contract
+ * DE-AC04-94AL85000 with Sandia Coroporation, the U.S. Government
+ * retains certain rights in this software.
+ * This library is free software; you can redistribute it and/or
+ * modify it under the terms of the GNU Lesser General Public
+ * License as published by the Free Software Foundation; either
+ * version 2.1 of the License, or (at your option) any later version.
+#include "SweptElementData.hpp"
+#include "SweptVertexData.hpp"
+#include "MBInterface.hpp"
+#include "MBReadUtilIface.hpp"
+#include "MBCN.hpp"
+#include "MBInternals.hpp"
+#include <assert.h>
+MBEntityID SweptElementData::calc_num_entities(MBEntityHandle start_handle,
+                                int irange, int jrange, int krange)
+  size_t result = 1;
+  switch (MBCN::Dimension(TYPE_FROM_HANDLE(start_handle))) {
+    default: result = 0; assert( false );
+    case 3: result *= krange;
+    case 2: result *= jrange;
+    case 1: result *= irange;
+  return result;
+SweptElementData::SweptElementData(
+                             MBEntityHandle start_handle,
+                             const int imin, const int jmin, const int kmin,
+                             const int imax, const int jmax, const int kmax,
+			     const int* Cq )
+    : SequenceData(0, start_handle,
+                   start_handle +
+                   calc_num_entities( start_handle, imax-imin, jmax-jmin, kmax-kmin )
+                   - 1)
+    // need to have meaningful parameters
+  assert(imax >= imin && jmax >= jmin && kmax >= kmin);
+  elementParams[0] = HomCoord(imin, jmin, kmin);
+  elementParams[1] = HomCoord(imax, jmax, kmax);
+  elementParams[2] = HomCoord(1, 1, 1);
+    // assign and compute parameter stuff
+  dIJK[0] = elementParams[1][0] - elementParams[0][0] + 1;
+  dIJK[1] = elementParams[1][1] - elementParams[0][1] + 1;
+  dIJK[2] = elementParams[1][2] - elementParams[0][2] + 1;
+  dIJKm1[0] = dIJK[0] - 1;
+  dIJKm1[1] = dIJK[1] - 1;
+  dIJKm1[2] = dIJK[2] - 1;
+SweptElementData::~SweptElementData()
+bool SweptElementData::boundary_complete() const
+    // test the bounding vertex sequences to see if they fully define the
+    // vertex parameter space for this rectangular block of elements
+  int p;
+  std::vector<VertexDataRef> minlist, maxlist;
+    // pseudo code:
+    // for each vertex sequence v:
+  for (std::vector<VertexDataRef>::const_iterator vseq = vertexSeqRefs.begin();
+       vseq != vertexSeqRefs.end(); vseq++)
+    //   test min corner mincorner:
+    bool mincorner = true;
+    //   for each p = (i-1,j,k), (i,j-1,k), (i,j,k-1):
+    for (p = 0; p < 3; p++) {
+    //     for each vsequence v' != v:
+      for (std::vector<VertexDataRef>::const_iterator othervseq = vertexSeqRefs.begin();
+           othervseq != vertexSeqRefs.end(); othervseq++)
+        if (othervseq == vseq) continue;
+    //       if v.min-p contained in v'
+        if ((*othervseq).contains((*vseq).minmax[0]-HomCoord::unitv[p])) {
+    //         mincorner = false
+          mincorner = false;
+          break;
+      if (!mincorner) break;
+    bool maxcorner = true;
+    //       if v.max+p contained in v'
+        if ((*othervseq).contains((*vseq).minmax[1]+HomCoord::unitv[p])) {
+    //         maxcorner = false
+          maxcorner = false;
+          break;
+      if (!maxcorner) break;
+    //   if mincorner add to min corner list minlist
+    if (mincorner) minlist.push_back(*vseq);
+    //   if maxcorner add to max corner list maxlist
+    if (maxcorner) maxlist.push_back(*vseq);
+    // if minlist.size = 1 & maxlist.size = 1 & minlist[0] = esequence.min &
+    //         maxlist[0] = esequence.max+(1,1,1)
+  if (minlist.size() == 1 && maxlist.size() == 1 &&
+      minlist[0].minmax[0] == elementParams[0] &&
+      maxlist[0].minmax[1] == elementParams[1])
+      //   complete
+    return true;
+    // else
+  return false;
+SequenceData* SweptElementData::subset( MBEntityHandle /*start*/,
+                                      MBEntityHandle /*end*/,
+                                      const int* /*sequence_data_sizes*/,
+                                      const int* /*tag_data_sizes*/ ) const
+  return 0;
+unsigned long SweptElementData::get_memory_use() const
+  return sizeof(*this) + vertexSeqRefs.capacity() * sizeof(VertexDataRef);
Property changes on: MOAB/trunk/SweptElementData.cpp
___________________________________________________________________
   + text/plain
   + native
Added: MOAB/trunk/SweptElementData.hpp
--- MOAB/trunk/SweptElementData.hpp	                        (rev 0)
+++ MOAB/trunk/SweptElementData.hpp	2009-04-15 00:57:28 UTC (rev 2819)
@@ -0,0 +1,307 @@
+#ifndef SWEPT_ELEMENT_DATA_HPP
+#define SWEPT_ELEMENT_DATA_HPP
+// Class: SweptElementData
+// Purpose: represent a rectangular element of mesh
+// A SweptElement represents a rectangular element of mesh, including both vertices and
+// elements, and the parametric space used to address that element.  Vertex data,
+// i.e. coordinates, may not be stored directly in the element, but the element returns
+// information about the vertex handles of vertices in the element.  Vertex and element
+// handles associated with the element are each contiguous.
+#include "SequenceData.hpp"
+#include "HomXform.hpp"
+#include "MBRange.hpp"
+#include <vector>
+#include <algorithm>
+  //! structure to hold references to bounding vertex blocks
+class VertexDataRef
+private:
+  HomCoord minmax[2];
+  HomXform xform, invXform;
+  SweptVertexData *srcSeq;
+public:
+  friend class SweptElementData;
+  VertexDataRef(const HomCoord &min, const HomCoord &max,
+                const HomXform &tmp_xform, SweptVertexData *this_seq);
+  bool contains(const HomCoord &coords) const;
+class SweptElementData : public SequenceData
+private:
+    //! parameter min/max/stride, in homogeneous coords ijkh
+  HomCoord elementParams[3];
+    //! difference between max and min params plus one (i.e. # VERTICES in
+    //! each parametric direction)
+  int dIJK[3];
+    //! difference between max and min params (i.e. # ELEMENTS in
+  int dIJKm1[3];
+    //! bare constructor, so compiler doesn't create one for me
+  SweptElementData();
+    //! list of bounding vertex blocks
+  std::vector<VertexDataRef> vertexSeqRefs;
+public:
+    //! constructor
+  SweptElementData( MBEntityHandle start_handle,
+		  const int* Cq );
+  virtual ~SweptElementData();
+    //! get handle of vertex at homogeneous coords
+  inline MBEntityHandle get_vertex(const HomCoord &coords) const;
+  inline MBEntityHandle get_vertex(int i, int j, int k) const
+    { return get_vertex(HomCoord(i,j,k)); }
+    //! get handle of element at i, j, k
+  MBEntityHandle get_element(const int i, const int j, const int k) const;
+    //! get min params for this element
+  const HomCoord &min_params() const;
+    //! get max params for this element
+  const HomCoord &max_params() const;
+    //! get the number of vertices in each direction, inclusive
+  void param_extents(int &di, int &dj, int &dk) const;
+    //! given a handle, get the corresponding parameters
+  MBErrorCode get_params(const MBEntityHandle ehandle,
+                          int &i, int &j, int &k) const;
+    //! convenience functions for parameter extents
+  int i_min() const {return (elementParams[0].hom_coord())[0];}
+  int j_min() const {return (elementParams[0].hom_coord())[1];}
+  int k_min() const {return (elementParams[0].hom_coord())[2];}
+  int i_max() const {return (elementParams[1].hom_coord())[0];}
+  int j_max() const {return (elementParams[1].hom_coord())[1];}
+  int k_max() const {return (elementParams[1].hom_coord())[2];}
+    //! test the bounding vertex sequences and determine whether they fully
+    //! define the vertices covering this element block's parameter space
+  bool boundary_complete() const;
+    //! test whether this sequence contains these parameters
+  inline bool contains(const HomCoord &coords) const;
+    //! get connectivity of an entity given entity's parameters
+  inline MBErrorCode get_params_connectivity(const int i, const int j, const int k,
+                                       std::vector<MBEntityHandle>& connectivity) const;
+    //! add a vertex seq ref to this element sequence;
+    //! if bb_input is true, bounding box (in eseq-local coords) of vseq being added
+    //! is input in bb_min and bb_max (allows partial sharing of vseq rather than the whole
+    //! vseq); if it's false, the whole vseq is referenced and the eseq-local coordinates
+    //! is computed from the transformed bounding box of the vseq
+  MBErrorCode add_vsequence(SweptVertexData *vseq,
+                             const HomCoord &p1, const HomCoord &q1,
+                             const HomCoord &p2, const HomCoord &q2,
+                             const HomCoord &p3, const HomCoord &q3,
+                             bool bb_input = false,
+                             const HomCoord &bb_min = HomCoord::unitv[0],
+                             const HomCoord &bb_max = HomCoord::unitv[0]);
+  SequenceData* subset( MBEntityHandle start,
+                        MBEntityHandle end,
+                        const int* sequence_data_sizes,
+                        const int* tag_data_sizes ) const;
+  static MBEntityID calc_num_entities( MBEntityHandle start_handle,
+                                       int irange,
+                                       int jrange,
+                                       int krange );
+  unsigned long get_memory_use() const;
+inline MBEntityHandle SweptElementData::get_element(const int i, const int j, const int k) const
+  return start_handle() + (i-i_min()) + (j-j_min())*dIJKm1[0] + (k-k_min())*dIJKm1[0]*dIJKm1[1];
+inline const HomCoord &SweptElementData::min_params() const
+  return elementParams[0];
+inline const HomCoord &SweptElementData::max_params() const
+  return elementParams[1];
+inline void SweptElementData::param_extents(int &di, int &dj, int &dk) const
+  di = dIJK[0];
+  dj = dIJK[1];
+  dk = dIJK[2];
+inline MBErrorCode SweptElementData::get_params(const MBEntityHandle ehandle,
+  if (TYPE_FROM_HANDLE(ehandle) != TYPE_FROM_HANDLE(start_handle())) return MB_FAILURE;
+  int hdiff = ehandle - start_handle();
+    // use double ?: test below because on some platforms, both sides of the : are
+    // evaluated, and if dIJKm1[1] is zero, that'll generate a divide-by-zero
+  k = (dIJKm1[1] > 0 ? hdiff / (dIJKm1[1] > 0 ? dIJKm1[0]*dIJKm1[1] : 1) : 0);
+  j = (hdiff - (k*dIJKm1[0]*dIJKm1[1])) / dIJKm1[0];
+  i = hdiff % dIJKm1[0];
+  k += elementParams[0].k();
+  j += elementParams[0].j();
+  i += elementParams[0].i();
+  return (ehandle >= start_handle() &&
+          ehandle < start_handle()+size() &&
+          i >= i_min() && i <= i_max() &&
+          j >= j_min() && j <= j_max() &&
+          k >= k_min() && k <= k_max()) ? MB_SUCCESS : MB_FAILURE;
+inline bool SweptElementData::contains(const HomCoord &temp) const
+    // upper bound is < instead of <= because element params max is one less
+    // than vertex params max
+  return (temp >= elementParams[0] && temp < elementParams[1]);
+inline bool VertexDataRef::contains(const HomCoord &coords) const
+  return (minmax[0] <= coords && minmax[1] >= coords);
+inline VertexDataRef::VertexDataRef(const HomCoord &this_min, const HomCoord &this_max,
+    : xform(tmp_xform), invXform(tmp_xform.inverse()), srcSeq(this_seq)
+  minmax[0] = HomCoord(this_min);
+  minmax[1] = HomCoord(this_max);
+inline MBEntityHandle SweptElementData::get_vertex(const HomCoord &coords) const
+  assert(boundary_complete());
+   for (std::vector<VertexDataRef>::const_iterator it = vertexSeqRefs.begin();
+        it != vertexSeqRefs.end(); it++) {
+     if ((*it).minmax[0] <= coords && (*it).minmax[1] >= coords) {
+         // first get the vertex block-local parameters
+       HomCoord local_coords = coords / (*it).xform;
+      // now get the vertex handle for those coords
+       return (*it).srcSeq->get_vertex(local_coords);
+     // got here, it's an error
+   return 0;
+inline MBErrorCode SweptElementData::add_vsequence(SweptVertexData *vseq,
+                                                 bool bb_input,
+                                                 const HomCoord &bb_min,
+                                                 const HomCoord &bb_max)
+    // compute the transform given the vseq-local parameters and the mapping to
+    // this element sequence's parameters passed in minmax
+  HomXform M;
+  M.three_pt_xform(p1, q1, p2, q2, p3, q3);
+    // min and max in element seq's parameter system may not be same as those in
+    // vseq's system, so need to take min/max
+  if (bb_input) {
+    minmax[0] = bb_min;
+    minmax[1] = bb_max;
+  else {
+    minmax[0] = vseq->min_params() * M;
+    minmax[1] = vseq->max_params() * M;
+    // check against other vseq's to make sure they don't overlap
+  for (std::vector<VertexDataRef>::const_iterator vsit = vertexSeqRefs.begin();
+       vsit != vertexSeqRefs.end(); vsit++)
+    if ((*vsit).contains(minmax[0]) || (*vsit).contains(minmax[1]))
+      return MB_FAILURE;
+  HomCoord tmp_min(std::min(minmax[0].i(), minmax[1].i()),
+                   std::min(minmax[0].j(), minmax[1].j()),
+                   std::min(minmax[0].k(), minmax[1].k()));
+  HomCoord tmp_max(std::max(minmax[0].i(), minmax[1].i()),
+                   std::max(minmax[0].j(), minmax[1].j()),
+                   std::max(minmax[0].k(), minmax[1].k()));
+    // set up a new vertex sequence reference
+  VertexDataRef tmp_seq_ref(tmp_min, tmp_max, M, vseq);
+    // add to the list
+  vertexSeqRefs.push_back(tmp_seq_ref);
+  return MB_SUCCESS;
+inline MBErrorCode SweptElementData::get_params_connectivity(const int i, const int j, const int k,
+  if (contains(HomCoord(i, j, k)) == false) return MB_FAILURE;
+  connectivity.push_back(get_vertex(i, j, k));
+  connectivity.push_back(get_vertex(i+1, j, k));
+  if (MBCN::Dimension(TYPE_FROM_HANDLE(start_handle())) < 2) return MB_SUCCESS;
+  connectivity.push_back(get_vertex(i+1, j+1, k));
+  connectivity.push_back(get_vertex(i, j+1, k));
+  if (MBCN::Dimension(TYPE_FROM_HANDLE(start_handle())) < 3) return MB_SUCCESS;
+  connectivity.push_back(get_vertex(i, j, k+1));
+  connectivity.push_back(get_vertex(i+1, j, k+1));
+  connectivity.push_back(get_vertex(i+1, j+1, k+1));
+  connectivity.push_back(get_vertex(i, j+1, k+1));
+#endif
Modified: MOAB/trunk/SweptElementSeq.cpp
--- MOAB/trunk/SweptElementSeq.cpp	2009-04-14 21:13:40 UTC (rev 2818)
+++ MOAB/trunk/SweptElementSeq.cpp	2009-04-15 00:57:28 UTC (rev 2819)
@@ -14,8 +14,8 @@
 #include "SweptElementSeq.hpp"
-#include "ScdVertexData.hpp"
-#include "ScdElementData.hpp"
 #include "MBCN.hpp"
@@ -31,9 +31,10 @@
                                                         jmax-jmin,
                                                         kmax-kmin ),
                      MBCN::VerticesPerEntity(TYPE_FROM_HANDLE(start_handle)),
-                     new ScdElementData( start_handle,
-                                        imin, jmin, kmin,
-                                        imax, jmax, kmax ) )
+                     new SweptElementData( start_handle,
+					   imin, jmin, kmin,
+					   imax, jmax, kmax,
+					   Cq ) )
Added: MOAB/trunk/SweptVertexData.cpp
--- MOAB/trunk/SweptVertexData.cpp	                        (rev 0)
+++ MOAB/trunk/SweptVertexData.cpp	2009-04-15 00:57:28 UTC (rev 2819)
@@ -0,0 +1,49 @@
+    //! constructor
+SweptVertexData::SweptVertexData(const MBEntityHandle start_vertex,
+                             const int imax, const int jmax, const int kmax)
+    : SequenceData( 3, start_vertex,
+                   start_vertex + (imax-imin+1)*(jmax-jmin+1)*(kmax-kmin+1) - 1 )
+  vertexParams[0] = HomCoord(imin, jmin, kmin);
+  vertexParams[1] = HomCoord(imax, jmax, kmax);
+  vertexParams[2] = HomCoord(1,1,1);
+  dIJK[0] = imax-imin+1; dIJK[1] = jmax-jmin+1; dIJK[2] = kmax-kmin+1;
+  dIJKm1[0] = dIJK[0]-1;
+  dIJKm1[1] = dIJK[1]-1;
+  dIJKm1[2] = dIJK[2]-1;
+  create_sequence_data( 0, sizeof(double) );
+  create_sequence_data( 1, sizeof(double) );
+  create_sequence_data( 2, sizeof(double) );
+SequenceData* SweptVertexData::subset( MBEntityHandle /*start*/,
+  return 0;
Property changes on: MOAB/trunk/SweptVertexData.cpp
   + text/plain
   + native
Added: MOAB/trunk/SweptVertexData.hpp
--- MOAB/trunk/SweptVertexData.hpp	                        (rev 0)
+++ MOAB/trunk/SweptVertexData.hpp	2009-04-15 00:57:28 UTC (rev 2819)
@@ -0,0 +1,176 @@
+#ifndef SWEPT_VERTEX_DATA_HPP
+#define SWEPT_VERTEX_DATA_HPP
+// Class: SweptVertexData
+// Purpose: represent a rectangular vertex block of mesh
+// A SweptVertex represents a rectangular vertex block of mesh, including both vertices and
+// the parametric space used to address those vertices.
+class SweptVertexData : public SequenceData
+private:
+    //! parameter min/max, in homogeneous coords ijkh (extra row for stride eventually)
+  HomCoord vertexParams[3];
+  int dIJK[3];
+    //! difference between max and min params (i.e. # VERTEXS in
+  int dIJKm1[3];
+public:
+    //! constructor
+  SweptVertexData(const MBEntityHandle start_vertex,
+                const int imax, const int jmax, const int kmax) ;
+  virtual ~SweptVertexData() {};
+    //! get handle of vertex at i, j, k
+  MBEntityHandle get_vertex(const int i, const int j, const int k) const;
+    //! get handle of vertex at homogeneous coordinates
+  MBEntityHandle get_vertex(const HomCoord &coords) const;
+    //! get the parameters of a given handle; return MB_FAILURE if vhandle not in this
+    //! sequence
+  MBErrorCode get_params(const MBEntityHandle vhandle,
+    //! get min params for this vertex
+  void min_params(int &i, int &j, int &k) const;
+    //! get max params for this vertex
+  void max_params(int &i, int &j, int &k) const;
+    //! get the min params
+    //! get the max params
+  int i_min() const {return vertexParams[0].hom_coord()[0];}
+  int j_min() const {return vertexParams[0].hom_coord()[1];}
+  int k_min() const {return vertexParams[0].hom_coord()[2];}
+  int i_max() const {return vertexParams[1].hom_coord()[0];}
+  int j_max() const {return vertexParams[1].hom_coord()[1];}
+  int k_max() const {return vertexParams[1].hom_coord()[2];}
+    //! return whether this vseq's parameter space contains these parameters
+  bool contains(const int i, const int j, const int k) const;
+inline MBEntityHandle SweptVertexData::get_vertex(const int i, const int j,
+                                                const int k) const
+  return start_handle() + (i-i_min()) + (j-j_min())*dIJK[0] +
+    (k-k_min())*dIJK[0]*dIJK[1];
+inline MBEntityHandle SweptVertexData::get_vertex(const HomCoord &coords) const
+  return get_vertex(coords.hom_coord()[0], coords.hom_coord()[1], coords.hom_coord()[2]);
+inline MBErrorCode SweptVertexData::get_params(const MBEntityHandle vhandle,
+  if (TYPE_FROM_HANDLE(vhandle) != MBVERTEX) return MB_FAILURE;
+  int hdiff = vhandle - start_handle();
+  k = hdiff / (dIJK[0]*dIJK[1]);
+  j = (hdiff - (k*dIJK[0]*dIJK[1])) / dIJK[0];
+  i = hdiff % dIJK[0];
+  k += vertexParams[0].k();
+  j += vertexParams[0].j();
+  i += vertexParams[0].i();
+  return (vhandle >= start_handle() &&
+inline void SweptVertexData::min_params(int &i, int &j, int &k) const
+  i = i_min();
+  j = j_min();
+  k = k_min();
+//! get max params for this vertex
+inline void SweptVertexData::max_params(int &i, int &j, int &k) const
+  i = i_max();
+  j = j_max();
+  k = k_max();
+inline const HomCoord &SweptVertexData::min_params() const
+  return vertexParams[0];
+inline const HomCoord &SweptVertexData::max_params() const
+  return vertexParams[1];
+inline void SweptVertexData::param_extents(int &di, int &dj, int &dk) const
+  di = dIJK[0];
+  dj = dIJK[1];
+  dk = dIJK[2];
+inline bool SweptVertexData::contains(const HomCoord &coords) const
+  return (coords >= vertexParams[0] && coords <= vertexParams[1]) ? true : false;
+inline bool SweptVertexData::contains(const int i, const int j, const int k) const
+  return contains(HomCoord(i, j, k));
+#endif
