[MOAB-dev] r2748 - MOAB/trunk/tools/iMesh
kraftche at cae.wisc.edu
Wed Mar 25 15:11:00 CDT 2009
Author: kraftche
Date: 2009-03-25 15:11:00 -0500 (Wed, 25 Mar 2009)
New Revision: 2748
Modified:
MOAB/trunk/tools/iMesh/iMesh.h
MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
Log:
change to iterator end semantics
Modified: MOAB/trunk/tools/iMesh/iMesh.h
--- MOAB/trunk/tools/iMesh/iMesh.h 2009-03-25 19:06:23 UTC (rev 2747)
+++ MOAB/trunk/tools/iMesh/iMesh.h 2009-03-25 20:11:00 UTC (rev 2748)
@@ -431,8 +431,8 @@
* entity_handles array
* \param *entity_handles_size Pointer to occupied size of entity_handles
* array
- * \param has_data Pointer to flag; if returned non-zero, next iterator
- * has a non-zero number of entities
+ * \param has_data Pointer to flag; zero if no entities returned
+ * because iterator is at end, one otherwize.
* \param *err Pointer to error type returned from function
void iMesh_getNextEntArrIter(iMesh_Instance instance,
@@ -1810,8 +1810,8 @@
* \param entity_iterator Iterator being queried
* \param entity_handle Pointer to an entity handle corresponding to the
* current value of iterator
- * has an entity
+ * \param has_data Pointer to flag; if non-zero, value returned in
+ * entity_handle is valid. Otherwise, the iteration as at the end.
void iMesh_getNextEntIter(iMesh_Instance instance,
Modified: MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp 2009-03-25 19:06:23 UTC (rev 2747)
+++ MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp 2009-03-25 20:11:00 UTC (rev 2748)
@@ -583,7 +583,7 @@
++(this_it->currentPos);
- *has_data = (this_it->currentPos != this_it->iteratorRange.end());
+ *has_data = !i;
*entity_handles_size = i;
RETURN(iBase_SUCCESS);
