[MOAB-dev] r2732 - MOAB/trunk/parallel
    kraftche at cae.wisc.edu
    Fri Mar 20 09:53:31 CDT 2009
Author: kraftche
Date: 2009-03-20 09:53:30 -0500 (Fri, 20 Mar 2009)
New Revision: 2732
Added:
   MOAB/trunk/parallel/parallel_write_test.cc
Modified:
   MOAB/trunk/parallel/Makefile.am
Log:
test code for timing parallel writer
Modified: MOAB/trunk/parallel/Makefile.am
--- MOAB/trunk/parallel/Makefile.am	2009-03-19 21:26:02 UTC (rev 2731)
+++ MOAB/trunk/parallel/Makefile.am	2009-03-20 14:53:30 UTC (rev 2732)
@@ -51,7 +51,7 @@
   MOAB_PARALLEL_SRCS += WriteHDF5Parallel.cpp
   MOAB_PARALLEL_HDRS += WriteHDF5Parallel.hpp
-  MOAB_PARALLEL_TEST += parallel_hdf5_test mhdf_parallel
+  MOAB_PARALLEL_TEST += parallel_hdf5_test mhdf_parallel parallel_write_test
 endif
   MOAB_PARALLEL_CHECK += mbparallelcomm_test
@@ -82,7 +82,10 @@
 mhdf_parallel_LDADD = ../mhdf/libmhdf.la
 parallel_unit_tests_SOURCES = parallel_unit_tests.cpp
 parallel_unit_tests_LDADD = ../libMOAB.la
+parallel_write_test_SOURCES = parallel_write_test.cc
+parallel_write_test_LDADD = ../libMOAB.la
 # Other files to clean up (e.g. output from tests)
 MOSTLYCLEANFILES = mhdf_ll.h5m
Added: MOAB/trunk/parallel/parallel_write_test.cc
--- MOAB/trunk/parallel/parallel_write_test.cc	                        (rev 0)
+++ MOAB/trunk/parallel/parallel_write_test.cc	2009-03-20 14:53:30 UTC (rev 2732)
@@ -0,0 +1,331 @@
+#include "MBCore.hpp"
+#include "MBParallelComm.hpp"
+#include "MBTagConventions.hpp"
+#include <mpi.h>
+#include <stdlib.h>
+#include <iostream>
+#include <time.h>
+#include <string.h>
+#include <math.h>
+#include <assert.h>
+const int DEFAULT_INTERVALS  = 2;
+const char* DEFAULT_FILE_NAME = "paralle_write_test.h5m";
+// Create mesh for each processor that is a cube of hexes
+// with the specified interval count along each edge.  Cubes
+// of mesh will be positioned and vertex IDs assigned such that
+// there are shared entities.  If the cubic root of the number
+// of processors is a whole number, then each processors mesh
+// will be a cube in a grid with that number of processor blocks
+// along each edge.  Otherwise processor blocks will be arranged
+// within the subset of the grid that is the ceiling of the cubic
+// root of the comm size such that there are no disjoint regions.
+MBErrorCode generate_mesh( MBInterface& moab, int intervals );
+const char args[] = "[-i <intervals>] [-o <filename>] [-g <filename>]";
+void help() {
+  std::cout << "parallel_write_test " << args << std::endl
+            << "-i <N>    Each processor owns an NxNxN cube of hex elements (default: " << DEFAULT_INTERVALS << ")" << std::endl
+            << "-o <name> Retain output file and name it as specified." << std::endl
+            << "-g <name> Write local mesh to file name prefixed with MPI rank" << std::endl
+            << std::endl;
+int main( int argc, char* argv[] )
+  int ierr = MPI_Init( &argc, &argv );
+  if (ierr) {
+    std::cerr << "MPI_Init failed with error code: " << ierr << std::endl;
+    return ierr;
+  int rank;
+  ierr = MPI_Comm_rank( MPI_COMM_WORLD, &rank );
+  if (ierr) {
+    std::cerr << "MPI_Comm_rank failed with error code: " << ierr << std::endl;
+    return ierr;
+  int size;
+  ierr = MPI_Comm_size( MPI_COMM_WORLD, &size );
+  if (ierr) {
+    std::cerr << "MPI_Comm_size failed with error code: " << ierr << std::endl;
+    return ierr;
+    // settings controlled by CL flags
+  const char* output_file_name = 0;
+  const char* indiv_file_name = 0;
+  int intervals = 0;
+    // state for CL flag processing
+  bool expect_intervals = false;
+  bool expect_file_name = false;
+  bool expect_indiv_file = false;
+    // process CL args
+  for (int i = 1; i < argc; ++i) {
+    if (expect_intervals) {
+      char* endptr = 0;
+      intervals = (int)strtol( argv[i], &endptr, 0 );
+      if (*endptr || intervals < 1) {
+        std::cerr << "Invalid block interval value: " << argv[i] << std::endl;
+        return 1;
+      expect_intervals = false;
+    else if (expect_indiv_file) {
+      indiv_file_name = argv[i];
+      expect_indiv_file = false;
+    else if (expect_file_name) {
+      output_file_name = argv[i];
+      expect_file_name = false;
+    else if (!strcmp( "-i", argv[i]))
+      expect_intervals = true;
+    else if (!strcmp( "-o", argv[i]))
+      expect_file_name = true;
+    else if (!strcmp( "-g", argv[i]))
+      expect_indiv_file = true;
+    else if (!strcmp( "-h", argv[i])) {
+      help();
+      return 0;
+    else {
+      std::cerr << "Unexpected argument: " << argv[i] << std::endl
+                << "Usage: " << argv[0] << " " << args << std::endl
+                << "       " << argv[0] << " -h" << std::endl
+                << " Try '-h' for help." << std::endl;
+      return 1;
+    // Check for missing argument after last CL flag
+  if (expect_file_name || expect_intervals || expect_indiv_file) {
+    std::cerr << "Missing argument for '" << argv[argc-1] << "'" << std::endl;
+    return 1;
+    // If intervals weren't specified, use default
+  if (intervals == 0) {
+    std::cout << "Using default interval count: " << DEFAULT_INTERVALS << std::endl;
+    intervals = DEFAULT_INTERVALS;
+    // If no output file was specified, use default one and note that
+    // we need to delete it when the test completes.
+  bool keep_output_file = true;
+  if (!output_file_name) {
+    output_file_name = DEFAULT_FILE_NAME;
+    keep_output_file = false;
+    // Create mesh
+  MBCore mb;
+  MBInterface& moab = mb;
+  MBErrorCode rval = generate_mesh( moab, intervals );
+  if (MB_SUCCESS != rval) {
+    std::cerr << "Mesh creation failed with error code: " << rval << std::endl;
+    return (int)rval;
+    // Write out local mesh on each processor if requested.
+  if (indiv_file_name) {
+    char buffer[64];
+    int width = (int)ceil( log10( size ) );
+    sprintf(buffer,"%0*d-", width, rank );
+    std::string name(buffer);
+    name += indiv_file_name;
+    rval = moab.write_file( name.c_str() );
+      std::cerr << "Failed to write file: " << name << std::endl;
+      return (int)rval;
+    // Negotiate shared entities using vertex global IDs
+  MBRange hexes;
+  moab.get_entities_by_type( 0, MBHEX, hexes );
+  MBParallelComm* pcomm = new MBParallelComm( &moab );
+  rval = pcomm->resolve_shared_ents( 0, hexes, 3, 0 );
+    std::cerr << "MBParallelComm::resolve_shared_ents failed" << std::endl;
+    return rval;
+    // Do parallel write
+  clock_t t = clock();
+  rval = moab.write_file( output_file_name, "MOAB", "PARALLEL=FORMAT" );
+  t = clock() - t;
+    std::cerr << "File creation failed with error code: " << rval << std::endl;
+    return (int)rval;
+    // Clean up and summarize
+  if (0 == rank) {
+    double sec = (double)t / CLOCKS_PER_SEC;
+    std::cout << "Wrote " << hexes.size()*size << " hexes in " << sec << " seconds." << std::endl;
+    if (!keep_output_file)
+      remove( output_file_name );
+  return MPI_Finalize();
+#define IDX(i,j,k) ((num_interval+1)*((num_interval+1)*(k) + (j)) + (i))
+MBErrorCode generate_mesh( MBInterface& moab, int num_interval )
+  int rank, size;
+  MPI_Comm_rank( MPI_COMM_WORLD, &rank );
+  MPI_Comm_size( MPI_COMM_WORLD, &size );
+  MBErrorCode rval;
+  MBTag global_id;
+  rval = moab.tag_get_handle( GLOBAL_ID_TAG_NAME, global_id );
+    return rval;
+    // Each processor will own one cube of mesh within
+    // an 3D grid of cubes.  Calculate the dimensions of
+    // that grid in numbers of cubes.
+  int root = 1;
+  while (root*root*root < size)
+    ++root;
+  int num_x_blocks = root;
+  int num_y_blocks = root-1;
+  int num_z_blocks = root-1;
+  if (num_x_blocks * num_y_blocks * num_z_blocks < size)
+    ++num_y_blocks;
+    ++num_z_blocks;
+    // calculate position of this processor in grid
+  int my_z_block = rank / (num_x_blocks * num_y_blocks);
+  int rem = rank % (num_x_blocks * num_y_blocks);
+  int my_y_block = rem / num_x_blocks;
+  int my_x_block = rem % num_x_blocks;
+    // Each processor's cube of mesh will be num_iterval^3 elements
+    // and will be 1.0 units on a side
+    // create vertices
+  const int num_x_vtx = num_interval * num_x_blocks + 1;
+  const int num_y_vtx = num_interval * num_y_blocks + 1;
+  const int x_offset = my_x_block * num_interval;
+  const int y_offset = my_y_block * num_interval;
+  const int z_offset = my_z_block * num_interval;
+  double step = 1.0 / num_interval;
+  std::vector<MBEntityHandle> vertices( (num_interval+1)*(num_interval+1)*(num_interval+1) );
+  std::vector<MBEntityHandle>::iterator v = vertices.begin();
+  for (int k = 0; k <= num_interval; ++k) {
+    for (int j = 0; j <= num_interval; ++j) {
+      for (int i = 0; i <= num_interval; ++i) {
+        double coords[] = { my_x_block + i*step,
+                            my_y_block + j*step,
+                            my_z_block + k*step };
+        MBEntityHandle h;
+        rval = moab.create_vertex( coords, h );
+          return rval;
+        int id = 1 +  x_offset + i
+                   + (y_offset + j) * num_x_vtx
+                   + (z_offset + k) * num_x_vtx * num_y_vtx;
+        rval = moab.tag_set_data( global_id, &h, 1, &id );
+          return rval;
+        *v++ = h;
+    // create hexes
+  for (int k = 0; k < num_interval; ++k) {
+    for (int j = 0; j < num_interval; ++j) {
+      for (int i = 0; i < num_interval; ++i) {
+        assert( IDX(i+1,j+1,k+1) < (int)vertices.size() );
+        const MBEntityHandle conn[] = { vertices[IDX(i,  j,  k  )],
+                                        vertices[IDX(i+1,j,  k  )],
+                                        vertices[IDX(i+1,j+1,k  )],
+                                        vertices[IDX(i,  j+1,k  )],
+                                        vertices[IDX(i,  j,  k+1)],
+                                        vertices[IDX(i+1,j,  k+1)],
+                                        vertices[IDX(i+1,j+1,k+1)],
+                                        vertices[IDX(i,  j+1,k+1)] };
+        MBEntityHandle elem;
+        rval = moab.create_element( MBHEX, conn, 8, elem );
+          return rval;
+    // create interface quads
+      MBEntityHandle h;
+      const MBEntityHandle conn1[] = { vertices[IDX(i,  j,  0)],
+                                       vertices[IDX(i+1,j,  0)],
+                                       vertices[IDX(i+1,j+1,0)],
+                                       vertices[IDX(i,  j+1,0)] };
+      rval = moab.create_element( MBQUAD, conn1, 4, h );
+        return rval;
+      const MBEntityHandle conn2[] = { vertices[IDX(i,  j,  num_interval)],
+                                       vertices[IDX(i+1,j,  num_interval)],
+                                       vertices[IDX(i+1,j+1,num_interval)],
+                                       vertices[IDX(i,  j+1,num_interval)] };
+      rval = moab.create_element( MBQUAD, conn2, 4, h );
+        return rval;
+      MBEntityHandle h;
+      const MBEntityHandle conn1[] = { vertices[IDX(i,  0,k  )],
+                                       vertices[IDX(i+1,0,k  )],
+                                       vertices[IDX(i+1,0,k+1)],
+                                       vertices[IDX(i,  0,k+1)] };
+        return rval;
+      const MBEntityHandle conn2[] = { vertices[IDX(i,  num_interval,k  )],
+                                       vertices[IDX(i+1,num_interval,k  )],
+                                       vertices[IDX(i+1,num_interval,k+1)],
+                                       vertices[IDX(i,  num_interval,k+1)] };
+        return rval;
+      MBEntityHandle h;
+      const MBEntityHandle conn1[] = { vertices[IDX(0,j,  k  )],
+                                       vertices[IDX(0,j+1,k  )],
+                                       vertices[IDX(0,j+1,k+1)],
+                                       vertices[IDX(0,j,  k+1)] };
+        return rval;
+      const MBEntityHandle conn2[] = { vertices[IDX(num_interval,j,  k  )],
+                                       vertices[IDX(num_interval,j+1,k  )],
+                                       vertices[IDX(num_interval,j+1,k+1)],
+                                       vertices[IDX(num_interval,j,  k+1)] };
+        return rval;
+  return MB_SUCCESS;
