[MOAB-dev] r2731 - MOAB/trunk
kraftche at cae.wisc.edu
Thu Mar 19 16:26:02 CDT 2009
Author: kraftche
Date: 2009-03-19 16:26:02 -0500 (Thu, 19 Mar 2009)
New Revision: 2731
Modified:
MOAB/trunk/WriteVtk.cpp
MOAB/trunk/WriteVtk.hpp
Log:
o Fix bug: WriteVtk stops (and doesn't write) global ID
o Fix bug: WriteVtk doesn't correctly handle MOAB geometric dimension < 3
o reduce memory requirements for WriteVtk
Modified: MOAB/trunk/WriteVtk.cpp
--- MOAB/trunk/WriteVtk.cpp 2009-03-19 19:56:43 UTC (rev 2730)
+++ MOAB/trunk/WriteVtk.cpp 2009-03-19 21:26:02 UTC (rev 2731)
@@ -52,21 +52,13 @@
{ return new WriteVtk( iface ); }
WriteVtk::WriteVtk(MBInterface *impl)
- : mbImpl(impl), writeTool(0), globalId(0), mStrict(DEFAULT_STRICT)
+ : mbImpl(impl), writeTool(0), mStrict(DEFAULT_STRICT)
assert(impl != NULL);
void* ptr = 0;
impl->query_interface( "MBWriteUtilIface", &ptr );
writeTool = reinterpret_cast<MBWriteUtilIface*>(ptr);
- MBErrorCode result = impl->tag_get_handle(GLOBAL_ID_TAG_NAME, globalId);
- if (MB_TAG_NOT_FOUND == result)
- result = impl->tag_create( GLOBAL_ID_TAG_NAME,
- sizeof(int),
- MB_TAG_SPARSE,
- MB_TYPE_INTEGER,
- globalId, 0 );
WriteVtk::~WriteVtk()
@@ -122,7 +114,7 @@
// Write file
if ((rval = write_header(file )) != MB_SUCCESS ||
(rval = write_nodes( file, nodes )) != MB_SUCCESS ||
- (rval = write_elems( file, elems )) != MB_SUCCESS ||
+ (rval = write_elems( file, nodes, elems)) != MB_SUCCESS ||
(rval = write_tags ( file, true, nodes)) != MB_SUCCESS ||
(rval = write_tags ( file, false, elems)) != MB_SUCCESS)
@@ -232,30 +224,23 @@
MBErrorCode rval;
- // Allocate storage for node coordinates
- const unsigned long n = nodes.size();
- std::vector<double> coord_mem( 3*n );
- double* x = &coord_mem[0];
- double* y = &coord_mem[n];
- double* z = &coord_mem[2*n];
- std::vector<double*> coord_arrays(3);
- coord_arrays[0] = x;
- coord_arrays[1] = y;
- coord_arrays[2] = z;
- // Get node coordinates
- rval = writeTool->get_node_arrays( 3, n, nodes, globalId, 0, coord_arrays );
- if (MB_SUCCESS != rval)
- return MB_FAILURE;
stream << "POINTS " << nodes.size() << " double" << std::endl;
- for (unsigned long i = 0; i < n; ++i, ++x, ++y, ++z )
- stream << *x << ' ' << *y << ' ' << *z << std::endl;
+ double coords[3];
+ for (MBRange::const_iterator i = nodes.begin(); i != nodes.end(); ++i) {
+ coords[1] = coords[2] = 0.0;
+ rval = mbImpl->get_coords( &*i, 1, coords );
+ if (MB_SUCCESS != rval)
+ return rval;
+ stream << coords[0] << ' ' << coords[1] << ' ' <<coords[2] << std::endl;
return MB_SUCCESS;
-MBErrorCode WriteVtk::write_elems( std::ostream& stream, const MBRange& elems )
+MBErrorCode WriteVtk::write_elems( std::ostream& stream,
+ const MBRange& nodes,
+ const MBRange& elems )
MBErrorCode rval;
@@ -302,11 +287,9 @@
// Get IDs from vertex handles
assert( conn_len > 0 );
- if (conn_data.size() < (unsigned)conn_len)
- conn_data.resize( conn_len );
- rval = mbImpl->tag_get_data( globalId, conn, conn_len, &conn_data[0] );
- return rval;
+ conn_data.resize( conn_len );
+ for (int j = 0; j < conn_len; ++j)
+ conn_data[j] = nodes.index( conn[j] );
// Save VTK type index for later
*t = vtk_type->vtk_type;
@@ -366,11 +349,6 @@
bool entities_have_tags = false;
for (std::vector<MBTag>::iterator i = tags.begin(); i != tags.end(); ++i)
- // Skip this tag because we created this data as part of writing
- // the mesh.
- if (*i == globalId)
- continue;
// Skip tags holding entity handles -- no way to save them
MBDataType type;
rval = mbImpl->tag_get_data_type( *i, type );
Modified: MOAB/trunk/WriteVtk.hpp
--- MOAB/trunk/WriteVtk.hpp 2009-03-19 19:56:43 UTC (rev 2730)
+++ MOAB/trunk/WriteVtk.hpp 2009-03-19 21:26:02 UTC (rev 2731)
@@ -62,7 +62,7 @@
MBErrorCode write_nodes( std::ostream& stream, const MBRange& nodes );
//! Write element connectivity
- MBErrorCode write_elems( std::ostream& stream, const MBRange& elems );
+ MBErrorCode write_elems( std::ostream& stream, const MBRange& nodes, const MBRange& elems );
//! Write all tags on either the list of nodes or the list of elements
MBErrorCode write_tags( std::ostream& stream, bool nodes, const MBRange& entities );
@@ -83,8 +83,7 @@
MBInterface* mbImpl;
MBWriteUtilIface* writeTool;
- MBTag globalId;
bool mStrict; // If true, do not write data that cannot fit in strict VTK file format.
